//GR
0x0B210001 1 Faults in control unit
0x0B210002 1 Faults in control unit
0x0B210003 7 Encoding data fault
0x0B210005 1 Faults in control unit
0x0B210006 1 Faults in control unit
0x0B210007 1 Faults in control unit
0x0B210010 2 Status of actuator clutch
0x0B210011 3 Actuator deactivation time
0x0B210012 4 Actuator position
0x0B210013 6 Supply voltage of feedback potentiometer
0x0B210021 5 Data line of ,ulti-function steering wheel
0x0B210030 1 Faults in control unit
0x0B220001 1 Faults in control unit
0x0B220002 1 Faults in control unit
0x0B220003 7 Encoding data fault
0x0B220004 1 Faults in control unit
0x0B220005 1 Faults in control unit
0x0B220006 1 Faults in control unit
0x0B220007 1 Faults in control unit
0x0B220010 2 Status of actuator clutch
0x0B220011 3 Actuator deactivation time
0x0B220012 4 Actuator position
0x0B220013 6 Supply voltage of feedback potentiometer
0x0B220021 5 Data line of ,ulti-function steering wheel
0x0B220030 1 Faults in control unit
0x0B230001 01 Control-module fault
0x0B230002 02 Control-module fault
0x0B230003 03 Control-module fault, coding data
0x0B230004 04 Control-module fault, coding data
0x0B230005 05 Control-module fault, coding
0x0B230006 06 Control-module fault, hardware/software
0x0B230010 10 Short circuit, actuator clutch
0x0B230011 11 Actuator, deactivation time
0x0B230012 12 Actuator position
0x0B230013 13 Check back-potentiometer voltage
0x0B230021 21 Data line, multifunction steering wheel
//PDC
0x0C210010 10 Converter, rear left
0x0C210011 11 Converter, rear right
0x0C210012 12 Converter, rear center left
0x0C210013 13 Converter, rear center right
0x0C210014 14 Transducer, front left
0x0C210015 15 Transducer, front right
0x0C210016 16 Transducer, front middle left
0x0C210017 17 Transducer, front middle right
0x0C210018 18 Voltage, Converters in general
0x0C210020 20 Acoustic generator, rear, off
0x0C210021 21 Acoustic generator, rear, on
0x0C210022 22 Acoustic generator, front off
0x0C210023 23 Acoustic generator, front on
0x0C210024 24 Function indicator off
0x0C210025 25 Function indicator on
0x0C210026 26 Position sensor
0x0C210027 27 Button
0x0C210028 28 Control unit
0x0C619E2B 9E2B Ultrasonic sensor, rear left
0x0C619E2E 9E2E Ultrasonic sensor, rear centre right
0x0C619E33 9E33 Wire, ultrasonic sensor, rear left
0x0C619E34 9E34 Wire, ultrasonic sensor, rear right
0x0C619E35 9E35 Wire, ultrasonic sensor, rear centre left
0x0C619E36 9E36 Wire, ultrasonic sensor, rear centre right
0x0C619E37 9E37 Wire, ultrasonic sensor, front left
0x0C619E38 9E38 Wire, ultrasonic sensor, front right
0x0C619E39 9E39 Wire, ultrasonic sensor, front centre left
0x0C619E3A 9E3A Wire, ultrasonic sensor, front centre right
0x0C619E3B 9E3B Supply, ultrasonic sensors
0x0C619E28 9E28 Control unit, internal fault
0x0C619E29 9E29 Function display
0x0C619E2A 9E2A Park Distance Control button
0x0C619E2B 9E2B Transducer, rear left
0x0C619E2C 9E2C Transducer, rear right
0x0C619E2D 9E2D Transducer, rear centre left
0x0C619E2E 9E2E Transducer, rear centre right
0x0C619E2F 9E2F Transducer, front left
0x0C619E30 9E30 Transducer, front right
0x0C619E31 9E31 Transducer, front centre left
0x0C619E32 9E32 Transducer, front centre right
0x0C619E33 9E33 Transducer lines, rear left
0x0C619E34 9E34 Transducer lines, rear right
0x0C619E35 9E35 Transducer lines, rear centre left
0x0C619E36 9E36 Transducer lines, rear centre right
0x0C619E37 9E37 Transducer lines, front left
0x0C619E38 9E38 Transducer lines, front right
0x0C619E39 9E39 Transducer lines, front centre left
0x0C619E3A 9E3A Transducer lines, front centre right
0x0C619E3B 9E3B Transducer supply
//SZM
0x0D210000 00 Terminal 30
0x0D210001 01 Seat heating, left, short or open circuit
0x0D210002 02 Seat heating, right , short or open circuit
0x0D210003 03 Temp. sensor, seat heating, left, short to grnd.
0x0D210004 04 Temp. sens., seat heating, right, short to grnd.
0x0D210005 05 Temp. sensor, seat heating, left, open circuit
0x0D210006 06 Temp. sensor, seat heating, right, open circuit
0x0D210007 07 Seat heating, seat cushion, left, open circuit
0x0D210008 08 Seat heating, seat cushion, right, open circuit
0x0D210009 09 Roller sun blind, motor, short or open circuit
0x0D21000A 0A Wire active seat, left
0x0D21000B 0B Wire active seat, right
0x0D21000C 0C Active seat, left, fault in switching centre
0x0D21000D 0D Active seat, right, fault in switching centre
0x0D21000E 0E K bus
0x0D220001 01 Terminal 30
0x0D220002 02 Seat heating, left, short or open circuit
0x0D220003 03 Seat heating, right, short or open circuit
0x0D220004 04 Temp. sensor, seat heating, left, open circuit
0x0D220005 05 Temp. sensor, seat heating, left, short to grnd.
0x0D220006 06 Temp. sensor, seat heating, right, open circuit
0x0D220007 07 Temp. sensor, seat heating, right, short to grnd.
0x0D220008 08 Seat heating, seat cushion, left, open circuit
0x0D220009 09 Seat heating, seat cushion, right, open circuit
0x0D22000A 0A Roller sun blind, motor, open circuit
0x0D22000B 0B Roller sun blind, motor, short circuit
//BIT
0x0E210001 01 Internal control-unit fault
0x0E210002 02 Internal Control-unit fault
0x0E210003 03 Line TEL_ON1 short circuit to ground
0x0E210004 04 Line TEL_ON2 short circuit to ground
0x0E210005 05 Line TEL_ON3 short circuit to ground
0x0E210006 06 Line TEL_ON4 short circuit to ground
0x0E210007 07 DSP signal, short circuit to ground
0x0E210008 08 DSP signal, short circuit to positive
0x0E210009 09 MUTE signal, short circuit to positive
0x0E21000A 0A Currently not present
0x0E210010 10 I-bus fault
0x0E210012 12 GSM level not OK
0x0E220001 01 Wire,compensator,short circuit to ground
0x0E220002 02 Wire,compensator,short circuit to positive
0x0E220003 03 Terminal 15,short circuit to ground
0x0E220004 04 Terminal 15,short circuit to positive
0x0E220005 05 Charging lead,short circuit to ground
0x0E220006 06 Charging lead,short circuit to positive
0x0E220007 07 Activation wire DSP,short circuit to ground
0x0E220008 08 Activation wire DSP,short circuit to positive
0x0E220009 09 Radio muting,short circuit to ground
0x0E22000A 0A Radio muting,short circuit to positive
//LSZ
0x0F21000A 0A Control-unit fault
0x0F21000B 0B Control-unit fault
0x0F21000C 0C Control-unit fault
0x0F21000D 0D Control-unit fault
0x0F21000E 0E Control-unit fault
0x0F21000F 0F Control-unit fault
0x0F210010 10 Control-unit fault
0x0F210014 14 Wire, brake-light switch, open circuit
0x0F210015 15 Break-light switch, short circ. to negative
0x0F210016 16 Turn-signal switch, short circ. to negative
0x0F210017 17 Main beam/headl. flasher, short circ. to neg.
0x0F210018 18 Connection to AHM is disturbed
0x0F21001E 1E Control-mod. fault w/headlight-range adjust.
0x0F21001F 1F Activ'n, motor for headlight-range adjust.
0x0F210020 20 Activ'n, motor for headlight-range adjust. 2
0x0F210021 21 Front load sensor, open circuit
0x0F210022 22 Front load sensor, short circuit to negative
0x0F210023 23 Rear load sensor, open circuit
0x0F210024 24 Rear load sensor, short circuit to negative
0x0F210028 28 Terminal R missing
0x0F210029 29 Terminal 15 missing
0x0F210032 32 Break light, centre, faulty
0x0F210033 33 Sidelight, front right, faulty
0x0F210034 34 Break light, left, faulty
0x0F210035 35 Break light, right, faulty
0x0F210036 36 Turn indicator, front left, faulty
0x0F210037 37 Turn indicator, front right, faulty
0x0F210038 38 Sidelight, front left, faulty
0x0F210039 39 Main beam, left faulty
0x0F21003A 3A Main beam, right, faulty
0x0F21003B 3B Sidelight, rear left, faulty
0x0F21003C 3C Number-plate light faulty
0x0F21003D 3D Sidelight, rear right, faulty
0x0F21003E 3E Rear fog light faulty
0x0F21003F 3F Turn indicator, rear left, faulty
0x0F210040 40 Turn indicator, rear right, faulty
0x0F210041 41 Dipped beam, right, faulty
0x0F210042 42 Dipped beam, left, faulty
0x0F210043 43 Supplementary turn indicator, left, faulty
0x0F210044 44 Supplementary turn indicator, right, faulty
0x0F21004A 4A Trailer, left turn-signal flasher faulty
0x0F21004B 4B Trailer, right turn-signal flasher faulty
0x0F210050 50 Activ'n headl.-range adj. driver, sporad. fault
0x0F22000A 0A Control-unit fault
0x0F22000B 0B Control-unit fault
0x0F22000C 0C Control-unit fault
0x0F22000D 0D Control-unit fault
0x0F22000F 0F Control-unit fault
0x0F220010 10 Term. 30 A faulty
0x0F220011 11 Term. 30 A faulty
0x0F220012 12 Control-unit fault
0x0F220013 13 Control-unit fault
0x0F220014 14 Wire, break-light switch, open circuit
0x0F220015 15 Wire, break-light switch, short circuit
0x0F220016 16 Wire/switch, turn indic., sh. circ. to earth
0x0F220017 17 Wire/switch, main b./headl.fl., sh. circ. to earth
0x0F220018 18 Connection to AHM is disturbed
0x0F220019 19 High-beam switch-inputs contradictory
0x0F22001E 1E Control-unit fault in HVAC section
0x0F22001F 1F Coils, stepping motors, faulty
0x0F220021 21 Headl.v.a.c., front load sensor, open circ.
0x0F220022 22 Headl.v.a.c., front load sens., sh. circ. to earth
0x0F220023 23 Headl.v.a.c., rear load sensor, open circ.
0x0F220024 24 Headl.v.a.c., rear load sens., sh. circ. to earth
0x0F220028 28 Terminal R missing
0x0F220029 29 Terminal 15 missing
0x0F22002A 2A HVAC potentiometer faulty
0x0F22002B 2B Dimmer potentiometer faulty
0x0F220032 32 Break light, centre, faulty
0x0F220033 33 Sidelight, front right, faulty
0x0F220034 34 Break light, left, faulty
0x0F220035 35 Break light, right, faulty
0x0F220036 36 Turn indicator, front left, faulty
0x0F220037 37 Turn indicator, front right, faulty
0x0F220038 38 Sidelight, front left, faulty
0x0F220039 29 Main beam, left, faulty
0x0F22003A 3A Main beam, right, faulty
0x0F22003B 3B Sidelight, rear left, faulty
0x0F22003C 3C Number-plate light faulty
0x0F22003D 3D Sidelight, rear right, faulty
0x0F22003E 3E Rear fog lights faulty
0x0F22003F 3F Turn indicator, rear left, faulty
0x0F220040 40 Turn indicator, rear right, faulty
0x0F220041 41 Dipped beam, right, faulty
0x0F220042 42 Dipped beam, left, faulty
0x0F220043 43 Supplementary turn indicator, left, faulty
0x0F220044 44 Supplementary turn indicator, right, faulty
0x0F220045 45 Side light 2, rear right, faulty
0x0F220046 46 Side light 3, rear left, faulty
0x0F220047 47 Side light 3, rear right, faulty
0x0F22004A 4A Trailer, left turn-signal flasher faulty
0x0F22004B 4B Trailer, right turn-signal flasher faulty
0x0F220050 50 Sporadic fault on activ. of headl.v.a.c driver
0x0F220051 51 Transport mode active
0x0F230078 120 Left low beam faulty
0x0F230079 121 Right low beam faulty
0x0F23007A 122 Front left parking light faulty
0x0F23007B 123 Front right parking light faulty
0x0F23007C 124 Front left turn-signal flasher faulty
0x0F23007D 125 Front right turn-signal flasher faulty
0x0F23007E 126 Right fog lamp faulty
0x0F23007F 127 Left fog lamp faulty
0x0F230080 128 Left high beam faulty
0x0F230081 129 Right high beam faulty
0x0F23008C 140 Left tail light faulty
0x0F23008D 141 Right reversing light faulty
0x0F23008E 142 Inside left reversing light faulty
0x0F23008F 143 Inside right reversing light faulty
0x0F230090 144 Rear left turn-signal falsher faulty
0x0F230091 145 Rear right turn-signal falsher faulty
0x0F230092 146 Left brake light faulty
0x0F230093 147 Right brake light faulty
0x0F230094 148 Left rear fog light faulty
0x0F230095 149 Right rear fog light faulty
0x0F230096 150 Left reversing light faulty
0x0F230097 151 Right reversing light faulty
0x0F230098 152 Middle brake light faulty
0x0F230099 153 Number-plate lamp faulty
0x0F24000A 0A Control-unit fault
0x0F24000B 0B Control-unit fault
0x0F24000C 0C Control-unit fault
0x0F24000D 0D Control-unit fault
0x0F24000F 0F Control-unit fault
0x0F240010 10 Term. 30 A faulty
0x0F240011 11 Term. 30 A faulty
0x0F240012 12 Control-unit fault
0x0F240013 13 Control-unit fault
0x0F240014 14 Wire, break-light switch, open circuit
0x0F240015 15 Wire, break-light switch, short circuit to earth
0x0F240016 16 Wire/switch, turn indic., sh. circ. to earth
0x0F240017 17 Wire/switch, main b./headl.fl., sh. circ. to earth
0x0F240018 18 Connection to AHM is disturbed
0x0F240019 19 High-beam switch-inputs contradictory
0x0F24001E 1E Control-unit fault in HVAC section
0x0F24001F 1F Coils, stepping motors, faulty
0x0F240021 21 Headl.v.a.c., front load sensor, open circ.
0x0F240022 22 Headl.v.a.c., front load sens., sh. circ. to earth
0x0F240023 23 Headl.v.a.c., rear load sensor, open circ.
0x0F240024 24 Headl.v.a.c., rear load sens., sh. circ. to earth
0x0F240028 28 Terminal R missing
0x0F240029 29 Terminal 15 missing
0x0F24002A 2A HVAC potentiometer faulty
0x0F24002B 2B Dimmer potentiometer faulty
0x0F240032 32 Break light, centre, faulty
0x0F240033 33 Sidelight, front right, faulty
0x0F240034 34 Break light, left, faulty
0x0F240035 35 Break light, right, faulty
0x0F240036 36 Turn indicator, front left, faulty
0x0F240037 37 Turn indicator, front right, faulty
0x0F240038 38 Sidelight, front left, faulty
0x0F240039 39 Main beam, left, faulty
0x0F24003A 3A Main beam, right, faulty
0x0F24003B 3B Sidelight, rear left, faulty
0x0F24003C 3C Number-plate light faulty
0x0F24003D 3D Sidelight, rear right, faulty
0x0F24003E 3E Rear fog lights faulty
0x0F24003F 3F Turn indicator, rear left, faulty
0x0F240040 40 Turn indicator, rear right, faulty
0x0F240041 41 Dipped beam, right, faulty
0x0F240042 42 Dipped beam, left, faulty
0x0F240043 43 Supplementary turn indicator, left, faulty
0x0F240044 44 Supplementary turn indicator, right, faulty
0x0F240045 45 Side light 2, rear right, faulty
0x0F240046 46 Side light 3, rear left, faulty
0x0F240047 47 Side light 3, rear right, faulty
0x0F24004A 4A Trailer, left turn-signal flasher faulty
0x0F24004B 4B Trailer, right turn-signal flasher faulty
0x0F240050 50 Sporadic fault on activ. of headl.v.a.c driver
0x0F240051 51 Transport mode active
//LEW
0x10210001 01 Supply (terminal 30)
0x10210002 02 Sensor current outside tolerance
0x10210003 03 Slider fault (normal operation)
0x10210004 04 Slider fault (adjustment operation)
0x10210005 05 Internal fault (EEPROM)
0x10210006 06 Internal fault (A/D converter)
0x10210007 07 Internal fault (ROM)
0x10210008 08 Internal fault (RAM)
0x1021000A 0A CAN version incorrect
0x1021000B 0B Sensor/vehicle allocation incorrect or not available
0x1021000C 0C CAN BUS OFF
0x1021000D 0D Steering speed implausible
0x1021000E 0E Steering angle implausible
0x1021000F 0F Internal fault (stack)
//RAD
0x11210001 01 Fault in the CD-changer interface
0x11210002 02 Fault in aerial power supply
0x11220000 00 Transport mode active
0x11220001 01 Fault in the CD-changer interface
0x11220002 02 Fault in aerial power supply
//EHC
0x12210001 01 Ride-level sensor,left
0x12210002 02 Ride-level sensor,right
0x12210003 03 Compressor relay
0x12210004 04 Valve, left
0x12210005 05 Valve, right
0x12210006 06 Drain valve
0x12210007 07 Control unit
0x12210008 08 Control-time fault 'lifting'
0x12210009 09 Control-time fault 'Lowering'
0x1221000A 0A Control-time fault 'One - sided'
0x12220001 01 Height sensor, left
0x12220002 02 Height sensor, right
0x12220003 03 Compressor relay
0x12220004 04 Valve, left
0x12220005 05 Valve, right
0x12220006 06 Drain valve
0x12220007 07 Control unit
0x12220008 08 Control-time fault 'Raising'
0x12220009 09 Control-time fault 'Lowering'
0x1222000A 10 Control-time fault 'One - sided'
0x12615F8E 5F8E Ride-level sensor,rear left
0x12615F8F 5F8F Ride-level sensor,rear right
0x12615F90 5F90 Supply,air suspension
0x12615F92 5F92 Supply,ride-level sensor,rear left
0x12615F93 5F93 Supply,ride-level sensor,rear right
0x12615F94 5F94 Solenoid value,rear left
0x12615F95 5F95 Solenoid value,rear right
0x12615F96 5F96 Drain value
0x12615F97 5F97 Compressor relay
0x12615F98 5F98 Control-time fault,lifting,rear left
0x12615F99 5F99 Control-time fault,lifting,rear right
0x12615F9A 5F9A Control-time fault,lifting
0x12615F9B 5F9B Control-time fault,lowering
0x12615F9C 5F9C Sensor activity,ride-level sensor,rear left
0x12615F9D 5F9D Sensor activity,ride-level sensor,rear right
0x12615FB0 5FB0 Control unit,internal fault
0x12615FB1 5FB1 Control-unit fault(EEPROM memory)
0x12615FB2 5FB2 Control-unit fault(flash memory)
0x12615FB3 5FB3 Checksum error,RAM error
0x12615FB4 5FB4 Energy-saving mode active
//BM
0x13210001 01 Control unit reset
0x13210002 02 PL line: short circuit to batt. +
0x13210003 03 PL line: short circuit to earth
0x13210004 04 PL line: open circuit
0x13210005 05 Overtemperature, monitor
0x13210006 06 Acknowledgement from radio not received
0x13210007 07 Fault, audio output, left +
0x13210008 08 Fault, audio output, left -
0x13210009 09 Fault, audio output, right +
0x1321000A 10 Fault, audio output, right -
0x1321000B 11 I-bus fault
0x1321000C 12 Forced switch-off, independent heating LED
//AIC
0x14210001 01 Internal hardware fault
0x14210002 02 No adaptation to windscreen possible
0x14210003 03 Supply voltage or temperature
0x14210004 04 Internal hardware fault
0x14210006 06 Reset contact not detected
0x14220001 10 Light sensor
0x14220002 20 Sensor not coded
0x14220003 30 Light sensor
0x14220004 40 Optical initialisation
0x14220005 50 Optical initialisation
0x14220006 60 Optical initialisation
0x14220007 70 Optical initialisation
0x14220008 80 Control unit
0x14220009 90 Control unit
0x1422000A A0 Control unit
0x1422000B B0 Control unit
0x1422000C C0 Control unit
0x1422000D D0 Control unit
0x1422000E E0 Control unit
0x1422000F F0 Control unit
//NAV
0x15210001 01 Navigation computer
0x15210002 02 Wheel sensor
0x15210003 03 Inputs,peripherals
0x15210004 04 GPS receiver does not respond to initialization of NavMk3
0x15210005 05 Temperature too high
0x15210006 06 Application software
0x15210007 07 Display
0x15210008 08 Audio
0x15210009 09 CD fault
0x1561D7D0 D7D0 Ring-break diagnosis has been carried out
0x1561D7D2 D7D2 Deactivation, high temperature
//VID
0x17210003 03 Transport mode active
0x17210029 29 Transport mode active
//MID
0x19210005 5 Transport mode active
//SHD
0x1A210001 1 Relays
0x1A210002 2 Incremental sensor
0x1A210003 3 Control switch
0x1A210004 4 Control-module fault
0x1A220008 08 Internal control-unit fault
0x1A220009 09 Internal control-unit fault
0x1A22000A 0A Internal control-unit fault
0x1A22000B 0B Internal control-unit fault
0x1A22000D 0D Internal control-unit fault
0x1A22000E 0E Transport mode active
0x1A220085 85 Internal control-unit fault
0x1A220088 88 Control switch
0x1A22008A 8A Switch backlighting
0x1A22008D 8D Coding
0x1A220090 90 Roof unit, slide/tilt sunroof
0x1A220091 91 Drive, slide/tilt sunroof
0x1A220092 92 Normalization, slide/tilt sunroof
0x1A2200A0 A0 Roof unit, sliding visor
0x1A2200A1 A1 Drive, sliding visor
0x1A2200A2 A2 Normalization, sliding visor
0x1A810001 01 Relay in module does not pick up
0x1A810002 02 Relay in module does not pick up
0x1A810003 03 Relay in module does not pick up
0x1A810004 04 Relay in module does not pick up
0x1A810005 05 Relay in module sticks
0x1A810006 06 Relay in module sticks
0x1A810007 07 Relay in module sticks
0x1A810008 08 Relay in module sticks
0x1A810009 09 Rear position sensor faulty or polarity of motor reversed
0x1A81000A 10 Front position sensor faulty or polarity of motor reversed
0x1A81000B 11 Rear position sensor or rear motor faulty
0x1A81000C 12 Front position sensor or front motor faulty
0x1A81000D 13 Power supply faulty
0x1A81000E 14 One motor faulty or wires are short-circuited to earth
0x1A81000F 15 SHD switch or wires faulty
0x1A810010 16 Internal fault
//SMF
0x1B210000 00 Hall sensor, backrest angle: short circuit to negative
0x1B210001 01 Hall sensor, backrest angle: open circuit
0x1B210002 02 Hall sensor, backrest angle: short circuit to positive
0x1B210003 03 Hall sensor, seat height: short circuit to negative
0x1B210004 04 Hall sensor, seat height: open circuit
0x1B210005 05 Hall sensor, seat height: short circuit to positive
0x1B210006 06 Hall sensor, seat angle: short circuit to ground
0x1B210007 07 Hall sensor, seat angle: open circuit
0x1B210008 08 Hall sensor, seat angle: short circuit to positive
0x1B210009 09 Hall sensor, seat sled: short circuit to negative
0x1B21000A 0A Hall sensor, seat sled: open circuit
0x1B21000B 0B Hall sensor, seat sled: short circuit to positive
0x1B21000C 0C Supply voltage, Hall sensors: short circuit to positive
0x1B21000D 0D Control-module fault: motor bridge faulty
0x1B220000 00 Hall sensor, backrest angle: short circuit to ground
0x1B220001 01 Hall sensor, backrest angle: open circuit
0x1B220002 02 Hall sensor, backrest angle: short circuit to positive
0x1B220003 03 Hall sensor, seat height: short circuit to ground
0x1B220004 04 Hall sensor, seat height: open circuit
0x1B220005 05 Hall sensor, seat height: short circuit to positive
0x1B220006 06 Hall sensor, seat angle: short circuit to ground
0x1B220007 07 Hall sensor, seat angle: open circuit
0x1B220008 08 Hall sensor, seat angle: short circuit to positive
0x1B220009 09 Hall sensor, seat carriage: short circuit to ground
0x1B22000A 0A Hall sensor, seat carriage: open circuit
0x1B22000B 0B Hall sensor, seat carriage: short circuit to positive
0x1B22000C 0C Hall sensor, head restraint: short circuit to positive
0x1B22000D 0D Hall sensor, head restraint: open circuit
0x1B22000E 0E Hall sensor, head restraint: short circuit to positive
0x1B22000F 0F Hall sensor, backrest lock: short circuit to ground
0x1B220010 10 Hall sensor, backrest lock: open circuit
0x1B220011 11 Hall sensor, backrest lock: short circuit to positive
0x1B220012 12 Hall sensor ST2 not connected: short circuit to ground
0x1B220013 13 Control-unit fault: motor bridge faulty
0x1B220014 14 Seat control switch: short circuit to positive
0x1B220015 15 Seat control switch: short circuit to ground
//SPMBT
0x1C210004 04 Mirror-adjustment switch,open circuit
0x1C210005 05 Mirror heater,open circuit
0x1C210006 06 Mirror heater,short circuit
0x1C210007 07 Mirror motor,potentiometer,vertical
0x1C210008 08 Mirror motor,potentiometer,horizontal
0x1C210009 09 Mirror motor,vertical,open circuit
0x1C21000A 0A Mirror motor,vertical,short circuit
0x1C21000B 0B Mirror motor,horizontal,open circuit
0x1C21000C 0C Mirror motor,horizontal,short circuit
0x1C21000D 0D Mirror motor,folding-in,open circuit
0x1C21000E 0E Mirror motor,folding-in,short circuit
//SMPFT
0x1D210004 04 Mirror-adjustment switch,open circuit
0x1D210005 05 Mirror heater,open circuit
0x1D210006 06 Mirror heater,short circuit
0x1D210007 07 Mirror motor,potentiometer,vertical
0x1D210008 08 Mirror motor,potentiometer,horizontal
0x1D210009 09 Mirror motor,vertical,open circuit
0x1D21000A 0A Mirror motor,vertical,short circuit
0x1D21000B 0B Mirror motor,horizontal,open circuit
0x1D21000C 0C Mirror motor,horizontal,short circuit
0x1D21000D 0D Mirror motor,folding-in,open circuit
0x1D21000E 0E Mirror motor,folding-in,short circuit
//VTG
0x1E415208 5208 Supply, servomotor
0x1E4152D0 52D0 Lead, servomotor (signal name: DIR)
0x1E4152D1 52D1 Incremental transducer in servomotor, supply
0x1E4152D2 52D2 Lead, servomotor (signal name: IMP)
0x1E4152D4 52D4 Incremental transducer
0x1E415398 5398 Control unit, internal (flash)
0x1E415399 5399 Control unit, internal (EEPROM)
0x1E41539A 539A Control unit, internal (watchdog)
0x1E41539B 539B Control unit, internal (RAM)
0x1E41539D 539D Control unit, internal
0x1E41539E 539E Transfer case malfunction
0x1E4153A0 53A0 Coding incorrect
0x1E4153FB 53FB Supply, control unit: reset due to undervoltage
0x1E4153FC 53FC Supply, control unit: terminal 30
0x1E4153FE 53FE Control unit, internal (unexpected reset)
0x1E4153FF 53FF Supply, control unit: terminal 15
0x1E415460 5460 Motor current measurement faulty
0x1E415461 5461 Activation, servomotor, faulty
0x1E415462 5462 Servomotor or coupling force too high
0x1E415463 5463 Mechanism faulty
0x1E4154C4 54C4 Calibration faulty
0x1E4154C5 54C5 Offset, motor current measurement
0x1E4154C6 54C6 Oil wear
0x1E4154C7 54C7 Incremental-transducer model implausible
0x1E4154C8 54C8 Classification resistor
0x1E4155C0 55C0 Limp-home controller, abort
0x1E6155C3 55C3 AWD limp-home control activated. No DSC specified nominal torque.
