Jump to content
DjMaxx
Коды ошибок
Recommended Posts
//EGS 4.XX E34 Gasoline Eng
0x02050001 1 P/N shift-lock
0x02050002 2 Program select
0x02050004 4 engine intervention
0x02050009 9 KVA signal
0x0205000b 11 speed signal n-mot
0x02050014 20 speed signal n-ab
0x02050016 22 ATF temp. sensor
0x02050017 23 selector lever pos.
0x0205001c 28 battery voltage
0x0205001e 30 kickdown switch
0x02050033 35 brake-light switch
0x02050025 37 voltage supply
0x02050026 38 solenoid valve torque converter cluth
0x02050027 39 brake-light switch
0x02050028 40 pressure regulator
0x0205002b 43 solenoid valve 2]
0x0205002d 45 solenoid valve,brake band
0x02050030 48 solenoid valve 1
0x02050036 54 ground solenoid valve
0x02050037 55 throttle-valve signal
0x02050064 100 gear monitoring
0x02050065 101 downshift protection
0x02050066 102 overrun protection
0x02050067 103 eprom checksum
0x02050068 104 DKT engine temp.info
0x02050069 105 DKT throttle-valve info
0x0205006e 110 control unit has not been programmed
0x020500c8 200 no kicksown shifts
0x020500c9 201 no S-program
0x020500ca 202 no M-program
0x020500cb 203 no S-program display
0x020500cc 204 no M-program display
0x020500cd 205 no program switchover
0x020500ce 206 no engine intervention
0x020500cf 207 adoption AC defective
0x020500d0 208 defective brake-light switch
0x020500d1 209 incorrect fault display
Share this post
Link to post
Share on other sites
//Jecs 5-speed trans.\n A5S 300J(Jatco RLA)
0x02060001 1 solenoid check
0x02060002 2 solenoid valve compressor
0x02060004 4 voltage supply
0x02060006 6 solenoid valve A
0x02060007 7 solenoid valve B
0x0206000a 10 engine intervention
0x02060014 20 program buttom
0x02060017 23 voltage supply
0x02060018 24 speed signal n-mod
0x02060019 25 speed signal n-ab
0x0206001b 27 speed-A signal
0x0206001d 29 solenoid valve WK
0x02060021 33 ATF temp sensor
0x02060022 34 throttle signal(DKT)
0x02060029 41 kickdown switch
0x0206002b 43 slip solenoid valve
0x0206002c 44 R shift solenoid fuse
0x0206002e 46 solenoid valve c
0x0206002f 47 P/N shift lock
0x02060032 50 WK slip test
0x02060033 51 shift test
0x02060034 52 engine overrev
0x02060035 53 A/D converter
0x020600c8 200 no kickdown shifts
0x020600c9 201 no S-program
0x020600ca 202 no *-program
0x020600cb 203 no program switchover
0x020600cc 204 no engine intervention
0x020600cd 205 defective brake-light switch
0x020600ce 206 incorrect fault display
Share this post
Link to post
//EGS 7.32 M60B30
0x02210001 001 Pressure regulator,EDS 2
0x02210002 002 Solenoid,P/N lock
0x02210003 003 Solenoid valve 5
0x02210004 004 Solenoid valve,converter lockup clutch
0x02210005 005 Pressure regulator,EDS 1
0x02210008 008 Selector-lever position L2
0x02210009 009 Selector-lever position L4
0x0221000C 012 Program-selector switch
0x02210010 016 Rotational-speed sensor,turbocharger
0x02210012 018 Kickdown switch
0x02210013 019 ASC monitoring
0x02210016 022 ATF-sump temperature sensor
0x0221001A 026 Batt.+ supply (perm.)
0x0221001D 029 Pressure regulator,EDS 3
0x0221001E 030 Solenoid valve 1
0x0221001F 031 Solenoid valve 4
0x02210020 032 Solenoid valve 3
0x02210021 033 Solenoid valve 2
0x02210024 036 Selector-lever position L1
0x02210026 038 Wheel speed,front left
0x02210027 039 Wheel speed,front right
0x02210028 040 Wheel speed,rear left
0x02210029 041 Wheel speed,rear right
0x0221002A 042 Rotat.-sp.signal n-ab(output)
0x02210033 051 Pressure regulator,EDS 5
0x02210036 054 Batt.+ supply
0x02210064 100 Speed monitoring
0x02210065 101 Speed monitoring
0x02210066 102 Speed monitoring
0x02210067 103 Internal SG fault 1
0x02210068 104 Gearbox relay in the EGS
0x02210069 105 Engine overrevving interlock
0x0221006A 106 Stall-speed monitoring
0x0221006B 107 Wheel speeds
0x0221006C 108 No programming
0x0221006D 109 Internal SG fault 2
0x0221006E 110 Internal SG fault 3
0x02210096 150 CAN bus monitoring
0x02210097 151 CAN status,fault
0x02210098 152 CAN engine intervention
0x02210099 153 CAN DME load signal
0x0221009A 154 CAN throttle-valve position
0x0221009B 155 CAN DME engine temperature
0x0221009C 156 CAN timeout 1(ignition ON)
0x0221009D 157 CAN timeout 2(operating)
0x0221009E 158 CAN throttle-valve and load signals
Share this post
Link to post
//EGS 8.60.0
0x02220001 001 Pressure actuator 1(P0748)
0x02220002 002 Pressure actuator 2(P0700,P1734)
0x02220003 003 Pressure actuator 3(P0700,P1738)
0x02220004 004 Pressure actuator 4(P0743)
0x0222001F 015 Pressure actuator,resultant current(P0700,P1748)
0x02220010 016 Solenoid valve 1(P0753)
0x02220011 017 Solenoid valve 2(P0758)
0x02220012 018 Solenoid valve 3(P0763)
0x02220013 019 Solenoid,shiftlock(P0700,P1761)
0x02220020 032 Speed signal,output(P0720)
0x02220021 033 Turbine speed sensor(P0715)
0x02220022 034 Transmission-fluid temperature sensor
0x02220030 048 Conv.lockup clutch,excessive slip(P0740)
0x02220031 049 Symptom,gear monitoring
0x02220032 050 Gear monitoring(P0731)
0x02220033 051 Gear monitoring 1M(P0731)
0x02220034 052 Gear monitoring 2(P0732)
0x02220035 053 Gear monitoring 3(P0733)
0x02220036 054 Gear monitoring 4(P0734)
0x02220037 055 Gear monitoring 5(P0735)
0x02220038 056 Symptom GLUE
0x02220039 057 GLUE monitoring 2/3(P0733)
0x0222003A 058 GLUE monitoring 3/4(P0734)
0x0222003B 059 Stall speed(P0720)
0x0222003C 060 Gearbox switch(P0705)
0x0222003D 061 Temperature monitoring,transmission
0x0222003E 062 Double fault n_ab
0x02220050 080 Control unit,internal fault 1(EPROM)(P0700,P1749)
0x02220051 081 Control unit,internal fault 2(EPROM)(P0700,P1748)
0x02220052 082 Control unit,internal fault 3(watchdog)(P0700,P1748)
0x02220053 083 Control unit,internal fault 4(FET)(P0700,P1746)
0x02220060 096 Battery voltage,supply,term.87(P0700,P1750)
0x02220061 097 Battery voltage,supply terminal 30
0x02220070 112 Program button
0x02220071 113 Kickdown switch
0x02220072 114 Steptronic switch
0x02220080 128 Monitoring CAN bus(P0700,P1747)
0x02220081 129 CAN timeout DME(P0700,P1747)
0x02220082 130 CAN timeout ASC
0x02220090 144 CAN-version erroe(P0700,P1747)
0x02220091 145 CAN torque reduction(P0700,P1750)
0x02220093 147 CAN throttle(P0700,P1765)
0x02220095 149 CAN wheel speeds
0x02220097 151 CAN brake signal
Share this post
Link to post
//EGS 8.51 M62
0x02230001 001 Pressure actuator 2
0x02230002 002 Solenoid,shift-lock
0x02230003 003 Solenoid,valve 5
0x02230004 004 Pressure actuator 4
0x02230005 005 Pressure actuator 1
0x02230008 008 Selector-lever position L2
0x02230009 009 Selector-lever position L4
0x0223000C 012 Program-selector switch
0x02230010 016 Speed sensor,turbocharger
0x02230012 018 Kickdown switch
0x02230013 019 ASC interface
0x02230016 022 ATF-sump temperature sensor
0x0223001A 026 Term.30 supply
0x0223001D 029 Pressure actuator 3
0x0223001E 030 Solenoid valve 1
0x0223001F 031 Solenoid valve 4
0x02230020 032 Solenoid valve 3
0x02230021 033 Solenoid valve 2
0x02230024 036 Selector-lever position L1
0x02230026 038 Wheel speed,front left
0x02230027 039 Wheel speed,front right
0x02230028 040 Wheel speed,rear left
0x02230029 041 Wheel speed,rear right
0x0223002A 042 Speed signal n-out(output)
0x0223002E 046 Stepper shift system
0x02230033 051 Pressure actuator 5
0x02230036 054 Batt.+supply
0x02230064 100 Gear monitoring 1(2nd-4th gear)
0x02230065 101 Gear monitoring 2(5th gear)
0x02230066 102 Speed monitoring
0x02230067 103 Control-unit-internal fault 1
0x02230068 104 Voltage supply to EDS and MV
0x02230069 105 Engine overrevving interlock
0x0223006A 106 Stall-speed monitoring
0x0223006B 107 Wheel speeds
0x0223006C 108 No programming
0x0223006D 109 Control-unit-internal fault 2
0x0223006E 110 Control-unit-internal fault 3
0x0223006F 111 Converter lockup clutch
0x0223007A 122 Gear monitoring(2nd-3rd gear)
0x0223007B 123 Gear monitoring(3rd-4th gear)
0x02230083 131 Gear monitoring 1
0x02230084 132 Gear monitoring 2
0x02230085 133 Gear monitoring 3
0x02230086 134 Gear monitoring 4
0x02230087 135 Gear monitoring 5
0x02230096 150 CAN bus monitoring
0x02230097 151 CAN version fault
0x02230098 152 CAN engine intervention
0x02230099 153 CAN DME load signal
0x0223009A 154 CAN accelerator pedal setting
0x0223009B 155 CAN engine temperature
0x0223009C 156 CAN Timeout
0x0223009D 157 CAN Timeout
0x0223009E 158 CAN throttle-valve and load signals
0x0223009F 159 CAN ABS/DSC wheel speeds
0x022300A0 160 CAN ABS/DSC signal
Share this post
Link to post
//EGS 9.22 M62/M73B54
0x02290001 001 Pressure actuator 2
0x02290002 002 Solenoid,shift-lock
0x02290003 003 Solenoid,valve 5
0x02290004 004 Pressure actuator 4
0x02290005 005 Pressure actuator 1
0x02290008 008 Selector-lever position L2
0x02290009 009 Selector-lever position L4
0x0229000C 012 Program-selector switch
0x02290010 016 Speed sensor,turbocharger
0x02290012 018 Kickdown switch
0x02290013 019 ASC interface
0x02290016 022 ATF-sump temperature sensor
0x0229001A 026 Term.30 supply
0x0229001D 029 Pressure actuator 3
0x0229001E 030 Solenoid valve 1
0x0229001F 031 Solenoid valve 4
0x02290020 032 Solenoid valve 3
0x02290021 033 Solenoid valve 2
0x02290024 036 Selector-lever position L1
0x02290026 038 Wheel speed,front left
0x02290027 039 Wheel speed,front right
0x02290028 040 Wheel speed,rear left
0x02290029 041 Wheel speed,rear right
0x0229002A 042 Speed signal n-out(output)
0x0229002E 046 Stepper shift system
0x02290033 051 Pressure actuator 5
0x02290036 054 Batt.+supply
0x02290064 100 Gear monitoring 1(2nd-4th gear)
0x02290065 101 Gear monitoring 2(5th gear)
0x02290066 102 Speed monitoring
0x02290067 103 Control-unit-internal fault 1
0x02290068 104 Voltage supply to EDS and MV
0x02290069 105 Engine overrevving interlock
0x0229006A 106 Stall-speed monitoring
0x0229006B 107 Wheel speeds
0x0229006C 108 No programming
0x0229006D 109 Control-unit-internal fault 2
0x0229006E 110 Control-unit-internal fault 3
0x0229006F 111 Converter lockup clutch
0x0229007A 122 Gear monitoring(2nd-3rd gear)
0x0229007B 123 Gear monitoring(3rd-4th gear)
0x02290083 131 Gear monitoring 1
0x02290084 132 Gear monitoring 2
0x02290085 133 Gear monitoring 3
0x02290086 134 Gear monitoring 4
0x02290087 135 Gear monitoring 5
0x02290096 150 CAN bus monitoring
0x02290097 151 CAN version fault
0x02290098 152 CAN engine intervention
0x02290099 153 CAN DME load signal
0x0229009A 154 CAN accelerator pedal setting
0x0229009B 155 CAN engine temperature
0x0229009C 156 CAN Timeout
0x0229009D 157 CAN Timeout
0x0229009E 158 CAN throttle-valve and load signals
0x0229009F 159 CAN ABS/DSC wheel speeds
0x022900A0 160 CAN ABS/DSC signal
Share this post
Link to post
//EGS 8.32 M52
0x022A0001 001 Pressure regulator,EDS 2
0x022A0002 002 Solenoid,P/N lock
0x022A0003 003 Solenoid valve 5
0x022A0004 004 Solenoid valve,converter clutch lockup
0x022A0005 005 Pressure regulator,EDS 1
0x022A0008 008 Selector-lever position L2
0x022A0009 009 Selector-lever position L4
0x022A000C 012 Program-selector switch
0x022A0010 016 Rotational-speed sensor,turbocharger
0x022A0012 018 Kickdown switch
0x022A0013 019 ASC monitoring
0x022A0016 022 ATF-sump temperature sensor
0x022A001A 026 Batt.+ supply (perm.)
0x022A001D 029 Pressure regulator,EDS 3
0x022A001E 030 Solenoid valve 1
0x022A001F 031 Solenoid valve 4
0x022A0020 032 Solenoid valve 3
0x022A0021 033 Solenoid valve 2
0x022A0024 036 Selector-lever position L1
0x022A0026 038 Wheel speed,front left
0x022A0027 039 Wheel speed,front right
0x022A0028 040 Wheel speed,rear left
0x022A0029 041 Wheel speed,rear right
0x022A002A 042 Rotat.-sp.signal n-ab(output)
0x022A0033 051 Pressure regulator,EDS 5
0x022A0036 054 Batt.+ supply
0x022A0064 100 Speed monitoring
0x022A0065 101 Speed monitoring
0x022A0066 102 Speed monitoring
0x022A0067 103 Internal SG fault 1
0x022A0068 104 Gearbox relay in the EGS
0x022A0069 105 Engine overrevving interlock
0x022A006A 106 Stall-speed monitoring
0x022A006B 107 Wheel speeds
0x022A006C 108 No programming
0x022A006D 109 Internal SG fault 2
0x022A006E 110 Internal SG fault 3
0x022A0096 150 CAN bus monitoring
0x022A0097 151 CAN status,fault
0x022A0098 152 CAN engine intervention
0x022A0099 153 CAN DME load signal
0x022A009A 154 CAN throttle-valve position
0x022A009B 155 CAN DME engine temperature
0x022A009C 156 CAN timeout 1(ignition ON)
0x022A009D 157 CAN timeout 2(operating)
0x022A009E 158 CAN throttle-valve and load signals
Share this post
Link to post
//EGS 8.34 M43/M44/M52
0x022B0001 001 Pressure actuator 2
0x022B0002 002 Solenoid,shiftlock(OBDII:p1761;EUIII:P0700)
0x022B0003 003 Solenoid value,reverse-gear lock
0x022B0004 004 Solenoid valve,brake band(OBDII:P1743;EUIII:P0700)
0x022B0005 005 Pressure actuator 1(OBDII:P0748;EUIII:P0748)
0x022B0008 008 Selector-lever position(OBDII:P0705;EUIII:P0705)
0x022B0009 009 Selector-lever position L4
0x022B0010 016 Speed sensor,turbocharger
0x022B000C 012 Program button
0x022B0012 018 Kickdown switch
0x022B0013 019 ASC interface
0x022B0016 022 Transmission-fluid temperature sensor
0x022B001A 026 Term,30 supply
0x022B001D 029 Pressure actuator 3
0x022B001E 030 Solenoid valve,1-2/3-4 shift(OBDII:P0753;EUIII:P0753)
0x022B001F 031 Solenoid value,overrunning clutch
0x022B0020 032 Solenoid valve,conv.lockup clutch(OBDII:p0743;EUIII:P0743)
0x022B0021 033 Solenoid valve,2-3 shift(OBDII:P0758;EUIII:P0758)
0x022B0024 036 Selector-lever position L1
0x022B0026 038 Wheel speed,front left
0x022B0027 039 Wheel speed,front right
0x022B0028 040 Wheel speed,rear left
0x022B0029 041 Wheel speed,rear right
0x022B002A 042 Output speed signal(OBDII:P0720;EUIII:P0720)
0x022B002E 046 Stepper shift system
0x022B0033 051 Engine intervention
0x022B0036 054 Batt.+supply(OBDII:P1750;EUIII:P0700)
0x022B0064 100 Gear monitoring(OBDII:P0730;EUIII:P0730)
0x022B0065 101 Speed monitoring
0x022B0067 103 Control unit,internal fault 1(EPROM)(OBDII:P1748;EUIII:P0700)
0x022B0068 104 Control unit,internal fault 4(FEt)(OBDII:P1746;EUIII:P0700)
0x022B0069 105 Engine overrevving lock(OBDII:P1748;EUIII:P0700)
0x022B006A 106 Stall-speed monitoring
0x022B006B 107 Wheel speeds
0x022B006C 108 No programming(OBDII:P1749;EUIII:P0700)
0x022B006D 109 Control unit,internal fault 2(EEPROM)
0x022B006E 110 Control unit,internal fault 3(watchdog)(OBDII:P1748;EUIII:P0700)
0x022B006F 111 Conv.lockup clutch/gear monitoring(OBDII:P0740;EUIII:P0740)
0x022B0070 112 N to D shift at high RPM
0x022B0072 114 DKT signal,load information
0x022B0096 150 CAN bus monitoring(OBDII:P1747;EUIII:P0700)
0x022B0097 151 CAN version fault(OBDII:P1747;EUIII:P0700)
0x022B0098 152 CAN engine intervention(OBDII:P1780;EUIII:P0700)
0x022B0099 153 CAN DME load signal
0x022B009A 154 CAN accel.-pedal position(OBDII:P1765;EUIII:P0700)
0x022B009B 155 CAN engine temperature
0x022B009C 156 CAN timeout DME(OBDII:P1747;EUIII:P0700)
0x022B009D 157 CAN Timeout
0x022B009E 158 CAN throttle and load signal(OBDII:P1765;EUIII:P0700)
0x022B009F 159 CAN ABS/DSC wheel speeds
0x022B00A0 160 CAN timeout ASC
0x022B00A1 161 CAN engine speed
0x022B00A2 162 Brake signal
0x022B00A3 163 Torque intervention(OBDII:P1780;EUIII:P0700)
Share this post
Link to post
//EGS 8.70 M52
0x022C0001 1 Pressure actuator 2
0x022C0002 2 P/N shift-lock
0x022C0003 3 solenoid valve 5
0x022C0004 4 torque converter clutch solenoid valve
0x022C0005 5 Pressure regulator
0x022C0006 8 Selector pos. L2
0x022C0009 9 Selector pos. L4
0x022C000C 12 Program button
0x022C0010 16 Turbocharger, speed sensor
0x022C0012 18 Kickdown switch
0x022C0013 19 ASC interface
0x022C001A 26 Battery voltage
0x022C001D 29 Pressure actuator 3
0x022C001E 30 Solenoid valve 1
0x022C001F 31 Solenoid valve 4
0x022C0020 32 Solenoid valve 3
0x022C0021 33 Solenoid valve 2
0x022C0023 35 Throttle signal (DKT)
0x022C0024 36 Selector pos. L1
0x022C0025 37 Selector pos. L3
0x022C0026 38 Front-left wheel rpm
0x022C0027 39 Front-right wheel rpm
0x022C0028 40 Rear-left wheel rpm
0x022C0029 41 Rear-right wheel rpm
0x022C002A 42 Speed signal n-out
0x022C002B 43 Speed signal n-Mot
0x022C002E 46 Step-shift system
0x022C0033 51 pressure actuator 5
0x022C0035 53 Voltage supply solenoid valve
0x022C0036 54 Voltage supply
0x022C0064 100 Gear monitoring
0x022C0065 101 EPROM checksum
0x022C0066 102 Program checksum
0x022C0067 103 Transmission relay
0x022C0068 104 Temp. information (DKT-signal)
0x022C0069 105 Engine overrun interlock
0x022C006A 106 Stall monitoring
0x022C006B 107 Wheel speed
0x022C006C 108 Control unit program
0x022C006F 111 Converter lookup clutch slippery
0x022C007B 123 Gear monitoring, 2nd/3rd gear
0x022C007C 124 Gear monitoring, 3rd/4th gear
0x022C0082 130 Gear monitoring 1M
0x022C0083 131 Gear monitoring 1
0x022C0084 132 Gear monitoring 2
0x022C0085 133 Gear monitoring 3
0x022C0086 134 Gear monitoring 4
0x022C0087 135 Gear monitoring 5
0x022C0096 150 CAN bus monitoring
0x022C0097 151 Faulty CAN status
0x022C0098 152 CAN: engine intervention
0x022C0099 153 CAN: DME load signal
0x022C009A 154 CAN: throttle valve position
0x022C009B 155 CAN: DME engine temp.
0x022C009C 156 CAN: timeout (ign. on)
0x022C009D 157 CAN: timeout (operate)
0x022C009E 158 CAN: throttle-valve and load signals
0x022C009F 159 CAN: ABS/DSC wheel speed signal
0x022C00A0 160 CAN: ABS/DSC wheel speed signal
0x022C00C8 200 No kickdown shifts
0x022C00C9 201 No s-program
0x022C00CA 202 no M-program
0x022C00CC 203 no program switchover
0x022C00CD 204 no engine intervention
0x022C00CE 205 defective brake-light switch
0x022C00CF 206 incorrect fault display
Share this post
Link to post
//EGS 8.36 M52
0x022D0001 1 Pressure actuator 2
0x022D0002 2 P/N shift-lock
0x022D0003 3 solenoid valve 5
0x022D0004 4 torque converter clutch solenoid valve
0x022D0005 5 Pressure regulator
0x022D0008 8 Selector pos. L2
0x022D0009 9 Selector pos. L4
0x022D000C 12 Program button
0x022D0010 16 Turbocharger,speed sensor
0x022D0012 18 Kickdown switch
0x022D0013 19 ASC interface
0x022D001A 26 Battery voltage
0x022D001D 29 Pressure actuator 3
0x022D001E 30 Solenoid valve 1
0x022D001F 31 Solenoid valve 4
0x022D0020 32 Solenoid valve 3
0x022D0021 33 Solenoid valve 2
0x022D0023 35 Throttle signal (DKT)
0x022D0024 36 Selector pos. L1
0x022D0025 37 Selector pos. L3
0x022D0026 38 Front-left wheel rpm
0x022D0027 39 Front-right wheel rpm
0x022D0028 40 Rear-left wheel rpm
0x022D0029 41 Rear-right wheel rpm
0x022D002A 42 Speed signal n-out
0x022D002B 43 Speed signal n-Mot
0x022D002E 46 Step-shift system
0x022D0033 51 pressure actuator 5
0x022D0035 53 Voltage supply solenoid valve
0x022D0036 54 Voltage supply
0x022D0064 100 Gear monitoring
0x022D0065 101 EPROM checksum
0x022D0066 102 Program checksum
0x022D0067 103 Transmission relay
0x022D0068 104 Temp. information (DKT-signal)
0x022D0069 105 Engine overrun interlock
0x022D006A 106 Stall monitoring
0x022D006B 107 Wheel speed
0x022D006C 108 Control unit program
0x022D006F 111 Converter lookup clutch slippery
0x022D007B 123 Gear monitoring 2nd/3rd gear
0x022D007C 124 Gear monitoring 3rd/4th gear
0x022D0082 130 Gear monitoring 1M
0x022D0083 131 Gear monitoring 1
0x022D0084 132 Gear monitoring 2
0x022D0085 133 Gear monitoring 3
0x022D0086 134 Gear monitoring 4
0x022D0087 135 Gear monitoring 5
0x022D0096 150 CAN bus monitoring
0x022D0097 151 Faulty CAN status
0x022D0098 152 CAN: engine intervention
0x022D0099 153 CAN: DME load signal
0x022D009A 154 CAN: throttle valve position
0x022D009B 155 CAN: DME engine temp.
0x022D009C 156 CAN: timeout (ign. on)
0x022D009D 157 CAN: timeout (operate)
0x022D009E 158 CAN: throttle-valve and load signals
0x022D009F 159 CAN: ABS/DSC wheel speed signal
0x022D00A0 160 CAN: ABS/DSC wheel speed signal
0x022D00C8 200 No kickdown shifts
0x022D00C9 201 No s-program
0x022D00CA 202 no M-program
0x022D00CB 203 no program switchover
0x022D00CC 204 no engine intervention
0x022D00CD 205 defective brake-light switch
0x022D00CE 206 incorrect fault display
Share this post
Link to post
//EGS 8.60.2 M62/M57 5-speed auto. trans. A5S 440Z (5HP-24)
0x022E0001 001 Pressure actuator EDS 1
0x022E0002 002 Pressure actuator EDS 2
0x022E0003 003 Pressure actuator EDS 3
0x022E0004 004 Pressure actuator EDS 4
0x022E0005 005 Pressure actuator EDS 5
0x022E000F 015 Pressure actuator EDS,total current
0x022E0010 016 Solenoid valve 1
0x022E0011 017 Solenoid valve 2
0x022E0012 018 Solenoid valve 3
0x022E0013 019 Solenoid,shiftlock
0x022E0020 032 Speed signal n-ou(output)
0x022E0021 033 Speed sensor,turbine
0x022E0022 034 Oil-sump temperature sensor
0x022E0030 048 Converter lockup clutch,excessive slip
0x022E0031 049 Symptom,gear monitoring
0x022E0032 050 Gear monitoring 1
0x022E0033 051 Gear monitoring 1M
0x022E0034 052 Gear monitoring 2
0x022E0035 053 Gear monitoring 3
0x022E0036 054 Gear monitoring 4
0x022E0037 055 Gear monitoring 5
0x022E0038 056 Symptom GLUE
0x022E0039 057 GLUE monitoring 2/3
0x022E003A 058 GLUE monitoring 3/4
0x022E003B 059 Stall speed
0x022E003C 060 Transmission switch
0x022E003D 061 Temperature monitoring,transmission
0x022E0050 080 ECU internal fault 1(EPROM)
0x022E0051 081 ECU internal fault 2(EEPROM)
0x022E0052 082 ECU internal fault 3(watchdog)
0x022E0053 083 ECU internal fault 4(FET)
0x022E0060 096 Batt.+supply,term.87
0x022E0061 097 Batt.+supply,term.30
0x022E0070 112 Program button
0x022E0071 113 Kickdown button
0x022E0072 114 Steptronic switch
0x022E0080 128 Monitoring,CAN bus
0x022E0081 129 CAN timeout DME
0x022E0082 130 CAN timeout ASC
0x022E0090 144 CAN version fault
0x022E0093 147 CAN throttle
0x022E0094 148 CAN engine temperature
0x022E0095 149 CAN wheel speeds
0x022E0097 151 CAN brake signal
0x022E00FF 255 Unknown fault location
Share this post
Link to post
//EGS 8.60.3 M73/M67 5-speed auto. Gearbox A5S 440Z(5HP-24)
0x022F0001 1 Pressure actuator EDS 1
0x022F0002 2 Pressure actuator EDS 2
0x022F0003 3 Pressure actuator EDS 3
0x022F0004 4 Pressure actuator 4
0x022F0005 5 Pressure actuator EDS 5
0x022F000F 15 Pressure actuator EDS, total current
0x022F0010 16 Solenoid valve 1
0x022F0011 17 Solenoid valve 2
0x022F0012 18 Solenoid valve 3
0x022F0013 19 Solenoid, shift-lock
0x022F0020 32 Speed signal n-ab (output)
0x022F0021 33 Speed signal, turbine
0x022F0022 34 ATF temperature
0x022F0030 48 Mechanical converter lockup
0x022F0031 49 Gear monitoring
0x022F0032 50 Speed monitoring 1
0x022F0033 51 Speed monitoring 1M
0x022F0034 52 Speed monitoring 2
0x022F0035 53 Speed monitoring 3
0x022F0036 54 Speed monitoring 4
0x022F0037 55 Speed monitoring 5
0x022F0038 56 Speed monitoring
0x022F0039 57 Speed monitoring (2nd-3rd gear)
0x022F003A 58 Speed monitoring (3rd-4th gear)
0x022F003B 59 Stall-speed monitoring
0x022F003C 60 Selector-lever switch
0x022F003D 61 Temperature monitoring, transmission
0x022F0040 64 Gear monitoring, flare
0x022F0050 80 SG internal fault 1
0x022F0051 81 SG internal fault 2
0x022F0052 82 SG internal fault 3
0x022F0053 84 EDS/MV supply
0x022F0060 96 Batt. + supply
0x022F0061 97 Term. 30 supply
0x022F0070 112 Program-selector switch
0x022F0071 113 Kickdown switch
0x022F0072 114 Step-by-step shift
0x022F0080 128 CAN bus monitoring
0x022F0081 129 CAN temeout DME
0x022F0082 130 CAN ABS/DSC signal
0x022F0084 132 CAN timeout EML
0x022F0090 144 CAN version fault
0x022F0091 145 CAN troque reduction
0x022F0093 147 CAN throttle-valve and load signal
0x022F0095 149 CAN ABS/DSC wheel speeds
0x022F0097 151 CAN brake signal
0x022F0098 152 CAN rotation uniformity
Share this post
Link to post
//EGS 8.60.4
0x02300001 001 Pressure actuator 1 (P0748)
0x02300002 002 Pressure actuator 2 (P0700,P0778)
0x02300003 003 Pressure actuator 3 (P0700,P0778)
0x02300004 004 Pressure actuator 4 (P0743)
0x0230000F 015 Pressure actuator, resulant current (P0700,P1748)
0x02300010 016 Solenoid valve 1 (P0753)
0x02300011 017 Solenoid valve 2 (P0758)
0x02300012 018 Solenoid valve 3 (P0763)
0x02300013 019 Solenoid, shiftlock (P0700,P1761)
0x02300020 032 Speed signal, output (P0720)
0x02300021 033 Turbine speed sensor (P0715)
0x02300022 034 Transmission-fluid temperature sensor
0x02300030 048 Conv. lockup clutch,excessive slip (P0740,P0741)
0x02300035 053 Gear monitoring 3 (P0733)
0x02300036 054 Grar monitoring 4 (P0734)
0x02300037 055 Gear monitoring 5 (P0735)
0x02300038 056 Symptom GLUE
0x02300039 057 GLUE monitoring 2/3 (P0733)
0x0230003A 058 GLUE monitoring 3/4 (P0734)
0x0230003B 059 Stall speed (P0720)
0x0230003C 060 Gearbox switch (P0705)
0x0230003D 061 Temperature monitoring, transmission
0x0230003E 062 Double fault n_ab
0x02300041 065 Gear monitoring 4 (limp-home program)
0x02300050 080 Control unit, internal fault 1 (EPROM) (P0700,P0601)
0x02300051 081 Control unit, internal fault 2 (EPROM) (P0700,P0603)
0x02300052 082 Control unit, internal fault 3 (EPROM) (P0700,P0606)
0x02300053 083 Control unit, internal fault 4 (FET) (P0700,P1746)
0x02300060 096 Battery voltage, supply, term. 87 (P0700,P0560)
0x02300061 097 Battery voltage, supply terminal 30
0x02300070 112 Program button
0x02300071 113 Kickdown switch
0x02300072 114 Steptronic switch
0x02300080 128 Monitoring, CAN bus (P0700,P1747)
0x02300081 129 CAN timeout DME (P0700,P0600)
0x02300082 130 CAN timeout ASC
0x02300090 144 CAN-version error (P0700,P0600)
0x02300095 149 CAN wheel speeds
0x02300097 151 CAN brake signal
0x023000FF 255 Unknown fault location
Share this post
Link to post
//ABS
0x03010004 4 rear left wheel speed sensor fault
0x03010005 5 rear right wheel speed sensor fault
0x03010006 6 front left wheel speed sensor fault
0x03010007 7 front right wheel speed sensor fault
0x03010008 8 rear left ABS valve fault
0x03010009 9 rear right ABS valve fault
0x0301000A 10 front left ABS valve fault
0x0301000B 11 front right ABS valve fault
0x0301000E 14 valve relay fault
0x0301000F 15 ABS return-pump fault
0x03010015 21 ABS control unit internal fault
0x03010018 24 wrong pulse gear at one wheel
0x03010019 25 stop-light switch
0x03210003 3 Ignition timing adjustment
0x03210004 4 RL wheel-speed signal
0x03210005 5 RR sheel-speed signal
0x03210006 6 FR wheel-speed signal
0x03210007 7 FL wheel-speed signal
0x0321001E 14 ABS valve pump
0x0321001F 15 Return pump
0x03210014 20 Transmission intervention
0x03210015 21 ABS/ASC control module
0x03210016 22 Speed signal from DME
0x03210017 23 Incorrect coding
0x03210018 24 Pulse gears
0x0321001B 27 Idle speed increase
0x0321001E 30 RL wheel-speed sensor wiring
0x0321001F 31 RR wheel-speed sensor wiring
0x03210020 32 FR wheel-speed sensor wiring
0x03210021 33 FL wheel-speed sensor wiring
0x03210022 34 ASC changeover valve
0x03210024 36 Ignition fadeout
0x03210025 37 ABS/ASC control module
0x03210026 38 Choke valve control faulty
0x03210027 39 Choke valve servomotor
0x03210028 40 Choke valve potentiometer
0x0321002F 47 RL outlet valve
0x03210030 48 RR outlet valve
0x03210031 49 FR outlet valve
0x03210032 50 FL outlet valve
0x03210033 51 Rear axle inlet valve
0x03210034 52 RR inlet valve
0x03210035 53 FR inlet valve
0x03210036 54 FL inlet valve
0x03210037 55 ASC intake valve
0x03210038 56 CAN:short circuit
0x03210039 57 TPS signal from DME
0x0321003A 58 CAN:interrupt to AGS
0x0321003B 59 CAN:open circuit to DME
0x0321003F 63 ABS/ASC control module
0x03210040 64 Signal interference
0x03210042 66 Speed sensor voltage supply
0x03210043 67 Intermittent interference
0x03210044 68 Intermittent interference after ignition on
0x03210047 71 ABS moter relay service life
0x03210049 73 Throttle valve angle fault from DME
0x0321004A 74 Engine torque fault from DME
0x0321004B 75 Engine speed fault from DME
0x0321004C 76 CAN: open circuit to DME
0x0321005D 93 DDE fault
0x0321005E 94 DDE fault
0x03220011 17 Operation of front left inlet valve faulty
0x03220012 18 Operation of front left outlet valve faulty
0x03220014 20 Operation of front right inlet valve faulty
0x03220018 24 Operation of front right outlet valve faulty
0x03220021 33 Operation of rear inlet valve faulty
0x03220022 34 Operation of rear axle outlet valve faulty
0x03220044 68 ABS microprocessor disturbed or faulty
0x03220048 72 Internal fault in control
0x03220051 81 Wheel-speed sensor, front left, not installed or faulty
0x03220052 82 Wheel-speed sensor, front right, not installed or faulty
0x03220054 84 Wheel-speed sensor, rear left, not installed or faulty
0x03220058 88 Wheel-speed sensor, rear right, not installed or faulty
0x03220061 97 Wheel-speed signal, front left, not plausible
0x03220062 98 Wheel-speed signal, front right, not plausible
0x03220064 100 Wheel-speed signal, rear left, not plausible
0x03220068 104 Wheel-speed signal, rear right, not plausible
0x03220071 113 Wheel-speed information, front left, not detected
0x03220072 114 Wheel-speed information, front right, not detected
0x03220074 116 Wheel-speed information, rear left, not detected
0x03220078 120 Wheel-speed information, rear right, not detected
0x03220091 145 Pump not functioning
0x03220094 148 Vehicle voltage was greater than 16.5V
0x032200A1 161 Outlet valve, front left, not functioning
0x032200A2 162 Outlet valve, front right, not functioning
0x032200A4 164 Outlet valve, rear axle, not functioning
0x032200A8 168 Outlet valve, rear right, not functioning
0x032200B1 177 Fault, valve load circuit fuse
0x032200B2 178 Valve fault
0x032200B3 180 Valve fault
0x032200B8 184 Controller hardware monitoring
0x032200FF 255 access to memory in control unit disturbed
0x03230002 02 CAN fault (open circuit to EML)
0x03230004 04 Wheel speed, rear left (Plausility)
0x03230005 05 Wheel speed, rear right (Plausility)
0x03230006 06 Wheel speed, front right (Plausility)
0x03230007 07 Wheel speed, front left (Plausility)
0x0323000E 14 ABS valve-relay fault
0x0323000F 15 Return-pump fault
0x03230015 21 ABS/ASC control-unit fault
0x03230017 23 Variant Coding fault
0x03230018 24 Pulse-gears fault
0x0323001E 30 Wheel-speed signal, rear left (wire)
0x0323001F 31 Wheel-speed signal, rear right (wire)
0x03230020 32 Wheel-speed signal, front right (wire)
0x03230021 33 Wheel-speed signal, front left (wire)
0x03230022 34 Change-over valve fault
0x03230029 41 Steering-angle sensor
0x0323002F 47 Fault, outlet valve, rear left
0x03230030 48 Fault, outlet valve, rear right
0x03230031 49 fault, outlet valve, front right
0x03230032 50 Fault, outlet valve, front left
0x03230033 51 Fault, inlet valve, rear left
0x03230034 52 Fault, inlet valve, rear right
0x03230035 53 Fault, inlet valve, front right
0x03230036 54 Fault, inlet valve, front left
0x03230037 55 Intake-valve fault
0x03230038 56 CAN fault (short circuit)
0x0323003A 58 CAN fault (Open circuit to AGS)
0x0323003B 59 CAN fault (Open circuit to DME1)
0x0323003F 63 ABS/ASC control unit fault (microprocessor)
0x03230040 64 Long-term scatter
0x03230042 66 Supply voltage, speed sensor
0x03230045 69 CAN fault (interrupt to DME2)
0x03230047 71 ABS motor-relay service life
0x03230048 72 Steering-angle-sensor adjustment fault
0x03240004 04 Wheel-speed signal, rear left
0x03240005 05 Wheel-speed signal, rear right
0x03240006 06 Wheel-speed signal, front right
0x03240007 07 Wheel-speed signal, front left
0x0324000E 14 ABS valve relay
0x0324000F 15 Return pump
0x03240015 21 ABS/ASC control unit
0x03240017 23 Variant coding
0x03240018 24 Pulse gears
0x0324001E 30 Wheel-speed signal, rear left
0x0324001F 31 Wheel-speed signal, rear right
0x03240020 32 Wheel-speed signal, front right
0x03240021 33 Wheel-speed signal, front left
0x03240022 34 ASC change-over valve
0x0324002F 47 Outlet valve, rear left
0x03240030 48 Outlet valve, rear right
0x03240031 49 Outlet valve, front right
0x03240032 50 Outlet valve, front left
0x03240033 51 Inlet valve, rear left
0x03240034 52 Inlet valve, rear right
0x03240035 53 Inlet valve, front right
0x03240036 54 Inlet valve, front left
0x03240037 55 ASC intake valve
0x03240038 56 CAN fault (short circuit)
0x0324003A 58 CAN fault (Open circuit to AGS)
0x0324003F 63 ABS/ASC control unit
0x03240040 64 Long-term scatter
0x03240042 66 Power supply, wheel-speed sensors
0x03240044 68 Intermittent interference after "Ignition on"
0x03240047 71 ABS motor-relay service life
0x0324004C 76 CAN fault (open circuit to DME/DDE)
0x0324005D 93 Accelerator-pedal-travel sensor
0x0324005E 94 DDE fault
0x03250004 04 Wheel-speed signal, rear left
0x03250005 05 Wheel-speed signal, rear right
0x03250006 06 Wheel-speed signal, front right
0x03250007 07 Wheel-speed signal, front left
0x0325000E 14 ABS valve relay
0x0325000F 15 Return pump
0x03250015 21 ABS/ASC control unit
0x03250017 23 Variant coding
0x03250018 24 Pulse gears
0x0325001E 30 Wheel-speed signal, rear left
0x0325001F 31 Wheel-speed signal, rear right
0x03250020 32 Wheel-speed signal, front right
0x03250021 33 Wheel-speed signal, front left
0x03250022 34 ASC change-over valve
0x03250025 37 ABS/ASC control unit
0x03250026 38 Control fault, choke valve
0x03250027 39 Servomotor, choke valve
0x03250028 40 Potentiometer, choke valve
0x0325002F 47 Outlet valve, rear left
0x03250030 48 Outlet valve, rear right
0x03250031 49 Outlet valve, front right
0x03250032 50 Outlet valve, front left
0x03250033 51 Inlet valve, rear left
0x03250034 52 Inlet valve, rear right
0x03250035 53 Inlet valve, front right
0x03250036 54 Inlet valve, front left
0x03250037 55 ASC intake valve
0x03250038 56 CAN fault (short circuit)
0x03250039 57 Throttle-valve signal from the DME
0x0325003A 58 CAN fault (Open circuit to AGS)
0x0325003B 59 CAN fault (Open circuit to DME)
0x0325003F 63 ABS/ASC control unit
0x03250040 64 Long-term scatter
0x03250042 66 Power supply, wheel-speed sensors
0x03250043 67 Intermittent interference
0x03250044 68 Intermittent interference after "Ignition on"
0x03250047 71 ABS motor-relay service life
0x0325004A 74 DME fault (engine torque)
0x0325004B 75 DME fault (engine speed)
0x03260002 02 CAN fault (open circuit to EML)
0x03260004 04 Wheel speed, rear left (Plausility)
0x03260005 05 Wheel speed, rear right (Plausility)
0x03260006 06 Wheel speed, front right (Plausility)
0x03260007 07 Wheel speed, front left (Plausility)
0x0326000E 14 ABS valve-relay fault
0x0326000F 15 Return-pump fault
0x03260015 21 ABS/ASC control-unit fault
0x03260018 24 Pulse gears fault
0x0326001E 30 Wheel-speed signal, rear left (wire)
0x0326001F 31 Wheel-speed signal, rear right (wire)
0x03260020 32 Wheel-speed signal, front right (wire)
0x03260021 33 Wheel-speed signal, front left (wire)
0x03260022 34 Changeover valve, front axle
0x03260029 41 Steering-angle sensor (Plausibility)
0x0326002F 47 Fault, outlet valve, rear left
0x03260030 48 Fault, outlet valve, rear right
0x03260031 49 fault, outlet valve, front right
0x03260032 50 Fault, outlet valve, front left
0x03260033 51 Fault, inlet valve, rear left
0x03260034 52 Fault, inlet valve, rear right
0x03260035 53 Fault, inlet valve, front right
0x03260036 54 Fault, inlet valve, front left
0x03260037 55 High-pressure changeover valve, front axle
0x03260038 56 CAN fault (short circuit)
0x0326003A 58 CAN fault (Open circuit to AGS)
0x0326003B 59 CAN fault (Open circuit to DME1)
0x0326003F 63 ABS/ASC control unit fault (microprocessor)
0x03260040 64 Long-term scatter
0x03260042 66 Supply voltage, speed sensor
0x03260045 69 CAN fault (interrupt to DME2)
0x03260047 71 ABS motor-relay service life
0x03260051 81 Pressure sensor (wire/offset)
0x03260052 82 Rotation-rate sensor (wire)
0x03260053 83 Transversal-accel. sensor (plausibility)
0x03260054 84 Rotation-rate sensor (plausibility)
0x03260056 86 Changeover valve, rear axle
0x03260057 87 Precharging valve, rear axle
0x03260058 88 Precharging pump
0x0326005B 91 CAN fault (open circuit to LWS)
0x0326005C 92 Pressure sensor (Precharging pump/plausibility)
0x0326005E 94 Rotation-rate sensor (test)
0x0326005F 95 Interference
0x03260060 96 Actuator test
0x03260061 97 Steering-angle sensor (adjustment)
0x03260064 100 Transversal-acceleration sensor (gradient)
0x03260067 103 Steering-angle sensor (revolution indetification)
0x03260068 104 Steering-angle sensor (control module)
0x03260069 105 Brake-light switch (plausibility)
0x0326006A 106 Transversal-acceleration sensor (plausibility)
0x0326006B 107 Rotation-rate sensor (gradient)
0x0326006C 108 Brake fluid
0x0326006D 109 End-of-belt test
0x03270003 03 Ingnition-timing adjustment
0x03270004 04 Wheel-speed signal, rear left
0x03270005 05 Wheel-speed signal, rear right
0x03270006 06 Wheel-speed signal, front right
0x03270007 07 Wheel-speed signal, front left
0x0327000E 14 ABS valve relay
0x0327000F 15 Return pump
0x03270014 20 Gearbox intervention
0x03270015 21 ABS/ASC control unit
0x03270016 22 Wheel-speed signal from the DME
0x03270017 23 Variant coding
0x03270018 24 Pulse gears
0x0327001B 27 Idle-speed increase
0x0327001E 30 Wheel-speed signal, rear left
0x0327001F 31 Wheel-speed signal, rear right
0x03270020 32 Wheel-speed signal, front right
0x03270021 33 Wheel-speed signal, front left
0x03270022 34 ASC change-over valve
0x03270024 34 Ignition fadeout
0x03270025 37 ABS/ASC control unit
0x03270026 38 Control fault, choke valve
0x03270027 39 Servomotor, choke valve
0x03270028 40 Potentiometer, choke valve
0x0327002F 47 Outlet valve, rear left
0x03270030 48 Outlet valve, rear right
0x03270031 49 Outlet valve, front right
0x03270032 50 Outlet valve, front left
0x03270033 51 Inlet valve, rear left
0x03270034 52 Inlet valve, rear right
0x03270035 53 Inlet valve, front right
0x03270036 54 Inlet valve, front left
0x03270037 55 ASC intake valve
0x03270039 57 Throttle-valve signal from the DME
0x0327003F 63 ABS/ASC control unit
0x03270040 64 Long-term scatter
0x03270042 66 Power supply, wheel-speed sensors
0x03270043 67 Intermittent interference
0x03270044 68 Intermittent interference after "Ignition on"
0x03270047 71 ABS motor-relay service life
0x03280002 02 CAN fault (open circuit to EML)
0x03280004 04 Wheel speed, rear left (Plausility)
0x03280005 05 Wheel speed, rear right (Plausility)
0x03280006 06 Wheel speed, front right (Plausility)
0x03280007 07 Wheel speed, front left (Plausility)
0x0328000E 14 ABS valve-relay fault
0x0328000F 15 Return-pump fault
0x03280015 21 ABS/ASC control-unit fault
0x03280018 24 Pulse gears fault
0x0328001E 30 Wheel-speed signal, rear left (wire)
0x0328001F 31 Wheel-speed signal, rear right (wire)
0x03280020 32 Wheel-speed signal, front right (wire)
0x03280021 33 Wheel-speed signal, front left (wire)
0x03280022 34 Changeover valve, front axle
0x03280025 37 ABS/DSC control module
0x03280026 38 Control fault, choke valve
0x03280027 39 Servomotor, choke valve
0x03280028 40 Potentiometer, choke valve
0x03280029 41 Steering-angle sensor (Plausibility)
0x0328002F 47 Fault, outlet valve, rear left
0x03280030 48 Fault, outlet valve, rear right
0x03280031 49 fault, outlet valve, front right
0x03280032 50 Fault, outlet valve, front left
0x03280033 51 Fault, inlet valve, rear left
0x03280034 52 Fault, inlet valve, rear right
0x03280035 53 Fault, inlet valve, front right
0x03280036 54 Fault, inlet valve, front left
0x03280037 55 High-pressure changeover valve, front axle
0x03280038 56 CAN fault (short circuit)
0x03280039 57 Throttle-valve signal from the DME
0x0328003A 58 CAN fault (Open circuit to AGS)
0x0328003B 59 CAN fault (Open circuit to DME1)
0x0328003F 63 ABS/ASC control unit fault (microprecessor)
0x03280040 64 Long-term scatter
0x03280045 69 CAN fault (interrupt to DME2)
0x03280047 71 ABS motor-relay service life
0x03280051 81 Pressure sensor (wire/offset)
0x03280052 82 Rotation-rate sensor (wire)
0x03280053 83 Transversal-accel. sensor (plausibility)
0x03280054 84 Rotation-rate sensor (plausibility)
0x03280056 86 Changeover valve, rear axle
0x03280057 87 High-pressure changeover valve, rear axle
0x03280058 88 Precharging pump
0x0328005B 91 CAN fault (open circuit to LWS)
0x0328005C 92 Pressure sensor (Precharging pump/plausibility)
0x0328005E 94 Rotation-rate sensor (test)
0x0328005F 95 Interference
0x03280060 96 Actuator test
0x03280061 97 Steering-angle sensor (adjustment)
0x03280064 100 Transversal-acceleration sensor (gradient)
0x03280067 103 Steering-angle sensor (revolution indetification)
0x03280068 104 Steering-angle sensor (control module)
0x03280069 105 Brake-light switch (plausibility)
0x0328006A 106 Transversal-acceleration sensor (plausibility)
0x0328006B 107 Rotation-rate sensor (gradient)
0x0328006C 108 Brake fluid
0x0328006D 109 End-of-belt test
0x03290004 04 Wheel-speed signal, rear left
0x03290005 05 Wheel-speed signal, rear right
0x03290006 06 Wheel-speed signal, front right
0x03290007 07 Wheel-speed signal, front left
0x0329000E 14 ABS valve relay
0x0329000F 15 Return pump
0x03290015 21 ABS/ASC control unit
0x03290017 23 Variant coding
0x03290018 24 Pulse gears
0x0329001E 30 Wheel-speed signal, rear left
0x0329001F 31 Wheel-speed signal, rear right
0x03290020 32 Wheel-speed signal, front right
0x03290021 33 Wheel-speed signal, front left
0x03290022 34 ASC change-over valve
0x0329002F 47 Outlet valve, rear left
0x03290030 48 Outlet valve, rear right
0x03290031 49 Outlet valve, front right
0x03290032 50 Outlet valve, front left
0x03290033 51 Inlet valve, rear left
0x03290034 52 Inlet valve, rear right
0x03290035 53 Inlet valve, front right
0x03290036 54 Inlet valve, front left
0x03290037 55 ASC intake valve
0x03290038 56 CAN fault (short circuit)
0x03290039 57 Throttle-valve signal from the DME
0x0329003A 58 CAN fault (Open circuit to AGS)
0x0329003B 59 CAN fault (Open circuit to DME)
0x0329003F 63 ABS/ASC control unit
0x03290040 64 Long-term scatter
0x03290042 66 Power supply, wheel-speed sensors
0x03290043 67 Intermittent interference
0x03290044 68 Intermittent interference after "Ignition on"
0x0329004B 75 DME fault (engine speed)
0x0329004C 76 CAN fault (Open circuit to DME)
0x032A0011 17 Speed signal, front left (electrical fault)
0x032A0012 18 Speed singal, front left (continuity)
0x032A0014 20 Speed signal, front left (drive-off detection)
0x032A0015 21 outlet valve, front left Speed sensor, front left (Position)
0x032A0021 33 Speed singal, front right (electrical fault)
0x032A0022 34 Speed signal, front right (Continuity)
0x032A0024 36 Speed signal, front right (drive-off detection)
0x032A0025 37 Outlet valve, front right speed sensor, front right (position)
0x032A0031 49 Speed signal, rear left (electrical fault)
0x032A0032 50 Speed signal, rear left (continuity)
0x032A0034 52 Speed signal, rear left (drive-off detection)
0x032A0035 53 Outlet valve, rear axle speed sensor, rear left (position)
0x032A0041 65 Speed signal, rear right (electrical fault)
0x032A0042 66 Speed signal, rear right (continuity)
0x032A0044 68 Speed signal, rear right (drive-off detection)
0x032A0045 69 Outlet valve, rear axle speed sensor, rear right (position)
0x032A0051 81 Inlet valve, front left
0x032A0052 82 Inlet valve, front right
0x032A0053 83 Inlet valve, rear left
0x032A0054 84 Inlet valve, rear right
0x032A0055 85 Outlet valve, front left
0x032A0056 86 Outlet valve, front right
0x032A0057 87 Outlet valve, rear left
0x032A0058 88 Outlet valve, rear right
0x032A0061 97 ASC special valve
0x032A0071 11 ABS pump-motor fault
0x032A0073 11 ABS/ASC control unit
0x032A0076 11 Electromagnetic or mechanical influence on Wheel-speed signals
0x032A0078 12 Battery voltage
0x032A0081 12 ABS/ASC main relay
0x032A0082 13 Power supply, solenoid valves
0x032A0083 13 Power input, solenoid valves
0x032A0091 14 CAN chip in ABS/ASC control unit
0x032A0092 14 CAN bus
0x032A0093 14 Engine intervention via CAN
0x032A0094 14 Engine speed via CAN
0x032A0095 14 Connection of DME/DDE to CAN bus
0x032A0096 15 Connection of EGS to CAN bus
0x032A0097 15 Variant coding, ABS/ASC control unit
0x032A0098 152 ASC button
0x032B0011 17 Speed signal, front left (electrical fault)
0x032B0012 18 Speed singal, front left (continuity)
0x032B0014 20 Speed signal, front left (drive-off detection)
0x032B0015 21 outlet valve, front left Speed sensor, front left (Position)
0x032B0021 33 Speed singal, front right (electrical fault)
0x032B0022 34 Speed signal, front right (Continuity)
0x032B0024 36 Speed signal, front right (drive-off detection)
0x032B0025 37 Outlet valve, front right speed sensor, front right (position)
0x032B0031 49 Speed signal, rear left (electrical fault)
0x032B0032 50 Speed signal, rear left (continuity)
0x032B0034 52 Speed signal, rear left (drive-off detection)
0x032B0035 53 Outlet valve, rear axle speed sensor, rear left (position)
0x032B0041 65 Speed signal, rear right (electrical fault)
0x032B0042 66 Speed signal, rear right (continuity)
0x032B0044 68 Speed signal, rear right (drive-off detection)
0x032B0045 69 Outlet valve, rear axle speed sensor, rear right (position)
0x032B0051 81 Inlet valve, front left
0x032B0052 82 Inlet valve, front right
0x032B0053 83 Inlet valve, rear left
0x032B0054 84 Inlet valve, rear right
0x032B0055 85 Outlet valve, front left
0x032B0056 86 Outlet valve, front right
0x032B0057 87 Outlet valve, rear left
0x032B0058 88 Outlet valve, rear right
0x032B0061 97 ASC special valve
0x032B0071 11 ABS pump-motor fault
0x032B0073 11 ABS/ASC control unit
0x032B0076 11 Electromagnetic or mechanical influence of Wheel speed signal
0x032B0078 12 Battery voltage
0x032B0081 12 ABS/ASC main relay
0x032B0082 13 Power supply, solenoid valves
0x032B0083 13 Power input, solenoid valves
0x032B0091 14 CAN chip in ABS/ASC control unit
0x032B0092 14 CAN bus
0x032B0093 14 Engine intervention via CAN
0x032B0094 14 Engine speed via CAN
0x032B0095 14 Connection of DME/DDE to CAN bus
0x032B0096 15 Connection of EGS to CAN bus
0x032B0097 15 Variant coding, ABS/ASC control unit
0x032B0098 152 ASC button
0x032C0011 17 Speed signal, front left (electrical fault)
0x032C0012 18 Speed singal, front left (continuity)
0x032C0014 20 Speed signal, front left (drive-off detection)
0x032C0015 21 outlet valve, front left Speed sensor, front left (Position)
0x032C0021 33 Speed singal, front right (electrical fault)
0x032C0022 34 Speed signal, front right (Continuity)
0x032C0024 36 Speed signal, front right (drive-off detection)
0x032C0025 37 Outlet valve, front right speed sensor, front right (position)
0x032C0031 49 Speed signal, rear left (electrical fault)
0x032C0032 50 Speed signal, rear left (continuity)
0x032C0034 52 Speed signal, rear left (drive-off detection)
0x032C0035 53 Outlet valve, rear axle speed sensor, rear left (position)
0x032C0041 65 Speed signal, rear right (electrical fault)
0x032C0042 66 Speed signal, rear right (continuity)
0x032C0044 68 Speed signal, rear right (drive-off detection)
0x032C0045 69 Outlet valve, rear axle speed sensor, rear right (position)
0x032C0051 81 Inlet valve, front left
0x032C0052 82 Inlet valve, front right
0x032C0053 83 Inlet valve, rear axle
0x032C0055 85 Outlet valve, front left
0x032C0056 86 Outlet valve, front right
0x032C0057 87 Outlet valve, rear axle
0x032C0071 113 ABS pump-motor fault
0x032C0076 118 Electromagnetic or mechanical influence on Wheel-speed signals
0x032C0078 120 Battery voltage
0x032C0081 129 ABS/ASC main relay
0x032C0082 130 Power supply, solenoid valves
0x032C0083 131 Power input, solenoid valves
0x032C0085 133 Solenoid-valve coil
0X032D0011 17 FL wheel-speed signal
0X032D0012 18 FL wheel-speed signal
0X032D0014 20 FL wheel-speed signal
0X032D0015 21 FL wheel-speed sensor or FL outlet valve
0X032D0021 33 FR wheel-speed signal
0X032D0022 34 FR wheel-speed signal
0X032D0024 36 FR wheel-speed signal
0X032D0025 37 FR wheel-speed signal or FR outlet valve
0X032D0031 49 FL wheel-speed signal
0X032D0032 50 FL wheel-speed signal
0X032D0034 52 FL wheel-speed signal
0X032D0035 53 RL wheel-speed signal or rear axle outlet valve
0X032D0041 65 RR wheel-speed signal
0X032D0042 66 RR wheel-speed signal
0X032D0044 68 RR wheel-speed signal
0X032D0045 69 RR wheel-speed signal or rear axle outlet valve
0X032D0051 81 FL inlet valve
0X032D0052 82 FR inlet valve
0X032D0053 83 RL inlet valve
0X032D0054 84 RR inlet valve
0X032D0055 85 FL outlet valve
0X032D0056 86 FR outlet valve
0X032D0057 87 RL outlet valve
0X032D0058 88 RR outlet valv
0X032D0061 97 ASC intake valve
0X032D0062 98 Monitoring of throttle valve control motor disturbed
0X032D0063 99 Fault in choke valve potentiometer
0X032D0064 100 Electric fault in throttle valve actuator
0X032D0065 101 Mechanical fault in throttle valve actuator
0X032D0066 102 Mechanical fault in throttle valve actuator(min.or max.value exceeded)
0X032D0067 103 Break light switch
0X032D0068 104 Pump motor relay service life
0X032D0071 113 Pump motor
0X032D0073 115 ABS/ASC control unit
0X032D0076 118 Electromagnetic or mechanical influence of wheel speed signal
0X032D0078 120 Battery voltage
0X032D0081 129 ABS/ASC main relay
0X032D0082 130 Solenoid valves power supply
0X032D0083 131 Solenoid valves power input
0X032D0085 133 Solenoid valves voltage
0X032D0091 145 CAN: chip in ABS/ASC control unit
0X032D0092 146 CAN: bus faulty
0X032D0093 147 CAN: engine intervention
0X032D0094 148 CAN: engine speed
0X032D0095 149 CAN: connection failed with DME/DDE
0X032D0096 150 CAN: connection failed with EGS
0X032D0097 151 Incorrect coding
0X032D0098 152 ASC button
0x032E0011 11 Wheel-speed sensor, front left
0x032E0012 12 Wheel-speed sensor, front left
0x032E0014 14 Wheel-speed sensor, front left
0x032E0015 15 Wheel-speed sensor position, front left
0x032E0021 21 Wheel- speed sensor, front right
0x032E0022 22 Wheel-speed sensor, front right
0x032E0024 24 Wheel-speed sensor, front right
0x032E0025 25 Wheel-speed sensor position, front right
0x032E0031 31 Wheel-speed sensor, rear left
0x032E0032 32 Wheel-speed sensor, rear left
0x032E0034 34 Wheel-speed sensor, rear left
0x032E0035 35 Wheel-speed sensor position, rear left
0x032E0041 41 Wheel-speed sensor, rear right
0x032E0042 42 Wheel-speed sensor, rear right
0x032E0044 44 Wheel-speed sensor, rear right
0x032E0045 45 Wheel-speed-sensor position, rear right
0x032E0051 51 Intake valve, front left
0x032E0052 52 Intake valve, front right
0x032E0053 53 Intake valve, rear left
0x032E0054 54 Intake valve, rear right
0x032E0055 55 Exhaust valve, front left
0x032E0056 56 Exhaust valve, front right
0x032E0057 57 Exhaust valve, rear left
0x032E0058 58 Exhaust valve, rear right
0x032E0061 61 Distribution valve
0x032E0067 67 Brake-light switch
0x032E0071 71 Pump motor
0x032E0073 73 Internal fault
0x032E0076 76 Speed sensor, signal interference
0x032E0078 78 Vehicle power > 18 V
0x032E0081 81 Positive supply, solenoid valves
0x032E0082 82 Main relay,voltage fault
0x032E0083 83 Current consumption, solenoid valves
0x032E0085 85 Overvoltage, valve coil
0x032E0091 91 CAN fault in control unit
0x032E0092 92 CAN bus fault
0x032E0093 93 CAN data fault from DME/DDE
0x032E0094 94 CAN data fault from DME/DDE
0x032E0095 95 CAN connection to DME/DDE
0x032E0096 96 CAN connection to EGS
0x032E0097 97 Variant coding
0x032E0098 98 Button
0x032F0011 11 Wheel-speed sensor, front left
0x032F0012 12 Wheel-speed sensor, front left
0x032F0014 14 Wheel-speed sensor, front left
0x032F0021 21 Wheel- speed sensor, front right
0x032F0022 22 Wheel-speed sensor, front right
0x032F0024 24 Wheel-speed sensor, front right
0x032F0025 25 Wheel-speed sensor position, front right
0x032F0031 31 Wheel-speed sensor, rear left
0x032F0032 32 Wheel-speed sensor, rear left
0x032F0034 34 Wheel-speed sensor, rear left
0x032F0035 35 Wheel-speed sensor position, rear left
0x032F0041 41 Wheel-speed sensor, rear right
0x032F0042 42 Wheel-speed sensor, rear right
0x032F0044 44 Wheel-speed sensor, rear right
0x032F0045 45 Wheel-speed-sensor position, rear right
0x032F0051 51 Intake valve, front left
0x032F0052 52 Intake valve, front right
0x032F0053 53 Intake valve, rear left
0x032F0054 54 Intake valve, rear right
0x032F0055 55 Exhaust valve, front left
0x032F0056 56 Exhaust valve, front right
0x032F0057 57 Exhaust valve, rear left
0x032F0058 58 Exhaust valve, rear right
0x032F0061 61 Distribution valve
0x032F0067 67 Brake-light switch
0x032F0071 71 Pump motor
0x032F0073 73 Internal fault
0x032F0076 76 Speed sensor, signal interference
0x032F0078 78 Vehicle power > 18 V
0x032F0081 81 Positive supply, solenoid valves
0x032F0083 83 Current consumption, solenoid valves
0x032F0085 85 Overvoltage, valve coil
0x032F0091 91 CAN fault in control unit
0x032F0092 92 CAN bus fault
0x032F0093 93 CAN data fault from DME/DDE
0x032F0094 94 CAN data fault from DME/DDE
0x032F0095 95 CAN connection to DME/DDE
0x032F0096 96 CAN connection to EGS
0x032F0097 97 Variant coding
0x032F0098 98 Button
0x03300011 17 Speed signal, front left (electrical fault)
0x03300012 18 Speed signal, front left (continuity)
0x03300014 20 Speed signal, front left (drive-off detection)
0x03300015 21 outlet valve, front left Speed sensor, front left (Position)
0x03300021 33 Speed signal, front right (electrical fault)
0x03300022 34 Speed signal, front right (Continuity)
0x03300024 36 Speed signal, front right (drive-off detection)
0x03300025 37 Outlet valve, front right speed sensor, front right (position)
0x03300031 49 Speed signal, rear left (electrical fault)
0x03300032 50 Speed signal, rear left (continuity)
0x03300034 52 Speed signal, rear left (drive-off detection)
0x03300035 53 Outlet valve, rear axle speed sensor, rear left (position)
0x03300041 65 Speed signal, rear right (electrical fault)
0x03300042 66 Speed signal, rear right (continuity)
0x03300044 68 Speed signal, rear right (drive-off detection)
0x03300045 69 Outlet valve, rear axle speed sensor, rear right (position)
0x03300051 81 Inlet valve, front left
0x03300052 82 Inlet valve, front right
0x03300053 83 Inlet valve, rear axle
0x03300055 85 Outlet valve, front left
0x03300056 86 Outlet valve, front right
0x03300057 87 Outlet valve, rear axle
0x03300071 113 ABS pump-motor fault
0x03300076 118 Electromagnetic or mechanical influence on Wheel-speed signals
0x03300078 120 Battery voltage
0x03300081 129 ABS/ASC main relay
0x03300082 130 Power supply, solenoid valves
0x03300083 131 Power input, solenoid valves
0x03300085 133 Solenoid-valve coil
0x03310002 XX CAN engine-power control
0x03310004 04 Wheel-speed sensor, rear left, transmits implausible signals
0x03310005 05 Wheel-speed sensor, rear right, transmits implausible signals
0x03310006 06 Wheel-speed sensor, front right, transmits implausible signals
0x03310007 07 Wheel-speed sensor, front left, transmits implausible signals
0x0331000E 0E Valve-relay fault
0x0331000F 0F Return-pump fault
0x03310015 15 Fault int DSC control unit
0x03310017 17 Coding error
0x03310018 18 Pulse-gear fault
0x0331001E 1E Wheel-speed sensor, rear left, transmits no signals
0x0331001F 1F Wheel-speed sensor, rear right, transmits no signals
0x03310020 20 Wheel-speed sensor, front right, transmits no signals
0x03310021 21 Wheel-speed sensor, front left, transmits no signals
0x03310022 22 Changerover valve, front axle
0x0331002F 2F Outlet valve, rear left
0x03310030 30 outlet valve, rear right
0x03310031 31 Outlet valve, front right
0x03310032 32 Outler valve, front left
0x03310033 33 Inlet valve, rear left
0x03310034 34 Inlet valve, rear right
0x03310035 35 Inlet valve, front right
0x03310036 36 Inlet valve, front left
0x03310037 37 High-pressure switching valve, front axle
0x03310038 38 DSC cannot transmit/receive on CAN
0x0331003A 3A No message from EGS control unit
0x0331003B 3B No message (DMER1) from DME/DDE control unit
0x0331003F 3F Speed processing in DSC control unit faulty
0x03310040 40 Continuous control
0x03310041 XX Voltage fault, active speed sensors
0x03310042 XX Voltage fault, active speed sensors
0x03310044 44 DSC passive switching
0x03310045 45 No message (DMER2) from DME/DDE control unit
0x03310051 51 Pressure sensor, line
0x03310052 52 Rotation-rate sensor, line
0x03310053 53 Transversal-acceleration sensor, line
0x03310054 54 Rotation-rate sensor, plausibility
0x03310056 56 Changerover valve, rear axle
0x03310057 57 High-pressure switching valve, rear axle
0x03310058 58 Precharging pump
0x03310059 59 Undervoltage
0x0331005A 5A Brief power interruption
0x0331005C 5C Pressure-sensor test
0x0331005E 5E Rotation-reat sensor, self-test
0x0331005F XX Scatter
0x03310060 XX Actuators
0x03310061 61 Steering-angle sensor,identification
0x03310062 62 Swerve detection
0x03310063 63 Continuous control
0x03310064 XX Transversal-acceleration sensor
0x03310067 67 Steering-angle sensor not transmitting a complete steering angle
0x03310068 68 Steering-angle sensor,internal"
0x03310069 69 Brake-light switch, plausibility
0x0331006A 6A Transversal-acceleration sensor
0x0331006B 6B Rotation rate sensor
0x0331006C 6C Brake-fluid switch
0x0331006D 6D End-of belt test not carried out
0x0331006E 6E Overvoltage
0x0331006F 6F No message from DME/DDE
0x03310072 72 Pressure sensor, zero deviation
0x03310073 73 Pressure sensor, line
0x03310074 74 Brake-light switch (DME/DDE)
0x03310075 75 Brake-light switch, line
0x03310076 76 DDE/DME does not fulfil torque request
0x03310077 77 HDC speed control
0x03310078 78 Rotation-rate sensor, suspicion of incorrect installation position
0x03310079 79 Rotation-rate sensor, incorrect installation position
0x0331007A 7A No message from ACC control unit"
0x0331007B 7B Deceleration request from ACC implausible"
0x0331007C 7C ACC has switched off"
0x0331007D 7D Fault in ACC control unit"
0x0331007E 7E ACC fault,brake-light activation"
0x03310080 80 Brakes were overheated
0x0331008A 8A No message from ride-level-control unit
0x0331008B XX TXU OFF-road reduction gear, CAN message error
0x03320003 XX CAN engine-power control
0x03320004 04 Wheel speed, rear left (Plausility)
0x03320005 05 Wheel speed, rear right (Plausility)
