//*DME MS42.0 M52TU*/
0x01270001 1 Activation, ignition cylinder 2
0x01270002 2 Activation, ignition cylinder 4
0x01270003 3 Activation, ignition cylinder 6
0x01270005 5 Activation, fuel injector, cylinder 2 (OBDII:P0202; EUIII:P0202)
0x01270006 6 Activation, fuel injector, cylinder 1 (OBDII:P0201; EUIII:P0201)
0x01270008 8 Signal, air-mass flow sensor (OBDII:P0101;EUIII:P0101)
0x0127000A 10 Signal, sensor, engine coolant temperature (OBDII:P0116; EUIII:P0116)
0x0127000B 11 Signal, sensor, radiator-outlet coolant temperature
0x0127000C 12 Plausibility, maximum coolant temperature (OBDII:P1115)
0x0127000E 14 Signal, sensor, intake-air temperature (OBDII:P0111; EUIII:P0111)
0x01270012 18 Signal, exhaust-camshaft sensor (OBDII:P1397; EUIII:P0340)
0x01270013 19 Activation, VANOS Solenoid valve, exhaust (OBDII: P1529)
0x01270015 21 Activation, VANOS solenoid valve, inlet (OBDII: P1525)
0x01270016 22 Activation, fuel injector, cylinder 3 (OBDII:P0203; EUIII:P0203)
0x01270017 23 Activation, fuel injector, cylinder 6 (OBDII:P0206; EUIII:P0206)
0x01270018 24 Activation, fuel injector, cylinder 4 (OBDII:P0204, EUIII:P0204)
0x01270019 25 Activation, OX,-sensor heater before cat. conv., bank 1 (OBDII:P0135; EUIII:P0135)
0x0127001B 27 Activation, idle-speed control valve/closing coil (OBDII:P1550; EUIII:P0505)
0x0127001D 29 Activation, ignition, cylinder 1
0x0127001E 30 Activation, ignition, cylinder 3
0x0127001F 31 Activation, ignition, cylinder 5
0x01270021 33 Activation, fuel injector, cylinder 5 (OBDII:P0205; EUIII:P0205)
0x01270026 38 Clutch switch
0x01270027 39 Plausibility, signal, brake-light switch/brake test switch
0x01270028 40 Plausibility, signal, brake-light switch/pedal-travel switch
0x0127002A 42 Multifunction steering wheel, plausibility, signal
0x0127002B 43 Multifunction steering wheel, plausibility, rocker switch
0x0127002D 45 Multifunction steering wheel, monitoring, interface
0x01270032 50 Activation,solenoid value,fuel-circuit changeover(OBDII:P1145)
0x01270035 53 Activation, idle-speed control valve/opening coil (OBDII:P1509; EUIII:P0505)
0x01270037 55 Activation, OX.-sensor heater before cat. conv., bank 2 (OBDII:P0155; EUIII:P0155)
0x01270038 56 Signal, ignition-current measurement, resistance
0x01270039 57 Signal, knock sensor 1 (OBDII:P0325; EUIII:P0325)
0x0127003B 59 Signal, Knock sensor 2 (OBDII:P0330; EUIII:P0330)
0x0127003D 61 Activation, OX-sensor heater after cat. conv., bank 2 (OBDII:P0141; EUIII:P0141)
0x01270041 65 Signal, inlet-camshaft sensor (OBDII:P0340; EUIII:P0340)
0x01270044 68 Activation, solenoid valve, tank ventilation (OBDII:P0443; EUIII:P0443)
0x01270045 69 Activation, fuel-pump relay
0x0127004A 74 Activation, A/C compressor
0x0127004F 79 Activation, OX.-sensor heater after cat. conv., bank 1 (OBDII:P0161; EUIII:P0161)
0x01270053 83 Signal, crankshaft sensor (OBDII:P0335; EUIII:P0335)
0x01270064 100 Control units, self-test (OBDII:P0601; EUIII:P0601)
0x01270067 103 Control VANOS, end-pos. fault, inlet camshaft (OBDII:P1519)
0x01270068 104 Control VANOS, end-pos. fault, exhaust camshaft (OBDII:P1520)
0x01270069 105 Control VANOS, position, inlet camshaft (OBDII:P1522)
0x0127006A 106 Control VANOS, position, exhaust camshaft (OBDII:P1523)
0x0127006D 109 Engine throttle, plausibility, activation duty factor (OBDII:P1580; EUIII:P0505)
0x0127006E 110 Signal, pedal-travel sensor (in thr.), pot. 1 (OBDII:P1542; EUIII:P0220)
0x0127006F 111 Signal, pedal-travel sensor (in thr.), pot. 2 (OBDII:P1542; EUIII:P0220)
0x01270070 112 Signal, throttle sensor, potentiometer 1 (OBDII:P0120; EUIII:P0120)
0x01270071 113 Signal, throttle sensor, Potentiometer 2 (OBDII:P0120; EUIII:P0120)
0x01270072 114 Activation, engine throttle (OBDII:P1580; EUIII:P0505)
0x01270073 115 Reference voltage 1, pedal-travel sensor/throttle sensor 1 (OBDII:P1623; EUIII:P0608)
0x01270074 116 Reference voltage 2, pedal-travel sensor/throttle sensor 2 (OBDII:P1623; EUIII:P0608)
0x01270075 117 Plausibility, signal, pedal-travel sensor (in thr.) pot. 1/2 (OBDII:P1542; EUIII:P0220)
0x01270076 118 Plausibility, signal, engine-throttle sensor, potentiometer (OBDII:P0120; EUIII:P0120)
0x01270077 119 Engine trottle, mechanical fault (sluggish/stuck) (OBDII:P1580; EUIII:P0505)
0x01270078 120 Plausibility, pedal-travel sensor (in thr.), throttle sensor (OBDII:P1542; EUIII:P0220)
0x0127007A 122 Signal, engine-oil temperature sensor (OBDII:P1161)
0x0127007B 123 Activation, map cooling (OBDII:P1622)
0x0127007C 124 Activation, solenoid valve, intake manifold (OBDII:P1593)
0x0127007D 125 Activation, electric fan
0x0127007E 126 Activation,solenoid value,tank-leak diagnosis pump(OBDII:P1479;EUIII:P0440)
0x01270080 128 DME-EWS interface
0x0127008C 140 Tank-leak diagnosis pump,reed switch not closed(OBDII:P1475;EUIII:P0440)
0x0127008D 141 Tank-leak diagnosis pump,reed switch not open(OBDII:P1477;EUIII:P0440)
0x01270091 145 Fuel system,minor leak detected;fuel cap possibly not secured(OBDII:P0455)
0x01270095 149 Plausibility fault, air mass to pedal-tr. sensor (in eng. thr.) (OBDII:P1140; EUIII:P0101)
0x01270096 150 Signal, ox.sensor before cat. conv., bank 1, max. value exceeded (OBDII:P0130; EUIII:P0130)
0x01270097 151 Signal, ox.sensor before cat. conv., bank 1, min. value undershot (OBDII:P0130; EUIII:P0130)
0x01270098 152 Signal, ox.sensor before cat. conv., bank 1, no signal (OBDII:P0130; EUIII:P0130)
0x01270099 153 Signal, ox.sensor before cat. conv., bank 2, max. value exceeded (OBDII:P0150; EUIII:P0150)
0x0127009A 154 Signal, ox.sensor before cat. conv., bnak 2, min. value undershot (OBDII:P1050; EUIII:P0150)
0x0127009B 155 Signal, ox.sensor before cat. conv., bank 2, no signal (OBDII:P0150; EUIII:P0150)
0x0127009C 156 Signal, ox.sensor after cat. conv., bank 1, max. value exceeded (OBDII:P0136; EUIII:P0136)
0x0127009D 157 Signal, ox.sensor after cat. conv., bank 1, min. value undershot (OBDII:P0136; EUIII:P0136)
0x0127009F 159 Signal, ox.sensor after cat. conv., bank 2, max. value exceeded (OBDII:P0156; EUIII:P0156)
0x012700A0 160 Signal, ox.sensor after cat. conv., bank 2, min. value undershot (OBDII:P0156; EUIII:P0156)
0x012700A8 168 Thermostat, map cooling, mechanical, stuck open (OBDII:P1624)
0x012700A9 169 Engine-throttle output-stage shutoff after diagn. error
0X012700aa 170 Control-unit self-test, engine throttle or internal fault (OBDII:P0601; EUIII:P0601)
0x012700AB 171 Plausibility, system, engine throeetle (OBDII:P0601; EUIII:P0601)
0x012700AC 172 Signal, pedal-travel sensor (in thr.), pot. 1/2, short circuit (OBDII:P1542; EUIII:P0220)
0x012700AD 173 Singal, throttle sensor, pot. 1/2, short circuit (OBDII:P0120; EUIII:P0120)
0x012700AE 174 Throttle sensor, potentiometer 1/2, adaptation (OBDII:P0120; EUIII:P0120)
0x012700AF 175 Pedal-travel sensor 1 (in thr.), adaptation (OBDII:P1542; EUIII:P0220)
0x012700B0 176 Pedal-travel sensor 2 (in thr.), adaptation (OBDII:P1542; EUIII:P0220)
0x012700BA 186 Voltage excursion before cat. sensor, bank 1 (OBDII:P0134; EUIII:P0134)
0x012700BB 187 Voltage excursion before cat. sensor, bank 2 (OBDII:P0154; EUUII:P0154)
0x012700BC 188 Heat output, ox.sensor before cat. conv., bank 1 (OBDII:P1132; EUIII:P0135)
0x012700BD 189 Heat output, ox,sensor before cat. conv., bank 2 (OBDII:P1133: EUIII:P0155)
0x012700BE 190 Heat output, ox.sensor after cat. conv., bank 1 (OBDII:P1186; EUIII:P0141)
0x012700BF 191 Heat output, ox.sensor after car. conv., bank 2 (OBDII:P1187; EUIII:P0161)
0x012700CA 202 Fuel trim bank 1 control limit (OBDII:P0170; EUIII:P0170)
0x012700CB 203 Fuel trim bank 2 control limit (OBDII:P0173; EUIII:P0173)
0x012700CC 204 Plausibility, idle speed (leakage air) (OBDII:P0505; EUIII:P0505)
0x012700D0 208 speed monitoring not plausible EWS
0x012700D1 209 Anti-tampering protection EWS
0x012700D2 210 Error, ign.-current measurement at more than 2 cylinders
0x012700D3 211 Idle-speed control valve, mechanical fault (OBDII:P1510; EUIII:P0505)
0x012700D6 214 Signal, road speed (OBDII:P0500; EUIII:P0500)
0x012700D7 215 Signal, ox.sensor after cat. conv., bank 1, no signal (OBDII:P0136; EUIII:P0136)
0x012700D8 216 Signal, ox.sensor after cat. conv., bank 2, no signal (OBDII:P0156; EUIII:P0156)
0x012700D9 217 signal, CAN EGS (OBDII:P0600; EUIII:P0600)
0x012700DC 220 Voltage, ox.sensor 1 after cat. conv., sensor too slow (OBDII:P1184; EUIII:P0140)
0x012700DD 221 Voltage, ox.sensor 2 after cat., sensor to slow (OBDII:P1185; EUIII:P0160)
0x012700DE 222 Plausibility, coolant temperature (OBDII:P0125; EUIII:P0125)
0x012700DF 223 Jump time, ox.sensor after cat. conv., bank 1 (OBDII:P1180; EUIII:P0139)
0x012700E0 224 Jump time, ox.sensor after cat. conv., bank 2 (OBDII:P1181; EUIII:P0159)
0x012700E1 225 Function, ox.sensor control after cat. conv., bank 1 (OBDII:P1192; EUIII:P0170)
0x012700E2 226 Function, ox.sensor control after cat., bank 2 (OBDII:P1193; EUIII:P0173)
0x012700E3 227 Fuel trim bank 1, perissible range exceeded (OBDII:P1188; EUIII:P0170)
0x012700E4 228 Fuel trim bank 2, permissible rang exceeded (OBDII:P1189; EUIII:P0173)
0x012700E5 229 Control frequency, ox.sensor, bank 1, faulty (OBDII:P0133; EUIII:P0133)
0x012700E6 230 Control frequency, ox,sensor, bank 2, faulty (OBDII:P0153; EUIII:P0153)
0x012700E7 231 Switch time, ox.sensor, bank 1 (OBDII:P1178; EUIII:P0133)
0x012700E8 232 Switch time, ox.sensor, bank 2 (OBDII:P1179; EUIII:P0153)
0x012700E9 233 Cat.-conv. efficiency, bank 1 (OBDII:P0420; EUIII:P0420)
0x012700EA 234 Cat.-conv. efficiency, bank 2 (OBDII:P0430; EUIII:P0430)
0x012700EB 235 Function, ox.sensor control before cat. conv., bank 1 (OBDII:P1190; EUIII:P0170)
0x012700EC 236 Function, ox.sensor control before cat. conv., bank 2 (OBDII:P1191; EUIII:P0173)
0x012700EE 238 Misfire, cylinder 1 (OBDII:P0301; EUIII:P0301)
0x012700EF 239 Misfire, cylinder 2 (OBDII:P0302; EUIII:P0302)
0x012700F0 240 Misfire, cylinder 3 (OBDII:P0303; EUIII:P0303)
0x012700F1 241 Misfire, cylinder 4 (OBDII:P0304; EUIII:P0304)
0x012700F2 242 Misfire, cylinder 5 (OBDII:P0305; EUIII:P0305)
0x012700F3 243 Misfire, cylinder 6 (OBDII:P0306; EUIII:P0306)
0x012700F4 244 Segment timing, ture running disturbed
0x012700F8 248 ACAT sensor, signal after SA, implausible, bank 1 (OBDII:P1184; EUIII:P0140)
0x012700F9 249 ACAT sensor, signal after SA, implausible, bank 2 (OBDII:P1185; EUIII:P0160)
0x012700FA 250 Function check, tank ventilation (OBDII:P0440)
//*DDE 2.2 M52*/
0x01280001 1 Delivery-controller control deviation
0x01280003 3 Electric shutoff valve
0x01280005 5 Needle-motion sensor
0x01280006 6 Exhaust gas recirculation, control deviation
0x01280008 8 Glow-duration control
0x0128000A 10 Start-of-injection control deviation
0x01280010 16 Supply voltage (batt. +)
0x01280015 21 controller sensor, distributor-type injection pump
0x0128001A 26 Brake-light switch/break-light test switch
0x0128001D 29 Road-speed signal
0x01280020 32 Control panel, cruise control, on multifunction steering wheel
0x01280023 35 Fuel temperature sensor
0x01280024 36 Engine-oil temperature sensor
0x01280025 37 Pedal-travel sensor
0x01280026 38 Hot-film air-mass flow sensor
0x0128002D 45 Electronic anti-theft vehicle disable (EWS II)
0x0128002F 47 Engine-speed sensor
0x01280035 53 Engine-coolant temperature sensor
0x01280036 54 Charge-air-pressure sensor
0x01280065 101 Charging-pressure control deviation
0x01280066 102 Control-module faults
0x01280067 103 Control-module faults
0x01280068 104 Control-module faults
0x01280069 105 Control-module faults
0x0128006A 106 Power output stages
0x0128006C 108 Variant coding
0x0128006D 109 Variant coding
0x0128006F 111 Adjustment,engine control module pairing
0x01280070 112 CAN bus to EGS control unit
0x01280071 113 CAN bus to ASC control unit
0x01280072 114 CAN bus to instrument cluster
//*DME MS41.1 M52*/
0x012C0001 1 Ignition,cylinder 2
0x012C0002 2 Ignition,cylinder 4
0x012C0003 3 Ignition,cylinder 6
0x012C0005 5 Fuel injector,cylinder 2
0x012C0006 6 Fuel injector,cylinder 1
0x012C0008 8 Air-mass flow sensor
0x012C000a 10 Coolant-temperature sensor
0x012C000B 11 Tank pressure sensor
0x012C000c 12 Throttle valve potentiometer
0x012C000E 14 Intake air temperature sensor
0x012C0010 16 Line for controlled air conditioning compressor
0x012C0012 18 EWS signal defective
0x012C0014 20 Fault lamp (MIL)
0x012C0015 21 VANOS: electrical fault
0x012C0016 22 Fuel injector,cylinder 3
0x012C0017 23 Fuel injector,cylinder 6
0x012C0018 24 Fuel injector,cylinder 4
0x012C0019 25 Output stage, oxygen-sensor hearter, sensor 1,cylinder 1-3 befor cat. con
0x012C001B 27 Idle actuator: closing winding
0x012C001D 29 Ignition,cylinder 1
0x012C001E 30 Ignition,cylinder 3
0x012C001F 31 Ignition,cylinder 5
0x012C0021 33 Fuel injector,cylinde 5
0x012C0023 35 Relay on secondary air pump
0x012C002e 46 Signal, "Fuel reserve"
0x012C0032 50 Solenoid valve for fuel evaporation system (running losses)
0x012C0033 51 Shoutoff valve, activated charcoal filter
0x012C0034 52 Solenoid valv, exhaust flap
0x012C0035 53 Idle actuator: opening winding
0x012C0037 55 Output stage for oxygen sensor heating, sensor 2 (cylinder 4-6; before cat')
0x012C0038 56 Open circuit, ignition-current-feedback resistor
0x012C0039 57 Knock sensor 1
0x012C003B 59 Knock sensor 2
0x012C003D 61 Oxygen sensor heating, sensor 4 (cylinder 4-6; after cat')
0x012C003E 62 Secondary air valve (electorically operated change-over valve)
0x012C0041 65 Camshaft sensor
0x012C0044 68 Tank-ventilation valve, electrical fault
0x012C0045 69 Electric-fuel-pump relay
0x012C004A 74 A/C-Compressor relay
0x012C004B 75 Oxygen-sensor voltage 1, cylinders 1-3; beofre cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012C004C 76 Oxygen sensor voltage 2 (cylinder 4-6; before cat')
0x012C004D 77 Oxygen-sensor voltage 3, cylinders 1-3; after cat, conv, Z3 and 323i US only: this fault affects cylinder 1-6
0x012C004E 78 Oxygen-sensor voltage 4 (cylinder 4-6; after cat')
0x012C004F 79 Oxygen-sensor heater, sensor 3, cylinders 1-3; after cat. conv. Z3 and 323i US only: this fault affects cylinder 1-6
0x012C0050 80 ABS/ASC interface, ignition fadeout
0x012C0051 81 ABS/ASC interface, idle-speed increas
0x012C0052 82 ABS/ASC interface, ignition-timing adjustment
0x012C0053 83 Crankshaft sensor
0x012C0064 100 DME control unit self-test
0x012C00BE 190 Tank-leakage diagnosis pump: reed contact dose not close
0x012C00BF 191 Tank-leakage diagnosis pump: reed contact dose not open
0x012C00C0 192 Tank-leakage diagnosis Zpump: reed contact no longer close
0x012C00C1 193 Reed Contact, tank-leak diagnisis pump: hose pinched
0x012C00C2 194 Tank-leakage detection: major leak
0x012C00C3 195 Tank-leakage detection: minor leak
0x012C00C4 196 Activation, solenoid valve, tank-leakage diagnosis pump
0x012C00C5 197 Ambient-pressure sensor
0x012C00C8 200 Oxygen-sensor voltage 1-3; before cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012C00C9 201 Oxygen sensor voltage stroke, sensor 2 (cylinder 4-6; before cat')
0x012C00CA 202 Oxygen sensor control limit, cylinders 1-3; Z3 and 323i US only: this fault affects cylinder 1-6
0x012C00CB 203 Oxygen-sensor control limit, cylinder 4-6
0x012C00CC 204 Idle speed deviates significantly from nominal value
0x012C00D1 209 Signal, EWS manipulated
0x012C00D2 210 Ignition-current-feedback fault: at more than 2 cylinders
0x012C00D3 211 Idle actuator: mechanical jamming
0x012C00D4 212 VANOS: mechanical jamming
0x012C00D6 214 Road-speed signal
0x012C00D7 215 ASC/MSR/EML: signal combination
0x012C00D8 216 Speed-range signal , EGS
0x012C00D9 217 CAN-bus: no EGS transmission
0x012C00DA 218 CAN module: warning level reached
0x012C00DB 219 CAN module: bus off
0x012C00DC 220 Function, oxygen-sensor control,bank 1
0x012C00DD 221 Function, oxygen-sensor control,bank 2
0x012C00DE 223 Oxygen sensor control not active after specified time
0x012C00E3 227 Mixture deviation, cylinders 1-3; Z3 and 323i US only: this fault affects cylinders 1-6
0x012C00E4 228 Mixture deviation, cylinders 4-6;
0x012C00E5 229 Control frequency, oxygen sensor 1, cylinders 1-3; before cat. conv. Z3 and 323i US only this fault affects cylinders 1-6
0x012C00E6 230 Control frequency, oxygen sensor 2 (cylinder 4-6; before cat')
0x012C00E7 231 Operating time, oxygen sensor 1, cylinders 1-3; before cat. conv. Z3 and 323i US only: this fault concers cylinders 1-6
0x012C00E8 232 Operating time, oxygen sensor 2, (cylinders 4-6; before cat. conv.)