//CID
0x1F41A469 A469 Control-module fault
0x1F41A46A A46A Temperature deactivation
0x1F41A46B A46B Control-module fault
0x1F41A46C A46C Transport mode active
0x1F61A468 A468 External open circuit (LVDS data line)
0x1F61A469 A469 Internal control-module fault
0x1F61A46A A46A Cutout due to overtemperature (no fault)
0x1F61A46B A46B Internal control-module fault
0x1F61A46C A46C Transport mode active
//EPS
0x2041D6FE D6FE Day/night switch signal
0x2041FFFF FFFF Unknown fault location
0x2041610C 610C Comparison,rotor anglesteering angle
0x2041610D 610D CAN bus
0x2041610E 610E Temperature EPS
0x2041610F 610F EEPROM,no risk
0x20416110 6110 Sensor supply
0x20416111 6111 ROM checksum
0x20416112 6112 Ignition
0x20416113 6113 Intelligent watchdog
0x20416114 6114 compare
0x20416115 6115 RAM
0x20416116 6116 Relays
0x20416117 6117 Internal voltage
0x20416118 6118 Control,servomotor
0x20416119 6119 Speed,servomotor
0x2041611A 611A Phase voltage,servomotor
0x2041611B 611B Steering angle
0x2041611C 611C Steering torque
0x2041611D 611D Power supply
0x2041611E 611E Vehicle speed
0x2041611F 611F Program
0x20416120 6120 Sport button display
0x20416121 6121 Vehicle engine speed
0x20416122 6122 EEPROM,high risk
0x20416123 6123 Module,engine control
0x20416124 6124 Power reduction due to overtemperature
0x20416125 6125 Steering angle correction
0x20416126 6126 Power reduction due to overloading
0x20416127 6127 Steering angle
0x20416128 6128 Vehicle speed
0x20416129 6129 Vehicle engine speed
0x2041612A 612A Mileage/km reading
0x2041612B 612B Sport button signal
0x2041612C 612C Day/night switch signal
0x2041612D 612D Steering angle correction
0x2041612E 612E Comparison,rotor anglesteering angle
//SBSL
0x21419828 9828 Processor:reset
0x21419829 9829 Control-unit fault
0x2141982A 982A Control-unit fault
0x2141982B 982B Incorrect chassis number
0x2141982C 982C System time fault
0x2141983E 983E Control-unit fault
0x21419840 9840 Coding-data error
0x21419841 9841 Coding-data error
0x21419842 9842 Self-test:too few messages
0x21419843 9843 Self-test:data error in message
0x21419844 9844 Self-test:transmission error
0x21419845 9845 Implausible crash severity
0x21419846 9846 Control-unit fault
0x21419847 9847 Short circuit,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to ground
0x21419848 9848 Short circuit,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to positive
0x21419849 9849 Resistance,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to low
0x2141984A 984A Resistance,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to high
0x2141984B 984B Resistance,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),to measured
0x2141984C 984C Open circuit,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x)
0x2141984D 984D Control-unit fault
0x2141984E 984E Control-unit fault
0x2141984F 984F Coding,firing circuit,front airbag,left,stage 1(E85),or active head restraint,front left(E6x),at variance
0x21419850 9850 Control-unit fault
0x21419851 9851 Control-unit fault
0x21419852 9852 Short circuit,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),to ground
0x21419853 9853 Short circuit,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),to positive
0x21419855 9854 Resistance,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),too low
0x21419855 9855 Resistance,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),too high
0x21419856 9856 Resistance,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),not measured
0x21419857 9857 Open circuit,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x)
0x21419858 9858 Control-unit fault
0x21419859 9859 Control-unit fault
0x2141985A 985A Coding ,firing circuit,front airbag,left,stage 2(E85),or active head restraint,front right(E6x),at variance
0x2141985B 985B Control-unit fault
0x2141985C 985C Control-unit fault
0x2141985D 985D Short circuit,firing circuit,belt tensioner,front left,to ground
0x2141985E 985E Short circuit,firing circuit,belt tensioner,front left,to positive
0x2141985F 985F Resistance,firing circuit,belt tensioner,front left,too low
0x21419860 9860 Resistance,firing circuit,belt tensioner,front left,too high
0x21419861 9861 Resistance,firing circuit,belt tensioner,front left,not measured
0x21419862 9862 Open circuit,firing circuit,belt tensioner,front left
0x21419863 9863 Control-unit fault
0x21419864 9864 Control-unit fault
0x21419865 9865 Coding,firing circuit,belt tensioner,front left,at variance
0x21419866 9866 Control-unit fault
0x21419867 9867 Control-unit fault
0x21419868 9868 Short circuit,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),to ground
0x21419869 9869 Short circuit,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),to positive
0x2141986A 986A Resistance,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),too low
0x2141986B 986B Resistance,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),too high
0x2141986C 986C Resistance,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64),not measured
0x2141986D 986D Open circuit,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64)
0x2141986E 986E Control-unit fault
0x2141986F 986F Control-unit fault
0x21419870 9870 Coding,firing circuit,thorax airbag,rear left(E85,E60,E61),or knee airbag,front left(E63,E64) at variance
0x21419871 9871 Control-unit fault
0x21419872 9872 Control-unit fault
0x21419873 9873 Short circuit,firing circuit,belt tensioner,rear left,to ground
0x21419874 9874 Short circuit,firing circuit,belt tensioner,rear left,to positive
0x21419875 9875 Resistance,firing circuit,belt tensioner,rear left,too low
0x21419876 9876 Resistance,firing circuit,belt tensioner,rear left,too high
0x21419877 9877 Resistance,firing circuit,belt tensioner,rear left,not measured
0x21419878 9878 Open circuit,firing circuit,belt tensioner,rear left
0x21419879 9879 Control-unit fault
0x2141987A 987A Control-unit fault
0x2141987B 987B Coding,firing circuit,belt tensioner,rear left,at variance
0x2141987C 987C Control-unit fault
0x2141987D 987D Control-unit fault
0x2141987E 987E Short circuit,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),to ground
0x2141987F 987F Short circuit,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),to positive
0x21419880 9880 Resistance,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),too low
0x21419881 9881 Resistance,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),too high
0x21419882 9882 Resistance,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),not measured
0x21419883 9883 Open circuit,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x)
0x21419884 9884 Control-unit fault
0x21419885 9885 Control-unit fault
0x21419886 9886 Coding,firing circuit,knee airbag,front left(E85),or head airbag,left(E6x),at variance
0x21419887 9887 Control-unit fault
0x21419888 9888 Control-unit fault
0x21419889 9889 Control-unit fault
0x2141988A 988A Control-unit fault
0x2141988B 988B Control-unit fault
0x2141988C 988C Control-unit fault
0x2141988D 988D Control-unit fault
0x2141988E 988E Control-unit fault
0x2141988F 988F Seat-belt buckle:short circuit
0x21419890 9890 Seat-belt buckle:implausible ,measured value
0x21419891 9891 Seat-belt buckle:open circuit
0x21419892 9892 Control unit fault(E6x) or software error(E85)
0x21419893 9893 Seat-occupancy detector,passenger:open circuit
0x21419894 9894 Seat-occupancy detector,passenger:short circuit
0x21419895 9895 Seat-occupancy detector,passenger:communication fault
0x21419896 9896 Control-unit fault
0x21419897 9897 Control-unit fault
0x21419898 9898 Firing attempt taken place
0x21419899 9899 Control-unit fault
0x2141989E 989E Voltage supply not in permitted range
//SBSL MODE5
0x2161982C 982C System time fault
0x21619842 9842 Self-Test: too few messages
//SBSR
0x224198A8 98A8 Processor:reset
0x224198A9 98A9 Control-unit fault
0x224198AA 98AA Control-unit fault
0x224198AB 98AB Incorrect chassis number
0x224198AC 98AC System time fault
0x224198AE 98AE Control-unit fault
0x224198C0 98C0 Coding-data error
0x224198C1 98C1 Coding-data error
0x224198C2 98C2 Self-test:too few messages
0x224198C3 98C3 Self-test:data error in message
0x224198C4 98C4 Self-test:transmission error
0x224198C5 98C5 Implausible crash severity
0x224198C6 98C6 Control-unit fault
0x224198C7 98C7 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,to ground
0x224198C8 98C8 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,to positive
0x224198C9 98C9 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,too low
0x224198CA 98CA Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,too high
0x224198CB 98CB Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,not measured
0x224198CC 98CC Open circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1
0x224198CD 98CD Control-unit fault
0x224198CE 98CE Control-unit fault
0x224198CF 98CF Coding,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 1,at variance
0x224198D0 98D0 Control-unit fault
0x224198D1 98D1 Control-unit fault
0x224198D2 98D2 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,to ground
0x224198D3 98D3 Short circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,to positive
0x224198D4 98D4 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,too low
0x224198D5 98D5 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,too high
0x224198D6 98D6 Resistance,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,not measured
0x224198D7 98D7 Open circuit,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2
0x224198D8 98D8 Control-unit fault
0x224198D9 98D9 Control-unit fault
0x224198DA 98DA Coding,firing circuit,front airbag,right(E85),or passenger airbag(E6x),stage 2,at variance
0x224198DB 98DB Control-unit fault
0x224198DC 98DC Control-unit fault
0x224198DD 98DD Short circuit,firing circuit,belt tensioner,front right,to ground
0x224198DE 98DE Short circuit,firing circuit,belt tensioner,front right,to positive
0x224198DF 98DF Resistance,firing circuit,belt tensioner,front right,too low
0x224198E0 98E0 Resistance,firing circuit,belt tensioner,front right,too high
0x224198E1 98E1 Resistance,firing circuit,belt tensioner,front right,not measured
0x224198E2 98E2 Open circuit,firing circuit,belt tensioner,front right
0x224198E3 98E3 Control-unit fault
0x224198E4 98E4 Control-unit fault
0x224198E5 98E5 Coding,firing circuit,belt tensioner,front right,at variance
0x224198E6 98E6 Control-unit fault
0x224198E7 98E7 Control-unit fault
0x224198E8 98E8 Short circuit,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),to ground
0x224198E9 98E9 Short circuit,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),to positive
0x224198EA 98EA Resistance,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),too low
0x224198EB 98EB Resistance,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),too high
0x224198EC 98EC Resistance,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64),not measured
0x224198ED 98ED Open circuit,firing circuit,thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64)
0x224198EE 98EE Control-unit fault
0x224198EF 98EF Control-unit fault
0x224198F0 98F0 Coding,firing circuit, thorax airbag,rear right(E85,E60,E61),or knee airbag,front right(E63,E64) at variance
0x224198F1 98F1 Control-unit fault
0x224198F2 98F2 Control-unit fault
0x224198F3 98F3 Short circuit,firing circuit,safety battery terminal(E85),or belt tensioner,rear right(E6x),to ground
0x224198F4 98F4 Short circuit,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),to positive
0x224198F5 98F5 Resistance,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),too low
0x224198F6 98F6 Resistance,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),too high
0x224198F7 98F7 Resistance,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x),not measured
0x224198F8 98F8 Open circuit,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x)
0x224198F9 98F9 Control-unit fault
0x224198FA 98FA Control-unit fault
0x224198FB 98FB Coding,firing circuit, safety battery terminal(E85),or belt tensioner,rear right(E6x) ,at variance
0x224198FC 98FC Control-unit fault
0x224198FD 98FD Control-unit fault
0x224198FE 98FE Short circuit,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too ground
0x224198FF 98FF Short circuit,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too positive
0x22419900 9900 Resistance,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too low
0x22419901 9901 Resistance,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),too high
0x22419902 9902 Resistance,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),not measured
0x22419903 9903 Open circuit,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x)
0x22419904 9904 Control-unit fault
0x22419905 9905 Control-unit fault
0x22419906 9906 Coding,firing circuit,knee airbag,front right(E85),or head airbag,right(E6x),at variance
0x22419907 9907 Control-unit fault
0x22419908 9908 Control-unit fault
0x22419909 9909 Control-unit fault
0x2241990A 990A Control-unit fault
0x2241990B 990B Control-unit fault
0x2241990C 990C Control-unit fault
0x2241990D 990D Control-unit fault
0x2241990E 990E Control-unit fault
0x2241990F 990F Seat-belt buckle:short circuit
0x22419910 9910 Seat-belt buckle:implausible measured value
0x22419911 9911 Seat-belt buckle:open circuit
0x22419912 9912 Control unit fault(E6x) or software error(E85)
0x22419913 9913 Seat-occupancy detector,passenger:open circuit
0x22419914 9914 Seat-occupancy detector,passenger:short circuit
0x22419915 9915 Seat-occupancy detector,passenger:communication fault
0x22419916 9916 Control-unit fault
0x22419917 9917 Control-unit fault
0x22419918 9918 Firing attempt taken place
0x22419919 9919 Control-unit fault
0x2241991A 991A Battery lead(shield):open circuit
0x2241991B 991B Battery lead(shield):short circuit to ground
0x2241991C 991C Battery lead(shield):short circuit to positive
0x2241991D 991D Battery lead(shield):implausible measured value
0x2241991E 991E Voltage supply not in permitted range
0x226198AC System time fault
0x226198C2 Self-test: too few messages
0x226198D5 Resistance, firing circuit, safety battery terminal, too high
//CVM
0x23210001 01 Coding-data record invalid, not coded
0x23210002 02 Coding implausible
0x23210003 03 Control-unit fault, internal memory
0x23210004 04 Control-unit fault, internal memory
0x23210005 05 Control-unit fault, coding data
0x23210006 06 Control-unit fault, internal memory
0x23210007 07 Control-unit fault
0x23210008 08 Control-unit fault
0x23210009 09 Control-unit fault
0x2321000A 0A K bus faulty
0x23210010 10 Voltage supply to switch in car faulty
0x23210011 11 Voltage supply to switch on convertible top faulty
0x23210012 12 Open control button permanently active
0x23210013 13 Close control button permanently active
0x23210014 14 Temperature-sensor input, permanently to ground
0x23210015 15 Temperature sensor open-circuited
0x23210016 16 Position switch for main pillar, open circuit
0x23210017 17 Position switch for main pillar, short circuit to ground
0x23210018 18 Position switch for tension bar, open circuit
0x23210019 19 Position switch for tension bar, short circuit to ground
0x2321001A 1A Switch, convertible-top comp. lid, voltage > 2.5V
0x2321001B 1B Switch, convertible-top comp. lid, voltage undefined
0x2321001C 1C Switch, convertible-top comp. lid, short to ground or open circuit
0x2321001D 1D Switch, cowl locked, voltage > 2.5V
0x2321001E 1E Switch, cowl locked, voltage undefined
0x2321001F 1F Switch, cowl locked, short to ground or open circuit
0x23210020 20 Switch, cowl unlocked, voltage > 2.5V
0x23210021 21 Switch, cowl unlocked, voltage undefined
0x23210022 22 Switch, cowl unlocked, short to ground or open circuit
0x23210023 23 Switch, convertible-top comp. lid, right, locked, voltage > 2.5V
0x23210024 24 Switch, convertible-top comp. lid, right, locked, voltage undefined
0x23210025 25 Switch, convertible-top comp. lid, right, locked, short to ground or open circuit
0x23210026 26 Switch, convertible-top comp. lid, left, locked, voltage > 2.5V
0x23210027 27 Switch, convertible-top comp. lid, left, locked, voltage undefined
0x23210028 28 Switch, convertible-top comp. lid, left, locked, short to ground or open circuit
0x23210029 29 Switch, convertible-top locked, voltage > 2.5V
0x2321002A 2A Switch, convertible-top locked, voltage undefined
0x2321002B 2B Switch, convertible-top locked, short to ground or open circuit
0x2321002C 2C VSW 9, voltage > 5V
0x2321002D 2D VSW 9, voltage undefined
0x2321002E 2E VSW 9, short circuit to ground
0x2321002F 2F Switch, hard top, voltage > 2.5V
0x23210030 30 Switch, hard top, voltage undefined
0x23210031 31 Switch, hard top, short to ground or open circuit
0x23210040 40 Drive, cowl, motor current too high during unlocking
0x23210041 41 Drive, cowl, motor current too high during unlocking
0x23210042 42 Drive, cowl, short circuit to +ve
0x23210043 43 Drive, cowl, fault during unlocking
0x23210044 44 Drive, cowl, fault during unlocking
0x23210045 45 Valve, retract clamping bracket, open circuit
0x23210046 46 Valve, retract clamping bracket, short circuit to ground
0x23210047 47 Valve, retract clamping bracket, short circuit to +ve
0x23210048 48 Valve, extend clamping bracket, open circuit
0x23210049 49 Valve, extend clamping bracket, short circuit to ground
0x2321004A 4A Valve, extend clamping bracket, short circuit to +ve
0x2321004B 4B Short between valve, retract clamping bracket, and valve, main pillar
0x2321004C 4C Valve, main pillar, open circuit
0x2321004D 4D Valve, main pillar, short circuit to ground
0x2321004E 4E Valve, main pillar, short circuit to ground
0x23210050 50 Valve, emergency release, open circuit
0x23210051 51 Valve, emergency release, short circuit to ground
0x23210052 52 Valve, emergency release, short circuit to positive
0x23210053 53 Relay, convertible top drive, open circuit
0x23210054 54 Relay, convertible top drive, short circuit to ground
0x23210055 55 Relay, convertible top drive, short circuit to positive
0x23210056 56 Short circuit between output, relay, convertible top drive, and valve, emergency release
0x23210057 57 Valve, convertible-top comp. lid, open circuit
0x23210058 58 Valve, convertible-top comp. lid, short circuit to ground
0x23210059 59 Valve, convertible-top comp. lid, short circuit to +ve
0x23210060 60 Convertible-top compartment lid is not raised
0x23210061 61 Convertible-top compartment lid is not opened
0x23210062 62 Convertible-top compartment lid is not closed
0x23210063 63 Main pillar does not pull clamping bracket from convertible-top compartment
0x23210064 64 Main pillar does not force clamping bracket into convertible-top compartment
0x23210065 65 Clamping bracket is not fully raised
0x23210066 66 Clamping bracket does not locate engagement area
0x23210067 67 Cowl does not move upwards
0x23210068 68 Cowl does not move downwards
0x23220001 01 Control unit not coded
0x23220002 02 Coding data incorrect
0x23220003 03 Control unit
0x23220005 05 Coding data incorrect
0x23220006 06 Control unit
0x23220007 07 Control unit
0x23220008 08 Control unit
0x23220009 09 Control unit
0x23220011 11 Supply,convertible-top switch(Hall sensors)
0x23220012 12 Control button,short circuit when opening
0x23220013 13 Control button,short circuit when closing
0x2322001A 1A Switch,convertible top closed,short circuit to positive
0x2322001B 1B Switch,convertible top closed,undefined voltage range
0x2322001C 1C Switch,convertible top closed, short circuit to ground
0x2322001D 1D Switch,cowl panel locked,short circuit to positive
0x2322001E 1E Switch,cowl panel locked, undefined voltage range
0x2322001F 1F Switch,cowl panel locked,short circuit to ground
0x23220020 20 Switch,cowl panel unlocked,short circuit to positive
0x23220021 21 Switch,cowl panel unlocked, undefined voltage range
0x23220022 22 Switch,cowl panel unlocked,short circuit to ground
0x23220023 23 Switch,convertible top stowed,short circuit to positive