0x03320006 06 Wheel speed, front right (Plausility)
0x03320007 07 Wheel speed, front left (Plausility)
0x0332000E 14 ABS valve-relay fault
0x0332000F 15 Return-pump fault
0x03320015 21 ABS/ASC control-unit fault
0x03320017 23 Variant coding
0x03320018 24 Pulse gears fault
0x03320019 XX Stop-light switch,open circuit
0x0332001E 30 Wheel-speed signal, rear left (wire)
0x0332001F 31 Wheel-speed signal, rear right (wire)
0x03320020 32 Wheel-speed signal, front right (wire)
0x03320021 33 Wheel-speed signal, front left (wire)
0x03320022 34 Changeover valve, front axle
0x03320029 41 Steering-angle sensor (Plausibility)
0x0332002F 47 Fault, outlet valve, rear left
0x03320030 48 Fault, outlet valve, rear right
0x03320031 49 fault, outlet valve, front right
0x03320032 50 Fault, outlet valve, front left
0x03320033 51 Fault, inlet valve, rear left
0x03320034 52 Fault, inlet valve, rear right
0x03320035 53 Fault, inlet valve, front right
0x03320036 54 Fault, inlet valve, front left
0x03320037 55 High-pressure changeover valve, front axle
0x03320038 56 CAN fault (short circuit)
0x0332003A 58 CAN fault (Open circuit to AGS)
0x0332003B 59 CAN fault (Open circuit to DME1)
0x0332003F 63 ABS/ASC control unit fault (microprecessor)
0x03320040 64 Long-term scatter
0x03320042 XX Voltage fault,active speed sensors
0x03320044 XX DSC passive switching
0x03320045 69 CAN fault (interrupt to DME2)
0x03320047 71 ABS motor-relay service life
0x03320051 81 Pressure sensor (wire/offset)
0x03320052 82 Rotation-rate sensor (wire)
0x03320053 83 Transversal-accel. sensor (plausibility)
0x03320054 84 Rotation-rate sensor (plausibility)
0x03320056 86 Changeover valve, rear axle
0x03320057 87 High-pressure changeover valve, rear axle
0x03320058 88 Precharging pump
0x03320059 89 Undervoltage
0x0332005A 90 Temporary system failure
0x0332005B 91 CAN fault (open circuit to LWS)
0x0332005C 92 Pressure sensor (Precharging pump/plausibility)
0x0332005E 94 Rotation-rate sensor (test)
0x0332005F 95 Interference
0x03320060 96 Actuator test
0x03320061 97 Steering-angle sensor (adjustment)
0x03320062 98 Skid detection
0x03320063 99 Permanent brake intervention
0x03320064 XX Lateral acceleration sensor
0x03320067 103 Steering-angle sensor (revolution indetification)
0x03320068 104 Steering-angle sensor (control module)
0x03320069 105 Brake-light switch (plausibility)
0x0332006A 106 Transversal-acceleration sensor (plausibility)
0x0332006B 107 Rotation-rate sensor (gradient)
0x0332006C 108 Brake fluid
0x0332006D 109 End-of-belt test (Commissioning of a new control unit)
0x0332006E 110 Voltage supply too high
0x0332006F 111 ASC acknowledgment
0x03320072 114 Pressure-sensor offset
0x03320073 115 Pressure-sensor interference
0x03320074 116 Brake-light switch
0x03320075 117 Brake-light switch (WIRE)
0x03320076 118 DME staus fault
0x03320077 119 HDC speed control
0x03320078 120 Suspicion incorrect installation of yaw-rate sensor
0x03320079 121 Incorrect installation, yaw-rate sensor
0x0332007A 122 No message from ACC control module
0x0332007B 123 Deceleration request from ACC implausible
0x0332007C 124 ACC has swiched off
0x0332007D 125 Fault in ACC control module
0x0332007E 126 ACC fault,stop-light activation
0x03320080 128 Overheating of service brake
0x0332008A 138 No message from ride-level-control control module
Share this post
Link to post
//SRS
0x04210001 1 control unit internal faulty
0x04210002 2 firing circuit,driver's airbag
0x04210003 3 firing circuit,belt-tensioner(driver)
0x04210004 4 firing circuit,belt-tensioner(passenger)
0x04210005 5 firing circuit,passenger airbag
0x04210011 17 power supply failure
0x04210013 19 warning lamp faulty
0x04210014 20 passenger seat occupancy detector
0x04210015 21 pressure sensor,driver's side
0x04210016 22 pressure sensor,passenger's side
0x04210018 24 seat-belt lock,driver's side
0x04210019 25 seat-belt lock,passenger's side
0x04220001 1 control unit internal faulty
0x04220002 2 firing circuit,driver's airbag
0x04220003 3 firing circuit,belt-tensioner(driver)
0x04220004 4 firing circuit,belt-tensioner(passenger)
0x04220005 5 firing circuit,passenger airbag
0x04220011 17 power supply failure
0x04220013 19 warning lamp faulty
0x04220014 20 passenger seat occupancy detector
0x04220015 21 pressure sensor,driver's side
0x04220016 22 pressure sensor,passenger's side
0x04220018 24 seat-belt lock,driver's side
0x04220019 25 seat-belt lock,passenger's side
0x04230001 1 control unit internal faulty
0x04230002 2 warning lamp faulty
0x04230003 3 Voltage supply
0x04230004 4 firing circuit,driver's airbag
0x04230005 5 firing circuit,belt-tensioner(driver)
0x04230006 6 firing circuit,belt-tensioner(passenger)
0x04230007 7 firing circuit,passenger airbag
0x04230010 16 driver side belt switch
0x04230011 17 Passenger side belt switch
0x04230018 24 passenger seat occupancy detector
0x04230019 25 passenger seat occupancy detector
0x0423001A 26 passenger seat occupancy detector
0x04240001 1 Internal control-unit fault
0x04240002 2 Failure warning lamp
0x04240003 3 Voltage supply
0x04240004 4 Firing circuit for driver airbag
0x04240005 5 Firing circuit, belt tensioner, driver's side
0x04240006 6 Firing circuit, belt tensioner, passenger side
0x04240007 7 Firing circuit for passenger airbag
0x04240008 8 Firing circuit, side airbag, left side
0x04240009 9 Firing circuit, side airbag, right side
0x04240010 16 Buckle switch, driver
0x04240011 17 Buckle switch, passenger
0x04240012 18 Satellite, left(sensor for side airbag)
0x04240013 18 Satellite, left(sensor for side airbag)
0x04240014 18 Satellite, left(sensor for side airbag)
0x04240015 21 Satellite, right(sensor for side airbag)
0x04240016 21 Satellite, right(sensor for side airbag)
0x04240017 21 Satellite, right(sensor for side airbag)
0x04240018 25 Seat-occupation recognition, passenger
0x04240019 25 Seat-occupation recognition, passenger
0x0424001A 25 Seat-occupation recognition, passenger
0x0424001B 251 Seat-occupancy detector
0x0424001D 251 Seat-occupancy detector
0x0424001F 251 Seat-occupancy detector
0x04240020 18 Satellite, left(sensor for side airbag)
0x04240021 21 Satellite, right(sensor for side airbag)
0x04250001 01 Internal control-unit fault
0x04250002 02 _Failure warning lamp
0x04250003 03 Power supply
0x04250004 04 Driver's airbag
0x04250005 05 Belt tensioner, driver's side
0x04250006 06 Belt tensioner, passenger side
0x04250007 07 Passenger airbag
0x04250008 08 Side airbag, front left
0x04250009 09 Side airbag, front right
0x0425000A 0A Side airbag, rear left
0x0425000B 0B Side airbag, rear right
0x0425000C 0C Airbag, head, left
0x0425000D 0D Airbag, head, left
0x0425000E 0E Battery disconnection
0x0425000F 0F Passenger airbag, stage 2
0x04250010 10 Seat-belt buckle, driver
0x04250012 12 Sensor, side airbag, left, data line
0x04250013 13 Sensor, side airbag, left, parameter fault
0x04250014 14 Sensor, side airbag, left, data fault
0x04250015 15 Sensor, side airbag, right, data line
0x04250016 16 Sensor, side airbag, right, parameter fault
0x04250017 17 Sensor, side airbag, right, data fault
0x04250018 18 Seat occupancy detector
0x0425001A 1A Seat occupancy detector: coding data
0x0425001C 1C Seat-occupancy detector: plausibility
0x0425001D 1D Seat-occupancy detector: plausibility
0x0425001F 1F Seat-occupancy detector: plausibility
0x04250020 20 Sensor, side airbag, left, line fault
0x04250021 21 Sensor, side airbag, right, line fault
0x04250035 35 Sensor, side airbag, left: coding data
0x04250036 36 Sensor, side airbag, right: coding data
0x04260001 01 Airbag, driver
0x04260002 02 Belt tensioner, driver
0x04260003 03 Belt tensioner, front passenger
0x04260004 04 Airbag, front passenger
0x04260005 05 Side airbag, front left
0x04260006 06 Side airbag, front right
0x04260007 07 Side airbag, rear left
0x04260008 08 Side airbag, rear right
0x04260009 09 Head airbag(ITS),front left
0x0426000A 0A Head airbag(ITS),front right
0x0426000B 0B Battery, positive terminal isolator 1
0x0426000C 0C Airbag, front passenger, stage 2
0x0426000D 0D Airbag, driver, stage 2
0x0426000E 0E Head airbag, rear left
0x0426000F 0F Head airbag, rear right
0x04260011 11 Power supply
0x04260012 12 Fault lamp(AWL)
0x04260013 13 Indicator lamp(HWL)
0x04260014 14 Seat belt buckle, driver
0x04260016 16 Sensor for side airbag, left
0x04260017 17 Sensor for side airbag, right
0x04260018 18 External rollover sensor
0x0426001A 1A Seat occupancy recognition 1(SBE 1)
0x0426001B 1B Crash telegram memory
0x0426001C 1C Coupling in firing circuit, airbag, driver
0x0426001D 1D Coupling in firing circuit, belt tensioner, driver
0x0426001E 1E Coupling in firing circuit, belt tensioner, passenger
0x0426001F 1F Coupling in firing circuit, airbag, driver
0x04260020 20 Coupling in firing circuit, side airbag, front left
0x04260021 21 Coupling in firing circuit, side airbag, front right
0x04260022 22 Coupling in firing circuit, side airbag, rear left
0x04260023 23 Coupling in firing circuit, side airbag, rear right
0x04260024 24 Coupling in firing circuit, head airbag(ITS),front left
0x04260025 25 Coupling in firing circuit, head airbag(ITS),front right
0x04260026 26 Coupling in firing circuit, battery pos.-term. disconnection 1
0x04260027 27 Coupling in firing circuit, airbag, passenger, stage 2
0x04260028 28 Coupling in firing circuit, airbag, driver, stage 2
0x04260029 29 Coupling in firing circuit, head airbag, rear left
0x0426002A 2A Coupling in firing circuit, head airbag, rear right
0x0426002B 2B Coupling in firing circuit, battery pos.-term. disconnection 2
0x0426002C 2C Checksum, coding data
0x0426002D 2D Sensors for side airbag, front
0x042600F0 F0 Internal control unit fault
0x04270001 01 Airbag, driver, stage1
0x04270002 02 Belt tensioner, driver
0x04270003 03 Belt tensioner, front passager
0x04270004 04 Airbag, passenger stage
0x04270005 05 Side airbag, front left
0x04270006 06 Side airbag, front right
0x04270007 07 Side airbag, rear left
0x04270008 08 Side airbag, rear right
0x04270009 09 Head airbag(ITS), left
0x0427000A 10 Head airbag(ITS), right
0x0427000B 11 Battery, positive terminal isolation 1
0x0427000C 12 Airbag, front passenger stage 2
0x0427000D 13 Airbag, driver stage 2
0x0427000E 14 Head airbag, rear left
0x0427000F 15 Head airbag, rear right
0x04270010 16 Battery, positive terminal isolation 2
0x04270011 17 Belt tensioner, rear left
0x04270012 18 Belt tensioner, rear right
0x04270013 19 Belt tensioner, rear middle
0x04270014 20 Firing circuit ZK19
0x04270015 21 Airbag driver, stage 2
0x04270016 22 Firing circuit ZK7
0x04270030 48 Coupling in firing circuit, airbag driver, stage 1
0x04270031 49 Coupling in firing circuit, belt tensioner, driver
0x04270032 50 Coupling in firing circuit, belt tensioner, passenger
0x04270033 51 Coupling in firing circuit, airbag passenger, stage 1
0x04270034 52 Coupling in firing circuit, side airbag, front left
0x04270035 53 Coupling in firing circuit, side airbag, front right
0x04270036 54 Coupling in firing circuit, side airbag, rear left
0x04270037 55 Coupling in firing circuit, side airbag, rear right
0x04270038 56 Coupling in firing circuit, Head airbag(ITS), left
0x04270039 57 Coupling in firing circuit, Head airbag(ITS), right
0x0427003A 58 Coupling in firing circuit, Pos.-term, disconnection 1
0x0427003B 59 Coupling in firing circuit, airbag passenger, stage 2
0x0427003C 60 Coupling in firing circuit, airbag driver, stager 2
0x0427003D 61 Coupling in firing circuit, head airbag, rear left
0x0427003E 62 Coupling in firing circuit, head airbag, rear right
0x0427003F 63 Coupling in firing circuit, pos.-term, disconnection 2
0x04270040 64 Coupling in firing circuit, belt tensioner, rear left
0x04270041 65 Coupling in firing circuit, belt tensioner, rear right
0x04270042 66 Coupling in firing circuit, belt tensioner, rear middle
0x04270043 67 Coupling in firing circuit, ZK 19
0x04270044 68 Coupling in firing circuit, airbag driver, stage 2
0x04270045 69 Coupling in firing circuit, ZK 7
0x04270050 80 Power supply
0x04270051 81 Fault lamp
0x04270052 82 Information lamp
0x04270057 87 Coupling fault, sensor, side airbag, left.
0x04270060 96 Seat-belt lock, driver
0x04270062 98 Seat-belt lock, rear left
0x04270063 99 Seat-blet lock, rear right
0x04270064 100 Seat-belt lock, rear middle
0x04270070 112 Seat occupancy detector
0x04270071 113 Seat occupancy detector 2
0x04270075 117 External rollover sensor
0x04270080 128 Sensor for side airbag, front
0x04270081 129 Sensor for side airbag, left
0x04270082 130 Sensor for side airbag, right
0x04270083 131 Sensor for side airbag, left
0x04270084 132 sensor for side airbag, right
0x04270085 133 sensor for side airbag, right
0x04270086 134 sensor for side airbag, right
0x04270087 135 Coupling fault, sensor for side airbag, left
0x04270088 136 Coupling fault, sensor for side airbag, right
0x04270090 144 Coding incorrect
0x04270091 145 Crash-telegram memory
0x042700F0 240 internal control unit fault
0x04280001 01 Airbag, driver, stage 1
0x04280002 02 Belt tensioner, driver
0x04280003 03 Belt tensioner, front passenger
0x04280004 04 Airbag, passenger, stage 1
0x04280005 05 Side airbag, front left
0x04280006 06 Side airbag, front right
0x04280007 07 Side airbag, rear left
0x04280008 08 Side airbag, rear right
0x04280009 09 Head airbag (ITS), left
0x0428000A 0A Head airbag (ITS), right
0x0428000B 0B Safety battery terminal 1
0x0428000C 0C Airbag, front passenger, stage 2
0x0428000D 0D Airbag, driver, stage 2
0x0428000E 0E Head airbag, rear left
0x0428000F 0F Head airbag, rear right
0x04280010 10 Safety battery terminal 2
0x04280030 30 Coupling in firing circuit, airbag, driver, stage 1
0x04280031 31 Coupling in firing circuit, belt tensioner, driver
0x04280032 32 Coupling in firing circuit, belt tensioner, passenger
0x04280033 33 Coupling in firing circuit, airbag passenger, stage 1
0x04280034 34 Coupling in firing circuit, side airbag, front left
0x04280035 35 Coupling in firing circuit, side airbag, front right
0x04280036 36 Coupling in firing circuit, side airbag, rear left
0x04280037 37 Coupling in firing circuit, side airbag, rear right
0x04280038 38 Coupling in firing circuit, head airbag(ITS), left
0x04280039 39 Coupling in firing circuit, head airbag(ITS), right
0x0428003A 3A Coupling in ignition circuit, safety battery terminal 1
0x0428003B 3B Coupling in firing circuit, airbag, passenger, stage 2
0x0428003C 3C Coupling in firing circuit, airbag, driver, stage 2
0x0428003D 3D Coupling in firing circuit, head airbag, rear left
0x0428003E 3E Coupling in firing circuit, head airbag, rear right
0x0428003F 3F Coupling in ignition circuit, safety battery terminal 2
0x04280050 50 Power supply
0x04280051 51 Fault lamp (AWL)
0x04280052 52 Passenger airbag OFF lamp (POL)
0x04280060 60 Seat-belt contact, driver
0x04280061 61 Seat-belt contact, passenger
0x04280067 67 Passenger airbag off switch (POS)
0x04280068 68 Passenger airbag off switch (POS) inverse
0x04280069 69 Passenger airbag off switch (POS)
0x04280070 70 Seat occupancy detector
0x04280071 71 Seat occupancy detector
0x04280072 72 Seat occupancy detector
0x04280080 80 Side sensor, door, left
0x04280081 81 Side sensor, door, left
0x04280082 82 Side sensor, door, right
0x04280083 83 Side sensor, door, right
0x04280084 84 Front sensor, left
0x04280085 85 Front sensor, left
0x04280086 86 Front sensor, right
0x04280087 87 Front sensor, right
0x04280088 88 Side sensor, B-pillar, X-direction, left
0x04280089 89 Side sensor, B-pillar, X-direction, left
0x0428008A 8A Side sensor, B-pillar, X-direction, right
0x0428008B 8B Side sensor, B-pillar, X-direction, right
0x0428008C 8C Side sensor, B-pillar, Y-direction, left
0x0428008D 8D Side sensor, B-pillar, Y-direction, left
0x0428008E 8E Side sensor, B-pillar, Y-direction, right
0x0428008F 8F Side sensor, B-pillar, Y-direction, right
0x04280090 90 Coding incorrect (CBD block)
0x04280091 91 Crash telegram memory
0x04280092 92 Crash telegram memory
0x04280093 93 ECU lock
0x04280094 94 Alert threshold
0x042800F0 F0 Internal control unit fault
0x04410001 1 Crash-sensor closed once
0x04410002 2 Crash-sensor closed several times
0x04410005 5 Crash-sensor closed permanently
0x0441000D 13 Two firing circuits shorted
0x04410013 19 Left crash-sensor lead insulation
0x04410014 20 Right crash-sensor lead insulation
0x0441001B 27 One firing circuit short to positive
0x04410021 33 One firing circuit short to ground
0x0441002A 42 Resister too small, drivers airbag
0x0441002B 43 Resister too small, firing circuit II
0x0441002C 44 Resister too small, firing circuit III
0x0441002D 45 Resister too large, drivers airbag
0x0441002E 46 Resister too large, firing circuit II
0x0441002F 47 Resister too large, firing circuit III
0x04410031 49 Warning lamp faulty
0x04410032 50 Diagnostic unit faulty
0x04410034 52 Crash evidence set
Share this post
Link to post
Share on other sites
//EML
0x07010017 23 Control for DK servomotor cylinder 1..6
0x07010039 57 Control unit or throttle valve, cyl 1..6 or cyl 7..12
0x0701005A 90 DK or PWG switch cyl 1..6
0x07010066 102 DK potentiometer cylinder 7..12
0x07010071 113 Control for DK servomotor, cylinders 7..12
0x0701008E 142 PWG potentiometer
0x07010099 153 EML system fault
0x070100A5 165 DK or PWG switch cyl 7..12
0x070100B2 178 Connection from EML SG to ASC SG disturbed
0x070100C3 195 FGR Control button
0x07020017 23 Control for DK servomotor cylinder 1..6
0x07020039 57 Control unit or throttl valve, cyl 1..6 or cyl 7..12
0x0702005A 90 DK or PWG switch cylinder 1..6
0x07020066 102 DK potentiometer cylinder 7..12
0x07020071 113 Control for DK servomotor, cylinders 7..12
0x0702008E 142 PWG potentiometer
0x07020099 153 EML system fault
0x070200A5 165 DK or PWG switch cyl 7..12
0x070200B2 178 Connection from EML SG to ASC SG disturbed
0x070200C3 195 FGR control button
0x07030017 23 EML system fault
0x0703002A 43 Control for DK servomtor
0x0703003C 60 ti injection signal
0x0703004D 77 Pedal-travel-sensor switch
0x0703005A 90 Pedal-travel-sensor switch
0x07030066 102 Throttle-valve potentiometer
0x07030081 129 Throttle-valve switch
0x0703008E 142 Engine temp. tmot
0x07030099 153 Engine-speed signal TD
0x070300A8 165 Speed signal
0x070300B2 178 FGR control button
0x070300C3 195 Connection, EML SG to ASC SG disturbed
0x070300D4 212 EML Control unit A/D converter
0x070300E8 232 Pedal Stop wrongly adjusted
0x07210001 1 Throttle valve 1 potentiometer 1, voltage too low (OBD II codeP1543)
0x07210002 2 Throttle valve 1 potentiometer 1, voltage too high (OBD IcoedP1544)
0x07210003 3 Throttle valve 1 potentiometer 2, voltage too low (OBD II codeP1543)
0x07210004 4 Throttle valve 1 potentiometer 2, voltage too high (OBDIIcodeP1544)
0x07210005 5 Throttle valve 2 potentiometer 1, voltage too low (OBD II code P1590)
0x07210006 6 Throttle valve 2 potentiometer 1, voltage too high (OBD II code P1591)
0x07210007 7 Throttle valve 2 Potentiometer 2, voltage too low (OBD II code P1590)
0x07210008 8 Throttle valve 2 potentiometer 2, voltage too high (OBD II code P1591)
0x07210009 9 Potentiometer supply voltage 1 of throttle valve 1/2 deviates (OBD II code P0601)
0x0721000A 10 Potentiometer supply voltage 2 of throttle valve 1/2 deviates (OBD II code P0601)
0x0721000B 11 Difference in potentiometer 1/2 voltage of throttle valve 1 too low (ODB II code P1545)
0x0721000C 12 Difference in potentiometer 1/2 voltage of throttle valve 1 too high (ODB II code P1545)
0x0721000D 13 Difference in potentiometer 1/2 voltage of throttle valve 2 too low (ODB II code P1591)
0x0721000E 14 Difference in potentiometer 1/2 voltage of throttle valve 2 too high (ODB II code P1592)
0x07210014 20 IC fault, pedal-travel sensor 1
0x07210015 21 IC fault, pedal-travel sensor 2
0x07210016 22 IC fault, pedal-travel sensor 3
0x07210017 23 IC fault, pedal-travel sensor 1
0x07210018 24 IC fault, pedal-travel sensor 2
0x07210019 25 IC fault, pedal-travel sensor 3
0x0721001A 26 Pedal-travel sensor 1 signal faulty
0x0721001B 27 Pedal-travel sensor 2 signal faulty
0x0721001C 28 Pedal-travel sensor 3 signal faulty
0x0721001D 29 Pedal-travel sensor 1 signal faulty
0x0721001E 30 Pedal-travel sensor 2 signal faulty
0x0721001F 31 Pedal-travel sensor 3 signal faulty
0x07210020 32 Fault,mesa,amplitude, pedal-travel sensor 1
0x07210021 33 Fault,mesa,amplitude, pedal-travel sensor 2
0x07210022 34 Fault,mesa,amplitude, pedal-travel sensor 3
0x07210023 35 Fault,mesa,amplitude, pedal-travel sensor 1
0x07210024 36 Fault,mesa,amplitude, pedal-travel sensor 2
0x07210025 37 Fault,mesa,amplitude, pedal-travel sensor 3
0x07210026 38 Faulty signal, pedal-travel sensors 1/2
0x07210027 39 Faulty signal, pedal-travel sensors 1/3
0x07210028 40 Faulty signal, pedal-travel sensors 2/3
0x07210029 41 Faulty signal, pedal-travel sensors 1/2
0x0721002A 42 Faulty signal, pedal-travel sensors 1/3
0x0721002B 43 Faulty signal, pedal-travel sensors 2/3
0x0721002C 44 Pedal-travel sensor, difference too large in sensor 1/2
0x0721002D 45 Pedal-travel sensor, difference too large in sensor 1/3
0x0721002E 46 Pedal-travel sensor, difference too large in sensor 2/3
0x0721002F 47 Pedal-travel sensor, difference too large in sensor 1/2
0x07210030 48 Pedal-travel sensor, difference too large in sensor 1/3
0x07210031 49 Pedal-travel sensor, difference too large in sensor 2/3
0x07210032 50 Pedal-travel sensor, basic adaptation
0x07210033 51 Pedal-travel sensor, basic adaptation
0x07210034 52 Assignment pedal-travel sensor 3 faulty
0x07210035 53 Assignment pedal-travel sensor 3 faulty
0x07210036 54 Pedal-travel sensors
0x07210037 55 Pedal-travel sensors
0x07210038 56 Pedal-travel sensors
0x07210039 57 Pedal-travel sensors
0x0721003A 58 Pedal-travel sensors
0x0721003B 59 Pedal-travel sensors
0x0721003C 60 Pedal-travel sensors
0x0721003D 61 Pedal-travel sensors
0x0721003E 62 Pedal-travel sensors
0x0721003F 63 Pedal-travel sensors
0x07210040 64 Pedal-travel sensors
0x07210041 65 Pedal-travel sensors
0x07210042 66 Pedal-travel sensors
0x07210043 67 Pedal-travel sensors
0x07210044 68 Pedal-travel sensors
0x07210045 69 Pedal-travel sensors
0x07210050 80 CAN fault when sending EML 1 message
0x07210051 81 CAN: error receiving control-unit messages
0x07210052 82 CAN: error reception DME I or II messages, or incorrect CAN version (OBD II code P0600)
0x07210053 83 CAN not work properly (OBD II code P0600)
0x07210056 86 Throttle valve 2, potentiometer 2, voltage abnormal (OBD II code P1592)
0x07210057 87 Throttle valve 2 potentiometer 1, voltage abnormal (OBD II code P1592)
0x07210058 88 Throttle valve 1 potentiometer 1, voltage abnormal (OBD II code P1545)
0x07210059 89 Throttle valve 1 potentiometer 2, voltage abnormal (OBD II code P1545)
0x0721005A 90 Control-unit fault (OBD II code P0601)
0x0721005B 91 Control-unit fault (OBD II code P0601)
0x0721005C 92 Control-unit fault (OBD II code P0601)
0x0721005D 93 Control-unit fault (OBD II code P0601)
0x07210064 100 Control-module faults
0x07210065 101 Control-module faults
0x07210066 102 Control-module faults
0x07210067 103 Control-module faults
0x07210068 104 Control-module faults
0x07210069 105 Control-module faults
0x0721006A 106 Control-module faults
0x0721006B 107 Control-module faults
0x0721006C 108 Control-module faults
0x0721006D 109 Control-module faults
0x0721006E 110 Control-module faults
0x07210070 112 Cruise Control (FGR) faulty
0x07210071 113 Road-speed signal faulty
0x07210072 114 Kickdown-switch faulty
0x07210073 115 Brake-light switch faulty
0x07210074 116 Brake-test switch faulty
0x07210075 117 External safety path to right DME control unit
0x07210076 118 External safety path to left DME control unit
0x07210077 119 CAN: idle speed from right DME control unit
0x07210078 120 CAN: idle speed from left DME control unit
0x07210079 121 CAN: safety path from right DME control unit
0x0721007A 122 CAN: safety path from left DME control unit
0x0721007B 123 CAN: emergency shutoff from right DME module
0x0721007C 124 CAN: emergency shutoff from left DME module
0x0721007D 125 Idle-controller changeover or idle-controller subset. val. (OBD II code Po600)
0x0721007E 126 CAN: message ram DSC control unit faulty
0x07210080 128 Throttle valve 1 potentiometer 1 offset test failed (OBD II code P1545)
0x07210081 129 Throttle valve 2 potentiometer 1 offset failed (OBD II code P1592)
0x07210082 130 Throttle valve 1 potentiometer 1 jump test failed (OBD II code P1580)
0x07210083 131 Throttle valve 2 Potentiometer 1 jump test failed (OBD II code P1581)
0x07210084 132 Throttle valve 1 spring test failed (OBD II code P1580)
0x07210085 133 Throttle valve 2 spring test failed (OBD II code P1581)
0x07210086 134 Control-unit faulty (OBD II code P0601)
0x07210087 135 Control-unit faulty (OBD II code P0601)
0x07210088 136 Throttle valve 2 potentiometer 2 offset test failed (OBD II coed P1592)
0x07210089 137 Throttle valve 1 potentiometer 2 offset test failed (OBD II coed P1545)
0x0721008A 138 Throttle valve 2 potentiometer 2 jump test failed (OBD II coed P1581)
0x0721008B 139 Throttle valve 1 potentiometer 2 jump test failed (OBD II coed P1580)
0x0721008C 140 Throttle valve 2 spring test failed (OBD II coed P1581)
0x0721008D 141 Throttle valve 1 Spring test failed (OBD II coed P1580)
0x0721008E 142 Control-unit faulty (OBD II code P0601)
0x0721008F 143 Control-unit faulty (OBD II code P0601)
0x07210090 144 ECU incorrectly coded
0x07210091 145 ECU incorrectly coded
0x07210098 152 Throttle valve 1 stepping-motor output stage (OBD II code P1558)
0x07210099 153 Throttle valve 1 stepping-motor output stage (OBD II code P1558)
0x0721009A 154 Throttle valve 2 stepping-motor output stage (OBD II code P1558)
0x0721009B 155 Throttle valve 2 stepping-motor output stage (OBD II code P1558)
0x0721009C 156 Throttle valve 2 stepping-motor output stage (OBD II code P1558)
0x0721009D 157 Throttle valve 2 stepping-motor output stage (OBD II code P1558)
0x0721009E 158 Throttle valve 1 stepping-motor output stage (OBD II code P1558)
0x0721009F 159 Throttle valve 1 stepping-motor output stage (OBD II code P1558)
Share this post
Link to post
//ZKE
0x0A210001 1 Fuse or lead for load circuit 1
0x0A210002 2 Fuse or lead for load circuit 2
0x0A210003 3 Horn for anti-theft alarm system - fuse
0x0A210004 4 Terminal R
0x0A210008 8 General module not coded
0x0A210009 9 General module not coded
0x0A21000A 10 Coding incorrect
0x0A21000B 11 Coding incorrect
0x0A210030 48 Potentiometer for interval time
0x0A210031 49 Wiper motor is blocked or return contact is faulty
0x0A210033 51 Pump for windscreen washer system - short circuit
0x0A210034 52 Motor for contact-pressure control
0x0A210035 53 Motor for contact-pressure control-short circuit
0x0A210036 54 Cam-operated switch for contact-pressure control
0x0A210037 55 Relay for intensive windscreen cleaning
0x0A210038 56 Relay for headlight cleaning
0x0A210039 57 Relay for intensive windscreen cleaning and headlight cleaning sticks
0x0A210040 64 Interior lights
0x0A210041 65 Interior lighting, short circuit
0x0A210044 68 Door-lock heater
0x0A210045 69 Door-lock heater, short circuit
0x0A210048 72 Relay for wiper motor, short circuit to positive
0x0A210049 73 Relay for wiper motor, open circuit
0x0A21004A 74 Changeover relay, stage 1/2, for wiper motor, short circuit to positive
0x0A21004B 75 Changeover relay, stage 1/2, for wiper motor, open circuit
0x0A210050 80 Relay for central-locking drives, rear, unlocking, sticks
0x0A210051 81 Relay for central-locking drives, rear, unlocking, does not pick up
0x0A210052 82 Relay for central-locking drives, rear, locking, sticks
0x0A210053 83 Relay for central-locking drives, rear, locking, does not pick up
0x0A210054 84 Relay for central-locking drives, rear, double locking, sticks
0x0A210055 85 Relay for central-locking drives, rear, double locking, does not pick up
0x0A210056 86 Relay for tailgate drive sticks
0x0A210057 87 Relay for tailgate drive does not pick up
0x0A210058 88 Crash detection
0x0A21005D 93 Central-locking drive, driver's door
0x0A21005E 94 Central-locking drive, passenger's door
0x0A210060 96 Relay for PW motor, driver's door, sticks
0x0A210061 97 Relay for PW motor, driver's door, does not pick up
0x0A210062 98 Relay for PW motor, driver's door, sticks
0x0A210063 99 Relay for PW motor, driver's door, does not pick up
0x0A210064 100 Relay for PW motor, passenger's door, sticks
0x0A210065 101 Relay for PW motor, passenger's door, does not pick up
0x0A210066 102 Relay for PW motor, passenger's door, sticks
0x0A210067 103 Relay for PW motor, passenger's door, does not pick up
0x0A210068 104 Relay for PW motor, driver's side rear, sticks
0x0A210069 105 Relay for PW motor, driver's side rear, does not pick up
0x0A21006A 106 Relay for PW motor, driver's side rear, sticks
0x0A21006B 107 Relay for PW motor, driver's side rear, does not pick up
0x0A21006C 108 Relay for PW motor, passenger's side rear, sticks
0x0A21006D 109 Relay for PW motor, passenger's side rear, does not pick up
0x0A21006E 110 Relay for PW motor, passenger's side rear, sticks
0x0A21006F 111 Relay for PW motor, passenger's side rear, does not pick up
0x0A210070 112 Power-window switch block
0x0A21007F 127 Slide/tilt sunroof module
0x0A210080 128 Servotronic servo valve, open circuit
0x0A210081 129 Servotronic servo valve, short circuit
0x0A210082 130 Speedo signal interrupted
0x0A210083 131 Speedo signal incorrect
0x0A210092 146 Tilt sensor of anti-theft alarm system
0x0A210093 147 LED for anti-theft alarm system, short circuit to positive
0x0A210094 148 LED for anti-theft alarm system, open circuit
0x0A210095 149 Passenger-compartment sensor
0x0A210096 150 Passenger-compartment sensor, rear
0x0A2100A1 161 Mirror heater, driver's door, short circuit
0x0A2100A3 163 Mirror heater, passenger's door, short circuit
0x0A2100B1 177 Motor, mirror retraction, driver's door, short circuit
0x0A2100B3 179 Motor, mirror retraction, passenger's door, short circuit
0x0A2100B4 185 Transport mode active
0x0A2100C0 192 Servomotor, seat sled, driver: transmission error
0x0A2100C1 193 Servomotor, seat sled, driver: overloading of the output stage
0x0A2100C2 194 Servomotor, seat sled, driver: blocking during forward movement
0x0A2100C4 196 Servomotor, seat height, driver: transmission error
0x0A2100C5 197 Servomotor, seat height, driver: overloading of the output stage
0x0A2100C6 198 Servomotor, seat height, driver: blocking during upward movement
0x0A2100C7 199 Servomotor, seat height, driver: blocking during downward movement
0x0A2100C8 200 Servomotor, seat angle, driver: transmission error
0x0A2100C9 201 Servomotor, seat angle, driver: overloading of the output stage
0x0A2100CA 202 Servomotor, seat angle, driver: blocking during upward movement
0x0A2100CB 203 Servomotor, seat angle, driver: blocking during backward movement
0x0A2100CC 204 Servomotor, backrest, driver: transmission error
0x0A2100CD 205 Servomotor, backrest, driver: overloading of the output stage
0x0A2100CE 206 Servomotor, backrest, driver: blocking during forward movement
0x0A2100CF 207 Servomotor, backrest, driver: blocking during backward movement
0x0A2100D0 208 Servomotor, head restraint, driver: transmission error
0x0A2100D1 209 Servomotor, head restraint, driver: overloading of the output stage
0x0A2100D2 210 Servomotor, head restraint, driver: blocking during upward movement
0x0A2100D3 211 Servomotor, head restraint, driver: blocking during downward movement
0x0A2100D4 212 Servomotor, thigh support, driver: transmission error
0x0A2100D5 213 Servomotor, thigh support, driver: overloading of the output stage
0x0A2100D6 214 Servomotor, thigh support, driver: blocking during forward movement
0x0A2100D7 215 Servomotor, thigh support, driver: blocking during backward movement
0x0A2100D8 216 Servomotor, backrest head, driver: transmission error
0x0A2100D9 217 Servomotor, backrest head, driver: overloading of the output stage
0x0A2100DA 218 Servomotor, backrest head, driver: blocking during forward movement
0x0A2100DB 219 Servomotor, backrest head, driver: blocking during backward movement
0x0A2100DC 220 Servomotor, steering column (height): transmission error
0x0A2100DD 221 Servomotor, steering column (height): overloading of the output stage
0x0A2100DE 222 Servomotor, steering column (height): blocking during upward movement
0x0A2100DF 223 Servomotor, steering column (height): blocking during downward movement
0x0A2100E0 224 Servomotor, steering column (extension): transmission error
0x0A2100E1 225 Servomotor, steering column (extension): overloading of the output stage
0x0A2100E2 226 Servomotor, steering column (extension): blocking during forward movement
0x0A2100E3 227 Servomotor, steering column (extension): blocking during backward movement
0x0A2100E4 192 Servomotor, seat sled, passenger: transmission error
0x0A2100E5 193 Servomotor, seat sled, passenger: overloading of the output stage
0x0A2100E6 194 Servomotor, seat sled, passenger: blocking during forward movement
0x0A2100E8 196 Servomotor, seat height, passenger: transmission error
0x0A2100E9 197 Servomotor, seat height, passenger: overloading of the output stage
0x0A2100EA 198 Servomotor, seat height, passenger: blocking during upward movement
0x0A2100EB 199 Servomotor, seat height, passenger: blocking during downward movement
0x0A2100EC 200 Servomotor, seat angle, passenger: transmission error
0x0A2100ED 201 Servomotor, seat angle, passenger: overloading of the output stage
0x0A2100EE 202 Servomotor, seat angle, passenger: blocking during upward movement
0x0A2100EF 203 Servomotor, seat angle, passenger: blocking during backward movement
0x0A2100F0 204 Servomotor, backrest, passenger: transmission error
0x0A2100F1 205 Servomotor, backrest, passenger: overloading of the output stage
0x0A2100F2 206 Servomotor, backrest, passenger: blocking during forward movement
0x0A2100F3 207 Servomotor, backrest, passenger: blocking during backward movement
0x0A2100F4 208 Servomotor, head restraint, passenger: transmission error
0x0A2100F5 209 Servomotor, head restraint, passenger: overloading of the output stage
0x0A2100F6 210 Servomotor, head restraint, passenger: blocking during upward movement
0x0A2100F7 211 Servomotor, head restraint, passenger: blocking during downward movement
0x0A2100F8 212 Servomotor, thigh support, passenger: transmission error
0x0A2100F9 213 Servomotor, thigh support, passenger: overloading of the output stage
0x0A2100FA 214 Servomotor, thigh support, passenger: blocking during forward movement
0x0A2100FB 215 Servomotor, thigh support, passenger: blocking during backward movement
0x0A2100FC 216 Servomotor, backrest head, passenger: transmission error
0x0A2100FD 217 Servomotor, backrest head, passenger: overloading of the output stage
0x0A2100FE 218 Servomotor, backrest head, passenger: blocking during forward movement
0x0A2100FF 219 Servomotor, backrest head, passenger: blocking during backward movement
0x0A220000 00 General module V: internal fault voltage
0x0A220001 01 Interior light, washer pump: fuse
0x0A220002 02 Central locking: fuse
0x0A220003 03 Central locking: input
0x0A220004 04 Transport mode active
0x0A220006 06 Burglar-alarm system: signal STDWA
0x0A220007 07 Burglar-alarm system: signal STDWA
0x0A220008 08 Power windows: fuse
0x0A220009 09 Power windows: motor or relay, driver door
0x0A22000A 0A Power windows: motor or relay, passenger door
0x0A22000B 0B Power windows: motor or relay, driver, rear
0x0A22000C 0C Power windows: motor or relay passenger, rear
0x0A22000D 0D Power windows: anti-trapp. machine. driver's door
0x0A22000E 0E Power windows: anti-trapp. machine. passenger door
0x0A22000F 0F Power windows: anti-trapp. machine. driver, rear
0x0A220010 10 Power windows: anti-trapp. machine. passenger, rear
0x0A220020 20 General module V: internal fault processor
0x0A220021 21 General module V: internal fault processor
0x0A220022 22 General module V: internal fault clock generate.
0x0A220023 23 General module V: internal fault EEPROM
0x0A220024 24 Relay for central locking, locking
0x0A220025 25 Relay for central locking, unlocking
0x0A220026 26 Relay for central locking, double locking
0x0A220028 28 Relay for central locking, locking
0x0A220029 29 Relay for central locking, unlocking
0x0A22002A 2A Relay for central locking, double locking
0x0A22002B 2B Relay for locking driver's door
0x0A22002C 2C Relay for power window, driver's door
0x0A22002D 2D Relay for power window, passenger's door
0x0A22002E 2E Relay for power window, driver's side, rear
0x0A22002F 2F Relay for power window, passenger's side, rear
0x0A220030 30 K bus: data transmission disturbed
0x0A220031 31 Wiper potentiometer
0x0A220032 32 Wiper potentiometer
0x0A220033 33 Wipers: interlock active
0x0A220036 36 Wipers: relay or wire for wiper on
0x0A220037 37 Wipers: relay or wire for stage 2
0x0A220038 38 Windscreen washer pump
0x0A22003B 3B interior light
0x0A22003D 3D Boot-lid unlocking: mechanism
0x0A220041 41 Burglar alarm system: pitch sensor
0x0A220042 42 Burglar-al. system: pass.- comport. sensor
0x0A220043 43 Burglar-al. syst pass.-comports
0x0A220044 44 General module V not coded
0x0A220045 45 Central locking: switch ,driver's door
0x0A220046 46 Central locking: switch, passenger door
0x0A220080 80 DWA alarm memory: terminal R
0x0A220081 81 DWA alarm memory: door contact, driver's door
0x0A220082 82 DWA alarm memory: door contact, pass'gr door
0x0A220085 85 DWA alarm memory: rear lid
0x0A220087 87 DWA alarm memory: glove compartment
0x0A220088 88 DWA alarm memory: engine bonnet
0x0A220089 89 DWA alarm memory: pitch sensor
0x0A22008A 8A DWA alarm memory: passenger-comp. sensor, front
0x0A22008B 8B DWA alarm memory: pass.-comp. sensor, rear
0x0A22008D 8D DWA alarm memory: lock contact, driver's door
0x0A22008E 8E DWA alarm memory: lock contact, pass'gr door
0x0A220091 91 Info memory: crash was triggered
0x0A230001 1 Fuse or lead for load circuit 1
0x0A230002 2 Fuse or lead for load circuit 2
0x0A230004 4 Terminal R
0x0A230008 8 General module not coded
0x0A230009 9 General module not coded
0x0A23000A 10 Coding incorrect
0x0A23000B 11 Coding incorrect
0x0A230030 48 Potentiometer for interval time
0x0A230033 51 Pump for windowscreen washer system - short circuit
0x0A230040 64 Interior lights
0x0A230041 65 Interior lighting, short circuit
0x0A230048 72 Relay for wiper motor - short circuit to positive
0x0A230049 73 Relay for wiper motor - open circuit
0x0A23004A 74 Relay for wiper motor, stage 2 - short circuit to positive
0x0A23004B 75 Relay for wiper motor, stage 2 - open circuit
0x0A230050 80 Relay for central-locking drives, rear , unlocking sticks
0x0A230051 81 Relay for central-locking drives, rear , unlocking, does not pick up
0x0A230052 82 Relay for central-locking drives, rear , locking sticks
0x0A230053 83 Relay for central-locking drives, rear , locking, does not pick up
0x0A230054 84 Relay for central-locking drives, rear , double locking sticks
0x0A230055 85 Relay for central-locking drives, rear , double locking, does not pick up
0x0A230056 86 Relay for central-locking drives, top, sticks
0x0A230057 87 Relay for central-locking drives, top, does not pick up
0x0A230058 88 Crash detection
0x0A230059 89 Central-locking drive, driver's door, open circuit
0x0A23005A 90 Central-locking drive, passenger's door, open circuit
0x0A23005B 91 Central-locking drive, driver's door, short circuit
0x0A23005C 92 Central-locking drive, passenger's door, short circuit
0x0A230060 96 Relay for PW motor, driver's door, sticks
0x0A230061 97 Relay for PW motor, driver's door, does not pick up
0x0A230062 98 Relay for PW motor, driver's door, sticks
0x0A230063 99 Relay for PW motor, driver's door, does not pick up
0x0A230064 10 Relay for PW motor, passenger's door, sticks
0x0A230065 10 Relay for PW motor, passenger's door, does not pick up
0x0A230066 10 Relay for PW motor, passenger's door, sticks
0x0A230067 10 Relay for PW motor, passenger's door, does not pick up
0x0A230068 104 Relay for PW motor, driver's side rear, sticks
0x0A230069 105 Relay for PW motor, driver's side rear, does not pick up
0x0A23006A 106 Relay for PW motor, driver's side rear, sticks
0x0A23006B 107 Relay for PW motor, driver's side rear, does not pick up
0x0A23006C 108 Relay for PW motor, passenger's side rear, sticks
0x0A23006D 109 Relay for PW motor, passenger's side rear, does not pick up
0x0A23006E 110 Relay for PW motor, passenger's side rear, sticks
0x0A23006F 111 Relay for PW motor, passenger's side rear, does not pick up
0x0A23007F 127 Slide/tilt sunroof module
0x0A230080 128 Servotronic servo valve, open circuit
0x0A230081 129 Servotronic servo valve, open circuit
0x0A230082 130 Speedo signal interrupted
0x0A230092 146 Tilt sensor for anti-theft alarm system
0x0A230093 147 LED for anti-theft alarm system, short circuit to positive
0x0A230094 148 LED for anti-theft alarm system, open circuit
0x0A230095 149 Passenger-compartment sensor
0x0A2300A1 161 Mirror heater, driver's door, short circuit
0x0A2300A3 163 Mirror heater, passenger's door, short circuit
0x0A2300B1 177 Motor, mirror retraction, driver's door, short circuit
0x0A2300B3 179 Motor, mirror retraction, passenger's door, short circuit
0x0A2300B9 185 Transport mode active
0x0A250001 01 Fuse for IB and TSH
0x0A250002 02 Fuse for ZV
0x0A250003 03 Fuse for front FHs
0x0A250004 04 Terminal R
0x0A250005 05 Terminal 15
0x0A250006 06 Ground for ZV FHs
0x0A250008 14 Crash sensor
0x0A250009 15 Lock contact
0x0A25000A 16 Pin contact, driver's door
0x0A25000B 17 Pin contact, driver's door - open circuit
0x0A25000C 18 Pin contact, passenger's door
0x0A25000D 19 Pin contact, passenger door - open circuit
0x0A25000E 20 Pin contact, trunk lid
0x0A25000F 21 Pin contact, trunk lid - open circuit
0x0A250011 25 Pulse generator for front power windows short-circuited
0x0A250012 36 FH drive, rear , (driver's side) not functioning
0x0A250013 37 Wire to rear FH driver (driver's side) is short-circuited to ground
0x0A250014 38 Relay for rear FH drive (driver's side) sticks
0x0A250015 39 FH drive, rear, (passenger's side) not functioning
0x0A250016 40 Wire to rear FH drive (pseeneger's side) is short-circuited to ground
0x0A250017 41 Relay for rear FH drive (passenger's side) sticks
0x0A250018 42 Wire to relay module - driver's side FH, rear
0x0A250019 43 Wire to relay module - driver's side FH, rear, short circuit to B+
0x0A25001A 44 Wire to relay module - passenger's side FH, rear
0x0A25001B 45 Wire to relay module - passenger's side FH, rear short circuit to B+
0x0A25001C 46 Wire to relay module - driver's side FH, rear
0x0A25001D 47 Wire to relay module - driver's side FH, rear, short circuit to B+
0x0A25001E 48 Wire to relay module - passenger's side FH, rear
0x0A25001F 49 Wire to relay module - passenger's side FH, rear, short circuit to B+
0x0A250022 54 Wire to convertible-top module - short circuit to ground
0x0A250023 55 Wire to crash-alarm sensor is short-circuit to B+
0x0A250024 56 LED fro DWA or wire is short-circuit to B+
0x0A250025 57 LED for DWA or wire os short-circuit to ground or open-circuited
0x0A250026 58 DWA relay or the wire is short-circuited to B+
0x0A250027 59 Pitch sensor or interior sensor or short circuit in wire
0x0A250028 7 Module not need
0x0A250029 8 Internal fault
0x0A25002A 9 Interior lights. short circuit or overload
0x0A25002B 10 Electrical-load cutoff wire or lamp
0x0A25002C 11 Electrical-load cutoff - short circuit or overload
0x0A25002D 12 Door-lock heater
0x0A25002E 13 Door-lock heater - short circuit
0x0A250030 22 Relay for ZV unlocking does not pick up
0x0A250031 62 Relay for ZV unlocking sticks
0x0A250032 23 Relay for ZV locking does not pick up
0x0A250033 63 Relay for ZV locking sticks
0x0A250034 24 Relay for ZV double-locking does not pick up
0x0A250035 64 Relay for ZV double-locking sticks
0x0A250036 26 Relay for dirver's door FH does not pick up
0x0A250037 27 Realy for driver's door FH sticks
0x0A250038 28 Relay for driver's door FH does not pick up
0x0A250039 29 Relay for driver's door FH sticks
0x0A25003A 30 Relay for passenger's door FH does not stick up
0x0A25003B 31 Relay for passenger's door FH sticks
0x0A25003C 32 Relay for passenger's door FH does not pick up
0x0A25003D 33 Relay for passenger's door FH sticks
0x0A25003E 34 Thermoswitch in the driver's door FH motor has responded
0x0A25003F 35 Thermoswitch in the passenger-door FH motor has responded
0x0A250042 50 FH drive, driver's side, rear, stiff
0x0A250043 51 FH drive, passenger's side, rear, stiff
0x0A250044 60 Fuse for pitch sensor
0x0A250045 61 Fues for passenger-compartment sensor
0x0A260000 00 General module 5: Internal fault, voltage
0x0A260001 01 Fuse for interior lights, washer pump
0x0A260002 02 Fuse for central locking
0x0A260003 03 Central locking, crash input
0x0A260004 04 Transport mode active
0x0A260006 06 Anti-theft alarm system, STDWA signal
0x0A260007 07 Anti-theft alarm system, STDWA signal
0x0A260008 08 Fuse for power window unit
0x0A260009 09 Motor or relay for power window unit, front, driver's side
0x0A26000A 0A Motor or relay for power window unit, front, passenger's side
0x0A26000B 0B Motor or relay for power window unit, rear, driver's side
0x0A26000C 0C Motor or relay for power window unit, rear, passenger's side
0x0A26000D 0D Anti-trap protection for power window unit, front, driver's side
0x0A26000E 0E Anti-trap protection for power window unit, front, passenger's side
0x0A26000F 0F Anti-trap protection for power window unit, rear, driver's side
0x0A260010 10 Anti-trap protection for power window unit, rear, passenger's side
0x0A260020 20 General module 5: Internal fault, processor
0x0A260021 21 General module 5: Internal fault, processor
0x0A260022 22 General module 5: Internal fault, clock generator
0x0A260023 23 General module 5: Internal fault, EEPROM
0x0A260024 24 Relay for central locking, locking
0x0A260025 25 Relay for central locking, unlocking
0x0A260026 26 Relay for central locking, double locking
0x0A260027 27 Relay for central locking driver's door
0x0A260028 28 Relay for central locking, locking
0x0A260029 29 Relay for central locking, unlocking
0x0A26002A 2A Relay for central locking, double locking
0x0A26002B 2B Relay for central locking driver's door
0x0A26002C 2C Relay for power window unit, front, driver's side
0x0A26002D 2D Relay for power window unit, front, passenger's side
0x0A26002E 2E Relay for power window unit, rear, driver's side
0x0A26002F 2F Relay for power window unit, rear, passenger's side
0x0A260030 30 K bus: data transmission disturbed
0x0A260031 31 Wiper potentiometer
0x0A260032 32 Wiper potentiometer
0x0A260033 33 Wipers: interlock active
0x0A260036 36 Relay or wire for wiper on
0x0A260037 37 Relay or wire for wiper stage 2
0x0A260038 38 Windscreen washer pump
0x0A26003A 3A Relay pump or wire for headlight washers
0x0A26003B 3B Interior lights, short circuit
0x0A26003C 3C Load/consumer shutdown, output VA2: short circuit to ground
0x0A26003D 3D Drive for rear-lid unlocking
0x0A26003F 3F Relay for rear-window unlocking
0x0A260041 41 Tilt sensor for anti-theft alarm system
0x0A260042 42 Anti-theft alarm system, interior movement detector
0x0A260043 43 Anti-theft alarm system, interior movement detector, rear
0x0A260044 44 General module 5 not coded
0x0A260045 45 Central locking, switch, driver's door
0x0A260046 46 Central locking, switch, passenger's door
0x0A260048 48 Interior lights, open circuit
0x0A260049 49 Load/consumer shutdown, output VA2: short circuit to positive
0x0A26004A 4A Load/consumer shutdown: short circuit to ground
0x0A26004B 4B General module 5: Internal fault, processor
0x0A26004C 4C Passenger mirror: Internal fault
0x0A26004D 4D Mirror heater, front passenger mirror: open circuit
0x0A26004E 4E Mirror heater, front passenger mirror: short circuit
0x0A26004F 4F Potentiometer, front passenger mirror, horizontal
0x0A260050 50 Potentiometer, front passenger mirror, vertical
0x0A260051 51 Motor, front passenger mirror, horizontal: open circuit
0x0A260052 52 Motor, front passenger mirror, horizontal: short circuit
0x0A260053 53 Motor, front passenger mirror, vertical: open circuit
0x0A260054 54 Motor, front passenger mirror, vertical: short circuit
0x0A260055 55 Motor, pivoting front passenger mirror: open circuit
0x0A260056 56 Motor, pivoting front passenger mirror: short circuit
0x0A26005B 5B Driver's mirror: internal fault
0x0A26005C 5C Mirror heater, driver's mirror: open circuit
0x0A26005D 5D Mirror heater, driver's mirror: short circuit
0x0A26005E 5E Potentiometer, driver's mirror, horizontal
0x0A26005F 5F Potentiometer, driver's mirror, vertical
0x0A260060 60 Motor, driver's mirror, horizontal: open circuit
0x0A260061 61 Motor, driver's mirror, horizontal: short circuit
0x0A260062 62 Motor, driver's mirror, vertical: open circuit
0x0A260063 63 Motor, driver's mirror, vertical: short circuit
0x0A260064 64 Motor, pivoting driver's mirror: open circuit
0x0A260065 65 Motor, pivoting driver's mirror: short circuit
0x0A26006A 6A LIN bus: no response, switch block
0x0A26006B 6B LIN bus: no response, passenger mirror
0x0A26006C 6C LIN bus: no response, driver's mirror
0x0A26006D 6D Power-window switch, front left, in switch block: signal invalid
0x0A26006E 6E Power-window switch, front right, in switch block: signal invalid
0x0A26006F 6F Power-window switch, rear left, in switch block: signal invalid
0x0A260070 70 Power-window switch, rear right, in switch block: signal invalid
0x0A260071 71 Mirror adjustment switch, horizontal, in switch block: signal invalid
0x0A260072 72 Mirror adjustment switch, vertical, in switch block: signal invalid
0x0A260080 80 DWA alarm memory,terminal R
0x0A260081 81 DWA alarm memory,door contact, drive's door
0x0A260082 82 DWA alarm memory,door contact, passenger's door
0x0A260083 83 DWA alarm memory,door contact,rear,drive's side
0x0A260084 84 DWA alarm memory,door contact,rear,passenger's side
0x0A260085 85 DWA alarm memory,rear-lid
0x0A260086 86 DWA alarm memory,rear-window
0x0A260087 87 Anti-theft alarm memory,tyre pressure control
0x0A260088 88 DWA alarm memory,engine-bonnet
0x0A260089 89 DWA alarm memory,pitch sensor
0x0A26008A 8A DWA alarm memory,passenger-comp.sensor,front
0x0A26008B 8B Anti-theft alarm memory,glovebox(Convertible)/interior movement detector,rear(Touring)
0x0A26008D 8D DWA alarm memory,lock contact,drive's door
0x0A26008E 8E DWA alarm memory,lock contact,passanger's door
0x0A260091 91 Info memory:crash was triggered
0x0A270000 00 General module 5: Internal fault, voltage
0x0A270001 01 Fuse for interior lights, washer pump
0x0A270002 02 Fuse for central locking
0x0A270003 03 Central locking, crash input
0x0A270006 06 Anti-theft alarm system, STDWA signal
0x0A270007 07 Anti-theft alarm system, STDWA signal
0x0A270008 08 Fuse for power window unit
0x0A270009 09 Motor or relay for power window unit, front, driver's side
0x0A27000A 0A Motor or relay for power window unit, front, passenger's side
0x0A27000B 0B Motor or relay for power window unit, rear, driver's side
0x0A27000C 0C Motor or relay for power window unit, rear, passenger's side
0x0A27000D 0D Anti-trap protection for power window unit, front, driver's side
0x0A27000E 0E Anti-trap protection for power window unit, front, passenger's side
0x0A27000F 0F Anti-trap protection for power window unit, rear, driver's side
0x0A270010 10 Anti-trap protection for power window unit, rear, passenger's side
0x0A270020 20 General module 5: Internal fault, processor
0x0A270021 21 General module 5: Internal fault, processor
0x0A270022 22 General module 5: Internal fault, clock generator
0x0A270023 23 General module 5: Internal fault, EEPROM
0x0A270024 24 Relay for central locking, locking
0x0A270025 25 Relay for central locking, unlocking
0x0A270026 26 Relay for central locking, double locking
0x0A270027 27 Relay for central locking driver's door
0x0A270028 28 Relay for central locking, locking
0x0A270029 29 Relay for central locking, unlocking
0x0A27002A 2A Relay for central locking, double locking
0x0A27002B 2B Relay for central locking driver's door
0x0A27002C 2C Relay for power window unit, front, driver's side
0x0A27002D 2D Relay for power window unit, front, passenger's side
0x0A27002E 2E Relay for power window unit, rear, driver's side
0x0A27002F 2F Relay for power window unit, rear, passenger's side
0x0A270030 30 K bus: data transmission disturbed
0x0A270031 31 Wiper potentiometer
0x0A270032 32 Wiper potentiometer
0x0A270033 33 Wipers: interlock active
0x0A270036 36 Relay or wire for wiper on
0x0A270037 37 Relay or wire for wiper stage 2
0x0A270038 38 Windscreen washer pump
0x0A27003A 3A Relay pump or wire for headlight washers
0x0A27003B 3B Interior lights, short circuit
0x0A27003C 3C Load/consumer shutdown, output VA2: short circuit to ground
0x0A27003D 3D Drive for rear-lid unlocking
0x0A27003F 3F Relay for rear-window unlocking
0x0A270041 41 Tilt sensor for anti-theft alarm system
0x0A270042 42 Anti-theft alarm system, interior movement detector
0x0A270043 43 Anti-theft alarm system, interior movement detector, rear
0x0A270044 44 General module 5 not coded
0x0A270045 45 Central locking, switch, driver's door
0x0A270046 46 Central locking, switch, passenger's door
0x0A270047 47 General module 5: Internal fault, processor
0x0A270048 48 Interior lights, open circuit
0x0A270049 49 Load/consumer shutdown, output VA2: short circuit to positive
0x0A27004A 4A Load/consumer shutdown: short circuit to ground
0x0A27004B 4B General module 5: Internal fault, processor
0x0A27004C 4C Passenger mirror: Internal fault
0x0A27004D 4D Mirror heater, front passenger mirror: open circuit
0x0A27004E 4E Mirror heater, front passenger mirror: short circuit
0x0A27004F 4F Potentiometer, front passenger mirror, horizontal
0x0A270050 50 Potentiometer, front passenger mirror, vertical
0x0A270051 51 Motor, front passenger mirror, horizontal: open circuit
0x0A270052 52 Motor, front passenger mirror, horizontal: short circuit
0x0A270053 53 Motor, front passenger mirror, vertical: open circuit
0x0A270054 54 Motor, front passenger mirror, vertical: short circuit
0x0A270055 55 Motor, pivoting front passenger mirror: open circuit
0x0A270056 56 Motor, pivoting front passenger mirror: short circuit
0x0A27005B 5B Driver's mirror: internal fault
0x0A27005C 5C Mirror heater, driver's mirror: open circuit
0x0A27005D 5D Mirror heater, driver's mirror: short circuit
0x0A27005E 5E Potentiometer, driver's mirror, horizontal
0x0A27005F 5F Potentiometer, driver's mirror, vertical
0x0A270060 60 Motor, driver's mirror, horizontal: open circuit
0x0A270061 61 Motor, driver's mirror, horizontal: short circuit
0x0A270062 62 Motor, driver's mirror, vertical: open circuit
0x0A270063 63 Motor, driver's mirror, vertical: short circuit
0x0A270064 64 Motor, pivoting driver's mirror: open circuit
0x0A270065 65 Motor, pivoting driver's mirror: short circuit
0x0A27006A 6A LIN bus: no response, switch block
0x0A27006B 6B LIN bus: no response, passenger mirror
0x0A27006C 6C LIN bus: no response, driver's mirror
0x0A27006D 6D Power-window switch, front left, in switch block: signal invalid
0x0A27006E 6E Power-window switch, front right, in switch block: signal invalid
0x0A27006F 6F Power-window switch, rear left, in switch block: signal invalid
0x0A270070 70 Power-window switch, rear right, in switch block: signal invalid
0x0A270071 71 Mirror adjustment switch, horizontal, in switch block: signal invalid
0x0A270072 72 Mirror adjustment switch, vertical, in switch block: signal invalid
0x0A270073 73 Spray-nozzle heater, left: short circuit to ground
0x0A270074 74 Spray-nozzle heater, left: open circuit
0x0A270075 75 Spray-nozzle heater, right: short circuit to ground
0x0A270076 76 Spray-nozzle heater, right: open circuit
0x0A270080 80 Anti-theft alarm memory, terminal R
0x0A270081 81 Anti-theft alarm memory, door contact, front, drive's side
0x0A270082 82 Anti-theft alarm memory, door contact, front, passenger's side
0x0A270083 83 Anti-theft alarm memory, door contact, rear, drive's side
0x0A270084 84 Anti-theft alarm memory, door contact, rear, passenger, rear
0x0A270085 85 Anti-theft alarm memory, rear-lid contact
0x0A270086 86 Anti-theft alarm memory, rear-window contact
0x0A270087 87 Anti-theft alarm memory, tyre pressure control
0x0A270088 88 Anti-theft alarm memory, engine-bonnet/hood contact
0x0A270089 89 Anti-theft alarm memory, tilt sensor
0x0A27008A 8A Anti-theft alarm memory, interior movement detector, front
0x0A27008B 8B Anti-theft alarm memory, glovebox(Convertible)/interior movement detector, rear(Touring)
0x0A27008D 8D Anti-theft alarm memory, lock contact, drive's door
0x0A27008E 8E Anti-theft alarm memory, lock contact, passenger's door
0x0A27008F 8F Anti-theft alarm memory, panic mode active
0x0A270090 90 Battery voltage: open circuit
0x0A270091 91 Crash input active
0x0A270092 92 Central locking: repeat interlock
0x0A270093 93 Unlocking rear lid: repeat interlock
0x0A270094 94 Unlocking rear window: repeat interlock
0x0A270095 95 Power window: repeat interlock
0x0A270097 97 Mirror pivoting: repeat interlock
Share this post
Link to post
Коды ошибок VAG (отчасти схожи с ошибками BMW, а остальные могут помочь правильно перевести с английского ошибки BMW.)