0x012C00E9 233 Total CAT. ConV. efficiency, cylinders 1-3; Z3 and 323i US only: this fault affects cylinders 1-6
0x012C00EA 234 CAT overall efficiency rating, cylinder 4-6
0x012C00EB 235 Heat output, oxygen sensor 3, cylinders 1-3; after cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012C00EC 236 Heating power, oxygen sensor 4 (cylinder 4-6; after cat')
0x012C00EE 238 Misfire, cylinder 1
0x012C00EF 239 Misfire, cylinder 2
0x012C00F0 240 Misfire, cylinder 3
0x012C00F1 241 Misfire, cylinder 4
0x012C00F2 242 Misfire, cylinder 5
0x012C00F3 243 Misfire, cylinder 6
0x012C00F4 244 Crankshaft segment timing
0x012C00F5 245 Secondary-air system, cylinders 1-3 Only Z3 and 323i US and E36/5 from 12/98: This fault affects cylinder 1-6
0x012C00F6 246 Secondary air system, cylinders 4-6
0x012C00F7 247 Secondary air valve jams in open position
0x012C00FA 250 Function fault, tank vent valve
0x012C00FB 251 Tank-leak detection: minor leak
0x012C00FC 252 Tank-Ventilation system: suction fault
0x012C00FD 253 Shut-off valve, activated-charcoal filter, jammed shut
0x012C00FE 254 Tank-leak detection: major leak
0x012C00FF 255 Tank-Ventilation system: tank-Ventilation valve jams open
//*DME MS41.1 M52 ORVR*/
0x012D0001 1 Ignition,cylinder 2
0x012D0002 2 Ignition,cylinder 4
0x012D0003 3 Ignition,cylinder 6
0x012D0005 5 Fuel injector,cylinder 2
0x012D0006 6 Fuel injector,cylinder 1
0x012D0008 8 Air-mass flow sensor
0x012D000a 10 Coolant-temperature sensor
0x012D000B 11 Tank pressure sensor
0x012D000c 12 Throttle valve potentiometer
0x012D000E 14 Intake air temperature sensor
0x012D0010 16 Line for controlled air conditioning compressor
0x012D0012 18 EWS signal defective
0x012D0014 20 Fault lamp (MIL)
0x012D0015 21 VANOS: electrical fault
0x012D0016 22 Fuel injector,cylinder 3
0x012D0017 23 Fuel injector,cylinder 6
0x012D0018 24 Fuel injector,cylinder 4
0x012D0019 25 Output stage, oxygen-sensor hearter, sensor 1,cylinder 1-3 befor cat. con
0x012D001B 27 Idle actuator: closing winding
0x012D001D 29 Ignition,cylinder 1
0x012D001E 30 Ignition,cylinder 3
0x012D001F 31 Ignition,cylinder 5
0x012D0021 33 Fuel injector,cylinde 5
0x012D0023 35 Relay on secondary air pump
0x012D002e 46 Signal, "Fuel reserve"
0x012D0032 50 Solenoid valve for fuel evaporation system (running losses)
0x012D0033 51 Shoutoff valve, activated charcoal filter
0x012D0034 52 Solenoid valv, exhaust flap
0x012D0035 53 Idle actuator: opening winding
0x012D0037 55 Output stage for oxygen sensor heating, sensor 2 (cylinder 4-6; before cat')
0x012D0038 56 Open circuit, ignition-current-feedback resistor
0x012D0039 57 Knock sensor 1
0x012D003B 59 Knock sensor 2
0x012D003D 61 Oxygen sensor heating, sensor 4 (cylinder 4-6; after cat')
0x012D003E 62 Secondary air valve (electorically operated change-over valve)
0x012D0041 65 Camshaft sensor
0x012D0044 68 Tank-ventilation valve, electrical fault
0x012D0045 69 Electric-fuel-pump relay
0x012D004A 74 A/C-Compressor relay
0x012D004B 75 Oxygen-sensor voltage 1, cylinders 1-3; beofre cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012D004C 76 Oxygen sensor voltage 2 (cylinder 4-6; before cat')
0x012D004D 77 Oxygen-sensor voltage 3, cylinders 1-3; after cat, conv, Z3 and 323i US only: this fault affects cylinder 1-6
0x012D004E 78 Oxygen-sensor voltage 4 (cylinder 4-6; after cat')
0x012D004F 79 Oxygen-sensor heater, sensor 3, cylinders 1-3; after cat. conv. Z3 and 323i US only: this fault affects cylinder 1-6
0x012D0050 80 ABS/ASC interface, ignition fadeout
0x012D0051 81 ABS/ASC interface, idle-speed increas
0x012D0052 82 ABS/ASC interface, ignition-timing adjustment
0x012D0053 83 Crankshaft sensor
0x012D0064 100 DME control unit self-test
0x012D00BE 190 Tank-leakage diagnosis pump: reed contact dose not close
0x012D00BF 191 Tank-leakage diagnosis pump: reed contact dose not open
0x012D00C0 192 Tank-leakage diagnosis Zpump: reed contact no longer close
0x012D00C1 193 Reed Contact, tank-leak diagnisis pump: hose pinched
0x012D00C2 194 Tank-leakage detection: major leak
0x012D00C3 195 Tank-leakage detection: minor leak
0x012D00C4 196 Activation, solenoid valve, tank-leakage diagnosis pump
0x012D00C5 197 Ambient-pressure sensor
0x012D00C8 200 Oxygen-sensor voltage 1-3; before cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012D00C9 201 Oxygen sensor voltage stroke, sensor 2 (cylinder 4-6; before cat')
0x012D00CA 202 Oxygen sensor control limit, cylinders 1-3; Z3 and 323i US only: this fault affects cylinder 1-6
0x012D00CB 203 Oxygen-sensor control limit, cylinder 4-6
0x012D00CC 204 Idle speed deviates significantly from nominal value
0x012D00D1 209 Signal, EWS manipulated
0x012D00D2 210 Ignition-current-feedback fault: at more than 2 cylinders
0x012D00D3 211 Idle actuator: mechanical jamming
0x012D00D4 212 VANOS: mechanical jamming
0x012D00D6 214 Road-speed signal
0x012D00D7 215 ASC/MSR/EML: signal combination
0x012D00D8 216 Speed-range signal , EGS
0x012D00D9 217 CAN-bus: no EGS transmission
0x012D00DA 218 CAN module: warning level reached
0x012D00DB 219 CAN module: bus off
0x012D00DC 220 Function, oxygen-sensor control,bank 1
0x012D00DD 221 Function, oxygen-sensor control,bank 2
0x012D00DE 223 Oxygen sensor control not active after specified time
0x012D00E3 227 Mixture deviation, cylinders 1-3; Z3 and 323i US only: this fault affects cylinders 1-6
0x012D00E4 228 Mixture deviation, cylinders 4-6;
0x012D00E5 229 Control frequency, oxygen sensor 1, cylinders 1-3; before cat. conv. Z3 and 323i US only this fault affects cylinders 1-6
0x012D00E6 230 Control frequency, oxygen sensor 2 (cylinder 4-6; before cat')
0x012D00E7 231 Operating time, oxygen sensor 1, cylinders 1-3; before cat. conv. Z3 and 323i US only: this fault concers cylinders 1-6
0x012D00E8 232 Operating time, oxygen sensor 2, (cylinders 4-6; before cat. conv.)
0x012D00E9 233 Total CAT. ConV. efficiency, cylinders 1-3; Z3 and 323i US only: this fault affects cylinders 1-6
0x012D00EA 234 CAT overall efficiency rating, cylinder 4-6
0x012D00EB 235 Heat output, oxygen sensor 3, cylinders 1-3; after cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012D00EC 236 Heating power, oxygen sensor 4 (cylinder 4-6; after cat')
0x012D00EE 238 Misfire, cylinder 1
0x012D00EF 239 Misfire, cylinder 2
0x012D00F0 240 Misfire, cylinder 3
0x012D00F1 241 Misfire, cylinder 4
0x012D00F2 242 Misfire, cylinder 5
0x012D00F3 243 Misfire, cylinder 6
0x012D00F4 244 Crankshaft segment timing
0x012D00F5 245 Secondary-air system, cylinders 1-3 Only Z3 and 323i US and E36/5 from 12/98: This fault affects cylinder 1-6
0x012D00F6 246 Secondary air system, cylinders 4-6
0x012D00F7 247 Secondary air valve jams in open position
0x012D00FA 250 Function fault, tank vent valve
0x012D00FB 251 Tank-leak detection: minor leak
0x012D00FC 252 Tank-Ventilation system: suction fault
0x012D00FD 253 Shut-off valve, activated-charcoal filter, jammed shut
0x012D00FE 254 Tank-leak detection: major leak
0x012D00FF 255 Tank-Ventilation system: tank-Ventilation valve jams open
//*DME MS41 M52*/
0x012E0001 1 Ignition,cylinder 2
0x012E0002 2 Ignition,cylinder 4
0x012E0003 3 Ignition,cylinder 6
0x012E0005 5 Fuel injector,cylinder 2
0x012E0006 6 Fuel injector,cylinder 1
0x012E0008 8 Air-mass flow sensor
0x012E000a 10 Coolant-temperature sensor
0x012E000B 11 Tank pressure sensor
0x012E000c 12 Throttle valve potentiometer
0x012E000E 14 Intake air temperature sensor
0x012E0010 16 Line for controlled air conditioning compressor
0x012E0012 18 EWS signal defective
0x012E0014 20 Fault lamp (MIL)
0x012E0015 21 VANOS: electrical fault
0x012E0016 22 Fuel injector,cylinder 3
0x012E0017 23 Fuel injector,cylinder 6
0x012E0018 24 Fuel injector,cylinder 4
0x012E0019 25 Output stage, oxygen-sensor hearter, sensor 1,cylinder 1-3 befor cat. conv. Z3 and 323i US only: this fault affects cylinder 1-6
0x012E001B 27 Idle actuator: closing winding
0x012E001D 29 Ignition,cylinder 1
0x012E001E 30 Ignition,cylinder 3
0x012E001F 31 Ignition,cylinder 5
0x012E0021 33 Fuel injector,cylinde 5
0x012E0023 35 Relay on secondary air pump
0x012E002e 46 Signal, "Fuel reserve"
0x012E0032 50 Solenoid valve for fuel evaporation system (running losses)
0x012E0033 51 Shoutoff valve, activated charcoal filter
0x012E0034 52 Solenoid valv, exhaust flap
0x012E0035 53 Idle actuator: opening winding
0x012E0037 55 Output stage for oxygen sensor heating, sensor 2 (cylinder 4-6; before cat')
0x012E0038 56 Open circuit, ignition-current-feedback resistor
0x012E0039 57 Knock sensor 1
0x012E003B 59 Knock sensor 2
0x012E003D 61 Oxygen sensor heating, sensor 4 (cylinder 4-6; after cat')
0x012E003E 62 Secondary air valve (electorically operated change-over valve)
0x012E0041 65 Camshaft sensor
0x012E0044 68 Tank-ventilation valve, electrical fault
0x012E0045 69 Electric-fuel-pump relay
0x012E004A 74 A/C-Compressor relay
0x012E004B 75 Oxygen-sensor voltage 1, cylinders 1-3; beofre cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012E004C 76 Oxygen sensor voltage 2 (cylinder 4-6; before cat')
0x012E004D 77 Oxygen-sensor voltage 3, cylinders 1-3; after cat, conv, Z3 and 323i US only: this fault affects cylinder 1-6
0x012E004E 78 Oxygen-sensor voltage 4 (cylinder 4-6; after cat')
0x012E004F 79 Oxygen-sensor heater, sensor 3, cylinders 1-3; after cat. conv. Z3 and 323i US only: this fault affects cylinder 1-6
0x012E0050 80 ABS/ASC interface, ignition fadeout
0x012E0051 81 ABS/ASC interface, idle-speed increas
0x012E0052 82 ABS/ASC interface, ignition-timing adjustment
0x012E0053 83 Crankshaft sensor
0x012E0064 100 DME cotrol unit self-test
0x012E00BE 190 Tank-lakage diagnosis pump: reed contact dose not close
0x012E00BF 191 Tank-leakage diagnosis pump: reed contact dose not open
0x012E00C0 192 Tank-leakage diagnosis Zpump: reed contact no longer close
0x012E00C1 193 Reed Contact, tank-leak diagnisis pump: hose pinched
0x012E00C2 194 Tank-leakage detection: major leak
0x012E00C3 195 Tank-leakage detection: minor leak
0x012E00C4 196 Activation, solenoid valve, tank-leakage diagnosis pump
0x012E00C5 197 Ambient-pressure sensor
0x012E00C8 200 Oxygen-sensor voltage 1-3; before cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012E00C9 201 Oxygen sensor voltage stroke, sensor 2 (cylinder 4-6; before cat')
0x012E00CA 202 Oxygen sensor control limit, cylinders 1-3; Z3 and 323i US only: this fault affects cylinder 1-6
0x012E00CB 203 Oxygen-sensor control limit, cylinder 4-6
0x012E00CC 204 Idle speed deviates significantly from nominal value
0x012E00D1 209 Signal, EWS manipulated
0x012E00D2 210 Ignition-current-feedback fault: at more than 2 cylinders
0x012E00D3 211 Idle actuator: mechanical jamming
0x012E00D4 212 VANOS: mechanical jamming
0x012E00D6 214 Road-speed signal
0x012E00D7 215 ASC/MSR/EML: signal combination
0x012E00D8 216 Speed-range signal , EGS
0x012E00D9 217 CAN-bus: no EGS transmission
0x012E00DA 218 CAN module: warning level reached
0x012E00DB 219 CAN module: bus off
0x012E00DC 220 Function, oxygen-sensor control,bank 1
0x012E00DD 221 Function, oxygen-sensor control,bank 2
0x012E00DE 223 Oxygen sensor control not active after specified time
0x012E00E3 227 Mixture deviation, cylinders 1-3; Z3 and 323i US only: this fault affects cylinders 1-6
0x012E00E4 228 Mixture deviation, cylinders 4-6;
0x012E00E5 229 Control frequency, oxygen sensor 1, cylinders 1-3; before cat. conv. Z3 and 323i US only this fault affects cylinders 1-6
0x012E00E6 230 Control frequency, oxygen sensor 2 (cylinder 4-6; before cat')
0x012E00E7 231 Operating time, oxygen sensor 1, cylinders 1-3; before cat. conv. Z3 and 323i US only: this fault concers cylinders 1-6
0x012E00E8 232 Operating time, oxygen sensor 2, (cylinders 4-6; before cat. conv.)
0x012E00E9 233 Total CAT. ConV. efficiency, cylinders 1-3; Z3 and 323i US only: this fault affects cylinders 1-6
0x012E00EA 234 CAT overall efficiency rating, cylinder 4-6
0x012E00EB 235 Heat output, oxygen sensor 3, cylinders 1-3; after cat. conv. Z3 and 323i US only: this fault affects cylinders 1-6
0x012E00EC 236 Heating power, oxygen sensor 4 (cylinder 4-6; after cat')
0x012E00EE 238 Misfire, cylinder 1
0x012E00EF 239 Misfire, cylinder 2
0x012E00F0 240 Misfire, cylinder 3
0x012E00F1 241 Misfire, cylinder 4
0x012E00F2 242 Misfire, cylinder 5
0x012E00F3 243 Misfire, cylinder 6
0x012E00F4 244 Crankshaft segment timing
0x012E00F5 245 Secondary-air system, cylinders 1-3 Only Z3 and 323i US and E36/5 from 12/98: This fault affects cylinder 1-6
0x012E00F6 246 Secondary air system, cylinders 4-6
0x012E00F7 247 Secondary air valve jams in open position
0x012E00FA 250 Function fault, tank vent valve
0x012E00FB 251 Tank-leak detection: minor leak
0x012E00FC 252 Tank-Ventilation system: suction fault
0x012E00FD 253 Shut-off valve, activated-charcoal filter, jammed shut
0x012E00FE 254 Tank-leak detection: major leak
0x012E00FF 255 Tank-Ventilation system: tank-Ventilation valve jams open
//*DME MS43 M54*/
0x01300001 1 Activation, ignition cylinder 2
0x01300002 2 Activation, ignition cylinder 4
0x01300003 3 Activation, ignition cylinder 6
0x01300005 5 Activation, fuel injector, cylinder 2
0x01300006 6 Activation, fuel injector, cylinder 1
0x01300008 8 Signal, air-mass flow sensor
0x0130000A 10 Signal, sensor, engine coolant temperature
0x0130000B 11 Signal, sensor, radiator-outlet coolant temperature
0x0130000C 12 Plausibility, maximum coolant temperature
0x0130000D 13 Plausibility, radiator outlet temperature
0x0130000E 14 Signal, sensor, intake-air temperature
0x0130000F 15 Plausibility, cutout time
0x01300010 16 Plausibility, intake-air temperature
0x01300011 17 Plausibility, engine coolant temperature
0x01300012 18 Signal, camshaft sensor,exhaust
0x01300013 19 Activation, VANOS Solenoid valve, exhaust
0x01300015 21 Activation, VANOS solenoid valve, inlet
0x01300016 22 Activation, fuel injector, cylinder 3
0x01300017 23 Activation, fuel injector, cylinder 6
0x01300018 24 Activation, fuel injector, cylinder 4
0x01300019 25 Activation, oxygen-sensor heater before catalytic converter, bank 1
0x0130001B 27 Activation, idle-speed control valve/closing coil
0x0130001D 29 Activation, ignition, cylinder 1
0x0130001E 30 Activation, ignition, cylinder 3
0x0130001F 31 Activation, ignition, cylinder 5
0x01300021 33 Activation, fuel injector, cylinder 5
0x01300023 35 Activation,relay,secondary-air pump
0x01300024 36 Main relay
0x01300025 37 Main relay:switching delay
0x01300026 38 Clutch switch
0x01300027 39 Plausibility,signal,brake-light switch/brake-light test switch
0x0130002A 42 Multifunction steering wheel, plausibility, signal
0x0130002B 43 Multifunction steering wheel, plausibility, rocker switch
0x0130002D 45 Multifunction steering wheel, monitoring, interface
0x0130002F 47 Torque limitation,safety concept,level 1
0x01300030 48 Control-unit self-test 1,plausibilisation
0x01300031 49 Fault,torque monitoring,level 2
0x01300032 50 Fault,response monitoring,level 2
0x01300033 51 Request,control-unit reset
0x01300034 52 Activation, solenoid valve, exhaust flap
0x01300035 53 Activation, idle-speed control valve/opening coil
0x01300037 55 Activation, oxygen-sensor heater before catalytic converter, bank 2
0x01300038 56 Signal, ignition-current measurement, resistance
0x01300039 57 Signal, knock sensor 1
0x0130003A 58 Control-unit self-test 2,plausibilisation
0x0130003B 59 Signal, Knock sensor 2
0x0130003D 61 Activation, oxygen-sensor heater behind catalytic, bank 2
0x0130003E 62 Activation,solenoid valve,secondary air
0x0130003F 63 Signal, ambient temperature, via CAN bus
0x01300040 64 Plausibility, ambient temperature
0x01300041 65 Signal, inlet-camshaft sensor
0x01300042 66 Control-unit self-test,plausibilisation 4
0x01300043 67 Control-unit self-test,plausibilisation 5
0x01300044 68 Activation, solenoid valve, tank ventilation
0x01300045 69 Activation, fuel-pump relay
0x01300046 70 Control-unit self-test,6 plausibilisation
0x01300047 71 Control-unit self-test,7 plausibilisation
0x0130004A 74 Activation, A/C compressor
0x0130004F 79 Activation, oxygen-sensor heater behind catalytic, bank 1
0x01300053 83 Signal, crankshaft sensor
0x0130005A 90 Exhaust temperature before cat.conv.,bank 1
0x0130005B 91 Exhaust temperature before cat.conv.,bank 2
0x0130005C 92 Exhaust temperature after cat.conv.,bank 1
0x0130005D 93 Exhaust temperature after cat.conv.,bank 2
0x0130005E 94 Secondary-air hot-film air-mass sensor
0x0130005F 95 Secondary-air valve or secondary-air hose blocked
0x01300060 96 Secondary-air pump not active
0x01300061 97 Secondary-air flow rate too low
0x01300062 98 Secondary-air flow rate too high
0x01300063 99 Secondary-air valve jammed open
0x01300064 100 Control units, self-test
0x01300067 103 VANOS inlet camshaft,end position not reached
0x01300068 104 VANOS exhaust camshaft,end position not reached
0x01300069 105 VANOS inlet camshaft,tight or jammed
0x0130006A 106 VANOS exhaust camshaft,tighy or jammed
0x0130006D 109 Engine throttle, output-stage fault
0x0130006E 110 Signal, pedal-travel sensor,signal 1
0x0130006F 111 Signal, pedal-travel sensor,signal 2
0x01300070 112 Signal, engine-throttle sensor, potentiometer 1
0x01300071 113 Signal, engine-throttle sensor, Potentiometer 2
0x01300072 114 Pedal-position sensor,double fault
0x01300073 115 Adaptation,engine throttle
0x01300075 117 Plausibility, signal 1/2, pedal-position sensor
0x01300076 118 Plausibility, signal 1,engine throttle to air-mass flow sensor
0x01300077 119 Plausibility, signal 2,engine throttle to air-mass flow sensor
0x01300078 120 Plausibility, accelerator and brake pedals
0x0130007A 122 Signal, sensor,engine-oil temperature
0x0130007B 123 Activation, map cooling
0x0130007C 124 Activation, solenoid valve, intake manifold(DISA)
0x0130007D 125 Activation, electric fan
0x0130007E 126 Output-stage fault, diagn. Module, tank-leak diagnosis valve
0x01300080 128 EWS transmission/parity
0x01300081 129 Signal CAN SMG 1
0x01300082 130 Signal,CAN ASC/DSC
0x01300083 131 Signal,CAN instrument cluster