0x23220024 24 Switch,convertible top stowed,undefined voltage range
0x23220025 25 Switch,convertible top stowed, short circuit to ground
0x23220040 40 Drive,cowl panel,current too high when opening safety catch
0x23220041 41 Drive,cowl panel,current too high when closing safety catch
0x23220042 42 Drive,cowl panel,short circuit to positive
0x23220043 43 Drive,cowl panel,open circuit
0x23220044 44 Drive,cowl panel,open circuit
0x23220063 63 Time exceeded,close convertible top
0x23220064 64 Time exceeded,open convertible top
0x23220067 67 Time exceeded,unlocked convertible top
0x23220068 68 Time exceeded,lock convertible top
0x23220069 69 Circuit,pump,open convertible top
0x2322006A 6A Circuit,pump,open convertible top,short circuit to ground
0x2322006B 6B Circuit,pump,open convertible top,short circuit to positive
0x2322006C 6C Circuit,pump,close convertible top,open circuit
0x2322006D 6D Circuit,pump,close convertible top,short circuit to ground
0x2322006E 6E Circuit,pump,close convertible top,short circuit to positive
//SIM
0x244193A8 93A8 Processor: reset
0x244193A9 93A9 Control-unit fault
0x244193AA 93AA Control-unit fault
0x244193AB 93AB Incorrect chassis number
0x244193AC 93AC System time fault
0x244193AD 93AD No message (1) from satellite,door,front left
0x244193AF 93AF No message (3) from satellite,door,front right
0x244193B1 93B1 No message (5) from satellite,B-pillar, left
0x244193B3 93B3 No message (7) from satellite,B-pillar, right
0x244193B7 93B7 No message (B) from satellite,B-pillar, left
0x244193B8 93B8 No message © from satellite,B-pillar, right
0x244193BA 93BA No message (11) from satellite,B-pillar, right
0x244193BB 93BB No message (12) from satellite,B-pillar, left
0x244193BC 93BC No message (20) from satellite,B-pillar, left
0x244193BD 93BD No message (21) from satellite,B-pillar, right
0x244193C0 93C0 Coding-data error
0x244193C1 93C1 Coding-data error
0x244193C2 93C2 Self-test:too few messages
0x244193C3 93C3 Self-test:data error in message
0x244193C4 93C4 Self-test:transmission error
0x244193C5 93C5 Implausible crash severity
0x244193C6 93C6 Control-unit fault
0x244193C7 93C7 Deactivation:satellite,B-pillar,left
0x244193C8 93C8 Deactivation:satellite,B-pillar,right
0x244193C9 93C9 Deactivation:satellite,door,front left
0x244193CA 93CA Deactivation:satellite,door,front right
0x244193D9 93D9 Control-unit fault
0x244193DB 93DB Control-unit fault
0x244193DC 93DC Control-unit fault
0x244193DD 93DD Control-unit fault
0x244193DE 93DE Firing attempt taken place
0x244193DF 93DF Control-unit fault
0x244193E0 93E0 Control-unit fault
0x244193E1 93E1 Control-unit fault
0x244193E2 93E2 Key-operated switch,passenger airbag:short circuit
0x244193E3 93E3 Key-operated switch,passenger airbag:implausible measured value
0x244193E4 93E4 Key-operated switch,passenger airbag:open circuit
0x244193E5 93E5 Indicator lamp,airbag deactivation:short circuit to ground
0x244193E6 93E6 Signal lamp,airbag deactivation:open circuit
0x244193E7 93E7 Undervoltage
0x244193E8 93E8 Control-unit fault
0x244193E9 93E9 Terminal 30:overvoltage
0x244193EA 93EA Indicator lamp,airbag deactivation:short circuit to positive
0x244193EB 93EB Control-unit fault
0x244193EC 93EC Control-unit fault
0x244193ED 93ED Control-unit fault
0x244193EE 93EE Control-unit fault
0x244193EF 93EF Communication fault to satellite,passenger airbag
0x244193F0 93F0 Fault during activation and deactivation of passenger airbag
0x244193F1 93F1 Driver's airbag coded out instead of passenger airbag
0x244193F2 93F2 Key-operated switch,passenger airbag:status change during driving
0x244193F3 93F3 Key switch,passenger airbag:coding data fault
0x244193F4 93F4 Control-unit fault
0x244193F5 93F5 Coding-data error
0x244193FF 93FF Front sensor,left:wrong component
0x24419400 9400 Front sensor,right:wrong component
0x24419401 9401 Control-unit fault
0x24419402 9402 Front sensor,left
0x24419403 9403 Front sensor,right
//SMB
0x25210009 09 Hall sensor, seat carriage, short circuit to ground
0x2521000A 0A Hall sensor, seat carriage, open circuit
0x2521000B 0B Hall sensor, seat carriage, short circuit to positive
0x2521000C 0C Supply voltage, Hall sensors, short circuit to +ve
0x2521000D 0D Control-module fault, motor bridge faulty
//URS
0x26210001 1 Internal hardware fault
0x26210002 2 Malfunction warning lamp
0x26210003 3 Undervoltage
0x26210004 4 Short circuit between actuators 1 and 2
0x26210005 5 Actuator 1 (left)
0x26210006 6 Actuator 2 (right)
0x26210007 7 Number of triggerings greater than 200
0x26210008 8 Sensor for overturning (level gauge 1)
0x26210009 9 Sensor for overturning (level gauge 1)
0x2621000A 10 Sensor for overturning (level gauge 1)
0x2621000B 11 Sensor for overturning (level gauge 2)
0x2621000C 12 Sensor for overturning (level gauge 2)
0x2621000D 13 Sensor for overturning (level gauge 2)
0x2621000E 14 Sensor for overturning (g sensor)
//RDC
0x27210000 00 Control module
0x27210001 01 Control module
0x27210002 02 Control module
0x27210003 03 Control module
0x27210004 04 Control unit
0x27210005 05 Control module
0x27210006 06 Control module
0x27210007 07 Control module
0x27210008 08 Control module
0x27210009 09 Control module
0x2721000B 11 Control module
0x2721000C 12 Control module
0x2721000D 13 Control module
0x27210010 16 Control module
0x27210011 17 Control module
0x27210012 18 Control module
0x27210013 19 Control module
0x27210014 20 Control module
0x27210019 25 DWA output faulty
0x2721001A 26 RDC pushbutton
0x2721001B 27 RDC pushbutton
0x2721001C 28 RDC pushbutton
0x27210029 41 K-bus fault
0x2721002C 44 Battery, front left
0x2721002D 45 Sensor fault, front left
0x2721002E 46 Signal path, front left, not OK
0x2721002F 47 Battery, front right
0x27210030 48 Sensor fault, front right
0x27210031 49 Signal path, front right, not OK
0x27210032 50 Battery, rear left
0x27210033 51 Sensor fault, rear left
0x27210034 52 Signal path, rear left not OK
0x27210035 53 Battery, rear right
0x27210038 54 Sensor fault, rear right
0x27210037 55 Signal path, rear right, not OK
0x2721003B 59 Battery Less than 2.7 volts
0x2721003C 60 Sensor fault (pressure > 6.3 bar)
0x2721003D 61 Transmission channel faulty
0x27210068 10 Aerial, front left
0x27210069 10 Aerial, front right
0x2721006A 10 Aerial, rear left
0x2721006B 10 Aerial, rear right
0x27210073 11 Wheel allocation not possible
0x27210080 12 Terminal 30
0x27210081 12 Terminal 15/K bus
0x27210082 13 Terminal 15/K bus
0x27220001 01 Control unit fault(ROM error)
0x27220002 02 Control unit fault(RAM error)
0x27220003 03 Control unit fault(EEPROM error)
0x27220004 04 Control unit fault(system error)
0x27220005 05 Control unit fault(system error)
0x27220006 06 RPA button,short circuit to ground(plausibility)
0x27220007 07 Speed pulses FL
0x27220008 08 Speed pulses FR
0x27220009 09 Speed pulses RL
0x2722000A 0A Speed pulses RR
0x2722000B 0B K bus(60s no reception with KL15)
0x2722000C 0C Control unit fault(EEPROM error)
0x2761604C 604C Terminal fault
0x2761604D 604D Fault, control unit
0x2761604E 604E Fault, RDC system
0x2761604F 604F Fault, transmission channel FL
0x27616050 6050 Fault, transmission channel FR
0x27616051 6051 Fault, transmission channel RL
0x27616052 6052 Fault, transmission channel RR
0x27616053 6053 Fault, transmission channel SW
0x27616054 6054 Fault, wheel sensor FL
0x27616055 6055 Fault, wheel sensor FR
0x27616056 6056 Fault, wheel sensor RL
0x27616057 6057 Fault, wheel sensor RR
0x27616058 6058 Fault, wheel sensor SW
0x27616059 6059 Fault, wheel sensor undefined
//VNC
0x29210005 01 Valve 1 (retarded adjustment)
0x29210006 02 CAN BUS
0x2921000D 06 Sensor 1 (outlet shaft)
0x2921000F 08 Checksum
0x29210011 09 Valve 2 (advanced adjustment)
0x29210013 14 Sensor 2 (inlet shaft)
//DWA
0x2B619CE8 9CE8 Control-unit fault
0x2B619CE9 9CE9 Control-unit fault
0x2B619CEA 9CEA Control-unit fault
0x2B619CEB 9CEB Control-unit fault / Transport mode active
0x2B619CEC 9CEC Ultrasonic sensor
0x2B619CF9 9CF9 DWA-LED
0x2B619D00 9D00 Communication fault with siren / DWA BUS
0x2B619D01 9D01 Microwave senor, incorrect version
0x2B619D0C 9D0C DWA-data bus
0x2B619D12 9D12 Internal battery discharged
0x2B619D14 9D14 Circuit, protective device, faulty
0x2B619D15 9D15 Wakeup circuit faulty
0x2B619D16 9D16 Circuit, warning signal, faulty
0x2B619D17 9D17 Maxmum operating temperature reached
0x2B619D18 9D18 Coding-data error
0x2B619D19 9D19 Coding-data error
0x2B619D1A 9D1A Coding-data error
0x2B619D1B 9D1B Coding-data error
0x2B619D1C 9D1C Min. operating temperature reached
0x2B619D1D 9D1D Coding-data error
0x2B619D1F 9D1F Tilt sensor faulty
//GAS
0x2E810001 01 Failure of all four wheel speeds
0x2E810002 02 Wheel-speed signal, front left
0x2E810003 03 Wheel-speed signal, front right
0x2E810004 04 Wheel-speed signal, rear left
0x2E810005 05 Wheel-speed signal, rear right
0x2E810006 06 Brake signal faulty
0x2E810007 07 Fault, throttle-valve signal
0x2E810008 08 Fault, engine speed
0x2E81000A 10 Fault in hydraulics self-test while driving
0x2E81000B 11 Fault, safety relay
0x2E810010 16 Control-unit fault
0x2E810011 17 Coding data absent
0x2E810013 19 No pressure reduction during hydraulics self-test while driving
0x2E810014 20 Electrical fault, pressure build-up valve
0x2E810015 21 Electrical fault, pressure-reduction valve
0x2E810016 22 Electrical fault, central-differential lock
//CAS
0x3161A0A8 A0A8 Control module fault
0x3161A0A9 A0A9 Control module fault
0x3161A0AA A0AA Control module fault
0x3161A0AB A0AB Programming error
0x3161A0AC A0AC Control module fault
0x3161A0AD A0AD Processor
0x3161A0AE A0AE Transport mode active
0x3161A0AF A0AF Control-module fault
0x3161A0B0 A0B0 Input, brake lights, implausible
0x3161A0B1 A0B1 Input, selector lever/clutch switch, implausible
0x3161A0B3 A0B3 Starter motor, terminal 50
0x3161A0B4 A0B4 Engine starting, starter motor operation
0x3161A0B4 A0B4 Engine start,starter operation
0x3161A0B5 A0B5 Fault, road speed signal
0x3161A0B6 A0B6 Selector-lever interlock
0x3161A0B8 A0B8 Hall sensor, key engaged
0x3161A0B9 A0B9 Hall sensor, key eject
0x3161A0BA A0BA Hall sensor, start/stop button
0x3161A0BB A0BB Hall sensor, start/stop button
0x3161A0BC A0BC Identification sensor, solenoid
0x3161A0BD A0BD Output, wakeup line PT-CAN
0x3161A0BE A0BE Terminal 15 output 1
0x3161A0BF A0BF Terminal 15 output 2
0x3161A0C0 A0C0 Terminal 15 output 3
0x3161A0C1 A0C1 Output, terminal 50
0x3161A0C2 A0C2 Output, terminal 50 RS
0x3161A0C3 A0C3 Output, wakeup line ACC
0x3161A0C4 A0C4 Terminal 15 output 4
0x3161A0C6 A0C6 Terminal R
0x3161A0C7 A0C7 Terminal R
0x3161A0C8 A0C8 Lock cylinder, driver's door
0x3161A0CC A0CC Continuous signal, remote control
0x3161A0CF A0CF Outside door handle
0x3161A0F0 A0F0 Transponder coil
0x3161A0F1 A0F1 Key number invalid
0x3161A0F2 A0F2 Incorrect duplicate key
0x3161A100 A100 Immobilizer random code
0x3161A110 A110 Roadspeed signal implausible
0x3161A111 A111 Control-module fault
0x3161A112 A112 ELV fault
0x3161A113 A113 ELV fault
0x3161A114 A114 Line fault, el.steering lock
0x3161A115 A115 Line fault, el.steering lock
0x3161A116 A116 Critical status, el.steering lock
0x3161A117 A117 Programming error, CAS
0x3161A118 A118 Roadspeed signal implausible
0x3161A119 A119 Power supply el.steering lock
0x3161A11A A11A ELV fault
0x3161A120 A120 Terminal 30g short circuit
0x3161A121 A121 Short circuit, LED START - STOP button
0x3161A124 A124 Terminal Control
0x3162A0A8 A0A8 Control module fault
0x3162A0A9 A0A9 Control module fault
0x3162A0AA A0AA Control module fault
0x3162A0AB A0AB Programming error
0x3162A0AC A0AC Control module fault
0x3162A0AD A0AD Control module fault
0x3162A0AE A0AE Transport mode active
0x3162A0AF A0AF Control-module fault
0x3162A0B1 A0B1 Input, selector lever/clutch switch, implausible
0x3162A0B4 A0B4 Engine starting, starter motor operation
0x3162A0B5 A0B5 Wheel speed sensor
0x3162A0B9 A0B9 Hall sensor, key eject
0x3162A0BA A0BA Hall sensor, start/stop button
0x3162A0BB A0BB Hall sensor, start/stop button
0x3162A0BC A0BC Ignition lock, solenoid
0x3162A0BD A0BD Output, wakeup line PT-CAN
0x3162A0BE A0BE Terminal 15 output 1
0x3162A0BF A0BF Terminal 15 output 2
0x3162A0C0 A0C0 Terminal 15 output 3
0x3162A0C1 A0C1 Output, terminal 50, short-circuit
0x3162A0C2 A0C2 Output, terminal 50
0x3162A0C3 A0C3 Output, wakeup line ACC
0x3162A0C4 A0C4 Terminal 15 output 4
0x3162A0C8 A0C8 Lock cylinder, driver's door
0x3162A0CC A0CC Continuous signal, open window
0x3162A0CF A0CF Outside door handle
0x3162A0F0 A0F0 Transponder coil
0x3162A0F1 A0F1 Immobilizer key data
0x3162A0F2 A0F2 Incorrect duplicate key
0x3162A100 A100 Immobilizer random code
0x3162A110 A110 Control-module fault
0x3162A111 A111 Control-module fault
0x3162A112 A112 ELV fault
0x3162A113 A113 ELV fault
0x3162A114 A114 ELV fault
0x3162A115 A115 ELV fault
0x3162A116 A116 ELV fault
0x3162A117 A117 ELV fault
0x3162A119 A119 ELV fault
0x3162A11A A11A ELV fault
0x3162A11B A11B ELV fault
0x3162A120 A120 Terminal 30g short circuit
0x3162A121 A121 Fault LED START - STOP button
0x3162A122 A122 Short circuit Hall sensors
0x3162D905 D905 Spare
0x3162D906 D906 Spare
0x3162D940 D940 Spare
0x3162D941 D941 Spare
0x3162D942 D942 Spare
0x3163A0A8 A0A8 Control-unit fault
0x3163A0AA A0AA Control-unit fault
0x3163A0AB A0AB Programming error
0x3163A0AC A0AC Control-unit fault
0x3163A0AD A0AD Control-unit fault
0x3163A0B0 A0B0 Input, brake lights, implausible
0x3163A0B1 A0B1 Input, selector lever, implausible
0x3163A0B2 A0B2 Supply, terminal 30E
0x3163A0B3 A0B3 Starter motor, terminal 50
0x3163A0B4 A0B4 Engine starting, starter-motor operation
0x3163A0B5 A0B5 Wheel-speed sensor
0x3163A0B8 A0B8 Hall sensor, key engaged
0x3163A0B9 A0B9 Hall sensor, key eject
0x3163A0BA A0BA Hall sensor, start/stop button
0x3163A0BB A0BB Hall sensor, start/stop button
0x3163A0BC A0BC Ignition lock, solenoid
0x3163A0BD A0BD Output, Wakeup line PT-CAN
0x3163A0BE A0BE Terminal 15 output 1
0x3163A0BF A0BF Terminal 15 output 2
0x3163A0C0 A0C0 Terminal 15 output 3
0x3163A0C1 A0C1 Output, terminal 50, short circuit
0x3163A0C2 A0C2 Output, terminal 50
0x3163A0C3 A0C3 Output, wakeup line ACC
0x3163A0C4 A0C4 Terminal 15 output 4
0x3163A0C8 A0C8 Lock cylinder, driver's door
0x3163A0CC A0CC Continuous signal, open window
0x3163A0CF A0CF Outside door handle
0x3163A0E0 A0E0 Signal or value above threshold
0x3163A0E7 A0E7 Signal or value above threshold
0x3163A0F0 A0F0 Transponder coil
0x3163A0F1 A0F1 Immobiliser key data
0x3163A0F2 A0F2 Incorrect duplicate key
0x3163A0F3 A0F3 Immobiliser key data
0x3163A100 A100 Immobiliser random code
//ARS ÎÞ¹ÊÕÏÂë¿â
//cim
0x38615D2C 5D2C KL30
0x38615D2D 5D2D ECU internal
0x38615D2F 5D2F MLSL+
0x38615D30 5D30 MLSL-
0x38615D31 5D31 MLSN+
0x38615D32 5D32 MLSN-
0x38615D35 5D35 Hall sensor, longitudinal
0x38615D36 5D36 Hall sensor, inclination
0x38615D38 5D38 Position data, steering column
0x38615D39 5D39 EEPROM fault
//EDC
0x3A615FCC 5FCC Signal, acceleration, front left, too low
0x3A615FCD 5FCD Signal, acceleration, front left, too high
0x3A615FCE 5FCE Signal, acceleration, front left, implausible
0x3A615FD0 5FD0 Signal, acceleration, front right, too low
0x3A615FD1 5FD1 Signal, acceleration, front right, too high
0x3A615FD2 5FD2 Signal, acceleration, front right, implausible
0x3A615FD4 5FD4 Signal, acceleration, rear right, too low
0x3A615FD5 5FD5 Signal, acceleration, rear right, too high
0x3A615FD6 5FD6 Signal, acceleration, rear right, implausible
0x3A615FD8 5FD8 Signal, acceleration, implausible
0x3A615FE1 5FE1 Steering angle, correction value exceeded
0x3A615FE4 5FE4 Shock-absorber valves, front axle, over current
0x3A615FE5 5FE5 Shock-absorber valves, rear axle, over current
0x3A615FE6 5FE6 Shock-absorber valves, front axle
0x3A615FE7 5FE7 Shock-absorber valves, rear axle
0x3A615FE8 5FE8 Shock-absorber valves, front axle, short circuit
0x3A615FE9 5FE9 Shock-absorber valves, rear axle, shot circuit
0x3A615FF0 5FF0 CAN message (Vehicle speed) from DSC
0x3A615FF1 5FF1 Wheel speed, front left
0x3A615FF2 5FF2 Wheel speed, front right
0x3A615FF3 5FF3 CAN message (wheel speed, front left) from DSC
0x3A615FF4 5FF4 CAN message (wheel speed, front right) from DSC
0x3A615FF5 5FF5 CAN message (outside temperature) from instrument cluster
0x3A615FF6 5FF6 CAN message (mileage) from instrument cluster
0x3A615FF7 5FF7 CAN message (steering angle) from SZL
0x3A615FF8 5FF8 CAN message (vehicle speeds) from DSC
0x3A615FF9 5FF9 Coding-data error
0x3A615FFA 5FFA Supply voltage, acceleration senor
0x3A615FFB 5FFB Terminal voltage, Electronic Damper Control
0x3A615FFC 5FFC Supply voltage, Electronic Damper control
0x3A615FFD 5FFD Wakeup line, Electronic Damper Control
0x3A615FFE 5FFE Voltage, terminal EDC
//EMF
//AHL
0x3E61A588 A588 Internal fault AHL
0x3E61A589 A589 Communication with stepper motor box 1 impaired
0x3E61A58A A58A Communication with stepper motor box 2 impaired
0x3E61A58B A58B Sensor,ride level,front,faulty
0x3E61A58C A58C Ride-level sensor,rear,faulty
0x3E61A58D A58D Brake-light switch faulty
0x3E61A58E A58E Energy,saving mode on
0x3E61A58F A58F Fault,WAKE-UP line
0x3E61A590 A590 SMC left faulty
0x3E61A591 A591 SMC right faulty
//KHI
//AMP
0x4061A1A9 A1A9 Overload, output stages
0x4061D6D0 D6D0 Ring-break diagnosis has been carried out
0x4061D6D2 D6D2 Deactivation, high temperature
0x4061D6D4 D6D4 Control module fault
0x4061D6D5 D6D5 Control module fault
//SGFD
//SGFDGW
//CD
0x4461A048 A048 Fault memory test, control display, computer
//CCC-BO
0x4462A048 A048 Fault memory test, control display, computer
//M-ASK-BO
0x4463ABC9 ABC9 Drive faulty
0x4463ABCA ABCA aerial power supply
0x4463ABCB ABCB Connection, Top hi-fi
//RAD
//RAD2-BO
0x4465ABC8 ABC8 Drive faulty
0x4465ABCC ABCC Short circuit at antenna power supply
0x4465ABCE ABCE Flash memory fault
0x4465ABCF ABCF Memory fault
0x4465ABD0 ABD0 Control-module fault
0x4465ABD1 ABD1 No connection to antenna
0x4465ABD2 ABD2 Incorrect antenna
0x4465ABD3 ABD3 Antenna-diversity fault
//CDGW
0x4561E192 E192 Deactivation, overtemperature
//M-ASK-GW
0x4562A168 A168 Hardware faulty
0x4562A169 A169 Hardware fault LCD
0x4562A16A A16A Checksum error, gateway table
0x4562A16B A16B Transport mode active
0x4562E192 E192 Deactivation, high temperature
//CCC-GW
0x4563A179 A179 Control-unit fault or over-/undervoltage
0x4563A168 A168 Control-unit fault
0x4563A169 A169 Control-unit fault
0x4563A16A A16A Control-unit fault or voltage supply
0x4563A16B A16B Control-unit fault
0x4563A16D A16D Temperature outside permitted range
0x4563A170 A170 RAD_ON Signal: setpoint/actual value does not correspond
0x4563A171 A171 Control-unit fault
0x4563A172 A172 Control-unit fault
0x4563A174 A174 Control-unit fault
0x4563A175 A175 Control-unit fault
0x4563A176 A176 Control-unit fault
0x4563A178 A178 Temperature too high
0x4563A17B A17B Battery voltage over 14V
0x4563A187 A187 Transport mode active
0x4563E192 E192 Deactivation, Overtemperature
//RAD2-GW
0x4564E192 E192 Deactivation, overtemperature
//FD
0x4861A489 A489 Control-unit fault
//CDC
0x49619D28 9D28 Changer mechanism, load CD
0x49619D29 9D29 Changer mechanism, unload CD
0x49619D2B 9D2B Changer mechanism, magazine ejection
0x4961D810 D810 No code descriptions
0x4961D812 D812 Deactivation, high temperature
//CON
0x4A61A2C8 A2C8 Internal control-unit fault
0x4A61A2CB A2CB Internal control-unit fault
0x4A61A2CC A2CC Transport mode active
//FCON
0x4B61E307 E307 K-CAN Communication fault
//HKL
0x5061A2B3 A2B3 Angle-of-rotation sensor
//DVDC
//RSL
0x5B61A128 A128 Hardware,rain sensor
0x5B61A129 A129 No adaptation to windscreen
0x5B61A12A A12A Overtemperature
0x5B61A12B A12B Overvoltage/undervoltage
0x5B61A12D A12D Overvoltage/undervoltage
0x5B61A12E A12E Calibration error,light sensor
0x5B61A128 A128 Hardware, rain sensor
0x5B61A129 A129 No adaptation to windshield