Расшифровка кодов ошибок протокола VAG (автомобили Audi, Skoda, Volkswagen).
Коды ошибок Описание
VAG OBDII
16394 P0010 Ряд 1: сбой в работе регулятора фаз газораспределения
16395 P0011 Ряд 1: сдвиг фаз газораспределения в позднюю сторону Не достигнуто номинальное значение
16396 P0012 Ряд 1: сдвиг фаз газораспределения в раннюю сторону Не достигнуто номинальное значение
16397 P0013 Ряд 1, распределительный вал выпускных клапанов: сбой в работе регулятора фаз газораспределения
16398 P0014 Ряд 1, распределительный вал выпускных клапанов: сдвиг фаз газораспределения в позднюю сторону Не достигнуто номинальное значение
16399 P0015 Ряд 1, распределительный вал выпускных клапанов: сдвиг фаз газораспределения в раннюю сторону Не достигнуто номинальное значение
16400 P0016 Ряд 1, датчик положения распредвала.-G40/датчик положения коленвала-G28: несоответствие сигналов
16401 P0017 Ряд 1, датчик положения распредвала.-G300/датчик положения коленвала-G28: несоответствие сигналов
16402 P0018 Ряд 2, датчик положения распредвала.-G163/датчик положения коленвала-G28: несоответствие сигналов
16403 P0019 Ряд 2, датчик положения распредвала.-G301/датчик положения коленвала-G28: несоответствие сигналов
16404 P0020 Ряд 2: сбой в работе регулятора фаз газораспределения
16405 P0021 Ряд 2: сдвиг фаз газораспределения в позднюю сторону Не достигнуто номинальное значение
16406 P0022 Ряд 2: сдвиг фаз газораспределения в раннюю сторону Не достигнуто номинальное значение
16407 P0023 Ряд 2, распределительный вал выпускных клапанов: сбой в работе регулятора фаз газораспределения
16408 P0024 Ряд 2, распределительный вал выпускных клапанов: сдвиг фаз газораспределения в позднюю сторону Не достигнуто номинальное значение
16409 P0025 Ряд 2, распределительный вал выпускных клапанов: сдвиг фаз газораспределения в раннюю сторону Не достигнуто номинальное значение
16414 P0030 Ряд 1-зонд 1: обрыв электрической цепи подогрева
16415 P0031 Ряд 1-зонд 1: короткое замыкание на массу электрической цепи подогрева
16416 P0032 Ряд 1-зонд 1: короткое замыкание на плюс электрической цепи подогрева
16417 P0033 Перепускной клапан турбонагнетателя Сбой в электрической цепи
16418 P0034 Перепускной клапан турбонагнетателя: короткое замыкание на массу
16419 P0035 Перепускной клапан турбонагнетателя
16420 P0036 Ряд 1-зонд 2: обрыв электрической цепи подогрева
16421 P0037 Ряд 1-зонд 2, электрическая цепь подогрева: короткое замыкание на массу
16422 P0038 Ряд 1-зонд 2, короткое замыкание на плюс электрической цепи подогрева
16423 P0039 Перепускной клапан турбонагнетателя-N249: недостоверный сигнал
16424 P0040 Перепутан ряд 1-зонд 1 и Ряд 2-зонд 1
16425 P0041 Перепутан ряд 1-зонд 2 и Ряд 2-зонд 2
16426 P0042 Ряд 1-зонд 3: обрыв электрической цепи подогрева
16427 P0043 Ряд 1-зонд 3: короткое замыкание на массу электрической цепи подогрева
16428 P0044 Ряд 1-зонд 3: короткое замыкание на плюс электрической цепи подогрева
16434 P0050 Ряд 2-зонд 1: сбой в электрической цепи подогрева
16435 P0051 Ряд 2-зонд 1: короткое замыкание на массу электрической цепи подогрева
16436 P0052 Ряд 2-зонд 1: короткое замыкание на плюс электрической цепи подогрева
16440 P0056 Ряд 2-зонд 2: сбой в электрической цепи подогрева
16441 P0057 Ряд 2-зонд 2: короткое замыкание на массу электрической цепи подогрева
16442 P0058 Ряд 2-зонд 2: короткое замыкание на плюс электрической цепи подогрева
16448 P0064 Ряд 2-зонд 3: короткое замыкание на плюс электрической цепи подогрева
16449 P0065 Пневматический управляющий клапан форсунок-N212: недостоверный сигнал
16450 P0066 Пневматический управляющий клапан форсунок-N212: короткое замыкание на массу
16451 P0067 Пневматический управляющий клапан форсунок-N212: короткое замыкание на плюс
16452 P0068 Давление на впуске/масса воздуха отклонение угла положения дроссельной заслонки
16453 P0069 Давление воздуха на впуске давление воздуха: неправильное соотношение
16455 P0071 Датчик температуры наружного воздуха-G17
16456 P0072 Датчик температуры наружного воздуха-G17: слишком низкий уровень сигнала
16457 P0073 Датчик температуры наружного воздуха-G17: слишком высокий уровень сигнала
16458 P0074 Датчик температуры наружного воздуха-G17: обрыв цепи
16473 P0089 Клапан дозирования топлива: недостоверный сигнал
16474 P0090 Клапан дозирования топлива: сбой в электрической цепи
16475 P0091 Клапан дозирования топлива: короткое замыкание на массу
16476 P0092 Клапан дозирования топлива: короткое замыкание на плюс
16481 P0097 Датчик -2- температуры воздуха на впуске G299: слишком низкий уровень сигнала
16482 P0098 Датчик -2- температуры воздуха на впуске-G299: слишком высокий уровень сигнала
16483 P0099 Датчик -2- температуры воздуха на впуске-G299: нет сигнала
16485 P0101 Расходомер воздуха-G70: недостоверный сигнал
16486 P0102 Расходомер воздуха-G70: слишком низкий уровень сигнала
16487 P0103 Расходомер воздуха-G70: слишком высокий уровень сигнала
16488 P0104 Расходомер воздуха-G70: нет сигнала
16489 P0105 Датчик давления во впускном коллекторе-G71: напряжение питания
16490 P0106 Давление на впуске/давление воздуха=>-G71/-F96: недостоверный сигнал
16491 P0107 Давление на впуске/давление воздуха=>-G71/-F96: слишком низкий уровень сигнала
16492 P0108 Давление на впуске/давление воздуха=>-G71/-F96: слишком высокий уровень сигнала
16495 P0111 Датчик температуры воздуха на впуске-G42: недостоверный сигнал
16496 P0112 Датчик температуры воздуха на впуске-G42: слишком низкий уровень сигнала
16497 P0113 Датчик температуры воздуха на впуске-G42: слишком высокий уровень сигнала
16498 P0114 Датчик температуры воздуха на впуске-G42: нет сигнала
16500 P0116 Датчик температуры охлаждающей жидкости-G62: недостоверный сигнал
16501 P0117 Датчик температуры охлаждающей жидкости-G62: слишком низкий уровень сигнала
16502 P0118 Датчик температуры охлаждающей жидкости-G62, слишком высокий уровень сигнала
16504 P0120 Потенциометр дроссельной заслонки-G69, неисправность в электрической цепи
16505 P0121 Потенциометр дроссельной заслонки-G69, недостоверный сигнал
16506 P0122 Потенциометр дроссельной заслонки-G69: слишком низкий уровень сигнала
16507 P0123 Потенциометр дроссельной заслонки-G69: слишком высокий уровень сигнала
16509 P0125 Не достигнута температура охлаждающей жидкости для лямбда-регулирования
16512 P0128 Клапан в контуре циркуляции охлаждающей жидкости-N214: температура ниже диапазона регулирования
16514 P0130 Ряд 1-зонд 1: сбой в электрической цепи
16515 P0131 Ряд 1-зонд 1: слишком низкое напряжение
16516 P0132 Ряд 1-зонд 1: слишком высокое напряжение
16517 P0133 Ряд 1-зонд 1: время реакции слишком велико
16518 P0134 Ряд 1-зонд 1: нет активности
16519 P0135 Ряд 1-зонд 1: сбой в электрической цепи подогрева
16520 P0136 Ряд 1-зонд 2: сбой в электрической цепи
16521 P0137 Ряд 1-зонд 2: слишком низкое напряжение
16522 P0138 Ряд 1-зонд 2: слишком высокое напряжение
16523 P0139 Ряд 1-зонд 2: слишком низкая скорость сигнала
16524 P0140 Ряд 1-зонд 2: нет активности
16525 P0141 Ряд 1-зонд 2: сбой в электрической цепи подогрева
16526 P0142 Ряд 1-зонд 3: сбой в электрической цепи
16527 P0143 Ряд 1-зонд 3: слишком низкое напряжение
16528 P0144 Ряд 1-зонд 3: слишком высокое напряжение
16529 P0145 Ряд 1-зонд 3: время реакции слишком велико
16530 P0146 Ряд 1-зонд 3: нет активности
16531 P0147 Ряд 1-зонд 3: сбой в электрической цепи подогрева
16533 P0149 Система определения параметров топливо-возд.смеси(ряд 1): отклонение времени впрыска
16534 P0150 Ряд 2-зонд 1: сбой в электрической цепи
16535 P0151 Ряд 2-зонд 1: слишком низкое напряжение
16536 P0152 Ряд 2-зонд 1: слишком высокое напряжение
16537 P0153 Ряд 2-зонд 1: время реакции слишком велико
16538 P0154 Ряд 2-зонд 1: нет активности
16539 P0155 Ряд 2-зонд 1: сбой в электрической цепи подогрева
16540 P0156 Ряд 2-зонд 2: сбой в электрической цепи
16541 P0157 Ряд 2-зонд 2: слишком низкое напряжение
16542 P0158 Ряд 2-зонд 2: слишком высокое напряжение
16543 P0159 Ряд 2-зонд 2: время реакции слишком велико
16544 P0160 Ряд 2-зонд 2: нет активности
16545 P0161 Ряд 2-зонд 2: сбой в электрической цепи подогрева
16546 P0162 Ряд 2-зонд 3: сбой в электрической цепи
16547 P0163 Ряд 2-зонд 3: слишком низкое напряжение
16548 P0164 Ряд 2-зонд 3: слишком высокое напряжение
16549 P0165 Ряд 2-зонд 3: время реакции слишком велико
16550 P0166 Ряд 2-зонд 3: нет активности
16551 P0167 Ряд 2-зонд 3: сбой в электрической цепи подогрева
16554 P0170 Ряд 1: сбой в работе системы определения параметров топливо-возд.смеси
16555 P0171 Ряд 1, система определения параметров топливо-возд.смеси: смесь слишком бедная
16556 P0172 Ряд 1, система определения параметров топливо-возд.смеси: смесь слишком богатая
16557 P0173 Ряд 2: сбой в работе системы определения параметров топливо-возд.смеси
16558 P0174 Ряд 2, система определения параметров топливо-возд.смеси: смесь слишком бедная
16559 P0175 Ряд 2, система определения параметров топливо-возд.смеси: смесь слишком богатая
16561 P0177 Датчик качества топлива G446: недостоверный сигнал
16562 P0178 Датчик качества топлива G446: пройдено нижнее предельное значение
16563 P0179 Датчик качества топлива G446: превышено верхнее предельное значение
16565 P0181 Датчик температуры топлива-G81: недостоверный сигнал
16566 P0182 Датчик температуры топлива-G81: короткое замыкание на массу
16567 P0183 Датчик температуры топлива-G81: обрыв цепи/короткое замыкание на плюс
16570 P0186 Датчик 2 температуры топлива-G248: недостоверный сигнал
16571 P0187 Датчик 2 температуры топлива-G248: короткое замыкание на массу
16572 P0188 Датчик 2 температуры топлива-G248: короткое замыкание на плюс
16574 P0190 Датчик давления топлива-G247: сбой в электрической цепи
16575 P0191 Датчик давления топлива-G247: недостоверный сигнал
16576 P0192 Датчик давления топлива-G247: короткое замыкание на массу
16577 P0193 Датчик давления топлива-G247: короткое замыкание на плюс
16578 P0194 Датчик давления топлива-G247: обрыв цепи
16580 P0196 Датчик температуры масла-G8: недостоверный сигнал
16581 P0197 Датчик температуры масла-G8: слишком низкий уровень сигнала
16582 P0198 Датчик температуры масла-G8: слишком высокий уровень сигнала
16584 P0200 Форсунки: сбой в электрической цепи
16585 P0201 Форсунка цилиндра 1-N30: сбой в электрической цепи
16586 P0202 Форсунка цилиндра 2-N31: сбой в электрической цепи
16587 P0203 Форсунка цилиндра 3-N32: сбой в электрической цепи
16588 P0204 Форсунка цилиндра 4-N33: сбой в электрической цепи
16589 P0205 Форсунка цилиндра 5-N83: сбой в электрической цепи
16590 P0206 Форсунка цилиндра 6-N84, сбой в электрической цепи
16591 P0207 Форсунка цилиндра 7-N85: сбой в электрической цепи
16592 P0208 Форсунка цилиндра 8-N86: сбой в электрической цепи
16593 P0209 Форсунка цилиндра 9-N299: сбой в электрической цепи
16594 P0210 Форсунка цилиндра 10-N300: сбой в электрической цепи
16595 P0211 Форсунка цилиндра 11-N301: сбой в электрической цепи
16596 P0212 Форсунка цилиндра 12-N302: сбой в электрической цепи
16599 P0215 Клапан отключения подачи топлива-N109: сбой в работе
16600 P0216 Клапан управления опережением впрыска-N108: сбой в работе
16603 P0219 Превышена максимальная частота вращения вала двигателя
16605 P0221 Датчик угла поворота 2 привода дроссельной заслонки-G188: недостоверный сигнал
16606 P0222 Датчик угла поворота 2 привода дроссельной заслонки-G188: слишком низкий уровень сигнала
16607 P0223 Датчик угла поворота 2 привода дроссельной заслонки-G188: слишком высокий уровень сигнала
16609 P0225 Датчик положения педали акселератора-G79: напряжение питания
16610 P0226 Датчики 1/2 положения педали акселератора-G79+G185: недостоверный сигнал
16611 P0227 Датчик положения педали акселератора-G79: слишком низкий уровень сигнала
16612 P0228 Датчик положения педали акселератора-G79: слишком высокий уровень сигнала
16614 P0230 Реле топливного насоса-J17, сбой в электрической цепи
16618 P0234 Регулятор давления наддува: выход из диапазона регулирования (больше верхнего предела)
16619 P0235 Регулятор давления наддува: выход из диапазона регулирования (меньше нижнего предела)
16620 P0236 Датчик давления наддува: недостоверный сигнал
16621 P0237 Датчик давления наддува: слишком низкий уровень сигнала
16622 P0238 Датчик давления наддува: слишком высокий уровень сигнала
16624 P0240 Датчик 2 давления наддува-G447: недостоверный сигнал
16625 P0241 Датчик 2 давления наддува-G447: слишком низкий уровень сигнала
16626 P0242 Датчик 2 давления наддува-G447, слишком высокий уровень сигнала
16627 P0243 Электромагн. клапан огранич. давления наддува-N75: обрыв цепи/короткое замыкание на массу
16629 P0245 Электромагн. клапан огранич. давления наддува-N75: короткое замыкание на массу
16630 P0246 Электромагн. клапан огранич. давления наддува-N75: короткое замыкание на плюс
16633 P0249 Электромагн. клапан 2 огранич. давления наддува-N774: обрыв цепи/короткое замыкание на массу
16634 P0250 Электромагн. клапан 2 огранич. давления наддува-N774: короткое замыкание на плюс
16635 P0251 Неисправен насос высокого давления
16636 P0252 Регулирование начала впрыска, диапазон регулирования
16645 P0261 Форсунка цилиндра 1-N30: короткое замыкание на массу
16646 P0262 Форсунка цилиндра 1-N30: короткое замыкание на плюс
16647 P0263 Отклонение количества впрыскиваемого топлива на цилиндре 1
16648 P0264 Форсунка цилиндра 2-N31: короткое замыкание на массу
16649 P0265 Форсунка цилиндра 2-N31: короткое замыкание на плюс
16650 P0266 Отклонение количества впрыскиваемого топлива на цилиндре 2
16651 P0267 Форсунка цилиндра 3-N32: короткое замыкание на массу
16652 P0268 Форсунка цилиндра 3-N32, короткое замыкание на плюс
16653 P0269 Отклонение количества впрыскиваемого топлива на цилиндре 3
16654 P0270 Форсунка цилиндра 4-N33: короткое замыкание на массу
16655 P0271 Форсунка цилиндра 4-N33: короткое замыкание на плюс
16656 P0272 Отклонение количества впрыскиваемого топлива на цилиндре 4
16657 P0273 Форсунка цилиндра 5-N83: короткое замыкание на массу
16658 P0274 Форсунка цилиндра 5-N83: короткое замыкание на плюс
16659 P0275 Отклонение количества впрыскиваемого топлива на цилиндре 5
16660 P0276 Форсунка цилиндра 6-N84: короткое замыкание на массу
16661 P0277 Форсунка цилиндра 6-N84: короткое замыкание на плюс
16662 P0278 Отклонение количества впрыскиваемого топлива на цилиндре 6
16663 P0279 Форсунка цилиндра 7-N85: короткое замыкание на массу
16664 P0280 Форсунка цилиндра 7-N85: короткое замыкание на плюс
16665 P0281 Отклонение количества впрыскиваемого топлива на цилиндре 7
16666 P0282 Форсунка цилиндра 8-N865: короткое замыкание на массу
16667 P0283 Форсунка цилиндра 8-N86: короткое замыкание на плюс
16668 P0284 Отклонение количества впрыскиваемого топлива на цилиндре 8
16669 P0285 Форсунка цилиндра 9-299: короткое замыкание на массу
16670 P0286 Форсунка цилиндра 9-299: короткое замыкание на плюс
16672 P0288 Форсунка цилиндра 10-N300: короткое замыкание на массу
16673 P0289 Форсунка цилиндра 10-N300: короткое замыкание на плюс
16675 P0291 Форсунка цилиндра 11-N301: короткое замыкание на массу
16676 P0292 Форсунка цилиндра 11-N301: короткое замыкание на плюс
16678 P0294 Форсунка цилиндра 12-N302: короткое замыкание на массу
16679 P0295 Форсунка цилиндра 12-N302: короткое замыкание на плюс
16683 P0299 Регулятор давления наддува, выход из диапазона регулирования (меньше нижнего предела)
16684 P0300 Обнаружен пропуск воспламенения
16685 P0301 Цилиндр 1: обнаружен пропуск воспламенения
16686 P0302 Цилиндр 2: обнаружен пропуск воспламенения
16687 P0303 Цилиндр 3: обнаружен пропуск воспламенения
16688 P0304 Цилиндр 4: обнаружен пропуск воспламенения
16689 P0305 Цилиндр 5: обнаружен пропуск воспламенения
16690 P0306 Цилиндр 6: обнаружен пропуск воспламенения
16691 P0307 Цилиндр 7: обнаружен пропуск воспламенения
16692 P0308 Цилиндр 8: обнаружен пропуск воспламенения
16693 P0309 Цилиндр 9: обнаружен пропуск воспламенения
16694 P0310 Цилиндр 10: обнаружен пропуск воспламенения
16695 P0311 Цилиндр 11: обнаружен пропуск воспламенения
16696 P0312 Цилиндр 12: обнаружен пропуск воспламенения
16697 P0313 Обнаружен пропуск воспламенения, причина: недостаток топлива
16698 P0314 Пропуск воспламенения в отдельных цилиндрах
16702 P0318 Информ. о плохой дороге/ заданный момент двиг. от блока упр. ABS: сбой в электрической цепи
16705 P0321 Датчик оборотов двигателя-G28: недостоверный сигнал
16706 P0322 Датчик оборотов двигателя-G28: нет сигнала
16708 P0324 Ошибка регулирования по детонации
16709 P0325 Датчик детонации 1-G61: сбой в электрической цепи
16710 P0326 Датчик детонации 1-G61: недостоверный сигнал
16711 P0327 Датчик детонации 1-G61: слишком низкий уровень сигнала
16712 P0328 Датчик детонации 1-G61: слишком высокий уровень сигнала
16715 P0331 Датчик детонации 2-G66: недостоверный сигнал
16716 P0332 Датчик детонации 2-G66: слишком низкий уровень сигнала
16717 P0333 Датчик детонации 2-G66: слишком высокий уровень сигнала
16719 P0335 Датчик оборотов двигателя-G28: сбой в работе
16720 P0336 Датчик оборотов двигателя-G28: нет зубца
16721 P0337 Датчик положения коленвала=>датчик-G4, слишком низкий уровень сигнала
16724 P0340 Датчик положения распредвала: сбой в работе
16725 P0341 Датчик положения распредвала=>датчик-G40: недостоверный сигнал
16726 P0342 Датчик положения распредвала=>датчик-G40: слишком низкий уровень сигнала
16727 P0343 Датчик положения распредвала=>датчик-G40: слишком высокий уровень сигнала
16729 P0345 Датчик положения распредвала=>датчик-G163: сбой в электрической цепи
16730 P0346 Датчик положения распредвала=>датчик-G163: недостоверный сигнал
16731 P0347 Датчик положения распредвала=>датчик-G163: короткое замыкание на массу
16732 P0348 Датчик положения распредвала=>датчик-G163: короткое замыкание на плюс
16735 P0351 Управление зажиганием, цилиндр 1: сбой в работе
16736 P0352 Управление зажиганием, цилиндр 2: сбой в работе
16737 P0353 Управление зажиганием, цилиндр 3: сбой в работе
16738 P0354 Управление зажиганием, цилиндр 4: сбой в работе
16739 P0355 Управление зажиганием, цилиндр 5: сбой в работе
16740 P0356 Управление зажиганием, цилиндр 6: сбой в работе
16741 P0357 Управление зажиганием, цилиндр 7: сбой в работе
16742 P0358 Управление зажиганием, цилиндр 8: сбой в работе
16743 P0359 Управление зажиганием, цилиндр 9: сбой в работе
16744 P0360 Управление зажиганием, цилиндр 10: сбой в работе
16745 P0361 Управление зажиганием, цилиндр 11: сбой в работе
16746 P0362 Управление зажиганием, цилиндр 12: сбой в работе
16749 P0365 Датчик положения распредвала=>датчик-G300: сбой в работе
16750 P0366 Датчик положения распредвала=>датчик-G300: недостоверный сигнал
16751 P0367 Датчик положения распредвала=>датчик-G300: слишком низкий уровень сигнала
16752 P0368 Датчик положения распредвала=>датчик-G300: слишком высокий уровень сигнала
16764 P0380 Свеча накаливания-Q6: сбой в электрической цепи
16774 P0390 Датчик положения распредвала=>датчик-G301: сбой в работе
16775 P0391 Датчик положения распредвала=>датчик-G301: недостоверный сигнал
16776 P0392 Датчик положения распредвала=>датчик-G301: слишком низкий уровень сигнала
16777 P0393 Датчик положения распредвала=>датчик-G301: слишком высокий уровень сигнала
16784 P0400 Система рециркуляции ОГ: сбой в работе
16785 P0401 Система рециркуляции ОГ: слишком низкая пропускная способность
16786 P0402 Система рециркуляции ОГ: слишком высокая пропускная способность
16787 P0403 Клапан рециркуляции ОГ-N18: сбой в работе
16788 P0404 Система рециркуляции ОГ, диапазон регулирования
16789 P0405 Датчик температуры в системе рециркуляции ОГ-G98: слишком низкий уровень сигнала
16790 P0406 Датчик температуры в системе рециркуляции ОГ-G98: слишком высокий уровень сигнала
16791 P0407 Потенциометр системы рециркуляции ОГ-G212: слишком низкий уровень сигнала
16792 P0408 Потенциометр системы рециркуляции ОГ-G212: слишком высокий уровень сигнала
16794 P0410 Система подачи вторичного воздуха: сбой в работе
16795 P0411 Система подачи вторичного воздуха: снижение пропускной способности
16796 P0412 Клапан управления подачей вторичного воздуха-N112: сбой в электрической цепи
16797 P0413 Клапан управления подачей вторичного воздуха-N112: обрыв цепи
16798 P0414 Клапан управления подачей вторичного воздуха-N112: короткое замыкание
16799 P0415 Клапан 2 управления подачей вторичного воздуха-N320: сбой в электрической цепи
16800 P0416 Клапан 2 управления подачей вторичного воздуха-N320: обрыв цепи
16801 P0417 Клапан 2 управления подачей вторичного воздуха-N320: короткое замыкание
16802 P0418 Реле насоса вторичного воздуха-J299: сбой в работе
16803 P0419 Реле насоса вторичного воздуха 2-J545: сбой в работе
16804 P0420 Ряд 1, система катализаторов: снижение эффективности
16805 P0421 Передний катализатор, ряд 1: снижение эффективности
16806 P0422 Ряд 1, основной катализатор: снижение эффективности
16811 P0427 Датчик температуры 1 катализатора-G20: короткое замыкание на массу
16812 P0428 Датчик температуры 1 катализатора-G20: короткое замыкание на плюс
16814 P0430 Система катализаторов, ряд 2: снижение эффективности
16815 P0431 Передний катализатор, ряд 2: снижение эффективности
16816 P0432 Ряд 2, основной катализатор: снижение эффективности
16820 P0436 Датчик температуры 2 катализатора-G132, недостоверный сигнал
16821 P0437 Датчик температуры 2 катализатора-G132: короткое замыкание на массу
16822 P0438 Датчик температуры 2 катализатора-G132: короткое замыкание на плюс
16824 P0440 Система вентиляции топливного бака: сбой в работе
16825 P0441 Система вентиляции топливного бака: снижение пропускной способности
16826 P0442 Система вентиляции топливного бака: обнаружена небольшая утечка
16827 P0443 Электромагнитный клапан 1 абсорбера с активированным углем-N80: сбой в электрической цепи
16828 P0444 Электромагнитный клапан 1 абсорбера с активированным углем-N80: обрыв цепи
16829 P0445 Электромагнитный клапан 1 абсорбера с активированным углем-N80: короткое замыкание
16833 P0449 Электромагнитный клапан 2 абсорбера с активированным углем-N115: сбой в электрической цепи
16836 P0452 Датчик давления в контуре системы вентиляции топл. бака: слишком низкий уровень сигнала
16837 P0453 Датчик давления в контуре системы вентиляции топл. бака: слишком высокий уровень сигнала
16839 P0455 Система вентиляции топливного бака: обнаружена крупная утечка
16840 P0456 Система вентиляции топливного бака: обнаружена небольшая утечка
16842 P0458 Электромагнитный клапан 1 абсорбера с активированным углем-N80: короткое замыкание на массу
16843 P0459 Электромагнитный клапан 1 абсорбера с активированным углем-N80: короткое замыкание на плюс
16845 P0461 Сигнал уровня топлива в баке: недостоверный сигнал
16846 P0462 Датчик запаса топлива-G: слишком низкий уровень сигнала
16847 P0463 Датчик запаса топлива-G: слишком высокий уровень сигнала
16854 P0470 Датчик 1 давления ОГ-G450: обрыв цепи
16855 P0471 Датчик 1 давления ОГ-G450: недостоверный сигнал
16856 P0472 Датчик 1 давления ОГ-G450: короткое замыкание на массу
16857 P0473 Датчик 1 давления ОГ-G450: короткое замыкание на плюс
16864 P0480 Управление вентилятором радиатора 1: сбой в электрической цепи
16865 P0481 Управление вентилятором радиатора 2: сбой в электрической цепи
16873 P0489 Управление рециркуляцией ОГ: короткое замыкание на массу
16874 P0490 Управление рециркуляцией ОГ: короткое замыкание на плюс
16875 P0491 Система подачи вторичного воздуха, ряд 1: снижение пропускной способности
16876 P0492 Ряд 2, система подачи вторичного воздуха: сбой в работе
16882 P0498 Электромагнитный клапан 2 абсорбера с активированным углем-N115: слишком низкий уровень сигнала
16883 P0499 Электромагнитный клапан 2 абсорбера с активированным углем-N115: слишком высокий уровень сигнала
16885 P0501 Датчик скорости движения автомобиля: недостоверный сигнал
16886 P0502 Датчик скорости движения автомобиля: слишком низкий уровень сигнала
16887 P0503 Датчик скорости движения автомобиля: слишком высокий уровень сигнала
16889 P0505 Система регулирования холостого хода: сбой в работе
16890 P0506 Система регулирования холостого хода: обороты ниже номинального значения
16891 P0507 Система регулирования холостого хода, обороты выше номинального значения
16894 P0510 Датчик положения дроссельной заслонки (выключатель, срабатывающий при установке ДЗ в положение, соответствующее ХХ)-F60: сбой в работе