0x01300084 132 Signal,CAN instrument cluster
0x01300085 133 Signal,CAN ASC/DSC
0x01300086 134 Request, SMG intervention, implausible
0x01300087 135 Engine-throttle sensor starting test,readaptation was triggered
0x01300088 136 Engine-throttle sensor starting test,readaptation necessary
0x01300089 137 Signal CAN steering-angle sensor
0x0130008B 139 Signal, CAN, tank fill level
0x0130008C 140 Output-stage fault, DMTL pump
0x0130008D 141 Plausibility, tank fill level
0x0130008E 142 Module fault DMTL
0x0130008F 143 Tank-leak diagnosis with DMTL
0x01300092 146 Supply voltage,potentiometer 1
0x01300093 147 Supply voltage,potentiometer 2
0x01300095 149 Plausibility error, air mass to engine throttle
0x01300096 150 Oxygen-sensor voltage before catalytic converter, bank 1
0x01300097 151 Oxygen-sensor voltage before catalytic converter, bank 2
0x01300098 152 Oxygen-sensor voltage behind catalytic converter, bank 1
0x01300099 153 Oxygen-sensor voltage behind catalytic converter, bank 2
0x013000A0 160 Engine-throttle position controller,jammed briefly
0x013000A1 161 Engine-throttle position controller,jammed permanently
0x013000A2 162 Engine-throttle position controller,sluggish
0x013000A8 168 Thermostat, map cooling, mechanical, jammed open
0x013000BA 186 Voltage excursion before cat. sensor, bank 1
0x013000BB 187 Voltage excursion before cat. sensor, bank 2
0x013000BC 188 Insufficient heat output,oxygen sensor before catalytic converter, bank 1
0x013000BD 189 Insufficient heat output,oxygen sensor before catalytic converter, bank 2
0x013000BE 190 Insufficient heat output,oxygen sensor behind catalytic converter, bank 1
0x013000BF 191 Insufficient heat output,oxygen sensor behind catalytic converter, bank 2
0x013000C4 196 Fault,pressure-sensor variant
0x013000C5 197 Ambient-pressure sensor
0x013000C6 198 Cat.efficiency during starting sequence, bank 1
0x013000C7 199 Cat.efficiency during starting sequence, bank 2
0x013000CA 202 Fuel trim bank 1 control limit
0x013000CB 203 Fuel trim bank 2 control limit
0x013000CC 204 Plausibility, idle speed (leakage air)
0x013000D1 209 Anti-tampering protection EWS
0x013000D2 210 Error, ign.-current measurement at more than 2 cylinders
0x013000D3 211 Idle-speed control valve, mechanical fault
0x013000D6 214 Signal, road speed
0x013000D7 215 Oxygen sensor behind catalytic converter, bank 1, no signal
0x013000D8 216 Oxygen sensor behind catalytic converter, bank 2, no signal
0x013000D9 217 Signal CAN EGS
0x013000DB 219 Monitoring, CAN
0x013000DC 220 Voltage, oxygen sensor, bank 1, behind catalytic converter, sensor too slow
0x013000DD 221 Voltage, oxygen sensor, bank 2, behind catalytic converter, sensor too slow
0x013000DE 222 Oxygen-sensor control not active after specified time
0x013000DF 223 Jump time, oxygen sensor behind catalytic converter, bank 1
0x013000E0 224 Jump time, oxygen sensor behind catalytic converter, bank 2
0x013000E1 225 Trimming, oxygen sensor behind catalytic converter, bank 1
0x013000E2 226 Trimming, oxygen sensor behind catalytic converter, bank 2
0x013000E3 227 Fuel trim bank 1, permissible range exceeded
0x013000E4 228 Fuel trim bank 2, permissible range exceeded
0x013000E5 229 Control frequency, oxygen sensor, bank 1, incorrect
0x013000E6 230 Control frequency, oxygen sensor, bank 2, incorrect
0x013000E7 231 Switch time, oxygen sensor before catalytic converter, bank 1
0x013000E8 232 Switch time, oxygen sensor before catalytic converter, bank 2
0x013000E9 233 Catalytic-converter efficiency, bank 1
0x013000EA 234 Catalytic-converter efficiency, bank 2
0x013000EB 235 Trimming, oxygen sensor before catalytic converter, bank 1
0x013000EC 236 Trimming, oxygen sensor before catalytic converter, bank 2
0x013000EE 238 Misfire, cylinder 1
0x013000EF 239 Misfire, cylinder 2
0x013000F0 240 Misfire, cylinder 3
0x013000F1 241 Misfire, cylinder 4
0x013000F2 242 Misfire, cylinder 5
0x013000F3 243 Misfire, cylinder 6
0x013000F4 244 Segment timing, ture running disturbed
0x013000F5 245 Flow rate,secondary-air system,too low,bank 1
0x013000F6 246 Flow rate,secondary-air system,too low,bank 2
0x013000F7 247 Secondary-air valve open,jammed mechanically
0x013000F8 248 Sensor signal behind catalytic converter implausible, bank 1
0x013000F9 249 Sensor signal behind catalytic converter implausible, bank 2
0x013000FA 250 FA Function check, tank ventilation
//*MSS54 M54*/
0x01320001 001 Driver/fuel-pump relay
0x01320002 002 Idle-speed control valve, closing winding
0x01320003 003 Fuel injector cylinder 1
0x01320004 004 Fuel injector cylinder 3
0x01320005 005 Fuel injector cylinder 2
0x01320007 007 Signal, camshaft sensor, inlet, bank 1
0x01320008 008 Signal, camshaft sensor, inlet, bank 2
0x01320009 009 Signal, knock sensor, cylinder 1-2
0x0132000A 010 Signal, camshaft sensor, exhaust, bank 1
0x0132000B 011 Signal, camshaft sensor, exhaust, bank 2
0x0132000C 012 Signal, oxygen sensor before cat. conv., bank 2
0x0132000D 013 Signal, oxygen sensor before cat. conv., bank 1
0x0132000E 014 Heating, DMTL module
0x0132000F 015 Camshaft sensor, bank 1: synchronization to crankshaft
0x01320010 016 Signal, crankshaft sensor
0x01320013 019 Relay, secondary air pump
0x01320014 020 Starter relay
0x01320015 021 Exhaust VANOS, bank 1, retard valve
0x01320016 022 Exhaust VANOS, bank 1, Advance valve
0x01320017 023 Ignition coil, cylinder 2
0x01320018 024 Ignition coil, cylinder 3
0x01320019 025 Ignition coil, cylinder 1
0x0132001A 026 Ignition coil, cylinder 8
0x0132001B 027 DMTL changeover valve
0x0132001D 029 Idle-speed control valve, NC winding
0x0132001E 030 Internal DME fault
0x0132001F 031 Fuel injector cylinder 5
0x01320020 032 Fuel injector cylinder 6
0x01320021 033 Fuel injector cylinder 4
0x01320022 034 Fuel injector cylinder 7
0x01320023 035 Fuel injector cylinder 8
0x01320024 036 Tank-venting valve
0x01320025 037 Oxygen-sensor heater before cat. conv., bank 1
0x01320026 038 Oxygen-sensor heater before cat. conv., bank 2
0x01320027 039 Oxygen-sensor heater behind cat. conv., bank 1
0x01320028 040 Oxygen-sensor heater behind cat. conv., bank 2
0x01320029 041 Signal, air-mass flow sensor, right
0x0132002A 042 Roadspeed signal, pin 4-22
0x0132002B 043 Signal, temperature sensor, radiater outlet
0x0132002C 044 Signal, thermal oil-level, sensor
0x0132002D 045 Electric throttle-servomotor
0x0132002F 047 Output, engine-speed signal TD
0x01320030 048 Internal, A/C control module
0x01320031 049 Internal index 95
0x01320032 050 Ignition coil, cylinder 4
0x01320033 051 Ignition coil, cylinder 6
0x01320034 052 Ignition coil, cylinder 5
0x01320035 053 Interface, electric fan
0x01320036 054 System voltages, main relay
0x01320037 055 Ignition coil, cylinder 7
0x01320039 057 Signal, air-mass flow sensor left
0x0132003A 058 Voltage supply, sensors
0x0132003B 059 Voltage supply, sensors
0x0132003C 060 Signal, pedal-position sensor 1
0x0132003D 061 Signal, pedal-position sensor 2
0x0132003F 063 Secondary-air valve
0x01320041 065 Signal,potentiometer, throttle and electric throttle actuator
0x01320042 066 EWS 3.3 interface: no DME-EWS communication
0x01320043 067 Inlet VANOS, bank 1, advance valve
0x01320045 069 Signal, knock sensor, cylinder 3-4
0x01320046 070 Signal, knock sensor, cylinder 7-8
0x01320047 071 Signal, knock sensor, cylinder 5-6
0x01320048 072 Inlet VANOS, bank 1, retard valve
0x01320049 073 Signal, air-mass flow sensor, implausible
0x0132004A 074 Inlet VANOS, bank 2, advance valve
0x0132004B 075 Inlet VANOS, bank 2, retard valve
0x0132004C 076 Ambient-pressure sensor (DME internal)
0x0132004D 077 Signal, intake-air temperature sensor
0x0132004E 078 Signal, coolant temperature sensor
0x0132004F 079 Singal, exhaust-gass temperature sensor
0x01320050 080 Switch chain, frictional connection
0x01320051 081 Interface, multifunction steering wheel(E39)/steering-column lever(E52)
0x01320053 083 Exhaust VANOS, bank 2, advance valve
0x01320054 084 Exhaust VANOS, bank 2, retard valve
0x01320055 085 Signal, throttle potentiometer
0x01320056 086 No CAN-bus signal to DME
0x01320057 087 Signal, oxygen-sensor after cat. conv., bank 1
0x01320058 088 Signal, oxygen-sensor after cat. conv., bank 2
0x01320059 089 Internal DME fault
0x0132005C 092 Oxygen sensor after cat. conv., bank 1: voltage monitoring
0x0132005D 093 Oxygen sensor after cat. conv., bank 2: voltage monitoring
0x01320063 099 Internal DME fault
0x01320064 100 Signal tire pressure, front left
0x01320065 101 Signal tire pressure, front right
0x01320066 102 Signal tire pressure, rear right
0x01320067 103 Signal tire pressure, rear left
0x01320069 105 Signal, engine temperautre, implausible
0x0132006A 106 Signal, brake-light switch
0x0132006B 107 Electric throttle: self-test
0x0132006C 108 Activation, oil-circuit changeover valve, left
0x0132006D 109 Activation, oil-circuit changeover valve, right
0x0132006E 110 Function light, switch,vehicle dynamics
0x0132006F 111 Pedal-position sensor, comparison fault
0x01320070 112 Pedal-position sensor, comparison fault
0x01320071 113 Function, inlet VANOS, bank 2
0x01320072 114 Function, exhaust VANOS, bank 2
0x01320073 115 Sensor,control module temperature (DME internal) or button, tire pressure control system
0x01320074 116 Valve, servotronic
0x01320075 117 Servotronic: no roadspeed signal
0x01320076 118 Electric throttle: signal, potentiometer, bank 1
0x01320077 119 Electric throttle: signal, potentiometer, bank 2
0x01320078 120 Electric throttle: potentiometer, signal comparison
0x01320079 121 Electric throttle: both potentiomters faulty
0x0132007A 122 DME-internal processor check
0x0132007D 125 Thermal oil-level sensor: function lamp
0x0132007E 126 Crash deactivation, electric fuel pump
0x0132007F 127 DMTL module, tank-leakage diagnosis
0x01320080 128 Deviation, idle speed
0x01320081 129 Cat. protection function as result of empty tank or lack of fuel
0x01320082 130 EWS 3.3 auti-tampering protection
0x01320083 131 DSC intervention implausible
0x01320084 132 CAN timeout, DSC
0x01320085 133 CAN timeout, Steering-angla sensor
0x01320086 134 CAN timeout, instrumeat cluster
0x01320087 135 NO roadspeed signal
0x01320088 136 Function, idle-speed control
0x0132008B 139 Interruption, Tempormat operation
0x0132008C 140 Knock control deactivated/knock prtrction
0x0132008D 141 Tank fill level implausible
0x0132008F 143 Electronics-box fan
0x01320090 144 Function, oxygen-sensor control, bank 1
0x01320091 145 Function, oxygen-sensor control, bank 2
0x01320095 149 Fault with empty tank
0x01320096 150 DME memory fault
0x01320097 151 Internal DME fault
0x0132009B 155 Saving adaptation values not possible
0x0132009C 156 Saving adaptation values not possible
0x0132009D 157 DME memory fault
0x0132009E 158 Reset DME possibly as result of over speed
0x0132009F 159 Internal DME fault: knock control
0x013200A0 160 Internal DME fault: knlck control
0x013200A1 161 Internal DME fault: knlck control
0x013200A2 162 Camshaft sensor, bank 2: synchronization to crankshaft
0x013200A3 163 Reset DME possibly as result of over speed
0x013200AA 170 Secondary-air quantity too low
0x013200AB 171 Function, secondary-air valve: jammed
0x013200AC 172 VANOS admission-pressure pump
0x013200AD 173 Continuous signal, tm. 50, starter switch
0x013200AE 174 Fuel-system diagnosis, bank 1
0x013200AF 175 Fuel-system diagnosis, bank 2
0x013200B0 176 Abort tank-leak diagnosis due to moisture
0x013200B2 178 Catalytic-converter conversion, bank 1
0x013200B3 179 Catalytic-converter conversion, bank 2
0x013200B4 180 Tank leakage detected
0x013200B5 181 Fuel filler cap open/missing
0x013200B6 182 Internal DME fault
0x013200B7 183 Internal DME fault
0x013200B8 184 Function, inlet VANOS, bank 1: control
0x013200B9 185 Function, exhaust VANOS, bank 1: control
0x013200C2 194 Electric throttle limp-home program from cruise-control mode
0x013200C3 195 Deviation, setpoint torque from actual torque
0x013200C4 196 Misfiring, cylinder 1 with cylinder cutout
0x013200C5 197 Misfiring, cylinder 2 with cylinder cutout
0x013200C6 198 Misfiring, cylinder 3 with cylinder cutout
0x013200C7 199 Misfiring, cylinder 4 with cylinder cutout
0x013200C8 200 Misfiring, cylinder 5 with cylinder cutout
0x013200C9 201 Misfiring, cylinder 6 with cylinder cutout
0x013200CA 202 Misfiring, cylinder 7 with cylinder cutout
0x013200CB 203 Misfiring, cylinder 8 with cylinder cutout
0x013200CC 204 Misfiring, several cylinder with cylinder cutout
0x013200CD 195 Misfiring, cylinder 1 without cylinder cutout
0x013200CE 196 Misfiring, cylinder 2 without cylinder cutout
0x013200CF 197 Misfiring, cylinder 3 without cylinder cutout
0x013200D0 198 Misfiring, cylinder 4 without cylinder cutout
0x013200D1 209 Misfiring, cylinder 5 without cylinder cutout
0x013200D2 210 Misfiring, cylinder 6 without cylinder cutout
0x013200D3 211 Misfiring, cylinder 7 without cylinder cutout
0x013200D4 212 Misfiring, cylinder 8 without cylinder cutout
0x013200D5 213 Misfiring, several cylinder without cylinder cutout
0x013200D6 214 Oxygen sensor before cat. conv., bank 1: period duration
0x013200D7 215 Oxygen sensor before cat. conv., bank 2: period duration
0x013200D8 216 Oxygen sensor before cat. conv., bank 1: jump time
0x013200D9 217 Oxygen sensor before cat. conv., bank 2: jump time
0x013200DA 218 Oxygen sensor before cat. conv., bank 1: Signal excursion
0x013200DB 219 Oxygen sensor before cat. conv., bank 2: Signal excursion
0x013200DC 220 DME-internal processor check
0x013200E4 228 Electric throttle: limit violation
0x013200E6 230 Electic throttle: setpoint/actual value deviation
0x013200E7 231 DME-internal processor check
0x013200E8 232 Function check, tank-venting valve
0x013200F7 247 VANOS pressure-accumulator valve
//*BMS46 III M43*/
0x01350064 100 Activation, ignition coil, cylinder 1
0x01350065 101 Activation, ignition coil, cylinder 2
0x01350066 102 Activation, ignition coil, cylinder 3
0x01350067 103 Activation, ignition coil, cylinder 4
0x01350068 104 Activation, fuel injector, cylinder 1 (EUIII code: P0201)
0x01350069 105 Activation, fuel injector, cylinder 2 (EUIII code: P0202)
0x0135006A 106 Activation, fuel injector, cylinder 3 (EUIII code: P0203)
0x0135006B 107 Activation, fuel injector, cylinder 4 (EUIII code: P0204)
0x0135006C 108 Activation, electric fan
0x0135006E 110 Activation, A/C compressor
0x0135006F 111 Activation, fuel-pump relay
0x01350070 112 Activation, DISA valve
0x01350071 113 Activation, tank-venting valve (EUIII code: P0443)
0x01350072 114 Activation, suction-jet-pump valve
0x01350073 115 Activation, map cooling
0x01350075 117 Activation, idle-speed control valve (EUIII code: P0505)
0x01350076 118 Activation, ox.-sensor heater before cat. conv. (EUIII code: P0135)
0x01350077 119 Signal, throttle potentiometer (EUIII code: P0120)
0x01350078 120 Signal, hot-film air-mass flow sensor (EUIII code: P0101)
0x01350079 121 Signal, intake-air temperature (EUIII code: P0110)
0x0135007A 122 Signal, coolant temperature (EUIII code: P0115)
0x0135007B 123 Signal, coolant outlet temperature
0x0135007C 124 Battery positive voltage, main relay
0x0135007D 125 Signal, oxygen sensor before catalytic converter (EUIII code: P0130)
0x0135007E 126 Signal, CAN ASC
0x0135007F 127 Request, CAN ASC
0x01350080 128 Signal, CAN EGS (EUIII code: P0700)
0x01350081 129 Request, CAN EGS
0x01350082 130 Signal, CAN IKE
0x01350083 131 Signal, road speed (EUIII code: P0500)
0x01350084 132 Ref. voltage for hot-film air-mass flow sensor (EUIII code: P0101)
0x01350085 133 Reference voltage for throttle potentiometer (EUIII code: P0608)
0x01350087 135 Signal, camshaft sensor (EUIII code: P0340)
0x01350088 136 Signal, crankshaft sensor (EUIII code: P0335)
0x01350089 137 Signal, knock sensor 1 (EUIII code: P0325)
0x0135008A 138 Signal, knock sensor 2 (EUIII code: P0330)
0x0135008B 139 Signal, oxygen sensor after catalytic converter (EUIII code: P0136)
0x0135008C 140 DME-EWS 3.3 interface
0x0135008D 141 Oxygen-sensor control, control limit (EUIII code: P0170)
0x0135008E 142 Knock control, self-test (EUIII code: P0325)
0x0135008F 143 Control modules, self-test (EUIII code: P0601)
0x01350090 144 Anti-tampering protection EWS 3.3
0x01350091 145 Misfire relevant to exhaust gas, cylinder 1 (EUIII code: P0301)
0x01350092 146 Misfire relevant to exhaust gas, cylinder 2 (EUIII code: P0302)
0x01350093 147 Misfire relevant to exhaust gas, cylinder 3 (EUIII code: P0303)
0x01350094 148 Misfire relevant to exhaust gas, cylinder 4 (EUIII code: P0304)
0x01350095 149 Activation, secondary-air valve (EUIII code: P0412)
0x01350096 150 Activation, secondary-air pump (EUIII code: P0418)
0x01350097 151 Secondary-air system, plausibility (EUIII code: P0410)
0x01350098 152 ECU self-test, E2PROM emulation (EUIII code: P0602)
0x01350099 153 Activation, ox.-sensor heater after cat. conv. (EUIII code: P0141)
0x0135009B 155 Misfire relevant to exhaust gas, total (EUIII code: P0300)
0x0135009C 156 Misfire with cylinder cutout at cylinder 1 (EUIII code: P0301)
0x0135009D 157 Misfire with cylinder cutout at cylinder 2 (EUIII code: P0302)
0x0135009E 158 Misfire with cylinder cutout at cylinder 3 (EUIII code: P0303)
0x0135009F 159 Misfire with cylinder cutout at cylinder 4 (EUIII code: P0304)
0x013500A0 160 Misfire with cylinder cutout, total (EUIII code: P0300)
0x013500A5 165 Catalytic-converter conversion (EUIII code: P0420)
0x013500A6 166 Period duration, ox.sensor before cat. conv. (EUIII code: P0133)
0x013500A9 169 Heat output, sensor before cat. conv. (EUIII code: P0135)
0x013500AA 170 Heat output, sensor after cat. conv. (EUIII code: P0141)
0x013500AB 171 Check, fuel supply system (EUIII code: P0170)
//*M3.3 M60 */
0x01100001 1 EKP relay
0x01100002 2 Idle-actuator closing winding
0x01100003 3 Fuel injector, cylinder 1
0x01100004 4 Fuel injector, cylinder 4
0x01100005 5 Fuel injector, cylinder 6
0x01100006 6 Fuel-injector, output stage
0x01100007 7 Fuel-injector, cylinder 7
0x01100008 8 Fault lamp (US only)
0x0110000C 12 Oxygen sensor 2
0x0110000D 13 Oxygen sensor 1