0x5B61A12A A12A High temperature
0x5B61A12B A12B Overvoltage / undervoltage
0x5B61A12D A12D Hardware, light sensor
0x5B61A12E A12E Calibration error, light sensor
0x5B62A148 A148 Control module fault
0x5B62A149 A149 Input term. 15 waking
0x5B62A14A A14A Battery switch
0x5B62A14B A14B Eccentric contact
0x5B62A14C A14C Battery temperature sensor
0x5B62A14D A14D Driver Term. 30
0x5B62A14E A14E Driver, rear window defroster
0x5B62A14F A14F Driver, interior lighting
0x5B62A150 A150 Driver Term. 15
0x5B62A151 A151 Driver Term. R
0x5B62A152 A152 Driver, electrical load, roof
0x5B62A153 A153 Driver, electrical load, body
0x5B62A154 A154 Fuel filler flap motor
0x5B62A155 A155 Trunk motor
0x5B62A156 A156 Trunk contact
0x5B62A157 A157 SCA motor
0x5B62A158 A158 Battery disconnection (closed-circuit current)
0x5B62A159 A159 Battery disconnection (lmax)
0x5B62A15A A15A Battery disconnection (short circuit)
0x5B62A15B A15B Driver, light module
0x5B62A15C A15C Transport mode active
0x5B62A15D A15D Battery, exhaustive discharge
0x5B62A15E A15E Light module
0x5B62A15F A15F Exhibition mode
0x5B62A160 A160 Multi-fuses
//SASL
0x5C619557 9557 Open circuit, firing circuit, knee airbag, front left
0x5C61952C 952C System time fault
0x5C619542 9542 Self-test: too few messages
0x5C61954C 954C Open circuit, firing circuit, head airbag, left
//SASR
0x5D6195D7 95D7 Open circuit, firing circuit, knee airbag, front right
0x5D6195AC 95AC System time fault
//SFZ
0x60619AAC 9AAC System time fault
0x60619AC2 9AC2 Self-test: too few messages
0x60619AA8 9AA8 Processor: reset
0x60619AA9 9AA9 Control-module fault
0x60619AAA 9AAA Control-module fault
0x60619AAB 9AAB Incorrect chassis number
0x60619AAD 9AAD Spare
0x60619AAE 9AAE Spare
0x60619AAF 9AAF Spare
0x60619AB0 9AB0 Spare
0x60619AB1 9AB1 Spare
0x60619AB2 9AB2 Spare
0x60619AB3 9AB3 Spare
0x60619AB4 9AB4 Spare
0x60619AB5 9AB5 Spare
0x60619AB6 9AB6 Spare
0x60619AB7 9AB7 Spare
0x60619AB9 9AB9 Spare
0x60619ABA 9ABA Spare
0x60619ABB 9ABB Spare
0x60619ABC 9ABC Spare
0x60619ABD 9ABD Spare
0x60619ABE 9ABE Spare
0x60619AC1 9AC1 Control-module fault
0x60619AC3 9AC3 Self-test: data error in message
0x60619AC4 9AC4 Self-test: transmission error
0x60619AC5 9AC5 Implausible crash severity
0x60619AC6 9AC6 Control-module fault
0x60619AC7 9AC7 Control-module fault
0x60619AC8 9AC8 Control-module fault
0x60619AC9 9AC9 Control-module fault
0x60619ACA 9ACA Control-module fault
0x60619ACB 9ACB Control-module fault
0x60619ACC 9ACC Control-module fault
0x60619ACD 9ACD Control-module fault
//SSBF
0x616197AC 97AC System time fault
0x616197C2 97C2 Self-test: too few messages
0x616197CC 97CC Open circuit, firing circuit, passenger belt tensioner
0x616197D7 97D7 Open circuit, firing circuit, passenger active head restraint
0x616197DD 97DD Seatbelt-catch switch, front passenger: open circuit
0x616197DF 97DF Seat occupancy detector, passenger: communication fault
0x616197FF 97FF Communication fault, seat-occupancy detector, passenger
0x616197A8 97A8 Processor: reset
0x616197A9 97A9 Control-module fault
0x616197AA 97AA Control-module fault
0x616197AB 97AB Incorrect chassis number
0x616197AD 97AD Spare
0x616197AE 97AE Spare
0x616197AF 97AF Spare
0x616197B0 97B0 Spare
0x616197B2 97B2 Spare
0x616197B4 97B4 Spare
0x616197B5 97B5 Spare
0x616197B6 97B6 Spare
0x616197B8 97B8 Spare
0x616197BA 97BA Spare
0x616197BB 97BB Spare
0x616197BD 97BD Spare
0x616197BE 97BE Spare
0x616197C0 97C0 Coding/data error
0x616197C1 97C1 Control-module fault
0x616197C3 97C3 Self-test: data error in message
0x616197C4 97C4 Self-test: transmission error
0x616197C5 97C5 Implausible crash severity
0x616197C6 97C6 Control-module fault
0x616197C7 97C7 Short-circuit, firing circuit, passenger seat belt tensioner, to ground
0x616197C8 97C8 Short-circuit, firing circuit, passenger seat belt tensioner, to positive
0x616197C9 97C9 Resistance, firing circuit, seat belt tensioner, front passenger, too low
0x616197CA 97CA Resistance, firing circuit, seat belt tensioner, front passenger, too high
0x616197CB 97CB Resistance, firing circuit, seat belt tensioner, front passenger, can not be measured
0x616197CC 97CC Open circuit, firing circuitm passenger seat belt tensioner
0x616197CD 97CD Control-module fault
0x616197CE 97CE Control-module fault
0x616197CF 97CF Coding, firing circuit, seat belt tensioner, front passenger, at variance
0x616197D0 97D0 Control-module fault
0x616197D1 97D1 Control-module fault
0x616197D2 97D2 Short-circuit, firing circuit, passenger active head restraint, to ground
0x616197D3 97D3 Short-circuit, firing circuit, passenger active head restraint, to positive
0x616197D4 97D4 Resistance, firing circuit, active head restraint, front passenger, too low
0x616197D5 97D5 Resistance, firing circuit, active head restraint, front passenger, too high
0x616197D6 97D6 Resistance, firing circuit, active head restraint, front passenger, can not be measured
0x616197D8 97D8 Control-module fault
0x616197D9 97D9 Control-module fault
0x616198DA 98DA Coding, firing circuit, active head restraint, front passenger, at variance
0x616197DB 97DB Control-module fault
0x616197DC 97DC Seat-belt buckle switch, passenger, short circuit
0x616197DD 97DD Seat-belt buckle switch, passenger, open circuit
0x616197DE 97DE Control-module fault
0x616197FD 97FD Open circuit, seat occupancy detector, passenger
0x616197FE 97FE Short-circuit, seat occupancy detector, passenger
0x616197FF 97FF Communication fault, seat occupancy detector, passenger
0x616197E0 97E0 seat occupancy detector, passenger:faulty
//SSFA
0x62619763 9763 Open circuit, seat-occupancy detector, driver
0x62619728 9728 Processor: reset
0x62619729 9729 Control-module fault
0x6261972A 972A Control-module fault
0x6261972B 972B Incorrect chassis number
0x6261972C 972C System time fault
0x6261972D 972D Spare
0x6261972E 972E Spare
0x6261972F 972F Spare
0x62619730 9730 Spare
0x62619732 9732 Spare
0x62619724 9724 Spare
0x62619735 9735 Spare
0x62619736 9736 Spare
0x62619738 9738 Spare
0x6261973A 973A Spare
0x6261973B 973B Spare
0x6261973C 973C Spare
0x6261973E 973E Spare
0x62619740 9740 Coding/data error
0x62619741 9741 Control-module fault
0x62619742 9742 Self-test: too few message
0x62619743 9743 Self-test: data error in message
0x62619744 9744 Self test: transmission error
0x62619745 9745 Implausible crash severity
0x62619747 9747 Control-mocule fault
0x62619747 9747 Short-circuit, firing circuit, driver's seat belt tensioner, to ground
0x62619748 9748 Short-circuit, firing circuit, driver's seat belt tensioner, to positive
0x62619749 9749 Resistance, firing circuit, seat belt tensioner, driver, too low
0x6261974A 974A Resistance, firing circuit, seat belt tensioner, driver, too high
0x6261974B 974B Resistance, firing circuit, seat belt tensioner, driver, can not be measured
0x6261974C 974C Open circuit, firing circuit, driver's seat belt tensioner
0x6261974D 974D Control-module fault
0x6261974E 974E Control-module fault
0x6261974F 974F Coding, firing circuit, seat belt tensioner, driver, at variance
0x62619750 9750 Control-module fault
0x62619751 9751 Control-module fault
0x62619752 9752 Short-circuit, firing circuit, driver's active head restraint, to ground
0x62619753 9753 Short-circuit, firing circuit, driver's active head restraint, to positive
0x62619754 9754 Resistance, firing circuit, active head restraint, driver, too low
0x62619755 9755 Resistance, firing circuit, active head restraint, driver, too high
0x62619756 9756 Resistance, firing circuit, active head restraint, can not be measured
0x62619757 9757 Open circuit, firing circuit, driver's active head restraint
0x62619758 9758 Control-module fault
0x62619759 9759 Control-module fault
0x6261975A 975A Coding, firing circuit, active head restaint, driver, at variance
0x6261975B 975B Control-module fault
0x6261975C 975C Seat-belt buckle switch, driver, short circuit
0x6261975D 975D Seat-belt buckle switch, driver, open circuit
0x6261975E 975E Control-module fault
0x62619763 9763 Open circuit, seat occupancy detector, driver
0x62619764 9764 Short-circuit, seat occupancy detector, driver
0x62619765 9765 Communication fault, seat occupancy detector, driver
0x62619766 9766 Control-module fault
0x62619767 9767 Control-module fault
0x62619768 9768 Firing attempt taken place
0x62619769 9769 Control-module fault
0x6261976A 976A Control-module fault
0x6261976B 976B Control-module fault
0x6261976C 976C Control-module fault
0x6261976D 976D Control-module fault
0x6261976E 976E Control-module fault
//SSH
0x63619A2C 9A2C System time fault
0x63619A4C 9A4C Open circuit, firing circuit, thorax airbag, rear right
0x63619A57 9A57 Open circuit, firing circuit, belt tensioner, rear right
0x63619A62 9A62 Open circuit, firing circuit, belt tensioner, rear left
0x63619A6D 9A6D Open circuit, firing circuit, thorax airbag, rear left
0x63619A81 9A81 Communication fault, seat-occupancy detector, rear left
0x63619A84 9A84 Communication fault, seat-occupancy detector, rear right
0x63619A28 9A28 Processor:reset
0x63619A29 9A29 Control-unit fault
0x63619A2a 9A2a Control-unit fault
0x63619A2B 9A2B Incorrect chassis number
0x63619A40 9A40 Coding-data error
0x63619A41 9A41 Control-unit fault
0x63619A42 9A42 Self-test:too few messages
0x63619A43 9A43 Self-test:data error in message
0x63619A44 9A44 Self-test:transmission error
0x63619A45 9A45 Implausible crash severity
0x63619A46 9A46 Control-unit fault
0x63619A47 9A47 Short citcuit,firing circuit,thorax airbag,rear right,to ground
0x63619A48 9A48 Short citcuit,firing circuit,thorax airbag,rear right,to positive
0x63619A49 9A49 Resistance,firing circuit,thorax airbag,rear right,too low
0x63619A4A 9A4A Resistance,firing circuit,thorax airbag,rear right,too high
0x63619A4B 9A4B Resistance,firing circuit,thorax airbag,rear right,cannot be measured
0x63619A4C 9A4C Open citcuit,firing circuit,thorax airbag,rear right
0x63619A4D 9A4D Control-unit fault
0x63619A4E 9A4E Control-unit fault
0x63619A4F 9A4F Coding,firing circuit,thorax airbag,rear right,at variance
0x63619A50 9A50 Control-unit fault
0x63619A51 9A51 Control-unit fault
0x63619A52 9A52 Short circuit,firing circuit,belt tensioner,rear right,to ground
0x63619A53 9A53 Short circuit,firing circuit,belt tensioner,rear right,to positive
0x63619A54 9A54 Resistance,firing circuit,belt tensioner,rear right,too low
0x63619A55 9A55 Resistance,firing circuit,belt tensioner,rear right,too high
0x63619A56 9A56 Resistance,firing circuit,belt tensioner,rear right,cannot be measured
0x63619A57 9A57 Open citcuit,firing circuit,belt tensioner,rear right
0x63619A58 9A58 Control-unit fault
0x63619A59 9A59 Control-unit fault
0x63619A5A 9A5A Coding,firing circuit,belt tensioner,rear right,at variance
0x63619A5B 9A5B Control-unit fault
0x63619A5C 9A5C Control-unit fault
0x63619A5D 9A5D Short circuit,firing circuit,belt tensioner,rear left,to ground
0x63619A5E 9A5E Short circuit,firing circuit,belt tensioner,rear left,to positive
0x63619A5F 9A5F Resistance,firing circuit,belt tensioner,rear left,too low
0x63619A60 9A60 Resistance,firing circuit,belt tensioner,rear left,too high
0x63619A61 9A61 Resistance,firing circuit,belt tensioner,rear left,cannot be measured
0x63619A62 9A62 Open citcuit,firing circuit,belt tensioner,rear left
0x63619A63 9A63 Control-unit fault
0x63619A64 9A64 Control-unit fault
0x63619A65 9A65 Coding,firing circuit,belt tensioner,rear left,at variance
0x63619A66 9A66 Control-unit fault
0x63619A67 9A67 Control-unit fault
0x63619A68 9A68 Short citcuit,firing circuit,thorax airbag,rear left,to ground
0x63619A69 9A69 Short citcuit,firing circuit,thorax airbag,rear left,to positive
0x63619A6A 9A6A Resistance,firing circuit,thorax airbag,rear left,too low
0x63619A6B 9A6B Resistance,firing circuit,thorax airbag,rear left,too high
0x63619A6C 9A6C Resistance,firing circuit,thorax airbag,rear left,cannot be measured
0x63619A6D 9A6D Open citcuit,firing circuit,thorax airbag,rear left
0x63619A6E 9A6E Control-unit fault
0x63619A6F 9A6F Control-unit fault
0x63619A70 9A70 Coding,firing circuit,thorax airbag,rear left,at variance
0x63619A71 9A71 Control-unit fault
0x63619A72 9A72 Control-unit fault
0x63619A73 9A73 Overload,head-restraint adjustment,rear left
0x63619A74 9A74 Overload,head-restraint adjustment,rear right
0x63619A75 9A75 Open circuit,head-restraint adjustment,rear left
0x63619A76 9A76 Open circuit,head-restraint adjustment,rear right
0x63619A77 9A77 Belt-buckle switch,rear left:short circuit
0x63619A78 9A78 Belt-buckle switch,rear left:implausible measured value
0x63619A79 9A79 Belt-buckle switch,rear left:open circuit
0x63619A7A 9A7A Belt-buckle switch,rear right:short circuit
0x63619A7B 9A7B Belt-buckle switch,rear right:implausible measured value
0x63619A7C 9A7C Belt-buckle switch,rear right:open circuit
0x63619A7D 9A7D Communication fault,seat-occupancy detector,rear left
0x63619A7E 9A7E Communication fault,seat-occupancy detector,rear right
0x63619A7F 9A7F Open circuit,seat-occupancy detector,rear left
0x63619A80 9A80 Short circuit,seat-occupancy detector,rear left
0x63619A81 9A81 Communication fault,seat-occupancy detector,rear left
0x63619A82 9A82 Open circuit,seat-occupancy detector,rear right
0x63619A83 9A83 Short circuit,seat-occupancy detector,rear right
0x63619A84 9A84 Communication fault,seat-occupancy detector,rear right
0x63619A85 9A85 Control-unit fault
0x63619A86 9A86 Control-unit fault
0x63619A87 9A87 Firing attempt taken place
0x63619A88 9A88 Control-unit fault
//STVL
0x64619628 9628 Processor: reset
0x6461962C 962C System time fault
0x64619642 9642 Self-test: too few messages
0x6461964C 964C Open circuit, firing circuit, thorax airbag, front left
0x64619673 9673 Control-unit fault
0x64619629 9629 Control-unit fault
0x6461962A 962A Control-unit fault
0x6461962B 962B Incorrect chassis number
0x64619640 9640 Coding-data error
0x64619641 9641 Control-unit fault
0x64619642 9642 Self-test:too few messages
0x64619643 9643 Self-test:data error in message
0x64619644 9644 Self-test:transmission error
0x64619645 9645 Implausible crash severity
0x64619646 9646 Control-unit fault
0x64619647 9647 Short citcuit,firing circuit,thorax airbag,front left,to ground
0x64619648 9648 Short circuit,throrax airbag,front left,to positive
0x64619649 9649 Resistance,firing circuit,thorax airbag,front left,too low
0x6461964A 964A Resistance,firing circuit,thorax airbag,front left,too high
0x6461964B 964B Resistance,firing circuit,thorax airbag,front left,cannot be measured
0x6461964C 964C Open citcuit,firing circuit,thorax airbag,front left
0x6461964D 964D Control-unit fault
0x6461964E 964E Control-unit fault
0x6461964F 964F Coding,firing circuit,thorax airbag,front left,at variance
0x64619650 9650 Control-unit fault
0x6461965D 965D Control-unit fault
0x6461965E 965E Control-unit fault
0x6461965F 965F Control-unit fault
0x64619660 9660 Firing attempt taken place
0x64619661 9661 Control-unit fault
0x64619662 9662 Pressure sensor
0x64619663 9663 Control-unit fault
0x64619664 9664 Control-unit fault
0x64619665 9665 Control-unit fault
0x64619666 9666 Control-unit fault
0x64619667 9667 Control-unit fault
0x64619672 9672 Control-unit fault
0x64619674 9674 Control-unit fault
0x64619675 9675 Control-unit fault
0x64619676 9676 Control-unit fault
0x64619677 9677 Control-unit fault
0x64619678 9678 Control-unit fault
0x64619679 9679 Control-unit fault
0x6461967A 967A Control-unit fault
0x6461967B 967B Control-unit fault
0x6461967C 967C Voltage supply:limit value undershot
0x6461967D 967D Voltage supply:limit value exceeded
0x6461967E 967E Transport mode active
0x6461967F 967F Coding-data error
0x64619628 9628 Processor:reset
0x64629628 9628 Processor:reset
0x64629629 9629 Control-unit fault
0x6462962A 962A Control-unit fault
0x6462962B 962B Incorrect chassis number
0x6462962C 962C System time fault
0x64629640 9640 Coding-data error
0x64629642 9642 Self-test:too few messages
0x64629643 9643 Self-test:data error in message
0x64629644 9644 Self-test:transmission error
0x64629645 9645 Implausible crash severity
0x64629647 9647 Short circuit,firing circuit,thorax airbag,driver,to ground
0x64629648 9648 Short circuit,firing circuit,thorax airbag,driver,to positive
0x64629649 9649 Resistance,firing circuit,thorax airbag,driver,too low
0x6462964A 964A Resistance,firing circuit,thorax airbag,driver,too high
0x6462964B 964B Resistance,firing circuit,thorax airbag,driver,cannot be measured
0x6462964C 964C Open circuit,firing circuit,thorax airbag,driver
0x6462964D 964D Control-unit fault
0x6462964E 964E Control-unit fault
0x6462964F 964F Coding,firing circuit,thorax airbag,driver,at variance
0x64629650 9650 Control-unit fault
0x6462965D 965D Control-unit fault
0x6462965E 965E Control-unit fault
0x6462965F 965F Control-unit fault
0x64629660 9660 Firing attempt taken place
0x64629661 9661 Control-unit fault
0x64629662 9662 Pressure sensor
0x64629663 9663 Control-unit fault
0x64629664 9664 Control-unit fault
0x64629665 9665 Control-unit fault
0x64629666 9666 Control-unit fault
0x64629667 9667 Control-unit fault
0x64629672 9672 Control-unit fault
0x64629673 9673 Control-unit fault
0x64629674 9674 Control-unit fault
0x64629675 9675 Control-unit fault
0x64629676 9676 Control-unit fault
0x64629677 9677 Transport mode active
0x64629678 9678 Control-unit fault
0x64629679 9679 Control-unit fault
0x6462967A 967A Control-unit fault
0x6462967B 967B Control-unit fault
0x6462967C 967C Control-unit fault
0x6462967D 967D Voltage supply:limit value undershot
0x6462967E 967E Voltage supply:limit value exceeded
0x6462967F 967F Terminal 30
0x64629B48 9B48 Ambient lighting faulty
0x64629B49 9B49 Mirror, potentiometer, vertical
0x64629B4A 9B4A Mirror position, potentiometer, horizontal
0x64629B4B 9B4B Mirror position, potentiometer, supply
0x64629B4C 9B4C Courtesy lighting
0x64629B4D 9B4D Switch block, supply
0x64629B4E 9B4E Power window, supply, Hall sensors
0x64629B4F 9B4F Switch block, data transfer
0x64629B52 9B52 Power window, Hall sensor
0x64629B53 9B53 Power-window relay
0x64629B54 9B54 Power-window electronics
0x64629B55 9B55 Door mirror, motor, horizontal
0x64629B56 9B56 Door mirror, motor, vertical
0x64629B57 9B57 Drive, swivel door mirror
0x64629B58 9B58 Mirror, wiring fault
0x64629B59 9B59 Switch block, driver's door
0x64629B5A 9B5A Programming fault
0x64629B5B 9B5B Central-locking drive, locking
0x64629B5C 9B5C Central-locking drive, double
0x64629B5D 9B5D Central-locking drive, unlocking
0x64629B5E 9B5E Entrance lighting
//STVR
0x656196AC 96AC System time fault
0x656196C2 96C2 Self-test: too few messages
0x656196C9 96C9 Resistance, firing circuit, thorax airbag, front right, too low
0x656196CC 96CC Open circuit, firing circuit, thorax airbag, front right
0x656196FD 96FD Voltage supply: limit value exceeded
0x656196A8 96A8 Processor:reset
0x656196A9 96A9 Control-unit fault
0x656196AA 96AA Control-unit fault
0x656196AB 96AB Incorrect chassis number
0x656196C0 96C0 Coding-data error
0x656196C1 96C1 Control-unit fault
0x656196C2 96C2 Self-test:too few messages
0x656196C3 96C3 Self-test:data error in message
0x656196C4 96C4 Self-test:transmission error
0x656196C5 96C5 Implausible crash severity
0x656196C6 96C6 Control-unit fault
0x656196C7 96C7 Short citcuit,firing circuit,thorax airbag,front right,to ground
0x656196C8 96C8 Short circuit,throrax airbag,front right,to positive
0x656196C9 96C9 Resistance,firing circuit,thorax airbag,front right,too low
0x656196CA 96CA Resistance,firing circuit,thorax airbag,front right,too high
0x656196CB 96CB Resistance,firing circuit,thorax airbag,front right,cannot be measured
0x656196CC 96CC Open citcuit,firing circuit,thorax airbag,front right
0x656196CD 96CD Control-unit fault
0x656196CE 96CE Control-unit fault
0x656196CF 96CF Coding,firing circuit,thorax airbag,front right,at variance
0x656196D0 96D0 Control-unit fault
0x656196DD 96DD Control-unit fault