16897 P0513 Неверный код иммобилайзера
16915 P0531 Сигнал нагрузки от компрессора кондиционера: недостоверный сигнал
16916 P0532 Датчик давления в контуре кондиционера-G65: слишком низкий уровень сигнала
16917 P0533 Датчик давления в контуре кондиционера-G65: слишком высокий уровень сигнала
16928 P0544 Датчик температуры ОГ 1-G235: сбой в электрической цепи
16929 P0545 Датчик температуры ОГ 1-G235: короткое замыкание на массу
16930 P0546 Датчик температуры ОГ 1-G235: короткое замыкание на плюс
16931 P0547 Датчик температуры ОГ 1, ряд 2-G236: сбой в электрической цепи
16932 P0548 Датчик температуры ОГ 1, ряд 2-G236: короткое замыкание на массу
16933 P0549 Датчик температуры ОГ 1, ряд 2-G236: короткое замыкание на плюс
16934 P0550 Регулятор давления на гидроусилителе рулевого управления: сбой в электрической цепи
16935 P0551 Реле давления в контуре усилителя рулевого управления-F88: недостоверный сигнал
16944 P0560 Электропитание: недостоверный сигнал
16945 P0561 Нестабильно напряжение питания
16946 P0562 Электропитание: слишком низкий уровень напряжения
16947 P0563 Электропитание: слишком высокий уровень напряжения
16952 P0568 Переключатель управления круиз-контролем: недостоверный сигнал
16955 P0571 Включатель стоп-сигнала-F: недостоверный сигнал
16981 P0597 Термостат электронного управления системой охлаждения двигателя-F265, обрыв цепи
16982 P0598 Термостат электронного управления системой охлаждения двигателя-F265: короткое замыкание на массу
16983 P0599 Термостат электронного управления системой охлаждения двигателя-F265: короткое замыкание на плюс
16984 P0600 Шина данных-привод: нет сообщения
16985 P0601 Неисправен блок управления
16986 P0602 Программирование блоков управления, сбой в работе
16987 P0603 Неисправен блок управления
16988 P0604 Неисправен блок управления
16989 P0605 Неисправен блок управления
16990 P0606 Неисправен блок управления
16991 P0607 Управляющий модуль: недостоверные данные
16992 P0608 Напряжение питания на датчиках и исполнит. механизмах
16993 P0609 Напряжение питания 2 на датчиках и исполнит. механизмах
16994 P0610 Блок управления двигателя: неправильное кодирование
16997 P0613 Неисправен процессор блока управления коробки передач
16998 P0614 Блок управления коробки передач: неправильная версия ПО
16999 P0615 Подача сигнала управления на реле стартера, обрыв цепи
17000 P0616 Подача сигнала управления на реле стартера: короткое замыкание на массу
17001 P0617 Подача сигнала управления на реле стартера: короткое замыкание на плюс
17011 P0627 Реле электрического топливного насоса 1: сбой в электрической цепи/обрыв цепи
17012 P0628 Реле электрического топливного насоса 1: короткое замыкание на массу
17013 P0629 Реле электрического топливного насоса 1: короткое замыкание на плюс
17018 P0634 Блок управления: отключение по температуре
17022 P0638 Блок дроссельной заслонки-J338: недостоверный сигнал
17023 P0639 Блок дроссельной заслонки 2-J544: недостоверный сигнал
17025 P0641 Опорное напряжение датчика -A- обрыв цепи
17026 P0642 Опорное напряжение датчика -A- слишком низкое
17027 P0643 Опорное напряжение датчика -A- слишком высокое
17029 P0645 Климатическая установка Вход/выход
17034 P0650 Контрольная лампа самодиагностики-K83: сбой в электрической цепи
17035 P0651 Опорное напряжение датчика -В- обрыв цепи
17036 P0652 Опорное напряжение датчика -В- слишком низкое
17037 P0653 Опорное напряжение датчика -В- слишком высокое
17038 P0654 Выходной сигнал оборотов двигателя: сбой в электрической цепи
17040 P0656 Сигнал расхода топлива: сбой в электрической цепи
17041 P0657 Питание компонентов двигателя: обрыв цепи
17042 P0658 Питание компонентов двигателя: слишком низкий уровень
17043 P0659 Питание компонентов двигателя: слишком высокий уровень
17044 P0660 Изменение геометрии впускного коллектора, сбой в электрической цепи
17045 P0661 Изменение геометрии впускного коллектора, короткое замыкание на массу
17046 P0662 Изменение геометрии впускного коллектора, короткое замыкание на плюс
17051 P0667 Внутренний датчик температуры: недостоверный сигнал
17052 P0668 Внутренний датчик температуры: напряжение слишком низкое
17053 P0669 Внутренний датчик температуры: напряжение слишком высокое
17054 P0670 Блок управления свечей накаливания 1, электрическая цепь свечей накаливания: сбой в электрической цепи
17055 P0671 Свеча накаливания цилиндра 1-Q10: сбой в электрической цепи
17056 P0672 Свеча накаливания цилиндра 2-Q11: сбой в электрической цепи
17057 P0673 Свеча накаливания цилиндра 3-Q12: сбой в электрической цепи
17058 P0674 Свеча накаливания цилиндра 4-Q13, сбой в электрической цепи
17059 P0675 Свеча накаливания цилиндра 5-Q14: сбой в электрической цепи
17060 P0676 Свеча накаливания цилиндра 6-Q15: сбой в электрической цепи
17061 P0677 Свеча накаливания цилиндра 7-Q16: сбой в электрической цепи
17062 P0678 Свеча накаливания цилиндра 8-Q17: сбой в электрической цепи
17063 P0679 Свеча накаливания цилиндра 9-Q18: сбой в электрической цепи
17064 P0680 Свеча накаливания цилиндра 10-Q19: сбой в электрической цепи
17065 P0681 Свеча накаливания цилиндра 11-Q20: сбой в электрической цепи
17066 P0682 Свеча накаливания цилиндра 12-Q21: сбой в электрической цепи
17068 P0684 Блок управления свечей накаливания 1=>-J179: недостоверный сигнал
17069 P0685 Основное реле=>-J271: обрыв цепи
17070 P0686 Основное реле=>-J271: короткое замыкание на массу
17071 P0687 Основное реле=>-J271: короткое замыкание на плюс
17072 P0688 Основное реле, контур нагрузки=>-J271, обрыв цепи
17075 P0691 Управление вентилятором радиатора 1: короткое замыкание на массу
17076 P0692 Управление вентилятором радиатора 1: короткое замыкание на плюс
17077 P0693 Управление вентилятором радиатора 2: короткое замыкание на массу
17078 P0694 Управление вентилятором радиатора 2: короткое замыкание на плюс
17081 P0697 Опорное напряжение датчика -С- обрыв цепи
17082 P0698 Опорное напряжение датчика -С- слишком низкое
17083 P0699 Опорное напряжение датчика -С- слишком высокое
17084 P0700 Неисправен блок управления
17085 P0701 Неисправен блок управления
17086 P0702 Неисправен блок управления
17087 P0703 Выключатель стоп-сигнала-F: сбой в электрической цепи
17088 P0704 Датчик педали сцепления-F36: недостоверный сигнал
17089 P0705 Датчик включенной передачи=>-F125: сбой в электрической цепи
17090 P0706 Датчик включенной передачи=>-F125: недостоверный сигнал
17091 P0707 Датчик включенной передачи=>-F125: слишком низкий уровень сигнала
17092 P0708 Датчик включенной передачи=>-F125: слишком высокий уровень сигнала
17094 P0710 Датчик температуры масла КП-G93, сбой в электрической цепи
17095 P0711 Датчик температуры масла КП-G93: недостоверный сигнал
17096 P0712 Датчик температуры масла КП-G93: слишком низкий уровень сигнала
17097 P0713 Датчик температуры масла КП-G93: слишком высокий уровень сигнала
17098 P0714 Датчик температуры масла КП-G93: обрыв цепи
17099 P0715 Датчик частоты вращения входного вала-G182: сбой в электрической цепи
17100 P0716 Датчик частоты вращения входного вала-G182: недостоверный сигнал
17101 P0717 Датчик частоты вращения входного вала-G182: нет сигнала
17104 P0720 Датчик частоты вращения выходного вала КП-G195: сбой в электрической цепи
17105 P0721 Датчик частоты вращения выходного вала КП-G195: недостоверный сигнал
17106 P0722 Датчик частоты вращения выходного вала КП-G195: нет сигнала
17109 P0725 Датчик частоты вращения от блока управления двигателя: сбой в электрической цепи
17110 P0726 Сигнал частоты вращения от блока управления двигателя: недостоверный сигнал
17111 P0727 Сигнал частоты вращения от блока управления двигателя, нет сигнала
17113 P0729 6. передача: неправильное передаточное отношение
17114 P0730 Контроль передачи и передаточного отношения: неправильное передаточное отношение
17115 P0731 1. передача: неправильное передаточное отношение
17116 P0732 2. передача: неправильное передаточное отношение
17117 P0733 3. передача: неправильное передаточное отношение
17118 P0734 4. передача: неправильное передаточное отношение
17119 P0735 5. передача: неправильное передаточное отношение
17120 P0736 Задний ход: неправильное передаточное отношение
17124 P0740 Муфта блокировки гидротрансформатора: механическое повреждение
17125 P0741 Муфта блокировки гидротрансформатора: отсутствует передача крутящего момента
17127 P0743 Муфта блокировки гидротрансформатора: сбой в электрической цепи
17130 P0746 Регулятор давления 1: обрыв цепи/короткое замыкание на массу
17131 P0747 Регулятор давления 1: короткое замыкание на плюс
17132 P0748 Регулятор давления 1, сбой в электрической цепи
17133 P0749 Регулятор давления 1: обрыв цепи
17134 P0750 Переключающий клапан 1=>электромагнитный клапан 1-N88: сбой в работе
17135 P0751 Переключающий клапан 1=>электромагнитный клапан 1-N88: обрыв цепи/короткое замыкание на массу
17136 P0752 Переключающий клапан 1=>электромагнитный клапан 1-N88: короткое замыкание на плюс
17137 P0753 Переключающий клапан 1=>электромагнитный клапан 1-N88: сбой в электрической цепи
17140 P0756 Переключающий клапан 2=>электромагнитный клапан 2-N89: обрыв цепи/короткое замыкание на массу
17141 P0757 Переключающий клапан 2=>электромагнитный клапан 2-N89: короткое замыкание на плюс
17142 P0758 Переключающий клапан 2=>электромагнитный клапан 2-N89: сбой в электрической цепи
17145 P0761 Переключающий клапан 3=>электромагнитный клапан 3-N90: обрыв цепи/короткое замыкание на массу
17146 P0762 Переключающий клапан 3=>электромагнитный клапан 3-N90: короткое замыкание на плюс
17147 P0763 Переключающий клапан 3=>электромагнитный клапан 3-N90: сбой в электрической цепи
17150 P0766 Переключающий клапан 4=>электромагнитный клапан 4-N91: обрыв цепи/короткое замыкание на массу
17152 P0768 Переключающий клапан 4=>электромагнитный клапан 4-N91: сбой в электрической цепи
17155 P0771 Переключающий клапан 5=>электромагнитный клапан 5-N92: обрыв цепи/короткое замыкание на массу
17157 P0773 Переключающий клапан 5=>электромагнитный клапан 5-N92: сбой в электрической цепи
17160 P0776 Регулятор давления 2: обрыв цепи/короткое замыкание на массу
17161 P0777 Регулятор давления 2: короткое замыкание на плюс
17162 P0778 Регулятор давления 2: сбой в электрической цепи
17163 P0779 Регулятор давления 2: обрыв цепи
17164 P0780 Контроль переключения передач
17165 P0781 Контроль переключения передач 1-2
17166 P0782 Контроль переключения передач 2-3
17167 P0783 Контроль переключения передач 3-4
17168 P0784 Контроль переключения передач 4-5
17169 P0785 Время переключения электромагнита
17174 P0790 Переключатель программ-E122: сбой в электрической цепи
17175 P0791 Датчик оборотов ""A"" промежуточного вала: сбой в электрической цепи
17180 P0796 Регулятор давления 3: обрыв цепи/короткое замыкание на массу
17181 P0797 Регулятор давления 3: короткое замыкание на плюс
17182 P0798 Регулятор давления 3: сбой в электрической цепи
17183 P0799 Регулятор давления 3: обрыв цепи
17195 P0811 сильное проскальзывание сцепления/муфты
17199 P0815 Переключатель Tiptronic, повышение передачи-F189: сбой в электрической цепи
17200 P0816 Переключатель Tiptronic, понижение передачи-F189: сбой в электрической цепи
17201 P0817 Сигнал блокировки стартера
17204 P0820 Сообщение от селектора АКП: работа в аварийном режиме
17213 P0829 Контроль переключения передач 5-6
17224 P0840 Датчик 1 давления в гидросистеме КП: сбой в электрической цепи
17225 P0841 Датчик 1 давления в гидросистеме КП: недостоверный сигнал
17226 P0842 Датчик 1 давления в гидросистеме КП: короткое замыкание на массу
17227 P0843 Датчик 1 давления в гидросистеме КП: короткое замыкание на плюс
17228 P0844 Датчик 1 давления в гидросистеме КП: обрыв цепи
17229 P0845 Датчик 2 давления в гидросистеме КП: сбой в электрической сети
17230 P0846 Датчик 2 давления в гидросистеме КП: недостоверный сигнал
17231 P0847 Датчик 2 давления в гидросистеме КП: короткое замыкание на массу
17232 P0848 Датчик 2 давления в гидросистеме КП: короткое замыкание на плюс
17233 P0849 Датчик 2 давления в гидросистеме КП: обрыв цепи
17234 P0850 Сигнал блокировки стартера (P/N), обрыв цепи
17235 P0851 Сигнал блокировки стартера (P/N): короткое замыкание на массу
17236 P0852 Сигнал блокировки стартера (P/N): короткое замыкание на плюс
17247 P0863 Коммуникация с блоком управления КП: сбой в электрической цепи
17248 P0864 Коммуникация с блоком управления КП: недостоверный сигнал
17249 P0865 Коммуникация с блоком управления КП: короткое замыкание на массу
17252 P0868 Давление в коробке передач: адаптация на пределе
17268 P0884 Подача напряжения на блок управления КП: обрыв цепи/плохой контакт
17270 P0886 Подача сигнала управления на реле подачи напряжения на блок управления КП: короткое замыкание на массу
17271 P0887 Подача сигнала управления на реле подачи напряжения на блок управления КП: короткое замыкание на плюс
17273 P0889 Электропитание электромагнитного клапана: недостоверный сигнал
17274 P0890 Электропитание электромагнитного клапана: короткое замыкание на массу
17275 P0891 Электропитание электромагнитного клапана: короткое замыкание на плюс
17276 P0892 Электропитание электромагнитного клапана, обрыв цепи
17281 P0897 Ухудшение состояния трансмиссионного масла
17288 P0904 Переключатель Tiptronic-F189: сбой в электрической цепи
17289 P0905 Переключатель Tiptronic-F189: недостоверный сигнал
17290 P0906 Переключатель Tiptronic-F189: короткое замыкание на массу
17298 P0914 Селектор АКП: сбой в электрической цепи
17303 P0919 Селектор АКП: ошибка
17313 P0929 Электромагнит блокировки селектора АКП: недостоверный сигнал
17314 P0930 Электромагнит блокировки селектора АКП: короткое замыкание на массу
17315 P0931 Электромагнит блокировки селектора АКП: короткое замыкание на плюс
17408 P1000 Форсунка цилиндра 9-N299: сбой в электрической цепи
17409 P1001 Форсунка цилиндра 10-N300: сбой в электрической цепи
17410 P1002 Форсунка цилиндра 11-N301: сбой в электрической цепи
17411 P1003 Форсунка цилиндра 12-N302: сбой в электрической цепи
17412 P1004 Разница моментов цил. 1: превышено предельное значение
17413 P1005 Разница моментов цил. 2: превышено предельное значение
17414 P1006 Разница моментов цил. 3: превышено предельное значение
17415 P1007 Разница моментов цил. 4: превышено предельное значение
17416 P1008 Расходомеры воздуха 1/2: недостоверный сигнал
17417 P1009 Расходомеры воздуха 1/2: недостоверный сигнал измерения нагрузки
17418 P1010 Форсунка цилиндра 9-N299: обрыв цепи
17419 P1011 Форсунка цилиндра 10-N300: обрыв цепи
17420 P1012 Форсунка цилиндра 11-N301: обрыв цепи
17421 P1013 Форсунка цилиндра 12-N302: обрыв цепи
17422 P1014 Клапан перепускной заслонки воздушного фильтра-N275: короткое замыкание на плюс
17423 P1015 Клапан перепускной заслонки воздушного фильтра-N275: короткое замыкание на массу
17424 P1016 Перепускной клапан воздушного фильтра-N275: обрыв цепи
17425 P1017 Заслонки 2 впускных каналов, не достигнут верхний предел
17426 P1018 Заслонки 2 впускных каналов: не достигнут нижний предел
17427 P1019 Датчик NOx-G295: время реакции слишком велико
17428 P1020 Регулятор давления топлива: выход из диапазона регулирования (больше верхнего предела)
17429 P1021 Ряд 1: сдвиг фаз газораспределения в позднюю сторону Не достигнуто номинальное значение
17430 P1022 Ряд 1: сдвиг фаз газораспределения в раннюю сторону Не достигнуто номинальное значение
17431 P1023 Регулятор давления топлива: короткое замыкание на массу
17432 P1024 Регулятор давления топлива: обрыв цепи
17433 P1025 Регулятор давления топлива: механическое повреждение
17434 P1026 Подача сигнала управления на заслонки впускных каналов: короткое замыкание на плюс
17435 P1027 Подача сигнала управления на заслонки впускных каналов: короткое замыкание на массу
17436 P1028 Подача сигнала управления на заслонки впускных каналов: обрыв цепи
17437 P1029 Клапан заслонок впускных каналов-N316: не достигнут верхний предел
17438 P1030 Клапан заслонок впускных каналов-N316: не достигнут нижний предел
17439 P1031 Клапан заслонок впускных каналов-N316: не достигнуто номинальное значение
17440 P1032 Датчик NOx-G295: слишком высокий уровень сигнала
17441 P1033 Датчик NOx-G295: слишком низкий уровень сигнала
17442 P1034 Датчик NOx-G295: сигнал за пределами допуска
17443 P1035 Датчик NOx-G295: недостоверный сигнал
17444 P1036 Подача управляющего сигнала на нагревательный элемент датчика NOx: короткое замыкание на плюс
17445 P1037 Подача сигнала управления на нагревательный элемент датчика NOx: короткое замыкание на массу
17446 P1038 Подача управляющего сигнала на нагревательный элемент датчика NOx: обрыв цепи
17447 P1039 Питание форсунки(-ок) А короткое замыкание.
17448 P1040 Питание форсунки(-ок) А: сбой в электрической цепи
17449 P1041 Питание форсунки(-ок) В: короткое замыкание
17450 P1042 Питание форсунки(-ок) В: сбой в электрической цепи
17451 P1043 Питание форсунки(-ок) С: короткое замыкание
17452 P1044 Питание форсунки(-ок) С: сбой в электрической цепи
17453 P1045 Питание форсунки(-ок) D: короткое замыкание
17454 P1046 Питание форсунки(-ок) D: сбой в электрической цепи
17455 P1047 Ряд 1, клапан регулирования фаз газораспределения выпускных клапанов-N318, сбой в электрической цепи
17456 P1048 Ряд 1, клапан регулирования фаз газораспределения выпускных клапанов-N318: короткое замыкание на плюс
17457 P1049 Ряд 1, клапан регулирования фаз газораспределения выпускных клапанов-N318: короткое замыкание на массу
17458 P1050 Ряд 1, клапан регулирования фаз газораспределения выпускных клапанов-N318: обрыв цепи
17459 P1051 Ряд 2, клапан регулирования фаз газораспределения выпускных клапанов-N319: сбой в электрической цепи
17460 P1052 Ряд 2, клапан регулирования фаз газораспределения выпускных клапанов-N319: короткое замыкание на плюс
17461 P1053 Ряд 2, клапан регулирования фаз газораспределения выпускных клапанов-N319: короткое замыкание на массу
17462 P1054 Ряд 2, клапан регулирования фаз газораспределения выпускных клапанов-N319: обрыв цепи
17463 P1055 Ряд 1, регулятор фаз газораспределения выпускных клапанов: короткое замыкание на плюс
17464 P1056 Ряд 1, регулятор фаз газораспределения выпускных клапанов: короткое замыкание на массу
17465 P1057 Ряд 1, регулятор фаз газораспределения выпускных клапанов: обрыв цепи
17466 P1058 Ряд 2, регулятор фаз газораспределения выпускных клапанов: короткое замыкание на плюс
17467 P1059 Ряд 2, регулятор фаз газораспределения выпускных клапанов: короткое замыкание на массу
17468 P1060 Ряд 2, регулятор фаз газораспределения выпускных клапанов: обрыв цепи
17469 P1061 Ряд 2: сдвиг фаз газораспределения в позднюю сторону Не достигнуто номинальное значение
17470 P1062 Ряд 2: сдвиг фаз газораспределения в раннюю сторону Не достигнуто номинальное значение
17471 P1063 Регулятор давления топлива: выход из диапазона регулирования (меньше нижнего предела)
17472 P1064 Система регулирования давления топлива: механическое повреждение
17473 P1065 Диапазон регулирования давления топлива
17474 P1066 Переключающий клапан впуска воздуха-N335: короткое замыкание на плюс
17475 P1067 Переключающий клапан впуска воздуха-N335: короткое замыкание на массу
17476 P1068 Переключающий клапан впуска воздуха-N335: обрыв цепи
17477 P1069 Датчик NOx-G295, сигнал контроля нагрева: короткое замыкание на массу
17478 P1070 Датчик NOx-G295, сигнал контроля нагрева: короткое замыкание на плюс
17479 P1071 Датчик NOx-G295 сигнал контроля нагрева: недостоверный сигнал
17480 P1072 Датчик NOx-G295, сигнал контроля нагрева: сбой в электрической цепи
17481 P1073 Расходомер воздуха 2-G246: слишком низкий уровень сигнала
17482 P1074 Расходомер воздуха 2-G246: слишком высокий уровень сигнала
17483 P1075 Лямбда-регулирование Ряд 3: переобеднение смеси в системе
17484 P1076 Лямбда-регулирование Ряд 3: переобогащение смеси в системе
17485 P1077 Лямбда-регулирование Ряд 4, переобеднение смеси в системе
17486 P1078 Лямбда-регулирование Ряд 4: переобогащение смеси в системе
17487 P1079 Лямбда-регулирование Ряд 3: недостоверное значение регулирующего параметра
17488 P1080 Лямбда-регулирование Ряд 4: недостоверное значение регулирующего параметра
17489 P1081 Ряд 3: адаптация смеси в диапазоне 1: переобеднение смеси
17490 P1082 Ряд 3: адаптация смеси в диапазоне 2: переобеднение смеси
17491 P1083 Ряд 3: адаптация смеси в диапазоне 1: переобогащение смеси
17492 P1084 Ряд 3, адаптация смеси в диапазоне 2: переобогащение смеси
17493 P1085 Ряд 4, адаптация смеси в диапазоне 1: переобеднение смеси
17494 P1086 Ряд 4, адаптация смеси в диапазоне 2: переобеднение смеси
17495 P1087 Ряд 4, адаптация смеси в диапазоне 1: переобогащение смеси
17496 P1088 Ряд 4, адаптация смеси в диапазоне 2: переобогащение смеси
17497 P1089 Ряд 2, адаптация смеси в диапазоне 1: переобеднение смеси
17498 P1090 Ряд 2, адаптация смеси в диапазоне 2: переобеднение смеси
17499 P1091 Ряд 2, адаптация смеси в диапазоне 1: переобогащение смеси
17500 P1092 Ряд 2, адаптация смеси в диапазоне 2: переобогащение смеси
17501 P1093 Ряд 1, система определения параметров топливо-возд.смеси 2: сбой в работе
17502 P1094 Ряд 2, система определения параметров топливо-возд.смеси 2: сбой в работе
17503 P1095 Датчик положения заслонок впускных каналов (потенциометр)-G336: короткое замыкание на плюс
17504 P1096 Датчик положения заслонок впускных каналов (потенциометр)-G336: короткое замыкание на массу
17505 P1097 Датчик положения заслонок впускных каналов (потенциометр)-G336: обрыв цепи
17506 P1098 Датчик положения заслонок впускных каналов (потенциометр)-G336: обрыв цепи/короткое замыкание на плюс
17507 P1099 Подача сигнала управления на заслонки впускных каналов: сбой в электрической цепи
17508 P1100 Ряд 1-зонд 2: электрическая цепь подогрева, слишком малая мощность
17509 P1101 Ряд 1-зонд 1: слишком низкое напряжение/негерметичность
17510 P1102 Ряд 1-зонд 1, электрическая цепь подогрева: короткое замыкание на плюс
17511 P1103 Ряд 1-зонд 1, электрическая цепь подогрева: слишком малая мощность
17512 P1104 Ряд 1-зонд 2: слишком низкое напряжение/негерметичность
17513 P1105 Ряд 1-зонд 2, электрическая цепь подогрева: короткое замыкание на плюс
17514 P1106 Ряд 2-зонд 1: слишком низкое напряжение/негерметичность
17515 P1107 Ряд 2-зонд 1, электрическая цепь подогрева: короткое замыкание на плюс
17516 P1108 Ряд 2-зонд 1, электрическая цепь подогрева: слишком малая мощность
17517 P1109 Ряд 2-зонд 2: слишком низкое напряжение/негерметичность
17518 P1110 Ряд 2-зонд 2, электрическая цепь подогрева: короткое замыкание на плюс
17519 P1111 Лямбда-регулирование (Ряд 1): переобеднение смеси в системе
17520 P1112 Лямбда-регулирование (Ряд 1): переобогащение смеси в системе
17521 P1113 Ряд 1, зонд 1: внутреннее сопротивление слишком велико
17522 P1114 Ряд 1, зонд 2 внутреннее сопротивление слишком велико
17523 P1115 Ряд 1-зонд 1, электрическая цепь подогрева: короткое замыкание на массу
17524 P1116 Ряд 1-зонд 1: обрыв электрической цепи подогрева
17525 P1117 Ряд 1-зонд 2, электрическая цепь подогрева: короткое замыкание на массу
17526 P1118 Ряд 1-зонд 2: обрыв электрической цепи подогрева
17527 P1119 Ряд 2-зонд 1, электрическая цепь подогрева: короткое замыкание на массу
17528 P1120 Ряд 2-зонд 1: обрыв электрической цепи подогрева
17529 P1121 Ряд 2-зонд 2, электрическая цепь подогрева: короткое замыкание на массу
17530 P1122 Ряд 2-зонд 2: обрыв электрической цепи подогрева
17531 P1123 Ряд 1, адаптация смеси, воздух (add.): переобогащение смеси в системе
17532 P1124 Ряд 2, адаптация смеси, воздух (add.): переобеднение смеси в системе
17533 P1125 Ряд 2, адаптация смеси, воздух (add.): переобогащение смеси в системе
17534 P1126 Ряд 2, адаптация смеси, воздух (add.): переобеднение смеси в системе
17535 P1127 Ряд 1, адаптация смеси (под нагрузкой): переобогащение смеси в системе
17536 P1128 Ряд 1, адаптация смеси (под нагрузкой): переобеднение смеси в системе
17537 P1129 Ряд 2, адаптация смеси (под нагрузкой): переобогащение смеси в системе
17538 P1130 Ряд 2, адаптация смеси (под нагрузкой): переобеднение смеси в системе
17539 P1131 Ряд 2, зонд 1: внутреннее сопротивление слишком велико
17540 P1132 Ряд 1+2-зонд 1, электрическая цепь подогрева: короткое замыкание на плюс
17541 P1133 Ряд 1+2-зонд 1: сбой в электрической цепи подогрева
17542 P1134 Ряд 1+2-зонд 2, электрическая цепь подогрева: короткое замыкание на плюс
17543 P1135 Ряд 1+2-зонд 2: сбой в электрической цепи подогрева
17544 P1136 Ряд 1, адаптация смеси (на холостом ходу): переобеднение смеси в системе
17545 P1137 Ряд 1, адаптация смеси (на холостом ходу): переобогащение смеси в системе
17546 P1138 Ряд 2, адаптация смеси (на холостом ходу): переобеднение смеси в системе
17547 P1139 Ряд 2, адаптация смеси (на холостом ходу): переобогащение смеси в системе
17548 P1140 Ряд 2, зонд 2: внутреннее сопротивление слишком велико
17549 P1141 Недостоверные данные учета нагрузки
17550 P1142 Учет нагрузки, не достигнуто нижнее пороговое значение
17551 P1143 Учет нагрузки: превышено верхнее пороговое значение
17552 P1144 Расходомер воздуха-G70: обрыв цепи/замыкание на массу
17553 P1145 Расходомер воздуха-G70: короткое замыкание на плюс
17554 P1146 Расходомер воздуха-G70: напряжение питания
17555 P1147 Лямбда-регулирование (Ряд 2): переобеднение смеси в системе
17556 P1148 Лямбда-регулирование (Ряд 2): переобогащение смеси в системе
17557 P1149 Лямбда-регулирование-ряд 1: недостоверное значение параметра регулирования
17558 P1150 Лямбда-регулирование-ряд 2: недостоверное значение параметра регулирования
17559 P1151 Ряд 1, адаптация смеси в диапазоне 1: переобеднение смеси
17560 P1152 Ряд 1, адаптация смеси в диапазоне 2: переобеднение смеси
17561 P1153 Перепутаны лямбда-зонды после катализатора
17562 P1154 Система изменения геометрии впускного коллектора: сбой в работе
17563 P1155 Датчик давления во впускном коллекторе-G71: короткое замыкание на плюс
17564 P1156 Датчик давления во впускном коллекторе-G71: обрыв цепи/короткое замыкание на плюс
17565 P1157 Датчик давления во впускном коллекторе-G71: напряжение питания
17566 P1158 Датчик давления во впускном коллекторе-G71: недостоверный сигнал
17567 P1159 Сигнал расходомера воздуха 1/расходомера воздуха 2: недостоверное соотношение
17568 P1160 Датчик температуры во впускном коллекторе-G72: короткое замыкание на массу
17569 P1161 Датчик температуры во впускном коллекторе-G72: обрыв цепи/короткое замыкание на плюс
17570 P1162 Датчик температуры топлива-G81: короткое замыкание на массу
17571 P1163 Датчик температуры топлива-G81: обрыв цепи/короткое замыкание на плюс
17572 P1164 Датчик температуры топлива-G81, недостоверный сигнал
17573 P1165 Ряд 1, адаптация смеси в диапазоне 1: переобогащение смеси
17574 P1166 Ряд 1, адаптация смеси в диапазоне 2: переобогащение смеси
17575 P1167 Расходомер воздуха 2-G246: недостоверный сигнал
17576 P1168 Расходомер воздуха 2-G246: обрыв цепи/замыкание на массу
17577 P1169 Расходомер воздуха 2-G246: короткое замыкание на плюс
17578 P1170 Расходомер воздуха 2-G246: напряжение питания
17579 P1171 Датчик угла поворота 2 привода дроссельной заслонки-G188: недостоверный сигнал
17580 P1172 Датчик угла поворота 2 привода дроссельной заслонки-G188: слишком низкий уровень сигнала
17581 P1173 Датчик угла поворота 2 привода дроссельной заслонки-G188: слишком высокий уровень сигнала
17582 P1174 Ряд 1, система определения параметров топливо-возд.смеси: отклонение времени впрыска
17583 P1175 Предварительный впрыск отключен
17584 P1176 Ряд 1, лямбда-коррекция после катализатора: достигнут предел регулирования
17585 P1177 Ряд 2, лямбда-коррекция после катализатора: достигнут предел регулирования
17586 P1178 Линейный лямбда-зонд/ток сигнала: обрыв цепи
17587 P1179 Линейный лямбда-зонд/ток сигнала: короткое замыкание на массу
17588 P1180 Линейный лямбда-зонд/ток сигнала: короткое замыкание на плюс
17589 P1181 Линейный лямбда-зонд /опорное напряжение: обрыв цепи
17590 P1182 Линейный лямбда-зонд/опорное напряжение: короткое замыкание на массу
17591 P1183 Линейный лямбда-зонд/опорное напряжение: короткое замыкание на плюс
17592 P1184 Линейный лямбда-зонд/общий кабель массы: обрыв цепи
17593 P1185 Линейный лямбда-зонд/общий кабель массы: короткое замыкание на массу
17594 P1186 Линейный лямбда-зонд/общий кабель массы: короткое замыкание на плюс
17595 P1187 Линейный лямбда-зонд/компенс. сопротивление: обрыв цепи
17596 P1188 Линейный лямбда-зонд/компенс. сопротивление: короткое замыкание на массу
17597 P1189 Линейный лямбда-зонд/компенс. сопротивление: короткое замыкание на плюс
17598 P1190 Линейный лямбда-зонд/опорное напряжение недостоверно
17599 P1191 Перепутаны линейные лямбда-зонды перед катализатором
17600 P1192 Датчик давления топлива-G247: напряжение питания
17601 P1193 Датчик давления топлива-G247: обрыв цепи/короткое замыкание на плюс
17602 P1194 Клапан регулятора давления топлива-N276: короткое замыкание на плюс
17603 P1195 Клапан регулятора давления топлива-N276: обрыв цепи/короткое замыкание на массу
17604 P1196 Ряд 1-зонд 1: сбой в электрической цепи подогрева
17605 P1197 Ряд 2-зонд 1: сбой в электрической цепи подогрева
17606 P1198 Ряд 1-зонд 2: сбой в электрической цепи подогрева
17607 P1199 Ряд 2-зонд 2: сбой в электрической цепи подогрева
17608 P1200 Перепускной клапан турбонагнетателя-N249: механическое повреждение
17609 P1201 Форсунка цилиндра 1-N30: сбой в электрической цепи
17610 P1202 Форсунка цилиндра 2-N31: сбой в электрической цепи
17611 P1203 Форсунка цилиндра 3-N32: сбой в электрической цепи
17612 P1204 Форсунка цилиндра 4-N33: сбой в электрической цепи
17613 P1205 Форсунка цилиндра 5-N83: сбой в электрической цепи
17614 P1206 Форсунка цилиндра 6-N84: сбой в электрической цепи
17615 P1207 Форсунка цилиндра 7-N85: сбой в электрической цепи
17616 P1208 Форсунка цилиндра 8-N86: сбой в электрической цепи
17617 P1209 Впускные клапаны для отключения цилиндров: короткое замыкание на массу
17618 P1210 Впускные клапаны для отключения цилиндров: короткое замыкание на плюс
17619 P1211 Впускные клапаны для отключения цилиндров: обрыв цепи
17620 P1212 Отключение цилиндров, ряд 1
17621 P1213 Форсунка цилиндра 1-N30: короткое замыкание на плюс
17622 P1214 Форсунка цилиндра 2-N31: короткое замыкание на плюс
17623 P1215 Форсунка цилиндра 3-N32: короткое замыкание на плюс
17624 P1216 Форсунка цилиндра 4-N33: короткое замыкание на плюс
17625 P1217 Форсунка цилиндра 5-N83: короткое замыкание на плюс
17626 P1218 Форсунка цилиндра 6-N84: короткое замыкание на плюс
17627 P1219 Форсунка цилиндра 7-N85: короткое замыкание на плюс
17628 P1220 Форсунка цилиндра 8-N86: короткое замыкание на плюс
17629 P1221 Выпускные клапаны для отключения цилиндров: короткое замыкание на массу
17630 P1222 Выпускные клапаны для отключения цилиндров: короткое замыкание на плюс
17631 P1223 Выпускные клапаны для отключения цилиндров: обрыв цепи
17632 P1224 Отключение цилиндров, ряд 2
17633 P1225 Форсунка цилиндра 1-N30: короткое замыкание на массу
17634 P1226 Форсунка цилиндра 2-N31: короткое замыкание на массу
17635 P1227 Форсунка цилиндра 3-N32: короткое замыкание на массу
17636 P1228 Форсунка цилиндра 4-N33: короткое замыкание на массу
17637 P1229 Форсунка цилиндра 5-N83: короткое замыкание на массу
17638 P1230 Форсунка цилиндра 6-N84: короткое замыкание на массу
17639 P1231 Форсунка цилиндра 7-N85: короткое замыкание на массу
17640 P1232 Форсунка цилиндра 8-N865: короткое замыкание на массу
17641 P1233 Ошибка учета нагрузки
17642 P1234 Ошибка при подаче топлива по нагнетательной магистрали
17643 P1235 Ряд 3, лямбда-коррекция после катализатора: достигнут предел регулирования
17644 P1236 ОГ, ряд 4, лямбда-коррекция после катализатора: достигнут предел регулирования
17645 P1237 Форсунка цилиндра 1-N30: обрыв цепи
17646 P1238 Форсунка цилиндра 2-N31: обрыв цепи
17647 P1239 Форсунка цилиндра 3-N32: обрыв цепи
17648 P1240 Форсунка цилиндра 4-N33: обрыв цепи
17649 P1241 Форсунка цилиндра 5-N83: обрыв цепи
17650 P1242 Форсунка цилиндра 6-N84: обрыв цепи
17651 P1243 Форсунка цилиндра 7-N85: обрыв цепи
17652 P1244 Форсунка цилиндра 8-N86: обрыв цепи
17653 P1245 Датчик хода иглы-G80: короткое замыкание на массу
17654 P1246 Датчик хода иглы-G80: недостоверный сигнал
17655 P1247 Датчик хода иглы-G80: обрыв цепи/короткое замыкание на плюс
17656 P1248 Регулирование опережения впрыска, диапазон регулирования
17657 P1249 Сигнал расхода топлива: сбой в электрической цепи
17658 P1250 Слишком низкий уровень топлива в баке
17659 P1251 Клапан управления опережением впрыска-N108: короткое замыкание на плюс
17660 P1252 Клапан управления опережением впрыска-N108: обрыв цепи/короткое замыкание на массу
17661 P1253 Сигнал расхода топлива: короткое замыкание на массу
17662 P1254 Сигнал расхода топлива: короткое замыкание на плюс
17663 P1255 Датчик температуры охлаждающей жидкости-G62: короткое замыкание на массу
17664 P1256 Датчик температуры охлаждающей жидкости-G62: обрыв цепи/короткое замыкание на плюс
17665 P1257 Клапан в контуре циркуляции охлаждающей жидкости-N214: обрыв цепи
17666 P1258 Клапан в контуре циркуляции охлаждающей жидкости-N214: короткое замыкание на плюс
17667 P1259 Клапан в контуре циркуляции охлаждающей жидкости-N214: короткое замыкание на плюс
17668 P1260 Клапан насос-форсунки цилиндра 1-N240: недостоверный сигнал
17669 P1261 Клапан насос-форсунки цилиндра 1-N240: выход из диапазона регулирования (больше верхнего предела)
17670 P1262 Клапан насос-форсунки цилиндра 1-N240: выход из диапазона регулирования (меньше нижнего предела)
17671 P1263 Клапан насос-форсунки цилиндра 2-N241: недостоверный сигнал
17672 P1264 Клапан насос-форсунки цилиндра 2-N241: выход из диапазона регулирования (больше верхнего предела)
17673 P1265 Клапан насос-форсунки цилиндра 2-N241: выход из диапазона регулирования (меньше нижнего предела)
17674 P1266 Клапан насос-форсунки цилиндра 3-N242, недостоверный сигнал
17675 P1267 Клапан насос-форсунки цилиндра 3-N242, выход из диапазона регулирования (больше верхнего предела)
17676 P1268 Клапан насос-форсунки цилиндра 3-N242: выход из диапазона регулирования (меньше нижнего предела)
17677 P1269 Клапан насос-форсунки цилиндра 4-N243: недостоверный сигнал
17678 P1270 Клапан насос-форсунки цилиндра 4-N243: выход из диапазона регулирования (больше верхнего предела)
17679 P1271 Клапан насос-форсунки цилиндра 4-N243: выход из диапазона регулирования (меньше нижнего предела)
17680 P1272 Клапан насос-форсунки цилиндра 5-N244: недостоверный сигнал
17681 P1273 Клапан насос-форсунки цилиндра 5-N244: выход из диапазона регулирования (больше верхнего предела)
17682 P1274 Клапан насос-форсунки цилиндра 5-N244: выход из диапазона регулирования (меньше нижнего предела)
17683 P1275 Клапан насос-форсунки цилиндра 6-N245: недостоверный сигнал
17684 P1276 Клапан насос-форсунки цилиндра 6-N245: выход из диапазона регулирования (больше верхнего предела)
17685 P1277 Клапан насос-форсунки цилиндра 6-N245: выход из диапазона регулирования (меньше нижнего предела)
17686 P1278 Клапан дозирования топлива-N290: короткое замыкание на плюс
17687 P1279 Клапан дозирования топлива-N290: обрыв цепи/короткое замыкание на массу
17688 P1280 Пневматический управляющий клапан форсунок-N212: недостаточная пропускная способность
17689 P1281 Клапан дозирования топлива-N290: короткое замыкание на массу
17690 P1282 Клапан дозирования топлива-N290: обрыв цепи
17691 P1283 Пневматический управляющий клапан форсунок-N212: сбой в электрической цепи
17692 P1284 Пневматический управляющий клапан форсунок-N212: обрыв цепи
17693 P1285 Пневматический управляющий клапан форсунок-N212: короткое замыкание на массу
17694 P1286 Пневматический управляющий клапан форсунок-N212: короткое замыкание на плюс
17695 P1287 Перепускной клапан турбонагнетателя-N249: обрыв цепи
17696 P1288 Перепускной клапан турбонагнетателя-N249: короткое замыкание на плюс
17697 P1289 Перепускной клапан турбонагнетателя-N249: короткое замыкание на массу
17698 P1290 Датчик температуры охлаждающей жидкости на выходе радиатора-G83: слишком высокий уровень сигнала
17699 P1291 Датчик температуры охлаждающей жидкости на выходе радиатора-G83: слишком низкий уровень сигнала
17700 P1292 Термостат электронного управления системы охлаждения двигателя-F265, обрыв цепи
17701 P1293 Термостат электронного управления системой охлаждения двигателя-F265, короткое замыкание на плюс
17702 P1294 Термостат электронного управления системой охлаждения двигателя-F265: короткое замыкание на массу
17703 P1295 Обходной канал турбонагнетателя: снижение пропускной способности
17704 P1296 Неисправность системы охлаждения
17705 P1297 Трубопроводы между турбиной и корпусом дроссельной заслонки: падение давления.
17706 P1298 Датчик температуры охлаждающей жидкости на выходе радиатора-G83: недостоверный сигнал
17707 P1299 Клапан дозирования топлива-N290: сбой в работе
17708 P1300 Обнаружен пропуск воспламенения, причина: нехватка топлива
17709 P1301 Регулирование по детонации цил. 9: достигнут предел регулирования
17710 P1302 Регулирование по детонации цил. 10: достигнут предел регулирования
17711 P1303 Регулирование по детонации цил. 11: достигнут предел регулирования
17712 P1304 Регулирование по детонации цил. 12: достигнут предел регулирования
17713 P1305 Управление зажиганием, цил. 9: обрыв цепи
17714 P1306 Управление зажиганием, цил. 9: короткое замыкание на плюс
17715 P1307 Управление зажиганием, цил. 9: короткое замыкание на массу
17716 P1308 Управление зажиганием, цил. 10: обрыв цепи
17717 P1309 Управление зажиганием, цил. 10: короткое замыкание на плюс
17718 P1310 Управление зажиганием, цил. 10: короткое замыкание на массу
17719 P1311 Управление зажиганием, цил. 11: обрыв цепи
17720 P1312 Управление зажиганием, цил. 11: короткое замыкание на плюс
17721 P1313 Управление зажиганием, цил. 11: короткое замыкание на массу
17722 P1314 Управление зажиганием, цил. 12: обрыв цепи
17723 P1315 Управление зажиганием, цил. 12: короткое замыкание на плюс
17724 P1316 Управление зажиганием, цил. 12: короткое замыкание на массу
17725 P1317 Регулирование по детонации цил. 13: достигнут предел регулирования
17726 P1318 Регулирование по детонации цил. 14: достигнут предел регулирования
17727 P1319 Датчик детонации 1-G61: короткое замыкание на массу
17728 P1320 Датчик детонации 2-G66: короткое замыкание на массу
17729 P1321 Датчик детонации 3-G198: слишком низкий уровень сигнала
17730 P1322 Датчик детонации 3-G198: слишком высокий уровень сигнала
17731 P1323 Датчик детонации 4-G199: слишком низкий уровень сигнала
17732 P1324 Датчик детонации 4-G199: слишком высокий уровень сигнала
17733 P1325 Регулирование по детонации цил. 1: достигнут предел регулирования
17734 P1326 Регулирование по детонации цил. 2: достигнут предел регулирования
17735 P1327 Регулирование по детонации цил. 3: достигнут предел регулирования
17736 P1328 Регулирование по детонации цил. 4: достигнут предел регулирования
17737 P1329 Регулирование по детонации цил. 5: достигнут предел регулирования
17738 P1330 Регулирование по детонации цил. 6: достигнут предел регулирования
17739 P1331 Регулирование по детонации цил. 7: достигнут предел регулирования
17740 P1332 Регулирование по детонации цил. 8: достигнут предел регулирования
17741 P1333 Регулирование по детонации цил. 15: достигнут предел регулирования
17742 P1334 Регулирование по детонации цил. 16: достигнут предел регулирования
17743 P1335 Контроль крутящего момента 2: превышен предел регулирования
17744 P1336 Контроль крутящего момента: превышен предел регулирования
17745 P1337 Ряд 1, датчик положения распредвала=>-G40: короткое замыкание на массу
17746 P1338 Ряд 1, датчик положения распредвала=>-G40: обрыв цепи/короткое замыкание на плюс
17747 P1339 Перепутаны датчики положения коленчатого вала и оборотов двигателя
17748 P1340 Датчик положения распредвала-G40/датчик положения коленвала-G28: несоответствие сигналов
17749 P1341 Вывод зажигания 1: короткое замыкание на массу
17750 P1342 Вывод зажигания 1: короткое замыкание на плюс
17751 P1343 Вывод зажигания 2: короткое замыкание на массу
17752 P1344 Вывод зажигания 2: короткое замыкание на плюс
17753 P1345 Вывод зажигания 3: короткое замыкание на массу
17754 P1346 Вывод зажигания 3: короткое замыкание на плюс
17755 P1347 Ряд 2, датчик положения распредвала-G163/датчик положения коленвала-G28: несоответствие сигналов
17756 P1348 Вывод зажигания 1: обрыв цепи
17757 P1349 Вывод зажигания 2: обрыв цепи
17758 P1350 Вывод зажигания 3: обрыв цепи
17759 P1351 Ряд 1, датчик положения распредвала=>-G40: недостоверный сигнал при пуске
17760 P1352 Ряд 1, регулятор фаз газораспределения: не достигнуто номинальное положение
17762 P1354 Датчик перемещения регулировочного золотника-G149: сбой в электрической цепи
17763 P1355 Управление зажиганием, цил. 1: обрыв цепи
17764 P1356 Управление зажиганием, цил. 1, короткое замыкание на плюс
17765 P1357 Управление зажиганием, цил. 1: короткое замыкание на массу
17766 P1358 Управление зажиганием, цил. 2: обрыв цепи
17767 P1359 Управление зажиганием, цил. 2: короткое замыкание на плюс
17768 P1360 Управление зажиганием, цил. 2: короткое замыкание на массу
17769 P1361 Управление зажиганием, цил. 3: обрыв цепи
17770 P1362 Управление зажиганием, цил. 3: короткое замыкание на плюс
17771 P1363 Управление зажиганием, цил. 3: короткое замыкание на массу
17772 P1364 Управление зажиганием, цил. 4, обрыв цепи
17773 P1365 Управление зажиганием, цил. 4: короткое замыкание на плюс
17774 P1366 Управление зажиганием, цил. 4: короткое замыкание на массу
17775 P1367 Управление зажиганием, цил. 5: обрыв цепи
17776 P1368 Управление зажиганием, цил. 5: короткое замыкание на плюс
17777 P1369 Управление зажиганием, цил. 5: короткое замыкание на массу
17778 P1370 Управление зажиганием, цил. 6: обрыв цепи
17779 P1371 Управление зажиганием, цил. 6: короткое замыкание на плюс
17780 P1372 Управление зажиганием, цил. 6: короткое замыкание на массу
17781 P1373 Управление зажиганием, цил. 7: обрыв цепи
17782 P1374 Управление зажиганием, цил. 7: короткое замыкание на плюс
17783 P1375 Управление зажиганием, цил. 7: короткое замыкание на массу
17784 P1376 Управление зажиганием, цил. 8: обрыв цепи
17785 P1377 Управление зажиганием, цил. 8: короткое замыкание на плюс
17786 P1378 Управление зажиганием, цил. 8: короткое замыкание на массу
17787 P1379 Цилиндр 13: Обнаружен пропуск воспламенения
17788 P1380 Цилиндр 14: Обнаружен пропуск воспламенения
17789 P1381 Цилиндр 15: Обнаружен пропуск воспламенения
17790 P1382 Цилиндр 16: Обнаружен пропуск воспламенения
17792 P1384 Неисправен блок управления 2
17793 P1385 Неисправен блок управления
17794 P1386 Неисправен блок управления
17795 P1387 Неисправен блок управления
17796 P1388 Неисправен блок управления
17797 P1389 Поврежден блок управления 2 системы непосредственного впрыска дизельного топлива-J494
17799 P1391 Ряд 2, датчик положения распредвала=>-G163: короткое замыкание на массу
17800 P1392 Ряд 2, датчик положения распредвала=>-G163: обрыв цепи/короткое замыкание на плюс
17801 P1393 Вывод зажигания 1: сбой в электрической цепи
17802 P1394 Вывод зажигания 2: сбой в электрической цепи
17803 P1395 Вывод зажигания 3: сбой в электрической цепи
17804 P1396 Датчик числа оборотов двигателя-G28: отсутствует зуб
17805 P1397 Зубчатый диск датчика числа оборотов коленвала, достигнут предел адаптации
17806 P1398 Сигнал оборотов двигателя, TD: короткое замыкание на массу
17807 P1399 Сигнал оборотов двигателя, TD: короткое замыкание на плюс
17808 P1400 Клапан рециркуляции ОГ-N18: сбой в электрической цепи
17809 P1401 Клапан рециркуляции ОГ-N18: короткое замыкание на массу
17810 P1402 Клапан рециркуляции ОГ-N18: короткое замыкание на плюс
17811 P1403 Система рециркуляции ОГ, диапазон регулирования
17812 P1404 Система рециркуляции ОГ: не выполнены базовые установки
17813 P1405 Клапан 2 управления рециркуляцией ОГ-N213: сбой в работе
17814 P1406 Датчик температуры в системе рециркуляции ОГ-G98: недостоверный сигнал
17815 P1407 Датчик температуры в системе рециркуляции ОГ-G98: слишком низкий уровень сигнала
17816 P1408 Датчик температуры в системе рециркуляции ОГ-G98: слишком высокий уровень сигнала
17817 P1409 Электромагнитный клапан 1 абсорбера с активированным углем-N80: сбой в электрической цепи
17818 P1410 Электромагнитный клапан 1 абсорбера с активированным углем-N80, короткое замыкание на плюс
17819 P1411 Ряд 2, система подачи вторичного воздуха: слишком низкая пропускная способность
17820 P1412 Датчик давления в системе рециркуляции ОГ: слишком низкий уровень сигнала
17821 P1413 Датчик давления в системе рециркуляции ОГ: слишком высокий уровень сигнала
17822 P1414 Ряд 2, система подачи вторичного воздуха: обнаружена утечка
17823 P1415 Клапан рециркуляции ОГ-N18, адаптация характеристик: превышено нижнее предельное значение
17824 P1416 Клапан рециркуляции ОГ-N18: адаптация характеристик: превышено верхнее предельное значение
17825 P1417 Датчик запаса топлива-G: слишком низкий уровень сигнала
17826 P1418 Датчик запаса топлива-G: слишком высокий уровень сигнала
17827 P1419 Переключающий клапан 2 радиатора системы рециркуляции ОГ-N381: короткое замыкание на плюс
17828 P1420 Клапан управления подачей вторичного воздуха-N112: сбой в электрической цепи
17829 P1421 Клапан управления подачей вторичного воздуха-N112: короткое замыкание на массу
17830 P1422 Клапан управления подачей вторичного воздуха-N112: короткое замыкание на плюс
17831 P1423 Ряд 1, система подачи вторичного воздуха: слишком низкая пропускная способность
17832 P1424 Ряд 1, система подачи вторичного воздуха: обнаружена утечка
17833 P1425 Электромагнитный клапан 1 абсорбера с активированным углем-N80: короткое замыкание на массу
17834 P1426 Электромагнитный клапан 1 абсорбера с активированным углем-N80: обрыв цепи
17835 P1427 Подача управляющего сигнала на вакуумный насос усилителя тормозов: короткое замыкание на плюс
17836 P1428 Подача управляющего сигнала на вакуумный насос усилителя тормозов: короткое замыкание на массу
17837 P1429 Подача управляющего сигнала на вакуумный насос тормозной системы: обрыв цепи
17838 P1430 Подача управляющего сигнала на вакуумный насос усилителя тормозов: обрыв цепи/короткое замыкание на плюс
17839 P1431 Подача управляющего сигнала на вакуумный насос усилителя тормозов: короткое замыкание на массу
17840 P1432 Клапан управления подачей вторичного воздуха-N112: обрыв цепи
17841 P1433 Реле насоса вторичного воздуха-J299: обрыв цепи
17842 P1434 Реле насоса вторичного воздуха-J299: короткое замыкание на плюс
17843 P1435 Реле насоса вторичного воздуха-J299: короткое замыкание на массу
17844 P1436 Реле насоса вторичного воздуха-J299: сбой в электрической цепи
17845 P1437 Клапан 2 управления рециркуляцией ОГ-N213: короткое замыкание на плюс
17846 P1438 Клапан 2 управления рециркуляцией ОГ-N213: обрыв цепи/короткое замыкание на массу
17847 P1439 Потенциометр системы рециркуляции ОГ-G212: ошибка базовой настройки
17848 P1440 Клапан рециркуляции ОГ-N18: обрыв цепи
17849 P1441 Клапан рециркуляции ОГ-N18: обрыв цепи/короткое замыкание на массу
17850 P1442 Потенциометр системы рециркуляции ОГ-G212: слишком высокий уровень сигнала
17851 P1443 Потенциометр системы рециркуляции ОГ-G212: слишком низкий уровень сигнала
17852 P1444 Потенциометр системы рециркуляции ОГ-G212: недостоверный сигнал
17853 P1445 Датчик температуры 2 катализатора-G132: недостоверный сигнал
17854 P1446 Датчик температуры 1 катализатора-G20: короткое замыкание на массу
17855 P1447 Датчик температуры 1 катализатора-G20: обрыв цепи/короткое замыкание на плюс
17856 P1448 Датчик температуры 2 катализатора-G132: короткое замыкание на массу
17857 P1449 Датчик температуры 2 катализатора-G132: обрыв цепи/короткое замыкание на плюс
17858 P1450 Система подачи вторичного воздуха: короткое замыкание на плюс
17859 P1451 Система подачи вторичного воздуха: короткое замыкание на массу
17860 P1452 Система подачи вторичного воздуха: обрыв цепи
17861 P1453 Датчик 1 температуры ОГ 1-G235: обрыв цепи/короткое замыкание на плюс
17862 P1454 Датчик температуры ОГ 1-G235: короткое замыкание на массу
17863 P1455 Датчик температуры ОГ 1-G235: недостоверный сигнал
17864 P1456 Регулятор температуры ОГ, ряд 1: достигнут предел регулирования
17865 P1457 Датчик температуры ОГ 1 для 2 ряда цилиндров-G236: обрыв цепи/короткое замыкание на плюс
17866 P1458 Датчик температуры ОГ 1 для 2 ряда цилиндров-G236: короткое замыкание на массу
17867 P1459 Датчик температуры ОГ 1 для 2 ряда цилиндров-G236: недостоверный сигнал
17868 P1460 Регулирование температуры ОГ, ряд 2: достигнут предел регулирования
17869 P1461 Регулирование температуры ОГ, ряд 1: недостоверный сигнал
17870 P1462 Регулирование температуры ОГ, ряд 2: недостоверный сигнал
17871 P1463 Система подачи вторичного воздуха, ряд 3: сбой в работе
17872 P1464 Система подачи вторичного воздуха, ряд 4: сбой в работе
17873 P1465 Насос подачи присадки к топливу для работы сажевого фильтра-V135: короткое замыкание на плюс
17874 P1466 Насос подачи присадки к топливу для работы сажевого фильтра-V135: обрыв цепи/короткое замыкание на массу
17875 P1467 Электромагнитный клапан 2 абсорбера с активированным углем-N115: короткое замыкание на плюс
17876 P1468 Электромагнитный клапан 2 абсорбера с активированным углем-N115: короткое замыкание на массу
17877 P1469 Электромагнитный клапан 2 абсорбера с активированным углем-N115: обрыв цепи
17878 P1470 Насос диагностики герметичности системы вентиляции топливного бака: сбой в электрической цепи
17879 P1471 Насос диагностики герметичности системы вентиляции топливного бака: короткое замыкание на плюс
17880 P1472 Насос диагностики герметичности системы вентиляции топливного бака: короткое замыкание на массу
17881 P1473 Насос диагностики герметичности системы вентиляции топливного бака: обрыв цепи
17882 P1474 Электромагнитный клапан 2 абсорбера с активированным углем-N115: сбой в электрической цепи
17883 P1475 Насос диагностики герметичности системы вентиляции топливного бака: сбой в работе/нет сигнала
17884 P1476 Насос диагностики герметичности системы вентиляции топливного бака: сбой в работе/недостаточное разрежение
17885 P1477 Насос диагностики герметичности системы вентиляции топливного бака: сбой в работе
17886 P1478 Насос диагностики герметичности системы вентиляции топливного бака: обнаружен засоренный шланг
17887 P1479 Вакуумная система усилителя тормозов механическая неисправность
17888 P1480 Вакуумный насос тормозной системы
17889 P1481 Реле насоса вторичного воздуха 2-J545: обрыв цепи
17890 P1482 Реле насоса вторичного воздуха 2-J545: короткое замыкание на плюс
17891 P1483 Реле насоса вторичного воздуха 2-J545: короткое замыкание на массу
17892 P1484 Реле насоса вторичного воздуха 2-J545: сбой в электрической цепи
17893 P1485 Клапан 2 управления подачей вторичного воздуха-N320: обрыв цепи
17894 P1486 Клапан 2 управления подачей вторичного воздуха-N320: сбой в электрической цепи
17895 P1487 Клапан 2 управления подачей вторичного воздуха-N320: короткое замыкание на массу
17896 P1488 Клапан 2 управления подачей вторичного воздуха-N320: короткое замыкание на плюс
17897 P1489 Электромагнитный клапан 2 системы улавливания паров топлива-N333: короткое замыкание на плюс
17898 P1490 Электромагнитный клапан 2 системы улавливания паров топлива-N333: короткое замыкание на массу
17899 P1491 Электромагнитный клапан 2 системы улавливания паров топлива-N333: обрыв цепи
17900 P1492 Электромагнитный клапан 2 системы улавливания паров топлива-N333: сбой в электрической цепи
17901 P1493 Вакуумный насос тормозной системы: недостаточная мощность
17902 P1494 Система вентиляции топливного бака 2: снижение пропускной способности
17903 P1495 Переключающий клапан радиатора системы рециркуляции ОГ-N345: обрыв цепи/короткое замыкание на массу
17904 P1496 Переключающий клапан радиатора системы рециркуляции ОГ-N345: короткое замыкание на плюс
17905 P1497 Система подачи вторичного воздуха, ряд 3: снижение пропускной способности
17906 P1498 Система подачи вторичного воздуха, ряд 4: снижение пропускной способности
17907 P1499 Переключающий клапан 2 радиатора системы рециркуляции ОГ-N381: обрыв цепи/короткое замыкание на массу
17908 P1500 Реле топливного насоса-J17: сбой в электрической цепи
17909 P1501 Реле топливного насоса-J17: короткое замыкание на массу
17910 P1502 Реле топливного насоса-J17: короткое замыкание на плюс
17911 P1503 Сигнал нагрузки на клемме генератора DF: недостоверный сигнал
17912 P1504 Система забора воздуха: обнаружена негерметичность
17913 P1505 Датчик положения дроссельной заслонки (выключатель)-F60: не замыкается/обрыв цепи
17914 P1506 Датчик положения дроссельной заслонки (выключатель)-F60: не размыкается / Короткое замыкание на массу
17915 P1507 Система холостого хода - программируемое значение: достигнут нижний предел
17916 P1508 Система холостого хода - программируемое значение: достигнут верхний предел
17917 P1509 Клапан поддержания оборотов холостого хода-N71: сбой в электрической цепи
17918 P1510 Клапан поддержания оборотов холостого хода-N71: короткое замыкание на плюс
17919 P1511 Клапан системы изменения геометрии впускного коллектора-N156: сбой в электрической цепи
17920 P1512 Клапан системы изменения геометрии впускного коллектора-N156: короткое замыкание на плюс
17921 P1513 Клапан 2 системы изменения геометрии впускного коллектора-N261: короткое замыкание на плюс
17922 P1514 Клапан 2 системы изменения геометрии впускного коллектора-N261: короткое замыкание на массу
17923 P1515 Клапан системы изменения геометрии впускного коллектора-N156: короткое замыкание на массу
17924 P1516 Клапан системы изменения геометрии впускного коллектора-N156: обрыв цепи
17925 P1517 Основное реле=>-J271: сбой в электрической цепи
17926 P1518 Основное реле=>-J271: короткое замыкание на плюс
17927 P1519 Ряд 1, сбой в работе регулятора фаз газораспределения
17928 P1520 Клапан 2 системы изменения геометрии впускного коллектора-N261: обрыв цепи
17929 P1521 Клапан 2 системы изменения геометрии впускного коллектора-N261: сбой в электрической цепи
17930 P1522 Ряд 2, сбой в работе регулятора фаз газораспределения
17931 P1523 Сигнал удара от блока управления подушками безопасности: недостоверный сигнал
17932 P1524 Реле топливного насоса-J17: обрыв цепи/короткое замыкание на массу
17933 P1525 Ряд 1, регулирование фаз газораспределения=>-N205: сбой в электрической цепи
17934 P1526 Ряд 1, регулирование фаз газораспределения=>-N205: короткое замыкание на плюс
17935 P1527 Ряд 1, регулирование фаз газораспределения=>-N205: короткое замыкание на массу
17936 P1528 Ряд 1, регулирование фаз газораспределения=>-N205: обрыв цепи
17937 P1529 Регулятор фаз газораспределения: короткое замыкание на плюс
17938 P1530 Регулятор фаз газораспределения: короткое замыкание на массу
17939 P1531 Регулятор фаз газораспределения: обрыв цепи
17940 P1532 Регулирование холостого хода при работе на обедненной смеси: обороты ниже номинального значения
17941 P1533 Ряд 2, регулирование фаз газораспределения=>-N208: сбой в электрической цепи
17942 P1534 Ряд 2, регулирование фаз газораспределения=>-N208: короткое замыкание на плюс
17943 P1535 Ряд 2, регулирование фаз газораспределения=>-N208: короткое замыкание на массу
17944 P1536 Ряд 2, регулирование фаз газораспределения=>-N208: обрыв цепи
17945 P1537 Клапан отключения подачи топлива-N109: сбой в работе
17946 P1538 Клапан отключения подачи-N109: обрыв цепи/короткое замыкание на массу
17947 P1539 Датчик педали сцепления-F36: недостоверный сигнал
17948 P1540 Датчик скорости движения автомобиля: слишком высокий уровень сигнала
17949 P1541 Реле топливного насоса-J17: обрыв цепи
17950 P1542 Датчик угла поворота привода дроссельной заслонки-G187: недостоверный сигнал
17951 P1543 Датчик угла поворота привода дроссельной заслонки-G187: слишком низкий уровень сигнала
17952 P1544 Датчик угла поворота привода дроссельной заслонки-G187: слишком высокий уровень сигнала
17953 P1545 Управление дроссельной заслонкой: сбой в работе
17954 P1546 Электромагнитный клапан ограничения давления наддува-N75: короткое замыкание на плюс
17955 P1547 Электромагнитный клапан ограничения давления наддува-N75: короткое замыкание на массу
17956 P1548 Электромагнитный клапан ограничения давления наддува-N75: обрыв цепи
17957 P1549 Электромагнитный клапан ограничения давления наддува-N75: обрыв цепи/короткое замыкание на массу
17958 P1550 Диапазон регулирования давления наддува
17959 P1551 Датчик высоты-F96: короткое замыкание на плюс
17960 P1552 Датчик высоты-F96: обрыв цепи/замыкание на массу
17961 P1553 Сигнал датчика высоты/давление во впускном коллекторе: недостоверное соотношение
17962 P1554 Блок дроссельной заслонки-J338: не выполнены условия базовой установки
17963 P1555 Превышено максимальное давление наддува
17964 P1556 Регулятор давления наддува: выход из диапазона регулирования (меньше нижнего предела)
17965 P1557 Регулятор давления наддува: выход из диапазона регулирования (больше верхнего предела)
17966 P1558 Электропривод дроссельной заслонки-G186: сбой в электрической цепи
17967 P1559 Блок дроссельной заслонки-J338: ошибка базовой установки
17968 P1560 Превышены максимальные обороты двигателя
17969 P1561 Дозатор топливоподающего насоса-N146: диапазон регулирования
17970 P1562 Дозатор топливоподающего насоса-N146: верхний предел
17971 P1563 Дозатор топливоподающего насоса-N146: нижний предел
17972 P1564 Блок дроссельной заслонки-J338: недостаточное напряжение при выполнении базовой установки
17973 P1565 Блок дроссельной заслонки-J338: не достигается нижний предел
17974 P1566 Сигнал нагрузки от климатической установки: недостоверный сигнал
17975 P1567 Сигнал нагрузки от компрессора климатической установки: нет сигнала
17976 P1568 Блок дроссельной заслонки-J338: механическое повреждение
17977 P1569 Переключатель управления круиз-контролем-E45: недостоверный сигнал
17978 P1570 Блокирован блок управления двигателя
17979 P1571 Электромагнитный клапан левой электрогидравлической опоры двигателя-N144: короткое замыкание на плюс
17980 P1572 Электромагнитный клапан левой электрогидравлической опоры двигателя-N144: короткое замыкание на массу
17981 P1573 Электромагнитный клапан левой электрогидравлической опоры двигателя-N144: обрыв цепи
17982 P1574 Электромагнитный клапан левой электрогидравлической опоры двигателя-N144: сбой в электрической цепи
17983 P1575 Электромагнитный клапан правой электрогидравлической опоры двигателя-N145: короткое замыкание на плюс
17984 P1576 Электромагнитный клапан правой электрогидравлической опоры двигателя-N145: короткое замыкание на массу
17985 P1577 Электромагнитный клапан правой электрогидравлической опоры двигателя-N145: обрыв цепи
17986 P1578 Электромагнитный клапан правой электрогидравлической опоры двигателя-N145: сбой в электрической цепи
17987 P1579 Блок дроссельной заслонки-J338: не начата адаптация
17988 P1580 Электропривод дроссельной заслонки 1 ряда цилиндров: сбой в работе
17989 P1581 Блок дроссельной заслонки-J338: не выполнена базовая настройка
17990 P1582 Регулирование холостого хода: достигнут предел адаптации
17991 P1583 Клапаны опор КП-N262/263: короткое замыкание на плюс
17992 P1584 Клапаны опор КП-N262/263: короткое замыкание на массу
17993 P1585 Клапаны опор КП-N262/263: обрыв цепи
17994 P1586 Электромагнитные клапаны электрогидравлических опор двигателя-N144/145: короткое замыкание на плюс
17995 P1587 Электромагнитные клапаны электрогидравлических опор двигателя-N144/145: короткое замыкание на массу
17996 P1588 Электромагнитные клапаны электрогидравлических опор двигателя-N144/145: обрыв цепи
17997 P1589 Потенциометр поворотной рукоятки регулировки температуры-G267: короткое замыкание на массу
17998 P1590 Потенциометр поворотной рукоятки регулировки температуры-G267: обрыв цепи
17999 P1591 Электромагнитный клапан ограничения давления наддува N75: не работает
18000 P1592 Сигнал датчика высоты/датчика давления наддува: недостоверное соотношение
18001 P1593 Адаптация высоты: сигнал за пределами допуска
18002 P1594 Датчик температуры масла системы регулирования фаз газораспределения-G277: короткое замыкание на плюс
18003 P1595 Датчик температуры масла системы регулирования фаз газораспределения-G277: короткое замыкание на массу
18004 P1596 Шина данных-привод: недостоверное сообщение от блока управления системы регулирования дорожного просвета-J197
18005 P1597 Шина данных-привод: недостоверное сообщение от блока управления системы регулирования дорожного просвета-J197
18006 P1598 Датчик температуры масла системы регулирования фаз газораспределения-G277: недостоверный сигнал
18007 P1599 Регулирование холостого хода при работе на обедненной смеси: обороты двигателя выше номинального значения
18008 P1600 Напряжение питания на кл. 15: напряжение слишком низкое
18009 P1601 Реле электропитания клеммы 30-J317: недостоверный сигнал
18010 P1602 Напряжение питания на кл. 30: напряжение слишком низкое
18011 P1603 Неисправен блок управления
18012 P1604 Неисправен блок управления
18013 P1605 Датчик бездорожья/датчик ускорения: сбой в электрической цепи
18014 P1606 Информ. о плохой дороге/ заданный момент двигателя от блока управления ABS: сбой в электрической цепи
18015 P1607 Сигнал скорости: сообщение об ошибке от комбинации приборов
18016 P1608 Сигнал угла поворота: сообщение об ошибке от датчика угла поворота рулевого колеса
18017 P1609 Сработала система отключения при ударе
18018 P1610 Неисправен блок управления
18019 P1611 Запрос включения аварийной лампы: короткое замыкание на массу
18020 P1612 Неправильно кодирован блок управления двигателя
18021 P1613 Запрос включения аварийной лампы: обрыв цепи/короткое замыкание на плюс
18022 P1614 Запрос включения аварийной лампы: недостоверный сигнал
18023 P1615 Датчик температуры масла-G8: недостоверный сигнал
18024 P1616 Контрольная лампа, сигнализирующая о прогреве камеры сгорания свечами накаливания-K29: короткое замыкание на плюс
18025 P1617 Контрольная лампа, сигнализирующая о прогреве камеры сгорания свечами накаливания-K29: обрыв цепи/короткое замыкание на массу