0x0110000F 15 Ignition-circuit monitoring
0x01100010 16 Crankshaft pulse generator
0x01100011 17 Camshaft sensor
0x01100016 22 Ignition, cylinder 7
0x01100017 23 Ignition, cylinder 6
0x01100018 24 Ignition, cylinder 4
0x01100019 25 Ignition, cylinder 1
0x0110001A 26 Control-unit supply B+
0x0110001D 29 Idle-actuator opening winding
0x0110001F 31 Fuel injector, cylinder 5
0x01100020 32 Fuel injector, cylinder 8
0x01100021 33 Fuel injector, cylinder 3
0x01100023 35 Fuel injector, cylinder 2
0x01100024 36 Tank ventilation
0x01100025 37 Oxygen-sensor heating
0x01100026 38 O2 sensor heating ralay
0x01100029 41 Air-mass flow sensor (HFM)
0x0110002A 42 Road-speed sensor
0x0110002e 46 Free SG output stage
0x01100030 48 Air-conditioning compressor cutoff
0x01100031 49 Ignition, cylinder 2
0x01100032 50 Ignition, cylinder 3
0x01100033 51 Ignition, cylinder 8
0x01100034 52 Ignition, cylinder 5
0x01100036 54 Control-unit power supply via main relay (DME)
0x0110003E 62 Signal, electeonic engine-power control (EML)
0x01100042 66 Signal, burglar-alarm system DWA
0x01100043 67 Knock sensor 4
0x01100044 68 Knock snesor 3
0x01100045 69 Knock sensor 2
0x01100046 70 Knock snesor 1
0x01100049 73 Throttle-valve potentiometer
0x0110004D 77 Intake-air-temperature sensor
0x0110004E 78 Engine-temperature sensor (coolant)
0x01100052 82 Intervention, engine-drag-torque control (MSR)
0x01100053 83 Intervention Automatic Stability Control (ASC)
0x01100064 100 Output stage, Group 1
0x01100065 101 Output stage, Group 2
0x011000C8 333 DME control unit
0x011000C9 201 Oxygen-sensor control 1
0x011000CA 202 Fault memory
0x011000CB 203 Oxygen-sensor control 2
0x011000CC 204 Idle-speed increase during MSR increase
0x011000CD 205 Gearbox intervention during gearshifts (with EGS only)
0x011000CE 206 Knock-control test pulse
0x011000D2 210 CAN interface, gearbox intervention
0x011000DC 220 Electronic immobilizer EWS II
//*M1.2 М70 */
0x01110000 0 No Description
0x01110001 1 DME control unit
0x01110003 3 TR signal
0x01110004 4 Idle control actuator(open)
0x01110005 5 Tank venting valve
0x01110007 7 Air-mass flow sensor
0x0111000a 10 Oxygen-sensor control
0x0111000f 15 Fault lamp
0x01110010 16 Fuel injectors, cyl. 1+3+5 or 7+9+11
0x01110011 17 Fuel injectors, cyl. 2+4+6 or 8+10+12
0x01110016 22 Idle control actuator(close)
0x01110017 23 Relay, oxygen-sensor heater
0x0111001c 28 Oxygen sensor
0x0111001d 29 Vehicle speed sensor signal
0x01110025 37 Control-unit power supply
0x01110026 38 Intervention, ASC/DWA
0x01110028 40 Air conditioner compressor operation
0x0111002b 43 Idle CO potentiometer
0x0111002c 44 Intak-air temperature sensor
0x0111002d 45 Coolant-temperature sensor (engine)
0x01110032 50 Intervention, MSR
0x01110033 51 Ignition-timing intervention
0x01110034 52 Idle switch
0x01110035 53 Throttle position switch(open)
0x01110036 54 Converter lockup clutch
0x01110064 100 Output stage
0x01110063 101 Engine cannot operation
//*M1.7 M70*/
0x01120000 0 No Description
0x01120001 1 Fuel pump relay
0x01120003 3 Injector cyl.2+4+6 or 8+10+12
0x01120008 8 Fault indicator lamp
0x01120010 16 Ignition system
0x01120012 18 Control unit,pin18 stage
0x01120020 32 Injector cyl.1+3+5 or 7+9+11
0x01120024 36 Fuel tank evaporation ventilation valve
0x01120025 37 O2 sensor heating relay
0x01120029 41 Air flow meter(HLM)
0x01120030 48 air conditioner compressor cutoff
0x01120036 54 control system unit power supply(B+)
0x0112003f 63 Torque converter clutch
0x01120040 64 Ignition timing intervention
0x01120046 70 O2 sensor signal
0x01120049 73 Vehicle speed sensor
0x0112004c 76 Idle CO potentiometer
0x0112004d 77 Intake air temperature signal
0x0112004e 78 Engine temperature signal
0x01120052 82 Engine drag-torque control
0x01120053 83 Automatic stability control(ASC)
0x01120064 100 Engine control system
0x011200c8 200 DME control unit
0x011200c9 201 2 sensor control
//*M1.7.1 S70B56*/
0x01130000 0 No Description
0x01130001 1 Fuel pump relay
0x01130003 3 Injector cyl.2+4+6 or 8+10+12
0x01130004 4 Idle control actuator (OPEN)
0x01130008 8 Fault indicator lamp
0x01130010 16 Ignition system
0x01130012 18 Control unit,pin18 stage
0x01130020 32 Injector cyl.1+3+5 or 7+9+11
0x01130024 36 Fuel tank evaporation ventilation valve
0x01130025 37 O2 sensor heating relay
0x01130029 41 Air flow meter(HLM)
0x01130030 48 air conditioner compressor cutoff
0x01130036 54 control system unit power supply(B+)
0x0113003f 63 Torque converter clutch
0x01130040 64 Ignition timing intervention
0x01130046 70 O2 sensor signal
0x01130049 73 Vehicle speed sensor
0x0113004c 76 Idle CO potentiometer
0x0113004d 77 Intake air temperature signal
0x0113004e 78 Engine temperature signal
0x01130052 82 Engine drag-torque control
0x01130053 83 Automatic stability control(ASC)
0x01130064 100 Engine control system
0x011300c8 200 DME control unit
0x011300c9 201 2 sensor control
//*DME M5.2 M70*/
0x01140001 1 leakgage diagnosis pump output stage
0x01140002 2 Fuel circuit changeover
0x01140003 3 leakgage diagnosis pump
0x01140004 4 O2 sensor heater after cat. converter cylinders 5-8
0x01140005 5 O2 sensor heater before cat. converter cylinders 5-8
0x01140006 6 CAN instrumentation
0x01140008 8 Misfire detection, tank run empty
0x0114000A 10 Oxygen sensor upstream of catalytic converter
0x0114000C 12 Oxygen sensor downstream of catalytic converter
0x0114000D 13 Oxygen sensor heater before catalytic converter
0x0114000E 14 Oxygen sensor heater after catalytic converter
0x0114000F 15 Oxygen-sensor ageing TP
0x01140010 16 O2 sensor ageing TV before cat. Converter
0x01140011 17 O2 sensor ageing after cat. converter cylinders 1-4
0x01140012 18 O2 sensor before catalytic converter Cylinders 5-8
0x01140014 20 O2 sensor after catalytic converter Cylinders 5-8
0x01140015 21 O2 sensor ageing TP before cat. converter Cylinders 5-8
0x01140016 22 O2 sensor ageing TV before cat. converter Cylinders 5-8
0x01140017 23 O2 sensor ranging after cat. converter Cylinders 5-8
0x01140018 24 diagnosis A/C compressor function
0x0114001A 26 Multipicativa mixt. adaptation (part load control limit reached)
0x0114001B 27 Additive mixture adaptation (idle) Control limit reached
0x0114001C 28 Additive mixture adaptation (idle) Control limit reached
0x01140020 32 Idle speed control valve blocked
0x01140022 34 Multiplicative mixture adaptation (part load)Cylinders 5-8,control limit reached
0x01140024 36 Multiplicative mixture adaptation (idle)Cylinders 1-4,control limit reached
0x01140027 39 Electronic engine immobilize EWS
0x01140028 40 Catalytic-converter conversion
0x0114002c 45 CAT. converter conversion, cylinder 5-8
0x01140032 50 Misfiring detection cyl. 1, relevant to exhaust gas
0x01140033 51 Misfiring detection cyl. 2, relevant to exhaust gas
0x01140034 52 Misfiring detection cyl. 3, relevant to exhaust gas
0x01140035 53 Misfiring detection cyl. 4, relevant to exhaust gas
0x01140036 54 Misfiring detection cyl. 5, relevant to exhaust gas
0x01140037 55 Misfiring detection cyl. 6, relevant to exhaust gas
0x01140038 56 Misfiring detection cyl. 7, relevant to exhaust gas
0x01140039 57 Misfiring detection cyl. 8, relevant to exhaust gas
0x0114003A 58 Misfiring detection cyl. 9, relevant to exhaust gas
0x0114003B 59 Misfiring detection cyl. 10, relevant to exhaust gas
0x0114003C 60 Misfiring detection cyl. 11, relevant to exhaust gas
0x0114003D 61 Misfiring detection cyl. 12, relevant to exhaust gas
0x0114003E 62 Misfiring detection, sum, relevant to exhaust gas
0x0114003F 63 Misfiring with cylinder cutout, cyl. 1
0x01140040 64 Misfiring with cylinder cutout, cyl. 2
0x01140041 65 Misfiring with cylinder cutout, cyl. 3
0x01140042 66 Misfiring with cylinder cutout, cyl. 4
0x01140043 67 Misfiring with cylinder cutout, cyl. 5
0x01140044 68 Misfiring with cylinder cutout, cyl. 6
0x01140045 69 Misfiring with cylinder cutout, cyl. 7
0x01140046 70 Misfiring with cylinder cutout, cyl. 8
0x01140047 71 Misfiring with cylinder cutout, cyl. 9
0x01140048 72 Misfiring with cylinder cutout, cyl. 10
0x01140049 73 Misfiring with cylinder cutout, cyl. 11
0x0114004A 74 Misfiring with cylinder cutout, cyl. 12
0x0114004B 75 Misfiring with cylinder cutout, total
0x0114004E 78 Speed sensor, one tooth too many
0x0114004f 79 Secondary air pump, stage 2(output stage)
0x01140050 80 Secondary air system
0x01140054 84 Secondary air pump (output stage)
0x01140055 85 Secondary air valve (output stage)
0x0114005B 91 Tank-ventilation valve, output stage, bank 2
0x0114005D 93 Tank-ventilation system
0x01140061 97 Tank leak detection: minor leak
0x01140062 98 Tank-ventilation-valve output stage
0x01140065 101 Control unit faulty (Master iRAM)
0x01140066 102 Control unit faulty (xRAM)
0x01140067 103 Control unit faulty (Master ROM)
0x01140068 104 Wrong values in fault memory
0x0114006B 107 Terminal 15 power supply
0x0114006C 108 Continuous voltage (+)
0x0114006F 111 Crankshaft position sensor
0x01140070 112 Camshaft position sensor
0x01140073 115 Air mass
0x01140075 117 Throttle valve potentiometer
0x01140078 120 Road speed
0x01140079 121 Load detection
0x0114007B 123 Engine-temperature sensor (coolant)
0x0114007C 124 Intake-air temperature sensor
0x01140082 130 O2 sensors before catalytic converter mixed up
0x01140086 134 Tank fuel level
0x01140087 135 Engine intervention / Specified engine torque (gearbox intervention)
0x0114008A 138 Compressor intervention
0x0114008B 139 Output stage, map cooling
0x0114008C 140 Engine torque, bank comparison
0x0114008D 141 Dynamic Stability Control (DSC) intervention with fadeout
0x0114008F 143 Engine drag-torque control (MSR) intervention
0x01140090 144 Dynamic Stability Control (DSC) intervention
0x01140093 147 Function, map cooling
0x01140094 148 Burglar alarm system
0x01140096 150 Fuel injector, cyl. 1
0x01140097 151 Fuel injector, cyl. 2
0x01140098 152 Fuel injector, cyl. 3
0x01140099 153 Fuel injector, cyl. 4
0x0114009A 154 Fuel injector, cyl. 5
0x0114009B 155 Fuel injector, cyl. 6
0x0114009C 156 Fuel injector, cyl. 7
0x0114009D 157 Fuel injector, cyl. 8
0x0114009E 158 Fuel injector, cyl. 9
0x0114009F 159 Fuel injector, cyl. 10
0x011400A0 160 Fuel injector, cyl. 11
0x011400A1 161 Fuel injector, cyl. 12
0x011400A3 163 Electric-fuel-pump relay
0x011400A5 165 Exhaust-gas warning lamp ('CHECK ENGINE' lamp is fitted in US vehicle only)
0x011400A7 167 Electric-fuel-pump relay output stage
0x011400A8 168 Idle speed control valve, opening coil
0x011400A9 169 Idle speed control valve, closing coil
0x011400AA 170 A/C-compressor control
0x011400AE 174 Camshaft control, bank 1
0x011400B2 178 Camshaft control, bank 2
0x011400B3 179 A/C-compressor control, bank 2
0x011400BC 188 Exhaust-gas warning lamp, bank 2 ('CHECK ENGINE' lamp is fitted in US vehicle fitted)
0x011400BD 189 inlet camshaft setting, bank 1
0x011400CB 203 Ignition-circuit monitoring
0x011400CC 204 EWS random code storage
0x011400D0 208 Secondary air system
0x011400D2 210 Knock sensor 1
0x011400D3 211 Knock sensor 2
0x011400D4 212 Knock sensor 3
0x011400D5 213 Knock sensor 4
0x011400D6 214 Controller Area Network (CAN) interface, version No.
0x011400D7 215 Controller Area Network (CAN) interface, Digital Motor Electronics (DME) timeout
0x011400D8 216 Controller Area Network (CAN) interface, Dynamic Stability Control (DSC) timeout
0x011400D9 217 Controller Area Network (CAN) interface, Electronic engine-power control (EML) timeout
0x011400DC 220 Knock control
0x011400DE 222 Knock-control test pulse
0x011400E4 228 Automatic excess-fuel starting device output stage, bank 2
0x011400E9 233 Automatic excess-fuel starting deveice output stage
0x011400EA 234 Starting signal
0x011400EC 236 Controller Area Network (CAN) interface, Electronic gearbox control (EGS) timeout
0x011400ED 237 Automatic exess-fuel starting deveice
//*DME M5.2 M73 (DME M5.2 M70)*/
0x01150001 1 leakgage diagnosis pump output stage
0x01150002 2 Fuel circuit changeover
0x01150003 3 leakgage diagnosis pump
0x01150004 4 O2 sensor heater after cat. converter cylinders 5-8
0x01150005 5 O2 sensor heater before cat. converter cylinders 5-8
0x01150006 6 CAN instrumentation
0x01150008 8 Misfire detection, tank run empty
0x0115000A 10 Oxygen sensor upstream of catalytic converter
0x0115000C 12 Oxygen sensor downstream of catalytic converter
0x0115000D 13 Oxygen sensor heater before catalytic converter
0x0115000E 14 Oxygen sensor heater after catalytic converter
0x0115000F 15 Oxygen-sensor ageing TP
0x01150010 16 O2 sensor ageing TV before cat. Converter
0x01150011 17 O2 sensor ageing after cat. converter cylinders 1-4
0x01150012 18 O2 sensor before catalytic converter Cylinders 5-8
0x01150014 20 O2 sensor after catalytic converter Cylinders 5-8
0x01150015 21 O2 sensor ageing TP before cat. converter Cylinders 5-8
0x01150016 22 O2 sensor ageing TV before cat. converter Cylinders 5-8
0x01150017 23 O2 sensor ranging after cat. converter Cylinders 5-8
0x01150018 24 diagnosis A/C compressor function
0x0115001A 26 Multipicativa mixt. adaptation (part load control limit reached)
0x0115001B 27 Additive mixture adaptation (idle) Control limit reached
0x0115001C 28 Additive mixture adaptation (idle) Control limit reached
0x01150020 32 Idle speed control valve blocked
0x01150022 34 Multiplicative mixture adaptation (part load)Cylinders 5-8,control limit reached
0x01150024 36 Multiplicative mixture adaptation (idle)Cylinders 1-4,control limit reached
0x01150027 39 Electronic engine immobilize EWS
0x01150028 40 Catalytic-converter conversion
0x0115002c 45 CAT. converter conversion, cylinder 5-8
0x01150032 50 Misfiring detection cyl. 1, relevant to exhaust gas
0x01150033 51 Misfiring detection cyl. 2, relevant to exhaust gas
0x01150034 52 Misfiring detection cyl. 3, relevant to exhaust gas
0x01150035 53 Misfiring detection cyl. 4, relevant to exhaust gas
0x01150036 54 Misfiring detection cyl. 5, relevant to exhaust gas
0x01150037 55 Misfiring detection cyl. 6, relevant to exhaust gas
0x01150038 56 Misfiring detection cyl. 7, relevant to exhaust gas
0x01150039 57 Misfiring detection cyl. 8, relevant to exhaust gas
0x0115003A 58 Misfiring detection cyl. 9, relevant to exhaust gas
0x0115003B 59 Misfiring detection cyl. 10, relevant to exhaust gas
0x0115003C 60 Misfiring detection cyl. 11, relevant to exhaust gas
0x0115003D 61 Misfiring detection cyl. 12, relevant to exhaust gas
0x0115003E 62 Misfiring detection, sum, relevant to exhaust gas
0x0115003F 63 Misfiring with cylinder cutout, cyl. 1
0x01150040 64 Misfiring with cylinder cutout, cyl. 2
0x01150041 65 Misfiring with cylinder cutout, cyl. 3
0x01150042 66 Misfiring with cylinder cutout, cyl. 4
0x01150043 67 Misfiring with cylinder cutout, cyl. 5
0x01150044 68 Misfiring with cylinder cutout, cyl. 6
0x01150045 69 Misfiring with cylinder cutout, cyl. 7
0x01150046 70 Misfiring with cylinder cutout, cyl. 8
0x01150047 71 Misfiring with cylinder cutout, cyl. 9
0x01150048 72 Misfiring with cylinder cutout, cyl. 10
0x01150049 73 Misfiring with cylinder cutout, cyl. 11
0x0115004A 74 Misfiring with cylinder cutout, cyl. 12
0x0115004B 75 Misfiring with cylinder cutout, total
0x0115004E 78 Speed sensor, one tooth too many
0x0115004f 79 Secondary air pump, stage 2(output stage)
0x01150050 80 Secondary air system
0x01150054 84 Secondary air pump (output stage)
0x01150055 85 Secondary air valve (output stage)
0x0115005B 91 Tank-ventilation valve, output stage, bank 2
0x0115005D 93 Tank-ventilation system
0x01150061 97 Tank leak detection: minor leak
0x01150062 98 Tank-ventilation-valve output stage
0x01150065 101 Control unit faulty (Master iRAM)
0x01150066 102 Control unit faulty (xRAM)
0x01150067 103 Control unit faulty (Master ROM)
0x01150068 104 Wrong values in fault memory
0x0115006B 107 Terminal 15 power supply
0x0115006C 108 Continuous voltage (+)
0x0115006F 111 Crankshaft position sensor
0x01150070 112 Camshaft position sensor
0x01150073 115 Air mass
0x01150075 117 Throttle valve potentiometer
0x01150078 120 Road speed
0x01150079 121 Load detection
0x0115007B 123 Engine-temperature sensor (coolant)
0x0115007C 124 Intake-air temperature sensor
0x01150082 130 O2 sensors before catalytic converter mixed up
0x01150086 134 Tank fuel level
0x01150087 135 Engine intervention / Specified engine torque (gearbox intervention)
0x0115008A 138 Compressor intervention
0x0115008B 139 Output stage, map cooling
0x0115008C 140 Engine torque, bank comparison
0x0115008D 141 Dynamic Stability Control (DSC) intervention with fadeout
0x0115008F 143 Engine drag-torque control (MSR) intervention
0x01150090 144 Dynamic Stability Control (DSC) intervention
0x01150093 147 Function, map cooling
0x01150094 148 Burglar alarm system
0x01150096 150 Fuel injector, cyl. 1
0x01150097 151 Fuel injector, cyl. 2
0x01150098 152 Fuel injector, cyl. 3
0x01150099 153 Fuel injector, cyl. 4
0x0115009A 154 Fuel injector, cyl. 5
0x0115009B 155 Fuel injector, cyl. 6
0x0115009C 156 Fuel injector, cyl. 7
0x0115009D 157 Fuel injector, cyl. 8
0x0115009E 158 Fuel injector, cyl. 9
0x0115009F 159 Fuel injector, cyl. 10
0x011500A0 160 Fuel injector, cyl. 11
0x011500A1 161 Fuel injector, cyl. 12
0x011500A3 163 Electric-fuel-pump relay
0x011500A5 165 Exhaust-gas warning lamp ('CHECK ENGINE' lamp is fitted in US vehicle only)
0x011500A7 167 Electric-fuel-pump relay output stage
0x011500A8 168 Idle speed control valve, opening coil
0x011500A9 169 Idle speed control valve, closing coil
0x011500AA 170 A/C-compressor control
0x011500AE 174 Camshaft control, bank 1
0x011500B2 178 Camshaft control, bank 2
0x011500B3 179 A/C-compressor control, bank 2
0x011500BC 188 Exhaust-gas warning lamp, bank 2 ('CHECK ENGINE' lamp is fitted in US vehicle fitted)
0x011500BD 189 inlet camshaft setting, bank 1
0x011500CB 203 Ignition-circuit monitoring
0x011500CC 204 EWS random code storage
0x011500D0 208 Secondary air system
0x011500D2 210 Knock sensor 1
0x011500D3 211 Knock sensor 2
0x011500D4 212 Knock sensor 3
0x011500D5 213 Knock sensor 4
0x011500D6 214 Controller Area Network (CAN) interface, version No.