0x656196DE 96DE Control-unit fault
0x656196DF 96DF Control-unit fault
0x656196E0 96E0 Firing attempt taken place
0x656196E1 96E1 Control-unit fault
0x656196E2 96E2 Pressure sensor
0x656196E3 96E3 Control-unit fault
0x656196E4 96E4 Control-unit fault
0x656196E5 96E5 Control-unit fault
0x656196E6 96E6 Control-unit fault
0x656196E7 96E7 Control-unit fault
0x656196F2 96F2 Control-unit fault
0x656196F3 96F3 Control-unit fault
0x656196F4 96F4 Control-unit fault
0x656196F5 96F5 Control-unit fault
0x656196F6 96F6 Control-unit fault
0x656196F7 96F7 Control-unit fault
0x656196F8 96F8 Control-unit fault
0x656196F9 96F9 Control-unit fault
0x656196FA 96FA Control-unit fault
0x656196FB 96FB Control-unit fault
0x656196FC 96FC Voltage supply:limit value undershot
0x656196FD 96FD Voltage supply:limit value exceeded
0x656196FE 96FE Transport mode active
0x656196FF 96FF Coding-data error
0x656296A8 96A8 Processor:reset
0x656296A9 96A9 Control-unit fault
0x656296AA 96AA Control-unit fault
0x656296AB 96AB Incorrect chassis number
0x656296AC 96AC System time fault
0x656296C0 96C0 Coding-data error
0x656296C2 96C2 Self-test:too few messages
0x656296C3 96C3 Self-test:data error in message
0x656296C4 96C4 Self-test:transmission error
0x656296C5 96C5 Implausible crash severity
0x656296C6 96C6 Control-unit fault
0x656296C7 96C7 Short circuit,firing circuit,thorax airbag,passenger,to ground
0x656296C8 96C8 Short circuit,firing circuit,thorax airbag, passenger,to positive
0x656296C9 96C9 Resistance,firing circuit,thorax airbag, passenger,too low
0x656296CA 96CA Resistance,firing circuit,thorax airbag, passenger,too high
0x656296CB 96CB Resistance,firing circuit,thorax airbag, passenger,cannot be measured
0x656296CC 96CC Open circuit,firing circuit,thorax airbag, passenger
0x656296CD 96CD Control-unit fault
0x656296CE 96CE Control-unit fault
0x656296CF 96CF Coding,firing circuit,thorax airbag,passenger,at variance
0x656296D0 96D0 Control-unit fault
0x656296DD 96DD Control-unit fault
0x656296DE 96DE Control-unit fault
0x656296DF 96DF Control-unit fault
0x656296E0 96E0 Firing attempt taken place
0x656296E1 96E1 Control-unit fault
0x656296E2 96E2 Pressure sensor
0x656296E3 96E3 Control-unit fault
0x656296E4 96E4 Control-unit fault
0x656296E5 96E5 Control-unit fault
0x656296E6 96E6 Control-unit fault
0x656296E7 96E7 Control-unit fault
0x656296F2 96F2 Control-unit fault
0x656296F3 96F3 Control-unit fault
0x656296F4 96F4 Control-unit fault
0x656296F5 96F5 Control-unit fault
0x656296F6 96F6 Control-unit fault
0x656296F7 96F7 Transport mode active
0x656296F8 96F8 Control-unit fault
0x656296F9 96F9 Control-unit fault
0x656296FA 96FA Control-unit fault
0x656296FB 96FB Control-unit fault
0x656296FC 96FC Control-unit fault
0x656296FD 96FD Voltage supply:limit value undershot
0x656296FE 96FE Voltage supply:limit value exceeded
0x656296FF 96FF Terminal 30
0x65629B88 9B88 Ambient lighting
0x65629B89 9B89 Mirror position, potentiometer, horizontal
0x65629B8A 9B8A Mirror position, potentiometer, vertical
0x65629B8B 9B8B Mirror position, potentiometer, supply
0x65629B8C 9B8C Courtesy lighting
0x65629B8E 9B8E Power window, supply, hall sensors
0x65629B8F 9B8F Switch block, data transfer disturbed
0x65629B92 9B92 Power window, Hall sensor
0x65629B93 9B93 Power-window relay
0x65629B94 9B94 Power-window electronics
0x65629B95 9B95 Door mirror, horizontal
0x65629B96 9B96 Door mirror, vertical
0x65629B97 9B97 Drive, swivel door mirror
0x65629B98 9B98 Mirror, wiring fault
0x65629B9A 9B9A Programming fault
0x65629B9B 9B9B Central locking, locking
0x65629B9C 9B9C Central locking, double locking
0x65629B9D 9B9D Central locking, unlocking
0x65629B9E 9B9E Entrance lighting
//SINE
0x67619D1F 9D1F Emergency siren
0x67619D11 9D11 DWA-data bus
0x67619D12 9D12 Internal battery
0x67619D13 9D13 Emergency siren
0x67619D14 9D14 Emergency siren
0x67619D15 9D15 Emergency siren
0x67619D16 9D16 Emergency siren
0x67619D44 9D44 Alarm memory: voltage-supply tampering
0x67619D45 9D45 Alarm memory: overvoltage or DWA bus, short circuit to position
0x67619D46 9D46 Alarm memory: DWA bus, short circuit to ground
0x67619D47 9D47 Alarm memory: siren disconnected
0x67619D45 9D45 Alarm memory: overvoltage or DWA bus, short circuit to positive
//SMFA
0x68619E48 9E48 No Hall pulses, longitudinal seat adjustment
0x68619E49 9E49 No Hall pulses,seat-height adjustment
0x68619E4A 9E4A No Hall pulses,seat-back width adjustment
0x68619E4B 9E4B No Hall pulses,seat-back inclination adjustment
0x68619E4C 9E4C No Hall pulses,seat-inclination adjustment
0x68619E4D 9E4D No Hall pulses,head-restraint adjustment
0x68619E4E 9E4E No Hall pulses,seat-back head adjustment
0x68619E4F 9E4F No Hall pulses,seat-cushion adjustment
0x68619E50 9E50 Motor, longitudinal seat adjustment
0x68619E51 9E51 Motor, seat height adjustment
0x68619E52 9E52 Motor, seat back width adjustment
0x68619E53 9E53 Motor, seat back inclination adjustment
0x68619E54 9E54 Motor, seat inclination adjustment
0x68619E55 9E55 Motor, head restraint adjustment
0x68619E56 9E56 Motor, seat back head adjustment
0x68619E57 9E57 Motor, seat cushion adjustment
0x68619E58 9E58 Temperature sensor, rapid heating area, cushion
0x68619E59 9E59 Temperature sensor, rapid heating area, seat back
0x68619E5A 9E5A Temperature sensor, residual heating area, cushion
0x68619E5B 9E5B Temperature sensor, residual heating area, seat back
0x68619E5C 9E5C Rapid heating area,cushion
0x68619E5D 9E5D Rapid heating area, seat back
0x68619E5E 9E5E Residual heating area, cushion
0x68619E5F 9E5F Residual heating area, seat back
0x68619E60 9E60 Heating driver failed
0x68619E61 9E61 Seat ventilation supply, cushion and seat back
0x68619E62 9E62 Seat ventilation control, cushion
0x68619E63 9E63 Seat ventilation control, seat back
0x68619E64 9E64 Active seat, motor
0x68619E65 9E65 Active seat solenoid
0x68619E66 9E66 Active seat, pressure switch
0x68619E67 9E67 Lumbar valves
0x68619E68 9E68 Lumbar pump
0x68619E69 9E69 Internal fault, supply voltage U12s
0x68619E6A 9E6A Internal fault, supply voltage tm. 30s
0x68619E6B 9E6B Control-unit fault
//SMFB
0x69619EA8 9EA8 No Hall pulses, longitudinal seat adjustment
0x69619EA9 9EA9 No Hall pulses, seat-height adjustment
0x69619EAA 9EAA No Hall pulses, seat-back width adjustment
0x69619EAB 9EAB No Hall pulses, seat-back inclination adjustment
0x69619EAC 9EAC No Hall pulses, seat-inclination adjustment
0x69619EAD 9EAD No Hall pulses, head-restraint adjustment
0x69619EAE 9EAE No Hall pulses, seat-back head adjustment
0x69619EAF 9EAF No Hall pulses, seat-cushion adjustment
0x69619EB0 9EB0 Motor, longitudinal seat adjustment
0x69619EB1 9EB1 Motor, seat height adjustment
0x69619EB2 9EB2 Motor, seat back width adjustment
0x69619EB3 9EB3 Motor, seat back inclination adjustment
0x69619EB4 9EB4 Motor, seat inclination adjustment
0x69619EB5 9EB5 Motor, head restraint adjustment
0x69619EB6 9EB6 Motor, seat back head adjustment
0x69619EB7 9EB7 Motor, seat cushion adjustment
0x69619EB8 9EB8 Temperature sensor, rapid heating area, cushion
0x69619EB9 9EB9 Temperature sesnor, rapid heating area, seat back
0x69619EBA 9EBA Temperature sesnor, residual heating area, cushion
0x69619EBB 9EBB Temperature sensor, residual heating area, seat back
0x69619EBC 9EBC Rapid heating area, cushion
0x69619EBD 9EBD Rapid heating area, seat back
0x69619EBE 9EBE Residual heating area, cushion
0x69619EBF 9EBF Residual heating area, seat back
0x69619EC0 9EC0 Heating driver failed
0x69619EC1 9EC1 Seat ventilation supply, cushion and seat back
0x69619EC2 9EC2 Seat ventilation control, cushion
0x69619EC3 9EC3 Seat ventilation control, seat back
0x69619EC4 9EC4 Active seat, motor
0x69619EC5 9EC5 Active seat, solenoid
0x69619EC6 9EC6 Active seat, pressure switch
0x69619EC7 9EC7 Lumbar valves
0x69619EC8 9EC8 Lumbar pump
0x69619EC9 9EC9 Internal fault supply voltage U12s
0x69619ECA 9ECA Internal fault supply voltage Term. 30s
0x69619ECB 9ECB Control-unit fault
//SMFAH
0x6A619F08 9F08 No Hall pulses, longitudinal seat adjustment
0x6A619F0E 9F0E No Hall pulses, seat-back head adjustment
0x6A619F10 9F10 Motor, longitudinal seat adjustment
0x6A619F13 9F13 Motor, seat-back inclination adjustment
0x6A619F14 9F14 Motor, seat-inclination adjustment
0x6A619F15 9F15 Motor, head-restraint height adjustment
0x6A619F16 9F16 Motor, seat-back head adjustment
0x6A619F22 9F22 Seat ventilation, control, seat cushion
0x6A619F23 9F23 Seat ventilation, control, backrest
0x6A619F08 9F08 No Hall pulses,longitudinal seat adjustment
0x6A619F0B 9F0B No Hall pulses,seat-back inclination adjustment
0x6A619F0C 9F0C No Hall pulses,seat-inclination adjustment
0x6A619F0D 9F0D No Hall pulses,head-restraint height adjustment
0x6A619F0E 9F0E No Hall pulses,seat-back head adjustment
0x6A619F0F 9F0F No Hall pulses,seat-cushion adjustment
0x6A619F10 9F10 Motor,longitudinal seat adjustment
0x6A619F13 9F13 Motor,seat-back inclination adjustment
0x6A619F14 9F14 Motor,seat-inclination adjustment
0x6A619F17 9F17 Motor,seat-cushion adjustment
0x6A619F18 9F18 Temperature sensor,rapid heating field,seat cushion
0x6A619F19 9F19 Temperature sensor,rapid heating field,seat backrest
0x6A619F1A 9F1A Temperature sensor,residual heating field,seat cushion
0x6A619F1B 9F1B Temperature sensor,residual heating field,seat backrest
0x6A619F1C 9F1C Rapid heating field,seat cushion
0x6A619F1D 9F1D Rapid heating field,seat backrest
0x6A619F1E 9F1E Residual heating field,seat cushion
0x6A619F1F 9F1F Residual heating field,seat backrest
0x6A619F20 9F20 Heating driver failed
0x6A619F21 9F21 Seat-ventilation supply,cushion and seat back
0x6A619F22 9F22 Seat-ventilation,control,seat cushion
0x6A619F23 9F23 Seat ventilation,control,backrest
0x6A619F24 9F24 Active seat,motor
0x6A619F25 9F25 Active seat,solenoid
0x6A619F26 9F26 Active seat,pressure switch
0x6A619F27 9F27 Lumbar valves
0x6A619F28 9F28 Lumbar pump
0x6A619F29 9F29 Internal fault,supply voltage U12s
0x6A619F2A 9F2A Internal fault,supply voltage tm.30s
0x6A619F2B 9F2B Control-unit fault
//SMBFH
0x6B619F70 9F70 Motor, longitudinal seat adjustment
0x6B619F73 9F73 Motor, seat-back inclination adjustment
0x6B619F74 9F74 Motor, seat-inclination adjustment
0x6B619F75 9F75 Motor, head-restraint adjustment
0x6B619F82 9F82 Seat ventilation, control, seat cushion
0x6B619F83 9F83 Seat ventilation, control, backrest
0x6B619F85 9F85 Active seat, solenoid
//SHZH
//SVS
0x6D61D644 D644 Fault, self test SVS faulty
0x6D61D650 D650 Ring-break diagnosis has been carried out
0x6D61D652 D652 Deactivation, hgih temperature
//SZL
0x6E6194EE 94EE MFL button pad, left
0x6E6194EF 94EF MFL button pad, right
0x6E6194F9 94F9 Fanfare horn: woofer
0x6E619501 9501 Steering-angle sensor not adjusted
0x6E61951A 951A Undervoltage
0x6E61951D 951D Direction indicator/high-beam switch
0x6E61A849 A849 Steering-column switch, cruise control
0x6E6294AB 94AB Incorrect chassis number
0x6E6294C3 94C3 Self-test: too few messages
0x6E6294CA 94CA Resistance, firing circuit, driver's airbag, stage 1, too low
0x6E6294CD 94CD Open circuit, firing circuit, driver's airbag, stage 1
0x6E6294D3 94D3 Short circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6294D5 94D5 Resistance, firing circuit, driver's airbag, stage 2, too low
0x6E6294D8 94D8 Open circuit, firing circuit, driver's airbag, stage 2
0x6E6294E3 94E3 Terminal U_ISIS or U_SZL missing
0x6E6294E4 94E4 Steering-angle sensor, plausibility
0x6E6294E7 94E7 Steering-angle sensor, wiper contact
0x6E6294EA 94EA Communication between steering wheel module and steering column module faulty
0x6E629EF9 9EF9 Fault, fanfare horn
0x6E6294FD 94FD Steering-wheel electronics: fault in alarm path
0x6E629500 9500 Firing attempt taken place
0x6E629501 9501 Steering-angle-sensor adjustment
0x6E629504 9504 Control-unit fault
0x6E629518 9518 Voltage supply: limit value undershot
0x6E62951A 951A Voltage supply (LRE): limit value undershot
0x6E62951D 951D Coding-data error
0x6E6294A8 94A8 Processor: reset
0x6E6294A9 94A9 Control-module fault
0x6E6294AA 94AA Control-module fault
0x6E6294AC 94AC System time fault
0x6E6294AD 94AD Control-module fault
0x6E6294C1 94C1 Coding/data error
0x6E6294C2 94C2 Control-module fault
0x6E6294C4 94C4 Self-test: data error in messages
0x6E6294C5 94C5 Self-test: transmission error
0x6E6294C6 94C6 Implausible crash severity
0x6E6294C7 94C7 Steering-wheel electronics
0x6E6294C8 94C8 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6294C9 94C9 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6294CB 94CB Resistance, firing circuit, driver's airbag, stage 1, too high
0x6E6294CC 94CC Resistance, firing circuit, driver's airbag, stage 1, cannot be measured
0x6E6294CE 94CE Steering-wheel electronics
0x6E6294CF 94CF Steering-wheel electronics
0x6E6294D0 94D0 Coding, firing circuit, driver's airbag, stage 1, at variance
0x6E6294D1 94D1 Steering-wheel electronics
0x6E6294D2 94D2 Steering-wheel electronics
0x6E6294D3 94D3 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6294D4 94D4 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6294D6 94D6 Resistance, firing circuit, driver's airbag, stage 2, too high
0x6E6294D7 94D7 Resistance, firing circuit, driver's airbag, stage 2, cannot be measured
0x6E6294D9 94D9 Steering-wheel electronics
0x6E6294DA 94DA Steering-wheel electronics
0x6E6294DB 94DB Coding, firing circuit, driver's airbag, stage 2, at variance
0x6E6294DC 94DC Steering-wheel electronics
0x6E6294DD 94DD Fault in alarm path
0x6E6294DE 94DE Transmission selector switch: bus fault
0x6E6294DF 94DF Transmission selector switch: bus fault and serial line fault
0x6E6294E0 94E0 Transmission selector switch: parking button, contact, faulty
0x6E6294E1 94E1 No terminal 30
0x6E6294E4 94E4 Steering-angle sensor plausibility
0x6E6294E5 94E5 Control-module fault
0x6E6294E6 94E6 Control-module fault
0x6E6294E7 94E7 Control-module fault
0x6E6294E9 94E9 Steering-angle sensor, internal
0x6E6294EB 94EB Steering wheel electronics: version not compatible
0x6E6294EC 94EC Multifunction steering wheel, left: short/open circuit
0x6E6294ED 94ED Multifunction steering wheel, right: short/open circuit
0x6E6294EE 94EE Multifunction steering wheel, left: voltage value not defined
0x6E6294EF 94EF Multifunction steering wheel, right: voltage value not defined
0x6E6294F0 94F0 Steering wheel heating: heating mat, open circuit
0x6E6294F1 94F1 Steering wheel heating: heating mat, short-circuit to terminal 31
0x6E6294F2 94F2 Steering wheel heating: heating mat, short-circuit to terminal 30
0x6E6294F3 94F3 Steering wheel heating: timeout control
0x6E6294F4 94F4 Steering wheel heating: temperature sensor faulty
0x6E6294F5 94F5 Steering column adjustment switch: short-circuit to ground
0x6E6294F6 94F6 Steering column adjustment switch: open/short-circuit to positive
0x6E6294F7 94F7 Steering column adjustment switch: voltage value not defined
0x6E6294F8 94F8 Fault, horn
0x6E6294F9 94F9 Fault, horn
0x6E6294FA 94FA Steering-column-switch evaluation faulty (E65, E66, E67, RR01) or programming fault (E60, E61, E63, E64)
0x6E6294FB 94FB Control-module fault
0x6E6294FC 94FC Steering wheel electronics: no triggering readiness
0x6E6294FD 94FD Steering wheel electronics: fault in alarm path
0x6E6294FE 94FE Control-module fault
0x6E6294FF 94FF Control-module fault
0x6E629501 9501 Steering-angle-sensor calibration
0x6E629502 9502 Control-module fault
0x6E629503 9503 Control-module fault
0x6E629506 9506 Steering-wheel electronics
0x6E629507 9507 Steering-wheel electronics
0x6E629508 9508 Steering-wheel electronics
0x6E629509 9509 Steering-wheel electronics
0x6E62950A 950A Steering-wheel electronics
0x6E62950B 950B Transport mode active
0x6E629519 9519 Voltage supply: limit value exceeded
0x6E62951B 951B Voltage supply (LRE): limit value exceeded
0x6E62951D 951D Coding-data fault
0x6E6394A8 94A8 Processor: reset
0x6E6394A9 94A9 Control-unit fault
0x6E6394AA 94AA Control-unit fault
0x6E6394AB 94AB Incorrect chassis number
0x6E6394AC 94AC System time fault
0x6E6394AD 94AD Analog/digital converter faulty
0x6E6394AE 94AE No message (1) from satellite, door, front left
0x6E63949F 949F Signal or value below threshold
0x6E6394B0 94B0 No message (3) from satellite, door, front right
0x6E6394B1 94B1 Signal or value below threshold
0x6E6394B2 94B2 No message (5) from satellite, B-pillar, left
0x6E6394B3 94B3 No message (6) from satellite, A-pillar, left
0x6E6394B4 94B4 No message (7) from satellite, B-pillar, right
0x6E6394B5 94B5 No message (8) from satellite, A-pillar, right
0x6E6394B6 94B6 No message (9) from satellite, vehicle centre
0x6E6394B7 94B7 No message (A) from safety information module
0x6E6394B8 94B8 No message (B) from satellite, A-pillar, left
0x6E6394B9 94B9 No message © from satellite, A-pillar, right
0x6E6394BA 94BA No message (D) from satellite, vehicle centre
0x6E6394BB 94BB signal or value
0x6E6394BD 94BD No message (20) from satellite, seat, driver
0x6E6394BE 94BE No message (21) from satellite, seat, passenger
0x6E6394BF 94BF No message (22) from satellite, rear seat
0x6E6394C0 94C0 No message (71) from safety Information Module
0x6E6394C1 94C1 Coding-data error
0x6E6394C2 94C2 Control-unit fault
0x6E6394C3 94C3 Self-test too few messages
0x6E6394C4 94C4 Self-test data error in message
0x6E6394C5 94C5 Self-test transmission error
0x6E6394C6 94C6 Implausible crash severity
0x6E6394C7 94C7 Firing transistor, firing circuit, driver's airbag, stage 1,faulty
0x6E6394C8 94C8 Short circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6394C9 94C9 Short circuit, firing circuit, driver's airbag, stage 1, to positive
0x6E6394CA 94CA Resistance, firing pellet, firing circuit, driver's airbag, stage 1, too low
0x6E6394CB 94CB Resistance, firing pellet, firing circuit, driver's airbag, stage 1, too high
0x6E6394CC 94CC Resistance, firing pellet, firing circuit, driver's airbag, stage 1, can not be measured
0x6E6394CD 94CD Open circuit, firing circuit, driver's airbag, stage 1
0x6E6394CE 94CE Voltage, firing circuit, driver's airbag, stage 1, not OK
0x6E6394CF 94CF Firing capacitor, firing circuit, driver's airbag, stage 1, not OK
0x6E6394D0 94D0 Coding/configuration, firing circuit, driver's airbag, stage 1, at variance
0x6E6394D1 94D1 Open circuit, discharge circuit, firing circuit, driver's airbag, stage 1
0x6E6394D2 94D2 Firing transistor, firing circuit, driver's airbag, stage 2. faulty
0x6E6394D3 94D3 Short circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6394D4 94D4 Short circuit, firing circuit, driver's airbag, stage 2, to position
0x6E6394D5 94D5 Resistance, firing pellet, firing circuit, driver's airbag, stage 2, too low
0x6E6394D6 94D6 Resistance, firing pellet, firing circuit, driver's airbag, stage 2, too high
0x6E6394D7 94D7 Resistance, firing pellet, firing circuit, driver's airbag, stage 2, can not be measured
0x6E6394D8 94D8 Open circuit, firing circuit, driver's airbag, stage 2
0x6E6394D9 94D9 Voltage, firing circuit, driver's airbag, stage 2, not OK
0x6E6394DA 94DA Firing capacitor, firing circuit, driver's airbag, stage 2, not OK
0x6E6394DB 94DB Coding/configuration, firing circuit, driver's airbag, stage 2, at variance
0x6E6394DC 94DC Open circuit, discharge circuit, firing circuit, driver's airbag, stage 2
0x6E6394DD 94DD Fault in alarm path
0x6E6394DE 94DE Transmission selector switch: bus fault
0x6E6394DF 94DF Transmission selector switch: bus fault and serial-line fault
0x6E6394E0 94E0 Transmission selector switch: parking button, contact, faulty
0x6E6394E1 94E1 No terminal 30 at steering-column switch centre
0x6E6393E2 93E2 Terminal 15 implausible
0x6E6394E3 94E3 No terminal U_Isis
0x6E6394E4 94E4 Steering-angle sensor: mechanical connection faulty
0x6E6394E5 94E5 Steering-angle sensor: internal fault
0x6E6394E6 94E6 Steering-angle sensor: internal fault
0x6E6394E7 94E7 Steering-angle sensor: internal fault