18026 P1618 Реле включения свечей накаливания-J52: короткое замыкание на плюс
18027 P1619 Реле включения свечей накаливания-J52: обрыв цепи/короткое замыкание на массу
18028 P1620 Сигнал температуры охлаждающей жидкости: обрыв цепи/короткое замыкание на плюс
18029 P1621 Сигнал температуры охлаждающей жидкости: короткое замыкание на массу
18030 P1622 Сигнал температуры охлаждающей жидкости Недостоверный сигнал
18031 P1623 Шина данных-привод: нет связи
18032 P1624 Запрос включения аварийной лампы: активен
18033 P1625 Шина данных-привод: недостоверное сообщение от блока управления КП
18034 P1626 Шина данных-привод: отсутствие сообщений от блока управления КП
18035 P1627 Шина данных-привод: отсутствие сообщений от блока управления ТНВД
18036 P1628 Шина данных-привод: отсутствие сообщений от датчика угла поворота рулевого колеса
18037 P1629 Шина данных-привод: отсутствие сообщений от блока управления адаптивного круиз-контроля
18038 P1630 Датчик положения педали акселератора-G79: слишком низкий уровень сигнала
18039 P1631 Датчик положения педали акселератора-G79: слишком высокий уровень сигнала
18040 P1632 Датчик положения педали акселератора-G79: напряжение питания
18041 P1633 Датчик 2 положения педали акселератора-G185: слишком низкий уровень сигнала
18042 P1634 Датчик 2 положения педали акселератора-G185: слишком высокий уровень сигнала
18043 P1635 Шина данных-привод: отсутствие сообщений от блока управления климатической установки
18044 P1636 Шина данных-привод: отсутствие сообщений от блока управления подушек безопасности
18045 P1637 Шина данных-привод: отсутствие сообщений от центрального коммутационного блока
18046 P1638 Шина данных-привод: отсутствие сообщений от блока управления сцепления/муфты
18047 P1639 Датчики 1/2 положения педали акселератора-G79+G185: недостоверный сигнал
18048 P1640 Неисправен блок управления
18049 P1641 Считать данные из памяти неисправностей блока управления климатической установки
18050 P1642 Считать данные из памяти неисправностей блока управления подушек безопасности
18051 P1643 Считать данные из памяти неисправностей центрального коммутационного блока
18052 P1644 Считать данные из памяти неисправностей блока управления сцепления/муфты
18053 P1645 Шина данных-привод: отсутствие сообщений от электронной системы полного привода
18054 P1646 Считать данные из памяти неисправностей электронной системы полного привода
18055 P1647 Проверить кодирование/модификации блоков управления трансмиссии
18056 P1648 Повреждена шина данных-привод
18057 P1649 Шина данных-привод: отсутствие сообщений от блока управления ABS
18058 P1650 Шина данных-привод: отсутствие сообщений от комбинации приборов
18059 P1651 Шина данных-привод: нет сообщений
18060 P1652 Считать данные из памяти неисправностей блока управления КП
18061 P1653 Считать данные из памяти неисправностей блока управления ABS
18062 P1654 Считать данные из памяти неисправностей комбинации приборов
18063 P1655 Считать данные из памяти неисправностей блока управления адаптивного круиз-контроля
18064 P1656 Климатическая установка вход/выход: короткое замыкание на массу
18065 P1657 Климатическая установка вход/выход: короткое замыкание на плюс
18066 P1658 Шина данных-привод: недостоверное сообщение от блока управления адаптивного круиз-контроля
18067 P1659 Управление вентилятором радиатора 1: короткое замыкание на плюс
18068 P1660 Управление вентилятором радиатора 1: короткое замыкание на массу
18069 P1661 Управление вентилятором радиатора 2: короткое замыкание на плюс
18070 P1662 Управление вентилятором радиатора 2: короткое замыкание на массу
18071 P1663 Подача управляющего сигнала на клапаны насос-форсунок: короткое замыкание на плюс
18072 P1664 Подача управляющего сигнала на клапаны насос-форсунок: сбой в электрической цепи
18073 P1665 Подача управляющего сигнала на клапаны насос-форсунок: механическое повреждение
18074 P1666 Клапан насос-форсунки цилиндра 1-N240: сбой в электрической цепи
18075 P1667 Клапан насос-форсунки цилиндра 2-N241: сбой в электрической цепи
18076 P1668 Клапан насос-форсунки цилиндра 3-N242: сбой в электрической цепи
18077 P1669 Клапан насос-форсунки цилиндра 4-N243: сбой в электрической цепи
18078 P1670 Клапан насос-форсунки цилиндра 5-N244: сбой в электрической цепи
18079 P1671 Клапан насос-форсунки цилиндра 6-N245: сбой в электрической цепи
18080 P1672 Управление вентилятором радиатора 1: обрыв цепи/короткое замыкание на массу
18081 P1673 Сигнал скорости: сообщение об ошибке от блока управления ABS
18082 P1674 Шина данных-привод: недостоверное сообщение от комбинации приборов
18083 P1675 Шина данных-привод: недостоверное сообщение от блока управления ТНВД
18084 P1676 Аварийная лампа электропривода дроссельной заслонки-K132: сбой в электрической цепи
18085 P1677 Аварийная лампа электропривода дроссельной заслонки-K132: короткое замыкание на плюс
18086 P1678 Аварийная лампа электропривода дроссельной заслонки-K132: короткое замыкание на массу
18087 P1679 Аварийная лампа электропривода дроссельной заслонки-K132: обрыв цепи
18088 P1680 Включен устойчивый от сброса аварийный режим
18089 P1681 Программирование блоков управления: программирование не завершено
18090 P1682 Шина данных-привод: недостоверное сообщение от блока управления ABS
18091 P1683 Шина данных-привод: недостоверное сообщение от блока управления подушек безопасности
18092 P1684 Программирование блоков управления: ошибка передачи данных
18093 P1685 Шина данных-привод: недостоверное сообщение от датчика угла поворота рулевого колеса
18094 P1686 Неисправность блока управления: ошибка программирования
18095 P1687 Шина данных-привод: недостоверное сообщение от блока управления климатической установки
18096 P1688 Шина данных-привод: недостоверное сообщение от электронной системы полного привода
18097 P1689 Шина данных-привод: недостоверное сообщение от центрального коммутационного блока
18098 P1690 Аварийная лампа системы самодиагностики-K83: сбой в электрической цепи
18099 P1691 Аварийная лампа системы самодиагностики-K83: обрыв цепи
18100 P1692 Аварийная лампа самодиагностики-K83: короткое замыкание на массу
18101 P1693 Аварийная лампа самодиагностики-K83: короткое замыкание на плюс
18102 P1694 Аварийная лампа самодиагностики-K83: обрыв цепи/короткое замыкание на массу
18104 P1696 Шина данных-привод: недостоверное сообщение от блока управления рулевой колонки
18105 P1697 Считать данные из памяти неисправностей датчика угла поворота рулевого колеса
18106 P1698 Считать данные из памяти неисправностей блока управления рулевой колонки
18107 P1699 Шина данных-привод: отсутствие сообщения от блока управления рулевой колонки
18108 P1700 Датчик давления в тормозной системе-F270: недостоверный сигнал.
18109 P1701 Блок управления коробки передач заблокирован
18110 P1702 Ошибка не может активировать функцию замены блока управления, поскольку имеется ошибка с равнозначным приоритетом
18111 P1703 Работа в аварийном режиме по причине перезагрузки блока управления
18112 P1704 Выключатель режима интенсивного разгона (Kick-Down)-F8: сбой в электрической цепи
18113 P1705 Контроль включения передачи и передаточного числа: достигнут предел адаптации
18114 P1706 Повреждена коробка передач
18115 P1707 Помехи в работе блока Mechatronik
18119 P1711 Сигнал частоты вращения колеса 1=>передний левый датчик-G47: недостоверный сигнал
18124 P1716 Сигнал частоты вращения колеса 2=>передний правый датчик-G45: недостоверный сигнал
18129 P1721 Сигнал частоты вращения колеса 3=>задний левый датчик-G46: недостоверный сигнал
18131 P1723 Сигнал блокировки пуска: обрыв цепи
18132 P1724 Сигнал блокировки пуска: короткое замыкание на массу
18134 P1726 Сигнал частоты вращения колеса 4=>задний правый датчик-G44: недостоверный сигнал
18136 P1728 Различные частоты вращения колес: недостоверный сигнал
18137 P1729 Сигнал блокировки пуска: короткое замыкание на плюс
18141 P1733 Переключатель Tiptronic, понижение передачи-F189: короткое замыкание на массу
18145 P1737 Датчик 1 давления в гидросистеме КП: обрыв цепи/короткое замыкание на плюс
18146 P1738 Датчик 2 давления в гидросистеме КП: обрыв цепи/короткое замыкание на плюс
18147 P1739 Переключатель Tiptronic, повышение передачи-F189: короткое замыкание на массу
18148 P1740 Система контроля температуры муфты
18149 P1741 Адаптация давления сцепления: достигнут предел адаптации
18150 P1742 Адаптация момента замыкания муфты: достигнут предел адаптации
18151 P1743 Сигнализатор пробуксовки муфты: слишком высокий уровень сигнала
18152 P1744 Переключатель Tiptronic, опознавание-F189: короткое замыкание на массу
18153 P1745 Подача напряжения на электромагнитные клапаны: короткое замыкание на плюс
18154 P1746 Подача напряжения на электромагнитные клапаны: сбой в электрической цепи
18155 P1747 Подача напряжения на электромагнитные клапаны: обрыв цепи/короткое замыкание на массу
18156 P1748 Неисправен блок управления
18157 P1749 Неправильно кодирован блок управления АКП
18158 P1750 Электропитание: слишком низкий уровень напряжения
18159 P1751 Электропитание: слишком высокий уровень напряжения
18160 P1752 Электропитание: недостоверный сигнал
18161 P1753 Переключатель Tiptronic-F189: недостоверный сигнал
18162 P1754 Переключатель Tiptronic-F189: обрыв цепи/короткое замыкание на плюс
18163 P1755 Переключатель Tiptronic, понижение передачи-F189: обрыв цепи/короткое замыкание на плюс
18164 P1756 Переключатель Tiptronic, опознавание-F189: обрыв цепи/короткое замыкание на плюс
18165 P1757 Электропитание: обрыв цепи
18166 P1758 Электропитание кл. 15: обрыв цепи
18167 P1759 Температура масла КП: многократно превышена
18168 P1760 Блокировка селектора АКП=>электромагнит-N110: сбой в электрической цепи
18169 P1761 Блокировка селектора АКП=>электромагнит-N110: короткое замыкание на массу
18170 P1762 Блокировка селектора АКП=>электромагнит-N110: короткое замыкание на плюс
18171 P1763 Блокировка селектора АКП=>электромагнит-N110: обрыв цепи
18172 P1764 Система контроля температуры КП
18173 P1765 Датчик давления в гидросистеме 2 для АКП-G194: достигнут предел адаптации
18174 P1766 Сигнал дроссельной заслонке от блока управления двигателя: обрыв цепи/короткое замыкание на плюс
18175 P1767 Сигнал дроссельной заслонке от блока управления двигателя: короткое замыкание на массу
18176 P1768 Датчик давления в гидросистеме 2 для АКП-G194: слишком высокий уровень сигнала
18177 P1769 Датчик давления в гидросистеме 2 для АКП-G194: слишком низкий уровень сигнала
18178 P1770 Сигнал нагрузки от блока управления двигателя: недостоверный сигнал
18179 P1771 Сигнал нагрузки от блока управления двигателя: обрыв цепи/короткое замыкание на плюс
18180 P1772 Сигнал нагрузки от блока управления двигателя: короткое замыкание на массу
18181 P1773 Датчик давления в гидросистеме 1 для АКП-G193: слишком высокий уровень сигнала
18182 P1774 Датчик давления в гидросистеме 1 для АКП-G193: слишком низкий уровень сигнала
18183 P1775 Датчик давления в гидросистеме 1 для АКП-G193: достигнут предел адаптации
18184 P1776 Датчик давления в гидросистеме 1 для АКП-G193: недостоверный сигнал
18185 P1777 Датчик давления в гидросистеме 2 для АКП-G194: недостоверный сигнал
18186 P1778 Клапан 7: сбой в электрической цепи
18188 P1780 Ошибка уменьшения момента
18189 P1781 Сигнал снижения крутящего момента: обрыв цепи/короткое замыкание на плюс
18190 P1782 Сигнал снижения крутящего момента: короткое замыкание на плюс
18191 P1783 Адаптация момента замыкания муфты 2: достигнут предел адаптации
18192 P1784 Провод повышения/понижения передачи: обрыв цепи/короткое замыкание на массу
18193 P1785 Провод повышения/понижения передачи: короткое замыкание на плюс
18194 P1786 Сигнал света заднего хода: обрыв цепи
18195 P1787 Сигнал света заднего хода: короткое замыкание на массу
18196 P1788 Сигнал света заднего хода: короткое замыкание на плюс
18197 P1789 Регулирование оборотов холостого хода: сообщение об ошибке от блока управления двигателя
18198 P1790 Сигнал указателя включенной передачи: обрыв цепи
18199 P1791 Сигнал указателя включенной передачи: короткое замыкание на массу
18200 P1792 Сигнал указателя включенной передачи: короткое замыкание на плюс
18201 P1793 Датчик 2 частоты вращения выходного вала КП-G196: нет сигнала
18203 P1795 Сигнал скорости движения: обрыв цепи
18204 P1796 Сигнал скорости движения: короткое замыкание на массу
18205 P1797 Сигнал скорости движения: короткое замыкание на плюс
18206 P1798 Датчик 2 частоты вращения выходного вала КП-G196: недостоверный сигнал
18207 P1799 Датчик 2 частоты вращения выходного вала КП-G196: слишком большая частота вращения
18208 P1800 Клапан исполнительного гидропривода-N331: сбой в электрической цепи
18209 P1801 Включение звукового сигнала: короткое замыкание на плюс
18210 P1802 Датчик педали сцепления-F194: недостоверный сигнал
18211 P1803 Планетарный демультипликатор: механическое повреждение
18212 P1804 Датчик хода исполнительного гидропривода-G302: сбой в электрической цепи
18213 P1805 Датчик хода исполнительного гидропривода-G302: превышено верхнее предельное значение
18214 P1806 Датчик хода исполнительного гидропривода-G302: пройдено нижнее предельное значение
18215 P1807 Датчик хода исполнительного гидропривода-G302: базовая установка/адаптация не выполнена или выполнена неверно
18216 P1808 Датчик хода исполнительного гидропривода-G302: недостоверный сигнал
18217 P1809 Гидронасос демультипликатора-V190: сбой в электрической цепи
18221 P1813 Клапан регулировки давления 1 для АКП-N215: сбой в электрической цепи
18222 P1814 Клапан регулировки давления 1 для АКП-N215: обрыв цепи/короткое замыкание на массу
18223 P1815 Клапан регулировки давления 1 для АКП-N215: короткое замыкание на плюс
18226 P1818 Клапан регулировки давления 2 для АКП-N216: сбой в электрической цепи
18227 P1819 Клапан регулировки давления 2 для АКП-N216: обрыв цепи/короткое замыкание на массу
18228 P1820 Клапан регулировки давления 2 для АКП-N216: короткое замыкание на плюс
18231 P1823 Клапан регулировки давления 3 для АКП-N217: сбой в электрической цепи
18232 P1824 Клапан регулировки давления 3 для АКП-N217: обрыв цепи/короткое замыкание на массу
18233 P1825 Клапан регулировки давления 3 для АКП-N217: короткое замыкание на плюс
18236 P1828 Клапан регулировки давления 4 для АКП-N218: сбой в электрической цепи
18237 P1829 Клапан регулировки давления 4 для АКП-N218: обрыв цепи/короткое замыкание на массу
18238 P1830 Клапан регулировки давления 4 для АКП-N218: короткое замыкание на плюс
18241 P1833 Клапан регулировки давления 5 для АКП-N233: сбой в электрической цепи
18242 P1834 Клапан регулировки давления 5 для АКП-N233: обрыв цепи/короткое замыкание на массу
18243 P1835 Клапан регулировки давления 5 для АКП-N233: короткое замыкание на плюс
18246 P1838 Клапан регулировки давления 6 для АКП-N371: сбой в электрической цепи
18247 P1839 Клапан регулировки давления 6 для АКП-N371: обрыв цепи/короткое замыкание на массу
18248 P1840 Клапан регулировки давления 6 для АКП-N371: короткое замыкание на плюс
18249 P1841 Не совместимы модификации блоков управления двигателя и коробки передач
18250 P1842 Считать данные из памяти неисправностей комбинации приборов
18251 P1843 Считать данные из памяти неисправностей блока управления адаптивного круиз-контроля
18252 P1844 Считать данные из памяти неисправностей центрального коммутационного блока
18253 P1845 Считать данные из памяти неисправностей блока управления рулевой колонки-J527
18255 P1847 Считать данные из памяти неисправностей блока управления ABS
18256 P1848 Считать данные из памяти неисправностей блока управления двигателя
18257 P1849 Считать данные из памяти неисправностей блока управления коробки передач
18258 P1850 Шина данных-привод: отсутствие сообщений от блока управления двигателя
18259 P1851 Шина данных-привод: отсутствие сообщений от блока управления ABS
18260 P1852 Шина данных-привод: недостоверное сообщение от блока управления двигателя
18261 P1853 Шина данных-привод: недостоверное сообщение от блока управления ABS
18262 P1854 Шина данных-привод: повреждение оборудования
18263 P1855 Шина данных-привод: контроль актуальности программы
18264 P1856 Потенциометр дроссельной заслонки-G69: сообщение об ошибке от блока управления двигателя
18265 P1857 Сигнал нагрузки: сообщение об ошибке от блока управления двигателя
18266 P1858 Сигнал частоты вращения от блока управления двигателя: сообщение об ошибке от блока управления двигателя
18267 P1859 Выключатель стоп-сигнала-F: сообщение об ошибке от блока управления двигателя
18268 P1860 Включатель режима интенсивного разгона (Kick-Down)-F8: сообщение об ошибке от блока управления двигателя
18269 P1861 Датчик положения педали акселератора-G79: сообщение об ошибке от блока управления двигателя
18270 P1862 Шина данных-привод: отсутствие сообщений от комбинации приборов
18271 P1863 Шина данных-привод: отсутствие сообщений от датчика угла поворота рулевого колеса
18272 P1864 Шина данных-привод: отсутствие сообщений от блока управления ADR
18273 P1865 Шина данных-привод: отсутствие сообщений от центрального коммутационного блока
18274 P1866 Шина данных-привод: нет сообщений
18275 P1867 Шина данных-привод: отсутствие сообщений от блока управления рулевой колонки-J527
18276 P1868 Клапан левой опоры КП-N262: короткое замыкание на плюс
18277 P1869 Клапан левой опоры КП-N262: короткое замыкание на массу
18278 P1870 Клапан левой опоры КП-N262: обрыв цепи
18279 P1871 Клапан правой опоры КП-N263: короткое замыкание на плюс
18280 P1872 Клапан правой опоры КП-N263: короткое замыкание на массу
18281 P1873 Клапан правой опоры КП-N263: обрыв цепи
18282 P1874 Клапан передней опоры силового агрегата: короткое замыкание на плюс
18283 P1875 Клапан передней опоры силового агрегата: короткое замыкание на массу
18284 P1876 Клапан передней опоры силового агрегата: обрыв цепи
18285 P1877 Подача сигнала управления на контур охлаждения КП-J696: обрыв цепи
18286 P1878 Подача сигнала управления на контур охлаждения КП-J696: короткое замыкание на плюс
18287 P1879 Подача сигнала управления на контур охлаждения КП-J696: короткое замыкание на массу
18288 P1880 Шина данных: отсутствие сообщения от блока управления диагностическим интерфейсом шин данных
18289 P1881 Сигнал надлежащего ускорения: нет сообщения
18290 P1882 Шина данных-привод: отсутствие сообщений от блока управления электромеханического стояночного тормоза
18291 P1883 Сигнал блокировки стартера (P/N): недостоверный сигнал
18292 P1884 Сигнал света заднего хода: короткое замыкание на массу
18293 P1885 Сигнал света заднего хода: короткое замыкание на плюс
18294 P1886 Сигнал света заднего хода: обрыв цепи
18295 P1887 Сигнал скорости: частота вращения колес от блока управления тормозов: недостоверный сигнал
18296 P1888 Запорный клапан системы охлаждения-N82: короткое замыкание на плюс
18297 P1889 Запорный клапан системы охлаждения-N82: короткое замыкание на массу/обрыв цепи
18308 P1900 Управление вентилятором радиатора 2: обрыв цепи/короткое замыкание на массу
18309 P1901 Блок управления работы вентиляторов радиатора после выкл. двигателя-J138: короткое замыкание на плюс
18310 P1902 Блок управления работы вентиляторов радиатора после выкл. двигателя-J138: обрыв цепи/короткое замыкание на массу
18311 P1903 Клапан вентилятора радиатора-N313: короткое замыкание на плюс
18312 P1904 Клапан вентилятора радиатора-N313: обрыв цепи/короткое замыкание на массу
18313 P1905 Реле насоса системы охлаждения наддувочного воздуха-J536: короткое замыкание на плюс
18314 P1906 Реле насоса системы охлаждения наддувочного воздуха-J536: обрыв цепи/короткое замыкание на массу
18315 P1907 Неисправность шины данных двигатель/двигатель
18316 P1908 Шина данных двигатель/двигатель: контроль актуальности ПО
18317 P1909 Шина данных двигатель/двигатель: отсутствие сообщения от блока управления двигателя 1
18318 P1910 Шина данных двигатель/двигатель: отсутствие сообщения от блока управления двигателя 2
18319 P1911 Провод синхронизации двигатель/двигатель: сбой в электрической цепи
18320 P1912 Датчик давления для усилителя тормозов-G294, короткое замыкание на плюс
18321 P1913 Датчик давления для усилителя тормозов-G294, короткое замыкание на массу
18322 P1914 Датчик давления для усилителя тормозов-G294: недостоверный сигнал
18323 P1915 Реле прокачки ОЖ после выкл. двигателя-J151: короткое замыкание на плюс
18324 P1916 Реле прокачки ОЖ после выкл. двигателя-J151: короткое замыкание на массу
18325 P1917 Реле прокачки ОЖ после выкл. двигателя-J151: обрыв цепи
18326 P1918 Сигнал нагрузки от клеммы генератора DF: обрыв цепи/короткое замыкание на плюс
18327 P1919 Сигнал нагрузки от клеммы генератора DF: короткое замыкание на массу
18328 P1920 Электромагнитные клапаны электрогидравлической опоры двигателя-N144/145: обрыв цепи/короткое замыкание на массу
18329 P1921 Датчик температуры наружного воздуха 2-G249: короткое замыкание на массу
18330 P1922 Датчик температуры наружного воздуха 2-G249: обрыв цепи/короткое замыкание на плюс
18331 P1923 Считать данные из памяти неисправностей блока управления двигателя 2
18332 P1924 Кодирование контактов блоков управления: недостоверный сигнал
18333 P1925 Реле дополнительного насоса системы охлаждения-J496: короткое замыкание на плюс
18334 P1926 Реле дополнительного насоса системы охлаждения-J496: короткое замыкание на массу
18335 P1927 Реле дополнительного насоса системы охлаждения-J496: обрыв цепи
18336 P1928 Запрос иммобилайзера не выполнялся
18337 P1929 Вентилятор системы охлаждения-V7: обрыв цепи
18338 P1930 Вентилятор радиатора 2-V177: обрыв цепи
18339 P1931 Блок управления вентилятора радиатора-J293: сбой в работе
18340 P1932 Шина данных-привод: недостоверное сообщение от блока управления доступа и разрешения пуска двигателя
18341 P1933 Управление дроссельной заслонкой 2: сбой в работе
18342 P1934 Датчик температуры контура привода вентилятора радиатора-G382: слишком низкий уровень сигнала
18343 P1935 Датчик температуры контура привода вентилятора радиатора-G382: слишком высокий уровень сигнала
18344 P1936 Отключение генератора: обрыв цепи /короткое замыкание на массу
18345 P1937 Отключение генератора: короткое замыкание на плюс
18346 P1938 Реле дополнительного насоса системы охлаждения-J496: обрыв цепи/короткое замыкание на массу
18347 P1939 Шина данных-привод: отсутствие сообщения от блока управления доступа и разрешения пуска двигателя
18348 P1940 Шина данных-привод: отсутствие сообщения от блока управления контроля АКБ
18349 P1941 Шина данных-привод: недостоверное сообщение от блока управления контроля АКБ
18350 P1942 Шина данных-привод: отсутствие сообщения от блока управления системы регулирования дорожного просвета
18351 P1943 Шина данных-привод: недостоверное сообщение от блока управления системы регулирования дорожного просвета
18352 P1944 Блок управления 1 вентилятора радиатора: превышение температуры
18353 P1945 Блок управления 1 вентилятора радиатора, включение вентилятора: короткое замыкание
18354 P1946 Неисправность блока управления вентилятора радиатора 1
18355 P1947 Блок управления 2 вентилятора радиатора: превышение температуры
18356 P1948 Блок управления 2 вентилятора радиатора, включение вентилятора: короткое замыкание
18357 P1949 Неисправность блока управления вентилятора радиатора 2
18358 P1950 Вентилятор системы охлаждения-V7: затруднен ход/блокирован
18359 P1951 Вентилятор 2 системы охлаждения-V177: затруднен ход/блокирован
18360 P1952 Неисправность блока управления 1 турбонагнетателя
18361 P1953 Неисправность блока управления 2 турбонагнетателя
18362 P1954 Блок управления свечей накаливания 2, электрическая цепь свечей накаливания: сбой в электрической цепи
18363 P1955 Блок управления свечей накаливания 2-J703: недостоверный сигнал
18364 P1956 Датчик температуры ОГ 2 для 1 ряда цилиндров-G448: сбой в электрической цепи
18365 P1957 Датчик температуры ОГ 2 для 1 ряда цилиндров-G448: короткое замыкание на массу
18366 P1958 Датчик температуры ОГ 2 для 1 ряда цилиндров-G448: короткое замыкание на плюс
18367 P1959 Датчик температуры ОГ 2 для 1 ряда цилиндров-G448: недостоверный сигнал
18368 P1960 Регулирование температуры ОГ, 3 ряд цилиндров: превышен верхний предел регулирования
18369 P1961 Датчик температуры ОГ 2 для 2 ряда цилиндров-G449: сбой в электрической цепи
18370 P1962 Датчик температуры ОГ 2 для 2 ряда цилиндров-G449: короткое замыкание на массу
18371 P1963 Датчик температуры ОГ 2 для 2 ряда цилиндров-G449: короткое замыкание на плюс
18372 P1964 Датчик температуры ОГ 2 для 2 ряда цилиндров-G449: недостоверный сигнал
18373 P1965 Регулирование температуры ОГ, 4 ряд цилиндров: превышен верхний предел регулирования
18374 P1966 Реле насоса вторичного воздуха 3-J704: обрыв цепи
18375 P1967 Реле насоса вторичного воздуха 3-J704: короткое замыкание на плюс
18376 P1968 Реле насоса вторичного воздуха 3-J704: короткое замыкание на массу
18377 P1969 Реле насоса вторичного воздуха 3-J704: сбой в электрической цепи
18378 P1970 Реле насоса вторичного воздуха 4-J705: обрыв цепи
18379 P1971 Реле насоса вторичного воздуха 4-J705: короткое замыкание на плюс
18380 P1972 Реле насоса вторичного воздуха 4-J705: короткое замыкание на массу
18381 P1973 Реле насоса вторичного воздуха 4-J705: сбой в электрической цепи
18382 P1974 Клапан управления подачей вторичного воздуха 3-N384: сбой в электрической цепи
18383 P1975 Клапан управления подачей вторичного воздуха 3-N384: короткое замыкание на массу
18384 P1976 Клапан управления подачей вторичного воздуха 3-N384: короткое замыкание на плюс
18385 P1977 Клапан управления подачей вторичного воздуха 3-N384: обрыв цепи
18386 P1978 Клапан управления подачей вторичного воздуха 4-N385: сбой в электрической цепи
18387 P1979 Клапан управления подачей вторичного воздуха 4-N385: короткое замыкание на массу
18388 P1980 Клапан управления подачей вторичного воздуха 4-N385: короткое замыкание на плюс
18389 P1981 Клапан управления подачей вторичного воздуха 4-N385: обрыв цепи
18390 P1982 Регулирование температуры ОГ, 3 ряд цилиндров: недостоверные данные
18391 P1983 Регулирование температуры ОГ, 4 ряд цилиндров: недостоверные данные
18392 P1984 Вентилятор радиатора 3-V284: вращение затруднено/застопорен
18393 P1985 Блок управления 2 вентилятора радиатора-J671: сбой в работе
18394 P1986 Блок управления 3 вентилятора радиатора, включение вентилятора: короткое замыкание
18395 P1987 Ограничение функции по температуре тормозов
18396 P1988 Реле вентилятора радиатора 3-J752: обрыв цепи
18397 P1989 Реле вентилятора радиатора 3-J752: короткое замыкание на плюс
18398 P1990 Реле вентилятора радиатора 3-J752: короткое замыкание на массу
18399 P1991 Неисправен блок управления
18400 P1992 Потенциометр 2 системы рециркуляции ОГ-G466: ошибка базовой установки
18401 P1993 Потенциометр 2 системы рециркуляции ОГ-G466: слишком высокий уровень сигнала
18402 P1994 Потенциометр 2 системы рециркуляции ОГ-G466: слишком низкий уровень сигнала
18403 P1995 Не опознан сигнал открытой двери
18404 P1996 Трение слишком велико: код Е1
18405 P1997 Трение слишком велико: код А1
18406 P1998 Трение слишком велико: код Е2
18407 P1999 Трение слишком велико: код Е2
18434 P2002 Сажевый фильтр 1 ряда цилиндров: сбой в работе
18435 P2003 Сажевый фильтр 2 ряда цилиндров: сбой в работе
18436 P2004 Не закрываются заслонки впускных каналов 1 ряда цилиндров
18437 P2005 Не закрываются заслонки впускных каналов 2 ряда цилиндров
18438 P2006 Не открываются заслонки впускных каналов 1 ряда цилиндров
18439 P2007 Не открываются заслонки впускных каналов 2 ряда цилиндров
18440 P2008 Заслонки впускных каналов: сбой в электрической цепи
18441 P2009 Заслонки впускных каналов: короткое замыкание на массу
18442 P2010 Заслонки впускных каналов: короткое замыкание на плюс
18443 P2011 Заслонки 2 впускных каналов: сбой в электрической цепи
18444 P2012 Заслонки 2 впускных каналов: короткое замыкание на массу
18445 P2013 Заслонки 2 впускных каналов: короткое замыкание на плюс
18446 P2014 Датчик положения заслонок впускных каналов: сбой в электрической цепи
18447 P2015 Датчик положения заслонок впускных каналов: недостоверный сигнал
18448 P2016 Датчик положения заслонок впускных каналов: короткое замыкание на массу
18449 P2017 Датчик положения заслонок впускных каналов: короткое замыкание на плюс
18451 P2019 Датчик положения заслонок впускных каналов 2: сбой в электрической цепи
18452 P2020 Датчик положения заслонок впускных каналов 2: недостоверный сигнал
18453 P2021 Датчик положения заслонок впускных каналов 2: короткое замыкание на массу
18454 P2022 Датчик положения заслонок впускных каналов 2: короткое замыкание на плюс
18463 P2031 Датчик 2 температуры ОГ: сбой в электрической цепи
18464 P2032 Датчик 2 температуры ОГ: короткое замыкание на массу
18465 P2033 Датчик 2 температуры ОГ: короткое замыкание на плюс
18466 P2034 Датчик температуры ОГ 2 для 2 ряда цилиндров: сбой в электрической цепи
18467 P2035 Датчик температуры ОГ 2 для 2 ряда цилиндров: короткое замыкание на массу
18468 P2036 Датчик температуры ОГ 2 для 2 ряда цилиндров: короткое замыкание на плюс
18502 P2070 Впускной коллектор с изменяемой геометрией: заслонка не закрывается
18503 P2071 Впускной коллектор с изменяемой геометрией: заслонка не открывается
18507 P2075 Датчик положения заслонки изменения геометрии впускного коллектора: сбой в электрической цепи
18508 P2076 Датчик положения заслонки изменения геометрии впускного коллектора: недостоверный сигнал
18509 P2077 Датчик положения заслонки изменения геометрии впускного коллектора: короткое замыкание на массу
18510 P2078 Датчик положения заслонки изменения геометрии впускного коллектора: короткое замыкание на плюс
18511 P2079 Датчик положения заслонки изменения геометрии впускного коллектора: обрыв цепи
18512 P2080 Датчик температуры ОГ 1-G235: недостоверный сигнал
18514 P2082 Датчик температуры ОГ 1 для 2 ряда цилиндров-G236: недостоверный сигнал
18516 P2084 Датчик температуры ОГ 2: недостоверный сигнал
18518 P2086 Датчик температуры ОГ 2 для 2 ряда цилиндров-G236: недостоверный сигнал
18520 P2088 Регулятор фаз газораспределения 1 ряда цилиндров: короткое замыкание на массу
18521 P2089 Регулятор фаз газораспределения 1 ряда цилиндров: короткое замыкание на плюс
18522 P2090 Регулятор фаз газораспределения 1 ряда цилиндров, выпуск: короткое замыкание на массу
18523 P2091 Регулятор фаз газораспределения 1 ряда цилиндров, выпуск: короткое замыкание на плюс
18524 P2092 Регулятор фаз газораспределения 2 ряда цилиндров: короткое замыкание на массу
18525 P2093 Регулятор фаз газораспределения 2 ряда цилиндров: короткое замыкание на плюс
18526 P2094 Регулятор фаз газораспределения 2 ряда цилиндров, выпуск: короткое замыкание на массу
18527 P2095 Регулятор фаз газораспределения 2 ряда цилиндров, выпуск: короткое замыкание на плюс
18528 P2096 Ряд 1, лямбда-коррекция после катализатора: превышен предел регулирования обеднения смеси
18529 P2097 Ряд 1, лямбда-коррекция после катализатора: превышен предел регулирования обогащения смеси
18530 P2098 Ряд 2, лямбда-коррекция после катализатора: превышен предел регулирования обеднения смеси
18531 P2099 Ряд 2, лямбда-коррекция после катализатора: превышен предел регулирования обогащения смеси
18554 P2122 Датчик положения педали акселератора-G79: слишком низкий уровень сигнала
18555 P2123 Датчик положения педали акселератора-G79: слишком высокий уровень сигнала
18559 P2127 Датчик 2 положения педали акселератора-G185: слишком низкий уровень сигнала
18560 P2128 Датчик 2 положения педали акселератора-G185: слишком высокий уровень сигнала
18570 P2138 Датчики 1/2 положения педали акселератора-G79+G185: недостоверный сигнал
18578 P2146 Питание форсунки(-ок) А: обрыв цепи
18579 P2147 Питание форсунки(-ок) А: короткое замыкание на массу
18580 P2148 Питание форсунки(-ок) А: короткое замыкание на плюс
18581 P2149 Питание форсунки(-ок) В: обрыв цепи
18582 P2150 Питание форсунки(-ок) В: короткое замыкание на массу
18583 P2151 Питание форсунки(-ок) В: короткое замыкание на плюс
18609 P2177 Ряд 1, система определения параметров топливо-возд. смеси: слишком бедная смесь в системе на оборотах выше холостого хода
18610 P2178 Ряд 1, система определения параметров топливо-возд. смеси: слишком богатая смесь в системе на оборотах выше холостого хода
18611 P2179 Ряд 2, система определения параметров топливо-возд. смеси: слишком бедная смесь в системе на оборотах выше холостого хода
18612 P2180 Ряд 2 система определения параметров топливо-возд. смеси: слишком богатая смесь в системе на оборотах выше холостого хода
18613 P2181 Неисправность системы охлаждения
18615 P2183 Датчик температуры охлаждающей жидкости на выходе радиатора-G83: недостоверный сигнал
18616 P2184 Датчик температуры охлаждающей жидкости на выходе радиатора-G83, слишком низкий уровень сигнала
18617 P2185 Датчик температуры охлаждающей жидкости на выходе радиатора-G83: слишком высокий уровень сигнала
18619 P2187 Ряд 1, система определения параметров топливо-возд. смеси: слишком бедная смесь в системе на оборотах холостого хода
18620 P2188 Ряд 1, система определения параметров топливо-возд. смеси: слишком богатая смесь в системе на оборотах холостого хода
18621 P2189 Ряд 2, система определения параметров топливо-возд. смеси: слишком бедная смесь в системе на оборотах холостого хода
18622 P2190 Ряд 2, система определения параметров топливо-возд. смеси: слишком богатая смесь в системе на оборотах холостого хода
18623 P2191 Ряд 1, система определения параметров топливо-возд. смеси: слишком бедная смесь в системе при полной нагрузке
18624 P2192 Ряд 1, система определения параметров топливо-возд. смеси: слишком богатая смесь в системе при полной нагрузке
18625 P2193 Ряд 2, система определения параметров топливо-возд. смеси: слишком бедная смесь в системе при полной нагрузке
18626 P2194 Ряд 2, система определения параметров топливо-возд. смеси: слишком богатая смесь в системе при полной нагрузке
18627 P2195 Лямбда-зонд 1-ряд 1: сигнал слишком бедной смеси
18628 P2196 Лямбда-зонд 1-ряд 1: сигнал слишком богатой смеси
18629 P2197 Лямбда-зонд 1-ряд 2: сигнал слишком бедной смеси
18630 P2198 Лямбда-зонд 1-ряд 2: сигнал слишком богатой смеси
18631 P2199 Датчики температуры воздуха на впуске 12: отклонение
18663 P2231 Лямбда-зонд 1-ряд 1: короткое замыкание на электрическую цепь подогрева
18664 P2232 Лямбда-зонд 2-ряд 1: короткое замыкание на электрическую цепь подогрева
18665 P2233 Лямбда-зонд 3-ряд 1: короткое замыкание на электрическую цепь подогрева
18666 P2234 Лямбда-зонд 1-ряд 2: короткое замыкание на электрическую цепь подогрева
18667 P2235 Лямбда-зонд 2-ряд 2: короткое замыкание на электрическую цепь подогрева
18668 P2236 Лямбда-зонд 3-ряд 2: короткое замыкание на электрическую цепь подогрева
18669 P2237 Лямбда-зонд 1-ряд 1, ток сигнала: обрыв цепи
18670 P2238 Лямбда-зонд 1-ряд 1, ток сигнала: короткое замыкание на массу
18671 P2239 Лямбда-зонд 1-ряд 1, ток сигнала: короткое замыкание на плюс
18672 P2240 Лямбда-зонд 1-ряд 2, ток сигнала: обрыв цепи
18673 P2241 Лямбда-зонд 1-ряд 2, ток сигнала: короткое замыкание на массу
18674 P2242 Лямбда-зонд 1-ряд 2, ток сигнала: короткое замыкание на плюс
18675 P2243 Лямбда-зонд 1-ряд 1, опорное напряжение: обрыв цепи
18676 P2244 Лямбда-зонд 1-ряд 1, опорное напряжение: недостоверный сигнал
18677 P2245 Лямбда-зонд 1-ряд 1, опорное напряжение: короткое замыкание на массу
18678 P2246 Лямбда-зонд 1-ряд 1, опорное напряжение: короткое замыкание на плюс
18679 P2247 Лямбда-зонд 1-ряд 2, опорное напряжение: обрыв цепи
18680 P2248 Лямбда-зонд 1-ряд 2, опорное напряжение: недостоверный сигнал
18681 P2249 Лямбда-зонд 1-ряд 2, опорное напряжение: короткое замыкание на массу
18682 P2250 Лямбда-зонд 1-ряд 2, опорное напряжение: короткое замыкание на плюс
18683 P2251 Лямбда-зонд 1-ряд 1, кабель массы: обрыв цепи
18684 P2252 Лямбда-зонд 1-ряд 1, кабель массы: короткое замыкание на массу
18685 P2253 Лямбда-зонд 1-ряд 1, кабель массы: короткое замыкание на плюс
18686 P2254 Лямбда-зонд 1-ряд 2, кабель массы: обрыв цепи
18687 P2255 Лямбда-зонд 1-ряд 2, кабель массы: короткое замыкание на массу
18688 P2256 Лямбда-зонд 1-ряд 2, кабель массы: короткое замыкание на плюс
18689 P2257 Реле насоса вторичного воздуха-J299: короткое замыкание на массу
18690 P2258 Реле насоса вторичного воздуха-J299: короткое замыкание на плюс
18693 P2261 Перепускной клапан турбонагнетателя-N249, механическое повреждение
18702 P2270 Лямбда-зонд 2- Ряд 1: сигнал слишком бедной смеси
18703 P2271 Лямбда-зонд 2- Ряд 1: сигнал слишком богатой смеси
18704 P2272 Лямбда-зонд 2- Ряд 2: сигнал слишком бедной смеси
18705 P2273 Лямбда-зонд 2- Ряд 2: сигнал слишком богатой смеси
18706 P2274 Лямбда-зонд 3- Ряд 1: сигнал слишком бедной смеси
18707 P2275 Лямбда-зонд 3- Ряд 1: сигнал слишком богатой смеси
18708 P2276 Лямбда-зонд 3- Ряд 2: сигнал слишком бедной смеси
18709 P2277 Лямбда-зонд 3- Ряд 2: сигнал слишком богатой смеси
18711 P2279 Негерметичность в системе впуска
18725 P2293 Регулятор давления топлива: механическое повреждение
18726 P2294 Регулятор давления топлива: обрыв цепи
18727 P2295 Регулятор давления топлива: короткое замыкание на массу
18728 P2296 Регулятор давления топлива: короткое замыкание на плюс
18729 P2297 Ряд 1, зонд 1, сигнал лямбда-зонда, напряжение в режиме принудительного ХХ: превышен предел регулирования
18730 P2298 Ряд 2, зонд 1, сигнал лямбда-зонда, напряжение в режиме принудительного ХХ: превышен предел регулирования
18732 P2300 Подача сигнала управления на катушку зажигания 1: короткое замыкание на массу
18733 P2301 Подача сигнала управления на катушку зажигания 1: короткое замыкание на плюс
18734 P2302 Вторичный контур катушки зажигания 1: сбой в работе
18735 P2303 Подача сигнала управления на катушку зажигания 2: короткое замыкание на массу
18736 P2304 Подача сигнала управления на катушку зажигания 2: короткое замыкание на плюс
18737 P2305 Вторичный контур катушки зажигания 2: сбой в работе
18738 P2306 Подача сигнала управления на катушку зажигания 3: короткое замыкание на массу
18739 P2307 Подача сигнала управления на катушку зажигания 3: короткое замыкание на плюс
18740 P2308 Вторичный контур катушки зажигания 3: сбой в работе
18741 P2309 Подача сигнала управления на катушку зажигания 4: короткое замыкание на массу
18742 P2310 Подача сигнала управления на катушку зажигания 4: короткое замыкание на плюс
18743 P2311 Вторичный контур катушки зажигания 4: сбой в работе
18744 P2312 Подача сигнала управления на катушку зажигания 5: короткое замыкание на массу
18745 P2313 Подача сигнала управления на катушку зажигания 5: короткое замыкание на плюс
18746 P2314 Вторичный контур катушки зажигания 5: сбой в работе
18747 P2315 Подача сигнала управления на катушку зажигания 6: короткое замыкание на массу
18748 P2316 Подача сигнала управления на катушку зажигания 6: короткое замыкание на плюс
18749 P2317 Вторичный контур катушки зажигания 6: сбой в работе
18750 P2318 Подача сигнала управления на катушку зажигания 7: короткое замыкание на массу
18751 P2319 Подача сигнала управления на катушку зажигания 7: короткое замыкание на плюс
18752 P2320 Вторичный контур катушки зажигания 7: сбой в работе
18753 P2321 Подача сигнала управления на катушку зажигания 8: короткое замыкание на массу
18754 P2322 Подача сигнала управления на катушку зажигания 8: короткое замыкание на плюс
18755 P2323 Вторичный контур катушки зажигания 8: сбой в работе
18756 P2324 Подача сигнала управления на катушку зажигания 9: короткое замыкание на массу
18757 P2325 Подача сигнала управления на катушку зажигания 9: короткое замыкание на плюс
18758 P2326 Вторичный контур катушки зажигания 9: сбой в работе
18759 P2327 Подача сигнала управления на катушку зажигания 10: короткое замыкание на массу
18760 P2328 Подача сигнала управления на катушку зажигания 10: короткое замыкание на плюс
18761 P2329 Вторичный контур катушки зажигания 10: сбой в работе
18762 P2330 Подача сигнала управления на катушку зажигания 11: короткое замыкание на массу
18763 P2331 Подача сигнала управления на катушку зажигания 11: короткое замыкание на плюс
18764 P2332 Вторичный контур катушки зажигания 11: сбой в работе
18765 P2333 Подача сигнала управления на катушку зажигания 12: короткое замыкание на массу
18766 P2334 Подача сигнала управления на катушку зажигания 12: короткое замыкание на плюс
18767 P2335 Вторичный контур катушки зажигания 12: сбой в работе
18768 P2336 Регулирование по детонации цил. 1: достигнут предел регулирования
18769 P2337 Регулирование по детонации цил. 2: достигнут предел регулирования
18770 P2338 Регулирование по детонации цил. 3: достигнут предел регулирования
18771 P2339 Регулирование по детонации цил. 4: достигнут предел регулирования
18772 P2340 Регулирование по детонации цил. 5: достигнут предел регулирования
18773 P2341 Регулирование по детонации цил. 6: достигнут предел регулирования
18774 P2342 Регулирование по детонации цил. 7: достигнут предел регулирования
18775 P2343 Регулирование по детонации цил. 8: достигнут предел регулирования
18776 P2344 Регулирование по детонации цил. 9: достигнут предел регулирования
18777 P2345 Регулирование по детонации цил. 10: достигнут предел регулирования
18778 P2346 Регулирование по детонации цил. 11: достигнут предел регулирования
18779 P2347 Регулирование по детонации цил. 12: достигнут предел регулирования
18832 P2400 Система вентиляции топливного бака, подача сигнала управления на насос диагностики утечек топлива: сбой в электрической цепи/обрыв цепи
18833 P2401 Система вентиляции топливного бака, подача сигнала управления на насос диагностики утечек топлива: короткое замыкание на массу
18834 P2402 Система вентиляции топливного бака, подача сигнала управления на насос диагностики утечек топлива: короткое замыкание на плюс
18835 P2403 Система вентиляции топливного бака, датчик насоса диагностики утечек топлива: сбой в электрической цепи/обрыв цепи
18836 P2404 Система вентиляции топливного бака, датчик насоса диагностики утечек топлива: недостоверный сигнал
18845 P2413 Ошибка в системе рециркуляции ОГ
18846 P2414 Ряд 1-зонд 1: слишком низкое напряжение/негерметичность
18847 P2415 Ряд 2-зонд 1: слишком низкое напряжение/негерметичность
18848 P2416 Ряд 1: перепутаны лямбда-зонды до и после основного катализатора
18849 P2417 Ряд 2: перепутаны лямбда-зонды до и после основного катализатора
18853 P2420 Система вентиляции топливного бака, электромагнитный клапан 2 абсорбера с активированным углем-N115: постоянно открыт
18854 P2421 Система вентиляции топливного бака, электромагнитный клапан 2 абсорбера с активированным углем-N115: постоянно закрыт
18857 P2425 Клапан охлаждения системы рециркуляции ОГ: обрыв цепи
18858 P2426 Клапан охлаждения системы рециркуляции ОГ: короткое замыкание на массу
18859 P2427 Клапан охлаждения системы рециркуляции ОГ: короткое замыкание на плюс
18884 P2452 Сажевый фильтр, датчик разности давлений: сбой в электрической цепи
18885 P2453 Сажевый фильтр, датчик разности давлений: недостоверный сигнал
18886 P2454 Сажевый фильтр, датчик разности давлений: короткое замыкание на массу
18887 P2455 Сажевый фильтр, датчик разности давлений: короткое замыкание на плюс
18965 P2533 Электрическая цепь замка зажигания: короткое замыкание на массу/обрыв цепи
18967 P2535 Электрическая цепь замка зажигания: короткое замыкание на плюс
18971 P2539 Датчик давления топлива, низкое давление-G410: обрыв цепи
18972 P2540 Датчик давления топлива, низкое давление-G410: недостоверный сигнал
18973 P2541 Датчик давления топлива, низкое давление-G410: короткое замыкание на массу
18974 P2542 Датчик давления топлива, низкое давление-G410: короткое замыкание на плюс
18975 P2543 Датчик давления топлива, низкое давление-G410: пульсация сигнала
18995 P2563 Датчик положения регулятора давления наддува: недостоверный сигнал
18996 P2564 Датчик положения регулятора давления наддува: слишком низкий уровень сигнала
18997 P2565 Датчик положения регулятора давления наддува: слишком высокий уровень сигнала
18998 P2566 Датчик положения регулятора давления наддува: нет сигнала
19032 P2600 Насос системы охлаждения: обрыв цепи
19033 P2601 Насос системы охлаждения: недостоверный сигнал
19034 P2602 Насос системы охлаждения: короткое замыкание на массу
19035 P2603 Насос системы охлаждения: короткое замыкание на плюс
19058 P2626 Линейный лямбда-зонд, Ряд 1/Согласующий провод Сигнал датчика: обрыв цепи
19061 P2629 Линейный лямбда-зонд, Ряд 2/Согласующий провод Сигнал датчика: обрыв цепи
19064 P2632 Реле электрического топливного насоса 2-J49: обрыв цепи
19065 P2633 Реле электрического топливного насоса 2-J49: короткое замыкание на массу
19066 P2634 Реле электрического топливного насоса 2-J49: короткое замыкание на плюс
19069 P2637 Сигнал крутящего момента двигателя A
19140 P2708 Переключающий клапан 6=>электромагнитный клапан 6-N93: короткое замыкание на плюс
19143 P2711 Недостоверные данные процесса переключения передач
19146 P2714 Регулятор давления 4: обрыв цепи/короткое замыкание на массу
19147 P2715 Регулятор давления 4: короткое замыкание на плюс
19148 P2716 Регулятор давления 4: сбой в электрической цепи
19149 P2717 Регулятор давления 4: обрыв цепи
19155 P2723 Регулятор давления 5: обрыв цепи/короткое замыкание на массу
19156 P2724 Регулятор давления 5: короткое замыкание на плюс
19157 P2725 Регулятор давления 5: сбой в электрической цепи
19158 P2726 Регулятор давления 5: обрыв цепи
19164 P2732 Регулятор давления 6: обрыв цепи/короткое замыкание на массу
19165 P2733 Регулятор давления 6: короткое замыкание на плюс
19166 P2734 Регулятор давления 6: сбой в электрической цепи
19167 P2735 Регулятор давления 6: обрыв цепи
19219 P2787 Перегрев муфты
19221 P2789 Адаптация муфты на пределе
19456 P3000 Контрольная лампа прогрева камеры сгорания свечами накаливания-K29: сообщение об ошибке от комбинации приборов
19457 P3001 Диапазон регулирования рабочей частоты вращения
19458 P3002 Выключатель режима интенсивного разгона (Kick-Down)-F86: недостоверный сигнал
19459 P3003 Реле малой мощности нагрева-J359: короткое замыкание на плюс
19460 P3004 Реле малой мощности нагрева-J359: обрыв цепи/короткое замыкание на массу
19461 P3005 Реле большой мощности нагрева-J359: короткое замыкание на плюс
19462 P3006 Реле большой мощности нагрева-J360: обрыв цепи/короткое замыкание на массу
19463 P3007 Датчик положения распредвала-G40: нет сигнала
19464 P3008 Датчик положения распредвала-G40: сигнал за пределами допуска
19465 P3009 Реле насоса системы охлаждения топлива-J445: короткое замыкание на плюс
19466 P3010 Реле насоса системы охлаждения топлива-J445: обрыв цепи/короткое замыкание на массу
19467 P3011 Реле электрического топливного насоса 2-J49: короткое замыкание на плюс
19468 P3012 Реле электрического топливного насоса 2-J49: обрыв цепи/короткое замыкание на массу
19469 P3013 Электромагнитный клапан 2 ограничения давления наддува-N274: короткое замыкание на плюс
19470 P3014 Клапан 2 ограничения давления наддува-N274: обрыв цепи/короткое замыкание на массу
19471 P3015 Клапан обходного канала подачи топлива-N312: короткое замыкание на плюс
19472 P3016 Клапан обходного канала подачи топлива-N312: обрыв цепи/короткое замыкание на массу
19473 P3017 Клапан заслонки ОГ 1-N321: короткое замыкание на плюс
19474 P3018 Клапан заслонки ОГ 1-N321: короткое замыкание на массу
19475 P3019 Клапан заслонки ОГ 1-N321: обрыв цепи
19476 P3020 Клапан заслонки ОГ 1-N321: сбой в электрической цепи
19477 P3021 Клапан заслонки ОГ 2-N322: короткое замыкание на плюс
19478 P3022 Клапан заслонки ОГ 2-N322: короткое замыкание на массу
19479 P3023 Клапан заслонки ОГ 2-N322: обрыв цепи
19480 P3024 Клапан заслонки ОГ 2-N322: сбой в электрической цепи
19481 P3025 Датчик угла поворота 1 привода дроссельной заслонки 2-G297: недостоверный сигнал
19482 P3026 Датчик угла поворота 1 привода дроссельной заслонки 2-G297: слишком низкий уровень сигнала
19483 P3027 Датчик угла поворота 1 привода дроссельной заслонки 2-G297: слишком высокий уровень сигнала
19484 P3028 Датчик угла поворота 2 привода дроссельной заслонки 2-G298: недостоверный сигнал
19485 P3029 Датчик угла поворота 2 привода дроссельной заслонки 2-G298: слишком низкий уровень сигнала
19486 P3030 Датчик угла поворота 2 привода дроссельной заслонки 2-G298: слишком высокий уровень сигнала
19487 P3031 Электропривод дроссельной заслонки 2-G296: сбой в электрической цепи
19488 P3032 Блок дроссельной заслонки 2-J544: ошибка базовой установки
19489 P3033 Датчик температуры воздуха на впуске 2-G299: слишком низкий уровень сигнала
19490 P3034 Датчик температуры воздуха на впуске 2-G299, слишком высокий уровень сигнала
19491 P3035 Блок дроссельной заслонки 2-J544: механическое повреждение
19492 P3036 Блок дроссельной заслонки 2-J544: недостаточное напряжение при выполнении базовой установки
19493 P3037 Блок дроссельной заслонки 2-J544: адаптация не начата
19494 P3038 Блок дроссельной заслонки 2-J544: не достигается нижний предел
19495 P3039 Запрос коробки передач, уменьшение момента: недостоверное значение
19496 P3040 Передаточное отношение коробки передач: недостоверное значение
19497 P3041 Шина данных-привод: недостоверный сигнал температуры двигателя от комбинации приборов
19498 P3042 Регулятор отопителя: недостоверный сигнал
19499 P3043 Топливный насос: механическое повреждение
19500 P3044 Топливный насос: короткое замыкание
19501 P3045 Неисправна электронная система топливного насоса
19502 P3046 Реле стартера 1: сбой в электрической цепи (реле заедает/не переключается)
19503 P3047 Подача сигнала управления на реле стартера 2: короткое замыкание на плюс
19504 P3048 Подача сигнала управления на реле стартера 2: короткое замыкание на массу
19505 P3049 Подача сигнала управления на реле стартера 2: обрыв цепи
19506 P3050 Реле стартера 2: сбой в электрической цепи (реле заедает/не переключается)
19507 P3051 Включение стартера, отзыв кл. 50: недостоверный сигнал
19508 P3052 Включение стартера, отзыв кл. 50: короткое замыкание на плюс
19509 P3053 Включение стартера, отзыв кл. 50: короткое замыкание на массу/обрыв цепи
19510 P3054 Стартер не проворачивается: механическое блокирование или сбой в электрической цепи
19511 P3055 Датчик 2 давления ОГ: обрыв цепи
19512 P3056 Датчик 2 давления ОГ: короткое замыкание на массу
19513 P3057 Датчик 2 давления ОГ: короткое замыкание на плюс
19514 P3058 Система рециркуляции ОГ 2: слишком низкая пропускная способность
19515 P3059 Система рециркуляции ОГ 2: слишком высокая пропускная способность
19516 P3060 Клапан обходного канала охлаждения, системы рециркуляции ОГ-N386: сбой в электрической цепи
19517 P3061 Клапан 2 обходного канала охлаждения, системы рециркуляции ОГ-N387: сбой в электрической цепи
19518 P3062 Регулятор 2 давления наддува: слишком большое давление наддува
19519 P3063 Регулятор 2 давления наддува: слишком малое давление наддува
19520 P3064 Клапан 3 ограничения давления наддува-N388: сбой в электрической цепи
19521 P3065 Клапан 3 ограничения давления наддува-N388: короткое замыкание на массу
19522 P3066 Клапан 3 ограничения давления наддува-N388: короткое замыкание на плюс
19523 P3067 Клапан 4 ограничения давления наддува-N389: сбой в электрической цепи
19524 P3068 Клапан 4 ограничения давления наддува-N389: короткое замыкание на массу
19525 P3069 Клапан 4 ограничения давления наддува-N389: короткое замыкание на плюс
19526 P3070 Неисправность насоса подачи присадки для работы сажевого фильтра-V135
19527 P3071 Емкость с присадкой для работы сажевого фильтра: пусто
19528 P3072 Реле подачи напряжения: сбой в электрической цепи
19529 P3073 Топливный насос: сбой в электрической цепи
19530 P3074 Топливный насос 2: сбой в электрической цепи
19531 P3075 Коррекция турбонагнетателей 1/2: не достигнуты пределы адаптации
19532 P3076 Блок управления двигателя: ошибка кодирования
19533 P3077 Электронная система топливного насоса, электропитание: сбой в электрической цепи
19534 P3078 Блок дроссельной заслонки: недостаточная подача воздуха на холостом ходу
19535 P3079 Реле топливного насоса холодного пуска-J748: короткое замыкание на плюс
19536 P3080 Реле топливного насоса холодного пуска-J748: короткое замыкание на массу/обрыв цепи
19537 P3081 Слишком низкая температура двигателя
19538 P3082 Датчик положения муфты/сцепления-G476: недостоверный сигнал
19539 P3083 Датчик бачка присадки для сажевого фильтра-G504: сбой в электрической цепи
19540 P3084 Перепускной клапан турбонагнетателя, ряд 2: механическое повреждение
19541 P3085 Подача сигнала управления на заслонки 2 впускных каналов: сбой в электрической цепи
19542 P3086 Заслонки 2 впускных каналов: не выполнены базовые установки
19543 P3087 Реле питания компонентов двигателя: сбой в электрической цепи
19544 P3088 Реле стартера: сбой в электрической цепи
19545 P3089 Электроника топливного насоса, сигнальный провод: сбой в электрической цепи
19546 P3090 Не опознан сигнал автономного отопителя
19547 P3091 Опознан длительный сигнал автономного отопителя
19548 P3092 Неисправен блок управления
19549 P3093 Неисправен блок управления
19550 P3094 Неисправен блок управления
19551 P3095 Неисправен блок управления
19552 P3096 Неисправен блок управления
19553 P3097 Неисправен блок управления
19554 P3098 Неисправен блок управления
19555 P3099 Неисправен блок управления
19556 P3100 Электродвигатель привода заслонки впускного коллектора-V157: короткое замыкание на плюс
19557 P3101 Электродвигатель привода заслонки впускного коллектора-V157: обрыв цепи/короткое замыкание на массу
19558 P3102 Электродвигатель привода заслонки впускного коллектора-V157: нет сигнала
19559 P3103 Электродвигатель привода заслонки впускного коллектора -V157: неисправен
19560 P3104 Переключающий клапан заслонки впускного коллектора-N239: короткое замыкание на плюс
19561 P3105 Переключающий клапан заслонки впускного коллектора-N239: обрыв цепи/короткое замыкание на массу
19562 P3106 Клапан насос-форсунки цилиндра 7-N303: недостоверный сигнал
19563 P3107 Клапан насос-форсунки цилиндра 7-N303: выход из диапазона регулирования (больше верхнего предела)
19564 P3108 Клапан насос-форсунки цилиндра 7-N303: выход из диапазона регулирования (меньше нижнего предела)
19565 P3109 Клапан насос-форсунки цилиндра 7-N303: сбой в электрической цепи
19566 P3110 Клапан насос-форсунки цилиндра 8-N304: недостоверный сигнал
19567 P3111 Клапан насос-форсунки цилиндра 8-N304: выход из диапазона регулирования (больше верхнего предела)
19568 P3112 Клапан насос-форсунки цилиндра 8-N304: выход из диапазона регулирования (меньше нижнего предела)
19569 P3113 Клапан насос-форсунки цилиндра 8-N304: сбой в электрической цепи
19570 P3114 Клапан насос-форсунки цилиндра 9-N305: недостоверный сигнал
19571 P3115 Клапан насос-форсунки цилиндра 9-N305: выход из диапазона регулирования (больше верхнего предела)
19572 P3116 Клапан насос-форсунки цилиндра 9-N305: выход из диапазона регулирования (меньше нижнего предела)
19573 P3117 Клапан насос-форсунки цилиндра 9-N305: сбой в электрической цепи
19574 P3118 Клапан насос-форсунки цилиндра 10-N306: недостоверный сигнал
19575 P3119 Клапан насос-форсунки цилиндра 10-N306: выход из диапазона регулирования (больше верхнего предела)
19576 P3120 Клапан насос-форсунки цилиндра 10-N306: выход из диапазона регулирования (меньше нижнего предела)
19577 P3121 Клапан насос-форсунки цилиндра 10-N306: сбой в электрической цепи
19578 P3122 Клапан насос-форсунки цилиндра 11-N307: недостоверный сигнал
19579 P3123 Клапан насос-форсунки цилиндра 11-N307: выход из диапазона регулирования (больше верхнего предела)
19580 P3124 Клапан насос-форсунки цилиндра 11-N307: выход из диапазона регулирования (меньше нижнего предела)
19581 P3125 Клапан насос-форсунки цилиндра 11-N307: сбой в электрической цепи
19582 P3126 Клапан насос-форсунки цилиндра 12-N308: недостоверный сигнал
19583 P3127 Клапан насос-форсунки цилиндра 12-N308: выход из диапазона регулирования (больше верхнего предела)
19584 P3128 Клапан насос-форсунки цилиндра 12-N308: выход из диапазона регулирования (меньше нижнего предела)
19585 P3129 Клапан насос-форсунки цилиндра 12-N308: сбой в электрической цепи
19586 P3130 Система рециркуляции ОГ: выход из диапазона регулирования (больше верхнего предела)
19587 P3131 Система рециркуляции ОГ: выход из диапазона регулирования (меньше нижнего предела)
19588 P3132 Блок управления свечей накаливания 2, электрическая цепь свечей накаливания: сбой в электрической цепи
19589 P3133 Блок управления свечей накаливания 2-J609: недостоверный сигнал
19590 P3134 Заслонки впускных каналов, не достигнут верхний предел
19591 P3135 Заслонки впускных каналов: не достигнут нижний предел
19592 P3136 Заслонки впускных каналов: не достигнуто номинальное значение
19593 P3137 Заслонки впускных каналов: не выполнены базовые установки
19594 P3138 Заслонки впускных каналов: диапазон регулирования
19595 P3139 Заслонки впускных каналов: сигнал за пределами допуска
19596 P3140 Клапан для запуска при пустом баке-Nххх: обрыв цепи/короткое замыкание на массу
19597 P3141 Клапан для запуска при пустом баке-Nххх: короткое замыкание на плюс
19598 P3142 Ряд 2, зонд 1, сигнал лямбда-зонда: недостоверно бедная смесь
19599 P3143 Ряд 2, зонд 1, сигнал лямбда-зонда: недостоверно богатая смесь
19600 P3144 Ряд 3, зонд 1, сигнал лямбда-зонда: недостоверно бедная смесь
19601 P3145 Ряд 3, зонд 1, сигнал лямбда-зонда: недостоверно богатая смесь
19602 P3146 Ряд 4, зонд 1, сигнал лямбда-зонда: недостоверно бедная смесь
19603 P3147 Ряд 4, зонд 1, сигнал лямбда-зонда: недостоверно богатая смесь
19604 P3148 Ряд 3, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут верхний предел регулирования
19605 P3149 Ряд 3, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут нижний предел регулирования
19606 P3150 Ряд 4, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут верхний предел регулирования
19607 P3151 Ряд 4, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут нижний предел регулирования
19608 P3152 Ряд 3, зонд 1: недостоверное значение внутреннего сопротивления
19609 P3153 Ряд 4, зонд 1: недостоверное значение внутреннего сопротивления
19610 P3154 Ряд 2, зонд 1: слишком низкое напряжение/негерметичность
19611 P3155 Ряд 3-зонд 1: слишком низкое напряжение/негерметичность
19612 P3156 Ряд 4-зонд 1: слишком низкое напряжение/негерметичность
19613 P3157 Ряд 1-зонд 1, сигнал лямбда-зонда: слишком малое напряжение в режиме принудительного ХХ
19614 P3158 Ряд 2-зонд 1, сигнал лямбда-зонда: слишком малое напряжение в режиме принудительного ХХ
19615 P3159 Ряд 3-зонд 1, сигнал лямбда-зонда: слишком малое напряжение в режиме принудительного ХХ
19616 P3160 Ряд 4-зонд 1, сигнал лямбда-зонда: слишком малое напряжение в режиме принудительного ХХ
19617 P3161 Линейный лямбда-зонд, Ряд 1/Согласующий провод Сигнал датчика: обрыв цепи
19618 P3162 Линейный лямбда-зонд, Ряд 2/Согласующий провод Сигнал датчика: обрыв цепи
19619 P3163 Линейный лямбда-зонд, Ряд 3/Согласующий провод Сигнал датчика: обрыв цепи
19620 P3164 Линейный лямбда-зонд, Ряд 4/Согласующий провод Сигнал датчика: обрыв цепи
19621 P3165 Ряд 3, лямбда-коррекция после катализатора: превышен предел регулирования обеднения смеси
19622 P3166 Ряд 3, лямбда-коррекция после катализатора: превышен предел регулирования обогащения смеси
19623 P3167 Ряд 4, лямбда-коррекция после катализатора: превышен предел регулирования обеднения смеси
19624 P3168 Ряд 4, лямбда-коррекция после катализатора: превышен предел регулирования обогащения смеси
19625 P3169 Ряд 3, основной катализатор: снижение эффективности
19626 P3170 Ряд 4, основной катализатор: снижение эффективности
19627 P3171 Ряд 1, адаптация смеси в диапазоне 3, переобеднение смеси
19628 P3172 Ряд 1, адаптация смеси в диапазоне 3, переобогащение смеси
19629 P3173 Ряд 2, адаптация смеси в диапазоне 3, переобеднение смеси
19630 P3174 Ряд 2, адаптация смеси в диапазоне 3, переобогащение смеси
19631 P3175 Ряд 3, адаптация смеси в диапазоне 3, переобеднение смеси
19632 P3176 Ряд 3, адаптация смеси в диапазоне 3, переобогащение смеси
19633 P3177 Ряд 4, адаптация смеси в диапазоне 3, переобеднение смеси
19634 P3178 Ряд 4, адаптация смеси в диапазоне 3, переобогащение смеси
19635 P3179 Форсунка цил. 13-N390: короткое замыкание на массу
19636 P3180 Форсунка цил. 13-N390: короткое замыкание на плюс
19637 P3181 Форсунка цил. 13-N390: обрыв цепи
19638 P3182 Форсунка цил. 14-N391: короткое замыкание на массу
19639 P3183 Форсунка цил. 14-N391: короткое замыкание на плюс
19640 P3184 Форсунка цил. 14-N391: обрыв цепи
19641 P3185 Форсунка цил. 15-N392: короткое замыкание на массу
19642 P3186 Форсунка цил. 15-N392: короткое замыкание на плюс
19643 P3187 Форсунка цил. 15-N392: обрыв цепи
19644 P3188 Форсунка цил. 16-N393: короткое замыкание на массу
19645 P3189 Форсунка цил. 16-N393: короткое замыкание на плюс
19646 P3190 Форсунка цил. 16-N393: обрыв цепи
19647 P3191 Заслонки впускных каналов: нарушены базовые установки механич. упора в положении ОТКР.
19648 P3192 Заслонки впускных каналов: нарушены базовые установки механич. упора в положении ЗАКР.
19649 P3193 Заслонки впускных каналов: упор в положении ОТКР. за пределами действ. диапазона
19650 P3194 Расходомер воздуха 3-G456: слишком низкий уровень сигнала
19651 P3195 Расходомер воздуха 3-G456: слишком высокий уровень сигнала
19652 P3196 Расходомер воздуха 4-G457: слишком низкий уровень сигнала
19653 P3197 Расходомер воздуха 4-G457: слишком высокий уровень сигнала
19654 P3198 Подача сигнала управления на заслонки впускных каналов: недостоверный сигнал
19655 P3199 Подача сигнала управления на заслонки 2 впускных каналов: недостоверный сигнал
19656 P3200 Ряд 3-зонд 1, электрическая цепь подогрева: короткое замыкание на массу
19657 P3201 Ряд 3-зонд 1, электрическая цепь подогрева: короткое замыкание на плюс
19658 P3202 Ряд 3-зонд 1, электрическая цепь подогрева: обрыв цепи
19659 P3203 Ряд 3-зонд 1, электрическая цепь подогрева: сбой в электрической цепи
19660 P3204 Ряд 3-зонд 1: внутреннее сопротивление слишком велико
19661 P3205 Ряд 3-зонд 1: слишком низкое напряжение
19662 P3206 Ряд 3-зонд 1: напряжение слишком велико
19663 P3207 Ряд 3-зонд 1, сбой в электрической цепи
19664 P3208 Ряд 3-зонд 1: нет активности
19665 P3209 Ряд 3-зонд 1: время реакции слишком велико
19666 P3210 Ряд 3-зонд 1, электрическая цепь подогрева: слишком малая мощность
19667 P3211 Ряд 1-зонд 1: обратная связь цепи подогрева
19668 P3212 Ряд 2-зонд 1: обратная связь цепи подогрева
19669 P3213 Ряд 3-зонд 1: обратная связь цепи подогрева
19670 P3214 Ряд 4-зонд 1: обратная связь цепи подогрева
19671 P3215 Ряд 3-зонд 2, электрическая цепь подогрева: короткое замыкание на массу
19672 P3216 Ряд 3-зонд 2, электрическая цепь подогрева: короткое замыкание на плюс
19673 P3217 Ряд 3-зонд 2, электрическая цепь подогрева: обрыв цепи
19674 P3218 Ряд 3-зонд 2, электрическая цепь подогрева: сбой в электрической цепи
19675 P3219 Ряд 3-зонд 2: внутреннее сопротивление слишком велико
19676 P3220 Ряд 3-зонд 2: слишком низкое напряжение
19677 P3221 Ряд 3-зонд 2: напряжение слишком велико
19678 P3222 Ряд 3-зонд 2: сбой в электрической цепи
19679 P3223 Ряд 3-зонд 2: нет активности
19680 P3224 Ряд 3-зонд 2: время реакции слишком велико
19681 P3225 Ряд 3, лямбда-коррекция после катализатора: достигнут предел регулирования
19682 P3226 Ряд 4, лямбда-коррекция после катализатора: достигнут предел регулирования
19683 P3227 Ряд 1, зонд 1, регулировка отдельных цилиндров: время реакции зонда слишком велико
19684 P3228 Ряд 1, зонд 1, сигнал лямбда-зонда: недостоверно бедная смесь
19685 P3229 Ряд 1, зонд 1, сигнал лямбда-зонда: недостоверно богатая смесь
19686 P3230 Ряд 4-зонд 1, электрическая цепь подогрева: короткое замыкание на массу
19687 P3231 Ряд 4-зонд 1, электрическая цепь подогрева: короткое замыкание на плюс
19688 P3232 Ряд 4-зонд 1, электрическая цепь подогрева: обрыв цепи
19689 P3233 Ряд 4-зонд 1, электрическая цепь подогрева: сбой в электрической цепи
19690 P3234 Ряд 4-зонд 1: внутреннее сопротивление слишком велико
19691 P3235 Ряд 4-зонд 1: слишком низкое напряжение
19692 P3236 Ряд 4-зонд 1: напряжение слишком велико
19693 P3237 Ряд 4-зонд 1, сбой в электрической цепи
19694 P3238 Ряд 4-зонд 1: нет активности
19695 P3239 Ряд 4-зонд 1: время реакции слишком велико
19696 P3240 Ряд 4-зонд 1, электрическая цепь подогрева: слишком малая мощность
19697 P3241 Заслонки впускных каналов: слишком высокая температура
19698 P3242 Заслонки впускных каналов 2: слишком высокая температура
19699 P3243 Подача сигнала управления на блок дроссельной заслонки: сбой в электрической цепи
19700 P3244 Подача сигнала управления на блок дроссельной заслонки 2: сбой в электрической цепи
19701 P3245 Ряд 4-зонд 2, электрическая цепь подогрева: короткое замыкание на массу
19702 P3246 Ряд 4-зонд 2, электрическая цепь подогрева: короткое замыкание на плюс
19703 P3247 Ряд 4-зонд 2, электрическая цепь подогрева: обрыв цепи
19704 P3248 Ряд 4-зонд 2, электрическая цепь подогрева: сбой в электрической цепи
19705 P3249 Ряд 4-зонд 2: внутреннее сопротивление слишком велико
19706 P3250 Ряд 4-зонд 2: слишком низкое напряжение
19707 P3251 Ряд 4-зонд 2: напряжение слишком велико
19708 P3252 Ряд 4-зонд 2: сбой в электрической цепи
19709 P3253 Ряд 4-зонд 2: нет активности
19710 P3254 Ряд 4-зонд 2: время реакции слишком велико
19711 P3255 Ряд 1, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут верхний предел регулирования
19712 P3256 Ряд 1, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут нижний предел регулирования
19713 P3257 Ряд 2, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут верхний предел регулирования
19714 P3258 Ряд 2, лямбда-зонд до катализатора, электрическая цепь подогрева: достигнут нижний предел регулирования
19715 P3259 Дополнительный топливный насос для пуска двигателя: сбой в работе
19716 P3260 Ряд 1/2: перепутаны лямбда-зонды до катализатора
19717 P3261 Ряд 3/4: перепутаны лямбда-зонды до катализатора
19718 P3262 Ряд 1/2: перепутаны лямбда-зонды после катализатора
19719 P3263 Ряд 3/4: перепутаны лямбда-зонды после катализатора
19720 P3264 Передний катализатор, ряд 3: недостаточная эффективность.
19721 P3265 Передний катализатор, ряд 4: недостаточная эффективность.
19722 P3266 Ряд 1, зонд 1: недостоверное значение внутреннего сопротивления
19723 P3267 Ряд 2, зонд 1: недостоверное значение внутреннего сопротивления
19724 P3268 Линейный лямбда-зонд, Ряд 2/ток сигнала: обрыв цепи
19725 P3269 Линейный лямбда-зонд, Ряд 2/ток сигнала: короткое замыкание на массу
19726 P3270 Линейный лямбда-зонд, Ряд 2/ток сигнала: короткое замыкание на плюс
19727 P3271 Линейный лямбда-зонд, Ряд 2/опорное напряжение: обрыв цепи
19728 P3272 Линейный лямбда-зонд, Ряд 2/опорное напряжение: короткое замыкание на массу
19729 P3273 Линейный лямбда-зонд, Ряд 2/опорное напряжение: короткое замыкание на плюс
19730 P3274 Линейный лямбда-зонд, Ряд 2/опорное напряжение: недостоверное значение
19731 P3275 Линейный лямбда-зонд, Ряд 2/общий кабель массы: обрыв цепи
19732 P3276 Линейный лямбда-зонд, Ряд 2/общий кабель массы: короткое замыкание на массу
19733 P3277 Линейный лямбда-зонд, Ряд 2/общий кабель массы: короткое замыкание на плюс
19734 P3278 Линейный лямбда-зонд, Ряд 3/ток сигнала: обрыв цепи
19735 P3279 Линейный лямбда-зонд, Ряд 3/ток сигнала: короткое замыкание на массу
19736 P3280 Линейный лямбда-зонд, Ряд 3/ток сигнала: короткое замыкание на плюс
19737 P3281 Линейный лямбда-зонд, Ряд 3/опорное напряжение: обрыв цепи
19738 P3282 Линейный лямбда-зонд, Ряд 3/опорное напряжение: короткое замыкание на массу
19739 P3283 Линейный лямбда-зонд, Ряд 3/опорное напряжение: короткое замыкание на плюс
19740 P3284 Линейный лямбда-зонд, Ряд 3/опорное напряжение: недостоверное значение
19741 P3285 Линейный лямбда-зонд, Ряд 3/общий кабель массы: обрыв цепи
19742 P3286 Линейный лямбда-зонд, Ряд 3/общий кабель массы: короткое замыкание на массу
19743 P3287 Линейный лямбда-зонд, Ряд 3/общий кабель массы: короткое замыкание на плюс
19744 P3288 Линейный лямбда-зонд, Ряд 4/ток сигнала: обрыв цепи
19745 P3289 Линейный лямбда-зонд, Ряд 4/ток сигнала: короткое замыкание на массу
19746 P3290 Линейный лямбда-зонд, Ряд 4/ток сигнала: короткое замыкание на плюс
19747 P3291 Линейный лямбда-зонд, Ряд 4/опорное напряжение: обрыв цепи
19748 P3292 Линейный лямбда-зонд, Ряд 4/опорное напряжение: короткое замыкание на массу
19749 P3293 Линейный лямбда-зонд, Ряд 4/опорное напряжение: короткое замыкание на плюс
19750 P3294 Линейный лямбда-зонд, Ряд 4/опорное напряжение: недостоверное значение
19751 P3295 Линейный лямбда-зонд, Ряд 4/общий кабель массы: обрыв цепи
19752 P3296 Линейный лямбда-зонд, Ряд 4/общий кабель массы: короткое замыкание на массу
19753 P3297 Линейный лямбда-зонд, Ряд 4/общий кабель массы: короткое замыкание на плюс
19754 P3298 Система катализаторов, Ряд 3: слишком малая эффективность
19755 P3299 Система катализаторов, Ряд 4: слишком малая эффективность
19756 P3300 Ряд 1, датчик положения распредвала выпускных клапанов=>-G300: короткое замыкание на массу
19757 P3301 Ряд 1, датчик положения распредвала выпускных клапанов =>-G300: обрыв цепи/короткое замыкание на плюс
19758 P3302 Ряд 2, датчик положения распредвала выпускных клапанов =>-G301: короткое замыкание на массу
19759 P3303 Ряд 2, датчик положения распредвала выпускных клапанов =>-G301: обрыв цепи/короткое замыкание на плюс
19760 P3304 Ряд 1, датчик положения распредвала выпускных клапанов-G300/датчик положения коленвала-G28: несоответствие сигналов
19761 P3305 Ряд 2, датчик положения распредвала выпускных клапанов-G301/датчик положения коленвала-G28: несоответствие сигналов19762
19762 P3306 Управление зажиганием, цил. 13: короткое замыкание на массу
19763 P3307 Управление зажиганием, цил. 13: короткое замыкание на плюс
19764 P3308 Управление зажиганием, цил. 13: обрыв цепи
19765 P3309 Управление зажиганием, цил. 14: короткое замыкание на массу
19766 P3310 Управление зажиганием, цил. 14: короткое замыкание на плюс
19767 P3311 Управление зажиганием, цил. 14: обрыв цепи
19768 P3312 Управление зажиганием, цил. 15: короткое замыкание на массу
19769 P3313 Управление зажиганием, цил. 15: короткое замыкание на плюс
19770 P3314 Управление зажиганием, цил. 15: обрыв цепи
19771 P3315 Управление зажиганием, цил. 16: короткое замыкание на массу
19772 P3316 Управление зажиганием, цил. 16: короткое замыкание на плюс
19773 P3317 Управление зажиганием, цил. 16: обрыв цепи
19774 P3318 Реле 2 включения свечей накаливания-J495: короткое замыкание на плюс
19775 P3319 Реле 2 включения свечей накаливания-J495:обрыв цепи/короткое замыкание на массу
19776 P3320 Подача управляющего сигнала 2 на клапаны насос-форсунок: короткое замыкание на плюс
19777 P3321 Подача управляющего сигнала 2 на клапаны насос-форсунок: сбой в электрической цепи
19778 P3322 Реле 2 электропитания клеммы 30-J689: недостоверный сигнал
19779 P3323 Электропитание кл.15: слишком высокий уровень напряжения
19780 P3324 Электропитание кл.15: обрыв цепи
19781 P3325 Электропитание кл.15: недостоверные данные
19782 P3326 Переключающий клапан заслонки впускного коллектора 2-N239: короткое замыкание на плюс
19783 P3327 Переключающий клапан заслонки впускного коллектора 2-N239: обрыв цепи/короткое замыкание на массу
19784 P3328 Электродвигатель привода заслонки впускного коллектора 2-V275: короткое замыкание на плюс
19785 P3329 Электродвигатель привода заслонки впускного коллектора 2-V275: обрыв цепи/короткое замыкание на массу
19786 P3330 Электродвигатель привода заслонки впускного коллектора 2-V275: нет сигнала
19787 P3331 Электродвигатель привода заслонки впускного коллектора 2-V275: неисправен
19788 P3332 Распознавание процесса сгорания в цилиндрах на режиме принудительного холостого хода.
19789 P3333 Блок управления 1 турбонагнетателя: сообщение недостоверно
19790 P3334 Блок управления 2 турбонагнетателя: сообщение недостоверно
19791 P3335 Блок управления 1 турбонагнетателя: нет сообщений
19792 P3336 Блок управления 2 турбонагнетателя: нет сообщений
19793 P3337 Шина данных двигатель/двигатель: недостоверное сообщение
19794 P3338 Подача сигнала управления на блок управления свечей накаливания 1: сбой в электрической цепи
19795 P3339 Подача сигнала управления на блок управления свечей накаливания 2: сбой в электрической цепи
19796 P3340 Реле вентилятора охлаждения наддувочного воздуха-J712: короткое замыкание на плюс
19797 P3341 Реле вентилятора охлаждения наддувочного воздуха-J712: короткое замыкание на массу
19798 P3342 Реле вентилятора охлаждения наддувочного воздуха-J712: обрыв цепи
19799 P3343 Блок управления турбокомпрессора 1-J724: слишком высокая температура
19800 P3344 Блок управления турбокомпрессора 1-J724: напряжение питания за пределами допустимого диапазона
19801 P3345 Блок управления турбокомпрессора 2-J725: слишком высокая температура
19802 P3346 Блок управления турбокомпрессора 2-J725: напряжение питания за пределами допустимого диапазона
19803 P3347 Реле включения свечей накаливания: сбой в электрической цепи
19804 P3348 Подача сигнала управления на блок управления турбокомпрессора 1-J724: сбой в электрической цепи
19805 P3349 Подача сигнала управления на блок управления турбокомпрессора 2-J725: сбой в электрической цепи
19806 P3350 Адаптация газовоздушной смеси: выход за пределы диапазона 1 (меньше минимума)
19807 P3351 Адаптация газовоздушной смеси: выход за пределы диапазона 1 (больше максимума)
19808 P3352 Адаптация газовоздушной смеси: выход за пределы диапазона 2 (меньше минимума)
19809 P3353 Адаптация газовоздушной смеси: выход за пределы диапазона 2 (больше максимума)
19810 P3354 Адаптация газовоздушной смеси: выход за пределы диапазона 3 (меньше минимума)
19811 P3355 Адаптация газовоздушной смеси: выход за пределы диапазона 3 (больше максимума)
19812 P3356 Система катализаторов автомобиля, работающего на газе, ряд 1: слишком малая эффективность
19813 P3357 Коррекция лямбда-зонда при работе на газе: достигнут предел регулирования
19814 P3358 Зонд 1, ряд 1, работа на газе: время реакции слишком велико
19815 P3359 Ряд 1-зонд 1, работа на газе: обратная связь цепи подогрева
19816 P3360 Ряд 1-зонд 1, работа на газе: нет активности
19817 P3361 Работа на газе: обнаружен пропуск воспламенения
19818 P3362 Работа на газе, цил. 1: обнаружен пропуск воспламенения
19819 P3363 Работа на газе, цил. 2: обнаружен пропуск воспламенения
19820 P3364 Работа на газе, цил. 3: обнаружен пропуск воспламенения
19821 P3365 Работа на газе, цил. 4: обнаружен пропуск воспламенения
19822 P3366 Слишком высокое давление газа в системе
19823 P3367 Слишком низкое давление газа в системе
19824 P3368 Лямбда-зонд 1-ряд 3: сигнал слишком бедной смеси
19825 P3369 Лямбда-зонд 1-ряд 3: сигнал слишком богатой смеси
19826 P3370 Лямбда-зонд 1-ряд 4: сигнал слишком бедной смеси
19827 P3371 Лямбда-зонд 1-ряд 4: сигнал слишком богатой смеси
19828 P3372 Переключающий клапан заслонки изменения геометрии впускного коллектора: короткое замыкание на массу
19829 P3373 Переключающий клапан заслонки изменения геометрии впускного коллектора: обрыв цепи/короткое замыкание на массу
19830 P3374 Переключающий клапан заслонки изменения геометрии впускного коллектора 2: короткое замыкание на плюс
19831 P3375 Переключающий клапан заслонки изменения геометрии впускного коллектора 2: обрыв цепи/короткое замыкание на массу
19832 P3376 Датчик температуры воздуха на впуске 3-G520: слишком низкий уровень сигнала
19833 P3377 Датчик температуры воздуха на впуске 3-G520: слишком высокий уровень сигнала
19835 P3379 Клапан высокого давления для работы на газе-N372: обрыв цепи
19836 P3380 Клапан высокого давления для работы на газе-N372: короткое замыкание на плюс
19837 P3381 Клапан высокого давления для работы на газе-N372: короткое замыкание на массу
19838 P3382 Датчик контура высокого давления газа-G400: обрыв цепи
19839 P3383 Датчик контура высокого давления газа-G400: короткое замыкание на плюс
19840 P3384 Датчик контура высокого давления газа-G400: короткое замыкание на массу
19841 P3385 Датчик контура низкого давления газа-G401: обрыв цепи
19842 P3386 Датчик контура низкого давления газа-G401: короткое замыкание на плюс
19843 P3387 Датчик контура низкого давления газа-G401: короткое замыкание на массу
19844 P3388 Клапан подачи газа 1-N366: обрыв цепи
19845 P3389 Клапан подачи газа 1-N366: короткое замыкание на плюс
19846 P3390 Клапан подачи газа 1-N366: короткое замыкание на массу
19847 P3391 Клапан подачи газа 2-N367: обрыв цепи
19848 P3392 Клапан подачи газа 2-N367: короткое замыкание на плюс
19849 P3393 Клапан подачи газа 2-N367: короткое замыкание на массу
19850 P3394 Клапан подачи газа 3-N368: обрыв цепи
19851 P3395 Клапан подачи газа 3-N368: короткое замыкание на плюс
19852 P3396 Клапан подачи газа 3-N368: короткое замыкание на массу
19853 P3397 Клапан подачи газа 4-N369: обрыв цепи
19854 P3398 Клапан подачи газа 4-N369: короткое замыкание на плюс
19855 P3399 Клапан подачи газа 4-N369: короткое замыкание на массу
Share this post
Link to post
Share on other sites
//GR
0x0B210001 1 Faults in control unit
0x0B210002 1 Faults in control unit
0x0B210003 7 Encoding data fault
0x0B210005 1 Faults in control unit
0x0B210006 1 Faults in control unit
0x0B210007 1 Faults in control unit
0x0B210010 2 Status of actuator clutch
0x0B210011 3 Actuator deactivation time
0x0B210012 4 Actuator position
0x0B210013 6 Supply voltage of feedback potentiometer
0x0B210021 5 Data line of ,ulti-function steering wheel
0x0B210030 1 Faults in control unit
0x0B220001 1 Faults in control unit
0x0B220002 1 Faults in control unit
0x0B220003 7 Encoding data fault
0x0B220004 1 Faults in control unit
0x0B220005 1 Faults in control unit
0x0B220006 1 Faults in control unit
0x0B220007 1 Faults in control unit
0x0B220010 2 Status of actuator clutch
0x0B220011 3 Actuator deactivation time
0x0B220012 4 Actuator position
0x0B220013 6 Supply voltage of feedback potentiometer
0x0B220021 5 Data line of ,ulti-function steering wheel
0x0B220030 1 Faults in control unit
0x0B230001 01 Control-module fault
0x0B230002 02 Control-module fault
0x0B230003 03 Control-module fault, coding data
0x0B230004 04 Control-module fault, coding data
0x0B230005 05 Control-module fault, coding
0x0B230006 06 Control-module fault, hardware/software
0x0B230010 10 Short circuit, actuator clutch
0x0B230011 11 Actuator, deactivation time
0x0B230012 12 Actuator position
0x0B230013 13 Check back-potentiometer voltage
0x0B230021 21 Data line, multifunction steering wheel
//PDC
0x0C210010 10 Converter, rear left
0x0C210011 11 Converter, rear right
0x0C210012 12 Converter, rear center left
0x0C210013 13 Converter, rear center right
0x0C210014 14 Transducer, front left
0x0C210015 15 Transducer, front right
0x0C210016 16 Transducer, front middle left
0x0C210017 17 Transducer, front middle right
0x0C210018 18 Voltage, Converters in general
0x0C210020 20 Acoustic generator, rear, off
0x0C210021 21 Acoustic generator, rear, on
0x0C210022 22 Acoustic generator, front off
0x0C210023 23 Acoustic generator, front on
0x0C210024 24 Function indicator off
0x0C210025 25 Function indicator on
0x0C210026 26 Position sensor
0x0C210027 27 Button
0x0C210028 28 Control unit
0x0C619E2B 9E2B Ultrasonic sensor, rear left
0x0C619E2E 9E2E Ultrasonic sensor, rear centre right
0x0C619E33 9E33 Wire, ultrasonic sensor, rear left
0x0C619E34 9E34 Wire, ultrasonic sensor, rear right
0x0C619E35 9E35 Wire, ultrasonic sensor, rear centre left
0x0C619E36 9E36 Wire, ultrasonic sensor, rear centre right
0x0C619E37 9E37 Wire, ultrasonic sensor, front left
0x0C619E38 9E38 Wire, ultrasonic sensor, front right
0x0C619E39 9E39 Wire, ultrasonic sensor, front centre left
0x0C619E3A 9E3A Wire, ultrasonic sensor, front centre right
0x0C619E3B 9E3B Supply, ultrasonic sensors
0x0C619E28 9E28 Control unit, internal fault
0x0C619E29 9E29 Function display
0x0C619E2A 9E2A Park Distance Control button
0x0C619E2B 9E2B Transducer, rear left
0x0C619E2C 9E2C Transducer, rear right
0x0C619E2D 9E2D Transducer, rear centre left
0x0C619E2E 9E2E Transducer, rear centre right
0x0C619E2F 9E2F Transducer, front left
0x0C619E30 9E30 Transducer, front right
0x0C619E31 9E31 Transducer, front centre left
0x0C619E32 9E32 Transducer, front centre right
0x0C619E33 9E33 Transducer lines, rear left
0x0C619E34 9E34 Transducer lines, rear right
0x0C619E35 9E35 Transducer lines, rear centre left
0x0C619E36 9E36 Transducer lines, rear centre right
0x0C619E37 9E37 Transducer lines, front left
0x0C619E38 9E38 Transducer lines, front right
0x0C619E39 9E39 Transducer lines, front centre left
0x0C619E3A 9E3A Transducer lines, front centre right
0x0C619E3B 9E3B Transducer supply
//SZM
0x0D210000 00 Terminal 30
0x0D210001 01 Seat heating, left, short or open circuit
0x0D210002 02 Seat heating, right , short or open circuit
0x0D210003 03 Temp. sensor, seat heating, left, short to grnd.