0x011500D7 215 Controller Area Network (CAN) interface, Digital Motor Electronics (DME) timeout
0x011500D8 216 Controller Area Network (CAN) interface, Dynamic Stability Control (DSC) timeout
0x011500D9 217 Controller Area Network (CAN) interface, Electronic engine-power control (EML) timeout
0x011500DC 220 Knock control
0x011500DE 222 Knock-control test pulse
0x011500E4 228 Automatic excess-fuel starting device output stage, bank 2
0x011500E9 233 Automatic excess-fuel starting deveice output stage
0x011500EA 234 Starting signal
0x011500EC 236 Controller Area Network (CAN) interface, Electronic gearbox control (EGS) timeout
0x011500ED 237 Automatic exess-fuel starting deveice
//*DME M5.2 M62*/
0x01290001 1 Activation, leakage diagnosis pump
0x01290002 2 Fuel-circuit changeover
0x01290003 3 Leakage diagnosis pump
0x01290004 4 Oxygen-sensor heater after cat. comverter cylinder 5-8
0x01290005 5 Oxygen-sensor heater before cat. converter cylinder 5-8
0x01290006 6 CAN instrumentation
0x01290008 8 Misfiring was caused by tank having been run dry
0x0129000A 10 Oxygen sensor before catalytic converter cylinder 1-4
0x0129000C 12 Oxygen sensor after catalytic converter cylinder 1-4
0x0129000D 13 Oxygen-sensor heater before cat. converter cylinder 1-4
0x0129000E 14 Oxygen-sensor heater after cat. conberter cylinder 1-4
0x0129000F 15 Oxygen-sensor ageing TP before cat. conv. cylinder 1-4
0x01290010 16 Oxygen-sensor ageing TV before cat. conv. cylinder 1-4
0x01290011 17 Oxygen-sensor ageing after cat. converter cylinder 1-4
0x01290012 18 Oxygen-sensor ageing before cat. conv. cyl. 5-8
0x01290014 20 Oxygen sensor after catalytic converter cylinder 5-8
0x01290015 21 Oxygen sensor ageing TP before cat. conv. cylinder 5-8
0x01290016 22 Oxygen sensor ageing TV before cat. conv. cylinder 5-8
0x01290017 23 Oxygen sensor ageing after cat. converter cylinder 5-8
0x01290018 24 Diagnosis of function air conditioner compressor
0x0129001A 26 Multiplicative mixture adapt'n (Part load) cylinder 1-4, control limit reached
0x0129001B 27 Additive mixture adaptation (idle) cylinder 1-4, control limit reached
0x0129001C 28 Additive mixture adaptation (idle) cylinder 1-4, control limit reached
0x01290020 32 Idle speed actuator blocked
0x01290022 34 Multiplicative mixture adapt'n (part load) cylinder 5-8, control limit reached
0x01290023 35 Additive mixture adaptation (idle) cylinder 5-8, control limit reached
0x01290024 36 Additive mixture adaptation (idle) cylinder 5-8, control limit reached
0x01290027 39 Electronic car immobilisation system (EWS)
0x01290028 40 Cat. -converter conversion, cylinder 1-4
0x0129002D 45 Cat. -converter conversion, cylinder 5-8
0x01290032 50 Misfire, cyl. 1
0x01290033 51 Misfire, cyl. 2
0x01290034 52 Misfire, cyl. 3
0x01290035 53 Misfire, cyl. 4
0x01290036 54 Misfire, cyl. 5
0x01290037 55 Misfire, cyl. 6
0x01290038 56 Misfire, cyl. 7
0x01290039 57 Misfire, cyl. 8
0x0129003E 62 Misfiring, sum, relevant to exhaust gas
0x0129003F 63 Misfiring with cylinder cutout, cyl. 1
0x01290040 64 Misfiring with cylinder cutout, cyl. 2
0x01290041 65 Misfiring with cylinder cutout, cyl. 3
0x01290042 66 Misfiring with cylinder cutout, cyl. 4
0x01290043 67 Misfiring with cylinder cutout, cyl. 5
0x01290044 68 Misfiring with cylinder cutout, cyl. 6
0x01290045 69 Misfiring with cylinder cutout, cyl. 7
0x01290046 70 Misfiring with cylinder cutout, cyl. 8
0x0129004B 75 Misfiring with cylinder cutout, total
0x0129004E 78 Speed-sensor signal
0x0129004F 79 Secondary-air pump, stage 2 (output stage)
0x01290050 80 Secondary-air system
0x01290054 84 Secondary-air pump (output stage)
0x01290055 85 Secondary-air valve (output stage)
0x0129005B 91 Tank-ventilation valve,output stage, bank 2
0x0129005D 93 Tank-ventilation system
0x01290061 97 Tank-leak detection: minor leak
0x01290062 98 Tank-ventilation-valve output stage
0x01290065 101 Control module defective (internal RAM)
0x01290066 102 Control module faulty (external RAM)
0x01290067 103 Control module defective (ROM)
0x01290068 104 Wrong values in fault memory
0x0129006B 107 Terminal 15 power supply
0x0129006C 108 Continuous voltage (+)
0x0129006F 111 Crankshaft position sensor
0x01290070 112 Camshaft position sensor
0x01290073 115 Hot film mass air flow sensor
0x01290075 117 Throttle-valve potentiometer
0x01290078 120 Road speed
0x01290079 121 Load measurement
0x0129007B 123 Engine-temperature sensor (coolant)
0x0129007C 124 Intake-air temperature sensor
0x01290082 130 Oxygen sensors before catalytic converter inverted
0x01290086 134 Tank fill level
0x01290087 135 Engine intervention /specified engine torque (gearbox intervention)
0x0129008A 138 Compressor intervention
0x0129008B 139 Activation, map cooling
0x0129008C 140 Engine torque, bank comparison
0x0129008D 141 Dynamic stability control (SDC) intervention with fadeout
0x0129008F 143 Engine drag-torque control (MSR) intervention
0x01290090 144 Automatic stability control ASC intervention
0x01290093 147 Function, map cooling
0x01290094 148 Interface, electronic engine immobilizer
0x01290095 149 Inlet-camshaft setting, bnak 2
0x01290096 150 Fuel injector, cyl. 1
0x01290097 151 Fuel injector, cyl. 2
0x01290098 152 Fuel injector, cyl. 3
0x01290099 153 Fuel injector, cyl. 4
0x0129009A 154 Fuel injector, cyl. 5
0x0129009B 155 Fuel injector, cyl. 6
0x0129009C 156 Fuel injector, cyl. 7
0x0129009D 157 Fuel injector, cyl. 8
0x012900A3 163 Electric-fuel-pump relay
0x012900A5 165 Exhaust-gas warning lamp ("CHECK ENGINE" lamp is fitted in US vehicles only)
0x012900A7 167 Electric-fuel-pump relay output stage
0x012900A8 168 Idle speed actuator for opening coil
0x012900A9 169 Idle speed actuator for closing coil
0x012900AA 170 A/C-compressor control
0x012900AE 174 Camshaft control, bank 1
0x012900B2 178 Camshaft control, bnak 2
0x012900B3 179 A/C-compressor control, bank 2
0x012900BC 188 Exhaust-gas warning lamp, bank 2 ("CHECK ENGINE" lamp is fitted is UD vehicles only)
0x012900BD 189 Inlet-camshaft setting, bnak 1
0x012900CB 203 Ignition-circuit monitoring
0x012900CC 204 EWS random-code storage
0x012900D0 208 Secondary-air system
0x012900D2 210 Knock sensor 1
0x012900D3 211 Knock sensor 2
0x012900D4 212 Knock sensor 3
0x012900D5 213 Knock sensor 4
0x012900D6 214 Controller Area Network (CAN) interface, version No.
0x012900D7 215 Controller Area Network (CAN) interface, Digital Motor Electronics (DME) timeout
0x012900D8 216 Controller Area Network (CAN) interface, Dynamic Stability Control (DSC) timeout
0x012900D9 217 Controller Area Network (CAN) interface, Electronic engine-power control (EML) timeout
0x012900DC 220 Knock control
0x012900DE 222 Knock-control test pulse
0x012900E4 228 Automatic excess-fuel starting device output stage, bank 2
0x012900E9 233 Automatic excess-fuel starting device output stage
0x012900EA 234 Starting signal
0x012900EC 236 Controller Area Notwork (CAN) interface, Electronic gearbox control (EGS) timeout
0x012900ED 237 Automatic excess fuel starting device
//*DME M5.2.1 M73*/
0x012A0001 1 Activation, solenoid valve, leakage diagnosis pump
0x012A0002 2 Activation, solenoid valve, fuel system changeover
0x012A0003 3 Function, tank leakage diagnosis pump
0x012A0004 4 Oxygen-sensor heater after catalytic converter, bank 2
0x012A0005 5 Oxygen-sensor heater before catalytic converter, bank 2
0x012A0006 6 CAN instrument cluster
0x012A0008 8 Misfiring was caused by tank having been run dry
0x012A000A 10 Signal, oxygen sensor before cat., bank 1
0x012A000C 12 Signal, oxygen sensor after cat. conv., bank 1
0x012A000D 13 oxygen-sensor heater before catalytic converter, bank 1
0x012A000E 14 oxygen-sensor heater after catalytic converter, bank 1
0x012A000F 15 Oxygen-sensor ageing TP before catalytic converter, bnak 1
0x012A0010 16 Oxygen-sensor ageing TV before catalytic converter, bnak 1
0x012A0011 17 Oxygen-sensor ageing after catalytic converter, bnak 1
0x012A0012 18 Oxygen-sensor ageing before catalytic xonverter, bank 2
0x012A0014 20 Oxygen sensor after catalytic converter, bank 2
0x012A0015 21 Oxygen-sensor ageing TP before catalytic converter, bank 2
0x012A0016 22 Oxygen-sensor ageing TP before catalytic converter, bank 2
0x012A0017 23 Oxygen-sensor ageing after catalytic converter, bank 2
0x012A0018 24 Function, diagnosis, A/C compressor
0x012A001A 26 Multiplicative mixture adaptation
0x012A001B 27 Additive mixture adaptation (idle), bank 1, control limit reached
0x012A001C 28 Additive mixture afaptation (idle), bnak 1, control limit reached
0x012A001D 29 Activation, switching valve for aircontained fuel injectors, bank 1
0x012A0020 32 Function, idle-speed control
0x012A0022 34 Multiplicative mixture adaptation
0x012A0023 35 Additive mixture adaptation (idle), bank 2, control limit reached
0x012A0024 36 Additive mixture adaptation (idle), bank 2, control limit reached
0x012A0027 39 EWS 3.3 tampering protection
0x012A0028 40 Catalytic-converter conversion, bank 1
0x012A002D 45 Catalytic-converter conversion, bank 2
0x012A0032 50 Misfire detection, cyl. 1
0x012A0033 51 Misfire detection, cyl. 2
0x012A0034 52 Misfire detection, cyl. 3
0x012A0035 53 Misfire detection, cyl. 4
0x012A0036 54 Misfire detection, cyl. 5
0x012A0037 55 Misfire detection, cyl. 6
0x012A0038 56 Misfire detection, cyl. 7
0x012A0039 57 Misfire detection, cyl. 8
0x012A003A 58 Misfire detection, cyl. 9
0x012A003B 59 Misfire detection, cyl. 10
0x012A003C 60 Misfire detection, cyl. 11
0x012A003D 61 Misfire detection, cyl. 12
0x012A003E 62 Misfiring at several cylinders
0x012A003F 63 Misfiring with cylinder cutout, cyl. 1
0x012A0040 64 Misfiring with cylinder cutout, cyl. 2
0x012A0041 65 Misfiring with cylinder cutout, cyl. 3
0x012A0042 66 Misfiring with cylinder cutout, cyl. 4
0x012A0043 67 Misfiring with cylinder cutout, cyl. 5
0x012A0044 68 Misfiring with cylinder cutout, cyl. 6
0x012A0045 69 Misfiring with cylinder cutout, cyl. 7
0x012A0046 70 Misfiring with cylinder cutout, cyl. 8
0x012A0047 71 Misfiring with cylinder cutout, cyl. 9
0x012A0048 72 Misfiring with cylinder cutout, cyl. 10
0x012A0049 73 Misfiring with cylinder cutout, cyl. 11
0x012A004A 74 Misfiring with cylinder cutout, cyl. 12
0x012A004B 75 Misfiring with cylinder cutout, total
0x012A004D 77 Activation, air containment, fuel injectors, bank 1
0x012A004E 78 Signal, crankshaft speed sensor
0x012A0050 80 Function, secondary-air system
0x012A0054 84 Activative, relay, secondary-air pump
0x012A0055 85 Activation, relay, secondary-air pump
0x012A005B 91 Activation, tank-venting valve, bank 2
0x012A005D 93 Function, tank-venting system
0x012A0061 97 Tank-venting system, minor leak
0x012A0062 98 Activation, tank-venting valve, bank 1
0x012A0065 101 Control module faulty (internal RAM)
0x012A0066 102 Control module faulty (external RAM)
0x012A0067 103 Control module faulty (ROM)
0x012A0068 104 Wrong values in fault memory
0x012A006B 107 Voltage supply (via DME main relay)
0x012A006C 108 Open circuit, continuous
0x012A006F 111 Signal, crankshaft position sensor
0x012A0070 112 Signal, camshaft position sensor
0x012A0073 115 Signal, bot-film air-mass flow sensor
0x012A0075 117 Signal, throttle potentiometer
0x012A0078 120 Signal, vehicle speed
0x012A0079 121 Load measurement
0x012A007B 123 Signal, temperature sensor, engine coolant
0x012A007C 124 Signal, tempersture sensor, intake air
0x012A0082 130 Oxygen sensors before catalytic converter connected in incorrect sequence
0x012A0086 134 Switch, tank fill level
0x012A0087 135 Engine intervention/specified engine torque (gearbox intervention)
0x012A008A 138 Compressor intervention
0x012A008B 139 Activation, map cooling
0x012A008C 140 Engine torque, bank comparison
0x012A008D 141 Dynamic Stability Control DSC intervention with fadeout
0x012A008F 143 Function, ASC/DSC MSR - engine intervention
0x012A0090 144 Automatic Stability Control ASC - intervention
0x012A0093 147 Function, map cooling
0x012A0094 148 EWS 3.3 interface DME-EWS
0x012A0096 150 Activation, fuel injector, cyl. 1
0x012A0097 151 Activation, fuel injector, cyl. 2
0x012A0098 152 Activation, fuel injector, cyl. 3
0x012A0099 153 Activation, fuel injector, cyl. 4
0x012A009A 154 Activation, fuel injector, cyl. 5
0x012A009B 155 Activation, fuel injector, cyl. 6
0x012A009C 156 Activation, fuel injector, cyl. 7
0x012A009D 157 Activation, fuel injector, cyl. 8
0x012A009E 158 Activation, fuel injector, cyl. 9
0x012A009F 159 Activation, fuel injector, cyl. 10
0x012A00A0 160 Activation, fuel injector, cyl. 11
0x012A00A1 161 Activation, fuel injector, cyl. 12
0x012A00A3 163 Activation, electric fuel pump, EKP relay
0x012A00A7 167 Activation, electric fuel pump, EKP relay
0x012A00A8 168 Activation, idle-speed control valve, opening coil
0x012A00A9 169 Activation, idle-speed control valve, closing coil
0x012A00AA 170 A/C-compressor control
0x012A00AE 179 A/C-compressor control, bank 2
0x012A00B7 183 Tank-leak detection
0x012A00B8 184 Tank-venting system, blocked line
0x012A00BE 190 Ignition-circuit monitoring, cylinder 1
0x012A00BF 191 Ignition-circuit monitoring, cylinder 2
0x012A00C0 192 Ignition-circuit monitoring, cylinder 3
0x012A00C1 193 Ignition-circuit monitoring, cylinder 4
0x012A00C2 194 Ignition-circuit monitoring, cylinder 5
0x012A00C3 195 Ignition-circuit monitoring, cylinder 6
0x012A00C4 196 Ignition-circuit monitoring, cylinder 7
0x012A00C5 197 Ignition-circuit monitoring, cylinder 8
0x012A00C6 198 Ignition-circuit monitoring, cylinder 9
0x012A00C7 199 Ignition-circuit monitoring, cylinder 10
0x012A00C8 200 Ignition-circuit monitoring, cylinder 11
0x012A00C9 201 Ignition-circuit monitoring, cylinder 12
0x012A00CB 203 Ignition-circuit monitoring, bank 1
0x012A00CC 204 EWS 3.3 random-code storage
0x012A00D2 210 Signal, knock sensor 1
0x012A00D3 211 Signal, knock sensor 2
0x012A00D4 212 Knock sensor 3
0x012A00D5 213 Knock sensor 4
0x012A00D6 214 Control modules with different CAN versions at CAN bus
0x012A00D7 215 CAN timeout, Digital Motor Electronics (DME)
0x012A00D8 216 CAN timeout ASC/DSC
0x012A00D9 217 CAN timeout, electronic engine-power control EML
0x012A00DC 220 Knock control
0x012A00DE 222 Knock-control test pulse
0x012A00E4 228 Automatic, fuel injector, activation, bank 2
0x012A00E9 233 Activation, automatic starting devive
0x012A00EA 234 Start signal, ignition-lock position 3
0x012A00EC 236 CAN timeout, electronic transmission management (EGA/AGS)
0x012A00ED 237 Function, automatic starting device
0x012A00FA 250 Function,air-contained fuel injectors
//*DME M3.3 M60*/
0x012B0001 1 Relay for electric fuel pump
0x012B0002 2 Idle-actuator closing winding
0x012B0003 3 Fuel injector, cylinder 1
0x012B0004 4 Fuel injector, cylinder 4
0x012B0005 5 Fuel injector, cylinder 6
0x012B0006 6 Fuel-injector output stage without cylinder association
0x012B0007 7 Fuel injector, cylinder 7
0x012B0008 8 Fault lamp (US Only)
0x012B000C 12 Oxygen sensor 2
0x012B000D 13 Oxygen sensor 1
0x012B000F 15 Ignition-circuit monitoring
0x012B0010 16 Pusle generator for crankshaft
0x012B0011 17 Camshaft sensor
0x012B0016 22 Ignition, cylinder 7
0x012B0017 23 Ignition, cylinder 6
0x012B0018 24 Ignition, cylinder 4
0x012B0019 25 Ignition, cylinder 1
0x012B001A 26 Control-unit power supply B+
0x012B001D 29 Idle-actuator opening winding
0x012B001F 31 Fuel injector, cylinder 5
0x012B0020 32 Fuel injector, cylinder 8
0x012B0021 33 Fuel injector, cylinder 3
0x012B0023 35 Fuel injector, cylinder 2
0x012B0024 36 Tank ventilation
0x012B0025 37 Oxygen-sensor heater
0x012B0029 41 Air-mass flow sensor (hot-film)
0x012B002A 42 Speed sensor
0x012B0030 48 A/C-compressor cutoff
0x012B0031 49 Ignition, cylinder 2
0x012B0032 50 Ignition, cylinder 3
0x012B0033 51 Ignition, cylinder 8
0x012B0034 52 Ignition, cylinder 5
0x012B0036 54 Control-unit power supply via main relay
0x012B003E 62 Electronic engine-power-control signal (EML)
0x012B0042 66 Signal, burglar alarm system (DWA/EWS)
0x012B0043 67 Knock sensor 4
0x012B0044 68 Knock sensor 3
0x012B0045 69 Knock sensor 2
0x012B0046 70 Knock sensor 1
0x012B0049 73 Throttle-valve potentiometer
0x012B004D 77 Intake-air temperature sensor
0x012B004E 78 Engine-temperature sensor (coolant)
0x012B0052 82 Intervention, engine drag-torque control (MSR)
0x012B0053 83 Intervention, Automatic Stability Control
0x012B0064 100 Output stage, group 1
0x012B0065 101 Output stage, group 2
0x012B00C8 333 DME Control unit
0x012B00C9 201 Oxygen-sensor control 1
0x012B00CA 202 Fault memory
0x012B00CB 203 Oxygen-sensor control 2
0x012B00CC 204 Idle-speed increase during engine-dragtorque control
0x012B00CD 205 Gearbox intervention during gearshifts (with EGS only)
0x012B00CE 206 Knock-contorl test pulse
0x012B00D2 210 CAN interface, gearbox intervention
0x012B00DC 220 EWS code
//*DDE 3.0 M47*/
0x012F0001 01 Delivery controller
0x012F0003 03 Electric shut-off valve
0x012F0005 05 Needle-motion sensor
0x012F0006 06 Exhaust-gas recirculation
0x012F0008 08 Glow-plug system
0x012F000A 0A Control, start of injection
0x012F0010 10 Power supply
0x012F0011 11 DDE control unit
0x012F0012 12 Terminal 15
0x012F0013 13 DDE main relay
0x012F001A 1A Brake-light switch/brake-test switch
0x012F001B 1B Electric auxiliary heater
0x012F001C 1C Clutch switch
0x012F001D 1D Roadspeed signal
0x012F0020 20 Control element, cruise control
0x012F0023 23 Fuel temperature sensor