0x6E6394E8 94E8 Steering-angle sensor: no speed signals
0x6E6394E9 94E9 Steering angle implausible
0x6E6394EA 94EA Communication steering-wheel electronics steering-column electronics faulty
0x6E6394EB 94EB Steering-wheel electronics: version not compatible
0x6E6394EC 94EC Multifunction steering wheel, left, short/open circuit
0x6E6394ED 94ED Multifunction steering wheel, right, short/open circuit
0x6E6394EE 94EE Multifunction steering wheel, left, voltage value not defined
0x6E6394EF 94EF Multifunction steering wheel, right, voltage value not defined
0x6E6394F0 94F0 Steering-wheel heating: heating mat, open circuit
0x6E6394F1 94F1 Steering-wheel heating: heating mat, short circuit to terminal 31
0x6E6394F2 94F2 Steering-wheel heating: heating mat, short circuit to terminal 30
0x6E6394F3 94F3 Steering-wheel heating: timeout control
0x6E6394F4 94F4 Steering-wheel heating: temperature sensor faulty
0x6E6394F5 94F5 Steering-column adjustment switch: short circuit to ground
0x6E6394F6 94F6 Steering-column adjustment switch: open/short circuit to positive
0x6E6394F7 94F7 Steering-column adjustment switch: voltage value not defined
0x6E6394F8 94F8 Fault, fanfare horn
0x6E6394F9 94F9 Fault, fanfare horn
0x6E6394FA 94FA Steering-column-stalk evealuation faulty
0x6E6394FB 94FB Steering-angle sensor: voltage supply, internal
0x6E6394FC 94FC steering-wheel electronics: no triggering readiness
0x6E6394FD 94FD Steering-wheel electronics: fault in alarm path
0x6E6394FE 94FE Control-unit fault
0x6E6394FF 94FF Control-unit fault
0x6E639500 9500 Firing attempt taken place
0x6E639501 9501 Steering-angle sensor not adjusted
0x6E639502 9502 Control-unit fault
0x6E639503 9503 Steering-angle sensor, reset time measurement incorrect
0x6E639504 9504 Active Front steering: serial line fault
0x6E639505 9505 Communication error CAN
0x6E639506 9506 Control-unit fault
0x6E639507 9507 Control-unit fault
0x6E639508 9508 Control-unit fault
0x6E639509 9509 Control-unit fault
0x6E63950A 950A Control-unit fault
0x6E6494A8 94A8 Processor: reset
0x6E6494A9 94A9 Control-module fault
0x6E6494AA 94AA Control-module fault
0x6E6494AB 94AB Incorrect chassis number
0x6E6494AC 94AC System time fault
0x6E6494AD 94AD Control-module fault
0x6E6494C1 94C1 Coding/data error
0x6E6494C2 94C2 Control-module fault
0x6E6494C3 94C3 Self-test: too few messages
0x6E6494C4 94C4 Self-test: data error in messages
0x6E6494C5 94C5 Self-test: transmission error
0x6E6494C6 94C6 Implausible crash severity
0x6E6494C7 94C7 Steering-wheel electronics
0x6E6494C8 94C8 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6494C9 94C9 Short-circuit, firing circuit, driver's airbag, stage 1, to ground
0x6E6494CA 94CA Resistance, firing circuit, driver's airbag, stage 1, too low
0x6E6494CB 94CB Resistance, firing circuit, driver's airbag, stage 1, too high
0x6E6494CC 94CC Resistance, firing circuit, driver's airbag, stage 1, cannot be measured
0x6E6494CD 94CD Open circuit, firing circuit, driver's airbag, stage 1
0x6E6494CE 94CE Steering-wheel electronics
0x6E6494CF 94CF Steering-wheel electronics
0x6E6494D0 94D0 Coding, firing circuit, driver's airbag, stage 1, at variance
0x6E6494D1 94D1 Steering-wheel electronics
0x6E6494D2 94D2 Steering-wheel electronics
0x6E6494D3 94D3 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6494D4 94D4 Short-circuit, firing circuit, driver's airbag, stage 2, to ground
0x6E6494D5 94D5 Resistance, firing circuit, driver's airbag, stage 2, too low
0x6E6494D6 94D6 Resistance, firing circuit, driver's airbag, stage 2, too high
0x6E6494D7 94D7 Resistance, firing circuit, driver's airbag, stage 2, cannot be measured
0x6E6494D8 94D8 Open circuit, firing circuit, driver's airbag, stage 2
0x6E6494D9 94D9 Steering-wheel electronics
0x6E6494DA 94DA Steering-wheel electronics
0x6E6494DB 94DB Coding, firing circuit, driver's airbag, stage 2, at variance
0x6E6494DC 94DC Steering-wheel electronics
0x6E6494DD 94DD Fault in alarm path
0x6E6494DE 94DE Transmission selector switch: bus fault
0x6E6494DF 94DF Transmission selector switch: bus fault and serial line fault
0x6E6494E0 94E0 Transmission selector switch: parking button, contact, faulty
0x6E6494E1 94E1 No terminal 30
0x6E6494E3 94E3 Terminal U_ISIS or U_SZL missing
0x6E6494E4 94E4 Steering-angle sensor plausibility
0x6E6494E5 94E5 Control-module fault
0x6E6494E6 94E6 Control-module fault
0x6E6494E7 94E7 Control-module fault
0x6E6494E9 94E9 Steering-angle sensor, internal
0x6E6494EA 94EA Communication between steering wheel module and steering column module faulty
0x6E6494EB 94EB Steering wheel electronics: version not compatible
0x6E6494EC 94EC Multifunction steering wheel, left: short/open circuit
0x6E6494ED 94ED Multifunction steering wheel, right: short/open circuit
0x6E6494EE 94EE Multifunction steering wheel, left: voltage value not defined
0x6E6494EF 94EF Multifunction steering wheel, right: voltage value not defined
0x6E6494F0 94F0 Steering wheel heating: heating mat, open circuit
0x6E6494F1 94F1 Steering wheel heating: heating mat, short-circuit to terminal 31
0x6E6494F2 94F2 Steering wheel heating: heating mat, short-circuit to terminal 30
0x6E6494F3 94F3 Steering wheel heating: timeout control
0x6E6494F4 94F4 Steering wheel heating: temperature sensor faulty
0x6E6494F5 94F5 Steering column adjustment switch: short-circuit to ground
0x6E6494F6 94F6 Steering column adjustment switch: open/short-circuit to positive
0x6E6494F7 94F7 Steering column adjustment switch: voltage value not defined
0x6E6494F8 94F8 Fault, horn
0x6E6494F9 94F9 Fault, horn
0x6E6494FA 94FA Steering-column-switch evaluation faulty (E65, E66, E67, RR01) or programming fault (E60, E61, E63, E64)
0x6E6494FB 94FB Control-module fault
0x6E6494FC 94FC Steering wheel electronics: no triggering readiness
0x6E6494FD 94FD Steering wheel electronics: fault in alarm path
0x6E6494FE 94FE Control-module fault
0x6E6494FF 94FF Control-module fault
0x6E649500 9500 Firing attempt taken place
0x6E649501 9501 Steering-angle-sensor calibration
0x6E649502 9502 Control-module fault
0x6E649503 9503 Control-module fault
0x6E649506 9506 Steering-wheel electronics
0x6E649507 9507 Steering-wheel electronics
0x6E649508 9508 Steering-wheel electronics
0x6E649509 9509 Steering-wheel electronics
0x6E64950A 950A Steering-wheel electronics
0x6E64950B 950B Transport mode active
0x6E649518 9518 Voltage supply: limit value undershot
0x6E649519 9519 Voltage supply: limit value exceeded
0x6E64951A 951A Voltage supply (LRE): limit value undershot
0x6E64951B 951B Voltage supply (LRE): limit value exceeded
0x6E64951D 951D Coding-data fault
//TMBFT
0x72619B8A 9B8A Undervoltage
0x72619B97 9B97 Switch, Soft Close Automatic
0x72619BA4 9BA4 Power-window electronics
0x72619BA6 9BA6 Window Position invalid
0x72619BB5 9BB5 Mirror, potentiometer, vertical
0x7261DC44 DC44 K-CAN line fault
0x72619B88 9B88 Control module
0x72619B89 9B89 Switch block
0x72619B8A 9B8A Under-voltage
0x72619B8B 9B8B Transport mode active
0x72619B8E 9B8E Spare
0x72619B8F 9B8F Spare
0x72619B90 9B90 Central locking drive, unlocking
0x72619B91 9B91 Central locking drive, locking
0x72619B92 9B92 Central locking drive, double locking
0x72619B93 9B93 Motor, electric opening
0x72619B94 9B94 Motor, soft Close Automatic
0x72619B95 9B95 Switch, child lock
0x72619B96 9B96 Switch, central locking, unlocking
0x72619B98 9B98 Switch, electric opening
0x72619B99 9B99 Electric opening
0x72619B9A 9B9A Footwell light
0x72619B9B 9B9B Door warning light
0x72619B9C 9B9C Comfort lighting
0x72619B9D 9B9D Far-field lighting
0x72619BA0 9BA0 Power window fault
0x72619BA1 9BA1 Power window fault
0x72619BA2 9BA2 Power window sluggish
0x72619BA3 9BA3 Power window electronics
0x72619BA4 9BA4 Power window electronics
0x72619BA5 9BA5 Power window terminal voltage
0x72619BA6 9BA6 Window position invalid
0x72619BA7 9BA7 Power window characteristic curve
0x72619BA9 9BA9 Power window electronics
0x72619BB0 9BB0 Motor, mirror adjustment, horizontal
0x72619BB1 9BB1 Motor, mirror adjustment, vertical
0x72619BB2 9BB2 Motor, mirror pivoting
0x72619BB3 9BB3 Mirror heating
0x72619BBA 9BBA Mirror, potentiometer, horizontal
//TMBFH
0x73619C0A 9C0A Under voltage
0x73619C25 9C25 Power-window terminal voltage
0x73619C24 9C24 Power-window electronics
0x7361DCC4 DCC4 K-CAN line fault
0x73619C08 9C08 Control unit
0x73619C09 9C09 Switch block
0x73619C0A 9C0A Under-voltage
0x73619C0B 9C0B Transport mode active
0x73619C0E 9C0E Spare
0x73619C0F 9C0F Spare
0x73619C10 9C10 Central locking drive, unlocking
0x73619C11 9C11 Central locking drive, locking
0x73619C12 9C12 Central locking drive, double locking
0x73619C13 9C13 Motor, electric opening
0x73619C14 9C14 Motor, Soft Close Automatic
0x73619C15 9C15 Switch, child lock
0x73619C16 9C16 Switch, central locking, unlocking
0x73619C17 9C17 Switch, Soft Close Automatic
0x73619C18 9C18 Switch, electric opening
0x73619C19 9C19 Electric opening
0x73619C1A 9C1A Footwell light
0x73619C1B 9C1B Door warning light
0x73619C1C 9C1C Comfort lighting
0x73619C1D 9C1D Far-field lighting
0x73619C20 9C20 Power window fault
0x73619C21 9C21 Power window fault
0x73619C22 9C22 Power windows sluggish
0x73619C23 9C23 Power window electronics
0x73619C24 9C24 Power window electronics
0x73619C25 9C25 Power window terminal voltage
0x73619C26 9C26 window position invalid
0x73619C27 9C27 Power window characteristic curve
0x73619C29 9C29 Power window electronics
0x73619C30 9C30 Mirror adjusting motor, horizontal
0x73619C31 9C31 Mirror adjusting motor, vertical
0x73619C32 9C32 Tilt-back motor, exterior rearview mirror
0x73619C33 9C33 Mirror heating
0x73619C35 9C35 Mirror position, potentiometer, vertical
0x73619C36 9C36 Mirror position, potentiometer, horizontal
//TMFAT
0x74619B4A 9B4A Undervoltage
0x74619B57 9B57 Switch, Soft Close Automatic
0x74619B64 9B64 Power-window electronics
0x74619B66 9B66 Window position invalid
0x74619B75 9B75 Mirror, potentiometer, vertical
0x7461DC04 DC04 K-CAN line fault
0x74619B48 9B48 Control module
0x74619B49 9B49 Switch block, driver's door
0x74619B4B 9B4B Transport mode active
0x74619B4E 9B4E Spare
0x74619B4F 9B4F Spare
0x74619B50 9B50 Central-locking drive, unlocking
0x74619B51 9B51 Central locking drive, locking
0x74619B52 9B52 Central-locking drive, double locking
0x74619B53 9B53 Motor, electric opening
0x74619B54 9B54 Motor, Soft Close Automatic
0x74619B55 9B55 Switch, child lock
0x74619B56 9B56 Switch, unlocking, driver's door
0x74619B58 9B58 Switch, electric opening
0x74619B59 9B59 Electric opening
0x74619B5A 9B5A Footwell light
0x74619B5B 9B5B Door warning light
0x74619B5C 9B5C Comfort lighting
0x74619B5D 9B5D Far-field lighting
0x74619B60 9B60 Power window fault
0x74619B61 9B61 Power window fault
0x74619B62 9B62 Power windows sluggish
0x74619B63 9B63 Power window electronics
0x74619B64 9B64 Power window electronics
0x74619B65 9B65 Power window terminal voltage
0x74619B67 9B67 Power window characteristic curve
0x74619B69 9B69 Power window electronics
0x74619B70 9B70 Motor, mirror adjustment, horizontal
0x74619B71 9B71 Motor, mirror adjustment, vertical
0x74619B72 9B72 Motor, mirror pivoting
0x74619B73 9B73 Mirror heating
0x74619B76 9B76 Mirror, potentiometer, horizontal
//TMFAH
0x75619BCA 9BCA Undervoltage
0x7561DC84 DC84 K-CAN line fault
0x7561DC87 DC87 K-CAN communication fault
0x75619BD7 9BD7 Switch, Soft Close Automatic
0x75619BC8 9BC8 Control module
0x75619BC9 9BC9 Switch block
0x75619BCA 9BCA Under-voltage
0x75619BCB 9BCB Transport mode active
0x75619BCE 9BCE Spare
0x75619BCF 9BCF Spare
0x75619BD0 9BD0 Central-locking drive, unlocking
0x75619BD1 9BD1 Central-locking drive, locking
0x75619BD2 9BD2 Central-locking drive, double locking
0x75619BD3 9BD3 Motor, electric opening
0x75619BD4 9BD4 Motor, Soft Close Automatic
0x75619BD5 9BD5 Switch, child lock
0x75619BD6 9BD6 Switch, central locking, unlocking
0x75619BD8 9BD8 Switch, electric opening
0x75619BD9 9BD9 Electric opening
0x75619BDA 9BDA Footwell light
0x75619BDB 9BDB Door warning light
0x75619BDC 9BDC Comfort lighting
0x75619BDD 9BDD Far-field lighting
0x75619BE0 9BE0 Power window fault
0x75619BE1 9BE1 Power window fault
0x75619BE2 9BE2 Power windows sluggish
0x75619BE3 9BE3 Power window electronics
0x75619BE4 9BE4 Power window electronics
0x75619BE5 9BE5 Power window terminal voltage
0x75619BE6 9BE6 Window position invalid
0x75619BE7 9BE7 Power window characteristic curve
0x75619BE9 9BE9 Power window electronics
0x75619BF0 9BF0 Mirror adjusting motor, horizontal
0x75619BF1 9BF1 Mirror adjusting motor, vertical
0x75619BF2 9BF2 Tilt-back motor, exterior rearview mirror
0x75619BF3 9BF3 Mirror heating
0x75619BF5 9BF5 Mirror position, potentiometer, vertical
0x75619BF6 9BF6 Mirror position, potentiometer, horizontal
//VM
0x7661A38D A38D Receiving System, aerial supply voltage: outside tolerance
0x7661A388 A388 RGB input Red
0x7661A389 A389 RGB input Green
0x7661A38A A38A RGB input Blue
0x7661A38B A38B RGB input Sync
0x7661A38D A38D Antenna supply voltage
0x7661A38E A38E Antenna supply current
0x7661A390 A390 FABAS 1 output signal
0x7661A391 A391 Short circuit to battery voltage
0x7661A392 A392 RGB Output1 Red
0x7661A393 A393 RGB Output1 Green Sync
0x7661A394 A394 RGB Output1 Red
0x7661A395 A395 RGB Output2 Red
0x7661A396 A396 RGB Output2 Green Sync
0x7661A397 A397 RGB Output2 Blue
0x7661DBD0 DBD0 Ring-break diagnosis has been carried out
//WIM
0x77619E08 9E08 Wiper module
0x77619E09 9E09 Wiper-module coding
0x77619E0B 9E0B Washer pump
0x77619E0C 9E0C Pump,headlight cleaning
0x77619E0D 9E0D Wet-arm heater
0x77619E0F 9E0F Wiper sluggish
0x77619E10 9E10 Wiper motor,Hall sensor
0x77619E11 9E11 Wiper in assembly mode
0x77619E12 9E12 Wiper motor,Hall sensor
//SBSL_2 MODE8
0x7B619828 9828 Processor: reset
0x7B619829 9829 Control-module fault
0x7B61982A 982A Control-module fault
0x7B61982B 982B Incorrect chassis number
0x7B61982C 982C System time fault
0x7B61983E 983E Control-module fault
0x7B619840 9840 Coding/data error
0x7B619841 9841 Coding-data error
0x7B619842 9842 Self-test: too few messages
0x7B619843 9843 Self-test: data error in message
0x7B619844 9844 Self test: transmission error
0x7B619845 9845 Implausible crash severity
0x7B619846 9846 Control-module fault
0x7B619847 9847 Short circuit, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), to ground
0x7B619848 9848 Short circuit, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), to positive
0x7B619849 9849 Resistance, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), too low
0x7B61984A 984A Resistance, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), too high
0x7B61984B 984B Resistance, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), not measured
0x7B61984C 984C Open circuit, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x)
0x7B61984D 984D Control-module fault
0x7B61984E 984E Control-module fault
0x7B61984F 984F Coding, firing circuit, front airbag, left, stage 1 (E85), or active head restraint, front left (E6x), at variance
0x7B619850 9850 Control-module fault
0x7B619851 9851 Control-module fault
0x7B619852 9852 Short circuit, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), to ground
0x7B619853 9853 Short circuit, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), to positive
0x7B619854 9854 Resistance, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), too low
0x7B619855 9855 Resistance, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), too high
0x7B619856 9856 Resistance, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), not measured
0x7B619857 9857 Open circuit, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x)
0x7B619858 9858 Control-module fault
0x7B619859 9859 Control-module fault
0x7B61985A 985A Coding, firing circuit, front airbag, left, stage 2 (E85), or active head restraint, front right (E6x), at variance
0x7B61985B 985B Control-module fault
0x7B61985C 985C Control-module fault
0x7B61985D 985D Short circuit, firing circuit, seat belt tensioner, front left, to ground
0x7B61985E 985E Short circuit, firing circuit, seat belt tensioner, front left, to positive
0x7B61985F 985F Resistance, firing circuit, seat belt tensioner, front left, too low
0x7B619860 9860 Resistance, firing circuit, seat belt tensioner, front left, too high
0x7B619861 9861 Resistance, firing circuit, seat belt tensioner, front left, not measured
0x7B619862 9862 Open circuit, firing circuit, seat belt tensioner, front left
0x7B619863 9863 Control-module fault
0x7B619864 9864 Control-module fault
0x7B619865 9865 Coding, firing circuit, seat belt tensioner, front left, at variance
0x7B619866 9866 Control-module fault
0x7B619867 9867 Control-module fault
0x7B619868 9868 Short circuit, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), to ground
0x7B619869 9869 Short circuit, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), to positive
0x7B61986A 986A Resistance, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), too low
0x7B61986B 986B Resistance, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), too high
0x7B61986C 986C Resistance, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64), not measured
0x7B61986D 986D Open circuit, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64)
0x7B61986E 986E Control-module fault
0x7B61986F 986F Control-module fault
0x7B619870 9870 Coding, firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64) at variance
0x7B619871 9871 Control-module fault
0x7B619872 9872 Control-module fault
0x7B619873 9873 Short circuit, firing circuit, seat belt tensioner, rear left, to ground
0x7B619874 9874 Short circuit, firing circuit, seat belt tensioner, rear left, to positive
0x7B619875 9875 Resistance, firing circuit, seat belt tensioner, rear left, too low
0x7B619876 9876 Resistance, firing circuit, seat belt tensioner, rear left, too high
0x7B619877 9877 Resistance, firing circuit, seat belt tensioner, rear left, not measured
0x7B619878 9878 Open circuit, firing circuit, seat belt tensioner, rear left
0x7B619879 9879 Control-module fault
0x7B61987A 987A Control-module fault
0x7B61987B 987B Coding, firing circuit, seat belt tensioner, rear left, at variance
0x7B61987C 987C Control-module fault
0x7B61987D 987D Control-module fault
0x7B61987E 987E Short circuit, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), to ground
0x7B61987F 987F Short circuit, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), to positive
0x7B619880 9880 Resistance, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), too low
0x7B619881 9881 Resistance, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), too high
0x7B619882 9882 Resistance, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), not measured
0x7B619883 9883 Open circuit, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x)
0x7B619884 9884 Control-module fault
0x7B619885 9885 Control-module fault
0x7B619886 9886 Coding, firing circuit, knee airbag, front left (E85), or head airbag, left (E6x), at variance
0x7B619887 9887 Control-module fault
0x7B619888 9888 Control-module fault
0x7B619889 9889 Control-module fault
0x7B61988A 988A Control-module fault
0x7B61988B 988B Control-module fault
0x7B61988C 988C Control-module fault
0x7B61988D 988D Control-module fault
0x7B61988E 988E Control-module fault
0x7B61988F 988F Seat-belt buckle: short circuit
0x7B619890 9890 Seat-belt buckle: implausible measured value
0x7B619891 9891 Seat-belt buckle: open circuit
0x7B619892 9892 Control-module fault (E6x) or software fault (E85)
0x7B619893 9893 Seat-occupancy detector, passenger: open circuit
0x7B619894 9894 Seat-occupancy detector, passenger: short circuit
0x7B619895 9895 Seat-occupancy detector, passenger: communication fault
0x7B619896 9896 Control-module fault
0x7B619897 9897 Control-module fault
0x7B619898 9898 Firing attempt taken place
0x7B619899 9899 Control-module fault