0x0D210004 04 Temp. sens., seat heating, right, short to grnd.
0x0D210005 05 Temp. sensor, seat heating, left, open circuit
0x0D210006 06 Temp. sensor, seat heating, right, open circuit
0x0D210007 07 Seat heating, seat cushion, left, open circuit
0x0D210008 08 Seat heating, seat cushion, right, open circuit
0x0D210009 09 Roller sun blind, motor, short or open circuit
0x0D21000A 0A Wire active seat, left
0x0D21000B 0B Wire active seat, right
0x0D21000C 0C Active seat, left, fault in switching centre
0x0D21000D 0D Active seat, right, fault in switching centre
0x0D21000E 0E K bus
0x0D220001 01 Terminal 30
0x0D220002 02 Seat heating, left, short or open circuit
0x0D220003 03 Seat heating, right, short or open circuit
0x0D220004 04 Temp. sensor, seat heating, left, open circuit
0x0D220005 05 Temp. sensor, seat heating, left, short to grnd.
0x0D220006 06 Temp. sensor, seat heating, right, open circuit
0x0D220007 07 Temp. sensor, seat heating, right, short to grnd.
0x0D220008 08 Seat heating, seat cushion, left, open circuit
0x0D220009 09 Seat heating, seat cushion, right, open circuit
0x0D22000A 0A Roller sun blind, motor, open circuit
0x0D22000B 0B Roller sun blind, motor, short circuit
//BIT
0x0E210001 01 Internal control-unit fault
0x0E210002 02 Internal Control-unit fault
0x0E210003 03 Line TEL_ON1 short circuit to ground
0x0E210004 04 Line TEL_ON2 short circuit to ground
0x0E210005 05 Line TEL_ON3 short circuit to ground
0x0E210006 06 Line TEL_ON4 short circuit to ground
0x0E210007 07 DSP signal, short circuit to ground
0x0E210008 08 DSP signal, short circuit to positive
0x0E210009 09 MUTE signal, short circuit to positive
0x0E21000A 0A Currently not present
0x0E210010 10 I-bus fault
0x0E210012 12 GSM level not OK
0x0E220001 01 Wire,compensator,short circuit to ground
0x0E220002 02 Wire,compensator,short circuit to positive
0x0E220003 03 Terminal 15,short circuit to ground
0x0E220004 04 Terminal 15,short circuit to positive
0x0E220005 05 Charging lead,short circuit to ground
0x0E220006 06 Charging lead,short circuit to positive
0x0E220007 07 Activation wire DSP,short circuit to ground
0x0E220008 08 Activation wire DSP,short circuit to positive
0x0E220009 09 Radio muting,short circuit to ground
0x0E22000A 0A Radio muting,short circuit to positive
//LSZ
0x0F21000A 0A Control-unit fault
0x0F21000B 0B Control-unit fault
0x0F21000C 0C Control-unit fault
0x0F21000D 0D Control-unit fault
0x0F21000E 0E Control-unit fault
0x0F21000F 0F Control-unit fault
0x0F210010 10 Control-unit fault
0x0F210014 14 Wire, brake-light switch, open circuit
0x0F210015 15 Break-light switch, short circ. to negative
0x0F210016 16 Turn-signal switch, short circ. to negative
0x0F210017 17 Main beam/headl. flasher, short circ. to neg.
0x0F210018 18 Connection to AHM is disturbed
0x0F21001E 1E Control-mod. fault w/headlight-range adjust.
0x0F21001F 1F Activ'n, motor for headlight-range adjust.
0x0F210020 20 Activ'n, motor for headlight-range adjust. 2
0x0F210021 21 Front load sensor, open circuit
0x0F210022 22 Front load sensor, short circuit to negative
0x0F210023 23 Rear load sensor, open circuit
0x0F210024 24 Rear load sensor, short circuit to negative
0x0F210028 28 Terminal R missing
0x0F210029 29 Terminal 15 missing
0x0F210032 32 Break light, centre, faulty
0x0F210033 33 Sidelight, front right, faulty
0x0F210034 34 Break light, left, faulty
0x0F210035 35 Break light, right, faulty
0x0F210036 36 Turn indicator, front left, faulty
0x0F210037 37 Turn indicator, front right, faulty
0x0F210038 38 Sidelight, front left, faulty
0x0F210039 39 Main beam, left faulty
0x0F21003A 3A Main beam, right, faulty
0x0F21003B 3B Sidelight, rear left, faulty
0x0F21003C 3C Number-plate light faulty
0x0F21003D 3D Sidelight, rear right, faulty
0x0F21003E 3E Rear fog light faulty
0x0F21003F 3F Turn indicator, rear left, faulty
0x0F210040 40 Turn indicator, rear right, faulty
0x0F210041 41 Dipped beam, right, faulty
0x0F210042 42 Dipped beam, left, faulty
0x0F210043 43 Supplementary turn indicator, left, faulty
0x0F210044 44 Supplementary turn indicator, right, faulty
0x0F21004A 4A Trailer, left turn-signal flasher faulty
0x0F21004B 4B Trailer, right turn-signal flasher faulty
0x0F210050 50 Activ'n headl.-range adj. driver, sporad. fault
0x0F22000A 0A Control-unit fault
0x0F22000B 0B Control-unit fault
0x0F22000C 0C Control-unit fault
0x0F22000D 0D Control-unit fault
0x0F22000F 0F Control-unit fault
0x0F220010 10 Term. 30 A faulty
0x0F220011 11 Term. 30 A faulty
0x0F220012 12 Control-unit fault
0x0F220013 13 Control-unit fault
0x0F220014 14 Wire, break-light switch, open circuit
0x0F220015 15 Wire, break-light switch, short circuit
0x0F220016 16 Wire/switch, turn indic., sh. circ. to earth
0x0F220017 17 Wire/switch, main b./headl.fl., sh. circ. to earth
0x0F220018 18 Connection to AHM is disturbed
0x0F220019 19 High-beam switch-inputs contradictory
0x0F22001E 1E Control-unit fault in HVAC section
0x0F22001F 1F Coils, stepping motors, faulty
0x0F220021 21 Headl.v.a.c., front load sensor, open circ.
0x0F220022 22 Headl.v.a.c., front load sens., sh. circ. to earth
0x0F220023 23 Headl.v.a.c., rear load sensor, open circ.
0x0F220024 24 Headl.v.a.c., rear load sens., sh. circ. to earth
0x0F220028 28 Terminal R missing
0x0F220029 29 Terminal 15 missing
0x0F22002A 2A HVAC potentiometer faulty
0x0F22002B 2B Dimmer potentiometer faulty
0x0F220032 32 Break light, centre, faulty
0x0F220033 33 Sidelight, front right, faulty
0x0F220034 34 Break light, left, faulty
0x0F220035 35 Break light, right, faulty
0x0F220036 36 Turn indicator, front left, faulty
0x0F220037 37 Turn indicator, front right, faulty
0x0F220038 38 Sidelight, front left, faulty
0x0F220039 29 Main beam, left, faulty
0x0F22003A 3A Main beam, right, faulty
0x0F22003B 3B Sidelight, rear left, faulty
0x0F22003C 3C Number-plate light faulty
0x0F22003D 3D Sidelight, rear right, faulty
0x0F22003E 3E Rear fog lights faulty
0x0F22003F 3F Turn indicator, rear left, faulty
0x0F220040 40 Turn indicator, rear right, faulty
0x0F220041 41 Dipped beam, right, faulty
0x0F220042 42 Dipped beam, left, faulty
0x0F220043 43 Supplementary turn indicator, left, faulty
0x0F220044 44 Supplementary turn indicator, right, faulty
0x0F220045 45 Side light 2, rear right, faulty
0x0F220046 46 Side light 3, rear left, faulty
0x0F220047 47 Side light 3, rear right, faulty
0x0F22004A 4A Trailer, left turn-signal flasher faulty
0x0F22004B 4B Trailer, right turn-signal flasher faulty
0x0F220050 50 Sporadic fault on activ. of headl.v.a.c driver
0x0F220051 51 Transport mode active
0x0F230078 120 Left low beam faulty
0x0F230079 121 Right low beam faulty
0x0F23007A 122 Front left parking light faulty
0x0F23007B 123 Front right parking light faulty
0x0F23007C 124 Front left turn-signal flasher faulty
0x0F23007D 125 Front right turn-signal flasher faulty
0x0F23007E 126 Right fog lamp faulty
0x0F23007F 127 Left fog lamp faulty
0x0F230080 128 Left high beam faulty
0x0F230081 129 Right high beam faulty
0x0F23008C 140 Left tail light faulty
0x0F23008D 141 Right reversing light faulty
0x0F23008E 142 Inside left reversing light faulty
0x0F23008F 143 Inside right reversing light faulty
0x0F230090 144 Rear left turn-signal falsher faulty
0x0F230091 145 Rear right turn-signal falsher faulty
0x0F230092 146 Left brake light faulty
0x0F230093 147 Right brake light faulty
0x0F230094 148 Left rear fog light faulty
0x0F230095 149 Right rear fog light faulty
0x0F230096 150 Left reversing light faulty
0x0F230097 151 Right reversing light faulty
0x0F230098 152 Middle brake light faulty
0x0F230099 153 Number-plate lamp faulty
0x0F24000A 0A Control-unit fault
0x0F24000B 0B Control-unit fault
0x0F24000C 0C Control-unit fault
0x0F24000D 0D Control-unit fault
0x0F24000F 0F Control-unit fault
0x0F240010 10 Term. 30 A faulty
0x0F240011 11 Term. 30 A faulty
0x0F240012 12 Control-unit fault
0x0F240013 13 Control-unit fault
0x0F240014 14 Wire, break-light switch, open circuit
0x0F240015 15 Wire, break-light switch, short circuit to earth
0x0F240016 16 Wire/switch, turn indic., sh. circ. to earth
0x0F240017 17 Wire/switch, main b./headl.fl., sh. circ. to earth
0x0F240018 18 Connection to AHM is disturbed
0x0F240019 19 High-beam switch-inputs contradictory
0x0F24001E 1E Control-unit fault in HVAC section
0x0F24001F 1F Coils, stepping motors, faulty
0x0F240021 21 Headl.v.a.c., front load sensor, open circ.
0x0F240022 22 Headl.v.a.c., front load sens., sh. circ. to earth
0x0F240023 23 Headl.v.a.c., rear load sensor, open circ.
0x0F240024 24 Headl.v.a.c., rear load sens., sh. circ. to earth
0x0F240028 28 Terminal R missing
0x0F240029 29 Terminal 15 missing
0x0F24002A 2A HVAC potentiometer faulty
0x0F24002B 2B Dimmer potentiometer faulty
0x0F240032 32 Break light, centre, faulty
0x0F240033 33 Sidelight, front right, faulty
0x0F240034 34 Break light, left, faulty
0x0F240035 35 Break light, right, faulty
0x0F240036 36 Turn indicator, front left, faulty
0x0F240037 37 Turn indicator, front right, faulty
0x0F240038 38 Sidelight, front left, faulty
0x0F240039 39 Main beam, left, faulty
0x0F24003A 3A Main beam, right, faulty
0x0F24003B 3B Sidelight, rear left, faulty
0x0F24003C 3C Number-plate light faulty
0x0F24003D 3D Sidelight, rear right, faulty
0x0F24003E 3E Rear fog lights faulty
0x0F24003F 3F Turn indicator, rear left, faulty
0x0F240040 40 Turn indicator, rear right, faulty
0x0F240041 41 Dipped beam, right, faulty
0x0F240042 42 Dipped beam, left, faulty
0x0F240043 43 Supplementary turn indicator, left, faulty
0x0F240044 44 Supplementary turn indicator, right, faulty
0x0F240045 45 Side light 2, rear right, faulty
0x0F240046 46 Side light 3, rear left, faulty
0x0F240047 47 Side light 3, rear right, faulty
0x0F24004A 4A Trailer, left turn-signal flasher faulty
0x0F24004B 4B Trailer, right turn-signal flasher faulty
0x0F240050 50 Sporadic fault on activ. of headl.v.a.c driver
0x0F240051 51 Transport mode active
//LEW
0x10210001 01 Supply (terminal 30)
0x10210002 02 Sensor current outside tolerance
0x10210003 03 Slider fault (normal operation)
0x10210004 04 Slider fault (adjustment operation)
0x10210005 05 Internal fault (EEPROM)
0x10210006 06 Internal fault (A/D converter)
0x10210007 07 Internal fault (ROM)
0x10210008 08 Internal fault (RAM)
0x1021000A 0A CAN version incorrect
0x1021000B 0B Sensor/vehicle allocation incorrect or not available
0x1021000C 0C CAN BUS OFF
0x1021000D 0D Steering speed implausible
0x1021000E 0E Steering angle implausible
0x1021000F 0F Internal fault (stack)
//RAD
0x11210001 01 Fault in the CD-changer interface
0x11210002 02 Fault in aerial power supply
0x11220000 00 Transport mode active
0x11220001 01 Fault in the CD-changer interface
0x11220002 02 Fault in aerial power supply
//EHC
0x12210001 01 Ride-level sensor,left
0x12210002 02 Ride-level sensor,right
0x12210003 03 Compressor relay
0x12210004 04 Valve, left
0x12210005 05 Valve, right
0x12210006 06 Drain valve
0x12210007 07 Control unit
0x12210008 08 Control-time fault 'lifting'
0x12210009 09 Control-time fault 'Lowering'
0x1221000A 0A Control-time fault 'One - sided'
0x12220001 01 Height sensor, left
0x12220002 02 Height sensor, right
0x12220003 03 Compressor relay
0x12220004 04 Valve, left
0x12220005 05 Valve, right
0x12220006 06 Drain valve
0x12220007 07 Control unit
0x12220008 08 Control-time fault 'Raising'
0x12220009 09 Control-time fault 'Lowering'
0x1222000A 10 Control-time fault 'One - sided'
0x12615F8E 5F8E Ride-level sensor,rear left
0x12615F8F 5F8F Ride-level sensor,rear right
0x12615F90 5F90 Supply,air suspension
0x12615F92 5F92 Supply,ride-level sensor,rear left
0x12615F93 5F93 Supply,ride-level sensor,rear right
0x12615F94 5F94 Solenoid value,rear left
0x12615F95 5F95 Solenoid value,rear right
0x12615F96 5F96 Drain value
0x12615F97 5F97 Compressor relay
0x12615F98 5F98 Control-time fault,lifting,rear left
0x12615F99 5F99 Control-time fault,lifting,rear right
0x12615F9A 5F9A Control-time fault,lifting
0x12615F9B 5F9B Control-time fault,lowering
0x12615F9C 5F9C Sensor activity,ride-level sensor,rear left
0x12615F9D 5F9D Sensor activity,ride-level sensor,rear right
0x12615FB0 5FB0 Control unit,internal fault
0x12615FB1 5FB1 Control-unit fault(EEPROM memory)
0x12615FB2 5FB2 Control-unit fault(flash memory)
0x12615FB3 5FB3 Checksum error,RAM error
0x12615FB4 5FB4 Energy-saving mode active
//BM
0x13210001 01 Control unit reset
0x13210002 02 PL line: short circuit to batt. +
0x13210003 03 PL line: short circuit to earth
0x13210004 04 PL line: open circuit
0x13210005 05 Overtemperature, monitor
0x13210006 06 Acknowledgement from radio not received
0x13210007 07 Fault, audio output, left +
0x13210008 08 Fault, audio output, left -
0x13210009 09 Fault, audio output, right +
0x1321000A 10 Fault, audio output, right -
0x1321000B 11 I-bus fault
0x1321000C 12 Forced switch-off, independent heating LED
//AIC
0x14210001 01 Internal hardware fault
0x14210002 02 No adaptation to windscreen possible
0x14210003 03 Supply voltage or temperature
0x14210004 04 Internal hardware fault
0x14210006 06 Reset contact not detected
0x14220001 10 Light sensor
0x14220002 20 Sensor not coded
0x14220003 30 Light sensor
0x14220004 40 Optical initialisation
0x14220005 50 Optical initialisation
0x14220006 60 Optical initialisation
0x14220007 70 Optical initialisation
0x14220008 80 Control unit
0x14220009 90 Control unit
0x1422000A A0 Control unit
0x1422000B B0 Control unit
0x1422000C C0 Control unit
0x1422000D D0 Control unit
0x1422000E E0 Control unit
0x1422000F F0 Control unit
//NAV
0x15210001 01 Navigation computer
0x15210002 02 Wheel sensor
0x15210003 03 Inputs,peripherals
0x15210004 04 GPS receiver does not respond to initialization of NavMk3
0x15210005 05 Temperature too high
0x15210006 06 Application software
0x15210007 07 Display
0x15210008 08 Audio
0x15210009 09 CD fault
0x1561D7D0 D7D0 Ring-break diagnosis has been carried out
0x1561D7D2 D7D2 Deactivation, high temperature
//VID
0x17210003 03 Transport mode active
0x17210029 29 Transport mode active
//MID
0x19210005 5 Transport mode active
//SHD
0x1A210001 1 Relays
0x1A210002 2 Incremental sensor
0x1A210003 3 Control switch
0x1A210004 4 Control-module fault
0x1A220008 08 Internal control-unit fault
0x1A220009 09 Internal control-unit fault
0x1A22000A 0A Internal control-unit fault
0x1A22000B 0B Internal control-unit fault
0x1A22000D 0D Internal control-unit fault
0x1A22000E 0E Transport mode active
0x1A220085 85 Internal control-unit fault
0x1A220088 88 Control switch
0x1A22008A 8A Switch backlighting
0x1A22008D 8D Coding
0x1A220090 90 Roof unit, slide/tilt sunroof
0x1A220091 91 Drive, slide/tilt sunroof
0x1A220092 92 Normalization, slide/tilt sunroof
0x1A2200A0 A0 Roof unit, sliding visor
0x1A2200A1 A1 Drive, sliding visor
0x1A2200A2 A2 Normalization, sliding visor
0x1A810001 01 Relay in module does not pick up
0x1A810002 02 Relay in module does not pick up
0x1A810003 03 Relay in module does not pick up
0x1A810004 04 Relay in module does not pick up
0x1A810005 05 Relay in module sticks
0x1A810006 06 Relay in module sticks
0x1A810007 07 Relay in module sticks
0x1A810008 08 Relay in module sticks
0x1A810009 09 Rear position sensor faulty or polarity of motor reversed
0x1A81000A 10 Front position sensor faulty or polarity of motor reversed
0x1A81000B 11 Rear position sensor or rear motor faulty
0x1A81000C 12 Front position sensor or front motor faulty
0x1A81000D 13 Power supply faulty
0x1A81000E 14 One motor faulty or wires are short-circuited to earth
0x1A81000F 15 SHD switch or wires faulty
0x1A810010 16 Internal fault
//SMF
0x1B210000 00 Hall sensor, backrest angle: short circuit to negative
0x1B210001 01 Hall sensor, backrest angle: open circuit
0x1B210002 02 Hall sensor, backrest angle: short circuit to positive
0x1B210003 03 Hall sensor, seat height: short circuit to negative
0x1B210004 04 Hall sensor, seat height: open circuit
0x1B210005 05 Hall sensor, seat height: short circuit to positive
0x1B210006 06 Hall sensor, seat angle: short circuit to ground
0x1B210007 07 Hall sensor, seat angle: open circuit
0x1B210008 08 Hall sensor, seat angle: short circuit to positive
0x1B210009 09 Hall sensor, seat sled: short circuit to negative
0x1B21000A 0A Hall sensor, seat sled: open circuit
0x1B21000B 0B Hall sensor, seat sled: short circuit to positive
0x1B21000C 0C Supply voltage, Hall sensors: short circuit to positive
0x1B21000D 0D Control-module fault: motor bridge faulty
0x1B220000 00 Hall sensor, backrest angle: short circuit to ground
0x1B220001 01 Hall sensor, backrest angle: open circuit
0x1B220002 02 Hall sensor, backrest angle: short circuit to positive
0x1B220003 03 Hall sensor, seat height: short circuit to ground
0x1B220004 04 Hall sensor, seat height: open circuit
0x1B220005 05 Hall sensor, seat height: short circuit to positive
0x1B220006 06 Hall sensor, seat angle: short circuit to ground
0x1B220007 07 Hall sensor, seat angle: open circuit
0x1B220008 08 Hall sensor, seat angle: short circuit to positive
0x1B220009 09 Hall sensor, seat carriage: short circuit to ground
0x1B22000A 0A Hall sensor, seat carriage: open circuit
0x1B22000B 0B Hall sensor, seat carriage: short circuit to positive
0x1B22000C 0C Hall sensor, head restraint: short circuit to positive
0x1B22000D 0D Hall sensor, head restraint: open circuit
0x1B22000E 0E Hall sensor, head restraint: short circuit to positive
0x1B22000F 0F Hall sensor, backrest lock: short circuit to ground
0x1B220010 10 Hall sensor, backrest lock: open circuit
0x1B220011 11 Hall sensor, backrest lock: short circuit to positive
0x1B220012 12 Hall sensor ST2 not connected: short circuit to ground
0x1B220013 13 Control-unit fault: motor bridge faulty
0x1B220014 14 Seat control switch: short circuit to positive
0x1B220015 15 Seat control switch: short circuit to ground
//SPMBT
0x1C210004 04 Mirror-adjustment switch,open circuit
0x1C210005 05 Mirror heater,open circuit
0x1C210006 06 Mirror heater,short circuit
0x1C210007 07 Mirror motor,potentiometer,vertical
0x1C210008 08 Mirror motor,potentiometer,horizontal
0x1C210009 09 Mirror motor,vertical,open circuit
0x1C21000A 0A Mirror motor,vertical,short circuit
0x1C21000B 0B Mirror motor,horizontal,open circuit
0x1C21000C 0C Mirror motor,horizontal,short circuit
0x1C21000D 0D Mirror motor,folding-in,open circuit
0x1C21000E 0E Mirror motor,folding-in,short circuit
//SMPFT
0x1D210004 04 Mirror-adjustment switch,open circuit
0x1D210005 05 Mirror heater,open circuit
0x1D210006 06 Mirror heater,short circuit
0x1D210007 07 Mirror motor,potentiometer,vertical
0x1D210008 08 Mirror motor,potentiometer,horizontal
0x1D210009 09 Mirror motor,vertical,open circuit
0x1D21000A 0A Mirror motor,vertical,short circuit
0x1D21000B 0B Mirror motor,horizontal,open circuit
0x1D21000C 0C Mirror motor,horizontal,short circuit
0x1D21000D 0D Mirror motor,folding-in,open circuit
0x1D21000E 0E Mirror motor,folding-in,short circuit
//VTG
0x1E415208 5208 Supply, servomotor
0x1E4152D0 52D0 Lead, servomotor (signal name: DIR)
0x1E4152D1 52D1 Incremental transducer in servomotor, supply
0x1E4152D2 52D2 Lead, servomotor (signal name: IMP)
0x1E4152D4 52D4 Incremental transducer
0x1E415398 5398 Control unit, internal (flash)
0x1E415399 5399 Control unit, internal (EEPROM)
0x1E41539A 539A Control unit, internal (watchdog)
0x1E41539B 539B Control unit, internal (RAM)
0x1E41539D 539D Control unit, internal
0x1E41539E 539E Transfer case malfunction
0x1E4153A0 53A0 Coding incorrect
0x1E4153FB 53FB Supply, control unit: reset due to undervoltage
0x1E4153FC 53FC Supply, control unit: terminal 30
0x1E4153FE 53FE Control unit, internal (unexpected reset)
0x1E4153FF 53FF Supply, control unit: terminal 15
0x1E415460 5460 Motor current measurement faulty
0x1E415461 5461 Activation, servomotor, faulty
0x1E415462 5462 Servomotor or coupling force too high
0x1E415463 5463 Mechanism faulty
0x1E4154C4 54C4 Calibration faulty
0x1E4154C5 54C5 Offset, motor current measurement
0x1E4154C6 54C6 Oil wear
0x1E4154C7 54C7 Incremental-transducer model implausible
0x1E4154C8 54C8 Classification resistor
0x1E4155C0 55C0 Limp-home controller, abort
0x1E6155C3 55C3 AWD limp-home control activated. No DSC specified nominal torque.
//CID
0x1F41A469 A469 Control-module fault
0x1F41A46A A46A Temperature deactivation
0x1F41A46B A46B Control-module fault
0x1F41A46C A46C Transport mode active
0x1F61A468 A468 External open circuit (LVDS data line)
0x1F61A469 A469 Internal control-module fault
0x1F61A46A A46A Cutout due to overtemperature (no fault)
0x1F61A46B A46B Internal control-module fault
0x1F61A46C A46C Transport mode active
//EPS
0x2041D6FE D6FE Day/night switch signal
0x2041FFFF FFFF Unknown fault location
0x2041610C 610C Comparison,rotor anglesteering angle
0x2041610D 610D CAN bus
0x2041610E 610E Temperature EPS
0x2041610F 610F EEPROM,no risk
0x20416110 6110 Sensor supply
0x20416111 6111 ROM checksum
0x20416112 6112 Ignition
0x20416113 6113 Intelligent watchdog
0x20416114 6114 compare
0x20416115 6115 RAM
0x20416116 6116 Relays
0x20416117 6117 Internal voltage
0x20416118 6118 Control,servomotor
0x20416119 6119 Speed,servomotor
0x2041611A 611A Phase voltage,servomotor
0x2041611B 611B Steering angle
0x2041611C 611C Steering torque
0x2041611D 611D Power supply
0x2041611E 611E Vehicle speed
0x2041611F 611F Program
0x20416120 6120 Sport button display
0x20416121 6121 Vehicle engine speed
0x20416122 6122 EEPROM,high risk
0x20416123 6123 Module,engine control
0x20416124 6124 Power reduction due to overtemperature
0x20416125 6125 Steering angle correction
0x20416126 6126 Power reduction due to overloading
0x20416127 6127 Steering angle
0x20416128 6128 Vehicle speed
0x20416129 6129 Vehicle engine speed
0x2041612A 612A Mileage/km reading
0x2041612B 612B Sport button signal
0x2041612C 612C Day/night switch signal
0x2041612D 612D Steering angle correction
0x2041612E 612E Comparison,rotor anglesteering angle
//SBSL
0x21419828 9828 Processor:reset
0x21419829 9829 Control-unit fault
0x2141982A 982A Control-unit fault
0x2141982B 982B Incorrect chassis number
0x2141982C 982C System time fault
0x2141983E 983E Control-unit fault
0x21419840 9840 Coding-data error
0x21419841 9841 Coding-data error
0x21419842 9842 Self-test:too few messages
0x21419843 9843 Self-test:data error in message
0x21419844 9844 Self-test:transmission error
0x21419845 9845 Implausible crash severity
0x21419846 9846 Control-unit fault
0x21419847 9847 Short circuit,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to ground
0x21419848 9848 Short circuit,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to positive
0x21419849 9849 Resistance,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to low
0x2141984A 984A Resistance,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to high
0x2141984B 984B Resistance,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to measured
0x2141984C 984C Open circuit,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x)
0x2141984D 984D Control-unit fault
0x2141984E 984E Control-unit fault
0x2141984F 984F Coding,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),at variance
0x21419850 9850 Control-unit fault
0x21419851 9851 Control-unit fault
0x21419852 9852 Short circuit,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),to ground
0x21419853 9853 Short circuit,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),to positive
0x21419855 9854 Resistance,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),too low
0x21419855 9855 Resistance,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),too high
0x21419856 9856 Resistance,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),not measured
0x21419857 9857 Open circuit,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x)
0x21419858 9858 Control-unit fault
0x21419859 9859 Control-unit fault
0x2141985A 985A Coding ,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),at variance
0x2141985B 985B Control-unit fault
0x2141985C 985C Control-unit fault
0x2141985D 985D Short circuit,firing circuit,belt tensioner,front left,to ground
0x2141985E 985E Short circuit,firing circuit,belt tensioner,front left,to positive
0x2141985F 985F Resistance,firing circuit,belt tensioner,front left,too low
0x21419860 9860 Resistance,firing circuit,belt tensioner,front left,too high
0x21419861 9861 Resistance,firing circuit,belt tensioner,front left,not measured
0x21419862 9862 Open circuit,firing circuit,belt tensioner,front left
0x21419863 9863 Control-unit fault
0x21419864 9864 Control-unit fault
0x21419865 9865 Coding,firing circuit,belt tensioner,front left,at variance
0x21419866 9866 Control-unit fault
0x21419867 9867 Control-unit fault
0x21419868 9868 Short circuit,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),to ground
0x21419869 9869 Short circuit,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),to positive
0x2141986A 986A Resistance,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),too low
0x2141986B 986B Resistance,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),too high
0x2141986C 986C Resistance,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),not measured
0x2141986D 986D Open circuit,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64)
0x2141986E 986E Control-unit fault
0x2141986F 986F Control-unit fault
0x21419870 9870 Coding,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64) at variance
0x21419871 9871 Control-unit fault
0x21419872 9872 Control-unit fault
0x21419873 9873 Short circuit,firing circuit,belt tensioner,rear left,to ground
0x21419874 9874 Short circuit,firing circuit,belt tensioner,rear left,to positive
0x21419875 9875 Resistance,firing circuit,belt tensioner,rear left,too low
0x21419876 9876 Resistance,firing circuit,belt tensioner,rear left,too high
0x21419877 9877 Resistance,firing circuit,belt tensioner,rear left,not measured
0x21419878 9878 Open circuit,firing circuit,belt tensioner,rear left
0x21419879 9879 Control-unit fault
0x2141987A 987A Control-unit fault
0x2141987B 987B Coding,firing circuit,belt tensioner,rear left,at variance
0x2141987C 987C Control-unit fault
0x2141987D 987D Control-unit fault
0x2141987E 987E Short circuit,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),to ground
0x2141987F 987F Short circuit,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),to positive
0x21419880 9880 Resistance,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),too low
0x21419881 9881 Resistance,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),too high
0x21419882 9882 Resistance,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),not measured
0x21419883 9883 Open circuit,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x)
0x21419884 9884 Control-unit fault
0x21419885 9885 Control-unit fault
0x21419886 9886 Coding,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),at variance
0x21419887 9887 Control-unit fault
0x21419888 9888 Control-unit fault
0x21419889 9889 Control-unit fault
0x2141988A 988A Control-unit fault
0x2141988B 988B Control-unit fault
0x2141988C 988C Control-unit fault
0x2141988D 988D Control-unit fault
0x2141988E 988E Control-unit fault
0x2141988F 988F Seat-belt buckle:short circuit
0x21419890 9890 Seat-belt buckle:implausible ,measured value
0x21419891 9891 Seat-belt buckle:open circuit
0x21419892 9892 Control unit fault(E6x) or software error(E85)
0x21419893 9893 Seat-occupancy detector,passenger:open circuit
0x21419894 9894 Seat-occupancy detector,passenger:short circuit
0x21419895 9895 Seat-occupancy detector,passenger:communication fault
0x21419896 9896 Control-unit fault
0x21419897 9897 Control-unit fault
0x21419898 9898 Firing attempt taken place
0x21419899 9899 Control-unit fault
0x2141989E 989E Voltage supply not in permitted range
//SBSL MODE5
0x2161982C 982C System time fault
0x21619842 9842 Self-Test: too few messages
//SBSR
0x224198A8 98A8 Processor:reset
0x224198A9 98A9 Control-unit fault
0x224198AA 98AA Control-unit fault
0x224198AB 98AB Incorrect chassis number
0x224198AC 98AC System time fault
0x224198AE 98AE Control-unit fault
0x224198C0 98C0 Coding-data error
0x224198C1 98C1 Coding-data error
0x224198C2 98C2 Self-test:too few messages
0x224198C3 98C3 Self-test:data error in message
0x224198C4 98C4 Self-test:transmission error
0x224198C5 98C5 Implausible crash severity
0x224198C6 98C6 Control-unit fault
0x224198C7 98C7 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,to ground
0x224198C8 98C8 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,to positive
0x224198C9 98C9 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,too low
0x224198CA 98CA Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,too high
0x224198CB 98CB Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,not measured
0x224198CC 98CC Open circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1
0x224198CD 98CD Control-unit fault
0x224198CE 98CE Control-unit fault
0x224198CF 98CF Coding,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,at variance
0x224198D0 98D0 Control-unit fault
0x224198D1 98D1 Control-unit fault
0x224198D2 98D2 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,to ground
0x224198D3 98D3 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,to positive
0x224198D4 98D4 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,too low
0x224198D5 98D5 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,too high
0x224198D6 98D6 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,not measured
0x224198D7 98D7 Open circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2
0x224198D8 98D8 Control-unit fault
0x224198D9 98D9 Control-unit fault
0x224198DA 98DA Coding,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,at variance
0x224198DB 98DB Control-unit fault
0x224198DC 98DC Control-unit fault
0x224198DD 98DD Short circuit,firing circuit,belt tensioner,front right,to ground
0x224198DE 98DE Short circuit,firing circuit,belt tensioner,front right,to positive
0x224198DF 98DF Resistance,firing circuit,belt tensioner,front right,too low
0x224198E0 98E0 Resistance,firing circuit,belt tensioner,front right,too high
0x224198E1 98E1 Resistance,firing circuit,belt tensioner,front right,not measured
0x224198E2 98E2 Open circuit,firing circuit,belt tensioner,front right
0x224198E3 98E3 Control-unit fault
0x224198E4 98E4 Control-unit fault
0x224198E5 98E5 Coding,firing circuit,belt tensioner,front right,at variance
0x224198E6 98E6 Control-unit fault
0x224198E7 98E7 Control-unit fault
0x224198E8 98E8 Short circuit,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),to ground
0x224198E9 98E9 Short circuit,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),to positive
0x224198EA 98EA Resistance,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),too low
0x224198EB 98EB Resistance,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),too high
0x224198EC 98EC Resistance,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),not measured
0x224198ED 98ED Open circuit,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64)
0x224198EE 98EE Control-unit fault
0x224198EF 98EF Control-unit fault
0x224198F0 98F0 Coding,firing circuit, thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64) at variance
0x224198F1 98F1 Control-unit fault
0x224198F2 98F2 Control-unit fault
0x224198F3 98F3 Short circuit,firing circuit,safety battery terminal(E85),or belt tensioner,rear right(E6x),to ground
0x224198F4 98F4 Short circuit,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),to positive
0x224198F5 98F5 Resistance,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),too low
0x224198F6 98F6 Resistance,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),too high
0x224198F7 98F7 Resistance,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),not measured
0x224198F8 98F8 Open circuit,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x)
0x224198F9 98F9 Control-unit fault
0x224198FA 98FA Control-unit fault
0x224198FB 98FB Coding,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x) ,at variance
0x224198FC 98FC Control-unit fault
0x224198FD 98FD Control-unit fault
0x224198FE 98FE Short circuit,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too ground
0x224198FF 98FF Short circuit,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too positive
0x22419900 9900 Resistance,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too low
0x22419901 9901 Resistance,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too high
0x22419902 9902 Resistance,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),not measured
0x22419903 9903 Open circuit,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x)
0x22419904 9904 Control-unit fault
0x22419905 9905 Control-unit fault
0x22419906 9906 Coding,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),at variance
0x22419907 9907 Control-unit fault
0x22419908 9908 Control-unit fault
0x22419909 9909 Control-unit fault
0x2241990A 990A Control-unit fault
0x2241990B 990B Control-unit fault
0x2241990C 990C Control-unit fault
0x2241990D 990D Control-unit fault
0x2241990E 990E Control-unit fault
0x2241990F 990F Seat-belt buckle:short circuit
0x22419910 9910 Seat-belt buckle:implausible measured value
0x22419911 9911 Seat-belt buckle:open circuit
0x22419912 9912 Control unit fault(E6x) or software error(E85)
0x22419913 9913 Seat-occupancy detector,passenger:open circuit
0x22419914 9914 Seat-occupancy detector,passenger:short circuit
0x22419915 9915 Seat-occupancy detector,passenger:communication fault
0x22419916 9916 Control-unit fault
0x22419917 9917 Control-unit fault
0x22419918 9918 Firing attempt taken place
0x22419919 9919 Control-unit fault
0x2241991A 991A Battery lead(shield):open circuit
0x2241991B 991B Battery lead(shield):short circuit to ground
0x2241991C 991C Battery lead(shield):short circuit to positive
0x2241991D 991D Battery lead(shield):implausible measured value
0x2241991E 991E Voltage supply not in permitted range
0x226198AC System time fault
0x226198C2 Self-test: too few messages
0x226198D5 Resistance, firing circuit, safety battery terminal, too high
//CVM
0x23210001 01 Coding-data record invalid, not coded
0x23210002 02 Coding implausible
0x23210003 03 Control-unit fault, internal memory
0x23210004 04 Control-unit fault, internal memory
0x23210005 05 Control-unit fault, coding data
0x23210006 06 Control-unit fault, internal memory
0x23210007 07 Control-unit fault
0x23210008 08 Control-unit fault
0x23210009 09 Control-unit fault
0x2321000A 0A K bus faulty
0x23210010 10 Voltage supply to switch in car faulty
0x23210011 11 Voltage supply to switch on convertible top faulty
0x23210012 12 Open control button permanently active
0x23210013 13 Close control button permanently active
0x23210014 14 Temperature-sensor input, permanently to ground
0x23210015 15 Temperature sensor open-circuited
0x23210016 16 Position switch for main pillar, open circuit
0x23210017 17 Position switch for main pillar, short circuit to ground
0x23210018 18 Position switch for tension bar, open circuit
0x23210019 19 Position switch for tension bar, short circuit to ground
0x2321001A 1A Switch, convertible-top comp. lid, voltage > 2.5V
0x2321001B 1B Switch, convertible-top comp. lid, voltage undefined
0x2321001C 1C Switch, convertible-top comp. lid, short to ground or open circuit
0x2321001D 1D Switch, cowl locked, voltage > 2.5V
0x2321001E 1E Switch, cowl locked, voltage undefined
0x2321001F 1F Switch, cowl locked, short to ground or open circuit
0x23210020 20 Switch, cowl unlocked, voltage > 2.5V
0x23210021 21 Switch, cowl unlocked, voltage undefined
0x23210022 22 Switch, cowl unlocked, short to ground or open circuit
0x23210023 23 Switch, convertible-top comp. lid, right, locked, voltage > 2.5V
0x23210024 24 Switch, convertible-top comp. lid, right, locked, voltage undefined
0x23210025 25 Switch, convertible-top comp. lid, right, locked, short to ground or open circuit
0x23210026 26 Switch, convertible-top comp. lid, left, locked, voltage > 2.5V
0x23210027 27 Switch, convertible-top comp. lid, left, locked, voltage undefined
0x23210028 28 Switch, convertible-top comp. lid, left, locked, short to ground or open circuit
0x23210029 29 Switch, convertible-top locked, voltage > 2.5V
0x2321002A 2A Switch, convertible-top locked, voltage undefined
0x2321002B 2B Switch, convertible-top locked, short to ground or open circuit
0x2321002C 2C VSW 9, voltage > 5V
0x2321002D 2D VSW 9, voltage undefined
0x2321002E 2E VSW 9, short circuit to ground
0x2321002F 2F Switch, hard top, voltage > 2.5V
0x23210030 30 Switch, hard top, voltage undefined
0x23210031 31 Switch, hard top, short to ground or open circuit
0x23210040 40 Drive, cowl, motor current too high during unlocking
0x23210041 41 Drive, cowl, motor current too high during unlocking
0x23210042 42 Drive, cowl, short circuit to +ve
0x23210043 43 Drive, cowl, fault during unlocking
0x23210044 44 Drive, cowl, fault during unlocking
0x23210045 45 Valve, retract clamping bracket, open circuit
0x23210046 46 Valve, retract clamping bracket, short circuit to ground
0x23210047 47 Valve, retract clamping bracket, short circuit to +ve
0x23210048 48 Valve, extend clamping bracket, open circuit
0x23210049 49 Valve, extend clamping bracket, short circuit to ground
0x2321004A 4A Valve, extend clamping bracket, short circuit to +ve
0x2321004B 4B Short between valve, retract clamping bracket, and valve, main pillar
0x2321004C 4C Valve, main pillar, open circuit
0x2321004D 4D Valve, main pillar, short circuit to ground
0x2321004E 4E Valve, main pillar, short circuit to ground
0x23210050 50 Valve, emergency release, open circuit
0x23210051 51 Valve, emergency release, short circuit to ground
0x23210052 52 Valve, emergency release, short circuit to positive
0x23210053 53 Relay, convertible top drive, open circuit
0x23210054 54 Relay, convertible top drive, short circuit to ground
0x23210055 55 Relay, convertible top drive, short circuit to positive
0x23210056 56 Short circuit between output, relay, convertible top drive, and valve, emergency release
0x23210057 57 Valve, convertible-top comp. lid, open circuit
0x23210058 58 Valve, convertible-top comp. lid, short circuit to ground
0x23210059 59 Valve, convertible-top comp. lid, short circuit to +ve
0x23210060 60 Convertible-top compartment lid is not raised
0x23210061 61 Convertible-top compartment lid is not opened
0x23210062 62 Convertible-top compartment lid is not closed
0x23210063 63 Main pillar does not pull clamping bracket from convertible-top compartment
0x23210064 64 Main pillar does not force clamping bracket into convertible-top compartment
0x23210065 65 Clamping bracket is not fully raised
0x23210066 66 Clamping bracket does not locate engagement area
0x23210067 67 Cowl does not move upwards
0x23210068 68 Cowl does not move downwards
0x23220001 01 Control unit not coded
0x23220002 02 Coding data incorrect
0x23220003 03 Control unit
0x23220005 05 Coding data incorrect
0x23220006 06 Control unit
0x23220007 07 Control unit
0x23220008 08 Control unit
0x23220009 09 Control unit
0x23220011 11 Supply,convertible-top switch(Hall sensors)
0x23220012 12 Control button,short circuit when opening
0x23220013 13 Control button,short circuit when closing
0x2322001A 1A Switch,convertible top closed,short circuit to positive
0x2322001B 1B Switch,convertible top closed,undefined voltage range
0x2322001C 1C Switch,convertible top closed, short circuit to ground
0x2322001D 1D Switch,cowl panel locked,short circuit to positive
0x2322001E 1E Switch,cowl panel locked, undefined voltage range
0x2322001F 1F Switch,cowl panel locked,short circuit to ground
0x23220020 20 Switch,cowl panel unlocked,short circuit to positive
0x23220021 21 Switch,cowl panel unlocked, undefined voltage range
0x23220022 22 Switch,cowl panel unlocked,short circuit to ground
0x23220023 23 Switch,convertible top stowed,short circuit to positive
0x23220024 24 Switch,convertible top stowed,undefined voltage range
0x23220025 25 Switch,convertible top stowed, short circuit to ground
0x23220040 40 Drive,cowl panel,current too high when opening safety catch
0x23220041 41 Drive,cowl panel,current too high when closing safety catch
0x23220042 42 Drive,cowl panel,short circuit to positive
0x23220043 43 Drive,cowl panel,open circuit
0x23220044 44 Drive,cowl panel,open circuit
0x23220063 63 Time exceeded,close convertible top
0x23220064 64 Time exceeded,open convertible top
0x23220067 67 Time exceeded,unlocked convertible top
0x23220068 68 Time exceeded,lock convertible top
0x23220069 69 Circuit,pump,open convertible top
0x2322006A 6A Circuit,pump,open convertible top,short circuit to ground
0x2322006B 6B Circuit,pump,open convertible top,short circuit to positive
0x2322006C 6C Circuit,pump,close convertible top,open circuit
0x2322006D 6D Circuit,pump,close convertible top,short circuit to ground
0x2322006E 6E Circuit,pump,close convertible top,short circuit to positive
//SIM
0x244193A8 93A8 Processor: reset
0x244193A9 93A9 Control-unit fault
0x244193AA 93AA Control-unit fault
0x244193AB 93AB Incorrect chassis number
0x244193AC 93AC System time fault
0x244193AD 93AD No message (1) from satellite,door,front left
0x244193AF 93AF No message (3) from satellite,door,front right
0x244193B1 93B1 No message (5) from satellite,B-pillar, left
0x244193B3 93B3 No message (7) from satellite,B-pillar, right
0x244193B7 93B7 No message (B) from satellite,B-pillar, left
0x244193B8 93B8 No message © from satellite,B-pillar, right
0x244193BA 93BA No message (11) from satellite,B-pillar, right
0x244193BB 93BB No message (12) from satellite,B-pillar, left
0x244193BC 93BC No message (20) from satellite,B-pillar, left
0x244193BD 93BD No message (21) from satellite,B-pillar, right
0x244193C0 93C0 Coding-data error
0x244193C1 93C1 Coding-data error
0x244193C2 93C2 Self-test:too few messages
0x244193C3 93C3 Self-test:data error in message
0x244193C4 93C4 Self-test:transmission error
0x244193C5 93C5 Implausible crash severity
0x244193C6 93C6 Control-unit fault
0x244193C7 93C7 Deactivation:satellite,B-pillar,left
0x244193C8 93C8 Deactivation:satellite,B-pillar,right
0x244193C9 93C9 Deactivation:satellite,door,front left
0x244193CA 93CA Deactivation:satellite,door,front right
0x244193D9 93D9 Control-unit fault
0x244193DB 93DB Control-unit fault
0x244193DC 93DC Control-unit fault
0x244193DD 93DD Control-unit fault
0x244193DE 93DE Firing attempt taken place
0x244193DF 93DF Control-unit fault
0x244193E0 93E0 Control-unit fault
0x244193E1 93E1 Control-unit fault
0x244193E2 93E2 Key-operated switch,passenger airbag:short circuit
0x244193E3 93E3 Key-operated switch,passenger airbag:implausible measured value
0x244193E4 93E4 Key-operated switch,passenger airbag:open circuit
0x244193E5 93E5 Indicator lamp,airbag deactivation:short circuit to ground
0x244193E6 93E6 Signal lamp,airbag deactivation:open circuit
0x244193E7 93E7 Undervoltage
0x244193E8 93E8 Control-unit fault
0x244193E9 93E9 Terminal 30:overvoltage
0x244193EA 93EA Indicator lamp,airbag deactivation:short circuit to positive
0x244193EB 93EB Control-unit fault
0x244193EC 93EC Control-unit fault
0x244193ED 93ED Control-unit fault
0x244193EE 93EE Control-unit fault
0x244193EF 93EF Communication fault to satellite,passenger airbag
0x244193F0 93F0 Fault during activation and deactivation of passenger airbag
0x244193F1 93F1 Driver's airbag coded out instead of passenger airbag
0x244193F2 93F2 Key-operated switch,passenger airbag:status change during driving
0x244193F3 93F3 Key switch,passenger airbag:coding data fault
0x244193F4 93F4 Control-unit fault
0x244193F5 93F5 Coding-data error
0x244193FF 93FF Front sensor,left:wrong component
0x24419400 9400 Front sensor,right:wrong component
0x24419401 9401 Control-unit fault
0x24419402 9402 Front sensor,left
0x24419403 9403 Front sensor,right
//SMB
0x25210009 09 Hall sensor, seat carriage, short circuit to ground
0x2521000A 0A Hall sensor, seat carriage, open circuit
0x2521000B 0B Hall sensor, seat carriage, short circuit to positive
0x2521000C 0C Supply voltage, Hall sensors, short circuit to +ve
0x2521000D 0D Control-module fault, motor bridge faulty
//URS
0x26210001 1 Internal hardware fault
0x26210002 2 Malfunction warning lamp
0x26210003 3 Undervoltage
0x26210004 4 Short circuit between actuators 1 and 2
0x26210005 5 Actuator 1 (left)
0x26210006 6 Actuator 2 (right)
0x26210007 7 Number of triggerings greater than 200
0x26210008 8 Sensor for overturning (level gauge 1)
0x26210009 9 Sensor for overturning (level gauge 1)
0x2621000A 10 Sensor for overturning (level gauge 1)
0x2621000B 11 Sensor for overturning (level gauge 2)
0x2621000C 12 Sensor for overturning (level gauge 2)
0x2621000D 13 Sensor for overturning (level gauge 2)
0x2621000E 14 Sensor for overturning (g sensor)
//RDC
0x27210000 00 Control module
0x27210001 01 Control module
0x27210002 02 Control module
0x27210003 03 Control module
0x27210004 04 Control unit
0x27210005 05 Control module
0x27210006 06 Control module
0x27210007 07 Control module
0x27210008 08 Control module
0x27210009 09 Control module
0x2721000B 11 Control module
0x2721000C 12 Control module
0x2721000D 13 Control module
0x27210010 16 Control module
0x27210011 17 Control module
0x27210012 18 Control module
0x27210013 19 Control module
0x27210014 20 Control module
0x27210019 25 DWA output faulty
0x2721001A 26 RDC pushbutton
0x2721001B 27 RDC pushbutton
0x2721001C 28 RDC pushbutton
0x27210029 41 K-bus fault
0x2721002C 44 Battery, front left
0x2721002D 45 Sensor fault, front left
0x2721002E 46 Signal path, front left, not OK
0x2721002F 47 Battery, front right
0x27210030 48 Sensor fault, front right
0x27210031 49 Signal path, front right, not OK
0x27210032 50 Battery, rear left
0x27210033 51 Sensor fault, rear left
0x27210034 52 Signal path, rear left not OK
0x27210035 53 Battery, rear right
0x27210038 54 Sensor fault, rear right
0x27210037 55 Signal path, rear right, not OK
0x2721003B 59 Battery Less than 2.7 volts
0x2721003C 60 Sensor fault (pressure > 6.3 bar)
0x2721003D 61 Transmission channel faulty
0x27210068 10 Aerial, front left
0x27210069 10 Aerial, front right
0x2721006A 10 Aerial, rear left
0x2721006B 10 Aerial, rear right
0x27210073 11 Wheel allocation not possible
0x27210080 12 Terminal 30
0x27210081 12 Terminal 15/K bus
0x27210082 13 Terminal 15/K bus
0x27220001 01 Control unit fault(ROM error)
0x27220002 02 Control unit fault(RAM error)
0x27220003 03 Control unit fault(EEPROM error)
0x27220004 04 Control unit fault(system error)
0x27220005 05 Control unit fault(system error)
0x27220006 06 RPA button,short circuit to ground(plausibility)
0x27220007 07 Speed pulses FL
0x27220008 08 Speed pulses FR
0x27220009 09 Speed pulses RL
0x2722000A 0A Speed pulses RR
0x2722000B 0B K bus(60s no reception with KL15)
0x2722000C 0C Control unit fault(EEPROM error)
0x2761604C 604C Terminal fault
0x2761604D 604D Fault, control unit
0x2761604E 604E Fault, RDC system
0x2761604F 604F Fault, transmission channel FL
0x27616050 6050 Fault, transmission channel FR
0x27616051 6051 Fault, transmission channel RL
0x27616052 6052 Fault, transmission channel RR
0x27616053 6053 Fault, transmission channel SW
0x27616054 6054 Fault, wheel sensor FL
0x27616055 6055 Fault, wheel sensor FR
0x27616056 6056 Fault, wheel sensor RL
0x27616057 6057 Fault, wheel sensor RR
0x27616058 6058 Fault, wheel sensor SW
0x27616059 6059 Fault, wheel sensor undefined
//VNC
0x29210005 01 Valve 1 (retarded adjustment)
0x29210006 02 CAN BUS
0x2921000D 06 Sensor 1 (outlet shaft)
0x2921000F 08 Checksum
0x29210011 09 Valve 2 (advanced adjustment)
0x29210013 14 Sensor 2 (inlet shaft)
//DWA
0x2B619CE8 9CE8 Control-unit fault
0x2B619CE9 9CE9 Control-unit fault
0x2B619CEA 9CEA Control-unit fault
0x2B619CEB 9CEB Control-unit fault / Transport mode active
0x2B619CEC 9CEC Ultrasonic sensor
0x2B619CF9 9CF9 DWA-LED
0x2B619D00 9D00 Communication fault with siren / DWA BUS
0x2B619D01 9D01 Microwave senor, incorrect version
0x2B619D0C 9D0C DWA-data bus
0x2B619D12 9D12 Internal battery discharged
0x2B619D14 9D14 Circuit, protective device, faulty
0x2B619D15 9D15 Wakeup circuit faulty
0x2B619D16 9D16 Circuit, warning signal, faulty
0x2B619D17 9D17 Maxmum operating temperature reached
0x2B619D18 9D18 Coding-data error
0x2B619D19 9D19 Coding-data error
0x2B619D1A 9D1A Coding-data error
0x2B619D1B 9D1B Coding-data error
0x2B619D1C 9D1C Min. operating temperature reached
0x2B619D1D 9D1D Coding-data error
0x2B619D1F 9D1F Tilt sensor faulty
//GAS
0x2E810001 01 Failure of all four wheel speeds
0x2E810002 02 Wheel-speed signal, front left
0x2E810003 03 Wheel-speed signal, front right
0x2E810004 04 Wheel-speed signal, rear left
0x2E810005 05 Wheel-speed signal, rear right
0x2E810006 06 Brake signal faulty
0x2E810007 07 Fault, throttle-valve signal
0x2E810008 08 Fault, engine speed
0x2E81000A 10 Fault in hydraulics self-test while driving
0x2E81000B 11 Fault, safety relay
0x2E810010 16 Control-unit fault
0x2E810011 17 Coding data absent
0x2E810013 19 No pressure reduction during hydraulics self-test while driving
0x2E810014 20 Electrical fault, pressure build-up valve
0x2E810015 21 Electrical fault, pressure-reduction valve
0x2E810016 22 Electrical fault, central-differential lock
//CAS
0x3161A0A8 A0A8 Control module fault
0x3161A0A9 A0A9 Control module fault
0x3161A0AA A0AA Control module fault
0x3161A0AB A0AB Programming error
0x3161A0AC A0AC Control module fault
0x3161A0AD A0AD Processor
0x3161A0AE A0AE Transport mode active
0x3161A0AF A0AF Control-module fault
0x3161A0B0 A0B0 Input, brake lights, implausible
0x3161A0B1 A0B1 Input, selector lever/clutch switch, implausible
0x3161A0B3 A0B3 Starter motor, terminal 50
0x3161A0B4 A0B4 Engine starting, starter motor operation
0x3161A0B4 A0B4 Engine start,starter operation
0x3161A0B5 A0B5 Fault, road speed signal
0x3161A0B6 A0B6 Selector-lever interlock
0x3161A0B8 A0B8 Hall sensor, key engaged
0x3161A0B9 A0B9 Hall sensor, key eject
0x3161A0BA A0BA Hall sensor, start/stop button
0x3161A0BB A0BB Hall sensor, start/stop button
0x3161A0BC A0BC Identification sensor, solenoid
0x3161A0BD A0BD Output, wakeup line PT-CAN
0x3161A0BE A0BE Terminal 15 output 1
0x3161A0BF A0BF Terminal 15 output 2
0x3161A0C0 A0C0 Terminal 15 output 3
0x3161A0C1 A0C1 Output, terminal 50
0x3161A0C2 A0C2 Output, terminal 50 RS
0x3161A0C3 A0C3 Output, wakeup line ACC
0x3161A0C4 A0C4 Terminal 15 output 4
0x3161A0C6 A0C6 Terminal R
0x3161A0C7 A0C7 Terminal R
0x3161A0C8 A0C8 Lock cylinder, driver's door
0x3161A0CC A0CC Continuous signal, remote control
0x3161A0CF A0CF Outside door handle
0x3161A0F0 A0F0 Transponder coil
0x3161A0F1 A0F1 Key number invalid
0x3161A0F2 A0F2 Incorrect duplicate key
0x3161A100 A100 Immobilizer random code
0x3161A110 A110 Roadspeed signal implausible
0x3161A111 A111 Control-module fault
0x3161A112 A112 ELV fault
0x3161A113 A113 ELV fault
0x3161A114 A114 Line fault, el.steering lock
0x3161A115 A115 Line fault, el.steering lock
0x3161A116 A116 Critical status, el.steering lock
0x3161A117 A117 Programming error, CAS
0x3161A118 A118 Roadspeed signal implausible
0x3161A119 A119 Power supply el.steering lock
0x3161A11A A11A ELV fault
0x3161A120 A120 Terminal 30g short circuit
0x3161A121 A121 Short circuit, LED START - STOP button
0x3161A124 A124 Terminal Control
0x3162A0A8 A0A8 Control module fault
0x3162A0A9 A0A9 Control module fault
0x3162A0AA A0AA Control module fault
0x3162A0AB A0AB Programming error
0x3162A0AC A0AC Control module fault
0x3162A0AD A0AD Control module fault
0x3162A0AE A0AE Transport mode active
0x3162A0AF A0AF Control-module fault
0x3162A0B1 A0B1 Input, selector lever/clutch switch, implausible
0x3162A0B4 A0B4 Engine starting, starter motor operation
0x3162A0B5 A0B5 Wheel speed sensor
0x3162A0B9 A0B9 Hall sensor, key eject
0x3162A0BA A0BA Hall sensor, start/stop button
0x3162A0BB A0BB Hall sensor, start/stop button
0x3162A0BC A0BC Ignition lock, solenoid
0x3162A0BD A0BD Output, wakeup line PT-CAN
0x3162A0BE A0BE Terminal 15 output 1
0x3162A0BF A0BF Terminal 15 output 2
0x3162A0C0 A0C0 Terminal 15 output 3
0x3162A0C1 A0C1 Output, terminal 50, short-circuit
0x3162A0C2 A0C2 Output, terminal 50
0x3162A0C3 A0C3 Output, wakeup line ACC
0x3162A0C4 A0C4 Terminal 15 output 4
0x3162A0C8 A0C8 Lock cylinder, driver's door
0x3162A0CC A0CC Continuous signal, open window
0x3162A0CF A0CF Outside door handle
0x3162A0F0 A0F0 Transponder coil
0x3162A0F1 A0F1 Immobilizer key data
0x3162A0F2 A0F2 Incorrect duplicate key
0x3162A100 A100 Immobilizer random code
0x3162A110 A110 Control-module fault
0x3162A111 A111 Control-module fault
0x3162A112 A112 ELV fault
0x3162A113 A113 ELV fault
0x3162A114 A114 ELV fault
0x3162A115 A115 ELV fault
0x3162A116 A116 ELV fault
0x3162A117 A117 ELV fault
0x3162A119 A119 ELV fault
0x3162A11A A11A ELV fault
0x3162A11B A11B ELV fault
0x3162A120 A120 Terminal 30g short circuit
0x3162A121 A121 Fault LED START - STOP button
0x3162A122 A122 Short circuit Hall sensors
0x3162D905 D905 Spare