0x012F0024 24 Engine-oil temperature sensor
0x012F0025 25 Pedal-travel sensor
0x012F0026 26 Air-mass flow sensor
0x012F002d 2D Electronic car immobilization system
0x012F002E 2E Speed sensor, injection pump
0x012F002F 2F Speed sensor, crankshaft
0x012F0034 34 intake-air temperature sensor
0x012F0035 35 Coolant temperature sensor
0x012F0036 36 Charge-air-pressure sensor
0x012F0040 40 DDE control module (microcontroller)
0x012F0041 41 injection pump, solenoid shutoff valve
0x012F0042 42 DDE control module (EEPROM and configuration)
0x012F0043 43 Control module, injection pump
0x012F0044 44 Solenoid valve, injection rate
0x012F0045 45 Control unit DDE (CAN controller)
0x012F0046 46 Control unit, injection pump (communication)
0x012F0047 47 Synchronicity of speed sensors
0x012F0048 48 Control, timing device
0x012F0049 49 Speed sensor, injection pump
0x012F0050 50 Engine mount control
0x012F0052 52 Electric fan
0x012F0056 56 Radiator blind
0x012F0065 65 Charge-air-pressure control
0x012F006B 6B Atmospheric-pressure sensor
0x012F0072 72 CAN Bus
0x012F0073 73 Fuel pre-supply pump
0x012F0074 74 Activation, A/C compressor
0x012F0075 75 Alternator load signal
0x012F0077 77 Ambient temperature
//*MSS52 S62*/
0x01310001 001 Driver/fuel-pump relay
0x01310002 002 Idle-speed control valve, closing winding
0x01310003 003 Fuel injector cylinder 1
0x01310004 004 Fuel injector cylinder 3
0x01310005 005 Fuel injector cylinder 2
0x01310007 007 Signal, camshaft sensor, inlet, bank 1
0x01310008 008 Signal, camshaft sensor, inlet, bank 2
0x01310009 009 Signal, knock sensor, cylinder 1-2
0x0131000A 010 Signal, camshaft sensor, exhaust, bank 1
0x0131000B 011 Signal, camshaft sensor, exhaust, bank 2
0x0131000C 012 Signal, oxygen sensor before cat. conv., bank 2
0x0131000D 013 Signal, oxygen sensor before cat. conv., bank 1
0x0131000E 014 Heating, DMTL module
0x0131000F 015 Camshaft sensor, bank 1: synchronization to crankshaft
0x01310010 016 Signal, crankshaft sensor
0x01310013 019 Relay, secondary air pump
0x01310014 020 Starter relay
0x01310015 021 Exhaust VANOS, bank 1, retard valve
0x01310016 022 Exhaust VANOS, bank 1, Advance valve
0x01310017 023 Ignition coil, cylinder 2
0x01310018 024 Ignition coil, cylinder 3
0x01310019 025 Ignition coil, cylinder 1
0x0131001A 026 Ignition coil, cylinder 8
0x0131001B 027 DMTL changeover valve
0x0131001D 029 Idle-speed control valve, NC winding
0x0131001E 030 Internal DME fault
0x0131001F 031 Fuel injector cylinder 5
0x01310020 032 Fuel injector cylinder 6
0x01310021 033 Fuel injector cylinder 4
0x01310022 034 Fuel injector cylinder 7
0x01310023 035 Fuel injector cylinder 8
0x01310024 036 Tank-venting valve
0x01310025 037 Oxygen-sensor heater before cat. conv., bank 1
0x01310026 038 Oxygen-sensor heater before cat. conv., bank 2
0x01310027 039 Oxygen-sensor heater behind cat. conv., bank 1
0x01310028 040 Oxygen-sensor heater behind cat. conv., bank 2
0x01310029 041 Signal, air-mass flow sensor, right
0x0131002A 042 Roadspeed signal, pin 4-22
0x0131002B 043 Signal, temperature sensor, radiater outlet
0x0131002C 044 Signal, thermal oil-level, sensor
0x0131002D 045 Electric throttle-servomotor
0x0131002F 047 Output, engine-speed signal TD
0x01310030 048 Internal, A/C control module
0x01310031 049 Internal index 95
0x01310032 050 Ignition coil, cylinder 4
0x01310033 051 Ignition coil, cylinder 6
0x01310034 052 Ignition coil, cylinder 5
0x01310035 053 Interface, electric fan
0x01310036 054 System voltages, main relay
0x01310037 055 Ignition coil, cylinder 7
0x01310039 057 Signal, air-mass flow sensor left
0x0131003A 058 Voltage supply, sensors
0x0131003B 059 Voltage supply, sensors
0x0131003C 060 Signal, pedal-position sensor 1
0x0131003D 061 Signal, pedal-position sensor 2
0x0131003F 063 Secondary-air valve
0x01310041 065 Signal,potentiometer, throttle and electric throttle actuator
0x01310042 066 EWS 3.3 interface: no DME-EWS communication
0x01310043 067 Inlet VANOS, bank 1, advance valve
0x01310045 069 Signal, knock sensor, cylinder 3-4
0x01310046 070 Signal, knock sensor, cylinder 7-8
0x01310047 071 Signal, knock sensor, cylinder 5-6
0x01310048 072 Inlet VANOS, bank 1, retard valve
0x01310049 073 Signal, air-mass flow sensor, implausible
0x0131004A 074 Inlet VANOS, bank 2, advance valve
0x0131004B 075 Inlet VANOS, bank 2, retard valve
0x0131004C 076 Ambient-pressure sensor (DME internal)
0x0131004D 077 Signal, intake-air temperature sensor
0x0131004E 078 Signal, coolant temperature sensor
0x0131004F 079 Singal, exhaust-gass temperature sensor
0x01310050 080 Switch chain, frictional connection
0x01310051 081 Interface, multifunction steering wheel(E39)/steering-column lever(E52)
0x01310053 083 Exhaust VANOS, bank 2, advance valve
0x01310054 084 Exhaust VANOS, bank 2, retard valve
0x01310055 085 Signal, throttle potentiometer
0x01310056 086 No CAN-bus signal to DME
0x01310057 087 Signal, oxygen-sensor after cat. conv., bank 1
0x01310058 088 Signal, oxygen-sensor after cat. conv., bank 2
0x01310059 089 Internal DME fault
0x0131005C 092 Oxygen sensor after cat. conv., bank 1: voltage monitoring
0x0131005D 093 Oxygen sensor after cat. conv., bank 2: voltage monitoring
0x01310063 099 Internal DME fault
0x01310064 100 Signal tire pressure, front left
0x01310065 101 Signal tire pressure, front right
0x01310066 102 Signal tire pressure, rear right
0x01310067 103 Signal tire pressure, rear left
0x01310069 105 Signal, engine temperautre, implausible
0x0131006A 106 Signal, brake-light switch
0x0131006B 107 Electric throttle: self-test
0x0131006C 108 Activation, oil-circuit changeover valve, left
0x0131006D 109 Activation, oil-circuit changeover valve, right
0x0131006E 110 Function light, switch,vehicle dynamics
0x0131006F 111 Pedal-position sensor, comparison fault
0x01310070 112 Pedal-position sensor, comparison fault
0x01310071 113 Function, inlet VANOS, bank 2
0x01310072 114 Function, exhaust VANOS, bank 2
0x01310073 115 Sensor,control module temperature (DME internal) or button, tire pressure control system
0x01310074 116 Valve, servotronic
0x01310075 117 Servotronic: no roadspeed signal
0x01310076 118 Electric throttle: signal, potentiometer, bank 1
0x01310077 119 Electric throttle: signal, potentiometer, bank 2
0x01310078 120 Electric throttle: potentiometer, signal comparison
0x01310079 121 Electric throttle: both potentiomters faulty
0x0131007A 122 DME-internal processor check
0x0131007D 125 Thermal oil-level sensor: function lamp
0x0131007E 126 Crash deactivation, electric fuel pump
0x0131007F 127 DMTL module, tank-leakage diagnosis
0x01310080 128 Deviation, idle speed
0x01310081 129 Cat. protection function as result of empty tank or lack of fuel
0x01310082 130 EWS 3.3 auti-tampering protection
0x01310083 131 DSC intervention implausible
0x01310084 132 CAN timeout, DSC
0x01310085 133 CAN timeout, Steering-angla sensor
0x01310086 134 CAN timeout, instrumeat cluster
0x01310087 135 NO roadspeed signal
0x01310088 136 Function, idle-speed control
0x0131008B 139 Interruption, Tempormat operation
0x0131008C 140 Knock control deactivated/knock prtrction
0x0131008D 141 Tank fill level implausible
0x0131008F 143 Electronics-box fan
0x01310090 144 Function, oxygen-sensor control, bank 1
0x01310091 145 Function, oxygen-sensor control, bank 2
0x01310095 149 Fault with empty tank
0x01310096 150 DME memory fault
0x01310097 151 Internal DME fault
0x0131009B 155 Saving adaptation values not possible
0x0131009C 156 Saving adaptation values not possible
0x0131009D 157 DME memory fault
0x0131009E 158 Reset DME possibly as result of over speed
0x0131009F 159 Internal DME fault: knock control
0x013100A0 160 Internal DME fault: knlck control
0x013100A1 161 Internal DME fault: knlck control
0x013100A2 162 Camshaft sensor, bank 2: synchronization to crankshaft
0x013100A3 163 Reset DME possibly as result of over speed
0x013100AA 170 Secondary-air quantity too low
0x013100AB 171 Function, secondary-air valve: jammed
0x013100AC 172 VANOS admission-pressure pump
0x013100AD 173 Continuous signal, tm. 50, starter switch
0x013100AE 174 Fuel-system diagnosis, bank 1
0x013100AF 175 Fuel-system diagnosis, bank 2
0x013100B0 176 Abort tank-leak diagnosis due to moisture
0x013100B2 178 Catalytic-converter conversion, bank 1
0x013100B3 179 Catalytic-converter conversion, bank 2
0x013100B4 180 Tank leakage detected
0x013100B5 181 Fuel filler cap open/missing
0x013100B6 182 Internal DME fault
0x013100B7 183 Internal DME fault
0x013100B8 184 Function, inlet VANOS, bank 1: control
0x013100B9 185 Function, exhaust VANOS, bank 1: control
0x013100C2 194 Electric throttle limp-home program from cruise-control mode
0x013100C3 195 Deviation, setpoint torque from actual torque
0x013100C4 196 Misfiring, cylinder 1 with cylinder cutout
0x013100C5 197 Misfiring, cylinder 2 with cylinder cutout
0x013100C6 198 Misfiring, cylinder 3 with cylinder cutout
0x013100C7 199 Misfiring, cylinder 4 with cylinder cutout
0x013100C8 200 Misfiring, cylinder 5 with cylinder cutout
0x013100C9 201 Misfiring, cylinder 6 with cylinder cutout
0x013100CA 202 Misfiring, cylinder 7 with cylinder cutout
0x013100CB 203 Misfiring, cylinder 8 with cylinder cutout
0x013100CC 204 Misfiring, several cylinder with cylinder cutout
0x013100CD 195 Misfiring, cylinder 1 without cylinder cutout
0x013100CE 196 Misfiring, cylinder 2 without cylinder cutout
0x013100CF 197 Misfiring, cylinder 3 without cylinder cutout
0x013100D0 198 Misfiring, cylinder 4 without cylinder cutout
0x013100D1 209 Misfiring, cylinder 5 without cylinder cutout
0x013100D2 210 Misfiring, cylinder 6 without cylinder cutout
0x013100D3 211 Misfiring, cylinder 7 without cylinder cutout
0x013100D4 212 Misfiring, cylinder 8 without cylinder cutout
0x013100D5 213 Misfiring, several cylinder without cylinder cutout
0x013100D6 214 Oxygen sensor before cat. conv., bank 1: period duration
0x013100D7 215 Oxygen sensor before cat. conv., bank 2: period duration
0x013100D8 216 Oxygen sensor before cat. conv., bank 1: jump time
0x013100D9 217 Oxygen sensor before cat. conv., bank 2: jump time
0x013100DA 218 Oxygen sensor before cat. conv., bank 1: Signal excursion
0x013100DB 219 Oxygen sensor before cat. conv., bank 2: Signal excursion
0x013100DC 220 DME-internal processor check
0x013100E4 228 Electric throttle: limit violation
0x013100E6 230 Electic throttle: setpoint/actual value deviation
0x013100E7 231 DME-internal processor check
0x013100E8 232 Function check, tank-venting valve
0x013100F7 247 VANOS pressure-accumulator valve
//*DME 5.2.1 M62*/
0x01330000 0 Undefined code
0x01330001 1 Activation, leakage diagnosis pump LDP
0x01330002 2 Activation, solenoid valve,fuel system changeover
0x01330003 3 Function, tank leakage diagnosis pump
0x01330004 4 Oxygen-sensor heater after catalytic converter,bank 2
0x01330005 5 Oxygen-sensor heater before catalytic converter, bank 2
0x01330006 6 CAN instrument cluster
0x01330008 8 Misfiring was caused by tank having been run dry
0x0133000A 10 Signal, oxygen sensor before cat., bank 1
0x0133000C 12 Signal, oxygen sensor after cat. conv., bank 1
0x0133000D 13 Oxygen-sensor heater before catalytic converter, bank 1
0x0133000E 14 Oxygen-sensor heater after catalytic converter, bank 1
0x0133000F 15 Oxygen-sensor ageing TP before catalytic converter, bank 1
0x01330010 16 Oxygen-sensor ageing TV before catalytic converter, bank 1
0x01330011 17 Oxygen-sensor ageing after catalytic converter, bank 1
0x01330012 18 Oxygen sensor before catalytic converter, bank 2
0x01330014 20 Oxygen sensor after catalytic converter, bank 2
0x01330015 21 Oxygen-sensor ageing TP before catalytic converter, bnak 2
0x01330016 22 Oxygen-sensor ageing TV before catalytic converter, bank 2
0x01330017 23 Oxygen-sensor ageing after catalytic converter, bank 2
0x01330018 24 Function, diagnosis, A/C compressor
0x0133001A 26 Multipcative mixture adaption (part load), bank 1, control limit reached
0x0133001B 27 Additive mixture adaptation (idle), bank 1, control limit reached
0x0133001C 28 Additive mixture adaptation (idle), bank 1, control limit reached
0x0133001D 29 Activation, switching valve for aircontained fuel injectors,bank 1
0x01330020 32 Function, idle-speed control
0x01330022 34 Multiplicative mixture adaptation , bank 2, control limit reached
0x01330023 35 Additive mixture adaptation (idle), bank 2, control limit reached
0x01330024 36 Additive mixture adaptation (idle), bank 2, control limit reached
0x01330027 39 EWS 3.3 tampering portection
0x01330028 40 Catalytic-converter conversion, bank 1
0x0133002D 45 Catalytic-converter conversion, bank 2
0x01330032 50 Misfire detection, cyl. 1
0x01330033 51 Misfire detection, cyl. 2
0x01330034 52 Misfire detection, cyl. 3
0x01330035 53 Misfire detection, cyl. 4
0x01330036 54 Misfire detection, cyl. 5
0x01330037 55 Misfire detection, cyl. 6
0x01330038 56 Misfire detection, cyl. 7
0x01330039 57 Misfire detection, cyl. 8
0x0133003A 58 Misfire detection, cyl. 9
0x0133003B 59 Misfire detection, cyl. 10
0x0133003C 60 Misfire detection, cyl. 11
0x0133003D 61 Misfire detection, cyl. 12
0x0133003E 62 Misfiring at several cylinders
0x0133003F 63 Misfiring with cylinder cutout, cyl. 1
0x01330040 64 Misfiring with cylinder cutout, cyl. 2
0x01330041 65 Misfiring with cylinder cutout, cyl. 3
0x01330042 66 Misfiring with cylinder cutout, cyl. 4
0x01330043 67 Misfiring with cylinder cutout, cyl. 5
0x01330044 68 Misfiring with cylinder cutout, cyl. 6
0x01330045 69 Misfiring with cylinder cutout, cyl. 7
0x01330046 70 Misfiring with cylinder cutout, cyl. 8
0x01330047 71 Misfiring with cylinder cutout, cyl. 9
0x01330048 72 Misfiring with cylinder cutout, cyl. 10
0x01330049 73 Misfiring with cylinder cutout, cyl. 11
0x0133004A 74 Misfiring with cylinder cutout, cyl. 12
0x0133004B 75 Misfiring with cylinder cutout, total
0x0133004D 77 Activation, air contatinment£¬fuel injectors, bank 1
0x0133004E 78 Signal, crankshaft speed sensor
0x01330050 80 Function, secondary-air system
0x01330054 84 Activation£¬ relay, secondary-air pump
0x01330055 85 Activation, relay, secondary-air pump
0x0133005B 91 Activation, tank-venting valve, bank 2
0x0133005D 93 Function, tank-venting system
0x01330061 97 Tank-venting system, minor leak
0x01330062 98 Activation, tank-venting valve, bank 1
0x01330065 101 Control module faulty (internal RAM)
0x01330066 102 Control module faulty (external RAM)
0x01330067 103 Control module faulty (ROM)
0x01330068 104 Wrong values in fault memory
0x0133006B 107 Voltage supply (via DME main relay)
0x0133006C 108 Open circuit, continuous power supply
0x0133006F 111 Signal, crankshaft position sensor
0x01330070 112 Signal, camshaft position sensor
0x01330073 115 Signal, hot-film air-mass flow sensor
0x01330075 117 Signal, throttle potentiometer
0x01330078 120 Signal, vehicle speed
0x01330079 121 Load measurement
0x0133007B 123 Signal, temperature sensor, engine coolant
0x0133007C 124 Signal, temperature sensor, intake air
0x01330082 130 Oxygen sensors beore catalytic converter connected in incorrect sequence
0x01330086 134 Switch, tank fill level
0x01330087 135 Engine intervention / specified engine torque (gearbox intervention)
0x0133008A 138 Compressor intervention
0x0133008B 139 Activation, map cooling
0x0133008C 140 Engine torques, bank comparison
0x0133008D 141 Dynamic Stability Control DSC intervention with fadeout
0x0133008F 143 Function, ASC/DSC MSR - engine intervention
0x01330090 144 Automatic Stability Control ASC - intervention
0x01330093 147 Function, map cooling
0x01330094 148 EWS 3.3 interface DME-EWS
0x01330096 150 Activation, fuel injector, cyl. 1
0x01330097 151 Activation, fuel injector, cyl. 2
0x01330098 152 Activation, fuel injector, cyl. 3
0x01330099 153 Activation, fuel injector, cyl. 4
0x0133009A 154 Activation, fuel injector, cyl. 5
0x0133009B 155 Activation, fuel injector, cyl. 6
0x0133009C 156 Activation, fuel injector, cyl. 7
0x0133009D 157 Activation, fuel injector, cyl. 8
0x0133009E 158 Activation, fuel injector, cyl. 9
0x0133009F 159 Activation, fuel injector, cyl. 10
0x013300A0 160 Activation, fuel injector, cyl. 11
0x013300A1 161 Activation, fuel injector, cyl. 12
0x013300A3 163 Activation, electric fuel pump, EKP relay
0x013300A7 167 Activation, electric fuel pump, EKP relay
0x013300A8 168 Activation, idle-speed control valve, opening coil
0x013300A9 169 Activation, idel-speed control valve, closing coil
0x013300AA 170 A/C-compressor control
0x013300AE 179 A/C-compressor control, bank 2
0x013300B7 183 Tank-leak detection
0x013300B8 184 Tank-venting system, blocked line
0x013300BE 190 Ignition-circuit monitoring, cylinder 1
0x013300BF 191 Ignition-circuit monitoring, cylinder 2
0x013300C0 192 Ignition-circuit monitoring, cylinder 3
0x013300C1 193 Ignition-circuit monitoring, cylinder 4
0x013300C2 194 Ignition-circuit monitoring, cylinder 5
0x013300C3 195 Ignition-circuit monitoring, cylinder 6
0x013300C4 196 Ignition-circuit monitoring, cylinder 7
0x013300C5 197 Ignition-circuit monitoring, cylinder 8
0x013300C6 198 Ignition-circuit monitoring, cylinder 9
0x013300C7 199 Ignition-circuit monitoring, cylinder 6
0x013300C8 200 Ignition-circuit monitoring, cylinder 11
0x013300C9 201 Ignition-circuit monitoring, cylinder 12
0x013300CB 203 Ignition-circuit monitoring, bank 1
