Вот вам пример кита на м52
Rotrex C38-81 trim supercharger
CNC machined supercharger bracket with hardware
Self-contained oil system with front-mount oil cooler
6 higher flow fuel Injectors
Bosch bypass valve
High temperature silicone hoses with stainless clamps
All mandrel bent tubing for improved flow
Air Filter (Some Models may use K&N)
Tuned Software
All mounting hardware, plumbing, hoses and clamps
или на лисхольме, который например еще и сжимает воздух, в отличии от обычного червячного
-Spec Lysholm 1.6L Twin Screw supercharger unit. -High strength, dual-layer cast aluminum alloy new intake manifold. -Uni-belt SC drive system with additional OEM quality idler pulleys. -6 larger Bosch fuel injectors. -Throttle body style butterfly bypass system for superior fuel economy during cruising and optimal throttle response under all conditions. -Perfectly optimized, dyno tweaked MS42 ECU software. -CNC hard anodized brackets and hardware. -Cast aluminium SC intake system with crankcase fume reduction system designed for boost. -High temperature, custom made silicone hoses with clamps throughout the system. -Detailed, step-by-step installation manual -Heavy-Duty drive belt. -All required installation hardware included
-HEXflash tool