0x3162D906 D906 Spare
0x3162D940 D940 Spare
0x3162D941 D941 Spare
0x3162D942 D942 Spare
0x3163A0A8 A0A8 Control-unit fault
0x3163A0AA A0AA Control-unit fault
0x3163A0AB A0AB Programming error
0x3163A0AC A0AC Control-unit fault
0x3163A0AD A0AD Control-unit fault
0x3163A0B0 A0B0 Input, brake lights, implausible
0x3163A0B1 A0B1 Input, selector lever, implausible
0x3163A0B2 A0B2 Supply, terminal 30E
0x3163A0B3 A0B3 Starter motor, terminal 50
0x3163A0B4 A0B4 Engine starting, starter-motor operation
0x3163A0B5 A0B5 Wheel-speed sensor
0x3163A0B8 A0B8 Hall sensor, key engaged
0x3163A0B9 A0B9 Hall sensor, key eject
0x3163A0BA A0BA Hall sensor, start/stop button
0x3163A0BB A0BB Hall sensor, start/stop button
0x3163A0BC A0BC Ignition lock, solenoid
0x3163A0BD A0BD Output, Wakeup line PT-CAN
0x3163A0BE A0BE Terminal 15 output 1
0x3163A0BF A0BF Terminal 15 output 2
0x3163A0C0 A0C0 Terminal 15 output 3
0x3163A0C1 A0C1 Output, terminal 50, short circuit
0x3163A0C2 A0C2 Output, terminal 50
0x3163A0C3 A0C3 Output, wakeup line ACC
0x3163A0C4 A0C4 Terminal 15 output 4
0x3163A0C8 A0C8 Lock cylinder, driver's door
0x3163A0CC A0CC Continuous signal, open window
0x3163A0CF A0CF Outside door handle
0x3163A0E0 A0E0 Signal or value above threshold
0x3163A0E7 A0E7 Signal or value above threshold
0x3163A0F0 A0F0 Transponder coil
0x3163A0F1 A0F1 Immobiliser key data
0x3163A0F2 A0F2 Incorrect duplicate key
0x3163A0F3 A0F3 Immobiliser key data
0x3163A100 A100 Immobiliser random code
//ARS ÎÞ¹ÊÕÏÂë¿â
//cim
0x38615D2C 5D2C KL30
0x38615D2D 5D2D ECU internal
0x38615D2F 5D2F MLSL+
0x38615D30 5D30 MLSL-
0x38615D31 5D31 MLSN+
0x38615D32 5D32 MLSN-
0x38615D35 5D35 Hall sensor, longitudinal
0x38615D36 5D36 Hall sensor, inclination
0x38615D38 5D38 Position data, steering column
0x38615D39 5D39 EEPROM fault
//EDC
0x3A615FCC 5FCC Signal, acceleration, front left, too low
0x3A615FCD 5FCD Signal, acceleration, front left, too high
0x3A615FCE 5FCE Signal, acceleration, front left, implausible
0x3A615FD0 5FD0 Signal, acceleration, front right, too low
0x3A615FD1 5FD1 Signal, acceleration, front right, too high
0x3A615FD2 5FD2 Signal, acceleration, front right, implausible
0x3A615FD4 5FD4 Signal, acceleration, rear right, too low
0x3A615FD5 5FD5 Signal, acceleration, rear right, too high
0x3A615FD6 5FD6 Signal, acceleration, rear right, implausible
0x3A615FD8 5FD8 Signal, acceleration, implausible
0x3A615FE1 5FE1 Steering angle, correction value exceeded
0x3A615FE4 5FE4 Shock-absorber valves, front axle, over current
0x3A615FE5 5FE5 Shock-absorber valves, rear axle, over current
0x3A615FE6 5FE6 Shock-absorber valves, front axle
0x3A615FE7 5FE7 Shock-absorber valves, rear axle
0x3A615FE8 5FE8 Shock-absorber valves, front axle, short circuit
0x3A615FE9 5FE9 Shock-absorber valves, rear axle, shot circuit
0x3A615FF0 5FF0 CAN message (Vehicle speed) from DSC
0x3A615FF1 5FF1 Wheel speed, front left
0x3A615FF2 5FF2 Wheel speed, front right
0x3A615FF3 5FF3 CAN message (wheel speed, front left) from DSC
0x3A615FF4 5FF4 CAN message (wheel speed, front right) from DSC
0x3A615FF5 5FF5 CAN message (outside temperature) from instrument cluster
0x3A615FF6 5FF6 CAN message (mileage) from instrument cluster
0x3A615FF7 5FF7 CAN message (steering angle) from SZL
0x3A615FF8 5FF8 CAN message (vehicle speeds) from DSC
0x3A615FF9 5FF9 Coding-data error
0x3A615FFA 5FFA Supply voltage, acceleration senor
0x3A615FFB 5FFB Terminal voltage, Electronic Damper Control
0x3A615FFC 5FFC Supply voltage, Electronic Damper control
0x3A615FFD 5FFD Wakeup line, Electronic Damper Control
0x3A615FFE 5FFE Voltage, terminal EDC
//EMF
//AHL
0x3E61A588 A588 Internal fault AHL
0x3E61A589 A589 Communication with stepper motor box 1 impaired
0x3E61A58A A58A Communication with stepper motor box 2 impaired
0x3E61A58B A58B Sensor,ride level,front,faulty
0x3E61A58C A58C Ride-level sensor,rear,faulty
0x3E61A58D A58D Brake-light switch faulty
0x3E61A58E A58E Energy,saving mode on
0x3E61A58F A58F Fault,WAKE-UP line
0x3E61A590 A590 SMC left faulty
0x3E61A591 A591 SMC right faulty
//KHI
//AMP
0x4061A1A9 A1A9 Overload, output stages
0x4061D6D0 D6D0 Ring-break diagnosis has been carried out
0x4061D6D2 D6D2 Deactivation, high temperature
0x4061D6D4 D6D4 Control module fault
0x4061D6D5 D6D5 Control module fault
//SGFD
//SGFDGW
//CD
0x4461A048 A048 Fault memory test, control display, computer
//CCC-BO
0x4462A048 A048 Fault memory test, control display, computer
//M-ASK-BO
0x4463ABC9 ABC9 Drive faulty
0x4463ABCA ABCA aerial power supply
0x4463ABCB ABCB Connection, Top hi-fi
//RAD
//RAD2-BO
0x4465ABC8 ABC8 Drive faulty
0x4465ABCC ABCC Short circuit at antenna power supply
0x4465ABCE ABCE Flash memory fault
0x4465ABCF ABCF Memory fault
0x4465ABD0 ABD0 Control-module fault
0x4465ABD1 ABD1 No connection to antenna
0x4465ABD2 ABD2 Incorrect antenna
0x4465ABD3 ABD3 Antenna-diversity fault
//CDGW
0x4561E192 E192 Deactivation, overtemperature
//M-ASK-GW
0x4562A168 A168 Hardware faulty
0x4562A169 A169 Hardware fault LCD
0x4562A16A A16A Checksum error, gateway table
0x4562A16B A16B Transport mode active
0x4562E192 E192 Deactivation, high temperature
//CCC-GW
0x4563A179 A179 Control-unit fault or over-/undervoltage
0x4563A168 A168 Control-unit fault
0x4563A169 A169 Control-unit fault
0x4563A16A A16A Control-unit fault or voltage supply
0x4563A16B A16B Control-unit fault
0x4563A16D A16D Temperature outside permitted range
0x4563A170 A170 RAD_ON Signal: setpoint/actual value does not correspond
0x4563A171 A171 Control-unit fault
0x4563A172 A172 Control-unit fault
0x4563A174 A174 Control-unit fault
0x4563A175 A175 Control-unit fault
0x4563A176 A176 Control-unit fault
0x4563A178 A178 Temperature too high
0x4563A17B A17B Battery voltage over 14V
0x4563A187 A187 Transport mode active
0x4563E192 E192 Deactivation, Overtemperature
//RAD2-GW
0x4564E192 E192 Deactivation, overtemperature
//FD
0x4861A489 A489 Control-unit fault
//CDC
0x49619D28 9D28 Changer mechanism, load CD
0x49619D29 9D29 Changer mechanism, unload CD
0x49619D2B 9D2B Changer mechanism, magazine ejection
0x4961D810 D810 No code descriptions
0x4961D812 D812 Deactivation, high temperature
//CON
0x4A61A2C8 A2C8 Internal control-unit fault
0x4A61A2CB A2CB Internal control-unit fault
0x4A61A2CC A2CC Transport mode active
//FCON
0x4B61E307 E307 K-CAN Communication fault
//HKL
0x5061A2B3 A2B3 Angle-of-rotation sensor
//DVDC
//RSL
0x5B61A128 A128 Hardware,rain sensor
0x5B61A129 A129 No adaptation to windscreen
0x5B61A12A A12A Overtemperature
0x5B61A12B A12B Overvoltage/undervoltage
0x5B61A12D A12D Overvoltage/undervoltage
0x5B61A12E A12E Calibration error,light sensor
0x5B61A128 A128 Hardware, rain sensor
0x5B61A129 A129 No adaptation to windshield
0x5B61A12A A12A High temperature
0x5B61A12B A12B Overvoltage / undervoltage
0x5B61A12D A12D Hardware, light sensor
0x5B61A12E A12E Calibration error, light sensor
0x5B62A148 A148 Control module fault
0x5B62A149 A149 Input term. 15 waking
0x5B62A14A A14A Battery switch
0x5B62A14B A14B Eccentric contact
0x5B62A14C A14C Battery temperature sensor
0x5B62A14D A14D Driver Term. 30
0x5B62A14E A14E Driver, rear window defroster
0x5B62A14F A14F Driver, interior lighting
0x5B62A150 A150 Driver Term. 15
0x5B62A151 A151 Driver Term. R
0x5B62A152 A152 Driver, electrical load, roof
0x5B62A153 A153 Driver, electrical load, body
0x5B62A154 A154 Fuel filler flap motor
0x5B62A155 A155 Trunk motor
0x5B62A156 A156 Trunk contact
0x5B62A157 A157 SCA motor
0x5B62A158 A158 Battery disconnection (closed-circuit current)
0x5B62A159 A159 Battery disconnection (lmax)
0x5B62A15A A15A Battery disconnection (short circuit)
0x5B62A15B A15B Driver, light module
0x5B62A15C A15C Transport mode active
0x5B62A15D A15D Battery, exhaustive discharge
0x5B62A15E A15E Light module
0x5B62A15F A15F Exhibition mode
0x5B62A160 A160 Multi-fuses
//SASL
0x5C619557 9557 Open circuit, firing circuit, knee airbag, front left
0x5C61952C 952C System time fault
0x5C619542 9542 Self-test: too few messages
0x5C61954C 954C Open circuit, firing circuit, head airbag, left
//SASR
0x5D6195D7 95D7 Open circuit, firing circuit, knee airbag, front right
0x5D6195AC 95AC System time fault
//SFZ
0x60619AAC 9AAC System time fault
0x60619AC2 9AC2 Self-test: too few messages
0x60619AA8 9AA8 Processor: reset
0x60619AA9 9AA9 Control-module fault
0x60619AAA 9AAA Control-module fault
0x60619AAB 9AAB Incorrect chassis number
0x60619AAD 9AAD Spare
0x60619AAE 9AAE Spare
0x60619AAF 9AAF Spare
0x60619AB0 9AB0 Spare
0x60619AB1 9AB1 Spare
0x60619AB2 9AB2 Spare
0x60619AB3 9AB3 Spare
0x60619AB4 9AB4 Spare
0x60619AB5 9AB5 Spare
0x60619AB6 9AB6 Spare
0x60619AB7 9AB7 Spare
0x60619AB9 9AB9 Spare
0x60619ABA 9ABA Spare
0x60619ABB 9ABB Spare
0x60619ABC 9ABC Spare
0x60619ABD 9ABD Spare
0x60619ABE 9ABE Spare
0x60619AC1 9AC1 Control-module fault
0x60619AC3 9AC3 Self-test: data error in message
0x60619AC4 9AC4 Self-test: transmission error
0x60619AC5 9AC5 Implausible crash severity
0x60619AC6 9AC6 Control-module fault
0x60619AC7 9AC7 Control-module fault
0x60619AC8 9AC8 Control-module fault
0x60619AC9 9AC9 Control-module fault
0x60619ACA 9ACA Control-module fault
0x60619ACB 9ACB Control-module fault
0x60619ACC 9ACC Control-module fault
0x60619ACD 9ACD Control-module fault
//SSBF
0x616197AC 97AC System time fault
0x616197C2 97C2 Self-test: too few messages
0x616197CC 97CC Open circuit, firing circuit, passenger belt tensioner
0x616197D7 97D7 Open circuit, firing circuit, passenger active head restraint
0x616197DD 97DD Seatbelt-catch switch, front passenger: open circuit
0x616197DF 97DF Seat occupancy detector, passenger: communication fault
0x616197FF 97FF Communication fault, seat-occupancy detector, passenger
0x616197A8 97A8 Processor: reset
0x616197A9 97A9 Control-module fault
0x616197AA 97AA Control-module fault
0x616197AB 97AB Incorrect chassis number
0x616197AD 97AD Spare
0x616197AE 97AE Spare
0x616197AF 97AF Spare
0x616197B0 97B0 Spare
0x616197B2 97B2 Spare
0x616197B4 97B4 Spare
0x616197B5 97B5 Spare
0x616197B6 97B6 Spare
0x616197B8 97B8 Spare
0x616197BA 97BA Spare
0x616197BB 97BB Spare
0x616197BD 97BD Spare
0x616197BE 97BE Spare
0x616197C0 97C0 Coding/data error
0x616197C1 97C1 Control-module fault
0x616197C3 97C3 Self-test: data error in message
0x616197C4 97C4 Self-test: transmission error
0x616197C5 97C5 Implausible crash severity
0x616197C6 97C6 Control-module fault
0x616197C7 97C7 Short-circuit, firing circuit, passenger seat belt tensioner, to ground
0x616197C8 97C8 Short-circuit, firing circuit, passenger seat belt tensioner, to positive
0x616197C9 97C9 Resistance, firing circuit, seat belt tensioner, front passenger, too low
0x616197CA 97CA Resistance, firing circuit, seat belt tensioner, front passenger, too high
0x616197CB 97CB Resistance, firing circuit, seat belt tensioner, front passenger, can not be measured
0x616197CC 97CC Open circuit, firing circuitm passenger seat belt tensioner
0x616197CD 97CD Control-module fault
0x616197CE 97CE Control-module fault
0x616197CF 97CF Coding, firing circuit, seat belt tensioner, front passenger, at variance
0x616197D0 97D0 Control-module fault
0x616197D1 97D1 Control-module fault
0x616197D2 97D2 Short-circuit, firing circuit, passenger active head restraint, to ground
0x616197D3 97D3 Short-circuit, firing circuit, passenger active head restraint, to positive
0x616197D4 97D4 Resistance, firing circuit, active head restraint, front passenger, too low
0x616197D5 97D5 Resistance, firing circuit, active head restraint, front passenger, too high
0x616197D6 97D6 Resistance, firing circuit, active head restraint, front passenger, can not be measured
0x616197D8 97D8 Control-module fault
0x616197D9 97D9 Control-module fault
0x616198DA 98DA Coding, firing circuit, active head restraint, front passenger, at variance
0x616197DB 97DB Control-module fault
0x616197DC 97DC Seat-belt buckle switch, passenger, short circuit
0x616197DD 97DD Seat-belt buckle switch, passenger, open circuit
0x616197DE 97DE Control-module fault
0x616197FD 97FD Open circuit, seat occupancy detector, passenger
0x616197FE 97FE Short-circuit, seat occupancy detector, passenger
0x616197FF 97FF Communication fault, seat occupancy detector, passenger
0x616197E0 97E0 seat occupancy detector, passenger:faulty
//SSFA
0x62619763 9763 Open circuit, seat-occupancy detector, driver
0x62619728 9728 Processor: reset
0x62619729 9729 Control-module fault
0x6261972A 972A Control-module fault
0x6261972B 972B Incorrect chassis number
0x6261972C 972C System time fault
0x6261972D 972D Spare
0x6261972E 972E Spare
0x6261972F 972F Spare
0x62619730 9730 Spare
0x62619732 9732 Spare
0x62619724 9724 Spare
0x62619735 9735 Spare
0x62619736 9736 Spare
0x62619738 9738 Spare
0x6261973A 973A Spare
0x6261973B 973B Spare
0x6261973C 973C Spare
0x6261973E 973E Spare
0x62619740 9740 Coding/data error
0x62619741 9741 Control-module fault
0x62619742 9742 Self-test: too few message
0x62619743 9743 Self-test: data error in message
0x62619744 9744 Self test: transmission error
0x62619745 9745 Implausible crash severity
0x62619747 9747 Control-mocule fault
0x62619747 9747 Short-circuit, firing circuit, driver's seat belt tensioner, to ground
0x62619748 9748 Short-circuit, firing circuit, driver's seat belt tensioner, to positive
0x62619749 9749 Resistance, firing circuit, seat belt tensioner, driver, too low
0x6261974A 974A Resistance, firing circuit, seat belt tensioner, driver, too high
0x6261974B 974B Resistance, firing circuit, seat belt tensioner, driver, can not be measured
0x6261974C 974C Open circuit, firing circuit, driver's seat belt tensioner
0x6261974D 974D Control-module fault
0x6261974E 974E Control-module fault
0x6261974F 974F Coding, firing circuit, seat belt tensioner, driver, at variance
0x62619750 9750 Control-module fault
0x62619751 9751 Control-module fault
0x62619752 9752 Short-circuit, firing circuit, driver's active head restraint, to ground
0x62619753 9753 Short-circuit, firing circuit, driver's active head restraint, to positive
0x62619754 9754 Resistance, firing circuit, active head restraint, driver, too low
0x62619755 9755 Resistance, firing circuit, active head restraint, driver, too high
0x62619756 9756 Resistance, firing circuit, active head restraint, can not be measured
0x62619757 9757 Open circuit, firing circuit, driver's active head restraint
0x62619758 9758 Control-module fault
0x62619759 9759 Control-module fault
0x6261975A 975A Coding, firing circuit, active head restaint, driver, at variance
0x6261975B 975B Control-module fault
0x6261975C 975C Seat-belt buckle switch, driver, short circuit
0x6261975D 975D Seat-belt buckle switch, driver, open circuit
0x6261975E 975E Control-module fault
0x62619763 9763 Open circuit, seat occupancy detector, driver
0x62619764 9764 Short-circuit, seat occupancy detector, driver
0x62619765 9765 Communication fault, seat occupancy detector, driver
0x62619766 9766 Control-module fault
0x62619767 9767 Control-module fault
0x62619768 9768 Firing attempt taken place
0x62619769 9769 Control-module fault
0x6261976A 976A Control-module fault
0x6261976B 976B Control-module fault
0x6261976C 976C Control-module fault
0x6261976D 976D Control-module fault
0x6261976E 976E Control-module fault
//SSH
0x63619A2C 9A2C System time fault
0x63619A4C 9A4C Open circuit, firing circuit, thorax airbag, rear right
0x63619A57 9A57 Open circuit, firing circuit, belt tensioner, rear right
0x63619A62 9A62 Open circuit, firing circuit, belt tensioner, rear left
0x63619A6D 9A6D Open circuit, firing circuit, thorax airbag, rear left
0x63619A81 9A81 Communication fault, seat-occupancy detector, rear left
0x63619A84 9A84 Communication fault, seat-occupancy detector, rear right
0x63619A28 9A28 Processor:reset
0x63619A29 9A29 Control-unit fault
0x63619A2a 9A2a Control-unit fault
0x63619A2B 9A2B Incorrect chassis number
0x63619A40 9A40 Coding-data error
0x63619A41 9A41 Control-unit fault
0x63619A42 9A42 Self-test:too few messages
0x63619A43 9A43 Self-test:data error in message
0x63619A44 9A44 Self-test:transmission error
0x63619A45 9A45 Implausible crash severity
0x63619A46 9A46 Control-unit fault
0x63619A47 9A47 Short citcuit,firing circuit,thorax airbag,rear right,to ground
0x63619A48 9A48 Short citcuit,firing circuit,thorax airbag,rear right,to positive
0x63619A49 9A49 Resistance,firing circuit,thorax airbag,rear right,too low
0x63619A4A 9A4A Resistance,firing circuit,thorax airbag,rear right,too high
0x63619A4B 9A4B Resistance,firing circuit,thorax airbag,rear right,cannot be measured
0x63619A4C 9A4C Open citcuit,firing circuit,thorax airbag,rear right
0x63619A4D 9A4D Control-unit fault
0x63619A4E 9A4E Control-unit fault
0x63619A4F 9A4F Coding,firing circuit,thorax airbag,rear right,at variance
0x63619A50 9A50 Control-unit fault
0x63619A51 9A51 Control-unit fault
0x63619A52 9A52 Short circuit,firing circuit,belt tensioner,rear right,to ground
0x63619A53 9A53 Short circuit,firing circuit,belt tensioner,rear right,to positive
0x63619A54 9A54 Resistance,firing circuit,belt tensioner,rear right,too low
0x63619A55 9A55 Resistance,firing circuit,belt tensioner,rear right,too high
0x63619A56 9A56 Resistance,firing circuit,belt tensioner,rear right,cannot be measured
0x63619A57 9A57 Open citcuit,firing circuit,belt tensioner,rear right
0x63619A58 9A58 Control-unit fault
0x63619A59 9A59 Control-unit fault
0x63619A5A 9A5A Coding,firing circuit,belt tensioner,rear right,at variance
0x63619A5B 9A5B Control-unit fault
0x63619A5C 9A5C Control-unit fault
0x63619A5D 9A5D Short circuit,firing circuit,belt tensioner,rear left,to ground
0x63619A5E 9A5E Short circuit,firing circuit,belt tensioner,rear left,to positive
0x63619A5F 9A5F Resistance,firing circuit,belt tensioner,rear left,too low
0x63619A60 9A60 Resistance,firing circuit,belt tensioner,rear left,too high
0x63619A61 9A61 Resistance,firing circuit,belt tensioner,rear left,cannot be measured
0x63619A62 9A62 Open citcuit,firing circuit,belt tensioner,rear left
0x63619A63 9A63 Control-unit fault
0x63619A64 9A64 Control-unit fault
0x63619A65 9A65 Coding,firing circuit,belt tensioner,rear left,at variance
0x63619A66 9A66 Control-unit fault
0x63619A67 9A67 Control-unit fault
0x63619A68 9A68 Short citcuit,firing circuit,thorax airbag,rear left,to ground
0x63619A69 9A69 Short citcuit,firing circuit,thorax airbag,rear left,to positive
0x63619A6A 9A6A Resistance,firing circuit,thorax airbag,rear left,too low
0x63619A6B 9A6B Resistance,firing circuit,thorax airbag,rear left,too high
0x63619A6C 9A6C Resistance,firing circuit,thorax airbag,rear left,cannot be measured
0x63619A6D 9A6D Open citcuit,firing circuit,thorax airbag,rear left
0x63619A6E 9A6E Control-unit fault
0x63619A6F 9A6F Control-unit fault
0x63619A70 9A70 Coding,firing circuit,thorax airbag,rear left,at variance
0x63619A71 9A71 Control-unit fault
0x63619A72 9A72 Control-unit fault
0x63619A73 9A73 Overload,head-restraint adjustment,rear left
0x63619A74 9A74 Overload,head-restraint adjustment,rear right
0x63619A75 9A75 Open circuit,head-restraint adjustment,rear left
0x63619A76 9A76 Open circuit,head-restraint adjustment,rear right
0x63619A77 9A77 Belt-buckle switch,rear left:short circuit
0x63619A78 9A78 Belt-buckle switch,rear left:implausible measured value
0x63619A79 9A79 Belt-buckle switch,rear left:open circuit
0x63619A7A 9A7A Belt-buckle switch,rear right:short circuit
0x63619A7B 9A7B Belt-buckle switch,rear right:implausible measured value
0x63619A7C 9A7C Belt-buckle switch,rear right:open circuit
0x63619A7D 9A7D Communication fault,seat-occupancy detector,rear left
0x63619A7E 9A7E Communication fault,seat-occupancy detector,rear right
0x63619A7F 9A7F Open circuit,seat-occupancy detector,rear left
0x63619A80 9A80 Short circuit,seat-occupancy detector,rear left
0x63619A81 9A81 Communication fault,seat-occupancy detector,rear left
0x63619A82 9A82 Open circuit,seat-occupancy detector,rear right
0x63619A83 9A83 Short circuit,seat-occupancy detector,rear right
0x63619A84 9A84 Communication fault,seat-occupancy detector,rear right
0x63619A85 9A85 Control-unit fault
0x63619A86 9A86 Control-unit fault
0x63619A87 9A87 Firing attempt taken place
0x63619A88 9A88 Control-unit fault
//STVL
0x64619628 9628 Processor: reset
0x6461962C 962C System time fault
0x64619642 9642 Self-test: too few messages
0x6461964C 964C Open circuit, firing circuit, thorax airbag, front left
0x64619673 9673 Control-unit fault
0x64619629 9629 Control-unit fault
0x6461962A 962A Control-unit fault
0x6461962B 962B Incorrect chassis number
0x64619640 9640 Coding-data error
0x64619641 9641 Control-unit fault
0x64619642 9642 Self-test:too few messages
0x64619643 9643 Self-test:data error in message
0x64619644 9644 Self-test:transmission error
0x64619645 9645 Implausible crash severity
0x64619646 9646 Control-unit fault
0x64619647 9647 Short citcuit,firing circuit,thorax airbag,front left,to ground
0x64619648 9648 Short circuit,throrax airbag,front left,to positive
0x64619649 9649 Resistance,firing circuit,thorax airbag,front left,too low
0x6461964A 964A Resistance,firing circuit,thorax airbag,front left,too high
0x6461964B 964B Resistance,firing circuit,thorax airbag,front left,cannot be measured
0x6461964C 964C Open citcuit,firing circuit,thorax airbag,front left
0x6461964D 964D Control-unit fault
0x6461964E 964E Control-unit fault
0x6461964F 964F Coding,firing circuit,thorax airbag,front left,at variance
0x64619650 9650 Control-unit fault
0x6461965D 965D Control-unit fault
0x6461965E 965E Control-unit fault
0x6461965F 965F Control-unit fault
0x64619660 9660 Firing attempt taken place
0x64619661 9661 Control-unit fault
0x64619662 9662 Pressure sensor
0x64619663 9663 Control-unit fault
0x64619664 9664 Control-unit fault
0x64619665 9665 Control-unit fault
0x64619666 9666 Control-unit fault
0x64619667 9667 Control-unit fault
0x64619672 9672 Control-unit fault
0x64619674 9674 Control-unit fault
0x64619675 9675 Control-unit fault
0x64619676 9676 Control-unit fault
0x64619677 9677 Control-unit fault
0x64619678 9678 Control-unit fault
0x64619679 9679 Control-unit fault
0x6461967A 967A Control-unit fault
0x6461967B 967B Control-unit fault
0x6461967C 967C Voltage supply:limit value undershot
0x6461967D 967D Voltage supply:limit value exceeded
0x6461967E 967E Transport mode active
0x6461967F 967F Coding-data error
0x64619628 9628 Processor:reset
0x64629628 9628 Processor:reset
0x64629629 9629 Control-unit fault
0x6462962A 962A Control-unit fault
0x6462962B 962B Incorrect chassis number
0x6462962C 962C System time fault
0x64629640 9640 Coding-data error
0x64629642 9642 Self-test:too few messages
0x64629643 9643 Self-test:data error in message
0x64629644 9644 Self-test:transmission error
0x64629645 9645 Implausible crash severity
0x64629647 9647 Short circuit,firing circuit,thorax airbag,driver,to ground
0x64629648 9648 Short circuit,firing circuit,thorax airbag,driver,to positive
0x64629649 9649 Resistance,firing circuit,thorax airbag,driver,too low
0x6462964A 964A Resistance,firing circuit,thorax airbag,driver,too high
0x6462964B 964B Resistance,firing circuit,thorax airbag,driver,cannot be measured
0x6462964C 964C Open circuit,firing circuit,thorax airbag,driver
0x6462964D 964D Control-unit fault
0x6462964E 964E Control-unit fault
0x6462964F 964F Coding,firing circuit,thorax airbag,driver,at variance
0x64629650 9650 Control-unit fault
0x6462965D 965D Control-unit fault
0x6462965E 965E Control-unit fault
0x6462965F 965F Control-unit fault
0x64629660 9660 Firing attempt taken place
0x64629661 9661 Control-unit fault
0x64629662 9662 Pressure sensor
0x64629663 9663 Control-unit fault
0x64629664 9664 Control-unit fault
0x64629665 9665 Control-unit fault
0x64629666 9666 Control-unit fault
0x64629667 9667 Control-unit fault
0x64629672 9672 Control-unit fault
0x64629673 9673 Control-unit fault
0x64629674 9674 Control-unit fault
0x64629675 9675 Control-unit fault
0x64629676 9676 Control-unit fault
0x64629677 9677 Transport mode active
0x64629678 9678 Control-unit fault
0x64629679 9679 Control-unit fault
0x6462967A 967A Control-unit fault
0x6462967B 967B Control-unit fault
0x6462967C 967C Control-unit fault
0x6462967D 967D Voltage supply:limit value undershot
0x6462967E 967E Voltage supply:limit value exceeded
0x6462967F 967F Terminal 30
0x64629B48 9B48 Ambient lighting faulty
0x64629B49 9B49 Mirror, potentiometer, vertical
0x64629B4A 9B4A Mirror position, potentiometer, horizontal
0x64629B4B 9B4B Mirror position, potentiometer, supply
0x64629B4C 9B4C Courtesy lighting
0x64629B4D 9B4D Switch block, supply
0x64629B4E 9B4E Power window, supply, Hall sensors
0x64629B4F 9B4F Switch block, data transfer
0x64629B52 9B52 Power window, Hall sensor
0x64629B53 9B53 Power-window relay
0x64629B54 9B54 Power-window electronics
0x64629B55 9B55 Door mirror, motor, horizontal
0x64629B56 9B56 Door mirror, motor, vertical
0x64629B57 9B57 Drive, swivel door mirror
0x64629B58 9B58 Mirror, wiring fault
0x64629B59 9B59 Switch block, driver's door
0x64629B5A 9B5A Programming fault
0x64629B5B 9B5B Central-locking drive, locking
0x64629B5C 9B5C Central-locking drive, double
0x64629B5D 9B5D Central-locking drive, unlocking
0x64629B5E 9B5E Entrance lighting
//STVR
0x656196AC 96AC System time fault
0x656196C2 96C2 Self-test: too few messages
0x656196C9 96C9 Resistance, firing circuit, thorax airbag, front right, too low
0x656196CC 96CC Open circuit, firing circuit, thorax airbag, front right
0x656196FD 96FD Voltage supply: limit value exceeded
0x656196A8 96A8 Processor:reset
0x656196A9 96A9 Control-unit fault
0x656196AA 96AA Control-unit fault
0x656196AB 96AB Incorrect chassis number
0x656196C0 96C0 Coding-data error
0x656196C1 96C1 Control-unit fault
0x656196C2 96C2 Self-test:too few messages
0x656196C3 96C3 Self-test:data error in message
0x656196C4 96C4 Self-test:transmission error
0x656196C5 96C5 Implausible crash severity
0x656196C6 96C6 Control-unit fault
0x656196C7 96C7 Short citcuit,firing circuit,thorax airbag,front right,to ground
0x656196C8 96C8 Short circuit,throrax airbag,front right,to positive
0x656196C9 96C9 Resistance,firing circuit,thorax airbag,front right,too low
0x656196CA 96CA Resistance,firing circuit,thorax airbag,front right,too high
0x656196CB 96CB Resistance,firing circuit,thorax airbag,front right,cannot be measured
0x656196CC 96CC Open citcuit,firing circuit,thorax airbag,front right
0x656196CD 96CD Control-unit fault
0x656196CE 96CE Control-unit fault
0x656196CF 96CF Coding,firing circuit,thorax airbag,front right,at variance
0x656196D0 96D0 Control-unit fault
0x656196DD 96DD Control-unit fault
0x656196DE 96DE Control-unit fault
0x656196DF 96DF Control-unit fault
0x656196E0 96E0 Firing attempt taken place
0x656196E1 96E1 Control-unit fault
0x656196E2 96E2 Pressure sensor
0x656196E3 96E3 Control-unit fault
0x656196E4 96E4 Control-unit fault
0x656196E5 96E5 Control-unit fault
0x656196E6 96E6 Control-unit fault
0x656196E7 96E7 Control-unit fault
0x656196F2 96F2 Control-unit fault
0x656196F3 96F3 Control-unit fault
0x656196F4 96F4 Control-unit fault
0x656196F5 96F5 Control-unit fault
0x656196F6 96F6 Control-unit fault
0x656196F7 96F7 Control-unit fault
0x656196F8 96F8 Control-unit fault
0x656196F9 96F9 Control-unit fault
0x656196FA 96FA Control-unit fault
0x656196FB 96FB Control-unit fault
0x656196FC 96FC Voltage supply:limit value undershot
0x656196FD 96FD Voltage supply:limit value exceeded
0x656196FE 96FE Transport mode active
0x656196FF 96FF Coding-data error
0x656296A8 96A8 Processor:reset
0x656296A9 96A9 Control-unit fault
0x656296AA 96AA Control-unit fault
0x656296AB 96AB Incorrect chassis number
0x656296AC 96AC System time fault
0x656296C0 96C0 Coding-data error
0x656296C2 96C2 Self-test:too few messages
0x656296C3 96C3 Self-test:data error in message
0x656296C4 96C4 Self-test:transmission error
0x656296C5 96C5 Implausible crash severity
0x656296C6 96C6 Control-unit fault
0x656296C7 96C7 Short circuit,firing circuit,thorax airbag,passenger,to ground
0x656296C8 96C8 Short circuit,firing circuit,thorax airbag, passenger,to positive
0x656296C9 96C9 Resistance,firing circuit,thorax airbag, passenger,too low
0x656296CA 96CA Resistance,firing circuit,thorax airbag, passenger,too high
0x656296CB 96CB Resistance,firing circuit,thorax airbag, passenger,cannot be measured
0x656296CC 96CC Open circuit,firing circuit,thorax airbag, passenger
0x656296CD 96CD Control-unit fault
0x656296CE 96CE Control-unit fault
0x656296CF 96CF Coding,firing circuit,thorax airbag,passenger,at variance
0x656296D0 96D0 Control-unit fault
0x656296DD 96DD Control-unit fault
0x656296DE 96DE Control-unit fault
0x656296DF 96DF Control-unit fault
0x656296E0 96E0 Firing attempt taken place
0x656296E1 96E1 Control-unit fault
0x656296E2 96E2 Pressure sensor
0x656296E3 96E3 Control-unit fault
0x656296E4 96E4 Control-unit fault
0x656296E5 96E5 Control-unit fault
0x656296E6 96E6 Control-unit fault
0x656296E7 96E7 Control-unit fault
0x656296F2 96F2 Control-unit fault
0x656296F3 96F3 Control-unit fault
0x656296F4 96F4 Control-unit fault
0x656296F5 96F5 Control-unit fault
0x656296F6 96F6 Control-unit fault
0x656296F7 96F7 Transport mode active
0x656296F8 96F8 Control-unit fault
0x656296F9 96F9 Control-unit fault
0x656296FA 96FA Control-unit fault
0x656296FB 96FB Control-unit fault
0x656296FC 96FC Control-unit fault
0x656296FD 96FD Voltage supply:limit value undershot
0x656296FE 96FE Voltage supply:limit value exceeded
0x656296FF 96FF Terminal 30
0x65629B88 9B88 Ambient lighting
0x65629B89 9B89 Mirror position, potentiometer, horizontal
0x65629B8A 9B8A Mirror position, potentiometer, vertical
0x65629B8B 9B8B Mirror position, potentiometer, supply
0x65629B8C 9B8C Courtesy lighting
0x65629B8E 9B8E Power window, supply, hall sensors
0x65629B8F 9B8F Switch block, data transfer disturbed
0x65629B92 9B92 Power window, Hall sensor
0x65629B93 9B93 Power-window relay
0x65629B94 9B94 Power-window electronics
0x65629B95 9B95 Door mirror, horizontal
0x65629B96 9B96 Door mirror, vertical
0x65629B97 9B97 Drive, swivel door mirror
0x65629B98 9B98 Mirror, wiring fault
0x65629B9A 9B9A Programming fault
0x65629B9B 9B9B Central locking, locking
0x65629B9C 9B9C Central locking, double locking
0x65629B9D 9B9D Central locking, unlocking
0x65629B9E 9B9E Entrance lighting
//SINE
0x67619D1F 9D1F Emergency siren
0x67619D11 9D11 DWA-data bus
0x67619D12 9D12 Internal battery
0x67619D13 9D13 Emergency siren
0x67619D14 9D14 Emergency siren
0x67619D15 9D15 Emergency siren
0x67619D16 9D16 Emergency siren
0x67619D44 9D44 Alarm memory: voltage-supply tampering
0x67619D45 9D45 Alarm memory: overvoltage or DWA bus, short circuit to position
0x67619D46 9D46 Alarm memory: DWA bus, short circuit to ground
0x67619D47 9D47 Alarm memory: siren disconnected
0x67619D45 9D45 Alarm memory: overvoltage or DWA bus, short circuit to positive
//SMFA
0x68619E48 9E48 No Hall pulses, longitudinal seat adjustment
0x68619E49 9E49 No Hall pulses,seat-height adjustment
0x68619E4A 9E4A No Hall pulses,seat-back width adjustment
0x68619E4B 9E4B No Hall pulses,seat-back inclination adjustment
0x68619E4C 9E4C No Hall pulses,seat-inclination adjustment
0x68619E4D 9E4D No Hall pulses,head-restraint adjustment
0x68619E4E 9E4E No Hall pulses,seat-back head adjustment
0x68619E4F 9E4F No Hall pulses,seat-cushion adjustment
0x68619E50 9E50 Motor, longitudinal seat adjustment
0x68619E51 9E51 Motor, seat height adjustment
0x68619E52 9E52 Motor, seat back width adjustment
0x68619E53 9E53 Motor, seat back inclination adjustment
0x68619E54 9E54 Motor, seat inclination adjustment
0x68619E55 9E55 Motor, head restraint adjustment
0x68619E56 9E56 Motor, seat back head adjustment
0x68619E57 9E57 Motor, seat cushion adjustment
0x68619E58 9E58 Temperature sensor, rapid heating area, cushion
0x68619E59 9E59 Temperature sensor, rapid heating area, seat back
0x68619E5A 9E5A Temperature sensor, residual heating area, cushion
0x68619E5B 9E5B Temperature sensor, residual heating area, seat back
0x68619E5C 9E5C Rapid heating area,cushion
0x68619E5D 9E5D Rapid heating area, seat back
0x68619E5E 9E5E Residual heating area, cushion
0x68619E5F 9E5F Residual heating area, seat back
0x68619E60 9E60 Heating driver failed
0x68619E61 9E61 Seat ventilation supply, cushion and seat back
0x68619E62 9E62 Seat ventilation control, cushion
0x68619E63 9E63 Seat ventilation control, seat back
0x68619E64 9E64 Active seat, motor
0x68619E65 9E65 Active seat solenoid
0x68619E66 9E66 Active seat, pressure switch
0x68619E67 9E67 Lumbar valves
0x68619E68 9E68 Lumbar pump
0x68619E69 9E69 Internal fault, supply voltage U12s
0x68619E6A 9E6A Internal fault, supply voltage tm. 30s
0x68619E6B 9E6B Control-unit fault
//SMFB
0x69619EA8 9EA8 No Hall pulses, longitudinal seat adjustment
0x69619EA9 9EA9 No Hall pulses, seat-height adjustment
0x69619EAA 9EAA No Hall pulses, seat-back width adjustment
0x69619EAB 9EAB No Hall pulses, seat-back inclination adjustment
0x69619EAC 9EAC No Hall pulses, seat-inclination adjustment
0x69619EAD 9EAD No Hall pulses, head-restraint adjustment
0x69619EAE 9EAE No Hall pulses, seat-back head adjustment
0x69619EAF 9EAF No Hall pulses, seat-cushion adjustment
0x69619EB0 9EB0 Motor, longitudinal seat adjustment
0x69619EB1 9EB1 Motor, seat height adjustment
0x69619EB2 9EB2 Motor, seat back width adjustment
0x69619EB3 9EB3 Motor, seat back inclination adjustment
0x69619EB4 9EB4 Motor, seat inclination adjustment
0x69619EB5 9EB5 Motor, head restraint adjustment
0x69619EB6 9EB6 Motor, seat back head adjustment
0x69619EB7 9EB7 Motor, seat cushion adjustment
0x69619EB8 9EB8 Temperature sensor, rapid heating area, cushion
0x69619EB9 9EB9 Temperature sesnor, rapid heating area, seat back
0x69619EBA 9EBA Temperature sesnor, residual heating area, cushion
0x69619EBB 9EBB Temperature sensor, residual heating area, seat back
0x69619EBC 9EBC Rapid heating area, cushion
0x69619EBD 9EBD Rapid heating area, seat back
0x69619EBE 9EBE Residual heating area, cushion
0x69619EBF 9EBF Residual heating area, seat back
0x69619EC0 9EC0 Heating driver failed
0x69619EC1 9EC1 Seat ventilation supply, cushion and seat back
0x69619EC2 9EC2 Seat ventilation control, cushion
0x69619EC3 9EC3 Seat ventilation control, seat back
0x69619EC4 9EC4 Active seat, motor
0x69619EC5 9EC5 Active seat, solenoid
0x69619EC6 9EC6 Active seat, pressure switch
0x69619EC7 9EC7 Lumbar valves
0x69619EC8 9EC8 Lumbar pump
0x69619EC9 9EC9 Internal fault supply voltage U12s
0x69619ECA 9ECA Internal fault supply voltage Term. 30s
0x69619ECB 9ECB Control-unit fault
//SMFAH
0x6A619F08 9F08 No Hall pulses, longitudinal seat adjustment
0x6A619F0E 9F0E No Hall pulses, seat-back head adjustment
0x6A619F10 9F10 Motor, longitudinal seat adjustment
0x6A619F13 9F13 Motor, seat-back inclination adjustment
0x6A619F14 9F14 Motor, seat-inclination adjustment
0x6A619F15 9F15 Motor, head-restraint height adjustment
0x6A619F16 9F16 Motor, seat-back head adjustment
0x6A619F22 9F22 Seat ventilation, control, seat cushion
0x6A619F23 9F23 Seat ventilation, control, backrest
0x6A619F08 9F08 No Hall pulses,longitudinal seat adjustment
0x6A619F0B 9F0B No Hall pulses,seat-back inclination adjustment
0x6A619F0C 9F0C No Hall pulses,seat-inclination adjustment
0x6A619F0D 9F0D No Hall pulses,head-restraint height adjustment
0x6A619F0E 9F0E No Hall pulses,seat-back head adjustment
0x6A619F0F 9F0F No Hall pulses,seat-cushion adjustment
0x6A619F10 9F10 Motor,longitudinal seat adjustment
0x6A619F13 9F13 Motor,seat-back inclination adjustment
0x6A619F14 9F14 Motor,seat-inclination adjustment
0x6A619F17 9F17 Motor,seat-cushion adjustment
0x6A619F18 9F18 Temperature sensor,rapid heating field,seat cushion
0x6A619F19 9F19 Temperature sensor,rapid heating field,seat backrest
0x6A619F1A 9F1A Temperature sensor,residual heating field,seat cushion
0x6A619F1B 9F1B Temperature sensor,residual heating field,seat backrest
0x6A619F1C 9F1C Rapid heating field,seat cushion
0x6A619F1D 9F1D Rapid heating field,seat backrest
0x6A619F1E 9F1E Residual heating field,seat cushion
0x6A619F1F 9F1F Residual heating field,seat backrest
0x6A619F20 9F20 Heating driver failed
0x6A619F21 9F21 Seat-ventilation supply,cushion and seat back
0x6A619F22 9F22 Seat-ventilation,control,seat cushion
0x6A619F23 9F23 Seat ventilation,control,backrest
0x6A619F24 9F24 Active seat,motor
0x6A619F25 9F25 Active seat,solenoid
0x6A619F26 9F26 Active seat,pressure switch
0x6A619F27 9F27 Lumbar valves
0x6A619F28 9F28 Lumbar pump
0x6A619F29 9F29 Internal fault,supply voltage U12s
0x6A619F2A 9F2A Internal fault,supply voltage tm.30s
0x6A619F2B 9F2B Control-unit fault
//SMBFH
0x6B619F70 9F70 Motor, longitudinal seat adjustment
0x6B619F73 9F73 Motor, seat-back inclination adjustment
0x6B619F74 9F74 Motor, seat-inclination adjustment
0x6B619F75 9F75 Motor, head-restraint adjustment
0x6B619F82 9F82 Seat ventilation, control, seat cushion
0x6B619F83 9F83 Seat ventilation, control, backrest
0x6B619F85 9F85 Active seat, solenoid
//SHZH
//SVS
0x6D61D644 D644 Fault, self test SVS faulty
0x6D61D650 D650 Ring-break diagnosis has been carried out
0x6D61D652 D652 Deactivation, hgih temperature
//SZL
0x6E6194EE 94EE MFL button pad, left
0x6E6194EF 94EF MFL button pad, right
0x6E6194F9 94F9 Fanfare horn: woofer
0x6E619501 9501 Steering-angle sensor not adjusted
0x6E61951A 951A Undervoltage
0x6E61951D 951D Direction indicator/high-beam switch
0x6E61A849 A849 Steering-column switch, cruise control
0x6E6294AB 94AB Incorrect chassis number
0x6E6294C3 94C3 Self-test: too few messages
0x6E6294CA 94CA Resistance, firing circuit, driver's airbag, stage 1, too low
0x6E6294CD 94CD Open circuit, firing circuit, driver's airbag, stage 1
0x6E6294D3 94D3 Short circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6294D5 94D5 Resistance, firing circuit, driver's airbag, stage 2, too low
0x6E6294D8 94D8 Open circuit, firing circuit, driver's airbag, stage 2
0x6E6294E3 94E3 Terminal U_ISIS or U_SZL missing
0x6E6294E4 94E4 Steering-angle sensor, plausibility
0x6E6294E7 94E7 Steering-angle sensor, wiper contact
0x6E6294EA 94EA Communication between steering wheel module and steering column module faulty
0x6E629EF9 9EF9 Fault, fanfare horn
0x6E6294FD 94FD Steering-wheel electronics: fault in alarm path
0x6E629500 9500 Firing attempt taken place
0x6E629501 9501 Steering-angle-sensor adjustment
0x6E629504 9504 Control-unit fault
0x6E629518 9518 Voltage supply: limit value undershot
0x6E62951A 951A Voltage supply (LRE): limit value undershot
0x6E62951D 951D Coding-data error
0x6E6294A8 94A8 Processor: reset
0x6E6294A9 94A9 Control-module fault
0x6E6294AA 94AA Control-module fault
0x6E6294AC 94AC System time fault
0x6E6294AD 94AD Control-module fault
0x6E6294C1 94C1 Coding/data error
0x6E6294C2 94C2 Control-module fault
0x6E6294C4 94C4 Self-test: data error in messages
0x6E6294C5 94C5 Self-test: transmission error
0x6E6294C6 94C6 Implausible crash severity
0x6E6294C7 94C7 Steering-wheel electronics
0x6E6294C8 94C8 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6294C9 94C9 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6294CB 94CB Resistance, firing circuit, driver's airbag, stage 1, too high
0x6E6294CC 94CC Resistance, firing circuit, driver's airbag, stage 1, cannot be measured
0x6E6294CE 94CE Steering-wheel electronics
0x6E6294CF 94CF Steering-wheel electronics
0x6E6294D0 94D0 Coding, firing circuit, driver's airbag, stage 1, at variance
0x6E6294D1 94D1 Steering-wheel electronics
0x6E6294D2 94D2 Steering-wheel electronics
0x6E6294D3 94D3 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6294D4 94D4 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6294D6 94D6 Resistance, firing circuit, driver's airbag, stage 2, too high
0x6E6294D7 94D7 Resistance, firing circuit, driver's airbag, stage 2, cannot be measured
0x6E6294D9 94D9 Steering-wheel electronics
0x6E6294DA 94DA Steering-wheel electronics
0x6E6294DB 94DB Coding, firing circuit, driver's airbag, stage 2, at variance
0x6E6294DC 94DC Steering-wheel electronics
0x6E6294DD 94DD Fault in alarm path
0x6E6294DE 94DE Transmission selector switch: bus fault
0x6E6294DF 94DF Transmission selector switch: bus fault and serial line fault
0x6E6294E0 94E0 Transmission selector switch: parking button, contact, faulty
0x6E6294E1 94E1 No terminal 30
0x6E6294E4 94E4 Steering-angle sensor plausibility
0x6E6294E5 94E5 Control-module fault
0x6E6294E6 94E6 Control-module fault
0x6E6294E7 94E7 Control-module fault
0x6E6294E9 94E9 Steering-angle sensor, internal
0x6E6294EB 94EB Steering wheel electronics: version not compatible
0x6E6294EC 94EC Multifunction steering wheel, left: short/open circuit
0x6E6294ED 94ED Multifunction steering wheel, right: short/open circuit
0x6E6294EE 94EE Multifunction steering wheel, left: voltage value not defined
0x6E6294EF 94EF Multifunction steering wheel, right: voltage value not defined
0x6E6294F0 94F0 Steering wheel heating: heating mat, open circuit
0x6E6294F1 94F1 Steering wheel heating: heating mat, short-circuit to terminal 31
0x6E6294F2 94F2 Steering wheel heating: heating mat, short-circuit to terminal 30
0x6E6294F3 94F3 Steering wheel heating: timeout control
0x6E6294F4 94F4 Steering wheel heating: temperature sensor faulty
0x6E6294F5 94F5 Steering column adjustment switch: short-circuit to ground
0x6E6294F6 94F6 Steering column adjustment switch: open/short-circuit to positive
0x6E6294F7 94F7 Steering column adjustment switch: voltage value not defined
0x6E6294F8 94F8 Fault, horn
0x6E6294F9 94F9 Fault, horn
0x6E6294FA 94FA Steering-column-switch evaluation faulty (E65, E66, E67, RR01) or programming fault (E60, E61, E63, E64)
0x6E6294FB 94FB Control-module fault
0x6E6294FC 94FC Steering wheel electronics: no triggering readiness
0x6E6294FD 94FD Steering wheel electronics: fault in alarm path
0x6E6294FE 94FE Control-module fault
0x6E6294FF 94FF Control-module fault
0x6E629501 9501 Steering-angle-sensor calibration
0x6E629502 9502 Control-module fault
0x6E629503 9503 Control-module fault
0x6E629506 9506 Steering-wheel electronics
0x6E629507 9507 Steering-wheel electronics
0x6E629508 9508 Steering-wheel electronics
0x6E629509 9509 Steering-wheel electronics
0x6E62950A 950A Steering-wheel electronics
0x6E62950B 950B Transport mode active
0x6E629519 9519 Voltage supply: limit value exceeded
0x6E62951B 951B Voltage supply (LRE): limit value exceeded
0x6E62951D 951D Coding-data fault
0x6E6394A8 94A8 Processor: reset
0x6E6394A9 94A9 Control-unit fault
0x6E6394AA 94AA Control-unit fault
0x6E6394AB 94AB Incorrect chassis number
0x6E6394AC 94AC System time fault
0x6E6394AD 94AD Analog/digital converter faulty
0x6E6394AE 94AE No message (1) from satellite, door, front left
0x6E63949F 949F Signal or value below threshold
0x6E6394B0 94B0 No message (3) from satellite, door, front right
0x6E6394B1 94B1 Signal or value below threshold
0x6E6394B2 94B2 No message (5) from satellite, B-pillar, left
0x6E6394B3 94B3 No message (6) from satellite, A-pillar, left
0x6E6394B4 94B4 No message (7) from satellite, B-pillar, right
0x6E6394B5 94B5 No message (8) from satellite, A-pillar, right
0x6E6394B6 94B6 No message (9) from satellite, vehicle centre
0x6E6394B7 94B7 No message (A) from safety information module
0x6E6394B8 94B8 No message (B) from satellite, A-pillar, left
0x6E6394B9 94B9 No message © from satellite, A-pillar, right
0x6E6394BA 94BA No message (D) from satellite, vehicle centre
0x6E6394BB 94BB signal or value
0x6E6394BD 94BD No message (20) from satellite, seat, driver
0x6E6394BE 94BE No message (21) from satellite, seat, passenger
0x6E6394BF 94BF No message (22) from satellite, rear seat
0x6E6394C0 94C0 No message (71) from safety Information Module
0x6E6394C1 94C1 Coding-data error
0x6E6394C2 94C2 Control-unit fault
0x6E6394C3 94C3 Self-test too few messages
0x6E6394C4 94C4 Self-test data error in message
0x6E6394C5 94C5 Self-test transmission error
0x6E6394C6 94C6 Implausible crash severity
0x6E6394C7 94C7 Firing transistor, firing circuit, driver's airbag, stage 1,faulty
0x6E6394C8 94C8 Short circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6394C9 94C9 Short circuit, firing circuit, driver's airbag, stage 1, to positive
0x6E6394CA 94CA Resistance, firing pellet, firing circuit, driver's airbag, stage 1, too low
0x6E6394CB 94CB Resistance, firing pellet, firing circuit, driver's airbag, stage 1, too high
0x6E6394CC 94CC Resistance, firing pellet, firing circuit, driver's airbag, stage 1, can not be measured
0x6E6394CD 94CD Open circuit, firing circuit, driver's airbag, stage 1
0x6E6394CE 94CE Voltage, firing circuit, driver's airbag, stage 1, not OK
0x6E6394CF 94CF Firing capacitor, firing circuit, driver's airbag, stage 1, not OK
0x6E6394D0 94D0 Coding/configuration, firing circuit, driver's airbag, stage 1, at variance
0x6E6394D1 94D1 Open circuit, discharge circuit, firing circuit, driver's airbag, stage 1
0x6E6394D2 94D2 Firing transistor, firing circuit, driver's airbag, stage 2. faulty
0x6E6394D3 94D3 Short circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6394D4 94D4 Short circuit, firing circuit, driver's airbag, stage 2, to position
0x6E6394D5 94D5 Resistance, firing pellet, firing circuit, driver's airbag, stage 2, too low
0x6E6394D6 94D6 Resistance, firing pellet, firing circuit, driver's airbag, stage 2, too high
0x6E6394D7 94D7 Resistance, firing pellet, firing circuit, driver's airbag, stage 2, can not be measured
0x6E6394D8 94D8 Open circuit, firing circuit, driver's airbag, stage 2
0x6E6394D9 94D9 Voltage, firing circuit, driver's airbag, stage 2, not OK
0x6E6394DA 94DA Firing capacitor, firing circuit, driver's airbag, stage 2, not OK
0x6E6394DB 94DB Coding/configuration, firing circuit, driver's airbag, stage 2, at variance
0x6E6394DC 94DC Open circuit, discharge circuit, firing circuit, driver's airbag, stage 2
0x6E6394DD 94DD Fault in alarm path
0x6E6394DE 94DE Transmission selector switch: bus fault
0x6E6394DF 94DF Transmission selector switch: bus fault and serial-line fault
0x6E6394E0 94E0 Transmission selector switch: parking button, contact, faulty
0x6E6394E1 94E1 No terminal 30 at steering-column switch centre
0x6E6393E2 93E2 Terminal 15 implausible
0x6E6394E3 94E3 No terminal U_Isis
0x6E6394E4 94E4 Steering-angle sensor: mechanical connection faulty
0x6E6394E5 94E5 Steering-angle sensor: internal fault
0x6E6394E6 94E6 Steering-angle sensor: internal fault
0x6E6394E7 94E7 Steering-angle sensor: internal fault
0x6E6394E8 94E8 Steering-angle sensor: no speed signals
0x6E6394E9 94E9 Steering angle implausible
0x6E6394EA 94EA Communication steering-wheel electronics steering-column electronics faulty
0x6E6394EB 94EB Steering-wheel electronics: version not compatible
0x6E6394EC 94EC Multifunction steering wheel, left, short/open circuit
0x6E6394ED 94ED Multifunction steering wheel, right, short/open circuit
0x6E6394EE 94EE Multifunction steering wheel, left, voltage value not defined
0x6E6394EF 94EF Multifunction steering wheel, right, voltage value not defined
0x6E6394F0 94F0 Steering-wheel heating: heating mat, open circuit
0x6E6394F1 94F1 Steering-wheel heating: heating mat, short circuit to terminal 31
0x6E6394F2 94F2 Steering-wheel heating: heating mat, short circuit to terminal 30
0x6E6394F3 94F3 Steering-wheel heating: timeout control
0x6E6394F4 94F4 Steering-wheel heating: temperature sensor faulty
0x6E6394F5 94F5 Steering-column adjustment switch: short circuit to ground
0x6E6394F6 94F6 Steering-column adjustment switch: open/short circuit to positive
0x6E6394F7 94F7 Steering-column adjustment switch: voltage value not defined
0x6E6394F8 94F8 Fault, fanfare horn
0x6E6394F9 94F9 Fault, fanfare horn
0x6E6394FA 94FA Steering-column-stalk evealuation faulty
0x6E6394FB 94FB Steering-angle sensor: voltage supply, internal
0x6E6394FC 94FC steering-wheel electronics: no triggering readiness
0x6E6394FD 94FD Steering-wheel electronics: fault in alarm path
0x6E6394FE 94FE Control-unit fault
0x6E6394FF 94FF Control-unit fault
0x6E639500 9500 Firing attempt taken place
0x6E639501 9501 Steering-angle sensor not adjusted
0x6E639502 9502 Control-unit fault
0x6E639503 9503 Steering-angle sensor, reset time measurement incorrect
0x6E639504 9504 Active Front steering: serial line fault
0x6E639505 9505 Communication error CAN
0x6E639506 9506 Control-unit fault
0x6E639507 9507 Control-unit fault
0x6E639508 9508 Control-unit fault
0x6E639509 9509 Control-unit fault
0x6E63950A 950A Control-unit fault
0x6E6494A8 94A8 Processor: reset
0x6E6494A9 94A9 Control-module fault
0x6E6494AA 94AA Control-module fault
0x6E6494AB 94AB Incorrect chassis number
0x6E6494AC 94AC System time fault
0x6E6494AD 94AD Control-module fault
0x6E6494C1 94C1 Coding/data error
0x6E6494C2 94C2 Control-module fault
0x6E6494C3 94C3 Self-test: too few messages
0x6E6494C4 94C4 Self-test: data error in messages
0x6E6494C5 94C5 Self-test: transmission error
0x6E6494C6 94C6 Implausible crash severity
0x6E6494C7 94C7 Steering-wheel electronics
0x6E6494C8 94C8 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6494C9 94C9 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6494CA 94CA Resistance, firing circuit, driver's airbag, stage 1, too low
0x6E6494CB 94CB Resistance, firing circuit, driver's airbag, stage 1, too high
0x6E6494CC 94CC Resistance, firing circuit, driver's airbag, stage 1, cannot be measured
0x6E6494CD 94CD Open circuit, firing circuit, driver's airbag, stage 1
0x6E6494CE 94CE Steering-wheel electronics
0x6E6494CF 94CF Steering-wheel electronics
0x6E6494D0 94D0 Coding, firing circuit, driver's airbag, stage 1, at variance
0x6E6494D1 94D1 Steering-wheel electronics
0x6E6494D2 94D2 Steering-wheel electronics
0x6E6494D3 94D3 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6494D4 94D4 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6494D5 94D5 Resistance, firing circuit, driver's airbag, stage 2, too low
0x6E6494D6 94D6 Resistance, firing circuit, driver's airbag, stage 2, too high
0x6E6494D7 94D7 Resistance, firing circuit, driver's airbag, stage 2, cannot be measured
0x6E6494D8 94D8 Open circuit, firing circuit, driver's airbag, stage 2
0x6E6494D9 94D9 Steering-wheel electronics
0x6E6494DA 94DA Steering-wheel electronics
0x6E6494DB 94DB Coding, firing circuit, driver's airbag, stage 2, at variance
0x6E6494DC 94DC Steering-wheel electronics
0x6E6494DD 94DD Fault in alarm path
0x6E6494DE 94DE Transmission selector switch: bus fault
0x6E6494DF 94DF Transmission selector switch: bus fault and serial line fault
0x6E6494E0 94E0 Transmission selector switch: parking button, contact, faulty
0x6E6494E1 94E1 No terminal 30
0x6E6494E3 94E3 Terminal U_ISIS or U_SZL missing
0x6E6494E4 94E4 Steering-angle sensor plausibility
0x6E6494E5 94E5 Control-module fault
0x6E6494E6 94E6 Control-module fault
0x6E6494E7 94E7 Control-module fault
0x6E6494E9 94E9 Steering-angle sensor, internal
0x6E6494EA 94EA Communication between steering wheel module and steering column module faulty
0x6E6494EB 94EB Steering wheel electronics: version not compatible
0x6E6494EC 94EC Multifunction steering wheel, left: short/open circuit
0x6E6494ED 94ED Multifunction steering wheel, right: short/open circuit
0x6E6494EE 94EE Multifunction steering wheel, left: voltage value not defined
0x6E6494EF 94EF Multifunction steering wheel, right: voltage value not defined
0x6E6494F0 94F0 Steering wheel heating: heating mat, open circuit
0x6E6494F1 94F1 Steering wheel heating: heating mat, short-circuit to terminal 31
0x6E6494F2 94F2 Steering wheel heating: heating mat, short-circuit to terminal 30
0x6E6494F3 94F3 Steering wheel heating: timeout control
0x6E6494F4 94F4 Steering wheel heating: temperature sensor faulty
0x6E6494F5 94F5 Steering column adjustment switch: short-circuit to ground
0x6E6494F6 94F6 Steering column adjustment switch: open/short-circuit to positive
0x6E6494F7 94F7 Steering column adjustment switch: voltage value not defined
0x6E6494F8 94F8 Fault, horn
0x6E6494F9 94F9 Fault, horn
0x6E6494FA 94FA Steering-column-switch evaluation faulty (E65, E66, E67, RR01) or programming fault (E60, E61, E63, E64)
0x6E6494FB 94FB Control-module fault
0x6E6494FC 94FC Steering wheel electronics: no triggering readiness
0x6E6494FD 94FD Steering wheel electronics: fault in alarm path
0x6E6494FE 94FE Control-module fault
0x6E6494FF 94FF Control-module fault
0x6E649500 9500 Firing attempt taken place
0x6E649501 9501 Steering-angle-sensor calibration
0x6E649502 9502 Control-module fault
0x6E649503 9503 Control-module fault
0x6E649506 9506 Steering-wheel electronics
0x6E649507 9507 Steering-wheel electronics
0x6E649508 9508 Steering-wheel electronics
0x6E649509 9509 Steering-wheel electronics
0x6E64950A 950A Steering-wheel electronics
0x6E64950B 950B Transport mode active
0x6E649518 9518 Voltage supply: limit value undershot
0x6E649519 9519 Voltage supply: limit value exceeded
0x6E64951A 951A Voltage supply (LRE): limit value undershot