0x013300CC 204 EWS 3.3 random-code storge
0x013300D2 210 Siganl, knock sensor 1
0x013300D3 211 Siganl, knock sensor 2
0x013300D4 212 Knock sensor 3
0x013300D5 213 Knock sensor 4
0x013300D6 214 Control modules with different CAN versions at CAN bus
0x013300D7 215 CAN timeout, Digital Motor Electronics (DME)
0x013300D8 216 CAN timeout ASC/DSC
0x013300D9 217 CAN timeout, electronic engine-power control (EML)
0x013300DC 220 Knock control
0x013300DE 222 Knock-control test pulse
0x013300E4 228 Automatic starting, activation, bank 2
0x013300E9 233 Activation, automatic starting device
0x013300EA 234 Start signal, ignition-lock position 3
0x013300EC 236 CAN timeout, electronic transimission management (EGS/AGS)
0x013300ED 237 Function,automatic starting device
0x013300FA 250 Function, air-contained fuel injectors
//*DME 5.2.1 M73TU*/
0x01340001 1 Activation, leakage diagnosis pump LDP
0x01340002 2 Activation, Solenoid valve, fuel system changeover
0x01340003 3 Function, tank leakage diagnosis pump
0x01340006 6 CAN instrument cluster
0x01340007 7 Temperature sensor, coolant outlet
0x01340008 8 Misfiring was caused by tank having been run dry
0x0134000A 10 Signal, oxygen sensor before cat. conv., bank 1
0x0134000B 12 Signal, oxygen sensor after cat. conv., bank 1
0x0134000D 13 Oxygen-sensor heater before catalytic converter, bank 1
0x0134000E 14 Oxygen-sensor heater after catalytic converter, bank 1
0x0134000F 15 Oxygen-sensor ageing TP before catalytic converter, bank 1
0x01340010 16 Oxygen-sensor ageing TV before catalytic converter, bank 1
0x01340011 17 Oxygen-sensor ageing after catalytic converter, bank 1
0x01340013 19 CAN timout ECAT
0x01340017 23 Oxygen-sensor ageing after catalytic converter, bank 2
0x0134001A 26 Multiplicative mixture adaptation (part load), bank 1, control limit reached
0x0134001B 27 Additive mixture adaptation (idle), bank 1, control limit reached
0x0134001C 28 Additive mixture adaptation (idle), bank 1, control limit reached
0x0134001D 29 Activation, switching valve for air-contained fuel injectors, bank 1
0x0134001E 30 Abort heating ECAT
0x01340020 32 Function, idle-speed control
0x01340021 33 Control unit, electr. heated cat. converter
0x01340027 39 EWS 3.3 tampering protection
0x01340028 40 Catalytic-converter conversion, bank 1
0x0134002A 42 Abort heating ECAT 1
0x0134002B 43 Abort heating ECAT 1
0x0134002C 44 Control module ECAT, circuit-breaker 1
0x0134002E 46 Abort heating ECAT 2
0x0134002F 47 Abort heating ECAT 2
0x01340030 48 Control module ECAT, circuit-breaker 2
0x01340032 50 Misfire detection, cyl. 1
0x01340033 51 Misfire detection, cyl. 2
0x01340034 52 Misfire detection, cyl. 3
0x01340035 53 Misfire detection, cyl. 4
0x01340036 54 Misfire detection, cyl. 5
0x01340037 55 Misfire detection, cyl. 6
0x01340038 56 Misfire detection, cyl. 7
0x01340039 57 Misfire detection, cyl. 8
0x0134003A 58 Misfire detection, cyl. 9
0x0134003B 59 Misfire detection, cyl. 10
0x0134003C 60 Misfire detection, cyl. 11
0x0134003D 61 Misfire detection, cyl. 12
0x0134003E 62 Misfiring at several cylinders
0x0134003F 63 Misfiring with cylinder cutout, cyl. 1
0x01340040 64 Misfiring with cylinder cutout, cyl. 2
0x01340041 65 Misfiring with cylinder cutout, cyl. 3
0x01340042 66 Misfiring with cylinder cutout, cyl. 4
0x01340043 67 Misfiring with cylinder cutout, cyl. 5
0x01340044 68 Misfiring with cylinder cutout, cyl. 6
0x01340045 69 Misfiring with cylinder cutout, cyl. 7
0x01340046 70 Misfiring with cylinder cutout, cyl. 8
0x01340047 71 Misfiring with cylinder cutout, cyl. 9
0x01340048 72 Misfiring with cylinder cutout, cyl. 10
0x01340049 73 Misfiring with cylinder cutout, cyl. 11
0x0134004A 74 Misfiring with cylinder cutout, cyl. 12
0x0134004B 75 Misfiring with cylinder cutout, tatal
0x0134004D 77 Activation, air containment, fuel injectors, bank 1
0x0134004E 78 Signal, crankshaft speed sensor
0x01340050 80 Function, secondary-air system
0x01340051 81 Temperature sensor 1, battery
0x01340052 82 Temperature sensor 2, battery
0x01340053 83 Temperature sensor, battery, not plausible
0x01340054 84 Activation, relay, secondary-air pump
0x01340055 85 Activation, relay, secondary-air pump
0x0134005B 91 Activation, tank-venting valve, bank 2
0x0134005D 93 Function, tank-venting system
0x01340062 98 Activation, tank-venting valve, bank 1
0x01340065 101 Control module faulty (internal RAM)
0x01340066 102 Control module faulty (external RAM)
0x01340067 103 Control module faulty (ROM)
0x01340068 104 Wrong values in fault memory
0x0134006B 107 Voltage supply (via DME main relay)
0x0134006C 108 Open circuit, continuous power supply
0x0134006F 111 Signal, crankshaft position sensor
0x01340070 112 Signal, camshaft position sensor
0x01340073 115 Signal, hot-film air-mass flow sensor
0x01340078 120 Signal, vehicle speed
0x01340079 121 Load measurement
0x0134007B 123 Signal, temperature sensor, engine coolant
0x0134007C 124 Signal, temperature sensor, intake air
0x01340082 130 Oxygen sensors before catalytic converter connected in incorrect sequence
0x01340086 134 Switch, tank fill level
0x01340087 135 Engine intervention / specified engine torque (gearbox intervention)
0x0134008A 138 Compressor intervention
0x0134008B 139 Activation, map cooling
0x0134008C 140 Engine torque, bank comparission
0x0134008D 141 Dynamix Stability Control DSC intervention with fadeout
0x0134008F 143 Function, ASC/DSC MSR - engine intervention
0x01340090 144 Automatic Stability Control ASC - intrvention
0x01340093 147 Function, map cooling
0x01340094 148 EWS 3.3 interface DME-EWS
0x01340095 149 Inlet-camshaft setting bank 2
0x01340096 150 Activation, fuel injector, cyl. 1
0x01340097 151 Activation, fuel injector, cyl. 2
0x01340098 152 Activation, fuel injector, cyl. 3
0x01340099 153 Activation, fuel injector, cyl. 4
0x0134009A 154 Activation, fuel injector, cyl. 5
0x0134009B 155 Activation, fuel injector, cyl. 6
0x0134009C 156 Activation, fuel injector, cyl. 7
0x0134009D 157 Activation, fuel injector, cyl. 8
0x0134009E 158 Activation, fuel injector, cyl. 9
0x0134009F 159 Activation, fuel injector, cyl. 10
0x013400A0 160 Activation, fuel injector, cyl. 11
0x013400A1 161 Activation, fuel injector, cyl. 12
0x013400A3 163 Activation, electric fuel pump, EKP relay
0x013400A7 167 Activation, electric fuel pump, EKP relay
0x013400A8 168 Activation, idle-speed control valve, opening coil
0x013400A9 169 Activation, idle-speed control valve, closing coil
0x013400AA 170 A/C-compressor control
0x013400B3 179 A/C-compressor control, bank 2
0x013400B7 183 Tank-leak detection
0x013400B8 184 Tank-venting system, blocked line
0x013400BE 190 Ignition-circuit monitoring, cylinder 1
0x013400BF 191 Ignition-circuit monitoring, cylinder 2
0x013400C0 192 Ignition-circuit monitoring, cylinder 3
0x013400C1 193 Ignition-circuit monitoring, cylinder 4
0x013400C2 194 Ignition-circuit monitoring, cylinder 5
0x013400C3 195 Ignition-circuit monitoring, cylinder 6
0x013400C4 196 Ignition-circuit monitoring, cylinder 7
0x013400C5 197 Ignition-circuit monitoring, cylinder 8
0x013400C6 198 Ignition-circuit monitoring, cylinder 9
0x013400C7 199 Ignition-circuit monitoring, cylinder 10
0x013400C8 200 Ignition-circuit monitoring, cylinder 11
0x013400C9 201 Ignition-circuit monitoring, cylinder 12
0x013400CB 203 Ignition-circuit monitoring, bank 1
0x013400CC 204 EWS 3.3 random-code storge
0x013400D2 210 Signal, knock sensor 1
0x013400D3 211 Signal, knock sensor 2
0x013400D6 214 Control modules with different CAN versions at CAN bus
0x013400D7 215 CAN timeout, Digital Motor Electronics (DME)
0x013400D8 216 CAN timeout ASC/DSC
0x013400D9 217 CAN timeout, electronic engine-power control EML
0x013400DC 220 Knock control
0x013400DE 222 Knock-control test pulse
0x013400E1 225 Control module ECAT, temperature sensor
0x013400E2 226 Ctr. module ECAT, voltage, circuit-breaker
0x013400E3 227 Activation, battery disconnecting switch
0x013400E4 228 Automatic starting, activation, bank 2
0x013400E9 233 Activation, automatic starting device
0x013400EA 234 Start signal, ignition-lock position 3
0x013400EC 236 CAN timeout, electronic transmission management (EGS/AGS)
0x013400ED 237 Function, automatic starting device
0x013400FA 250 Function, air-contained fuel injectors
0x013400FD 253 Activation, electric fan
//*DME 5.2.1 M62*/
//*DME M5.2.1 M73*/
0x01360001 1 Activation, solenoid valve, leakage diagnosis pump
0x01360002 2 Activation, solenoid valve, fuel system changeover
0x01360003 3 Function, tank leakage diagnosis pump
0x01360004 4 Oxygen-sensor heater after catalytic converter, bank 2
0x01360005 5 Oxygen-sensor heater before catalytic converter, bank 2
0x01360006 6 CAN instrument cluster
0x01360008 8 Misfiring was caused by tank having been run dry
0x0136000A 10 Signal, oxygen sensor before cat., bank 1
0x0136000C 12 Signal, oxygen sensor after cat. conv., bank 1
0x0136000D 13 oxygen-sensor heater before catalytic converter, bank 1
0x0136000E 14 oxygen-sensor heater after catalytic converter, bank 1
0x0136000F 15 Oxygen-sensor ageing TP before catalytic converter, bnak 1
0x01360010 16 Oxygen-sensor ageing TV before catalytic converter, bnak 1
0x01360011 17 Oxygen-sensor ageing after catalytic converter, bnak 1
0x01360012 18 Oxygen-sensor ageing before catalytic xonverter, bank 2
0x01360014 20 Oxygen sensor after catalytic converter, bank 2
0x01360015 21 Oxygen-sensor ageing TP before catalytic converter, bank 2
0x01360016 22 Oxygen-sensor ageing TP before catalytic converter, bank 2
0x01360017 23 Oxygen-sensor ageing after catalytic converter, bank 2
0x01360018 24 Function, diagnosis, A/C compressor
0x0136001A 26 Multiplicative mixture adaptation
0x0136001B 27 Additive mixture adaptation (idle), bank 1, control limit reached
0x0136001C 28 Additive mixture afaptation (idle), bnak 1, control limit reached
0x0136001D 29 Activation, switching valve for aircontained fuel injectors, bank 1
0x01360020 32 Function, idle-speed control
0x01360022 34 Multiplicative mixture adaptation
0x01360023 35 Additive mixture adaptation (idle), bank 2, control limit reached
0x01360024 36 Additive mixture adaptation (idle), bank 2, control limit reached
0x01360027 39 EWS 3.3 tampering protection
0x01360028 40 Catalytic-converter conversion, bank 1
0x0136002D 45 Catalytic-converter conversion, bank 2
0x01360032 50 Misfire detection, cyl. 1
0x01360033 51 Misfire detection, cyl. 2
0x01360034 52 Misfire detection, cyl. 3
0x01360035 53 Misfire detection, cyl. 4
0x01360036 54 Misfire detection, cyl. 5
0x01360037 55 Misfire detection, cyl. 6
0x01360038 56 Misfire detection, cyl. 7
0x01360039 57 Misfire detection, cyl. 8
0x0136003A 58 Misfire detection, cyl. 9
0x0136003B 59 Misfire detection, cyl. 10
0x0136003C 60 Misfire detection, cyl. 11
0x0136003D 61 Misfire detection, cyl. 12
0x0136003E 62 Misfiring at several cylinders
0x0136003F 63 Misfiring with cylinder cutout, cyl. 1
0x01360040 64 Misfiring with cylinder cutout, cyl. 2
0x01360041 65 Misfiring with cylinder cutout, cyl. 3
0x01360042 66 Misfiring with cylinder cutout, cyl. 4
0x01360043 67 Misfiring with cylinder cutout, cyl. 5
0x01360044 68 Misfiring with cylinder cutout, cyl. 6
0x01360045 69 Misfiring with cylinder cutout, cyl. 7
0x01360046 70 Misfiring with cylinder cutout, cyl. 8
0x01360047 71 Misfiring with cylinder cutout, cyl. 9
0x01360048 72 Misfiring with cylinder cutout, cyl. 10
0x01360049 73 Misfiring with cylinder cutout, cyl. 11
0x0136004A 74 Misfiring with cylinder cutout, cyl. 12
0x0136004B 75 Misfiring with cylinder cutout, total
0x0136004D 77 Activation, air containment, fuel injectors, bank 1
0x0136004E 78 Signal, crankshaft speed sensor
0x01360050 80 Function, secondary-air system
0x01360054 84 Activative, relay, secondary-air pump
0x01360055 85 Activation, relay, secondary-air pump
0x0136005B 91 Activation, tank-venting valve, bank 2
0x0136005D 93 Function, tank-venting system
0x01360061 97 Tank-venting system, minor leak
0x01360062 98 Activation, tank-venting valve, bank 1
0x01360065 101 Control module faulty (internal RAM)
0x01360066 102 Control module faulty (external RAM)
0x01360067 103 Control module faulty (ROM)
0x01360068 104 Wrong values in fault memory
0x0136006B 107 Voltage supply (via DME main relay)
0x0136006C 108 Open circuit, continuous
0x0136006F 111 Signal, crankshaft position sensor
0x01360070 112 Signal, camshaft position sensor
0x01360073 115 Signal, bot-film air-mass flow sensor
0x01360075 117 Signal, throttle potentiometer
0x01360078 120 Signal, vehicle speed
0x01360079 121 Load measurement
0x0136007B 123 Signal, temperature sensor, engine coolant
0x0136007C 124 Signal, tempersture sensor, intake air
0x01360082 130 Oxygen sensors before catalytic converter connected in incorrect sequence
0x01360086 134 Switch, tank fill level
0x01360087 135 Engine intervention/specified engine torque (gearbox intervention)
0x0136008A 138 Compressor intervention
0x0136008B 139 Activation, map cooling
0x0136008C 140 Engine torque, bank comparison
0x0136008D 141 Dynamic Stability Control DSC intervention with fadeout
0x0136008F 143 Function, ASC/DSC MSR - engine intervention
0x01360090 144 Automatic Stability Control ASC - intervention
0x01360093 147 Function, map cooling
0x01360094 148 EWS 3.3 interface DME-EWS
0x01360096 150 Activation, fuel injector, cyl. 1
0x01360097 151 Activation, fuel injector, cyl. 2
0x01360098 152 Activation, fuel injector, cyl. 3
0x01360099 153 Activation, fuel injector, cyl. 4
0x0136009A 154 Activation, fuel injector, cyl. 5
0x0136009B 155 Activation, fuel injector, cyl. 6
0x0136009C 156 Activation, fuel injector, cyl. 7
0x0136009D 157 Activation, fuel injector, cyl. 8
0x0136009E 158 Activation, fuel injector, cyl. 9
0x0136009F 159 Activation, fuel injector, cyl. 10
0x013600A0 160 Activation, fuel injector, cyl. 11
0x013600A1 161 Activation, fuel injector, cyl. 12
0x013600A3 163 Activation, electric fuel pump, EKP relay
0x013600A7 167 Activation, electric fuel pump, EKP relay
0x013600A8 168 Activation, idle-speed control valve, opening coil
0x013600A9 169 Activation, idle-speed control valve, closing coil
0x013600AA 170 A/C-compressor control
0x013600AE 179 A/C-compressor control, bank 2
0x013600B7 183 Tank-leak detection
0x013600B8 184 Tank-venting system, blocked line
0x013600BE 190 Ignition-circuit monitoring, cylinder 1
0x013600BF 191 Ignition-circuit monitoring, cylinder 2
0x013600C0 192 Ignition-circuit monitoring, cylinder 3
0x013600C1 193 Ignition-circuit monitoring, cylinder 4
0x013600C2 194 Ignition-circuit monitoring, cylinder 5
0x013600C3 195 Ignition-circuit monitoring, cylinder 6
0x013600C4 196 Ignition-circuit monitoring, cylinder 7
0x013600C5 197 Ignition-circuit monitoring, cylinder 8
0x013600C6 198 Ignition-circuit monitoring, cylinder 9
0x013600C7 199 Ignition-circuit monitoring, cylinder 10
0x013600C8 200 Ignition-circuit monitoring, cylinder 11
0x013600C9 201 Ignition-circuit monitoring, cylinder 12
0x013600CB 203 Ignition-circuit monitoring, bank 1
0x013600CC 204 EWS 3.3 random-code storage
0x013600D2 210 Signal, knock sensor 1
0x013600D3 211 Signal, knock sensor 2
0x013600D4 212 Knock sensor 3
0x013600D5 213 Knock sensor 4
0x013600D6 214 Control modules with different CAN versions at CAN bus
0x013600D7 215 CAN timeout, Digital Motor Electronics (DME)
0x013600D8 216 CAN timeout ASC/DSC
0x013600D9 217 CAN timeout, electronic engine-power control EML
0x013600DC 220 Knock control
0x013600DE 222 Knock-control test pulse
0x013600E4 228 Automatic, fuel injector, activation, bank 2
0x013600E9 233 Activation, automatic starting devive
0x013600EA 234 Start signal, ignition-lock position 3
0x013600EC 236 CAN timeout, electronic transmission management (EGA/AGS)
0x013600ED 237 Function, automatic starting device
0x013600FA 250 Function,air-contained fuel injectors
0x01370001 1 Activation, leakage diagnosis pump LDP
0x01370002 2 Activation, Solenoid valve, fuel system changeover
0x01370003 3 Function, tank leakage diagnosis pump
0x01370006 6 CAN instrument cluster
0x01370007 7 Temperature sensor, coolant outlet
0x01370008 8 Misfiring was caused by tank having been run dry
0x0137000A 10 Signal, oxygen sensor before cat. conv., bank 1
0x0137000B 12 Signal, oxygen sensor after cat. conv., bank 1
0x0137000D 13 Oxygen-sensor heater before catalytic converter, bank 1
0x0137000E 14 Oxygen-sensor heater after catalytic converter, bank 1
0x0137000F 15 Oxygen-sensor ageing TP before catalytic converter, bank 1
0x01370010 16 Oxygen-sensor ageing TV before catalytic converter, bank 1
0x01370011 17 Oxygen-sensor ageing after catalytic converter, bank 1
0x01370013 19 CAN timout ECAT
0x01370017 23 Oxygen-sensor ageing after catalytic converter, bank 2
0x0137001A 26 Multiplicative mixture adaptation (part load), bank 1, control limit reached
0x0137001B 27 Additive mixture adaptation (idle), bank 1, control limit reached
0x0137001C 28 Additive mixture adaptation (idle), bank 1, control limit reached
0x0137001D 29 Activation, switching valve for air-contained fuel injectors, bank 1
0x0137001E 30 Abort heating ECAT
0x01370020 32 Function, idle-speed control
0x01370021 33 Control unit, electr. heated cat. converter
0x01370027 39 EWS 3.3 tampering protection
0x01370028 40 Catalytic-converter conversion, bank 1
0x0137002A 42 Abort heating ECAT 1