0x7B61989E 989E Voltage supply not in permitted range
//SBSR_2
0x7C6198A8 98A8 Processor: reset
0x7C6198A9 98A9 Control-module fault
0x7C6198AA 98AA Control-module fault
0x7C6198AB 98AB Incorrect chassis number
0x7C6198AC 98AC System time fault
0x7C6198BE 98BE Control-module fault
0x7C6198C0 98C0 Coding/data error
0x7C6198C1 98C1 Coding-data error
0x7C6198C2 98C2 Self-test: too few messages
0x7C6198C3 98C3 Self-test: data error in message
0x7C6198C4 98C4 Self test: transmission error
0x7C6198C5 98C5 Implausible crash severity
0x7C6198C6 98C6 Control-module fault
0x7C6198C7 98C7 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, to ground
0x7C6198C8 98C8 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, to positive
0x7C6198C9 98C9 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, too low
0x7C6198CA 98CA Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, too high
0x7C6198CB 98CB Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, not measured
0x7C6198CC 98CC Open circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1
0x7C6198CD 98CD Control-module fault
0x7C6198CE 98CE Control-module fault
0x7C6198CF 98CF Coding, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 1, at variance
0x7C6198D0 98D0 Control-module fault
0x7C6198D1 98D1 Control-module fault
0x7C6198D2 98D2 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, to ground
0x7C6198D3 98D3 Short circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, to ground
0x7C6198D4 98D4 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, too low
0x7C6198D5 98D5 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, too high
0x7C6198D6 98D6 Resistance, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, not measured
0x7C6198D7 98D7 Open circuit, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2
0x7C6198D8 98D8 Control-module fault
0x7C6198D9 98D9 Control-module fault
0x7C6198DA 98DA Coding, firing circuit, front airbag, right (E85), or passenger airbag (E6x), stage 2, at variance
0x7C6198DB 98DB Control-module fault
0x7C6198DC 98DC Control-module fault
0x7C6198DD 98DD Short circuit, firing circuit, seat belt tensioner, front right, to ground
0x7C6198DE 98DE Short circuit, firing circuit, seat belt tensioner, front right, to positive
0x7C6198DF 98DF Resistance, firing circuit, seat belt tensioner, front right, too low
0x7C6198E0 98E0 Resistance, firing circuit, seat belt tensioner, front right, too high
0x7C6198E1 98E1 Resistance, firing circuit, seat belt tensioner, front right, not measured
0x7C6198E2 98E2 Open circuit, firing circuit, seat belt tensioner, front right
0x7C6198E3 98E3 Control-module fault
0x7C6198E4 98E4 Control-module fault
0x7C6198E5 98E5 Coding, firing circuit, seat belt tensioner, front right, at variance
0x7C6198E6 98E6 Control-module fault
0x7C6198E7 98E7 Control-module fault
0x7C6198E8 98E8 Short circuit, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), to ground
0x7C6198E9 98E9 Short circuit, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), to positive
0x7C6198EA 98EA Resistance, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), too low
0x7C6198EB 98EB Resistance, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), too high
0x7C6198EC 98EC Resistance, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64), not measured
0x7C6198ED 98ED Open circuit, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64)
0x7C6198EE 98EE Control-module fault
0x7C6198EF 98EF Control-module fault
0x7C6198F0 98F0 Coding, firing circuit, thorax airbag, rear right (E85, E60, E61), or knee airbag, front right (E63, E64) at variance
0x7C6198F1 98F1 Control-module fault
0x7C6198F2 98F2 Control-module fault
0x7C6198F3 98F3 Short circuit, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), to ground
0x7C6198F4 98F4 Short circuit, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), to positive
0x7C6198F5 98F5 Resistance, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), too low
0x7C6198F6 98F6 Resistance, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), too high
0x7C6198F7 98F7 Resistance, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), not measured
0x7C6198F8 98F8 Open circuit, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x)
0x7C6198F9 98F9 Control-module fault
0x7C6198FA 98FA Control-module fault
0x7C6198FB 98FB Coding, firing circuit, safety battery terminal (E85), or seat belt tensioner, rear right (E6x), at measured
0x7C6198FC 98FC Control-module fault
0x7C6198FD 98FD Control-module fault
0x7C6198FE 98FE Short circuit, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), to ground
0x7C6198FF 98FF Short circuit, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), to positive
0x7C619900 9900 Resistance, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), too low
0x7C619901 9901 Resistance, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), too high
0x7C619902 9902 Resistance, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), not measured
0x7C619903 9903 Open circuit, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x)
0x7C619904 9904 Control-module fault
0x7C619905 9905 Control-module fault
0x7C619906 9906 Coding, firing circuit, knee airbag, front right (E85), or head airbag, right (E6x), at variance
0x7C619907 9907 Control-module fault
0x7C619908 9908 Control-module fault
0x7C619909 9909 Control-module fault
0x7C61990A 990A Control-module fault
0x7C61990B 990B Control-module fault
0x7C61990C 990C Control-module fault
0x7C61990D 990D Control-module fault
0x7C61990E 990E Control-module fault
0x7C61990F 990F Seat-belt buckle: short circuit
0x7C619910 9910 Seat-belt buckle: implausible measured value
0x7C619911 9911 Seat-belt buckle: open circuit
0x7C619912 9912 Control-module fault (E6x) or software fault (E85)
0x7C619913 9913 Seat-occupancy detector, passenger: open circuit
0x7C619914 9914 Seat-occupancy detector, passenger: short circuit
0x7C619915 9915 Seat-occupancy detector, passenger: communication fault
0x7C619916 9916 Control-module fault
0x7C619917 9917 Control-module fault
0x7C619918 9918 Firing attempt taken place
0x7C619919 9919 Control-module fault
0x7C61991A 991A Battery lead (screen): open circuit
0x7C61991B 991B Battery lead (screen): short circuit to ground
0x7C61991C 991C Battery lead (screen): short circuit to positive
0x7C61991D 991D Battery lead (screen): implausible measured value
0x7C61991E 991E Voltage supply not in permitted range
//AL
0x8061612C 612C Control unit: hardware fault
0x80616134 6134 Motor actuating unit: fault, current
0x8061613A 613A Undervoltage
0x8061613C 613C Angle sum relation incorrect
0x8061613E 613E Lock: mechanical fault
0x8061613F 613F Steering-angle plausibility
0x80616140 6140 Redundancy comparison, driver steering angle, top
0x80616145 6145 No monitoring of angle sum relation
0x8061614A 614A Motor position angle not initialized
0x8061CE93 CE93 Message (steering-wheel angle top, OC8)
0x8061612C 612C Control unit:hardware fault
0x8061612D 612D Fluid temperature,steering
0x8061612E 612E Control unit:comparison,vehicle identification numbers
0x8061612F 612F Control unit:coding data error
0x80616130 6130 Control unit:boot or flash error MPC
0x80616131 6131 Control unit:flash operation or error NEC
0x80616132 6132 Redundant driver steering angle(SZL)
0x80616133 6133 Motor actuating unit:fault,voltage
0x80616134 6134 Motor actuating unit:fault,current
0x80616136 6136 Sensor supply,engine position
0x80616137 6137 Engine position sensor
0x80616138 6138 Servomotor overtemperature
0x80616139 6139 Vehicle ref. speed or direction of travel uncertain or not available
0x8061613B 613B DSC sensors
0x8061613D 613D Lock:electrical fault
0x8061613E 613E Lock:mechanical fault
0x80616140 6140 Redundancy comparison,driver steering angle,top
0x80616141 6141 Engine-dynamics monitoring
0x80616142 6142 ECO value in SGM
0x80616143 6143 Servotronic value in SGM
0x80616144 6144 Interlock:self-locking monitoring
0x80616146 6146 Engine temperature sensor
0x80616147 6147 Cumulative steering angle sensor:fault,supply
0x80616149 6149 Combined position,speed monitoring
0x8061614B 614B Control unit:fault,operating system
0x8061CE93 CE93 Message(steering-wheel angle top,0C8)
//FRM
0x8361A409 A409 Undervoltage
//KBM
0x8362A409 A409 Undervoltage
0x8362A40B A40B Programming fault
0x8362A40D A40D Control-module fault
0x8362A410 A410 Interior lights
0x8362A411 A411 Load cutoff
0x8362A418 A418 Hall sensor, power-window motor, rear right
0x8362A419 A419 Hall sensor, power window, rear right
0x8362A41A A41A Voltage, power window, rear right
0x8362A41B A41B Electronics, power window, rear right
0x8362A41C A41C Relay, power window, rear right
0x8362A41D A41D Relay, power window, rear right
0x8362A41E A41E Power-window position, rear invalid
0x8362A41F A41F Power-window motor, rear right
0x8362A420 A420 Mechanism, power window, rear right
0x8362A421 A421 Outside temperature implausible
0x8362A422 A422 Electronics, power window, rear right
0x8362A423 A423 Anti-repeat circuit, power window, rear right
0x8362A428 A428 Interlock, windshield wiper motor
0x8362A429 A429 Rain sensor
0x8362A42A A42A Interlock, rear window wiper
0x8362A430 A430 Soft Close Automatic, rear lid
0x8362A431 A431 Soft Close Automatic, rear lid
0x8362A432 A432 Drive unit, Soft Close Automatic, rear lid
0x8362A433 A433 Electronics, Soft Close Automatic, rear lid
0x8362A435 A435 Relay for central locking, unlocking
0x8362A436 A436 Relay for central locking, unlocking
0x8362A437 A437 Relay, central locking, locking
0x8362A438 A438 Relay, central locking, locking
0x8362A439 A439 Relay for central locking, double locking
0x8362A43A A43A Relay for central locking, double locking
0x8362A43B A43B Drive unit, rear lid unlocking
0x8362A43C A43C Drive unit, rear lid unlocking
0x8362A43D A43D Button, rear lid unlocking
0x8362A43E A43E Diagnosis lead, rear lid relay
0x8362A43F A43F Diagnosis lead, central locking relay
0x8362A440 A440 Diagnosis lead, rear lid relay
0x8362A441 A441 Diagnosis lead, central locking relay
0x8362A442 A442 Rear-window unlocking
0x8362A443 A443 Rear-window unlocking
0x8362A444 A444 Rear-window unlocking
0x8362A447 A447 Transport mode active
0x8362A448 A448 Hall sensor, power-window motor, rear left
0x8362A449 A449 Hall sensor, power-window motor, rear left
0x8362A44A A44A Voltage, power-window motor, rear left
0x8362A44B A44B Electronics, power-window motor, rear left
0x8362A44C A44C Relay, power-window motor, rear left
0x8362A44D A44D Relay, power-window motor, rear left
0x8362A44E A44E Window position, rear left, invalid
0x8362A44F A44F Power-window motor, rear left
0x8362A450 A450 Mechanism, power window, rear left
0x8362A451 A451 Outside temperature implausible
0x8362A452 A452 Electronics, power-window motor, rear left
0x8362A453 A453 Anti-repeat circuit, power-window motor, rear left
0x8362A455 A455 Mechanism, power window, rear left
0x8362A456 A456 Mechanism, power window, rear right
0x8362A457 A457 Drive unit, trunk space cover
0x8362A458 A458 Drive unit, trunk space cover
//FZD
0x8561A088 A088 Control switch SHD
0x8561A08A A08A Switch lighting
0x8561A08D A08D Coding incorrect
0x8561A090 A090 SHD mechanical system
0x8561A092 A092 SHD initialization
//RLS
0x8562A128 A128 Hardware fault, rain sensor
0x8562A129 A129 No adaptation to windshield
0x8562A12A A12A High temperature
0x8562A12B A12B Overvoltage / undervoltage
0x8562A12D A12D Hardware, light sensor
0x8562A12E A12E Calibration error, light sensor
//CCCA
0x8861A04A A04A Safety violation
0x8861A04E A04E Yaw sensor, internal fault
0x8861A04F A04F No speedometer signal but GPS position change
0x8861A050 A050 Too many speedo pulses
0x8861A051 A051 GPS direction and direction of travel do not correspond
0x8861A053 A053 Control-unit fault
0x8861A054 A054 GPS aerial not connected
0x8861A055 A055 Short circuit at GPS aerial connection
0x8861A056 A056 Control-unit fault
0x8861A057 A057 CCC time out equal to GPS time
0x8861A058 A058 Yaw-sensor fault during self-test
0x8861A059 A059 Yaw sensor issues incorrect signal
0x8861A05A A05A Yaw sensor, internal fault
0x8861A05B A05B General yaw-sensor fault
0x8861A05C A05C Yaw sensor, internal fault
0x8861A05D A05D Unknown speedo fault
0x8861A05F A05F Control-unit fault
0x8861A060 A060 Control-unit fault
0x8861A061 A061 Control-unit fault
0x8861A062 A062 No connection to HIP module
0x8861A063 A063 System fault
0x8861A6F1 A6F1 System fault
0x8861A6F2 A6F2 System fault
//CCCASK
0x8E61A18B A18B Control-unit fault
0x8E61A18C A18C Overcurrent, Minidisc player
0x8E61A18D A18D Overtemperature in Minidisc player
0x8E61A18E A18E MD hardware fault
0x8E61A18F A18F Loading mechanism of Minidisc player faulty
0x8E61A190 A190 Limit switch, loading mechanism of Minidisc player, faulty
0x8E61A191 A191 Control-unit fault
0x8E61A192 A192 Control-unit fault
0x8E61A193 A193 Connection fault between CCC-ASK and Minidisc player
0x8E61A194 A194 Control-unit fault
0x8E61A195 A195 Control-unit fault
0x8E61A196 A196 Control-unit fault
0x8E61A197 A197 Hardware fault in CCC
0x8E61A198 A198 No connection to minidisc player
0x8E61A199 A199 Control-unit fault
0x8E61A19B A19B Control-unit fault
0x8E61A19C A19C Microphone cable not connected or short circuit
0x8E61A19D A19D AUX not connected or short circuit
0x8E61A1A2 A1A2 Control-unit fault
0x8E61A1A3 A1A3 Control-unit fault
0x8E61A1A4 A1A4 Control-unit fault
0x8E61A1A5 A1A5 Control-unit fault
//FLA
//INSTR
0xA661930E 930E Gear display P
0xA6619316 9316 Odometer memory
0xA6619319 9319 Fuel-level sensor, right
0xA661931A 931A Fuel-level sensor, left
0xA661931B 931B Outside temperature
0xA661931C 931C Display-heater short circuit
0xA661931D 931D System voltage
//ANT
0xBF61A508 A508 Voltage supply, aerials
//BZM
0XC1619FC8 9FC8 Menu buttons,left
0XC1619FC9 9FC9 Turn rotary knob,left
0XC1619FCA 9FCA Heating/ventilation,left
0XC1619FCB 9FCB Push rotary knob,left
0XC1619FCC 9FCC Memory button,left
0XC1619FCD 9FCD Menu buttons,right
0XC1619FCE 9FCE Turn rotary knob,right
0XC1619FCF 9FCF Heating/ventilation,right
0XC1619FD0 9FD0 Push rotary knob,right
0XC1619FD1 9FD1 Memory button,right
//LM2
0xC5619CAB 9CAB One terminal 15 missing
0xC5619CB1 9CB1 Potentiometer, dimmer, faulty
0xC5619CB3 9CB3 Ride-height sensor, front, faulty
0xC5619CB4 9CB4 Ride-height sensor, rear ,faulty
0xC5619CB6 9CB6 HVAC coil chopping
0xC5629CAB 9CAB One terminal 15 missing
0xC5629CB1 9CB1 Potentiometer, dimmer, faulty
0xC5629CB3 9CB3 Ride-height sensor, front, faulty
0xC5629CB4 9CB4 Ride-height sensor, rear ,faulty
0xC5629CB6 9CB6 HVAC coil chopping
0xC5629CBC 9CBC Short circuit in a lamp circuit
0xC5629CBD 9CBD Battery exhaustive-protection: deactivation, side light
0xC5629CA8 9CA8 Control-module fault
0xC5629CA9 9CA9 Terminal 30A connection faulty
0xC5629CAA 9CAA Terminal 30B connection faulty
0xC5629CAC 9CAC Brake-light switch faulty
0xC5629CAD 9CAD AHM communication disturbed
0xC5629CAE 9CAE Control-panel fault
0xC5629CAF 9CAF Light switch position 1 faulty
0xC5629CB0 9CB0 Light switch position 2 faulty
0xC5629CB1 9CB1 Dimmer potentiometer faulty
0xC5629CB2 9CB2 LWR potentiometer faulty
0xC5629CB3 9CB3 Sensor, ride level, front, faulty
0xC5629CB4 9CB4 Ride-level sensor, rear, faulty
0xC5629CB5 9CB5 Transport mode active
0xC5629CB7 9CB7 HVAC driver fault
0xC5629CB8 9CB8 Lamp dimming faulty
0xC5629CB9 9CB9 Short circuit at a lamp output
0xC5629CBA 9CBA Short circuit at a lamp output
0xC5629CBB 9CBB Short circuit at a lamp output
0xC5629CBC 9CBC Short circuit at a lamp output
0xC5629CBD 9CBD Exhaustive-discharge protection of battery:deactivation,side-market light
0xC5629CBE 9CBE Exhaustive-discharge protection of battery:deactivation,parking light
0xC5629CBF 9CBF Battery exhausted
0xC5629CC0 9CC0 Software status and coding index do not match
0xC5639CAB 9CAB One terminal 15 missing
0xC5639CB1 9CB1 Potentiometer, dimmer, faulty
0xC5639CB3 9CB3 Ride-height sensor, front, faulty
0xC5639CB4 9CB4 Transport mode active
0xC5639CB6 9CB6 Short circuit in a lamp circuit
0xC5639CBC 9CBC Communication with SMC, left, disrupted
0xC5639CBD 9CBD Communication with SMC, right, disrupted
0xC5639CC3 9CC3 Battery exhausted
0xC5649CAB 9CAB One terminal 15 missing
0xC5649CB1 9CB1 Potentiometer, dimmer, faulty
0xC5649CB3 9CB3 Ride-height sensor, front, faulty
0xC5649CB4 9CB4 Transport mode active
0xC5649CB6 9CB6 Headlight vertical aim control coil break
0xC5649CBC 9CBC Communication with SMC, left, disrupted
0xC5649CBD 9CBD Communication with SMC, right, disrupted
0xC5649CC3 9CC3 LIN line fault (RLS)
0xC5659CA8 9CA8 Control-unit fault
0xC5659CA9 9CA9 Terminal 30A connection faulty
0xC5659CAB 9CAB Terminal 30B connection faulty
0xC5659CAB 9CAB One terminal 15 missing
0xC5659CAC 9CAC Brake-light switch faulty
0xC5659CAD 9CAD AHM communication disturbed
0xC5659CAE 9CAE Control-panel fault
0xC5659CAF 9CAF Light-switch position 1 faulty
0xC5659CB0 9CB0 Lgiht-switch psoition 2 faulty
0xC5659CB1 9CB1 Dimmer potentiometer faulty
0xC5659CB3 9CB3 Sensor, ride level, front, faulty
0xC5659CB4 9CB4 Ride-level sensor, rear, faulty
0xC5659CB5 9CB5 Transport mode active
0xC5659CB6 9CB6 HVAC coil chopping
0xC5659CB7 9CB7 HVAC driver fault
//PM
0xCA61A148 A148 Control-unit fault
0xCA61A149 A149 Input te.15 waking
0xCA61A14A A14A Battery switch
0xCA61A152 A152 Driver, electrical load, roof
0xCA61A154 A154 Fuel-filler-flap motor
0xCA61A156 A156 Rear-lid contact
0xCA61A158 A158 Battery disconnection (closed-circuit current)
0xCA61A15D A15D Battery, exhaustive discharge
0xCA61A161 A161 Battery, disconnection (Closed-circuit current)
0xCA61A163 A163 No bus rest, in spite of disconnection 30U and 30G
0xCA62A6A4 A6A4 Control-module fault
0xCA62A6A5 A6A5 Coding-data fault
0xCA62A6A6 A6A6 Coding-data fault
0xCA62A6A7 A6A7 Control-module fault
0xCA62A6A8 A6A8 Control-module fault
0xCA62A6A9 A6A9 Voltage supply, relay 1
0xCA62A6AA A6AA Voltage supply, relay 2
0xCA62A6AB A6AB Terminal 30
0xCA62A6AC A6AC Transport mode active
0xCA63A148 A148 Control module fault
0xCA63A149 A149 Input term. 15 waking
0xCA63A14A A14A Battery switch
0xCA63A14B A14B Eccentric contact
0xCA63A14C A14C Battery temperature sensor
0xCA63A14D A14D Driver Term. 30
0xCA63A14E A14E Driver, rear window defroster
0xCA63A14F A14F Driver, interior lighting
0xCA63A150 A150 Driver Term. 15
0xCA63A151 A151 Driver Term. R
0xCA63A152 A152 Driver, electrical load, roof
0xCA63A153 A153 Driver, electrical load, body
0xCA63A154 A154 Fuel filler flap motor
0xCA63A155 A155 Trunk motor
0xCA63A156 A156 Trunk contact
0xCA63A157 A157 SCA motor
0xCA63A158 A158 Battery disconnection (closed-circuit current)
0xCA63A159 A159 Battery disconnection (lmax)
0xCA63A15A A15A Battery disconnection (short circuit)
0xCA63A15B A15B Driver, light module
0xCA63A15C A15C Transport mode active
0xCA63A15D A15D Battery, exhaustive discharge
0xCA63A15E A15E Light module
0xCA63A15F A15F Exhibition mode
0xCA63A160 A160 Multi-fuses
//SGM-SIM
0xCC6193A8 93A8 Processor: reset
0xCC6193C1 93C1 Control-unit fault
0xCC6193C2 93C2 Self-test: too few messages
0xCC6193C9 93C9 Deactivation: satellite, A-pillar, left
0xCC6193CA 93CA Deactivation: satellite, A-pillar, right
0xCC6193CB 93CB Deactivation: satellite, vehicle centre
0xCC6193CC 93CC Deactivation: satellite, door, front left
0xCC6193CD 93CD Deactivation: satellite, seat, driver
0xCC6193CF 93CF Deactivation: satellite, door, front right
0xCC6193D0 93D0 Deactivation: satellite, seat, passenger
0xCC6193D9 93D9 Control-unit fault
0xCC6193DE 93DE Firing attempt taken place
0xCC6193DF 93DF Under voltage
0xCC6193A8 93A8 Processor: Reset
0xCC6193A9 93A9 Control-module fault
0xCC6193AA 93AA Control-module fault
0xCC6193AB 93AB Incorrect chassis number
0xCC6193AC 93AC System time fault
0xCC6193C0 93C0 Coding/data error
0xCC6193C1 93C1 Control-module fault
0xCC6193C3 93C3 Self-test: data error in message