0x6E64951B 951B Voltage supply (LRE): limit value exceeded
0x6E64951D 951D Coding-data fault
//TMBFT
0x72619B8A 9B8A Undervoltage
0x72619B97 9B97 Switch, Soft Close Automatic
0x72619BA4 9BA4 Power-window electronics
0x72619BA6 9BA6 Window Position invalid
0x72619BB5 9BB5 Mirror, potentiometer, vertical
0x7261DC44 DC44 K-CAN line fault
0x72619B88 9B88 Control module
0x72619B89 9B89 Switch block
0x72619B8A 9B8A Under-voltage
0x72619B8B 9B8B Transport mode active
0x72619B8E 9B8E Spare
0x72619B8F 9B8F Spare
0x72619B90 9B90 Central locking drive, unlocking
0x72619B91 9B91 Central locking drive, locking
0x72619B92 9B92 Central locking drive, double locking
0x72619B93 9B93 Motor, electric opening
0x72619B94 9B94 Motor, soft Close Automatic
0x72619B95 9B95 Switch, child lock
0x72619B96 9B96 Switch, central locking, unlocking
0x72619B98 9B98 Switch, electric opening
0x72619B99 9B99 Electric opening
0x72619B9A 9B9A Footwell light
0x72619B9B 9B9B Door warning light
0x72619B9C 9B9C Comfort lighting
0x72619B9D 9B9D Far-field lighting
0x72619BA0 9BA0 Power window fault
0x72619BA1 9BA1 Power window fault
0x72619BA2 9BA2 Power window sluggish
0x72619BA3 9BA3 Power window electronics
0x72619BA4 9BA4 Power window electronics
0x72619BA5 9BA5 Power window terminal voltage
0x72619BA6 9BA6 Window position invalid
0x72619BA7 9BA7 Power window characteristic curve
0x72619BA9 9BA9 Power window electronics
0x72619BB0 9BB0 Motor, mirror adjustment, horizontal
0x72619BB1 9BB1 Motor, mirror adjustment, vertical
0x72619BB2 9BB2 Motor, mirror pivoting
0x72619BB3 9BB3 Mirror heating
0x72619BBA 9BBA Mirror, potentiometer, horizontal
//TMBFH
0x73619C0A 9C0A Under voltage
0x73619C25 9C25 Power-window terminal voltage
0x73619C24 9C24 Power-window electronics
0x7361DCC4 DCC4 K-CAN line fault
0x73619C08 9C08 Control unit
0x73619C09 9C09 Switch block
0x73619C0A 9C0A Under-voltage
0x73619C0B 9C0B Transport mode active
0x73619C0E 9C0E Spare
0x73619C0F 9C0F Spare
0x73619C10 9C10 Central locking drive, unlocking
0x73619C11 9C11 Central locking drive, locking
0x73619C12 9C12 Central locking drive, double locking
0x73619C13 9C13 Motor, electric opening
0x73619C14 9C14 Motor, Soft Close Automatic
0x73619C15 9C15 Switch, child lock
0x73619C16 9C16 Switch, central locking, unlocking
0x73619C17 9C17 Switch, Soft Close Automatic
0x73619C18 9C18 Switch, electric opening
0x73619C19 9C19 Electric opening
0x73619C1A 9C1A Footwell light
0x73619C1B 9C1B Door warning light
0x73619C1C 9C1C Comfort lighting
0x73619C1D 9C1D Far-field lighting
0x73619C20 9C20 Power window fault
0x73619C21 9C21 Power window fault
0x73619C22 9C22 Power windows sluggish
0x73619C23 9C23 Power window electronics
0x73619C24 9C24 Power window electronics
0x73619C25 9C25 Power window terminal voltage
0x73619C26 9C26 window position invalid
0x73619C27 9C27 Power window characteristic curve
0x73619C29 9C29 Power window electronics
0x73619C30 9C30 Mirror adjusting motor, horizontal
0x73619C31 9C31 Mirror adjusting motor, vertical
0x73619C32 9C32 Tilt-back motor, exterior rearview mirror
0x73619C33 9C33 Mirror heating
0x73619C35 9C35 Mirror position, potentiometer, vertical
0x73619C36 9C36 Mirror position, potentiometer, horizontal
//TMFAT
0x74619B4A 9B4A Undervoltage
0x74619B57 9B57 Switch, Soft Close Automatic
0x74619B64 9B64 Power-window electronics
0x74619B66 9B66 Window position invalid
0x74619B75 9B75 Mirror, potentiometer, vertical
0x7461DC04 DC04 K-CAN line fault
0x74619B48 9B48 Control module
0x74619B49 9B49 Switch block, driver's door
0x74619B4B 9B4B Transport mode active
0x74619B4E 9B4E Spare
0x74619B4F 9B4F Spare
0x74619B50 9B50 Central-locking drive, unlocking
0x74619B51 9B51 Central locking drive, locking
0x74619B52 9B52 Central-locking drive, double locking
0x74619B53 9B53 Motor, electric opening
0x74619B54 9B54 Motor, Soft Close Automatic
0x74619B55 9B55 Switch, child lock
0x74619B56 9B56 Switch, unlocking, driver's door
0x74619B58 9B58 Switch, electric opening
0x74619B59 9B59 Electric opening
0x74619B5A 9B5A Footwell light
0x74619B5B 9B5B Door warning light
0x74619B5C 9B5C Comfort lighting
0x74619B5D 9B5D Far-field lighting
0x74619B60 9B60 Power window fault
0x74619B61 9B61 Power window fault
0x74619B62 9B62 Power windows sluggish
0x74619B63 9B63 Power window electronics
0x74619B64 9B64 Power window electronics
0x74619B65 9B65 Power window terminal voltage
0x74619B67 9B67 Power window characteristic curve
0x74619B69 9B69 Power window electronics
0x74619B70 9B70 Motor, mirror adjustment, horizontal
0x74619B71 9B71 Motor, mirror adjustment, vertical
0x74619B72 9B72 Motor, mirror pivoting
0x74619B73 9B73 Mirror heating
0x74619B76 9B76 Mirror, potentiometer, horizontal
//TMFAH
0x75619BCA 9BCA Undervoltage
0x7561DC84 DC84 K-CAN line fault
0x7561DC87 DC87 K-CAN communication fault
0x75619BD7 9BD7 Switch, Soft Close Automatic
0x75619BC8 9BC8 Control module
0x75619BC9 9BC9 Switch block
0x75619BCA 9BCA Under-voltage
0x75619BCB 9BCB Transport mode active
0x75619BCE 9BCE Spare
0x75619BCF 9BCF Spare
0x75619BD0 9BD0 Central-locking drive, unlocking
0x75619BD1 9BD1 Central-locking drive, locking
0x75619BD2 9BD2 Central-locking drive, double locking
0x75619BD3 9BD3 Motor, electric opening
0x75619BD4 9BD4 Motor, Soft Close Automatic
0x75619BD5 9BD5 Switch, child lock
0x75619BD6 9BD6 Switch, central locking, unlocking
0x75619BD8 9BD8 Switch, electric opening
0x75619BD9 9BD9 Electric opening
0x75619BDA 9BDA Footwell light
0x75619BDB 9BDB Door warning light
0x75619BDC 9BDC Comfort lighting
0x75619BDD 9BDD Far-field lighting
0x75619BE0 9BE0 Power window fault
0x75619BE1 9BE1 Power window fault
0x75619BE2 9BE2 Power windows sluggish
0x75619BE3 9BE3 Power window electronics
0x75619BE4 9BE4 Power window electronics
0x75619BE5 9BE5 Power window terminal voltage
0x75619BE6 9BE6 Window position invalid
0x75619BE7 9BE7 Power window characteristic curve
0x75619BE9 9BE9 Power window electronics
0x75619BF0 9BF0 Mirror adjusting motor, horizontal
0x75619BF1 9BF1 Mirror adjusting motor, vertical
0x75619BF2 9BF2 Tilt-back motor, exterior rearview mirror
0x75619BF3 9BF3 Mirror heating
0x75619BF5 9BF5 Mirror position, potentiometer, vertical
0x75619BF6 9BF6 Mirror position, potentiometer, horizontal
//VM
0x7661A38D A38D Receiving System, aerial supply voltage: outside tolerance
0x7661A388 A388 RGB input Red
0x7661A389 A389 RGB input Green
0x7661A38A A38A RGB input Blue
0x7661A38B A38B RGB input Sync
0x7661A38D A38D Antenna supply voltage
0x7661A38E A38E Antenna supply current
0x7661A390 A390 FABAS 1 output signal
0x7661A391 A391 Short circuit to battery voltage
0x7661A392 A392 RGB Output1 Red
0x7661A393 A393 RGB Output1 Green Sync
0x7661A394 A394 RGB Output1 Red
0x7661A395 A395 RGB Output2 Red
0x7661A396 A396 RGB Output2 Green Sync
0x7661A397 A397 RGB Output2 Blue
0x7661DBD0 DBD0 Ring-break diagnosis has been carried out
//WIM
0x77619E08 9E08 Wiper module
0x77619E09 9E09 Wiper-module coding
0x77619E0B 9E0B Washer pump
0x77619E0C 9E0C Pump,headlight cleaning
0x77619E0D 9E0D Wet-arm heater
0x77619E0F 9E0F Wiper sluggish
0x77619E10 9E10 Wiper motor,Hall sensor
0x77619E11 9E11 Wiper in assembly mode
0x77619E12 9E12 Wiper motor,Hall sensor
//SBSL_2 MODE8
0x7B619828 9828 Processor: reset
0x7B619829 9829 Control-module fault
0x7B61982A 982A Control-module fault
0x7B61982B 982B Incorrect chassis number
0x7B61982C 982C System time fault
0x7B61983E 983E Control-module fault
0x7B619840 9840 Coding/data error
0x7B619841 9841 Coding-data error
0x7B619842 9842 Self-test: too few messages
0x7B619843 9843 Self-test: data error in message
0x7B619844 9844 Self test: transmission error
0x7B619845 9845 Implausible crash severity
0x7B619846 9846 Control-module fault
0x7B619847 9847 Short circuit, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), to ground
0x7B619848 9848 Short circuit, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), to positive
0x7B619849 9849 Resistance, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), too low
0x7B61984A 984A Resistance, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), too high
0x7B61984B 984B Resistance, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), not measured
0x7B61984C 984C Open circuit, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x)
0x7B61984D 984D Control-module fault
0x7B61984E 984E Control-module fault
0x7B61984F 984F Coding, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), at variance
0x7B619850 9850 Control-module fault
0x7B619851 9851 Control-module fault
0x7B619852 9852 Short circuit, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), to ground
0x7B619853 9853 Short circuit, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), to positive
0x7B619854 9854 Resistance, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), too low
0x7B619855 9855 Resistance, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), too high
0x7B619856 9856 Resistance, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), not measured
0x7B619857 9857 Open circuit, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x)
0x7B619858 9858 Control-module fault
0x7B619859 9859 Control-module fault
0x7B61985A 985A Coding, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), at variance
0x7B61985B 985B Control-module fault
0x7B61985C 985C Control-module fault
0x7B61985D 985D Short circuit, firing circuit, seat belt tensioner, front left, to ground
0x7B61985E 985E Short circuit, firing circuit, seat belt tensioner, front left, to positive
0x7B61985F 985F Resistance, firing circuit, seat belt tensioner, front left, too low
0x7B619860 9860 Resistance, firing circuit, seat belt tensioner, front left, too high
0x7B619861 9861 Resistance, firing circuit, seat belt tensioner, front left, not measured
0x7B619862 9862 Open circuit, firing circuit, seat belt tensioner, front left
0x7B619863 9863 Control-module fault
0x7B619864 9864 Control-module fault
0x7B619865 9865 Coding, firing circuit, seat belt tensioner, front left, at variance
0x7B619866 9866 Control-module fault
0x7B619867 9867 Control-module fault
0x7B619868 9868 Short circuit, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), to ground
0x7B619869 9869 Short circuit, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), to positive
0x7B61986A 986A Resistance, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), too low
0x7B61986B 986B Resistance, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), too high
0x7B61986C 986C Resistance, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), not measured
0x7B61986D 986D Open circuit, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64)
0x7B61986E 986E Control-module fault
0x7B61986F 986F Control-module fault
0x7B619870 9870 Coding, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64) at variance
0x7B619871 9871 Control-module fault
0x7B619872 9872 Control-module fault
0x7B619873 9873 Short circuit, firing circuit, seat belt tensioner, rear left, to ground
0x7B619874 9874 Short circuit, firing circuit, seat belt tensioner, rear left, to positive
0x7B619875 9875 Resistance, firing circuit, seat belt tensioner, rear left, too low
0x7B619876 9876 Resistance, firing circuit, seat belt tensioner, rear left, too high
0x7B619877 9877 Resistance, firing circuit, seat belt tensioner, rear left, not measured
0x7B619878 9878 Open circuit, firing circuit, seat belt tensioner, rear left
0x7B619879 9879 Control-module fault
0x7B61987A 987A Control-module fault
0x7B61987B 987B Coding, firing circuit, seat belt tensioner, rear left, at variance
0x7B61987C 987C Control-module fault
0x7B61987D 987D Control-module fault
0x7B61987E 987E Short circuit, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), to ground
0x7B61987F 987F Short circuit, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), to positive
0x7B619880 9880 Resistance, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), too low
0x7B619881 9881 Resistance, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), too high
0x7B619882 9882 Resistance, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), not measured
0x7B619883 9883 Open circuit, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x)
0x7B619884 9884 Control-module fault
0x7B619885 9885 Control-module fault
0x7B619886 9886 Coding, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), at variance
0x7B619887 9887 Control-module fault
0x7B619888 9888 Control-module fault
0x7B619889 9889 Control-module fault
0x7B61988A 988A Control-module fault
0x7B61988B 988B Control-module fault
0x7B61988C 988C Control-module fault
0x7B61988D 988D Control-module fault
0x7B61988E 988E Control-module fault
0x7B61988F 988F Seat-belt buckle: short circuit
0x7B619890 9890 Seat-belt buckle: implausible measured value
0x7B619891 9891 Seat-belt buckle: open circuit
0x7B619892 9892 Control-module fault (E6x) or software fault (E85)
0x7B619893 9893 Seat-occupancy detector, passenger: open circuit
0x7B619894 9894 Seat-occupancy detector, passenger: short circuit
0x7B619895 9895 Seat-occupancy detector, passenger: communication fault
0x7B619896 9896 Control-module fault
0x7B619897 9897 Control-module fault
0x7B619898 9898 Firing attempt taken place
0x7B619899 9899 Control-module fault
0x7B61989E 989E Voltage supply not in permitted range
//SBSR_2
0x7C6198A8 98A8 Processor: reset
0x7C6198A9 98A9 Control-module fault
0x7C6198AA 98AA Control-module fault
0x7C6198AB 98AB Incorrect chassis number
0x7C6198AC 98AC System time fault
0x7C6198BE 98BE Control-module fault
0x7C6198C0 98C0 Coding/data error
0x7C6198C1 98C1 Coding-data error
0x7C6198C2 98C2 Self-test: too few messages
0x7C6198C3 98C3 Self-test: data error in message
0x7C6198C4 98C4 Self test: transmission error
0x7C6198C5 98C5 Implausible crash severity
0x7C6198C6 98C6 Control-module fault
0x7C6198C7 98C7 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, to ground
0x7C6198C8 98C8 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, to positive
0x7C6198C9 98C9 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, too low
0x7C6198CA 98CA Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, too high
0x7C6198CB 98CB Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, not measured
0x7C6198CC 98CC Open circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1
0x7C6198CD 98CD Control-module fault
0x7C6198CE 98CE Control-module fault
0x7C6198CF 98CF Coding, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, at variance
0x7C6198D0 98D0 Control-module fault
0x7C6198D1 98D1 Control-module fault
0x7C6198D2 98D2 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, to ground
0x7C6198D3 98D3 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, to ground
0x7C6198D4 98D4 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, too low
0x7C6198D5 98D5 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, too high
0x7C6198D6 98D6 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, not measured
0x7C6198D7 98D7 Open circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2
0x7C6198D8 98D8 Control-module fault
0x7C6198D9 98D9 Control-module fault
0x7C6198DA 98DA Coding, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, at variance
0x7C6198DB 98DB Control-module fault
0x7C6198DC 98DC Control-module fault
0x7C6198DD 98DD Short circuit, firing circuit, seat belt tensioner, front right, to ground
0x7C6198DE 98DE Short circuit, firing circuit, seat belt tensioner, front right, to positive
0x7C6198DF 98DF Resistance, firing circuit, seat belt tensioner, front right, too low
0x7C6198E0 98E0 Resistance, firing circuit, seat belt tensioner, front right, too high
0x7C6198E1 98E1 Resistance, firing circuit, seat belt tensioner, front right, not measured
0x7C6198E2 98E2 Open circuit, firing circuit, seat belt tensioner, front right
0x7C6198E3 98E3 Control-module fault
0x7C6198E4 98E4 Control-module fault
0x7C6198E5 98E5 Coding, firing circuit, seat belt tensioner, front right, at variance
0x7C6198E6 98E6 Control-module fault
0x7C6198E7 98E7 Control-module fault
0x7C6198E8 98E8 Short circuit, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), to ground
0x7C6198E9 98E9 Short circuit, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), to positive
0x7C6198EA 98EA Resistance, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), too low
0x7C6198EB 98EB Resistance, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), too high
0x7C6198EC 98EC Resistance, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), not measured
0x7C6198ED 98ED Open circuit, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64)
0x7C6198EE 98EE Control-module fault
0x7C6198EF 98EF Control-module fault
0x7C6198F0 98F0 Coding, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64) at variance
0x7C6198F1 98F1 Control-module fault
0x7C6198F2 98F2 Control-module fault
0x7C6198F3 98F3 Short circuit, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), to ground
0x7C6198F4 98F4 Short circuit, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), to positive
0x7C6198F5 98F5 Resistance, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), too low
0x7C6198F6 98F6 Resistance, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), too high
0x7C6198F7 98F7 Resistance, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), not measured
0x7C6198F8 98F8 Open circuit, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x)
0x7C6198F9 98F9 Control-module fault
0x7C6198FA 98FA Control-module fault
0x7C6198FB 98FB Coding, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), at measured
0x7C6198FC 98FC Control-module fault
0x7C6198FD 98FD Control-module fault
0x7C6198FE 98FE Short circuit, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), to ground
0x7C6198FF 98FF Short circuit, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), to positive
0x7C619900 9900 Resistance, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), too low
0x7C619901 9901 Resistance, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), too high
0x7C619902 9902 Resistance, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), not measured
0x7C619903 9903 Open circuit, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x)
0x7C619904 9904 Control-module fault
0x7C619905 9905 Control-module fault
0x7C619906 9906 Coding, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), at variance
0x7C619907 9907 Control-module fault
0x7C619908 9908 Control-module fault
0x7C619909 9909 Control-module fault
0x7C61990A 990A Control-module fault
0x7C61990B 990B Control-module fault
0x7C61990C 990C Control-module fault
0x7C61990D 990D Control-module fault
0x7C61990E 990E Control-module fault
0x7C61990F 990F Seat-belt buckle: short circuit
0x7C619910 9910 Seat-belt buckle: implausible measured value
0x7C619911 9911 Seat-belt buckle: open circuit
0x7C619912 9912 Control-module fault (E6x) or software fault (E85)
0x7C619913 9913 Seat-occupancy detector, passenger: open circuit
0x7C619914 9914 Seat-occupancy detector, passenger: short circuit
0x7C619915 9915 Seat-occupancy detector, passenger: communication fault
0x7C619916 9916 Control-module fault
0x7C619917 9917 Control-module fault
0x7C619918 9918 Firing attempt taken place
0x7C619919 9919 Control-module fault
0x7C61991A 991A Battery lead (screen): open circuit
0x7C61991B 991B Battery lead (screen): short circuit to ground
0x7C61991C 991C Battery lead (screen): short circuit to positive
0x7C61991D 991D Battery lead (screen): implausible measured value
0x7C61991E 991E Voltage supply not in permitted range
//AL
0x8061612C 612C Control unit: hardware fault
0x80616134 6134 Motor actuating unit: fault, current
0x8061613A 613A Undervoltage
0x8061613C 613C Angle sum relation incorrect
0x8061613E 613E Lock: mechanical fault
0x8061613F 613F Steering-angle plausibility
0x80616140 6140 Redundancy comparison, driver steering angle, top
0x80616145 6145 No monitoring of angle sum relation
0x8061614A 614A Motor position angle not initialized
0x8061CE93 CE93 Message (steering-wheel angle top, OC8)
0x8061612C 612C Control unit:hardware fault
0x8061612D 612D Fluid temperature,steering
0x8061612E 612E Control unit:comparison,vehicle identification numbers
0x8061612F 612F Control unit:coding data error
0x80616130 6130 Control unit:boot or flash error MPC
0x80616131 6131 Control unit:flash operation or error NEC
0x80616132 6132 Redundant driver steering angle(SZL)
0x80616133 6133 Motor actuating unit:fault,voltage
0x80616134 6134 Motor actuating unit:fault,current
0x80616136 6136 Sensor supply,engine position
0x80616137 6137 Engine position sensor
0x80616138 6138 Servomotor overtemperature
0x80616139 6139 Vehicle ref. speed or direction of travel uncertain or not available
0x8061613B 613B DSC sensors
0x8061613D 613D Lock:electrical fault
0x8061613E 613E Lock:mechanical fault
0x80616140 6140 Redundancy comparison,driver steering angle,top
0x80616141 6141 Engine-dynamics monitoring
0x80616142 6142 ECO value in SGM
0x80616143 6143 Servotronic value in SGM
0x80616144 6144 Interlock:self-locking monitoring
0x80616146 6146 Engine temperature sensor
0x80616147 6147 Cumulative steering angle sensor:fault,supply
0x80616149 6149 Combined position,speed monitoring
0x8061614B 614B Control unit:fault,operating system
0x8061CE93 CE93 Message(steering-wheel angle top,0C8)
//FRM
0x8361A409 A409 Undervoltage
//KBM
0x8362A409 A409 Undervoltage
0x8362A40B A40B Programming fault
0x8362A40D A40D Control-module fault
0x8362A410 A410 Interior lights
0x8362A411 A411 Load cutoff
0x8362A418 A418 Hall sensor, power-window motor, rear right
0x8362A419 A419 Hall sensor, power window, rear right
0x8362A41A A41A Voltage, power window, rear right
0x8362A41B A41B Electronics, power window, rear right
0x8362A41C A41C Relay, power window, rear right
0x8362A41D A41D Relay, power window, rear right
0x8362A41E A41E Power-window position, rear invalid
0x8362A41F A41F Power-window motor, rear right
0x8362A420 A420 Mechanism, power window, rear right
0x8362A421 A421 Outside temperature implausible
0x8362A422 A422 Electronics, power window, rear right
0x8362A423 A423 Anti-repeat circuit, power window, rear right
0x8362A428 A428 Interlock, windshield wiper motor
0x8362A429 A429 Rain sensor
0x8362A42A A42A Interlock, rear window wiper
0x8362A430 A430 Soft Close Automatic, rear lid
0x8362A431 A431 Soft Close Automatic, rear lid
0x8362A432 A432 Drive unit, Soft Close Automatic, rear lid
0x8362A433 A433 Electronics, Soft Close Automatic, rear lid
0x8362A435 A435 Relay for central locking, unlocking
0x8362A436 A436 Relay for central locking, unlocking
0x8362A437 A437 Relay, central locking, locking
0x8362A438 A438 Relay, central locking, locking
0x8362A439 A439 Relay for central locking, double locking
0x8362A43A A43A Relay for central locking, double locking
0x8362A43B A43B Drive unit, rear lid unlocking
0x8362A43C A43C Drive unit, rear lid unlocking
0x8362A43D A43D Button, rear lid unlocking
0x8362A43E A43E Diagnosis lead, rear lid relay
0x8362A43F A43F Diagnosis lead, central locking relay
0x8362A440 A440 Diagnosis lead, rear lid relay
0x8362A441 A441 Diagnosis lead, central locking relay
0x8362A442 A442 Rear-window unlocking
0x8362A443 A443 Rear-window unlocking
0x8362A444 A444 Rear-window unlocking
0x8362A447 A447 Transport mode active
0x8362A448 A448 Hall sensor, power-window motor, rear left
0x8362A449 A449 Hall sensor, power-window motor, rear left
0x8362A44A A44A Voltage, power-window motor, rear left
0x8362A44B A44B Electronics, power-window motor, rear left
0x8362A44C A44C Relay, power-window motor, rear left
0x8362A44D A44D Relay, power-window motor, rear left
0x8362A44E A44E Window position, rear left, invalid
0x8362A44F A44F Power-window motor, rear left
0x8362A450 A450 Mechanism, power window, rear left
0x8362A451 A451 Outside temperature implausible
0x8362A452 A452 Electronics, power-window motor, rear left
0x8362A453 A453 Anti-repeat circuit, power-window motor, rear left
0x8362A455 A455 Mechanism, power window, rear left
0x8362A456 A456 Mechanism, power window, rear right
0x8362A457 A457 Drive unit, trunk space cover
0x8362A458 A458 Drive unit, trunk space cover
//FZD
0x8561A088 A088 Control switch SHD
0x8561A08A A08A Switch lighting
0x8561A08D A08D Coding incorrect
0x8561A090 A090 SHD mechanical system
0x8561A092 A092 SHD initialization
//RLS
0x8562A128 A128 Hardware fault, rain sensor
0x8562A129 A129 No adaptation to windshield
0x8562A12A A12A High temperature
0x8562A12B A12B Overvoltage / undervoltage
0x8562A12D A12D Hardware, light sensor
0x8562A12E A12E Calibration error, light sensor
//CCCA
0x8861A04A A04A Safety violation
0x8861A04E A04E Yaw sensor, internal fault
0x8861A04F A04F No speedometer signal but GPS position change
0x8861A050 A050 Too many speedo pulses
0x8861A051 A051 GPS direction and direction of travel do not correspond
0x8861A053 A053 Control-unit fault
0x8861A054 A054 GPS aerial not connected
0x8861A055 A055 Short circuit at GPS aerial connection
0x8861A056 A056 Control-unit fault
0x8861A057 A057 CCC time out equal to GPS time
0x8861A058 A058 Yaw-sensor fault during self-test
0x8861A059 A059 Yaw sensor issues incorrect signal
0x8861A05A A05A Yaw sensor, internal fault
0x8861A05B A05B General yaw-sensor fault
0x8861A05C A05C Yaw sensor, internal fault
0x8861A05D A05D Unknown speedo fault
0x8861A05F A05F Control-unit fault
0x8861A060 A060 Control-unit fault
0x8861A061 A061 Control-unit fault
0x8861A062 A062 No connection to HIP module
0x8861A063 A063 System fault
0x8861A6F1 A6F1 System fault
0x8861A6F2 A6F2 System fault
//CCCASK
0x8E61A18B A18B Control-unit fault
0x8E61A18C A18C Overcurrent, Minidisc player
0x8E61A18D A18D Overtemperature in Minidisc player
0x8E61A18E A18E MD hardware fault
0x8E61A18F A18F Loading mechanism of Minidisc player faulty
0x8E61A190 A190 Limit switch, loading mechanism of Minidisc player, faulty
0x8E61A191 A191 Control-unit fault
0x8E61A192 A192 Control-unit fault
0x8E61A193 A193 Connection fault between CCC-ASK and Minidisc player
0x8E61A194 A194 Control-unit fault
0x8E61A195 A195 Control-unit fault
0x8E61A196 A196 Control-unit fault
0x8E61A197 A197 Hardware fault in CCC
0x8E61A198 A198 No connection to minidisc player
0x8E61A199 A199 Control-unit fault
0x8E61A19B A19B Control-unit fault
0x8E61A19C A19C Microphone cable not connected or short circuit
0x8E61A19D A19D AUX not connected or short circuit
0x8E61A1A2 A1A2 Control-unit fault
0x8E61A1A3 A1A3 Control-unit fault
0x8E61A1A4 A1A4 Control-unit fault
0x8E61A1A5 A1A5 Control-unit fault
//FLA
//INSTR
0xA661930E 930E Gear display P
0xA6619316 9316 Odometer memory
0xA6619319 9319 Fuel-level sensor, right
0xA661931A 931A Fuel-level sensor, left
0xA661931B 931B Outside temperature
0xA661931C 931C Display-heater short circuit
0xA661931D 931D System voltage
//ANT
0xBF61A508 A508 Voltage supply, aerials
//BZM
0XC1619FC8 9FC8 Menu buttons,left
0XC1619FC9 9FC9 Turn rotary knob,left
0XC1619FCA 9FCA Heating/ventilation,left
0XC1619FCB 9FCB Push rotary knob,left
0XC1619FCC 9FCC Memory button,left
0XC1619FCD 9FCD Menu buttons,right
0XC1619FCE 9FCE Turn rotary knob,right
0XC1619FCF 9FCF Heating/ventilation,right
0XC1619FD0 9FD0 Push rotary knob,right
0XC1619FD1 9FD1 Memory button,right
//LM2
0xC5619CAB 9CAB One terminal 15 missing
0xC5619CB1 9CB1 Potentiometer, dimmer, faulty
0xC5619CB3 9CB3 Ride-height sensor, front, faulty
0xC5619CB4 9CB4 Ride-height sensor, rear ,faulty
0xC5619CB6 9CB6 HVAC coil chopping
0xC5629CAB 9CAB One terminal 15 missing
0xC5629CB1 9CB1 Potentiometer, dimmer, faulty
0xC5629CB3 9CB3 Ride-height sensor, front, faulty
0xC5629CB4 9CB4 Ride-height sensor, rear ,faulty
0xC5629CB6 9CB6 HVAC coil chopping
0xC5629CBC 9CBC Short circuit in a lamp circuit
0xC5629CBD 9CBD Battery exhaustive-protection: deactivation, side light
0xC5629CA8 9CA8 Control-module fault
0xC5629CA9 9CA9 Terminal 30A connection faulty
0xC5629CAA 9CAA Terminal 30B connection faulty
0xC5629CAC 9CAC Brake-light switch faulty
0xC5629CAD 9CAD AHM communication disturbed
0xC5629CAE 9CAE Control-panel fault
0xC5629CAF 9CAF Light switch position 1 faulty
0xC5629CB0 9CB0 Light switch position 2 faulty
0xC5629CB1 9CB1 Dimmer potentiometer faulty
0xC5629CB2 9CB2 LWR potentiometer faulty
0xC5629CB3 9CB3 Sensor, ride level, front, faulty
0xC5629CB4 9CB4 Ride-level sensor, rear, faulty
0xC5629CB5 9CB5 Transport mode active
0xC5629CB7 9CB7 HVAC driver fault
0xC5629CB8 9CB8 Lamp dimming faulty
0xC5629CB9 9CB9 Short circuit at a lamp output
0xC5629CBA 9CBA Short circuit at a lamp output
0xC5629CBB 9CBB Short circuit at a lamp output
0xC5629CBC 9CBC Short circuit at a lamp output
0xC5629CBD 9CBD Exhaustive-discharge protection of battery:deactivation,side-market light
0xC5629CBE 9CBE Exhaustive-discharge protection of battery:deactivation,parking light
0xC5629CBF 9CBF Battery exhausted
0xC5629CC0 9CC0 Software status and coding index do not match
0xC5639CAB 9CAB One terminal 15 missing
0xC5639CB1 9CB1 Potentiometer, dimmer, faulty
0xC5639CB3 9CB3 Ride-height sensor, front, faulty
0xC5639CB4 9CB4 Transport mode active
0xC5639CB6 9CB6 Short circuit in a lamp circuit
0xC5639CBC 9CBC Communication with SMC, left, disrupted
0xC5639CBD 9CBD Communication with SMC, right, disrupted
0xC5639CC3 9CC3 Battery exhausted
0xC5649CAB 9CAB One terminal 15 missing
0xC5649CB1 9CB1 Potentiometer, dimmer, faulty
0xC5649CB3 9CB3 Ride-height sensor, front, faulty
0xC5649CB4 9CB4 Transport mode active
0xC5649CB6 9CB6 Headlight vertical aim control coil break
0xC5649CBC 9CBC Communication with SMC, left, disrupted
0xC5649CBD 9CBD Communication with SMC, right, disrupted
0xC5649CC3 9CC3 LIN line fault (RLS)
0xC5659CA8 9CA8 Control-unit fault
0xC5659CA9 9CA9 Terminal 30A connection faulty
0xC5659CAB 9CAB Terminal 30B connection faulty
0xC5659CAB 9CAB One terminal 15 missing
0xC5659CAC 9CAC Brake-light switch faulty
0xC5659CAD 9CAD AHM communication disturbed
0xC5659CAE 9CAE Control-panel fault
0xC5659CAF 9CAF Light-switch position 1 faulty
0xC5659CB0 9CB0 Lgiht-switch psoition 2 faulty
0xC5659CB1 9CB1 Dimmer potentiometer faulty
0xC5659CB3 9CB3 Sensor, ride level, front, faulty
0xC5659CB4 9CB4 Ride-level sensor, rear, faulty
0xC5659CB5 9CB5 Transport mode active
0xC5659CB6 9CB6 HVAC coil chopping
0xC5659CB7 9CB7 HVAC driver fault
//PM
0xCA61A148 A148 Control-unit fault
0xCA61A149 A149 Input te.15 waking
0xCA61A14A A14A Battery switch
0xCA61A152 A152 Driver, electrical load, roof
0xCA61A154 A154 Fuel-filler-flap motor
0xCA61A156 A156 Rear-lid contact
0xCA61A158 A158 Battery disconnection (closed-circuit current)
0xCA61A15D A15D Battery, exhaustive discharge
0xCA61A161 A161 Battery, disconnection (Closed-circuit current)
0xCA61A163 A163 No bus rest, in spite of disconnection 30U and 30G
0xCA62A6A4 A6A4 Control-module fault
0xCA62A6A5 A6A5 Coding-data fault
0xCA62A6A6 A6A6 Coding-data fault
0xCA62A6A7 A6A7 Control-module fault
0xCA62A6A8 A6A8 Control-module fault
0xCA62A6A9 A6A9 Voltage supply, relay 1
0xCA62A6AA A6AA Voltage supply, relay 2
0xCA62A6AB A6AB Terminal 30
0xCA62A6AC A6AC Transport mode active
0xCA63A148 A148 Control module fault
0xCA63A149 A149 Input term. 15 waking
0xCA63A14A A14A Battery switch
0xCA63A14B A14B Eccentric contact
0xCA63A14C A14C Battery temperature sensor
0xCA63A14D A14D Driver Term. 30
0xCA63A14E A14E Driver, rear window defroster
0xCA63A14F A14F Driver, interior lighting
0xCA63A150 A150 Driver Term. 15
0xCA63A151 A151 Driver Term. R
0xCA63A152 A152 Driver, electrical load, roof
0xCA63A153 A153 Driver, electrical load, body
0xCA63A154 A154 Fuel filler flap motor
0xCA63A155 A155 Trunk motor
0xCA63A156 A156 Trunk contact
0xCA63A157 A157 SCA motor
0xCA63A158 A158 Battery disconnection (closed-circuit current)
0xCA63A159 A159 Battery disconnection (lmax)
0xCA63A15A A15A Battery disconnection (short circuit)
0xCA63A15B A15B Driver, light module
0xCA63A15C A15C Transport mode active
0xCA63A15D A15D Battery, exhaustive discharge
0xCA63A15E A15E Light module
0xCA63A15F A15F Exhibition mode
0xCA63A160 A160 Multi-fuses
//SGM-SIM
0xCC6193A8 93A8 Processor: reset
0xCC6193C1 93C1 Control-unit fault
0xCC6193C2 93C2 Self-test: too few messages
0xCC6193C9 93C9 Deactivation: satellite, A-pillar, left
0xCC6193CA 93CA Deactivation: satellite, A-pillar, right
0xCC6193CB 93CB Deactivation: satellite, vehicle centre
0xCC6193CC 93CC Deactivation: satellite, door, front left
0xCC6193CD 93CD Deactivation: satellite, seat, driver
0xCC6193CF 93CF Deactivation: satellite, door, front right
0xCC6193D0 93D0 Deactivation: satellite, seat, passenger
0xCC6193D9 93D9 Control-unit fault
0xCC6193DE 93DE Firing attempt taken place
0xCC6193DF 93DF Under voltage
0xCC6193A8 93A8 Processor: Reset
0xCC6193A9 93A9 Control-module fault
0xCC6193AA 93AA Control-module fault
0xCC6193AB 93AB Incorrect chassis number
0xCC6193AC 93AC System time fault
0xCC6193C0 93C0 Coding/data error
0xCC6193C1 93C1 Control-module fault
0xCC6193C3 93C3 Self-test: data error in message
0xCC6193C4 93C4 Self-test: transmission error
0xCC6193C5 93C5 Implausible crash severity
0xCC6193C6 93C6 Control-module fault
0xCC6193C8 93C8 Deactivation: switch center, steering column
0xCC6193CB 93CB Deactivation: satellite, vehicle center
0xCC6193CD 93CD Deactivation: satellite, driver's seat
0xCC6193CE 93CE Deactivation: satellite, B-pillar, left
0xCC6193D0 93D0 Deactivation: satellite, passenger's seat
0xCC6193D1 93D1 Deactivation: satellite, B-pillar, right
0xCC6193D2 93D2 Deactivation: satellite, seat, rear
0xCC6193D9 93D9 Control-module fault
0xCC6193DB 93DB Control-module fault
0xCC6193DC 93DC Control-module fault
0xCC6193DD 93DD Control-module fault
0xCC6193DF 93DF Undervoltage
0xCC6193E0 93E0 Control-module fault
0xCC619488 9488 Attack alarm occurred
0xCC6293A8 93A8 Driver's airbag, stage 1
0xCC6293AD 93AD Side airbag, passenger
0xCC6293AE 93AE Side airbag, Driver, rear
0xCC6293AF 93AF Side airbag, passenger, rear
0xCC6293B4 93B4 Driver's airbag, stage 2
0xCC6293B5 93B5 Seat-belt tensioner, driver, rear
0xCC6293B8 93B8 Knee airbag, driver
0xCC6293BC 93BC Belt-buckle contact, driver, rear
0xCC6293BD 93BD Belt-buckle contact, passenger, rear
0xCC6293BE 93BE Switch for front passenger airbag deactivation
0xCC6293C1 93C1 Communication fault, seat-occupancy detector, passenger
0xCC6293C2 93C2 Seat mat, seat-occupancy detector, passenger, faulty
0xCC6293C9 93C9 Airbag front sensor, front passenger's side
0xCC6293CA 93CA Airbag sensor, B-pillar, driver's side (X-direction)
0xCC6293CB 93CB Airbag sensor, B-pillar, front passenger's side (X-direction)
0xCC6293CC 93CC Airbag sensor, B-pillar, driver's side (Y-direction)
0xCC6293CD 93CD Airbag sensor, B-pillar, front passenger's side (Y-directio)
0xCC6293CF 93CF Airbag sensor, door, passenger, front
0xCC6293D0 93D0 Under voltage
0xCC6293D7 93D7 Internal control-unit fault
0xCC6293D8 93D8 Seat occupancy detector, front passenger: system could not be released
0xCC6293D9 93D9 Airbag front sensor, driver's side: sensor type incorrect
0xCC6293DA 93DA Airbag front sensor, driver's side: sensor data implausible
0xCC6293DE 93DE Airbag sensor, B-pillar, driver's side (X-direction): sensor data implausible
0xCC6293DF 93DF Airbag sensor, B-pillar, passenger's side (X-direction): sensor type incorrect
0xCC6293E4 93E4 Airbag sensor, B-pillar, passenger's side (Y-direction): sensor data implausible
0xCC6293FC 93FC Battery lead, positive (monitoring of shielding)
0xCC6293A8 93A8 Driver's airbag,stage 1
0xCC6293A9 93A9 Belt tensioner.deiver
0xCC6293AA 93AA Belt tensioner,passenger
0xCC6293AB 93AB Passenger airbag,stage 1
0xCC6293AC 93AC Side airbag,driver
0xCC6293AD 93AD Side airbag,passenger
0xCC6293AE 93AE Side airbag,rear,driver's side
0xCC6293AF 93AF Side airbag,rear,passenger's side
0xCC6293B0 93B0 Head airbag,driver
0xCC6293B1 93B1 Head airbag,front passenger
0xCC6293B2 93B2 Safety battery terminal
0xCC6293B3 93B3 Passenger airbag,stage 2
0xCC6293B4 93B4 Driver's airbag,stage 2
0xCC6293B5 93B5 Seat-belt tensioner,rear,driver's side
0xCC6293B6 93B6 Seat-belt tensioner,rear,passenger's side
0xCC6293B8 93B8 Knee airbag,driver
0xCC6293BA 93BA Seatbelt-catch contact,driver
0xCC6293BB 93BB Seatbelt-catch contact,passenger
0xCC6293BC 93BC Belt-buckle contact,rear,driver's side
0xCC6293BD 93BD Belt-buckle contact,rear,passenger's side
0xCC6293C1 93C1 Seat-occupancy detector,passenger
0xCC6293C2 93C2 Sear mat,seat-occupancy detector,passenger
0xCC6293C3 93C3 Seat-occupancy detector,passenger
0xCC6293C4 93C4 Seat occupancy detector,front passenger:Internal fault
0xCC6293C5 93C5 Seat-occupancy detector,passenger:not released
0xCC6293C6 93C6 Backrest lock for driver's seat
0xCC6293C7 93C7 Backrest lock for passenger's seat
0xCC6293C8 93C8 Airbag front sensor,driver's side
0xCC6293C9 93C9 Airbag front sensor,front passenger's side
0xCC6293CA 93CA Airbag sensor,B-pillar,driver's side(X-direction)
0xCC6293CB 93CB Airbag sensor,B-pillar,front psssenger's side(X-direction)
0xCC6293CC 93CC Airbag sensor,B-pillar,driver's side(Y-direction)
0xCC6293CD 93CD Airbag sensor,B-pillar,front passenger's side(Y-direction)
0xCC6293CE 93CE Airbag sensor,door,front,driver's side
0xCC6293CF 93CF Airbag sensor,door,front,passenger's side
0xCC6293D0 93D0 Undervoltage
0xCC6293D1 93D1 Overvoltage
0xCC6293D2 93D2 Telltale lamp for front passenger airbag deactivation
0xCC6293D3 93D3 Coding data incorrect
0xCC6293D4 93D4 Crash telegram stored
0xCC6293D5 93D5 Three crash telegrams stored
0xCC6293D6 93D6 Coding data incorrect
0xCC6293D8 93D8 Seat occupancy detector,front passenger:Internal fault
0xCC6293D9 93D9 Airbag front sensor,driver's side:sensor type incorrect
0xCC6293DA 93DA Airbag front sensor,driver's side:sensor data implausible
0xCC6293DB 93DB Airbag front sensor, passenger's side:sensor type incorrect
0xCC6293DC 93DC Airbag front sensor, passenger's side:sensor data implausible
0xCC6293DD 93DD Airbag sensor,B-pillar,driver's side(X-direction):sensor type incorrect
0xCC6293DE 93DE Airbag sensor,B-pillar,driver' side(X-direction):sensor data implausible
0xCC6293DF 93DF Airbag sensor,B-pillar,passenger's side(X-direction): sensor type incorrect
0xCC6293E0 93E0 Airbag sensor,B-pillar,passenger's side(X-direction):sensor data implausible
0xCC6293E1 93E1 Airbag sensor,B-pillar,driver's side(Y-direction):sensor type incorrect
0xCC6293E2 93E2 Airbag sensor,B-pillar,driver' side(Y-direction):sensor data implausible
0xCC6293E3 93E3 Airbag sensor,B-pillar,passenger's side(Y-direction): sensor type incorrect
0xCC6293E4 93E4 Airbag sensor,B-pillar,passenger's side(Y-direction):sensor data implausible
0xCC6293E5 93E5 Airbag sensor,door,front,driver's side:sensor type incorrect
0xCC6293E6 93E6 Airbag sensor,door,front,driver's side:sensor data implausible
0xCC6293E7 93E7 Airbag sensor,door,front,passenger's side:sensor type incorrect
0xCC6293E8 93E8 Airbag sensor,door,front,passenger's side:sensor data implausible
0xCC6293EC 93EC Programming data faulty
0xCC6293F7 93F7 Knee airbag,front passenger
0xCC6293F8 93F8 Anchor-fitting tensioner,driver
0xCC6293F9 93F9 Active head restraint,driver
0xCC6293FA 93FA Active head restraint,front passenger
0xCC6293FC 93FC Battery lead,positive(monitoring of shielding)
0xCC6293FD 93FD Battery lead,ground(monitoring of shielding)
0xCC6293FE 93FE Rollover-proection controller:not fitted
0xCC6293FF 93FF Rollover-protection controller
0xCC629400 9400 Seat-occupancy detector,passenger:incorrect type
0xCC629401 9401 Rollover-protection controller:communication fault
0xCC629402 9402 Rollover-protection controller:internal fault
0xCC629403 9403 Rollover bar,left
0xCC629404 9404 Rollover bar,right
0xCC629405 9405 Rollover-protection controller:internal fault
0xCC629406 9406 Rollover-protection controller:undervoltage
0xCC629407 9407 Rollover-protection controller:internal fault
0xCC629408 9408 Undervoltage during self-test
0xCC629409 9409 Rollover-protection controller:reset
0xCC62940A 940A Overvoltage during self-test
0xCC62940B 940B Rollover-protection controller:sensor
0xCC62940C 940C Rollover-protection controller:sensor
0xCC6393A8 93A8 Processor: reset
0xCC6393AD 93AD System time fault
0xCC6393D7 93D7 Deactivation: Safety and Gateway Module
0xCC6393D8 93D8 Deactivation: switch centre, steering column switch cluster
0xCC6393D9 93D9 Deactivation: driver's door module (E60,E61,E63,E64) or steering column switch cluster(E65,E66,E67,RR01)
0xCC6393DA 93DA Deactivation: front passenger door module (E60,E61,E63,E64) or satellite, A-pillar, left (E65,E66,E67,RR01)
0xCC6393DE 93DE Deactivation: satellite, seat, driver
0xCC6393DF 93DF Deactivation: satellite, B-pillar, left
0xCC6393E4 93E4 Self-test: too few message
0xCC6393FB 93FB Control-unit fault
0xCC6393FC 93FC Under voltage
0xCC6393A9 93A9 Control-module fault
0xCC6393AA 93AA Control-module fault
0xCC6393AB 93AB Control-module fault
0xCC6393AC 93AC Incorrect chassis number
0xCC6393D8 93D8 Deactivation: switch center, steering column switch cluster
0xCC6393D9 93D9 Deactivation: driver's door module (E60, E61, E63, E64) or steering column switch cluster (E65, E66, E67, RR01)
0xCC6393DA 93DA Deactivation: front passenger door module (E60, E61, E63, E64) or satellite, A-pillar, left (E65, E66, E67, RR01)
0xCC6393DB 93DB Deactivation: satellite, B-pillar, left (E60, E61, E63, E64) or satellite, A-pillar, right (E65, E66, E67, RR01)
0xCC6393DC 93DC Deactivation: satellite, B-pillar, right (E60, E61, E63, E64) or satellite, vehicle center (E65, E66, E67, RR01)
0xCC6393DD 93DD Deactivation: satellite, vehicle center (E60, E61, E63, E64) or satellite, door, front left (E65, E66, E67, RR01)
0xCC6393DE 93DE Deactivation: satellite, driver's seat
0xCC6393E0 93E0 Deactivation: satellite, door, front right
0xCC6393E1 93E1 Deactivation: satellite, passenger's seat
0xCC6393E2 93E2 Deactivation: satellite, B-pillar, right
0xCC6393E3 93E3 Deactivation: satellite, seat, rear
0xCC6393E4 93E4 Self-test: too few messages
0xCC6393E5 93E5 Self-test: data fault in message
0xCC6393E6 93E6 Self-test: transmission fault
0xCC6393E9 93E9 Coding-data fault
0xCC6393EA 93EA Coding-data fault
0xCC6393EB 93EB Control-module fault
0xCC6393EC 93EC Control-module fault
0xCC6393F5 93F5 Control-module fault
0xCC6393F6 93F6 Control-module fault
0xCC6393F7 93F7 Control-module fault
0xCC6393F8 93F8 Control-module fault
0xCC6393F9 93F9 Control-module fault
0xCC6393FA 93FA Control-module fault
0xCC6393FB 93FB Control-module fault
0xCC6393FC 93FC Undervoltage
0xCC639401 9401 Control-module fault
0xCC639402 9402 Front sensor, left
0xCC639403 9403 Front sensor, right
0xCC639404 9404 Front sensor: wrong component
0xCC639406 9406 Current request from Active Front Steering too high
0xCC639407 9407 Servotronic converter
0xCC639408 9408 ECO converter
0xCC639409 9409 Overvoltage or under-voltage
0xCC63940F 940F Electric fuel pump deactivated
0xCC639410 9410 Coding-data fault
0xCC639411 9411 Indicator lamp, airbag deactivation: short circuit to ground
0xCC639412 9412 Indicator lamp, airbag deactivation: short circuit to positive
0xCC639413 9413 Signal lamp, airbag deactivation: open circuit
0xCC639415 9415 Rollover bar, left: short circuit to ground
0xCC639416 9416 Rollover bar, left: open circuit
0xCC639417 9417 Rollover bar, left: short circuit to positive
0xCC639418 9418 Rollover bar, right: short circuit to ground
0xCC639419 9419 Rollover bar, right: open circuit
0xCC63941A 941A Rollover bar, right: short circuit to positive
0xCC63941B 941B Rollover bar, left: resistance too high
0xCC63941C 941C Rollover bar, right: resistance too high
0xCC63941D 941D Rollover bar, left: resistance too low
0xCC63941E 941E Rollover bar, right: resistance too low
0xCC63941F 941F Control-module fault
0xCC639420 9420 Control-module fault
0xCC639421 9421 Control-module fault
0xCC639422 9422 Control-module fault
0xCC639423 9423 Control-module fault
0xCC639424 9424 No message ( via serial cable) from satellite, vehicle center
0xCC639425 9425 Serial cable to satellite, vehicle center
0xCC639426 9426 Activation, rollover bar
0xCC639427 9427 Implausible crash severity
0xCC63942B 942B Implausible crash severity
0xCC63942C 942C Fault, satellite, B-pillar
0xCC63942D 942D Fault, satellite, vehicle center
0xCC63942E 942E Attack alarm occurred
0xCC6493A8 93A8 Airbag, driver, 1st stage
0xCC6493A9 93A9 Seat belt tensioner, driver
0xCC6493AA 93AA Seat belt tensioner, passenger
0xCC6493AB 93AB Airbag, front passenger, 1st stage
0xCC6493AC 93AC Side airbag, front left
0xCC6493AD 93AD Side airbag, front right
0xCC6493AE 93AE Side airbag, rear left
0xCC6493AF 93AF Side airbag, rear right
0xCC6493B0 93B0 Head airbag, left
0xCC6493B1 93B1 Head airbag, right
0xCC6493B2 93B2 Safety battery terminal
0xCC6493B3 93B3 Airbag,front passenger,2nd stage
0xCC6493B4 93B4 Airbag,driver,2nd stage
0xCC6493B5 93B5 Belt tensioner,rear left
0xCC6493B6 93B6 Belt tensioner,rear right
0xCC6493B8 93B8 Knee airbag,driver
0xCC6493B9 93B9 Knee airbag,front passenger
0xCC6493BA 93BA Seatbelt-catch contact,driver
0xCC6493BB 93BB Seatbelt-catch contact,passenger
0xCC6493BC 93BC Seatbelt-catch contact,rear left
0xCC6493BD 93BD Seatbelt-catch contact,rear right
0xCC6493BE 93BE Switch for front passenger airbag deactivation
0xCC6493BF 93BF Switch for front passenger airbag deactivation inverted
0xCC6493C0 93C0 Switch for front passenger airbag deactivation:implausible signal
0xCC6493C1 93C1 Seat occupancy detector
0xCC6493C2 93C2 Seat mat,Seat occupancy detector
0xCC6493C3 93C3 Seat-occupancy detector,passenger
0xCC6493C4 93C4 Seat occupancy detector,front passenger:data memory full
0xCC6493C5 93C5 Seat occupancy detector,front passenger:system not yet released
0xCC6493C6 93C6 Backrest lock for driver's seat
0xCC6493C7 93C7 Backrest lock for passenger's seat
0xCC6493C8 93C8 Airbag front sensor,left
0xCC6493C9 93C9 Airbag front sensor,right
0xCC6493CA 93CA Airbag sensor,B-pillar,left(X-direction)
0xCC6493CB 93CB Airbag sensor,B-pillar,right(X-direction)
0xCC6493CC 93CC Airbag sensor,B-pillar,left(Y-direction)
0xCC6493CD 93CD Airbag sensor,B-pillar,right(Y-direction)
0xCC6493CE 93CE Airbag sensor,door,front left
0xCC6493CF 93CF Airbag sensor,door,front right
0xCC6493D0 93D0 Supply voltage:undervoltage
0xCC6493D1 93D1 Supply voltage:overvoltage
0xCC6493D2 93D2 Telltale lamp for front passenger airbag deactivation
0xCC6493D3 93D3 Coding incorrect
0xCC6493D4 93D4 Crash-telegram memory:at least one crash telegram is stored
0xCC6493D5 93D5 Crash-telegram memory:three crash telegrams is stored
0xCC6493D6 93D6 Internal control-unit fault:control unit is not locked
0xCC6493D7 93D7 Internal control-unit fault
0xCC6493D8 93D8 Seat occupancy detector,front passenger:system could not be released
0xCC6493D9 93D9 Airbag front sensor,left:incorrect measuring range
0xCC6493DA 93DA Airbag front sensor,left:message implausible
0xCC6493DB 93DB Airbag front sensor,right:incorrect measuring range
0xCC6493DC 93DC Airbag front sensor,right:message implausible
0xCC6493DD 93DD Airbag sensor,B-pillar,left(X-direction):incorrect measuring range
0xCC6493DE 93DE Airbag sensor,B-pillar,left(X-direction):message implausible
0xCC6493DF 93DF Airbag sensor,B-pillar,right(X-direction):incorrect measuring range
0xCC6493E0 93E0 Airbag sensor,B-pillar,right(X-direction):message implausible
0xCC6493E1 93E1 Airbag sensor,B-pillar,left(Y-direction):incorrect measuring range
0xCC6493E2 93E2 Airbag sensor,B-pillar,left(Y-dirction):message implausible
0xCC6493E3 93E3 Airbag sensor,B-pillar,right(Y-direction):incorrect measuring range
0xCC6493E4 93E4 Airbag sensor,B-pillar,right(Y-direction):message implausible
0xCC6493E5 93E5 Airbag sensor,door,front left:incorrect measuring range
0xCC6493E6 93E6 Airbag sensor,door,front left:message implausible
0xCC6493E7 93E7 Airbag sensor,door,front right:incorrect measuring range
0xCC6493E8 93E8 Airbag sensor,door,front right:message implausible
0xCC6493E9 93E9 Airbag telltale lamp
0xCC6493EB 93EB Emergency call function
0xCC6493EC 93EC Internal control-unit fault:incorrect software version
0xCC6493ED 93ED Control unit/sensors:unknown fault
0xCC6493EE 93EE Airbag sensor,door,front left:pressure sensor outside measuring range
0xCC6493EF 93EF Airbag sensor,door,front left:absolute pressure sensor outside measuring range
0xCC6493F0 93F0 Airbag sensor,door,front left:difference of absolute pressure outside measuring range
0xCC6493F1 93F1 Airbag sensor,door,front right:pressure sensor outside measuring range
0xCC6493F2 93F2 Airbag sensor,door,front right:absolute pressure sensor outside measuring range
0xCC6493F3 93F3 Airbag sensor,door,front right:difference of absolute pressure outside measuring range
0xCC6493F4 93F4 Airbag sensor,door,front left:communication fault
0xCC6493F5 93F5 Airbag sensor,door,front right:communication fault
0xCC6493F6 93F6 Internal control-unit fault:triggering threshold reached
//SGM-ZGM
0xCD61932B 932B BYTEFLIGHT damping too high
0xCD61932C 932C Control-module fault
0xCD61932D 932D Control-module fault
0xCD61932E 932E Control-module fault
//JBE
0xCD629C5E Refrigerant pressure sensor
0xCD629C69 Rear stratification-flap potentiometer
0xCD62A6C8 Heated rear window relay
0xCD62A6C9 Windscreen wipers, blocking
0xCD62A6CA Switch-on relay for windscreen wipers
0xCD62A8CB Changeover relay for windscreen wipers
0xCD62A8CC Relay, windscreen washing system
0xCD62A6CD Rear-window wiper, blocking
0xCD62A6CE Relay, rear-window wiper
0xCD62A6CF AUC sensor
0xCD62A6D0 Control valve in A/C compressor
0xCD62A6D1 Auxiliary-water pump
0xCD62A6D2 Water valve
0xCD62A6D3 Windscreen washer pump
0xCD62A6D4 Central-locking relay, unlocking
0xCD62A6D5 Central-locking relay, locking
0xCD62A6D6 Central-locking relay, double locking
0xCD62A6D7 Central-locking relay, selective unlocking
0xCD62A6D8 Power-window relay (closing), passenger, rear
0xCD62A6D9 Power-window relay (opening), passenger, rear
0xCD62A6DA Power-window relay (closing), driver's side, rear
0xCD62A6DB Power-window relay (opening), driver's side, rear
0xCD62A6DC Rear-window washer pump
0xCD62A6DD Roller sunblind/luggage compartment cover
0xCD62A6DE Mirror/spray-nozzle heating, left
0xCD62A6DF Mirror/spray-nozzle heating, right
0xCD62A6E0 Seat heating, driver's side
0xCD62A6E1 Seat heating, passenger's side
0xCD62A6E2 Central-locking drive, rear lid
0xCD62A6E3 Central-locking drive, rear window
0xCD62A6E4 Fuel level sensor 1
0xCD62A6E5 Fuel level sensor 2
0xCD62A6E6 Power-window switch, passenger's side, front
0xCD62A6E7 Transport mode active
0xCD62A728 Power-window switch, passenger, rear
0xCD62A729 Power-window switch, driver's side, rear
0xCD62A72A Power-window Hall sensor 1, driver's side, rear
0xCD62A72B Power-window Hall sensor 2, driver's side, rear
0xCD62A72C Power-window Hall sensor 1, passenger, rear
0xCD62A72D Power-window Hall sensor 2, passenger, rear
0xCD62A731 Supply, terminal 30g-f
//SM
0xEF210000 00 Hall sensor, backrest angle, short circuit to ground
0xEF210001 01 Hall sensor, backrest angle, open circuit
0xEF210002 02 Hall sensor, backrest angle, short circuit to positive
0xEF210003 03 Hall sensor, seat height, short circuit to ground
0xEF210004 04 Hall sensor, seat height, open circuit
0xEF210005 05 Hall sensor, seat height, short circuit to positive
0xEF210006 06 Hall sensor, seat angle, short circuit to ground
0xEF210007 07 Hall sensor, backrest angle, open circuit
0xEF210008 08 Hall sensor, seat angle, short circuit to positive
0xEF210009 09 Hall sensor, seat carriage, short circuit to ground
0xEF21000A 0A Hall sensor, seat carriage, open circuit
0xEF21000B 0B Hall sensor, seat carriage, short circuit to positive
0xEF21000F 0F Supply, Hall sensors, short circuit to ground or Hall sensor not connected
0xEF210010 10 Control-unit fault
0xEF210011 11 Steering column, radial, transmission fault
0xEF210012 12 Steering column, radial, short circuit
0xEF210013 13 Steering column, radial, block operation
0xEF210014 14 Steering column, radial, block operation
0xEF210015 15 Steering column, axial, transmission fault
0xEF210016 16 Steering column, axial, short circuit
0xEF210017 17 Steering column, axial, block operation
0xEF210018 18 Steering column, axial, block operation
//ZKE 2
0xF0210001 01 Fuse of load circuit faulty
0xF0210002 02 Pin contact in ZV drive, driver's door
0xF0210003 03 Pin contact in ZV drive, driver's door
0xF0210004 04 Pin contact in ZV drive, boot lid
0xF0210005 05 Pin contact in ZV drive, boot lid
0xF0210006 06 Relay for locking sticks
0xF0210007 07 Relay for double-locking sticks
0xF0210008 08 Relay for unlocking sticks
0xF0210009 09 Relay for locking does not pick up
0xF021000A 10 Relay for double-locking does not pick up
0xF021000B 11 Relay for unlocking does not pick up
0xF021000C 12 Short circuit in supply wire
0xF021000D 13 Door-lock heating faulty
0xF021000E 14 Short circuit in supply wire
Share this post
Link to post
Share on other sites
спасибо!!! нашел свою ошибку: 0x0203001e 30 solenoid valve 1 (5hp18 e34) осталось теперь найти, что с ней делать((((
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