0x0137002B 43 Abort heating ECAT 1
0x0137002C 44 Control module ECAT, circuit-breaker 1
0x0137002E 46 Abort heating ECAT 2
0x0137002F 47 Abort heating ECAT 2
0x01370030 48 Control module ECAT, circuit-breaker 2
0x01370032 50 Misfire detection, cyl. 1
0x01370033 51 Misfire detection, cyl. 2
0x01370034 52 Misfire detection, cyl. 3
0x01370035 53 Misfire detection, cyl. 4
0x01370036 54 Misfire detection, cyl. 5
0x01370037 55 Misfire detection, cyl. 6
0x01370038 56 Misfire detection, cyl. 7
0x01370039 57 Misfire detection, cyl. 8
0x0137003A 58 Misfire detection, cyl. 9
0x0137003B 59 Misfire detection, cyl. 10
0x0137003C 60 Misfire detection, cyl. 11
0x0137003D 61 Misfire detection, cyl. 12
0x0137003E 62 Misfiring at several cylinders
0x0137003F 63 Misfiring with cylinder cutout, cyl. 1
0x01370040 64 Misfiring with cylinder cutout, cyl. 2
0x01370041 65 Misfiring with cylinder cutout, cyl. 3
0x01370042 66 Misfiring with cylinder cutout, cyl. 4
0x01370043 67 Misfiring with cylinder cutout, cyl. 5
0x01370044 68 Misfiring with cylinder cutout, cyl. 6
0x01370045 69 Misfiring with cylinder cutout, cyl. 7
0x01370046 70 Misfiring with cylinder cutout, cyl. 8
0x01370047 71 Misfiring with cylinder cutout, cyl. 9
0x01370048 72 Misfiring with cylinder cutout, cyl. 10
0x01370049 73 Misfiring with cylinder cutout, cyl. 11
0x0137004A 74 Misfiring with cylinder cutout, cyl. 12
0x0137004B 75 Misfiring with cylinder cutout, tatal
0x0137004D 77 Activation, air containment, fuel injectors, bank 1
0x0137004E 78 Signal, crankshaft speed sensor
0x01370050 80 Function, secondary-air system
0x01370051 81 Temperature sensor 1, battery
0x01370052 82 Temperature sensor 2, battery
0x01370053 83 Temperature sensor, battery, not plausible
0x01370054 84 Activation, relay, secondary-air pump
0x01370055 85 Activation, relay, secondary-air pump
0x0137005B 91 Activation, tank-venting valve, bank 2
0x0137005D 93 Function, tank-venting system
0x01370062 98 Activation, tank-venting valve, bank 1
0x01370065 101 Control module faulty (internal RAM)
0x01370066 102 Control module faulty (external RAM)
0x01370067 103 Control module faulty (ROM)
0x01370068 104 Wrong values in fault memory
0x0137006B 107 Voltage supply (via DME main relay)
0x0137006C 108 Open circuit, continuous power supply
0x0137006F 111 Signal, crankshaft position sensor
0x01370070 112 Signal, camshaft position sensor
0x01370073 115 Signal, hot-film air-mass flow sensor
0x01370078 120 Signal, vehicle speed
0x01370079 121 Load measurement
0x0137007B 123 Signal, temperature sensor, engine coolant
0x0137007C 124 Signal, temperature sensor, intake air
0x01370082 130 Oxygen sensors before catalytic converter connected in incorrect sequence
0x01370086 134 Switch, tank fill level
0x01370087 135 Engine intervention / specified engine torque (gearbox intervention)
0x0137008A 138 Compressor intervention
0x0137008B 139 Activation, map cooling
0x0137008C 140 Engine torque, bank comparission
0x0137008D 141 Dynamix Stability Control DSC intervention with fadeout
0x0137008F 143 Function, ASC/DSC MSR - engine intervention
0x01370090 144 Automatic Stability Control ASC - intrvention
0x01370093 147 Function, map cooling
0x01370094 148 EWS 3.3 interface DME-EWS
0x01370095 149 Inlet-camshaft setting bank 2
0x01370096 150 Activation, fuel injector, cyl. 1
0x01370097 151 Activation, fuel injector, cyl. 2
0x01370098 152 Activation, fuel injector, cyl. 3
0x01370099 153 Activation, fuel injector, cyl. 4
0x0137009A 154 Activation, fuel injector, cyl. 5
0x0137009B 155 Activation, fuel injector, cyl. 6
0x0137009C 156 Activation, fuel injector, cyl. 7
0x0137009D 157 Activation, fuel injector, cyl. 8
0x0137009E 158 Activation, fuel injector, cyl. 9
0x0137009F 159 Activation, fuel injector, cyl. 10
0x013700A0 160 Activation, fuel injector, cyl. 11
0x013700A1 161 Activation, fuel injector, cyl. 12
0x013700A3 163 Activation, electric fuel pump, EKP relay
0x013700A7 167 Activation, electric fuel pump, EKP relay
0x013700A8 168 Activation, idle-speed control valve, opening coil
0x013700A9 169 Activation, idle-speed control valve, closing coil
0x013700AA 170 A/C-compressor control
0x013700B3 179 A/C-compressor control, bank 2
0x013700B7 183 Tank-leak detection
0x013700B8 184 Tank-venting system, blocked line
0x013700BE 190 Ignition-circuit monitoring, cylinder 1
0x013700BF 191 Ignition-circuit monitoring, cylinder 2
0x013700C0 192 Ignition-circuit monitoring, cylinder 3
0x013700C1 193 Ignition-circuit monitoring, cylinder 4
0x013700C2 194 Ignition-circuit monitoring, cylinder 5
0x013700C3 195 Ignition-circuit monitoring, cylinder 6
0x013700C4 196 Ignition-circuit monitoring, cylinder 7
0x013700C5 197 Ignition-circuit monitoring, cylinder 8
0x013700C6 198 Ignition-circuit monitoring, cylinder 9
0x013700C7 199 Ignition-circuit monitoring, cylinder 10
0x013700C8 200 Ignition-circuit monitoring, cylinder 11
0x013700C9 201 Ignition-circuit monitoring, cylinder 12
0x013700CB 203 Ignition-circuit monitoring, bank 1
0x013700CC 204 EWS 3.3 random-code storge
0x013700D2 210 Signal, knock sensor 1
0x013700D3 211 Signal, knock sensor 2
0x013700D6 214 Control modules with different CAN versions at CAN bus
0x013700D7 215 CAN timeout, Digital Motor Electronics (DME)
0x013700D8 216 CAN timeout ASC/DSC
0x013700D9 217 CAN timeout, electronic engine-power control EML
0x013700DC 220 Knock control
0x013700DE 222 Knock-control test pulse
0x013700E1 225 Control module ECAT, temperature sensor
0x013700E2 226 Ctr. module ECAT, voltage, circuit-breaker
0x013700E3 227 Activation, battery disconnecting switch
0x013700E4 228 Automatic starting, activation, bank 2
0x013700E9 233 Activation, automatic starting device
0x013700EA 234 Start signal, ignition-lock position 3
0x013700EC 236 CAN timeout, electronic transmission management (EGS/AGS)
0x013700ED 237 Function, automatic starting device
0x013700FA 250 Function, air-contained fuel injectors
0x013700FD 253 Activation, electric fan
//*DME 7.2 M62TU*/
0x01410001 001 Activation, leak diagnosis pump
0x01410002 002 DMTL output stage, solenoid valve
0x01410003 003 Oxygen sensors before catalytic converter mixed up
0x01410004 004 Oxygen-sensor heater after cat. conv., bank 2
0x01410005 005 Oxygen-sensor heater before cat. conv., bank 2
0x0141000A 010 Signal, oxygen sensor before cat. conv., bank 1
0x0141000C 012 Signal, oxygen sensor after cat. conv., bank 1
0x0141000D 013 Oxygen-sensor heater before cat. conv., bank 1
0x0141000E 014 Oxygen-senosr heater after cat. conv., bank 1
0x0141000F 015 Oxygen-sensor ageing before cat. conv., bank 1 (TP)
0x01410010 016 Oxygen-sensor ageing before cat. conv., bank 1 (TV)
0x01410011 017 Oxygen-sensor ageing before cat. conv., bank 1
0x01410012 018 Signal, oxygen sensor before cat. conv., bank 2
0x01410014 020 Signal, oxygen sensor after cat. conv., bank 2
0x01410015 021 Oxygen-sensor ageing before cat. conv., bank 2 (TP)
0x01410016 022 Oxygen-sensor ageing before cat. conv., bank 2 (TV)
0x01410017 023 Oxygen-sensor ageing after cat. conv., bank 2
0x01410018 024 Multiplication. Mixture adaptation, bank 1, control limit reached
0x01410019 025 Multiplication. Mixture adaptation, bank 2, control limit reached
0x0141001A 026 Multiplication. Mixture adaptation, bank 1, control limit reached
0x0141001B 027 Multiplication. Mixture adaptation, bank 2, control limit reached
0x0141001C 028 Additive mixture adaptation, bank 1, control limit reached
0x0141001D 029 Additive mixture adaptation, bank 2, control limit reached
0x0141001E 030 Fast add. Mixture adaptation, bank 1, control limit reached
0x0141001F 031 Fast add. Mixture adaptation, bank 2, control limit reached
0x01410020 032 Function, idle-speed control
0x01410021 033 Function, inlet-camshaft control, bank 1
0x01410022 034 Function, inlet-camshaft control, bank 2
0x01410027 039 EWS 3.3 Anti-tampering protection
0x01410028 040 Catalytic-converter conversion, bank 1
0x0141002D 045 Catalytic-converter conversion, bank 2
0x01410032 050 Misfire detection, cyl. 1
0x01410033 051 Misfire detection, cyl. 5
0x01410034 052 Misfire detection, cyl. 4
0x01410035 053 Misfire detection, cyl. 8
0x01410036 054 Misfire detection, cyl. 6
0x01410037 055 Misfire detection, cyl. 3
0x01410038 056 Misfire detection, cyl. 7
0x01410039 057 Misfire detection, cyl. 2
0x0141003E 062 Misfiring at several cylinders
0x01410050 080 Function, secondary-air system, bank 1
0x01410051 081 Function, secondary-air system, bank 2
0x01410052 082 Function, secondary-air valve
0x01410054 084 Activation, relay, secondary-air pump
0x01410055 085 Activation, secondary-air valve
0x0141005D 093 Function, tank-venting system
0x01410062 098 Activation, tank-venting valve
0x01410065 101 Torque monitoring, level 2
0x01410066 102 Signal, multifunction steering wheel
0x01410067 103 Function, monitoring, control unit
0x01410068 104 Signal, switch clutch
0x01410069 105 Control unit faulty (RAM)
0x0141006A 106 Signal, switch brake
0x0141006B 107 Control unit faulty (ROM)
0x0141006C 108 Reset DME / voltage supply
0x0141006D 109 Battery positive voltage
0x0141006E 110 Torque monitoring, level 1
0x0141006F 111 Signal, crankshaft speed sensor
0x01410070 112 Signal, crankshaft speed sensor
0x01410071 113 Signal, camshaft position sensor, bank 1
0x01410072 114 Signal, camshaft position sensor, bank 2
0x01410073 115 Signal, hot-film air-mass flow sensor
0x01410075 117 Signal, throttle potentiometer
0x01410076 118 Signal, throttle potentiometer 1
0x01410077 119 Signal, throttle potentiometer 2
0x01410078 120 Signal, vehicle speed
0x01410079 121 CAN signal, wheel speeds
0x0141007A 122 Ambient temperature
0x0141007B 123 Signal, temperature sensor engine coolant
0x0141007C 124 Signal, temperature sensor, intake air
0x0141007D 125 Signal, temperature sensor, radiator outlet
0x0141007F 127 TxU plausibility
0x01410082 130 Function, throttle actuator
0x01410083 131 Function, throttle actuator jammed
0x01410084 132 Activation, throttle actuator
0x01410085 133 Spring check, throttle actuator
0x01410086 134 Learning function, lower stop, throttle actuator
0x01410087 135 Throttle potentiometer, booster adjustment
0x01410088 136 Function check, throttle emergency operation point
0x0141008B 139 Thermostat jammed
0x0141008C 140 Activation map cooling
0x0141008D 141 Activation, electric fan
0x0141008E 142 Activation, exhaust flap
0x01410094 148 EWS 3.3 interface DME-EWS
0x01410096 150 Activation, fuel injector, cyl. 1
0x01410097 151 Activation, fuel injector, cyl. 5
0x01410098 152 Activation, fuel injector, cyl. 4
0x01410099 153 Activation, fuel injector, cyl. 8
0x0141009A 154 Activation, fuel injector, cyl. 6
0x0141009B 155 Activation, fuel injector, cyl. 3
0x0141009C 156 Activation, fuel injector, cyl. 7
0x0141009D 157 Activation, fuel injector, cyl. 2
0x014100A3 163 Diagnosis, throttle-air-mass flow sensor adjustment
0x014100A4 164 Signal, ambient-pressure sensor
0x014100A5 165 Activation, inlet VANOS, bank 1
0x014100A6 166 Activation, inlet VANOS, bank 2
0x014100A7 167 Activation, electric fuel pump, EKP relay
0x014100A8 168 Activation, fault lamp MIL
0x014100AA 170 A/C-compressor control
0x014100B6 182 Function, tank-leakage detection: minor leak
0x014100B7 183 Function, tank-leakage detection
0x014100B8 184 Function, tank-leak detection, blocked line
0x014100B9 185 Function, leakage diagnosis pump
0x014100BA 186 Activation, pump motor DMTL
0x014100BB 187 DMTL minimal leak (0.5mm)
0x014100BC 188 DMTL minor leak (1.0mm)
0x014100BD 189 DMTL module
0x014100C9 201 DMTL heating
0x014100CC 204 EWS 3.3 random-code storage
0x014100D2 210 Signal, knock sensor 1
0x014100D3 211 Signal, knock sensor 2
0x014100D4 212 Signal, knock sensor 3
0x014100D5 213 Signal, knock sensor 4
0x014100D6 214 Function, knock control, zero test
0x014100D7 215 Function, knock control, offset
0x014100D8 216 Function, knock control, test pulse
0x014100DB 219 CAN timeout TCU
0x014100DC 220 CAN timeout, electronic transmission management (EGS/AGS)
0x014100DD 221 CAN timeout ASC/DSC
0x014100DE 222 CAN timeout, instrument cluster
0x014100DF 223 CAN timeout ACC
0x014100E0 224 Function, plausibility, MSR intervention
0x014100E1 225 Function, plausibility, ACC intervention
0x014100E2 226 Plausibility, tank fill level
0x014100E5 229 Comparison, supplies, pedal-travel sensor
0x014100E6 230 Signal, pedal-travel sensor
0x014100E7 231 Signal, pedal-travel sensor, potentiometer 1
0x014100E8 232 Signal, pedal-travel sensor, potentiometer 2
0x014100E9 233 Activation, automatic starting
0x014100EA 234 Signal, ignition lock, position 3 (terminal 50)
0x014100EC 236 Activation, intake flap
0x014100ED 237 Function, automatic starti
Коды ошибок АКПП.
/EGS 1.XX 4HP-22/4HP gearbox
0X02010001 1 transmission relay
0x02010002 2 EPROM checksum
0x02010003 3 Kickdown switch
0x02010004 4 Program switch
0x02010005 5 throttle signal, accelerator pedal
0x02010006 6 solenoid valve MV 1
0x02010007 7 solenoid valve MV 2
0x02010008 8 MV1,MV2
0x02010009 9 P/N shift-Lock, solenoid valve R-Lock
0x0201000a 10 MV1,P/N shift-Lock, solenoid valve R-Lock]
0x0201000b 11 MV2,P/N shift-Lock, solenoid valve R-Lock
0x0201000c 12 MV1 2,P/N shift-Lock, solenoid valve R-Lock
0x0201000d 13 MV torque converter clutch
0x0201000e 14 MV 1,MV-WK
0x0201000f 15 MV 2,MV-WK
0x02010010 16 MV 1,MV 2,MV-WK
0x02010011 17 MV-WK,P/N shift-lock solenoid valve R-lock
0x02010012 18 MV 1,P/N shift-lock solenoid R-lock MV-WK
0x02010013 19 MV 2,P/N shift-lock solenoid R-lock MV-WK
0x02010014 20 voltage supply,MV and DR
0x02010015 21 Speed Signal,n-mot(TR)
0x02010016 22 pressure regulator
0x02010017 23 ignition timing intervention
0x02010018 24 speed sensor n-ab,downshift protection
0x02010019 25 overrun protection
0x0201001a 26 injection signal
0x0201001b 27 DZF,torque converter
0x0201001c 28 fault display
0x0201001d 29 checksum,program
0x0201001e 30 battery voltage
0x0201001f 31 selector lever pos.
0x020100c8 200 no kickdown shifts
0x020100c9 201 only kickdown shifts
0x020100ca 202 no s-program
0x020100cb 203 no M-program
0x020100cc 204 no program switchover
0x020100cd 205 no engine intervention
0x020100ce 206 incorrect fault display
0x020100cf 207 only full load shifts(without EML)
//EGS 2.XX 4HP-24
0X02020001 1 voltage supply
0x02020002 2 transmission output speed sensor
0x02020003 3 engine speed signal
0x02020005 5 solenoid valve 1
0x02020006 6 pressure regulator
0x0202000d 13 P/N shift-lock
0x0202000e 14 Selector pos. L2
0x02020013 19 Volt. supply,MV/EDS
0x02020015 21 injector,pulse width signal
0x02020018 24 solenoid valve 2
0x0202002d 29 selector pos. L3 L4
0x02020020 32 engine intervention
0x02020027 39 voltage supply
0x02020029 41 kickdown switch
0x0202002a 42 clutch lockup valve,torque converter
0x0202002b 43 program switch
0x0202003f 47 Throttle pedal position signal
0x02020032 50 selector pos L1
0x02020064 100 control unit internal fault
0x02020065 101 program checksum
0x02020066 102 volt. supply relay
0x02020068 104 transmission speed monitoring
0x02020067 105 wheel slip speed monitoring
//EGS 7.XX A5S 310Z (5HP-18)
0x02030002 2 P/N shift-lock
0x02030003 3 solenoid valve 5
0x02030004 4 torque converter clutch solenoid valve
0x02030005 5 pressure regulator
0x02030008 8 selector pos. L2
0x02030009 9 selector pos L3 L4
0x0203000c 12 program button
0x02030010 16 stall monitoring
0x02030012 18 kickdown switch
0x02030016 22 oil temp.sensor
0x0203001a 26 battery voltage
0x0203001e 30 solenoid valve 1
0x0203001f 31 solenoid valve 4
0x02030020 32 solenoid valve 3
0x02030021 33 solenoid valve 2
0x02030023 35 throttle signal(DKT)
0x02030024 36 selector pos. L1
0x02030028 40 engine intervention
0x02030029 41 KVA signal
0x0203002a 42 speed signal n-ab
0x0203002b 43 speed signal n-mod
0x02030035 53 voltage supply MV
0x02030036 54 voltage supply
0x02030064 100 gear monitoring
0x02030065 101 eprom checksum
0x02030066 102 program checksum
0x02030067 103 transmission relay
0x02030068 104 temp. information (DKT-signal)
0x02030069 105 load information(DKT-signal)
0x020300c8 200 no kickdown shifts
0x020300c9 201 no S-program
0x020300ca 202 no *-program
0x020300cb 203 no program switchover
0x020300cc 204 no engine intervention
0x020300cd 205 defective brake-light switch
0x020300ce 206 incorrect fault display
//EGS 9.XX 5HP-30 (A5S 560Z)
0x02040001 1 pressure regulator,EDS 2
0x02040002 2 P/N shift-lock
0x02040004 4 pressure regulator,EDS 4
0x02040005 5 pressure regulator,EDS 1
0x02040008 8 selector pos. L2
0x02040009 9 selector pos. L3 L4
0x0204000c 12 program button
0x02040010 16 turbo-charger rotational speed sensor
0x02040012 18 kickdown switch
0x02040013 19 ASC monitoring
0x02040016 22 ATF temp. sensor
0x0204001a 26 battery voltage
0x0204001d 29 pressure regulator,EDS 3
0x0204001e 30 solenoid valve 1
0x0204001f 31 solenoid valve 4
0x02040020 32 solenoid valve 3
0x02040021 33 solenoid valve 2
0x02040023 35 throttle signal(DKT)
0x02040024 36 selector pos L1
0x02040028 40 engine intervention
0x02040029 41 KVA signal
0x0204002a 42 speed signal n-ab
0x0204002b 43 speed signal n-mot
0x02040035 53 voltage supply MV
0x02040064 100 speed monitoring
0x02040065 101 eprom checksum
0x02040066 102 program checksum
0x02040067 103 transmission relay
0x02040068 104 temp. information(DKT-signal)
0x02040069 105 load information (DKT-signal)
0x0204006a 106 speed monitoring