0xCC6193C4 93C4 Self-test: transmission error
0xCC6193C5 93C5 Implausible crash severity
0xCC6193C6 93C6 Control-module fault
0xCC6193C8 93C8 Deactivation: switch center, steering column
0xCC6193CB 93CB Deactivation: satellite, vehicle center
0xCC6193CD 93CD Deactivation: satellite, driver's seat
0xCC6193CE 93CE Deactivation: satellite, B-pillar, left
0xCC6193D0 93D0 Deactivation: satellite, passenger's seat
0xCC6193D1 93D1 Deactivation: satellite, B-pillar, right
0xCC6193D2 93D2 Deactivation: satellite, seat, rear
0xCC6193D9 93D9 Control-module fault
0xCC6193DB 93DB Control-module fault
0xCC6193DC 93DC Control-module fault
0xCC6193DD 93DD Control-module fault
0xCC6193DF 93DF Undervoltage
0xCC6193E0 93E0 Control-module fault
0xCC619488 9488 Attack alarm occurred
0xCC6293A8 93A8 Driver's airbag, stage 1
0xCC6293AD 93AD Side airbag, passenger
0xCC6293AE 93AE Side airbag, Driver, rear
0xCC6293AF 93AF Side airbag, passenger, rear
0xCC6293B4 93B4 Driver's airbag, stage 2
0xCC6293B5 93B5 Seat-belt tensioner, driver, rear
0xCC6293B8 93B8 Knee airbag, driver
0xCC6293BC 93BC Belt-buckle contact, driver, rear
0xCC6293BD 93BD Belt-buckle contact, passenger, rear
0xCC6293BE 93BE Switch for front passenger airbag deactivation
0xCC6293C1 93C1 Communication fault, seat-occupancy detector, passenger
0xCC6293C2 93C2 Seat mat, seat-occupancy detector, passenger, faulty
0xCC6293C9 93C9 Airbag front sensor, front passenger's side
0xCC6293CA 93CA Airbag sensor, B-pillar, driver's side (X-direction)
0xCC6293CB 93CB Airbag sensor, B-pillar, front passenger's side (X-direction)
0xCC6293CC 93CC Airbag sensor, B-pillar, driver's side (Y-direction)
0xCC6293CD 93CD Airbag sensor, B-pillar, front passenger's side (Y-directio)
0xCC6293CF 93CF Airbag sensor, door, passenger, front
0xCC6293D0 93D0 Under voltage
0xCC6293D7 93D7 Internal control-unit fault
0xCC6293D8 93D8 Seat occupancy detector, front passenger: system could not be released
0xCC6293D9 93D9 Airbag front sensor, driver's side: sensor type incorrect
0xCC6293DA 93DA Airbag front sensor, driver's side: sensor data implausible
0xCC6293DE 93DE Airbag sensor, B-pillar, driver's side (X-direction): sensor data implausible
0xCC6293DF 93DF Airbag sensor, B-pillar, passenger's side (X-direction): sensor type incorrect
0xCC6293E4 93E4 Airbag sensor, B-pillar, passenger's side (Y-direction): sensor data implausible
0xCC6293FC 93FC Battery lead, positive (monitoring of shielding)
0xCC6293A8 93A8 Driver's airbag,stage 1
0xCC6293A9 93A9 Belt tensioner.deiver
0xCC6293AA 93AA Belt tensioner,passenger
0xCC6293AB 93AB Passenger airbag,stage 1
0xCC6293AC 93AC Side airbag,driver
0xCC6293AD 93AD Side airbag,passenger
0xCC6293AE 93AE Side airbag,rear,driver's side
0xCC6293AF 93AF Side airbag,rear,passenger's side
0xCC6293B0 93B0 Head airbag,driver
0xCC6293B1 93B1 Head airbag,front passenger
0xCC6293B2 93B2 Safety battery terminal
0xCC6293B3 93B3 Passenger airbag,stage 2
0xCC6293B4 93B4 Driver's airbag,stage 2
0xCC6293B5 93B5 Seat-belt tensioner,rear,driver's side
0xCC6293B6 93B6 Seat-belt tensioner,rear,passenger's side
0xCC6293B8 93B8 Knee airbag,driver
0xCC6293BA 93BA Seatbelt-catch contact,driver
0xCC6293BB 93BB Seatbelt-catch contact,passenger
0xCC6293BC 93BC Belt-buckle contact,rear,driver's side
0xCC6293BD 93BD Belt-buckle contact,rear,passenger's side
0xCC6293C1 93C1 Seat-occupancy detector,passenger
0xCC6293C2 93C2 Sear mat,seat-occupancy detector,passenger
0xCC6293C3 93C3 Seat-occupancy detector,passenger
0xCC6293C4 93C4 Seat occupancy detector,front passenger:Internal fault
0xCC6293C5 93C5 Seat-occupancy detector,passenger:not released
0xCC6293C6 93C6 Backrest lock for driver's seat
0xCC6293C7 93C7 Backrest lock for passenger's seat
0xCC6293C8 93C8 Airbag front sensor,driver's side
0xCC6293C9 93C9 Airbag front sensor,front passenger's side
0xCC6293CA 93CA Airbag sensor,B-pillar,driver's side(X-direction)
0xCC6293CB 93CB Airbag sensor,B-pillar,front psssenger's side(X-direction)
0xCC6293CC 93CC Airbag sensor,B-pillar,driver's side(Y-direction)
0xCC6293CD 93CD Airbag sensor,B-pillar,front passenger's side(Y-direction)
0xCC6293CE 93CE Airbag sensor,door,front,driver's side
0xCC6293CF 93CF Airbag sensor,door,front,passenger's side
0xCC6293D0 93D0 Undervoltage
0xCC6293D1 93D1 Overvoltage
0xCC6293D2 93D2 Telltale lamp for front passenger airbag deactivation
0xCC6293D3 93D3 Coding data incorrect
0xCC6293D4 93D4 Crash telegram stored
0xCC6293D5 93D5 Three crash telegrams stored
0xCC6293D6 93D6 Coding data incorrect
0xCC6293D8 93D8 Seat occupancy detector,front passenger:Internal fault
0xCC6293D9 93D9 Airbag front sensor,driver's side:sensor type incorrect
0xCC6293DA 93DA Airbag front sensor,driver's side:sensor data implausible
0xCC6293DB 93DB Airbag front sensor, passenger's side:sensor type incorrect
0xCC6293DC 93DC Airbag front sensor, passenger's side:sensor data implausible
0xCC6293DD 93DD Airbag sensor,B-pillar,driver's side(X-direction):sensor type incorrect
0xCC6293DE 93DE Airbag sensor,B-pillar,driver' side(X-direction):sensor data implausible
0xCC6293DF 93DF Airbag sensor,B-pillar,passenger's side(X-direction): sensor type incorrect
0xCC6293E0 93E0 Airbag sensor,B-pillar,passenger's side(X-direction):sensor data implausible
0xCC6293E1 93E1 Airbag sensor,B-pillar,driver's side(Y-direction):sensor type incorrect
0xCC6293E2 93E2 Airbag sensor,B-pillar,driver' side(Y-direction):sensor data implausible
0xCC6293E3 93E3 Airbag sensor,B-pillar,passenger's side(Y-direction): sensor type incorrect
0xCC6293E4 93E4 Airbag sensor,B-pillar,passenger's side(Y-direction):sensor data implausible
0xCC6293E5 93E5 Airbag sensor,door,front,driver's side:sensor type incorrect
0xCC6293E6 93E6 Airbag sensor,door,front,driver's side:sensor data implausible
0xCC6293E7 93E7 Airbag sensor,door,front,passenger's side:sensor type incorrect
0xCC6293E8 93E8 Airbag sensor,door,front,passenger's side:sensor data implausible
0xCC6293EC 93EC Programming data faulty
0xCC6293F7 93F7 Knee airbag,front passenger
0xCC6293F8 93F8 Anchor-fitting tensioner,driver
0xCC6293F9 93F9 Active head restraint,driver
0xCC6293FA 93FA Active head restraint,front passenger
0xCC6293FC 93FC Battery lead,positive(monitoring of shielding)
0xCC6293FD 93FD Battery lead,ground(monitoring of shielding)
0xCC6293FE 93FE Rollover-proection controller:not fitted
0xCC6293FF 93FF Rollover-protection controller
0xCC629400 9400 Seat-occupancy detector,passenger:incorrect type
0xCC629401 9401 Rollover-protection controller:communication fault
0xCC629402 9402 Rollover-protection controller:internal fault
0xCC629403 9403 Rollover bar,left
0xCC629404 9404 Rollover bar,right
0xCC629405 9405 Rollover-protection controller:internal fault
0xCC629406 9406 Rollover-protection controller:undervoltage
0xCC629407 9407 Rollover-protection controller:internal fault
0xCC629408 9408 Undervoltage during self-test
0xCC629409 9409 Rollover-protection controller:reset
0xCC62940A 940A Overvoltage during self-test
0xCC62940B 940B Rollover-protection controller:sensor
0xCC62940C 940C Rollover-protection controller:sensor
0xCC6393A8 93A8 Processor: reset
0xCC6393AD 93AD System time fault
0xCC6393D7 93D7 Deactivation: Safety and Gateway Module
0xCC6393D8 93D8 Deactivation: switch centre, steering column switch cluster
0xCC6393D9 93D9 Deactivation: driver's door module (E60,E61,E63,E64) or steering column switch cluster(E65,E66,E67,RR01)
0xCC6393DA 93DA Deactivation: front passenger door module (E60,E61,E63,E64) or satellite, A-pillar, left (E65,E66,E67,RR01)
0xCC6393DE 93DE Deactivation: satellite, seat, driver
0xCC6393DF 93DF Deactivation: satellite, B-pillar, left
0xCC6393E4 93E4 Self-test: too few message
0xCC6393FB 93FB Control-unit fault
0xCC6393FC 93FC Under voltage
0xCC6393A9 93A9 Control-module fault
0xCC6393AA 93AA Control-module fault
0xCC6393AB 93AB Control-module fault
0xCC6393AC 93AC Incorrect chassis number
0xCC6393D8 93D8 Deactivation: switch center, steering column switch cluster
0xCC6393D9 93D9 Deactivation: driver's door module (E60, E61, E63, E64) or steering column switch cluster (E65, E66, E67, RR01)
0xCC6393DA 93DA Deactivation: front passenger door module (E60, E61, E63, E64) or satellite, A-pillar, left (E65, E66, E67, RR01)
0xCC6393DB 93DB Deactivation: satellite, B-pillar, left (E60, E61, E63, E64) or satellite, A-pillar, right (E65, E66, E67, RR01)
0xCC6393DC 93DC Deactivation: satellite, B-pillar, right (E60, E61, E63, E64) or satellite, vehicle center (E65, E66, E67, RR01)
0xCC6393DD 93DD Deactivation: satellite, vehicle center (E60, E61, E63, E64) or satellite, door, front left (E65, E66, E67, RR01)
0xCC6393DE 93DE Deactivation: satellite, driver's seat
0xCC6393E0 93E0 Deactivation: satellite, door, front right
0xCC6393E1 93E1 Deactivation: satellite, passenger's seat
0xCC6393E2 93E2 Deactivation: satellite, B-pillar, right
0xCC6393E3 93E3 Deactivation: satellite, seat, rear
0xCC6393E4 93E4 Self-test: too few messages
0xCC6393E5 93E5 Self-test: data fault in message
0xCC6393E6 93E6 Self-test: transmission fault
0xCC6393E9 93E9 Coding-data fault
0xCC6393EA 93EA Coding-data fault
0xCC6393EB 93EB Control-module fault
0xCC6393EC 93EC Control-module fault
0xCC6393F5 93F5 Control-module fault
0xCC6393F6 93F6 Control-module fault
0xCC6393F7 93F7 Control-module fault
0xCC6393F8 93F8 Control-module fault
0xCC6393F9 93F9 Control-module fault
0xCC6393FA 93FA Control-module fault
0xCC6393FB 93FB Control-module fault
0xCC6393FC 93FC Undervoltage
0xCC639401 9401 Control-module fault
0xCC639402 9402 Front sensor, left
0xCC639403 9403 Front sensor, right
0xCC639404 9404 Front sensor: wrong component
0xCC639406 9406 Current request from Active Front Steering too high
0xCC639407 9407 Servotronic converter
0xCC639408 9408 ECO converter
0xCC639409 9409 Overvoltage or under-voltage
0xCC63940F 940F Electric fuel pump deactivated
0xCC639410 9410 Coding-data fault
0xCC639411 9411 Indicator lamp, airbag deactivation: short circuit to ground
0xCC639412 9412 Indicator lamp, airbag deactivation: short circuit to positive
0xCC639413 9413 Signal lamp, airbag deactivation: open circuit
0xCC639415 9415 Rollover bar, left: short circuit to ground
0xCC639416 9416 Rollover bar, left: open circuit
0xCC639417 9417 Rollover bar, left: short circuit to positive
0xCC639418 9418 Rollover bar, right: short circuit to ground
0xCC639419 9419 Rollover bar, right: open circuit
0xCC63941A 941A Rollover bar, right: short circuit to positive
0xCC63941B 941B Rollover bar, left: resistance too high
0xCC63941C 941C Rollover bar, right: resistance too high
0xCC63941D 941D Rollover bar, left: resistance too low
0xCC63941E 941E Rollover bar, right: resistance too low
0xCC63941F 941F Control-module fault
0xCC639420 9420 Control-module fault
0xCC639421 9421 Control-module fault
0xCC639422 9422 Control-module fault
0xCC639423 9423 Control-module fault
0xCC639424 9424 No message ( via serial cable) from satellite, vehicle center
0xCC639425 9425 Serial cable to satellite, vehicle center
0xCC639426 9426 Activation, rollover bar
0xCC639427 9427 Implausible crash severity
0xCC63942B 942B Implausible crash severity
0xCC63942C 942C Fault, satellite, B-pillar
0xCC63942D 942D Fault, satellite, vehicle center
0xCC63942E 942E Attack alarm occurred
0xCC6493A8 93A8 Airbag, driver, 1st stage
0xCC6493A9 93A9 Seat belt tensioner, driver
0xCC6493AA 93AA Seat belt tensioner, passenger
0xCC6493AB 93AB Airbag, front passenger, 1st stage
0xCC6493AC 93AC Side airbag, front left
0xCC6493AD 93AD Side airbag, front right
0xCC6493AE 93AE Side airbag, rear left
0xCC6493AF 93AF Side airbag, rear right
0xCC6493B0 93B0 Head airbag, left
0xCC6493B1 93B1 Head airbag, right
0xCC6493B2 93B2 Safety battery terminal
0xCC6493B3 93B3 Airbag,front passenger,2nd stage
0xCC6493B4 93B4 Airbag,driver,2nd stage
0xCC6493B5 93B5 Belt tensioner,rear left
0xCC6493B6 93B6 Belt tensioner,rear right
0xCC6493B8 93B8 Knee airbag,driver
0xCC6493B9 93B9 Knee airbag,front passenger
0xCC6493BA 93BA Seatbelt-catch contact,driver
0xCC6493BB 93BB Seatbelt-catch contact,passenger
0xCC6493BC 93BC Seatbelt-catch contact,rear left
0xCC6493BD 93BD Seatbelt-catch contact,rear right
0xCC6493BE 93BE Switch for front passenger airbag deactivation
0xCC6493BF 93BF Switch for front passenger airbag deactivation inverted
0xCC6493C0 93C0 Switch for front passenger airbag deactivation:implausible signal
0xCC6493C1 93C1 Seat occupancy detector
0xCC6493C2 93C2 Seat mat,Seat occupancy detector
0xCC6493C3 93C3 Seat-occupancy detector,passenger
0xCC6493C4 93C4 Seat occupancy detector,front passenger:data memory full
0xCC6493C5 93C5 Seat occupancy detector,front passenger:system not yet released
0xCC6493C6 93C6 Backrest lock for driver's seat
0xCC6493C7 93C7 Backrest lock for passenger's seat
0xCC6493C8 93C8 Airbag front sensor,left
0xCC6493C9 93C9 Airbag front sensor,right
0xCC6493CA 93CA Airbag sensor,B-pillar,left(X-direction)
0xCC6493CB 93CB Airbag sensor,B-pillar,right(X-direction)
0xCC6493CC 93CC Airbag sensor,B-pillar,left(Y-direction)
0xCC6493CD 93CD Airbag sensor,B-pillar,right(Y-direction)
0xCC6493CE 93CE Airbag sensor,door,front left
0xCC6493CF 93CF Airbag sensor,door,front right
0xCC6493D0 93D0 Supply voltage:undervoltage
0xCC6493D1 93D1 Supply voltage:overvoltage
0xCC6493D2 93D2 Telltale lamp for front passenger airbag deactivation
0xCC6493D3 93D3 Coding incorrect
0xCC6493D4 93D4 Crash-telegram memory:at least one crash telegram is stored
0xCC6493D5 93D5 Crash-telegram memory:three crash telegrams is stored
0xCC6493D6 93D6 Internal control-unit fault:control unit is not locked
0xCC6493D7 93D7 Internal control-unit fault
0xCC6493D8 93D8 Seat occupancy detector,front passenger:system could not be released
0xCC6493D9 93D9 Airbag front sensor,left:incorrect measuring range
0xCC6493DA 93DA Airbag front sensor,left:message implausible
0xCC6493DB 93DB Airbag front sensor,right:incorrect measuring range
0xCC6493DC 93DC Airbag front sensor,right:message implausible
0xCC6493DD 93DD Airbag sensor,B-pillar,left(X-direction):incorrect measuring range
0xCC6493DE 93DE Airbag sensor,B-pillar,left(X-direction):message implausible
0xCC6493DF 93DF Airbag sensor,B-pillar,right(X-direction):incorrect measuring range
0xCC6493E0 93E0 Airbag sensor,B-pillar,right(X-direction):message implausible
0xCC6493E1 93E1 Airbag sensor,B-pillar,left(Y-direction):incorrect measuring range
0xCC6493E2 93E2 Airbag sensor,B-pillar,left(Y-dirction):message implausible
0xCC6493E3 93E3 Airbag sensor,B-pillar,right(Y-direction):incorrect measuring range
0xCC6493E4 93E4 Airbag sensor,B-pillar,right(Y-direction):message implausible
0xCC6493E5 93E5 Airbag sensor,door,front left:incorrect measuring range
0xCC6493E6 93E6 Airbag sensor,door,front left:message implausible
0xCC6493E7 93E7 Airbag sensor,door,front right:incorrect measuring range
0xCC6493E8 93E8 Airbag sensor,door,front right:message implausible
0xCC6493E9 93E9 Airbag telltale lamp
0xCC6493EB 93EB Emergency call function
0xCC6493EC 93EC Internal control-unit fault:incorrect software version
0xCC6493ED 93ED Control unit/sensors:unknown fault
0xCC6493EE 93EE Airbag sensor,door,front left:pressure sensor outside measuring range
0xCC6493EF 93EF Airbag sensor,door,front left:absolute pressure sensor outside measuring range
0xCC6493F0 93F0 Airbag sensor,door,front left:difference of absolute pressure outside measuring range
0xCC6493F1 93F1 Airbag sensor,door,front right:pressure sensor outside measuring range
0xCC6493F2 93F2 Airbag sensor,door,front right:absolute pressure sensor outside measuring range
0xCC6493F3 93F3 Airbag sensor,door,front right:difference of absolute pressure outside measuring range
0xCC6493F4 93F4 Airbag sensor,door,front left:communication fault
0xCC6493F5 93F5 Airbag sensor,door,front right:communication fault
0xCC6493F6 93F6 Internal control-unit fault:triggering threshold reached
//SGM-ZGM
0xCD61932B 932B BYTEFLIGHT damping too high
0xCD61932C 932C Control-module fault
0xCD61932D 932D Control-module fault
0xCD61932E 932E Control-module fault
//JBE
0xCD629C5E Refrigerant pressure sensor
0xCD629C69 Rear stratification-flap potentiometer
0xCD62A6C8 Heated rear window relay
0xCD62A6C9 Windscreen wipers, blocking
0xCD62A6CA Switch-on relay for windscreen wipers
0xCD62A8CB Changeover relay for windscreen wipers
0xCD62A8CC Relay, windscreen washing system
0xCD62A6CD Rear-window wiper, blocking
0xCD62A6CE Relay, rear-window wiper
0xCD62A6CF AUC sensor
0xCD62A6D0 Control valve in A/C compressor
0xCD62A6D1 Auxiliary-water pump
0xCD62A6D2 Water valve
0xCD62A6D3 Windscreen washer pump
0xCD62A6D4 Central-locking relay, unlocking
0xCD62A6D5 Central-locking relay, locking
0xCD62A6D6 Central-locking relay, double locking
0xCD62A6D7 Central-locking relay, selective unlocking
0xCD62A6D8 Power-window relay (closing), passenger, rear
0xCD62A6D9 Power-window relay (opening), passenger, rear
0xCD62A6DA Power-window relay (closing), driver's side, rear
0xCD62A6DB Power-window relay (opening), driver's side, rear
0xCD62A6DC Rear-window washer pump
0xCD62A6DD Roller sunblind/luggage compartment cover
0xCD62A6DE Mirror/spray-nozzle heating, left
0xCD62A6DF Mirror/spray-nozzle heating, right
0xCD62A6E0 Seat heating, driver's side
0xCD62A6E1 Seat heating, passenger's side
0xCD62A6E2 Central-locking drive, rear lid
0xCD62A6E3 Central-locking drive, rear window
0xCD62A6E4 Fuel level sensor 1
0xCD62A6E5 Fuel level sensor 2
0xCD62A6E6 Power-window switch, passenger's side, front
0xCD62A6E7 Transport mode active
0xCD62A728 Power-window switch, passenger, rear
0xCD62A729 Power-window switch, driver's side, rear
0xCD62A72A Power-window Hall sensor 1, driver's side, rear
0xCD62A72B Power-window Hall sensor 2, driver's side, rear
0xCD62A72C Power-window Hall sensor 1, passenger, rear
0xCD62A72D Power-window Hall sensor 2, passenger, rear
0xCD62A731 Supply, terminal 30g-f
//SM
0xEF210000 00 Hall sensor, backrest angle, short circuit to ground
0xEF210001 01 Hall sensor, backrest angle, open circuit
0xEF210002 02 Hall sensor, backrest angle, short circuit to positive
0xEF210003 03 Hall sensor, seat height, short circuit to ground
0xEF210004 04 Hall sensor, seat height, open circuit
0xEF210005 05 Hall sensor, seat height, short circuit to positive
0xEF210006 06 Hall sensor, seat angle, short circuit to ground
0xEF210007 07 Hall sensor, backrest angle, open circuit
0xEF210008 08 Hall sensor, seat angle, short circuit to positive
0xEF210009 09 Hall sensor, seat carriage, short circuit to ground
0xEF21000A 0A Hall sensor, seat carriage, open circuit
0xEF21000B 0B Hall sensor, seat carriage, short circuit to positive
0xEF21000F 0F Supply, Hall sensors, short circuit to ground or Hall sensor not connected
0xEF210010 10 Control-unit fault
0xEF210011 11 Steering column, radial, transmission fault
0xEF210012 12 Steering column, radial, short circuit
0xEF210013 13 Steering column, radial, block operation
0xEF210014 14 Steering column, radial, block operation
0xEF210015 15 Steering column, axial, transmission fault
0xEF210016 16 Steering column, axial, short circuit
0xEF210017 17 Steering column, axial, block operation
0xEF210018 18 Steering column, axial, block operation
//ZKE 2
0xF0210001 01 Fuse of load circuit faulty
0xF0210002 02 Pin contact in ZV drive, driver's door
0xF0210003 03 Pin contact in ZV drive, driver's door
0xF0210004 04 Pin contact in ZV drive, boot lid
0xF0210005 05 Pin contact in ZV drive, boot lid
0xF0210006 06 Relay for locking sticks
0xF0210007 07 Relay for double-locking sticks
0xF0210008 08 Relay for unlocking sticks
0xF0210009 09 Relay for locking does not pick up
0xF021000A 10 Relay for double-locking does not pick up
0xF021000B 11 Relay for unlocking does not pick up
0xF021000C 12 Short circuit in supply wire
0xF021000D 13 Door-lock heating faulty
0xF021000E 14 Short circuit in supply wire
